[mapguide-commits] r4205 - in trunk/Tools/Maestro: Installer Maestro Maestro/FusionEditor Maestro/Globalizator Maestro/MaestroEditorInterface Maestro/ResourceBrowser/Properties Maestro/ResourceEditors Maestro/ResourceValidators MaestroAPI MaestroAPI/PackageBuilder/Properties MaestroAPI/XsdGenerator new w generics/Properties MgCooker/MgCookerCommandline/Properties MgCooker/Properties
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sun Aug 30 12:18:06 EDT 2009
Author: ksgeograf
Date: 2009-08-30 12:18:06 -0400 (Sun, 30 Aug 2009)
New Revision: 4205
   trunk/Tools/Maestro/Installer/UpgradeData.wxi
   trunk/Tools/Maestro/Installer/incBinFiles.wxs
   trunk/Tools/Maestro/Installer/incLocFiles.da-DK.wxs
   trunk/Tools/Maestro/Installer/incLocFiles.es-ES.wxs
   trunk/Tools/Maestro/Maestro/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/Globalizator/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs
   trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs
   trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs
Maestro: Version bump and rebuild
Modified: trunk/Tools/Maestro/Installer/UpgradeData.wxi
--- trunk/Tools/Maestro/Installer/UpgradeData.wxi	2009-08-30 16:03:06 UTC (rev 4204)
+++ trunk/Tools/Maestro/Installer/UpgradeData.wxi	2009-08-30 16:18:06 UTC (rev 4205)
@@ -3,7 +3,7 @@
   <?define UpgradeCode="A7C2ECB3-1991-47B9-A22E-8844BB95CAE2" ?>
   <!-- Remember to change product version on each install -->
-  <?define ProductVersion="1.0.0.4177" ?>
+  <?define ProductVersion="1.0.0.4203" ?>
   <?define Manufacturer="HexaD" ?>
Modified: trunk/Tools/Maestro/Installer/incBinFiles.wxs
--- trunk/Tools/Maestro/Installer/incBinFiles.wxs	2009-08-30 16:03:06 UTC (rev 4204)
+++ trunk/Tools/Maestro/Installer/incBinFiles.wxs	2009-08-30 16:18:06 UTC (rev 4205)
@@ -3,7 +3,7 @@
   <!--<CommandLineOptions>
   <Producer>Autogenerated by Paraffin - Wintellect - John Robbins - john at wintellect.com</Producer>
   <WARNING>Manual changes to this file may cause incorrect behavior.</WARNING>
-  <CreatedOn>23-08-2009 14:32</CreatedOn>
+  <CreatedOn>30-08-2009 17:12</CreatedOn>
   <Directory>..\InstallerTempRelease\MapGuideMaestro\</Directory>
   <Custom>MAESTROBIN</Custom>
   <DirAlias>..\InstallerTempRelease\MapGuideMaestro\</DirAlias>
@@ -35,7 +35,7 @@
     </ComponentGroup>
     <DirectoryRef Id="INSTALLLOCATION">
       <Directory Id="dir_MapGuideMaestro_0" Name="MapGuideMaestro">
-        <Component Id="comp_MAESTROBIN_0" DiskId="1" KeyPath="yes" Guid="A7A4DBFD-3C59-415B-8D97-7C5EA7FE2F38">
+        <Component Id="comp_MAESTROBIN_0" DiskId="1" KeyPath="yes" Guid="7A60D065-74A8-4B28-9481-7849740C4E1C">
           <File Id="file_MAESTROBIN_0" Name="ColorBrewer.csv" Source="..\InstallerTempRelease\MapGuideMaestro\ColorBrewer.csv" />
           <File Id="file_MAESTROBIN_1" Name="EditorMap.xml" Source="..\InstallerTempRelease\MapGuideMaestro\EditorMap.xml" />
           <File Id="file_MAESTROBIN_2" Name="Globalizator.dll" Source="..\InstallerTempRelease\MapGuideMaestro\Globalizator.dll" />
@@ -59,7 +59,7 @@
           <File Id="file_MAESTROBIN_20" Name="Topology.IO.MapGuide.dll" Source="..\InstallerTempRelease\MapGuideMaestro\Topology.IO.MapGuide.dll" />
         </Component>
         <Directory Id="dir_MapGuideMaestro_Schemas_1" Name="Schemas">
-          <Component Id="comp_MAESTROBIN_21" DiskId="1" KeyPath="yes" Guid="68AD300B-602F-481A-8C03-0FA637B81751">
+          <Component Id="comp_MAESTROBIN_21" DiskId="1" KeyPath="yes" Guid="8E76F5F0-42C1-4C9A-972B-93E419CCD16C">
             <File Id="file_MAESTROBIN_21" Name="ApplicationDefinition-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ApplicationDefinition-1.0.0.xsd" />
             <File Id="file_MAESTROBIN_22" Name="ApplicationDefinitionInfo-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ApplicationDefinitionInfo-1.0.0.xsd" />
             <File Id="file_MAESTROBIN_23" Name="DataStoreList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\DataStoreList-1.0.0.xsd" />
@@ -110,7 +110,7 @@
           </Component>
         </Directory>
         <Directory Id="dir_MapGuideMaestro_stdicons_2" Name="stdicons">
-          <Component Id="comp_MAESTROBIN_68" DiskId="1" KeyPath="yes" Guid="B697054C-BE1A-45C2-B044-32D212F4AF4F">
+          <Component Id="comp_MAESTROBIN_68" DiskId="1" KeyPath="yes" Guid="3997B3DD-7C5D-4656-B879-99526467A9E6">
             <File Id="file_MAESTROBIN_68" Name="copyright.txt" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\copyright.txt" />
             <File Id="file_MAESTROBIN_69" Name="icon_back.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_back.gif" />
             <File Id="file_MAESTROBIN_70" Name="icon_back_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_back_disabled.gif" />
@@ -193,7 +193,7 @@
           </Component>
         </Directory>
         <Directory Id="dir_MapGuideMaestro_Templates_3" Name="Templates">
-          <Component Id="comp_MAESTROBIN_147" DiskId="1" KeyPath="yes" Guid="4789493C-6E77-42C6-A5F1-985D0C108ABC">
+          <Component Id="comp_MAESTROBIN_147" DiskId="1" KeyPath="yes" Guid="E29EA1FB-868C-4D7F-9D1B-DF36F0C42B57">
             <File Id="file_MAESTROBIN_147" Name="Dataconnection.FeatureSource" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Dataconnection.FeatureSource" />
             <File Id="file_MAESTROBIN_148" Name="Fusion Application.ApplicationDefinition" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Fusion Application.ApplicationDefinition" />
             <File Id="file_MAESTROBIN_149" Name="Layer.LayerDefinition" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Layer.LayerDefinition" />
@@ -205,11 +205,11 @@
           </Component>
         </Directory>
         <Directory Id="dir_MapGuideMaestro_WebStudio_4" Name="WebStudio">
-          <Component Id="comp_MAESTROBIN_155" DiskId="1" KeyPath="yes" Guid="AF093228-39D2-4537-8FD4-C3C18FE97C94">
+          <Component Id="comp_MAESTROBIN_155" DiskId="1" KeyPath="yes" Guid="A77EDA43-6785-4A68-8ACB-48BBD05FB8B4">
             <File Id="file_MAESTROBIN_155" Name="copyright.txt" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\copyright.txt" />
           </Component>
           <Directory Id="dir_MapGuideMaestro_WebStudio_areas_5" Name="areas">
-            <Component Id="comp_MAESTROBIN_156" DiskId="1" KeyPath="yes" Guid="2733053C-8731-428A-ABFF-D8D853203BD9">
+            <Component Id="comp_MAESTROBIN_156" DiskId="1" KeyPath="yes" Guid="2025A74F-8A6C-4DA9-86BF-FE1CA9653252">
               <File Id="file_MAESTROBIN_156" Name="Acad_iso02w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso02w100.png" />
               <File Id="file_MAESTROBIN_157" Name="Acad_iso03w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso03w100.png" />
               <File Id="file_MAESTROBIN_158" Name="Acad_iso04w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso04w100.png" />
@@ -349,7 +349,7 @@
             </Component>
           </Directory>
           <Directory Id="dir_MapGuideMaestro_WebStudio_lines_6" Name="lines">
-            <Component Id="comp_MAESTROBIN_292" DiskId="1" KeyPath="yes" Guid="9BAA899C-E997-4079-B82A-0F4DC1E3BB82">
+            <Component Id="comp_MAESTROBIN_292" DiskId="1" KeyPath="yes" Guid="C6FC11BA-A545-4CAE-B5C3-28A5FC736135">
               <File Id="file_MAESTROBIN_292" Name="ACAD_ISO02W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO02W100.png" />
               <File Id="file_MAESTROBIN_293" Name="ACAD_ISO03W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO03W100.png" />
               <File Id="file_MAESTROBIN_294" Name="ACAD_ISO04W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO04W100.png" />
@@ -423,7 +423,7 @@
             </Component>
           </Directory>
           <Directory Id="dir_MapGuideMaestro_WebStudio_points_7" Name="points">
-            <Component Id="comp_MAESTROBIN_362" DiskId="1" KeyPath="yes" Guid="BD971E11-66C4-4C8E-8096-922CFA66754B">
+            <Component Id="comp_MAESTROBIN_362" DiskId="1" KeyPath="yes" Guid="13A08AE9-5718-404F-AB46-F0BF1135CCB3">
               <File Id="file_MAESTROBIN_362" Name="circle.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\circle.png" />
               <File Id="file_MAESTROBIN_363" Name="cross.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\cross.png" />
               <File Id="file_MAESTROBIN_364" Name="square.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\square.png" />
Modified: trunk/Tools/Maestro/Installer/incLocFiles.da-DK.wxs
--- trunk/Tools/Maestro/Installer/incLocFiles.da-DK.wxs	2009-08-30 16:03:06 UTC (rev 4204)
+++ trunk/Tools/Maestro/Installer/incLocFiles.da-DK.wxs	2009-08-30 16:18:06 UTC (rev 4205)
@@ -3,7 +3,7 @@
   <Directory>..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\</Directory>
   <Custom>MAESTROBIN_da-DK</Custom>
   <DirAlias>..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\</DirAlias>
@@ -28,7 +28,7 @@
     </ComponentGroup>
     <DirectoryRef Id="LANGLOCATION">
       <Directory Id="dir_da_DK_0" Name="da-DK">
-        <Component Id="comp_MAESTROBIN_da_DK_0" DiskId="1" KeyPath="yes" Guid="95ADD95A-4252-4D29-A0D6-3D31ABEEDD2D">
+        <Component Id="comp_MAESTROBIN_da_DK_0" DiskId="1" KeyPath="yes" Guid="9A06F98D-CD5C-403A-81A6-5C7AD0BA61FA">
           <File Id="file_MAESTROBIN_da_DK_0" Name="FusionEditor.ApplicationDefinitionEditor.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\FusionEditor.ApplicationDefinitionEditor.da-DK.resx" />
           <File Id="file_MAESTROBIN_da_DK_1" Name="FusionEditor.EditWidgets.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\FusionEditor.EditWidgets.da-DK.resx" />
           <File Id="file_MAESTROBIN_da_DK_2" Name="FusionEditor.SelectTemplate.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\FusionEditor.SelectTemplate.da-DK.resx" />
Modified: trunk/Tools/Maestro/Installer/incLocFiles.es-ES.wxs
--- trunk/Tools/Maestro/Installer/incLocFiles.es-ES.wxs	2009-08-30 16:03:06 UTC (rev 4204)
+++ trunk/Tools/Maestro/Installer/incLocFiles.es-ES.wxs	2009-08-30 16:18:06 UTC (rev 4205)
@@ -3,7 +3,7 @@
   <Directory>..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\</Directory>
   <Custom>MAESTROBIN_es-ES</Custom>
   <DirAlias>..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\</DirAlias>
@@ -28,7 +28,7 @@
     </ComponentGroup>
       <Directory Id="dir_es_ES_0" Name="es-ES">
-        <Component Id="comp_MAESTROBIN_es_ES_0" DiskId="1" KeyPath="yes" Guid="3023B708-78E4-4CB2-BEEC-3DA20CCA0C20">
+        <Component Id="comp_MAESTROBIN_es_ES_0" DiskId="1" KeyPath="yes" Guid="99417B81-83BB-4E03-9080-BD95BD5ADFBB">
           <File Id="file_MAESTROBIN_es_ES_0" Name="FusionEditor.ApplicationDefinitionEditor.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\FusionEditor.ApplicationDefinitionEditor.es-ES.resx" />
           <File Id="file_MAESTROBIN_es_ES_1" Name="FusionEditor.EditWidgets.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\FusionEditor.EditWidgets.es-ES.resx" />
           <File Id="file_MAESTROBIN_es_ES_2" Name="FusionEditor.SelectTemplate.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\FusionEditor.SelectTemplate.es-ES.resx" />
Modified: trunk/Tools/Maestro/Maestro/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/AssemblyInfo.cs	2009-08-30 16:03:06 UTC (rev 4204)
+++ trunk/Tools/Maestro/Maestro/AssemblyInfo.cs	2009-08-30 16:18:06 UTC (rev 4205)
@@ -45,7 +45,7 @@
 // You can specify all the values or you can default the Revision and Build Numbers
 // by using the '*' as shown below:
-[assembly: AssemblyVersion("1.1.0.4177")]
+[assembly: AssemblyVersion("1.1.0.4203")]
 // In order to sign your assembly you must specify a key to use. Refer to the
@@ -75,4 +75,4 @@
 [assembly: AssemblyDelaySign(false)]
 [assembly: AssemblyKeyFile("")]
 [assembly: AssemblyKeyName("")]
-[assembly: AssemblyFileVersionAttribute("1.1.0.4177")]
+[assembly: AssemblyFileVersionAttribute("1.1.0.4203")]
Modified: trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs	2009-08-30 16:03:06 UTC (rev 4204)
+++ trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs	2009-08-30 16:18:06 UTC (rev 4205)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/Maestro/Globalizator/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/Globalizator/AssemblyInfo.cs	2009-08-30 16:03:06 UTC (rev 4204)
+++ trunk/Tools/Maestro/Maestro/Globalizator/AssemblyInfo.cs	2009-08-30 16:18:06 UTC (rev 4205)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs	2009-08-30 16:03:06 UTC (rev 4204)
+++ trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs	2009-08-30 16:18:06 UTC (rev 4205)
@@ -45,7 +45,7 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs	2009-08-30 16:03:06 UTC (rev 4204)
+++ trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs	2009-08-30 16:18:06 UTC (rev 4205)
@@ -50,5 +50,5 @@
-[assembly: AssemblyFileVersion("1.1.0.4177")]
+[assembly: AssemblyFileVersion("1.1.0.4203")]
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs	2009-08-30 16:03:06 UTC (rev 4204)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs	2009-08-30 16:18:06 UTC (rev 4205)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs	2009-08-30 16:03:06 UTC (rev 4204)
+++ trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs	2009-08-30 16:18:06 UTC (rev 4205)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs	2009-08-30 16:03:06 UTC (rev 4204)
+++ trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs	2009-08-30 16:18:06 UTC (rev 4205)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
 [assembly: AssemblyKeyFile("..\\..\\maestroapi.key")]
Modified: trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs	2009-08-30 16:03:06 UTC (rev 4204)
+++ trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs	2009-08-30 16:18:06 UTC (rev 4205)
@@ -48,5 +48,5 @@
 //      Build Number
 //      Revision
Modified: trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs	2009-08-30 16:03:06 UTC (rev 4204)
+++ trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs	2009-08-30 16:18:06 UTC (rev 4205)
@@ -48,5 +48,5 @@
 //      Build Number
 //      Revision
Modified: trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs	2009-08-30 16:03:06 UTC (rev 4204)
+++ trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs	2009-08-30 16:18:06 UTC (rev 4205)
@@ -48,5 +48,5 @@
 //      Build Number
 //      Revision
Modified: trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs	2009-08-30 16:03:06 UTC (rev 4204)
+++ trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs	2009-08-30 16:18:06 UTC (rev 4205)
@@ -48,5 +48,5 @@
 //      Build Number
 //      Revision
More information about the mapguide-commits mailing list
