[mapguide-commits] r4369 - sandbox/adsk/2.1/Web/src/viewerfiles
svn_mapguide at osgeo.org
Thu Dec 3 17:32:06 EST 2009
Author: brucedechant
Date: 2009-12-03 17:32:06 -0500 (Thu, 03 Dec 2009)
New Revision: 4369
sandbox/adsk/2.1/Web/src/viewerfiles/legend.js
sandbox/adsk/2.1/Web/src/viewerfiles/legendui.templ
Fix for trac ticket 1023 - Low performance while generating legend
http://trac.osgeo.org/mapguide/ticket/1023
Notes:
- Change to dynamically generate the legend images as needed instead of requesting them all at once
Modified: sandbox/adsk/2.1/Web/src/viewerfiles/legend.js
--- sandbox/adsk/2.1/Web/src/viewerfiles/legend.js 2009-12-03 22:28:19 UTC (rev 4368)
+++ sandbox/adsk/2.1/Web/src/viewerfiles/legend.js 2009-12-03 22:32:06 UTC (rev 4369)
@@ -41,6 +41,7 @@
this.lyrtype = 0;
this.curScale = -1;
this.isDisplayed = false;
+ this.iconWasRequested = false;
function ScaleRangeItem(min, max, parent)
@@ -52,6 +53,7 @@
this.parent = parent;
this.showlongtheme = false;
this.children = new Array();
function StyleItem(legend, filter, geomtype, catindex)
Modified: sandbox/adsk/2.1/Web/src/viewerfiles/legendui.templ
--- sandbox/adsk/2.1/Web/src/viewerfiles/legendui.templ 2009-12-03 22:28:19 UTC (rev 4368)
+++ sandbox/adsk/2.1/Web/src/viewerfiles/legendui.templ 2009-12-03 22:32:06 UTC (rev 4369)
@@ -227,33 +227,39 @@
var layerIconImg = "";
if(hasThemes)
- for(var j=0; j < styles.length; j++)
- var node = styles[j];
- var iconId = GetIconId(layer) + '_Scl_' + layer.curScale + '_Th_' + j;
- var iconImg = RequestThemeStyleIconImg(layer, scale, node.catindex, node.geomtype, iconId);
+ if(layer.expanded && !sc.iconWasRequested)
+ for(var j=0; j < styles.length; j++)
+ var node = styles[j];
+ var iconId = GetIconId(layer) + '_Scl_' + layer.curScale + '_Th_' + j;
+ var iconImg = RequestThemeStyleIconImg(layer, scale, node.catindex, node.geomtype, iconId);
- code += '<table border=0 cellspacing="0" cellpadding="0"><tr height=17>';
- //icon
- code += '<td width=23 id="' + iconId + '">' + iconImg + '</td>';
- //legend text
- code += '<td>' + node.legend + '</td>';
- code += '</tr></table>';
- if(!sc.showlongtheme && styles.length > 10)
- if(j == styles.length - 1)
- break;
- code += '<td width=23><img width=16 height=16 src="../stdicons/transparentpixel.gif"></td>';
- code += '<td>...</td>';
+ //icon
+ code += '<td width=23 id="' + iconId + '">' + iconImg + '</td>';
+ //legend text
+ code += '<td>' + node.legend + '</td>';
- j = styles.length - 2;
+ if(!sc.showlongtheme && styles.length > 10)
+ if(j == styles.length - 1)
+ break;
+ code += '<table border=0 cellspacing="0" cellpadding="0"><tr height=17>';
+ code += '<td width=23><img width=16 height=16 src="../stdicons/transparentpixel.gif"></td>';
+ code += '<td>...</td>';
+ code += '</tr></table>';
+ j = styles.length - 2;
+ if(styles.length <= 10)
+ sc.showlongtheme = true;
+ layerChildren.innerHTML = code;
+ sc.iconWasRequested = true;
- if(styles.length <= 10)
- sc.showlongtheme = true;
- layerChildren.innerHTML = code;
layerIconImg = iconThemeLayer;
else
@@ -325,6 +331,7 @@
Expand(node);
+// Expanding a node, the legend for the sub-items of this node will be generated dynamically
function Expand(node)
var elt = document.getElementById('ChildrenOf_' + node.objectId);
@@ -332,6 +339,10 @@
node.expanded = true;
elt.style.display = "block";
+ RefreshNodesState(node.children);
+ iconsToLoad.reverse();
+ LoadNextIcon();
if(node.type == 0 || HasLayerThemes(node))
ShowExpandedState(node);
@@ -688,10 +699,18 @@
return layer.children[layer.curScale].children.length > 1;
-// set the active scale ranges in layers, according to current scale, and set the display state for layers and groups
-// update the layer styles if necessary
+// set the display state for themes, layers and groups and update the layer styles if necessary
function UpdateScaleRanges(nodes)
+ RefreshNodesState(nodes);
+// there are three possible reasons to refresh the nodes' state:
+// the first one is updating scale ranges to refresh the legend images
+// the second one is expanding a group to build the legend images of layers in that group.
+// the third one is expanding a layer node to build the legend images of themes in that layer.
+function RefreshNodesState(nodes)
for(var i=0; i < nodes.length; i++)
var node = nodes[i];
@@ -700,7 +719,7 @@
var count = node.children != null? node.children.length: 0;
node.hasVisibleLayers = false;
if(count > 0) {
- UpdateScaleRanges(node.children);
for(var j=0; j < node.children.length; j++)
child = node.children[j];
@@ -737,13 +756,69 @@
break;
- if(node.displayInLegend && rangeIndex != node.curScale && node.curScale != -1)
- SetLayerStyles(node);
+ if(node.displayInLegend && node.curScale != -1)
+ // scale changed
+ if(rangeIndex != node.curScale)
+ // the layer's theme will be changed on demand
+ node.children[node.curScale].iconWasRequested = false;
+ // the layer's legend image will be changed immediately
+ if(!HasCollapsedParent(node))
+ SetLayerStyles(node);
+ node.iconWasRequested = true;
+ // the layer's legend image will be changed on demand
+ else
+ node.iconWasRequested = false;
+ // parent group expanded
+ else if(!node.iconWasRequested && !HasCollapsedParent(node))
node.isDisplayed = node.displayInLegend && node.curScale != -1;
+ else if(node.type == 2)
+ // parent layer expanded
+ if(node.parent.children[node.parent.curScale]=== node && !node.iconWasRequested)
+ SetLayerStyles(node.parent);
+// To check if any parent node of current node is collapsed.
+function HasCollapsedParent(node)
+ if(node.parent != null)
+ if(node.parent.expanded == true)
+ return HasCollapsedParent(node.parent)
+ else
+ return true;
+ else
+ return false;
function FindNode(nodes, objectId)
More information about the mapguide-commits
