[mapguide-commits] r4398 - in
sandbox/rfc60/MgDev/Server/src/Services: Mapping Rendering
svn_mapguide at osgeo.org
Wed Dec 9 10:08:50 EST 2009
Author: uvlite
Date: 2009-12-09 10:08:49 -0500 (Wed, 09 Dec 2009)
New Revision: 4398
sandbox/rfc60/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
sandbox/rfc60/MgDev/Server/src/Services/Mapping/MappingUtil.h
sandbox/rfc60/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
RFC60 now only executes when image format uses colorpalette
Modified: sandbox/rfc60/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
--- sandbox/rfc60/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2009-12-09 15:06:58 UTC (rev 4397)
+++ sandbox/rfc60/MgDev/Server/src/Services/Mapping/MappingUtil.cpp 2009-12-09 15:08:49 UTC (rev 4398)
@@ -362,7 +362,8 @@
bool expandExtents,
bool checkRefreshFlag,
double scale,
- bool selection)
+ bool selection,
+ bool extractColors)
#ifdef _DEBUG
long dwStart = GetTickCount();
@@ -569,7 +570,16 @@
dr->StartLayer(&layerInfo, &fcinfo);
ds->StylizeVectorLayer(vl, dr, rsReader, xformer, scale, NULL, NULL);
dr->EndLayer();
- ExtractColors(map, scaleRange, ds);
+ #ifdef _DEBUG
+ printf(" StylizeLayers() //ExtractColors// -Vector- Name:%S Time:%6.4f (s)\n\n", (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0);
+ #endif
+ // color extraction for RFC60 only when needed
+ if (extractColors)
+ ExtractColors(map, scaleRange, ds);
+ #ifdef _DEBUG
+ printf(" StylizeLayers() ##ExtractColors## -Vector- Name:%S Time:%6.4f (s)\n\n", (mapLayer->GetName()).c_str(), (GetTickCount()-dwLayerStart)/1000.0);
+ #endif
else // not scaleRange
@@ -1205,6 +1215,7 @@
/// PURPOSE: Accessor method for the base colors defined in this Layer and scaleRange.
+/// used for RFC60
/// RETURNS: A pointer to the list of colors of the collected colors (maybe empty but not null)
PSTRCOLORLIST MgMappingUtil::GetUsedColorsFromScaleRange(MdfModel::VectorScaleRange* vsr,
Modified: sandbox/rfc60/MgDev/Server/src/Services/Mapping/MappingUtil.h
--- sandbox/rfc60/MgDev/Server/src/Services/Mapping/MappingUtil.h 2009-12-09 15:06:58 UTC (rev 4397)
+++ sandbox/rfc60/MgDev/Server/src/Services/Mapping/MappingUtil.h 2009-12-09 15:08:49 UTC (rev 4398)
@@ -55,7 +55,8 @@
bool expandExtents,
double scale,
- bool selection = false);
+ bool selection = false,
+ bool extractColors = false);
static RSMgFeatureReader * ExecuteFeatureQuery(MgFeatureService* svcFeature,
RS_Bounds& extent,
Modified: sandbox/rfc60/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp
--- sandbox/rfc60/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2009-12-09 15:06:58 UTC (rev 4397)
+++ sandbox/rfc60/MgDev/Server/src/Services/Rendering/ServerRenderingService.cpp 2009-12-09 15:08:49 UTC (rev 4398)
@@ -36,6 +36,9 @@
static const INT32 FILTER_SELECTABLE = 2;
static const INT32 FILTER_HASTOOLTIPS = 4;
+// could go into the utils also??
+inline bool hasColorMap (STRING format) { return format == L"PNG8" || format == L"GIF"; }
IMPLEMENT_CREATE_SERVICE(MgServerRenderingService)
// used when we want to process a given number of features
@@ -745,6 +748,7 @@
/// pack options into object and forward call (select Selection AND Layers) maybe keepSelection
+/// called by RenderTile
MgByteReader* MgServerRenderingService::RenderMapInternal(MgMap* map,
MgSelection* selection,
MgReadOnlyLayerCollection* roLayers,
@@ -818,12 +822,14 @@
RS_Color bgcolor(0, 0, 0, 255); //not used -- GDRenderer is already initialized to the correct bgcolor
+ STRING format = options->GetImageFormat();
RS_MapUIInfo mapInfo(sessionId, map->GetName(), map->GetObjectId(), srs, units, bgcolor);
// begin map stylization
dr->StartMap(&mapInfo, b, scale, map->GetDisplayDpi(), map->GetMetersPerUnit(), NULL);
-// MG_TRY()
+//## MG_TRY()
// if no layer collection is supplied, then put all layers in a temporary collection
Ptr<MgReadOnlyLayerCollection> tempLayers = SAFE_ADDREF(roLayers);
if (tempLayers == NULL) // if called from renderMap not RenderTile
@@ -838,13 +844,14 @@
INT32 behavior = options->GetBehavior();
- if (behavior & MgRenderingOptions::RenderLayers)
+ if (behavior & MgRenderingOptions::RenderLayers) // this is for tiles so observer colormaps
MgMappingUtil::StylizeLayers(m_svcResource, m_svcFeature, m_svcDrawing, m_pCSFactory, map,
- tempLayers, NULL, &ds, dr, dstCs, expandExtents, false, scale);
+ tempLayers, NULL, &ds, dr, dstCs, expandExtents, false, scale,
+ false, hasColorMap(format));
- // now we need to stylize the selection on top
+ // now we need to stylize the selection on top (this is not for tiles!)
if (selection && (behavior & MgRenderingOptions::RenderSelection))
Ptr<MgReadOnlyLayerCollection> selLayers = selection->GetLayers();
@@ -897,15 +904,15 @@
modLayers, overrideFilters, &ds, dr, dstCs, false, false, scale, (behavior & MgRenderingOptions::KeepSelection) != 0);
- // MG_CATCH(L"MgServerRenderingService.RenderMapInternal-StylizeLayers")
+//## MG_CATCH(L"MgServerRenderingService.RenderMapInternal-StylizeLayers")
dr->EndMap(); // cleanup??
-// if (mgException.p)
-// throw mgException; // to skip tile we need to throw an exception as a NULL return
-// // will cause a null pointer exception.
+//## if (mgException.p)
+//## throw mgException; // to skip a faulty tile we need to throw an exception
+//## // as simply returning NULL will cause a null pointer exception.
@@ -932,29 +939,26 @@
// get a byte representation of the image
auto_ptr<RS_ByteData> data;
- STRING imageFormat = options->GetImageFormat();
- // Both AGG and GD expect the format to be an uppercase string
- STRING format = MgUtil::ToUpper(imageFormat);
- /// PNG8 code by UV
+ /// rfc60 code to correct colormaps by UV
/// we examine the expressions collected from xml definitions of all layer.
- /// the color Palette for the renderer is a list<RSColor>
- PRSCOLORS tileColorPalette = new RSCOLORS();
/// the map object has a list from all color entries found in the most recent Layerstylization
/// TODO currently they are interpreted as ffffffff 32 bit RGBA string values.
/// adding expresssions and other interpretations could be done here.
+ /// the color Palette for the renderer is a list<RSColor>
+ PRSCOLORS tileColorPalette;
try {
- ParseColorStrings (tileColorPalette, map);
- #ifdef _DEBUG_PNG8
- printf("<<<<<<<<<<<<<<<<<<<<< MgServerRenderingService::ColorPalette->size(): %d\n", mapColorPalette->size());
- #endif
// call the image renderer to create the image ----------------------------------------
- if (wcscmp(m_rendererName.c_str(), L"AGG") == 0)
+ if (wcscmp(m_rendererName.c_str(), L"AGG") == 0 && hasColorMap(format))
+ tileColorPalette = new RSCOLORS();
+ ParseColorStrings (tileColorPalette, map);
+ #ifdef _DEBUG_PNG8
+ printf("<<<<<<<<<<<<<<<<<<<<< MgServerRenderingService::ColorPalette->size(): %d\n", mapColorPalette->size());
+ #endif
data.reset(((AGGRenderer*)dr)->Save(format, saveWidth, saveHeight, tileColorPalette));
- else
+ } else
data.reset(((GDRenderer*)dr)->Save(format, saveWidth, saveHeight));
} catch (exception e) {
if (tileColorPalette) // cleanup the bare pointer (its a STL list so we do it by hand
@@ -989,7 +993,7 @@
-/// PNG8 code by UV
+/// RFC60 code for colormapped tiles by UV
More information about the mapguide-commits
