[mapguide-commits] r4378 - sandbox/adsk/2.1/Web/src/HttpHandler
svn_mapguide at osgeo.org
Fri Dec 4 18:40:31 EST 2009
Author: brucedechant
Date: 2009-12-04 18:40:31 -0500 (Fri, 04 Dec 2009)
New Revision: 4378
sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteInfo.cpp
Fix for trac ticket 1173 - Add performance logging
http://trac.osgeo.org/mapguide/ticket/1173
Notes:
- Moved NEW items CacheSize and CacheDroppedEntries to only show up when the NEW GetSiteInfo request is done so as not to break existing functionality with the original 1.0.0 GetSiteInfo request
Modified: sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteInfo.cpp
--- sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteInfo.cpp 2009-12-04 21:43:12 UTC (rev 4377)
+++ sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteInfo.cpp 2009-12-04 23:40:31 UTC (rev 4378)
@@ -322,17 +322,20 @@
xml += MgUtil::MultiByteToWideChar(tmpStr);
xml += L"</Uptime>\n";
- xml += L"\t\t<CacheSize>";
- int32Prop = (MgInt32Property*)properties->GetItem(MgServerInformationProperties::CacheSize);
- MgUtil::Int32ToString(int32Prop->GetValue(), tmpStr);
- xml += MgUtil::MultiByteToWideChar(tmpStr);
- xml += L"</CacheSize>\n";
+ if (m_userInfo->GetApiVersion() == MG_API_VERSION(2,1,0))
+ xml += L"\t\t<CacheSize>";
+ int32Prop = (MgInt32Property*)properties->GetItem(MgServerInformationProperties::CacheSize);
+ MgUtil::Int32ToString(int32Prop->GetValue(), tmpStr);
+ xml += MgUtil::MultiByteToWideChar(tmpStr);
+ xml += L"</CacheSize>\n";
- xml += L"\t\t<CacheDroppedEntries>";
- int32Prop = (MgInt32Property*)properties->GetItem(MgServerInformationProperties::CacheDroppedEntries);
- xml += L"</CacheDroppedEntries>\n";
+ xml += L"\t\t<CacheDroppedEntries>";
+ int32Prop = (MgInt32Property*)properties->GetItem(MgServerInformationProperties::CacheDroppedEntries);
+ xml += L"</CacheDroppedEntries>\n";
xml += L"\t</Statistics>\n";
More information about the mapguide-commits
