[mapguide-commits] r4408 - in trunk/Tools/Maestro: . Installer Localization Maestro
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Dec 10 13:43:58 EST 2009
Author: ksgeograf
Date: 2009-12-10 13:43:57 -0500 (Thu, 10 Dec 2009)
New Revision: 4408
   trunk/Tools/Maestro/Installer/VSExpress Build.bat
   trunk/Tools/Maestro/Installer/incBinFiles.wxs
   trunk/Tools/Maestro/Installer/incLocFiles.da-DK.wxs
   trunk/Tools/Maestro/Installer/incLocFiles.es-ES.wxs
   trunk/Tools/Maestro/Installer/incLocFiles.fr-FR.wxs
   trunk/Tools/Maestro/Localization/LocalizationTool.exe
   trunk/Tools/Maestro/Maestro/Update DEBUG Environment.bat
   trunk/Tools/Maestro/Maestro/Update RELEASE Environment.bat
   trunk/Tools/Maestro/build.bat
Maestro:
Fixed issue #1181.
The translation tool is ready, and the localization instructions are updated.
This commit also fixes the build files to use the new localization files.
Modified: trunk/Tools/Maestro/Installer/VSExpress Build.bat
--- trunk/Tools/Maestro/Installer/VSExpress Build.bat	2009-12-09 23:47:43 UTC (rev 4407)
+++ trunk/Tools/Maestro/Installer/VSExpress Build.bat	2009-12-10 18:43:57 UTC (rev 4408)
@@ -1,35 +1,43 @@
 SET TYPEBUILD=Release
 SET MAESTRO_DEV=..\Maestro
+SET MAESTRO_LOCALIZATION=%CD%\..\Localization
 SET MAESTRO_OUTPUT=..\InstallerTemp%TYPEBUILD%\MapGuideMaestro
-SET MAESTRO_WIX=..\Installer
+SET OUTPUT_ZIPFILE=bin\%TYPEBUILD%\MapGuide Maestro.zip
+SET MAESTRO_WIX=%CD%
 SET PARAFFIN_PATH=%MAESTRO_WIX%\paraffin.exe
 SET XCOPY=xcopy /E /Y /I /Q
 SET ZIP=%PROGRAMFILES%\7-zip\7z.exe
+SET DELTREE=rmdir /S /Q
+%DELTREE% "%MAESTRO_OUTPUT%"
 %XCOPY% "..\Maestro\bin\%TYPEBUILD%" "%MAESTRO_OUTPUT%"
 del /Q "%MAESTRO_OUTPUT%"\*.vshost.*
 del /Q "%MAESTRO_OUTPUT%"\*.pdb
-del /S /Q "%MAESTRO_OUTPUT%"\Localization\default > NUL
 del /S /Q "%MAESTRO_OUTPUT%"\*.db > NUL
-rmdir "%MAESTRO_OUTPUT%"\Localization\default
-%PARAFFIN_PATH% -dir %MAESTRO_OUTPUT% -alias "%MAESTRO_OUTPUT%" -custom MAESTROBIN -dirref INSTALLLOCATION -multiple -guids incBinFiles.wxs -ext .pdb -direXclude .svn -direXclude Localization
+pushd %MAESTRO_LOCALIZATION%
+%DELTREE% compiled
+LocalizationTool.exe update
+LocalizationTool.exe build
+for /D %%d in ("compiled\*") do call :langbuild %%d
+popd
-rem del /Q "%MAESTRO_WIX%\incLang.wxs"
+"%PARAFFIN_PATH%" -dir %MAESTRO_OUTPUT% -alias "%MAESTRO_OUTPUT%" -custom MAESTROBIN -dirref INSTALLLOCATION -multiple -guids incBinFiles.wxs -ext .pdb -direXclude .svn
-for /D %%d in ("%MAESTRO_OUTPUT%\Localization\*") do call :langbuild %%d
 WixProjBuilder.exe Maestro.wixproj
-"%ZIP%" a -r "bin\%TYPEBUILD%\MapGuide Maestro.zip" "%MAESTRO_OUTPUT%"
+rem Move in localization files and build zip
+%XCOPY% "%MAESTRO_LOCALIZATION%\compiled\*" "%MAESTRO_OUTPUT%"
+del /Q "%OUTPUT_ZIPFILE%"
+"%ZIP%" a -r "%OUTPUT_ZIPFILE%" "%MAESTRO_OUTPUT%"
 goto end_of_program
 :langbuild
 set FOLDERNAME=
 for /f "tokens=*" %%a in ("%1") do set FOLDERNAME=%%~na
-%PARAFFIN_PATH% -dir %1 -alias %1 -custom MAESTROBIN_%FOLDERNAME% -dirref LANGLOCATION -multiple -guids incLocFiles.%FOLDERNAME%.wxs -ext .pdb -direXclude .svn -direXclude Localization
-rem echo "<?include incLocFiles.%FOLDERNAME%.wxs ?>" >> "%MAESTRO_WIX%\incLang.wxs"
+"%PARAFFIN_PATH%" -dir %1 -alias ..\Localization\%1 -custom MAESTROBIN_%FOLDERNAME% -dirref dir_MapGuideMaestro_0 -multiple -guids "%MAESTRO_WIX%\incLocFiles.%FOLDERNAME%.wxs" -ext .pdb -direXclude .svn
 goto end_of_program
Modified: trunk/Tools/Maestro/Installer/incBinFiles.wxs
--- trunk/Tools/Maestro/Installer/incBinFiles.wxs	2009-12-09 23:47:43 UTC (rev 4407)
+++ trunk/Tools/Maestro/Installer/incBinFiles.wxs	2009-12-10 18:43:57 UTC (rev 4408)
@@ -3,7 +3,7 @@
   <!--<CommandLineOptions>
   <Producer>Autogenerated by Paraffin - Wintellect - John Robbins - john at wintellect.com</Producer>
   <WARNING>Manual changes to this file may cause incorrect behavior.</WARNING>
-  <CreatedOn>25-11-2009 20:57</CreatedOn>
+  <CreatedOn>10-12-2009 19:25</CreatedOn>
   <Directory>..\InstallerTempRelease\MapGuideMaestro\</Directory>
   <Custom>MAESTROBIN</Custom>
   <DirAlias>..\InstallerTempRelease\MapGuideMaestro\</DirAlias>
@@ -17,25 +17,24 @@
   </ExtensionExcludes>
   <DirExcludes>
     <Dir>.svn</Dir>
-    <Dir>Localization</Dir>
   </DirExcludes>
   <NextDirectoryNumber>8</NextDirectoryNumber>
-  <NextComponentNumber>368</NextComponentNumber>
+  <NextComponentNumber>369</NextComponentNumber>
 </CommandLineOptions>-->
   <Fragment>
     <ComponentGroup Id="group_MAESTROBIN">
       <ComponentRef Id="comp_MAESTROBIN_0" />
-      <ComponentRef Id="comp_MAESTROBIN_21" />
-      <ComponentRef Id="comp_MAESTROBIN_68" />
-      <ComponentRef Id="comp_MAESTROBIN_147" />
-      <ComponentRef Id="comp_MAESTROBIN_155" />
+      <ComponentRef Id="comp_MAESTROBIN_22" />
+      <ComponentRef Id="comp_MAESTROBIN_69" />
+      <ComponentRef Id="comp_MAESTROBIN_148" />
       <ComponentRef Id="comp_MAESTROBIN_156" />
-      <ComponentRef Id="comp_MAESTROBIN_292" />
-      <ComponentRef Id="comp_MAESTROBIN_362" />
+      <ComponentRef Id="comp_MAESTROBIN_157" />
+      <ComponentRef Id="comp_MAESTROBIN_293" />
+      <ComponentRef Id="comp_MAESTROBIN_363" />
     </ComponentGroup>
     <DirectoryRef Id="INSTALLLOCATION">
       <Directory Id="dir_MapGuideMaestro_0" Name="MapGuideMaestro">
-        <Component Id="comp_MAESTROBIN_0" DiskId="1" KeyPath="yes" Guid="58FD668C-3198-4F7F-98D5-D32451C1E60E">
+        <Component Id="comp_MAESTROBIN_0" DiskId="1" KeyPath="yes" Guid="8BCB4EA8-D508-41F4-94FC-E978DF2460C7">
           <File Id="file_MAESTROBIN_0" Name="ColorBrewer.csv" Source="..\InstallerTempRelease\MapGuideMaestro\ColorBrewer.csv" />
           <File Id="file_MAESTROBIN_1" Name="EditorMap.xml" Source="..\InstallerTempRelease\MapGuideMaestro\EditorMap.xml" />
           <File Id="file_MAESTROBIN_2" Name="Globalizator.dll" Source="..\InstallerTempRelease\MapGuideMaestro\Globalizator.dll" />
@@ -47,389 +46,390 @@
           <File Id="file_MAESTROBIN_8" Name="MgCooker.exe" Source="..\InstallerTempRelease\MapGuideMaestro\MgCooker.exe" />
           <File Id="file_MAESTROBIN_9" Name="MgCookerCommandline.exe" Source="..\InstallerTempRelease\MapGuideMaestro\MgCookerCommandline.exe" />
           <File Id="file_MAESTROBIN_10" Name="OSGeo.MapGuide.Maestro.FusionEditor.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.FusionEditor.dll" />
-          <File Id="file_MAESTROBIN_11" Name="OSGeo.MapGuide.Maestro.MaestroEditorInterface.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.MaestroEditorInterface.dll" />
-          <File Id="file_MAESTROBIN_12" Name="OSGeo.MapGuide.Maestro.ResourceBrowser.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.ResourceBrowser.dll" />
-          <File Id="file_MAESTROBIN_13" Name="OSGeo.MapGuide.Maestro.ResourceEditors.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.ResourceEditors.dll" />
-          <File Id="file_MAESTROBIN_14" Name="OSGeo.MapGuide.Maestro.ResourceValidators.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.ResourceValidators.dll" />
-          <File Id="file_MAESTROBIN_15" Name="OSGeo.MapGuide.MaestroAPI.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.MaestroAPI.dll" />
-          <File Id="file_MAESTROBIN_16" Name="OSGeo.MapGuide.MaestroAPI.PackageBuilder.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.MaestroAPI.PackageBuilder.dll" />
-          <File Id="file_MAESTROBIN_17" Name="OSGeo.MapGuide.MaestroAPI.xml" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.MaestroAPI.xml" />
-          <File Id="file_MAESTROBIN_18" Name="ProviderMap.xml" Source="..\InstallerTempRelease\MapGuideMaestro\ProviderMap.xml" />
-          <File Id="file_MAESTROBIN_19" Name="Topology.dll" Source="..\InstallerTempRelease\MapGuideMaestro\Topology.dll" />
-          <File Id="file_MAESTROBIN_20" Name="Topology.IO.MapGuide.dll" Source="..\InstallerTempRelease\MapGuideMaestro\Topology.IO.MapGuide.dll" />
+          <File Id="file_MAESTROBIN_11" Name="OSGeo.MapGuide.Maestro.LoginForm.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.LoginForm.dll" />
+          <File Id="file_MAESTROBIN_12" Name="OSGeo.MapGuide.Maestro.MaestroEditorInterface.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.MaestroEditorInterface.dll" />
+          <File Id="file_MAESTROBIN_13" Name="OSGeo.MapGuide.Maestro.ResourceBrowser.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.ResourceBrowser.dll" />
+          <File Id="file_MAESTROBIN_14" Name="OSGeo.MapGuide.Maestro.ResourceEditors.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.ResourceEditors.dll" />
+          <File Id="file_MAESTROBIN_15" Name="OSGeo.MapGuide.Maestro.ResourceValidators.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.ResourceValidators.dll" />
+          <File Id="file_MAESTROBIN_16" Name="OSGeo.MapGuide.MaestroAPI.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.MaestroAPI.dll" />
+          <File Id="file_MAESTROBIN_17" Name="OSGeo.MapGuide.MaestroAPI.PackageBuilder.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.MaestroAPI.PackageBuilder.dll" />
+          <File Id="file_MAESTROBIN_18" Name="OSGeo.MapGuide.MaestroAPI.xml" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.MaestroAPI.xml" />
+          <File Id="file_MAESTROBIN_19" Name="ProviderMap.xml" Source="..\InstallerTempRelease\MapGuideMaestro\ProviderMap.xml" />
+          <File Id="file_MAESTROBIN_20" Name="Topology.dll" Source="..\InstallerTempRelease\MapGuideMaestro\Topology.dll" />
+          <File Id="file_MAESTROBIN_21" Name="Topology.IO.MapGuide.dll" Source="..\InstallerTempRelease\MapGuideMaestro\Topology.IO.MapGuide.dll" />
         </Component>
         <Directory Id="dir_MapGuideMaestro_Schemas_1" Name="Schemas">
-          <Component Id="comp_MAESTROBIN_21" DiskId="1" KeyPath="yes" Guid="B56B42FB-FC9F-404D-9D39-4E2E462DBCC2">
-            <File Id="file_MAESTROBIN_21" Name="ApplicationDefinition-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ApplicationDefinition-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_22" Name="ApplicationDefinitionInfo-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ApplicationDefinitionInfo-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_23" Name="DataStoreList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\DataStoreList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_24" Name="DrawingSectionList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\DrawingSectionList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_25" Name="DrawingSectionResourceList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\DrawingSectionResourceList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_26" Name="DrawingSource-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\DrawingSource-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_27" Name="Envelope-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\Envelope-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_28" Name="FdoLongTransactionList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FdoLongTransactionList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_29" Name="FdoProviderCapabilities-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FdoProviderCapabilities-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_30" Name="FdoSpatialContextList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FdoSpatialContextList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_31" Name="FeatureProviderRegistry-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FeatureProviderRegistry-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_32" Name="FeatureProviders-0.0.1.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FeatureProviders-0.0.1.xsd" />
-            <File Id="file_MAESTROBIN_33" Name="FeatureSet-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FeatureSet-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_34" Name="FeatureSource-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FeatureSource-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_35" Name="Group-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\Group-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_36" Name="GroupList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\GroupList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_37" Name="LayerDefinition-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\LayerDefinition-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_38" Name="LayerDefinition-1.1.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\LayerDefinition-1.1.0.xsd" />
-            <File Id="file_MAESTROBIN_39" Name="LayerDefinition-1.2.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\LayerDefinition-1.2.0.xsd" />
-            <File Id="file_MAESTROBIN_40" Name="LayerDefinition-1.3.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\LayerDefinition-1.3.0.xsd" />
-            <File Id="file_MAESTROBIN_41" Name="LoadProcedure-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\LoadProcedure-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_42" Name="MapDefinition-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\MapDefinition-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_43" Name="PlatformCommon-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\PlatformCommon-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_44" Name="PrintLayout-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\PrintLayout-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_45" Name="RepositoryContent-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\RepositoryContent-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_46" Name="RepositoryList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\RepositoryList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_47" Name="ResourceDataList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceDataList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_48" Name="ResourceDocumentHeader-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceDocumentHeader-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_49" Name="ResourceFolderHeader-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceFolderHeader-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_50" Name="ResourceList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_51" Name="ResourcePackageManifest-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourcePackageManifest-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_52" Name="ResourceReferenceList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceReferenceList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_53" Name="ResourceSecurity-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceSecurity-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_54" Name="Role-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\Role-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_55" Name="SelectAggregate-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SelectAggregate-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_56" Name="Server-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\Server-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_57" Name="ServerList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ServerList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_58" Name="SiteInformation-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SiteInformation-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_59" Name="SiteVersion-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SiteVersion-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_60" Name="SqlSelect-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SqlSelect-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_61" Name="SymbolDefinition-1.1.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SymbolDefinition-1.1.0.xsd" />
-            <File Id="file_MAESTROBIN_62" Name="SymbolLibrary-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SymbolLibrary-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_63" Name="Types-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\Types-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_64" Name="UnmanagedDataList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\UnmanagedDataList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_65" Name="User-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\User-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_66" Name="UserList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\UserList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_67" Name="WebLayout-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\WebLayout-1.0.0.xsd" />
+          <Component Id="comp_MAESTROBIN_22" DiskId="1" KeyPath="yes" Guid="3D801BF7-F3D7-4009-A056-EAA954B1C8DC">
+            <File Id="file_MAESTROBIN_22" Name="ApplicationDefinition-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ApplicationDefinition-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_23" Name="ApplicationDefinitionInfo-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ApplicationDefinitionInfo-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_24" Name="DataStoreList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\DataStoreList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_25" Name="DrawingSectionList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\DrawingSectionList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_26" Name="DrawingSectionResourceList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\DrawingSectionResourceList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_27" Name="DrawingSource-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\DrawingSource-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_28" Name="Envelope-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\Envelope-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_29" Name="FdoLongTransactionList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FdoLongTransactionList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_30" Name="FdoProviderCapabilities-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FdoProviderCapabilities-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_31" Name="FdoSpatialContextList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FdoSpatialContextList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_32" Name="FeatureProviderRegistry-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FeatureProviderRegistry-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_33" Name="FeatureProviders-0.0.1.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FeatureProviders-0.0.1.xsd" />
+            <File Id="file_MAESTROBIN_34" Name="FeatureSet-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FeatureSet-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_35" Name="FeatureSource-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FeatureSource-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_36" Name="Group-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\Group-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_37" Name="GroupList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\GroupList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_38" Name="LayerDefinition-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\LayerDefinition-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_39" Name="LayerDefinition-1.1.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\LayerDefinition-1.1.0.xsd" />
+            <File Id="file_MAESTROBIN_40" Name="LayerDefinition-1.2.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\LayerDefinition-1.2.0.xsd" />
+            <File Id="file_MAESTROBIN_41" Name="LayerDefinition-1.3.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\LayerDefinition-1.3.0.xsd" />
+            <File Id="file_MAESTROBIN_42" Name="LoadProcedure-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\LoadProcedure-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_43" Name="MapDefinition-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\MapDefinition-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_44" Name="PlatformCommon-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\PlatformCommon-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_45" Name="PrintLayout-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\PrintLayout-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_46" Name="RepositoryContent-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\RepositoryContent-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_47" Name="RepositoryList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\RepositoryList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_48" Name="ResourceDataList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceDataList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_49" Name="ResourceDocumentHeader-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceDocumentHeader-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_50" Name="ResourceFolderHeader-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceFolderHeader-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_51" Name="ResourceList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_52" Name="ResourcePackageManifest-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourcePackageManifest-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_53" Name="ResourceReferenceList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceReferenceList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_54" Name="ResourceSecurity-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceSecurity-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_55" Name="Role-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\Role-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_56" Name="SelectAggregate-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SelectAggregate-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_57" Name="Server-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\Server-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_58" Name="ServerList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ServerList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_59" Name="SiteInformation-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SiteInformation-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_60" Name="SiteVersion-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SiteVersion-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_61" Name="SqlSelect-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SqlSelect-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_62" Name="SymbolDefinition-1.1.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SymbolDefinition-1.1.0.xsd" />
+            <File Id="file_MAESTROBIN_63" Name="SymbolLibrary-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SymbolLibrary-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_64" Name="Types-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\Types-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_65" Name="UnmanagedDataList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\UnmanagedDataList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_66" Name="User-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\User-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_67" Name="UserList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\UserList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_68" Name="WebLayout-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\WebLayout-1.0.0.xsd" />
           </Component>
         </Directory>
         <Directory Id="dir_MapGuideMaestro_stdicons_2" Name="stdicons">
-          <Component Id="comp_MAESTROBIN_68" DiskId="1" KeyPath="yes" Guid="18D33365-7931-4FA7-956E-4100A73AC7D2">
-            <File Id="file_MAESTROBIN_68" Name="copyright.txt" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\copyright.txt" />
-            <File Id="file_MAESTROBIN_69" Name="icon_back.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_back.gif" />
-            <File Id="file_MAESTROBIN_70" Name="icon_back_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_back_disabled.gif" />
-            <File Id="file_MAESTROBIN_71" Name="icon_buffer.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_buffer.gif" />
-            <File Id="file_MAESTROBIN_72" Name="icon_buffer_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_buffer_disabled.gif" />
-            <File Id="file_MAESTROBIN_73" Name="icon_clearselect.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_clearselect.gif" />
-            <File Id="file_MAESTROBIN_74" Name="icon_clearselect_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_clearselect_disabled.gif" />
-            <File Id="file_MAESTROBIN_75" Name="icon_copy.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_copy.gif" />
-            <File Id="file_MAESTROBIN_76" Name="icon_copy_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_copy_disabled.gif" />
-            <File Id="file_MAESTROBIN_77" Name="icon_ctxarrow.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_ctxarrow.gif" />
-            <File Id="file_MAESTROBIN_78" Name="icon_fitwindow.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_fitwindow.gif" />
-            <File Id="file_MAESTROBIN_79" Name="icon_fitwindow_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_fitwindow_disabled.gif" />
-            <File Id="file_MAESTROBIN_80" Name="icon_forward.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_forward.gif" />
-            <File Id="file_MAESTROBIN_81" Name="icon_forward_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_forward_disabled.gif" />
-            <File Id="file_MAESTROBIN_82" Name="icon_help.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_help.gif" />
-            <File Id="file_MAESTROBIN_83" Name="icon_help_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_help_disabled.gif" />
-            <File Id="file_MAESTROBIN_84" Name="icon_home.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_home.gif" />
-            <File Id="file_MAESTROBIN_85" Name="icon_home_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_home_disabled.gif" />
-            <File Id="file_MAESTROBIN_86" Name="icon_invokescript.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_invokescript.gif" />
-            <File Id="file_MAESTROBIN_87" Name="icon_invokescript_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_invokescript_disabled.gif" />
-            <File Id="file_MAESTROBIN_88" Name="icon_invokeurl.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_invokeurl.gif" />
-            <File Id="file_MAESTROBIN_89" Name="icon_invokeurl_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_invokeurl_disabled.gif" />
-            <File Id="file_MAESTROBIN_90" Name="icon_loading.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_loading.gif" />
-            <File Id="file_MAESTROBIN_91" Name="icon_measure.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_measure.gif" />
-            <File Id="file_MAESTROBIN_92" Name="icon_measure_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_measure_disabled.gif" />
-            <File Id="file_MAESTROBIN_93" Name="icon_menuarrow.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_menuarrow.gif" />
-            <File Id="file_MAESTROBIN_94" Name="icon_menuarrowup.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_menuarrowup.gif" />
-            <File Id="file_MAESTROBIN_95" Name="icon_menuarrowup_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_menuarrowup_disabled.gif" />
-            <File Id="file_MAESTROBIN_96" Name="icon_menuarrow_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_menuarrow_disabled.gif" />
-            <File Id="file_MAESTROBIN_97" Name="icon_null.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_null.gif" />
-            <File Id="file_MAESTROBIN_98" Name="icon_pan.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_pan.gif" />
-            <File Id="file_MAESTROBIN_99" Name="icon_pandown.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_pandown.gif" />
-            <File Id="file_MAESTROBIN_100" Name="icon_pandown_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_pandown_disabled.gif" />
-            <File Id="file_MAESTROBIN_101" Name="icon_panleft.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panleft.gif" />
-            <File Id="file_MAESTROBIN_102" Name="icon_panleft_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panleft_disabled.gif" />
-            <File Id="file_MAESTROBIN_103" Name="icon_panright.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panright.gif" />
-            <File Id="file_MAESTROBIN_104" Name="icon_panright_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panright_disabled.gif" />
-            <File Id="file_MAESTROBIN_105" Name="icon_panup.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panup.gif" />
-            <File Id="file_MAESTROBIN_106" Name="icon_panup_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panup_disabled.gif" />
-            <File Id="file_MAESTROBIN_107" Name="icon_pan_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_pan_disabled.gif" />
-            <File Id="file_MAESTROBIN_108" Name="icon_plotdwf.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_plotdwf.gif" />
-            <File Id="file_MAESTROBIN_109" Name="icon_plotdwf_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_plotdwf_disabled.gif" />
-            <File Id="file_MAESTROBIN_110" Name="icon_popupscrolldown.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_popupscrolldown.gif" />
-            <File Id="file_MAESTROBIN_111" Name="icon_print.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_print.gif" />
-            <File Id="file_MAESTROBIN_112" Name="icon_printablepage.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_printablepage.gif" />
-            <File Id="file_MAESTROBIN_113" Name="icon_printablepage_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_printablepage_disabled.gif" />
-            <File Id="file_MAESTROBIN_114" Name="icon_print_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_print_disabled.gif" />
-            <File Id="file_MAESTROBIN_115" Name="icon_refreshmap.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_refreshmap.gif" />
-            <File Id="file_MAESTROBIN_116" Name="icon_refreshmap_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_refreshmap_disabled.gif" />
-            <File Id="file_MAESTROBIN_117" Name="icon_restorecenter.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_restorecenter.gif" />
-            <File Id="file_MAESTROBIN_118" Name="icon_restorecenter_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_restorecenter_disabled.gif" />
-            <File Id="file_MAESTROBIN_119" Name="icon_search.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_search.gif" />
-            <File Id="file_MAESTROBIN_120" Name="icon_search_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_search_disabled.gif" />
-            <File Id="file_MAESTROBIN_121" Name="icon_select.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_select.gif" />
-            <File Id="file_MAESTROBIN_122" Name="icon_selectpolygon.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectpolygon.gif" />
-            <File Id="file_MAESTROBIN_123" Name="icon_selectpolygon_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectpolygon_disabled.gif" />
-            <File Id="file_MAESTROBIN_124" Name="icon_selectradius.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectradius.gif" />
-            <File Id="file_MAESTROBIN_125" Name="icon_selectradius_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectradius_disabled.gif" />
-            <File Id="file_MAESTROBIN_126" Name="icon_selectwithin.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectwithin.gif" />
-            <File Id="file_MAESTROBIN_127" Name="icon_selectwithin_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectwithin_disabled.gif" />
-            <File Id="file_MAESTROBIN_128" Name="icon_select_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_select_disabled.gif" />
-            <File Id="file_MAESTROBIN_129" Name="icon_tasks.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_tasks.gif" />
-            <File Id="file_MAESTROBIN_130" Name="icon_tasks_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_tasks_disabled.gif" />
-            <File Id="file_MAESTROBIN_131" Name="icon_viewoptions.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_viewoptions.gif" />
-            <File Id="file_MAESTROBIN_132" Name="icon_viewoptions_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_viewoptions_disabled.gif" />
-            <File Id="file_MAESTROBIN_133" Name="icon_zoom.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoom.gif" />
-            <File Id="file_MAESTROBIN_134" Name="icon_zoomin.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomin.gif" />
-            <File Id="file_MAESTROBIN_135" Name="icon_zoomin_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomin_disabled.gif" />
-            <File Id="file_MAESTROBIN_136" Name="icon_zoomnext.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomnext.gif" />
-            <File Id="file_MAESTROBIN_137" Name="icon_zoomnext_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomnext_disabled.gif" />
-            <File Id="file_MAESTROBIN_138" Name="icon_zoomout.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomout.gif" />
-            <File Id="file_MAESTROBIN_139" Name="icon_zoomout_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomout_disabled.gif" />
-            <File Id="file_MAESTROBIN_140" Name="icon_zoomprev.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomprev.gif" />
-            <File Id="file_MAESTROBIN_141" Name="icon_zoomprev_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomprev_disabled.gif" />
-            <File Id="file_MAESTROBIN_142" Name="icon_zoomrect.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomrect.gif" />
-            <File Id="file_MAESTROBIN_143" Name="icon_zoomrect_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomrect_disabled.gif" />
-            <File Id="file_MAESTROBIN_144" Name="icon_zoomselect.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomselect.gif" />
-            <File Id="file_MAESTROBIN_145" Name="icon_zoomselect_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomselect_disabled.gif" />
-            <File Id="file_MAESTROBIN_146" Name="icon_zoom_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoom_disabled.gif" />
+          <Component Id="comp_MAESTROBIN_69" DiskId="1" KeyPath="yes" Guid="DB8686D0-98E2-41D0-9E3E-AC4DC6CEF101">
+            <File Id="file_MAESTROBIN_69" Name="copyright.txt" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\copyright.txt" />
+            <File Id="file_MAESTROBIN_70" Name="icon_back.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_back.gif" />
+            <File Id="file_MAESTROBIN_71" Name="icon_back_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_back_disabled.gif" />
+            <File Id="file_MAESTROBIN_72" Name="icon_buffer.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_buffer.gif" />
+            <File Id="file_MAESTROBIN_73" Name="icon_buffer_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_buffer_disabled.gif" />
+            <File Id="file_MAESTROBIN_74" Name="icon_clearselect.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_clearselect.gif" />
+            <File Id="file_MAESTROBIN_75" Name="icon_clearselect_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_clearselect_disabled.gif" />
+            <File Id="file_MAESTROBIN_76" Name="icon_copy.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_copy.gif" />
+            <File Id="file_MAESTROBIN_77" Name="icon_copy_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_copy_disabled.gif" />
+            <File Id="file_MAESTROBIN_78" Name="icon_ctxarrow.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_ctxarrow.gif" />
+            <File Id="file_MAESTROBIN_79" Name="icon_fitwindow.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_fitwindow.gif" />
+            <File Id="file_MAESTROBIN_80" Name="icon_fitwindow_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_fitwindow_disabled.gif" />
+            <File Id="file_MAESTROBIN_81" Name="icon_forward.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_forward.gif" />
+            <File Id="file_MAESTROBIN_82" Name="icon_forward_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_forward_disabled.gif" />
+            <File Id="file_MAESTROBIN_83" Name="icon_help.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_help.gif" />
+            <File Id="file_MAESTROBIN_84" Name="icon_help_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_help_disabled.gif" />
+            <File Id="file_MAESTROBIN_85" Name="icon_home.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_home.gif" />
+            <File Id="file_MAESTROBIN_86" Name="icon_home_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_home_disabled.gif" />
+            <File Id="file_MAESTROBIN_87" Name="icon_invokescript.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_invokescript.gif" />
+            <File Id="file_MAESTROBIN_88" Name="icon_invokescript_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_invokescript_disabled.gif" />
+            <File Id="file_MAESTROBIN_89" Name="icon_invokeurl.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_invokeurl.gif" />
+            <File Id="file_MAESTROBIN_90" Name="icon_invokeurl_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_invokeurl_disabled.gif" />
+            <File Id="file_MAESTROBIN_91" Name="icon_loading.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_loading.gif" />
+            <File Id="file_MAESTROBIN_92" Name="icon_measure.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_measure.gif" />
+            <File Id="file_MAESTROBIN_93" Name="icon_measure_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_measure_disabled.gif" />
+            <File Id="file_MAESTROBIN_94" Name="icon_menuarrow.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_menuarrow.gif" />
+            <File Id="file_MAESTROBIN_95" Name="icon_menuarrowup.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_menuarrowup.gif" />
+            <File Id="file_MAESTROBIN_96" Name="icon_menuarrowup_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_menuarrowup_disabled.gif" />
+            <File Id="file_MAESTROBIN_97" Name="icon_menuarrow_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_menuarrow_disabled.gif" />
+            <File Id="file_MAESTROBIN_98" Name="icon_null.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_null.gif" />
+            <File Id="file_MAESTROBIN_99" Name="icon_pan.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_pan.gif" />
+            <File Id="file_MAESTROBIN_100" Name="icon_pandown.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_pandown.gif" />
+            <File Id="file_MAESTROBIN_101" Name="icon_pandown_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_pandown_disabled.gif" />
+            <File Id="file_MAESTROBIN_102" Name="icon_panleft.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panleft.gif" />
+            <File Id="file_MAESTROBIN_103" Name="icon_panleft_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panleft_disabled.gif" />
+            <File Id="file_MAESTROBIN_104" Name="icon_panright.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panright.gif" />
+            <File Id="file_MAESTROBIN_105" Name="icon_panright_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panright_disabled.gif" />
+            <File Id="file_MAESTROBIN_106" Name="icon_panup.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panup.gif" />
+            <File Id="file_MAESTROBIN_107" Name="icon_panup_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panup_disabled.gif" />
+            <File Id="file_MAESTROBIN_108" Name="icon_pan_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_pan_disabled.gif" />
+            <File Id="file_MAESTROBIN_109" Name="icon_plotdwf.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_plotdwf.gif" />
+            <File Id="file_MAESTROBIN_110" Name="icon_plotdwf_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_plotdwf_disabled.gif" />
+            <File Id="file_MAESTROBIN_111" Name="icon_popupscrolldown.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_popupscrolldown.gif" />
+            <File Id="file_MAESTROBIN_112" Name="icon_print.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_print.gif" />
+            <File Id="file_MAESTROBIN_113" Name="icon_printablepage.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_printablepage.gif" />
+            <File Id="file_MAESTROBIN_114" Name="icon_printablepage_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_printablepage_disabled.gif" />
+            <File Id="file_MAESTROBIN_115" Name="icon_print_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_print_disabled.gif" />
+            <File Id="file_MAESTROBIN_116" Name="icon_refreshmap.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_refreshmap.gif" />
+            <File Id="file_MAESTROBIN_117" Name="icon_refreshmap_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_refreshmap_disabled.gif" />
+            <File Id="file_MAESTROBIN_118" Name="icon_restorecenter.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_restorecenter.gif" />
+            <File Id="file_MAESTROBIN_119" Name="icon_restorecenter_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_restorecenter_disabled.gif" />
+            <File Id="file_MAESTROBIN_120" Name="icon_search.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_search.gif" />
+            <File Id="file_MAESTROBIN_121" Name="icon_search_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_search_disabled.gif" />
+            <File Id="file_MAESTROBIN_122" Name="icon_select.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_select.gif" />
+            <File Id="file_MAESTROBIN_123" Name="icon_selectpolygon.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectpolygon.gif" />
+            <File Id="file_MAESTROBIN_124" Name="icon_selectpolygon_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectpolygon_disabled.gif" />
+            <File Id="file_MAESTROBIN_125" Name="icon_selectradius.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectradius.gif" />
+            <File Id="file_MAESTROBIN_126" Name="icon_selectradius_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectradius_disabled.gif" />
+            <File Id="file_MAESTROBIN_127" Name="icon_selectwithin.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectwithin.gif" />
+            <File Id="file_MAESTROBIN_128" Name="icon_selectwithin_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectwithin_disabled.gif" />
+            <File Id="file_MAESTROBIN_129" Name="icon_select_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_select_disabled.gif" />
+            <File Id="file_MAESTROBIN_130" Name="icon_tasks.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_tasks.gif" />
+            <File Id="file_MAESTROBIN_131" Name="icon_tasks_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_tasks_disabled.gif" />
+            <File Id="file_MAESTROBIN_132" Name="icon_viewoptions.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_viewoptions.gif" />
+            <File Id="file_MAESTROBIN_133" Name="icon_viewoptions_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_viewoptions_disabled.gif" />
+            <File Id="file_MAESTROBIN_134" Name="icon_zoom.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoom.gif" />
+            <File Id="file_MAESTROBIN_135" Name="icon_zoomin.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomin.gif" />
+            <File Id="file_MAESTROBIN_136" Name="icon_zoomin_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomin_disabled.gif" />
+            <File Id="file_MAESTROBIN_137" Name="icon_zoomnext.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomnext.gif" />
+            <File Id="file_MAESTROBIN_138" Name="icon_zoomnext_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomnext_disabled.gif" />
+            <File Id="file_MAESTROBIN_139" Name="icon_zoomout.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomout.gif" />
+            <File Id="file_MAESTROBIN_140" Name="icon_zoomout_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomout_disabled.gif" />
+            <File Id="file_MAESTROBIN_141" Name="icon_zoomprev.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomprev.gif" />
+            <File Id="file_MAESTROBIN_142" Name="icon_zoomprev_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomprev_disabled.gif" />
+            <File Id="file_MAESTROBIN_143" Name="icon_zoomrect.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomrect.gif" />
+            <File Id="file_MAESTROBIN_144" Name="icon_zoomrect_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomrect_disabled.gif" />
+            <File Id="file_MAESTROBIN_145" Name="icon_zoomselect.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomselect.gif" />
+            <File Id="file_MAESTROBIN_146" Name="icon_zoomselect_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomselect_disabled.gif" />
+            <File Id="file_MAESTROBIN_147" Name="icon_zoom_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoom_disabled.gif" />
           </Component>
         </Directory>
         <Directory Id="dir_MapGuideMaestro_Templates_3" Name="Templates">
-          <Component Id="comp_MAESTROBIN_147" DiskId="1" KeyPath="yes" Guid="7B53F848-F711-480C-865C-9DD1C5090D60">
-            <File Id="file_MAESTROBIN_147" Name="Dataconnection.FeatureSource" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Dataconnection.FeatureSource" />
-            <File Id="file_MAESTROBIN_148" Name="Fusion Application.ApplicationDefinition" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Fusion Application.ApplicationDefinition" />
-            <File Id="file_MAESTROBIN_149" Name="Layer.LayerDefinition" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Layer.LayerDefinition" />
-            <File Id="file_MAESTROBIN_150" Name="Layout.WebLayout" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Layout.WebLayout" />
-            <File Id="file_MAESTROBIN_151" Name="Map.MapDefinition" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Map.MapDefinition" />
-            <File Id="file_MAESTROBIN_152" Name="Print Layout.PrintLayout" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Print Layout.PrintLayout" />
-            <File Id="file_MAESTROBIN_153" Name="Symbol Definition.SymbolDefinition" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Symbol Definition.SymbolDefinition" />
-            <File Id="file_MAESTROBIN_154" Name="Symbol Library.SymbolLibrary" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Symbol Library.SymbolLibrary" />
+          <Component Id="comp_MAESTROBIN_148" DiskId="1" KeyPath="yes" Guid="7D523846-878A-4D79-86BE-93DC837966DE">
+            <File Id="file_MAESTROBIN_148" Name="Dataconnection.FeatureSource" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Dataconnection.FeatureSource" />
+            <File Id="file_MAESTROBIN_149" Name="Fusion Application.ApplicationDefinition" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Fusion Application.ApplicationDefinition" />
+            <File Id="file_MAESTROBIN_150" Name="Layer.LayerDefinition" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Layer.LayerDefinition" />
+            <File Id="file_MAESTROBIN_151" Name="Layout.WebLayout" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Layout.WebLayout" />
+            <File Id="file_MAESTROBIN_152" Name="Map.MapDefinition" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Map.MapDefinition" />
+            <File Id="file_MAESTROBIN_153" Name="Print Layout.PrintLayout" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Print Layout.PrintLayout" />
+            <File Id="file_MAESTROBIN_154" Name="Symbol Definition.SymbolDefinition" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Symbol Definition.SymbolDefinition" />
+            <File Id="file_MAESTROBIN_155" Name="Symbol Library.SymbolLibrary" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Symbol Library.SymbolLibrary" />
           </Component>
         </Directory>
         <Directory Id="dir_MapGuideMaestro_WebStudio_4" Name="WebStudio">
-          <Component Id="comp_MAESTROBIN_155" DiskId="1" KeyPath="yes" Guid="F289C6B9-6757-462D-A0D9-EEF6EC4C7B44">
-            <File Id="file_MAESTROBIN_155" Name="copyright.txt" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\copyright.txt" />
+          <Component Id="comp_MAESTROBIN_156" DiskId="1" KeyPath="yes" Guid="BF1E1737-C128-468E-B761-AE841B9E862B">
+            <File Id="file_MAESTROBIN_156" Name="copyright.txt" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\copyright.txt" />
           </Component>
           <Directory Id="dir_MapGuideMaestro_WebStudio_areas_5" Name="areas">
-            <Component Id="comp_MAESTROBIN_156" DiskId="1" KeyPath="yes" Guid="474B51EF-F145-4119-903D-E2C0DF4831A8">
-              <File Id="file_MAESTROBIN_156" Name="Acad_iso02w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso02w100.png" />
-              <File Id="file_MAESTROBIN_157" Name="Acad_iso03w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso03w100.png" />
-              <File Id="file_MAESTROBIN_158" Name="Acad_iso04w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso04w100.png" />
-              <File Id="file_MAESTROBIN_159" Name="Acad_iso05w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso05w100.png" />
-              <File Id="file_MAESTROBIN_160" Name="Acad_iso06w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso06w100.png" />
-              <File Id="file_MAESTROBIN_161" Name="Acad_iso07w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso07w100.png" />
-              <File Id="file_MAESTROBIN_162" Name="Acad_iso08w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso08w100.png" />
-              <File Id="file_MAESTROBIN_163" Name="Acad_iso09w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso09w100.png" />
-              <File Id="file_MAESTROBIN_164" Name="Acad_iso10w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso10w100.png" />
-              <File Id="file_MAESTROBIN_165" Name="Acad_iso11w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso11w100.png" />
-              <File Id="file_MAESTROBIN_166" Name="Acad_iso12w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso12w100.png" />
-              <File Id="file_MAESTROBIN_167" Name="Acad_iso13w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso13w100.png" />
-              <File Id="file_MAESTROBIN_168" Name="Acad_iso14w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso14w100.png" />
-              <File Id="file_MAESTROBIN_169" Name="Acad_iso15w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso15w100.png" />
-              <File Id="file_MAESTROBIN_170" Name="Angle.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Angle.png" />
-              <File Id="file_MAESTROBIN_171" Name="Ansi31.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi31.png" />
-              <File Id="file_MAESTROBIN_172" Name="Ansi32.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi32.png" />
-              <File Id="file_MAESTROBIN_173" Name="Ansi33.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi33.png" />
-              <File Id="file_MAESTROBIN_174" Name="Ansi34.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi34.png" />
-              <File Id="file_MAESTROBIN_175" Name="Ansi35.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi35.png" />
-              <File Id="file_MAESTROBIN_176" Name="Ansi36.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi36.png" />
-              <File Id="file_MAESTROBIN_177" Name="Ansi37.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi37.png" />
-              <File Id="file_MAESTROBIN_178" Name="Ansi38.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi38.png" />
-              <File Id="file_MAESTROBIN_179" Name="Ar_b816.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b816.png" />
-              <File Id="file_MAESTROBIN_180" Name="Ar_b816c.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b816c.png" />
-              <File Id="file_MAESTROBIN_181" Name="Ar_b88.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b88.png" />
-              <File Id="file_MAESTROBIN_182" Name="Ar_brelm.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_brelm.png" />
-              <File Id="file_MAESTROBIN_183" Name="Ar_brstd.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_brstd.png" />
-              <File Id="file_MAESTROBIN_184" Name="Ar_conc.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_conc.png" />
-              <File Id="file_MAESTROBIN_185" Name="Ar_hbone.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_hbone.png" />
-              <File Id="file_MAESTROBIN_186" Name="Ar_parq1.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_parq1.png" />
-              <File Id="file_MAESTROBIN_187" Name="Ar_rroof.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rroof.png" />
-              <File Id="file_MAESTROBIN_188" Name="Ar_rroof_90.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rroof_90.png" />
-              <File Id="file_MAESTROBIN_189" Name="Ar_rshke.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke.png" />
-              <File Id="file_MAESTROBIN_190" Name="Ar_rshke_180.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_180.png" />
-              <File Id="file_MAESTROBIN_191" Name="Ar_rshke_270.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_270.png" />
-              <File Id="file_MAESTROBIN_192" Name="Ar_rshke_90.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_90.png" />
-              <File Id="file_MAESTROBIN_193" Name="Ar_sand.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_sand.png" />
-              <File Id="file_MAESTROBIN_194" Name="Box.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Box.png" />
-              <File Id="file_MAESTROBIN_195" Name="Brass.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brass.png" />
-              <File Id="file_MAESTROBIN_196" Name="Brick.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brick.png" />
-              <File Id="file_MAESTROBIN_197" Name="Brstone.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brstone.png" />
-              <File Id="file_MAESTROBIN_198" Name="Clay.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Clay.png" />
-              <File Id="file_MAESTROBIN_199" Name="Cork.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Cork.png" />
-              <File Id="file_MAESTROBIN_200" Name="Cross.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Cross.png" />
-              <File Id="file_MAESTROBIN_201" Name="Dash.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dash.png" />
-              <File Id="file_MAESTROBIN_202" Name="Dolmit.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dolmit.png" />
-              <File Id="file_MAESTROBIN_203" Name="Dots.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dots.png" />
-              <File Id="file_MAESTROBIN_204" Name="Earth.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Earth.png" />
-              <File Id="file_MAESTROBIN_205" Name="Escher.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Escher.png" />
-              <File Id="file_MAESTROBIN_206" Name="Flex.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Flex.png" />
-              <File Id="file_MAESTROBIN_207" Name="Grass.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Grass.png" />
-              <File Id="file_MAESTROBIN_208" Name="Grate.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Grate.png" />
-              <File Id="file_MAESTROBIN_209" Name="Hex.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Hex.png" />
-              <File Id="file_MAESTROBIN_210" Name="Honey.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Honey.png" />
-              <File Id="file_MAESTROBIN_211" Name="Hound.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Hound.png" />
-              <File Id="file_MAESTROBIN_212" Name="Insul.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Insul.png" />
-              <File Id="file_MAESTROBIN_213" Name="Line.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line.png" />
-              <File Id="file_MAESTROBIN_214" Name="Line_135.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_135.png" />
-              <File Id="file_MAESTROBIN_215" Name="Line_45.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_45.png" />
-              <File Id="file_MAESTROBIN_216" Name="Line_90.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_90.png" />
-              <File Id="file_MAESTROBIN_217" Name="Mudst.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Mudst.png" />
-              <File Id="file_MAESTROBIN_218" Name="Net.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net.png" />
-              <File Id="file_MAESTROBIN_219" Name="Net3.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net3.png" />
-              <File Id="file_MAESTROBIN_220" Name="Net_45.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net_45.png" />
-              <File Id="file_MAESTROBIN_221" Name="Plast.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Plast.png" />
-              <File Id="file_MAESTROBIN_222" Name="Plasti.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Plasti.png" />
-              <File Id="file_MAESTROBIN_223" Name="Sacncr.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Sacncr.png" />
-              <File Id="file_MAESTROBIN_224" Name="Shapefill12.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill12.png" />
-              <File Id="file_MAESTROBIN_225" Name="Shapefill13.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill13.png" />
-              <File Id="file_MAESTROBIN_226" Name="Shapefill14.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill14.png" />
-              <File Id="file_MAESTROBIN_227" Name="Shapefill15.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill15.png" />
-              <File Id="file_MAESTROBIN_228" Name="Shapefill16.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill16.png" />
-              <File Id="file_MAESTROBIN_229" Name="Shapefill17.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill17.png" />
-              <File Id="file_MAESTROBIN_230" Name="Shapefill18.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill18.png" />
-              <File Id="file_MAESTROBIN_231" Name="Shapefill19.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill19.png" />
-              <File Id="file_MAESTROBIN_232" Name="Shapefill20.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill20.png" />
-              <File Id="file_MAESTROBIN_233" Name="Shapefill21.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill21.png" />
-              <File Id="file_MAESTROBIN_234" Name="Shapefill22.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill22.png" />
-              <File Id="file_MAESTROBIN_235" Name="Shapefill23.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill23.png" />
-              <File Id="file_MAESTROBIN_236" Name="Shapefill24.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill24.png" />
-              <File Id="file_MAESTROBIN_237" Name="Shapefill25.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill25.png" />
-              <File Id="file_MAESTROBIN_238" Name="Shapefill26.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill26.png" />
-              <File Id="file_MAESTROBIN_239" Name="Shapefill27.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill27.png" />
-              <File Id="file_MAESTROBIN_240" Name="Shapefill28.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill28.png" />
-              <File Id="file_MAESTROBIN_241" Name="Shapefill29.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill29.png" />
-              <File Id="file_MAESTROBIN_242" Name="Shapefill30.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill30.png" />
-              <File Id="file_MAESTROBIN_243" Name="Shapefill31.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill31.png" />
-              <File Id="file_MAESTROBIN_244" Name="Shapefill32.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill32.png" />
-              <File Id="file_MAESTROBIN_245" Name="Shapefill33.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill33.png" />
-              <File Id="file_MAESTROBIN_246" Name="Shapefill34.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill34.png" />
-              <File Id="file_MAESTROBIN_247" Name="Shapefill35.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill35.png" />
-              <File Id="file_MAESTROBIN_248" Name="Shapefill36.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill36.png" />
-              <File Id="file_MAESTROBIN_249" Name="Shapefill37.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill37.png" />
-              <File Id="file_MAESTROBIN_250" Name="Shapefill38.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill38.png" />
-              <File Id="file_MAESTROBIN_251" Name="Shapefill39.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill39.png" />
-              <File Id="file_MAESTROBIN_252" Name="Shapefill40.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill40.png" />
-              <File Id="file_MAESTROBIN_253" Name="Shapefill41.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill41.png" />
-              <File Id="file_MAESTROBIN_254" Name="Shapefill42.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill42.png" />
-              <File Id="file_MAESTROBIN_255" Name="Shapefill43.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill43.png" />
-              <File Id="file_MAESTROBIN_256" Name="Shapefill44.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill44.png" />
-              <File Id="file_MAESTROBIN_257" Name="Shapefill45.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill45.png" />
-              <File Id="file_MAESTROBIN_258" Name="Shapefill46.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill46.png" />
-              <File Id="file_MAESTROBIN_259" Name="Shapefill47.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill47.png" />
-              <File Id="file_MAESTROBIN_260" Name="Shapefill48.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill48.png" />
-              <File Id="file_MAESTROBIN_261" Name="Shapefill49.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill49.png" />
-              <File Id="file_MAESTROBIN_262" Name="Shapefill50.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill50.png" />
-              <File Id="file_MAESTROBIN_263" Name="Shapefill51.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill51.png" />
-              <File Id="file_MAESTROBIN_264" Name="Shapefill52.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill52.png" />
-              <File Id="file_MAESTROBIN_265" Name="Shapefill53.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill53.png" />
-              <File Id="file_MAESTROBIN_266" Name="Shapefill54.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill54.png" />
-              <File Id="file_MAESTROBIN_267" Name="Shapefill55.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill55.png" />
-              <File Id="file_MAESTROBIN_268" Name="Shapefill56.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill56.png" />
-              <File Id="file_MAESTROBIN_269" Name="Shapefill57.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill57.png" />
-              <File Id="file_MAESTROBIN_270" Name="Shapefill58.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill58.png" />
-              <File Id="file_MAESTROBIN_271" Name="Shapefill59.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill59.png" />
-              <File Id="file_MAESTROBIN_272" Name="Shapefill60.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill60.png" />
-              <File Id="file_MAESTROBIN_273" Name="Shapefill61.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill61.png" />
-              <File Id="file_MAESTROBIN_274" Name="Shapefill62.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill62.png" />
-              <File Id="file_MAESTROBIN_275" Name="Shapefill63.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill63.png" />
-              <File Id="file_MAESTROBIN_276" Name="Shapefill64.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill64.png" />
-              <File Id="file_MAESTROBIN_277" Name="Shapefill65.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill65.png" />
-              <File Id="file_MAESTROBIN_278" Name="Shapefill66.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill66.png" />
-              <File Id="file_MAESTROBIN_279" Name="Shapefill67.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill67.png" />
-              <File Id="file_MAESTROBIN_280" Name="Shapefill68.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill68.png" />
-              <File Id="file_MAESTROBIN_281" Name="Shapefill69.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill69.png" />
-              <File Id="file_MAESTROBIN_282" Name="Shapefill70.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill70.png" />
-              <File Id="file_MAESTROBIN_283" Name="Shapefill71.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill71.png" />
-              <File Id="file_MAESTROBIN_284" Name="Solid.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Solid.png" />
-              <File Id="file_MAESTROBIN_285" Name="Square.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Square.png" />
-              <File Id="file_MAESTROBIN_286" Name="Stars.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Stars.png" />
-              <File Id="file_MAESTROBIN_287" Name="Steel.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Steel.png" />
-              <File Id="file_MAESTROBIN_288" Name="Swamp.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Swamp.png" />
-              <File Id="file_MAESTROBIN_289" Name="Trans.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Trans.png" />
-              <File Id="file_MAESTROBIN_290" Name="Triang.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Triang.png" />
-              <File Id="file_MAESTROBIN_291" Name="Zigzag.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Zigzag.png" />
+            <Component Id="comp_MAESTROBIN_157" DiskId="1" KeyPath="yes" Guid="51AE0BB4-7969-4D39-B049-FD5741321E37">
+              <File Id="file_MAESTROBIN_157" Name="Acad_iso02w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso02w100.png" />
+              <File Id="file_MAESTROBIN_158" Name="Acad_iso03w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso03w100.png" />
+              <File Id="file_MAESTROBIN_159" Name="Acad_iso04w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso04w100.png" />
+              <File Id="file_MAESTROBIN_160" Name="Acad_iso05w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso05w100.png" />
+              <File Id="file_MAESTROBIN_161" Name="Acad_iso06w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso06w100.png" />
+              <File Id="file_MAESTROBIN_162" Name="Acad_iso07w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso07w100.png" />
+              <File Id="file_MAESTROBIN_163" Name="Acad_iso08w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso08w100.png" />
+              <File Id="file_MAESTROBIN_164" Name="Acad_iso09w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso09w100.png" />
+              <File Id="file_MAESTROBIN_165" Name="Acad_iso10w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso10w100.png" />
+              <File Id="file_MAESTROBIN_166" Name="Acad_iso11w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso11w100.png" />
+              <File Id="file_MAESTROBIN_167" Name="Acad_iso12w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso12w100.png" />
+              <File Id="file_MAESTROBIN_168" Name="Acad_iso13w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso13w100.png" />
+              <File Id="file_MAESTROBIN_169" Name="Acad_iso14w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso14w100.png" />
+              <File Id="file_MAESTROBIN_170" Name="Acad_iso15w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso15w100.png" />
+              <File Id="file_MAESTROBIN_171" Name="Angle.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Angle.png" />
+              <File Id="file_MAESTROBIN_172" Name="Ansi31.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi31.png" />
+              <File Id="file_MAESTROBIN_173" Name="Ansi32.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi32.png" />
+              <File Id="file_MAESTROBIN_174" Name="Ansi33.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi33.png" />
+              <File Id="file_MAESTROBIN_175" Name="Ansi34.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi34.png" />
+              <File Id="file_MAESTROBIN_176" Name="Ansi35.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi35.png" />
+              <File Id="file_MAESTROBIN_177" Name="Ansi36.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi36.png" />
+              <File Id="file_MAESTROBIN_178" Name="Ansi37.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi37.png" />
+              <File Id="file_MAESTROBIN_179" Name="Ansi38.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi38.png" />
+              <File Id="file_MAESTROBIN_180" Name="Ar_b816.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b816.png" />
+              <File Id="file_MAESTROBIN_181" Name="Ar_b816c.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b816c.png" />
+              <File Id="file_MAESTROBIN_182" Name="Ar_b88.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b88.png" />
+              <File Id="file_MAESTROBIN_183" Name="Ar_brelm.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_brelm.png" />
+              <File Id="file_MAESTROBIN_184" Name="Ar_brstd.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_brstd.png" />
+              <File Id="file_MAESTROBIN_185" Name="Ar_conc.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_conc.png" />
+              <File Id="file_MAESTROBIN_186" Name="Ar_hbone.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_hbone.png" />
+              <File Id="file_MAESTROBIN_187" Name="Ar_parq1.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_parq1.png" />
+              <File Id="file_MAESTROBIN_188" Name="Ar_rroof.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rroof.png" />
+              <File Id="file_MAESTROBIN_189" Name="Ar_rroof_90.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rroof_90.png" />
+              <File Id="file_MAESTROBIN_190" Name="Ar_rshke.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke.png" />
+              <File Id="file_MAESTROBIN_191" Name="Ar_rshke_180.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_180.png" />
+              <File Id="file_MAESTROBIN_192" Name="Ar_rshke_270.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_270.png" />
+              <File Id="file_MAESTROBIN_193" Name="Ar_rshke_90.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_90.png" />
+              <File Id="file_MAESTROBIN_194" Name="Ar_sand.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_sand.png" />
+              <File Id="file_MAESTROBIN_195" Name="Box.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Box.png" />
+              <File Id="file_MAESTROBIN_196" Name="Brass.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brass.png" />
+              <File Id="file_MAESTROBIN_197" Name="Brick.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brick.png" />
+              <File Id="file_MAESTROBIN_198" Name="Brstone.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brstone.png" />
+              <File Id="file_MAESTROBIN_199" Name="Clay.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Clay.png" />
+              <File Id="file_MAESTROBIN_200" Name="Cork.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Cork.png" />
+              <File Id="file_MAESTROBIN_201" Name="Cross.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Cross.png" />
+              <File Id="file_MAESTROBIN_202" Name="Dash.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dash.png" />
+              <File Id="file_MAESTROBIN_203" Name="Dolmit.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dolmit.png" />
+              <File Id="file_MAESTROBIN_204" Name="Dots.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dots.png" />
+              <File Id="file_MAESTROBIN_205" Name="Earth.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Earth.png" />
+              <File Id="file_MAESTROBIN_206" Name="Escher.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Escher.png" />
+              <File Id="file_MAESTROBIN_207" Name="Flex.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Flex.png" />
+              <File Id="file_MAESTROBIN_208" Name="Grass.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Grass.png" />
+              <File Id="file_MAESTROBIN_209" Name="Grate.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Grate.png" />
+              <File Id="file_MAESTROBIN_210" Name="Hex.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Hex.png" />
+              <File Id="file_MAESTROBIN_211" Name="Honey.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Honey.png" />
+              <File Id="file_MAESTROBIN_212" Name="Hound.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Hound.png" />
+              <File Id="file_MAESTROBIN_213" Name="Insul.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Insul.png" />
+              <File Id="file_MAESTROBIN_214" Name="Line.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line.png" />
+              <File Id="file_MAESTROBIN_215" Name="Line_135.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_135.png" />
+              <File Id="file_MAESTROBIN_216" Name="Line_45.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_45.png" />
+              <File Id="file_MAESTROBIN_217" Name="Line_90.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_90.png" />
+              <File Id="file_MAESTROBIN_218" Name="Mudst.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Mudst.png" />
+              <File Id="file_MAESTROBIN_219" Name="Net.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net.png" />
+              <File Id="file_MAESTROBIN_220" Name="Net3.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net3.png" />
+              <File Id="file_MAESTROBIN_221" Name="Net_45.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net_45.png" />
+              <File Id="file_MAESTROBIN_222" Name="Plast.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Plast.png" />
+              <File Id="file_MAESTROBIN_223" Name="Plasti.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Plasti.png" />
+              <File Id="file_MAESTROBIN_224" Name="Sacncr.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Sacncr.png" />
+              <File Id="file_MAESTROBIN_225" Name="Shapefill12.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill12.png" />
+              <File Id="file_MAESTROBIN_226" Name="Shapefill13.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill13.png" />
+              <File Id="file_MAESTROBIN_227" Name="Shapefill14.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill14.png" />
+              <File Id="file_MAESTROBIN_228" Name="Shapefill15.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill15.png" />
+              <File Id="file_MAESTROBIN_229" Name="Shapefill16.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill16.png" />
+              <File Id="file_MAESTROBIN_230" Name="Shapefill17.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill17.png" />
+              <File Id="file_MAESTROBIN_231" Name="Shapefill18.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill18.png" />
+              <File Id="file_MAESTROBIN_232" Name="Shapefill19.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill19.png" />
+              <File Id="file_MAESTROBIN_233" Name="Shapefill20.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill20.png" />
+              <File Id="file_MAESTROBIN_234" Name="Shapefill21.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill21.png" />
+              <File Id="file_MAESTROBIN_235" Name="Shapefill22.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill22.png" />
+              <File Id="file_MAESTROBIN_236" Name="Shapefill23.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill23.png" />
+              <File Id="file_MAESTROBIN_237" Name="Shapefill24.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill24.png" />
+              <File Id="file_MAESTROBIN_238" Name="Shapefill25.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill25.png" />
+              <File Id="file_MAESTROBIN_239" Name="Shapefill26.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill26.png" />
+              <File Id="file_MAESTROBIN_240" Name="Shapefill27.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill27.png" />
+              <File Id="file_MAESTROBIN_241" Name="Shapefill28.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill28.png" />
+              <File Id="file_MAESTROBIN_242" Name="Shapefill29.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill29.png" />
+              <File Id="file_MAESTROBIN_243" Name="Shapefill30.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill30.png" />
+              <File Id="file_MAESTROBIN_244" Name="Shapefill31.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill31.png" />
+              <File Id="file_MAESTROBIN_245" Name="Shapefill32.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill32.png" />
+              <File Id="file_MAESTROBIN_246" Name="Shapefill33.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill33.png" />
+              <File Id="file_MAESTROBIN_247" Name="Shapefill34.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill34.png" />
+              <File Id="file_MAESTROBIN_248" Name="Shapefill35.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill35.png" />
+              <File Id="file_MAESTROBIN_249" Name="Shapefill36.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill36.png" />
+              <File Id="file_MAESTROBIN_250" Name="Shapefill37.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill37.png" />
+              <File Id="file_MAESTROBIN_251" Name="Shapefill38.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill38.png" />
+              <File Id="file_MAESTROBIN_252" Name="Shapefill39.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill39.png" />
+              <File Id="file_MAESTROBIN_253" Name="Shapefill40.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill40.png" />
+              <File Id="file_MAESTROBIN_254" Name="Shapefill41.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill41.png" />
+              <File Id="file_MAESTROBIN_255" Name="Shapefill42.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill42.png" />
+              <File Id="file_MAESTROBIN_256" Name="Shapefill43.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill43.png" />
+              <File Id="file_MAESTROBIN_257" Name="Shapefill44.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill44.png" />
+              <File Id="file_MAESTROBIN_258" Name="Shapefill45.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill45.png" />
+              <File Id="file_MAESTROBIN_259" Name="Shapefill46.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill46.png" />
+              <File Id="file_MAESTROBIN_260" Name="Shapefill47.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill47.png" />
+              <File Id="file_MAESTROBIN_261" Name="Shapefill48.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill48.png" />
+              <File Id="file_MAESTROBIN_262" Name="Shapefill49.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill49.png" />
+              <File Id="file_MAESTROBIN_263" Name="Shapefill50.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill50.png" />
+              <File Id="file_MAESTROBIN_264" Name="Shapefill51.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill51.png" />
+              <File Id="file_MAESTROBIN_265" Name="Shapefill52.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill52.png" />
+              <File Id="file_MAESTROBIN_266" Name="Shapefill53.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill53.png" />
+              <File Id="file_MAESTROBIN_267" Name="Shapefill54.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill54.png" />
+              <File Id="file_MAESTROBIN_268" Name="Shapefill55.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill55.png" />
+              <File Id="file_MAESTROBIN_269" Name="Shapefill56.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill56.png" />
+              <File Id="file_MAESTROBIN_270" Name="Shapefill57.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill57.png" />
+              <File Id="file_MAESTROBIN_271" Name="Shapefill58.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill58.png" />
+              <File Id="file_MAESTROBIN_272" Name="Shapefill59.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill59.png" />
+              <File Id="file_MAESTROBIN_273" Name="Shapefill60.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill60.png" />
+              <File Id="file_MAESTROBIN_274" Name="Shapefill61.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill61.png" />
+              <File Id="file_MAESTROBIN_275" Name="Shapefill62.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill62.png" />
+              <File Id="file_MAESTROBIN_276" Name="Shapefill63.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill63.png" />
+              <File Id="file_MAESTROBIN_277" Name="Shapefill64.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill64.png" />
+              <File Id="file_MAESTROBIN_278" Name="Shapefill65.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill65.png" />
+              <File Id="file_MAESTROBIN_279" Name="Shapefill66.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill66.png" />
+              <File Id="file_MAESTROBIN_280" Name="Shapefill67.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill67.png" />
+              <File Id="file_MAESTROBIN_281" Name="Shapefill68.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill68.png" />
+              <File Id="file_MAESTROBIN_282" Name="Shapefill69.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill69.png" />
+              <File Id="file_MAESTROBIN_283" Name="Shapefill70.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill70.png" />
+              <File Id="file_MAESTROBIN_284" Name="Shapefill71.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill71.png" />
+              <File Id="file_MAESTROBIN_285" Name="Solid.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Solid.png" />
+              <File Id="file_MAESTROBIN_286" Name="Square.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Square.png" />
+              <File Id="file_MAESTROBIN_287" Name="Stars.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Stars.png" />
+              <File Id="file_MAESTROBIN_288" Name="Steel.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Steel.png" />
+              <File Id="file_MAESTROBIN_289" Name="Swamp.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Swamp.png" />
+              <File Id="file_MAESTROBIN_290" Name="Trans.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Trans.png" />
+              <File Id="file_MAESTROBIN_291" Name="Triang.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Triang.png" />
+              <File Id="file_MAESTROBIN_292" Name="Zigzag.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Zigzag.png" />
             </Component>
           </Directory>
           <Directory Id="dir_MapGuideMaestro_WebStudio_lines_6" Name="lines">
-            <Component Id="comp_MAESTROBIN_292" DiskId="1" KeyPath="yes" Guid="DBAA4553-5E9A-4500-8DF9-FCD719DD996A">
-              <File Id="file_MAESTROBIN_292" Name="ACAD_ISO02W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO02W100.png" />
-              <File Id="file_MAESTROBIN_293" Name="ACAD_ISO03W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO03W100.png" />
-              <File Id="file_MAESTROBIN_294" Name="ACAD_ISO04W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO04W100.png" />
-              <File Id="file_MAESTROBIN_295" Name="ACAD_ISO05W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO05W100.png" />
-              <File Id="file_MAESTROBIN_296" Name="ACAD_ISO06W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO06W100.png" />
-              <File Id="file_MAESTROBIN_297" Name="ACAD_ISO07W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO07W100.png" />
-              <File Id="file_MAESTROBIN_298" Name="ACAD_ISO08W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO08W100.png" />
-              <File Id="file_MAESTROBIN_299" Name="ACAD_ISO09W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO09W100.png" />
-              <File Id="file_MAESTROBIN_300" Name="ACAD_ISO10W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO10W100.png" />
-              <File Id="file_MAESTROBIN_301" Name="ACAD_ISO11W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO11W100.png" />
-              <File Id="file_MAESTROBIN_302" Name="ACAD_ISO12W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO12W100.png" />
-              <File Id="file_MAESTROBIN_303" Name="ACAD_ISO13W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO13W100.png" />
-              <File Id="file_MAESTROBIN_304" Name="ACAD_ISO14W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO14W100.png" />
-              <File Id="file_MAESTROBIN_305" Name="ACAD_ISO15W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO15W100.png" />
-              <File Id="file_MAESTROBIN_306" Name="BORDER.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDER.png" />
-              <File Id="file_MAESTROBIN_307" Name="BORDER2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDER2.png" />
-              <File Id="file_MAESTROBIN_308" Name="BORDERX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDERX2.png" />
-              <File Id="file_MAESTROBIN_309" Name="CENTER.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTER.png" />
-              <File Id="file_MAESTROBIN_310" Name="CENTER2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTER2.png" />
-              <File Id="file_MAESTROBIN_311" Name="CENTERX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTERX2.png" />
-              <File Id="file_MAESTROBIN_312" Name="Dash.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Dash.png" />
-              <File Id="file_MAESTROBIN_313" Name="DashDot.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DashDot.png" />
-              <File Id="file_MAESTROBIN_314" Name="DASHDOT2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOT2.png" />
-              <File Id="file_MAESTROBIN_315" Name="DASHDOT3.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOT3.png" />
-              <File Id="file_MAESTROBIN_316" Name="DashDotDot.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DashDotDot.png" />
-              <File Id="file_MAESTROBIN_317" Name="DASHDOTX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOTX2.png" />
-              <File Id="file_MAESTROBIN_318" Name="DASHED.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHED.png" />
-              <File Id="file_MAESTROBIN_319" Name="DASHED2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHED2.png" />
-              <File Id="file_MAESTROBIN_320" Name="DASHEDX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHEDX2.png" />
-              <File Id="file_MAESTROBIN_321" Name="DIVIDE.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDE.png" />
-              <File Id="file_MAESTROBIN_322" Name="DIVIDE2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDE2.png" />
-              <File Id="file_MAESTROBIN_323" Name="DIVIDEX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDEX2.png" />
-              <File Id="file_MAESTROBIN_324" Name="Dot.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Dot.png" />
-              <File Id="file_MAESTROBIN_325" Name="DOT2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOT2.png" />
-              <File Id="file_MAESTROBIN_326" Name="DOT3.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOT3.png" />
-              <File Id="file_MAESTROBIN_327" Name="DOTX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOTX2.png" />
-              <File Id="file_MAESTROBIN_328" Name="FENCELINE1.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\FENCELINE1.png" />
-              <File Id="file_MAESTROBIN_329" Name="FENCELINE2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\FENCELINE2.png" />
-              <File Id="file_MAESTROBIN_330" Name="HIDDEN.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDEN.png" />
-              <File Id="file_MAESTROBIN_331" Name="HIDDEN2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDEN2.png" />
-              <File Id="file_MAESTROBIN_332" Name="HIDDENX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDENX2.png" />
-              <File Id="file_MAESTROBIN_333" Name="LINE03.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE03.png" />
-              <File Id="file_MAESTROBIN_334" Name="LINE04.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE04.png" />
-              <File Id="file_MAESTROBIN_335" Name="LINE05.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE05.png" />
-              <File Id="file_MAESTROBIN_336" Name="LINE06.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE06.png" />
-              <File Id="file_MAESTROBIN_337" Name="LINE07.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE07.png" />
-              <File Id="file_MAESTROBIN_338" Name="LINE08.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE08.png" />
-              <File Id="file_MAESTROBIN_339" Name="LINE09.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE09.png" />
-              <File Id="file_MAESTROBIN_340" Name="LINE10.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE10.png" />
-              <File Id="file_MAESTROBIN_341" Name="LINE11.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE11.png" />
-              <File Id="file_MAESTROBIN_342" Name="LINE12.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE12.png" />
-              <File Id="file_MAESTROBIN_343" Name="LINE13.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE13.png" />
-              <File Id="file_MAESTROBIN_344" Name="LINE14.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE14.png" />
-              <File Id="file_MAESTROBIN_345" Name="LINE15.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE15.png" />
-              <File Id="file_MAESTROBIN_346" Name="LINE16.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE16.png" />
-              <File Id="file_MAESTROBIN_347" Name="LINE17.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE17.png" />
-              <File Id="file_MAESTROBIN_348" Name="LINE18.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE18.png" />
-              <File Id="file_MAESTROBIN_349" Name="LINE19.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE19.png" />
-              <File Id="file_MAESTROBIN_350" Name="LINE20.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE20.png" />
-              <File Id="file_MAESTROBIN_351" Name="LINE21.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE21.png" />
-              <File Id="file_MAESTROBIN_352" Name="LINE22.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE22.png" />
-              <File Id="file_MAESTROBIN_353" Name="LINE23.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE23.png" />
-              <File Id="file_MAESTROBIN_354" Name="LINE24.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE24.png" />
-              <File Id="file_MAESTROBIN_355" Name="LINE25.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE25.png" />
-              <File Id="file_MAESTROBIN_356" Name="PHANTOM.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOM.png" />
-              <File Id="file_MAESTROBIN_357" Name="PHANTOM2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOM2.png" />
-              <File Id="file_MAESTROBIN_358" Name="PHANTOMX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOMX2.png" />
-              <File Id="file_MAESTROBIN_359" Name="Rail.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Rail.png" />
-              <File Id="file_MAESTROBIN_360" Name="Solid.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Solid.png" />
-              <File Id="file_MAESTROBIN_361" Name="TRACKS.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\TRACKS.png" />
+            <Component Id="comp_MAESTROBIN_293" DiskId="1" KeyPath="yes" Guid="2FD3170C-89D4-484D-BD8B-E4FBAD466F1A">
+              <File Id="file_MAESTROBIN_293" Name="ACAD_ISO02W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO02W100.png" />
+              <File Id="file_MAESTROBIN_294" Name="ACAD_ISO03W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO03W100.png" />
+              <File Id="file_MAESTROBIN_295" Name="ACAD_ISO04W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO04W100.png" />
+              <File Id="file_MAESTROBIN_296" Name="ACAD_ISO05W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO05W100.png" />
+              <File Id="file_MAESTROBIN_297" Name="ACAD_ISO06W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO06W100.png" />
+              <File Id="file_MAESTROBIN_298" Name="ACAD_ISO07W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO07W100.png" />
+              <File Id="file_MAESTROBIN_299" Name="ACAD_ISO08W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO08W100.png" />
+              <File Id="file_MAESTROBIN_300" Name="ACAD_ISO09W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO09W100.png" />
+              <File Id="file_MAESTROBIN_301" Name="ACAD_ISO10W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO10W100.png" />
+              <File Id="file_MAESTROBIN_302" Name="ACAD_ISO11W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO11W100.png" />
+              <File Id="file_MAESTROBIN_303" Name="ACAD_ISO12W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO12W100.png" />
+              <File Id="file_MAESTROBIN_304" Name="ACAD_ISO13W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO13W100.png" />
+              <File Id="file_MAESTROBIN_305" Name="ACAD_ISO14W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO14W100.png" />
+              <File Id="file_MAESTROBIN_306" Name="ACAD_ISO15W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO15W100.png" />
+              <File Id="file_MAESTROBIN_307" Name="BORDER.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDER.png" />
+              <File Id="file_MAESTROBIN_308" Name="BORDER2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDER2.png" />
+              <File Id="file_MAESTROBIN_309" Name="BORDERX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDERX2.png" />
+              <File Id="file_MAESTROBIN_310" Name="CENTER.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTER.png" />
+              <File Id="file_MAESTROBIN_311" Name="CENTER2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTER2.png" />
+              <File Id="file_MAESTROBIN_312" Name="CENTERX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTERX2.png" />
+              <File Id="file_MAESTROBIN_313" Name="Dash.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Dash.png" />
+              <File Id="file_MAESTROBIN_314" Name="DashDot.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DashDot.png" />
+              <File Id="file_MAESTROBIN_315" Name="DASHDOT2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOT2.png" />
+              <File Id="file_MAESTROBIN_316" Name="DASHDOT3.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOT3.png" />
+              <File Id="file_MAESTROBIN_317" Name="DashDotDot.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DashDotDot.png" />
+              <File Id="file_MAESTROBIN_318" Name="DASHDOTX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOTX2.png" />
+              <File Id="file_MAESTROBIN_319" Name="DASHED.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHED.png" />
+              <File Id="file_MAESTROBIN_320" Name="DASHED2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHED2.png" />
+              <File Id="file_MAESTROBIN_321" Name="DASHEDX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHEDX2.png" />
+              <File Id="file_MAESTROBIN_322" Name="DIVIDE.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDE.png" />
+              <File Id="file_MAESTROBIN_323" Name="DIVIDE2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDE2.png" />
+              <File Id="file_MAESTROBIN_324" Name="DIVIDEX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDEX2.png" />
+              <File Id="file_MAESTROBIN_325" Name="Dot.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Dot.png" />
+              <File Id="file_MAESTROBIN_326" Name="DOT2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOT2.png" />
+              <File Id="file_MAESTROBIN_327" Name="DOT3.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOT3.png" />
+              <File Id="file_MAESTROBIN_328" Name="DOTX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOTX2.png" />
+              <File Id="file_MAESTROBIN_329" Name="FENCELINE1.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\FENCELINE1.png" />
+              <File Id="file_MAESTROBIN_330" Name="FENCELINE2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\FENCELINE2.png" />
+              <File Id="file_MAESTROBIN_331" Name="HIDDEN.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDEN.png" />
+              <File Id="file_MAESTROBIN_332" Name="HIDDEN2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDEN2.png" />
+              <File Id="file_MAESTROBIN_333" Name="HIDDENX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDENX2.png" />
+              <File Id="file_MAESTROBIN_334" Name="LINE03.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE03.png" />
+              <File Id="file_MAESTROBIN_335" Name="LINE04.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE04.png" />
+              <File Id="file_MAESTROBIN_336" Name="LINE05.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE05.png" />
+              <File Id="file_MAESTROBIN_337" Name="LINE06.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE06.png" />
+              <File Id="file_MAESTROBIN_338" Name="LINE07.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE07.png" />
+              <File Id="file_MAESTROBIN_339" Name="LINE08.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE08.png" />
+              <File Id="file_MAESTROBIN_340" Name="LINE09.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE09.png" />
+              <File Id="file_MAESTROBIN_341" Name="LINE10.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE10.png" />
+              <File Id="file_MAESTROBIN_342" Name="LINE11.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE11.png" />
+              <File Id="file_MAESTROBIN_343" Name="LINE12.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE12.png" />
+              <File Id="file_MAESTROBIN_344" Name="LINE13.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE13.png" />
+              <File Id="file_MAESTROBIN_345" Name="LINE14.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE14.png" />
+              <File Id="file_MAESTROBIN_346" Name="LINE15.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE15.png" />
+              <File Id="file_MAESTROBIN_347" Name="LINE16.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE16.png" />
+              <File Id="file_MAESTROBIN_348" Name="LINE17.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE17.png" />
+              <File Id="file_MAESTROBIN_349" Name="LINE18.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE18.png" />
+              <File Id="file_MAESTROBIN_350" Name="LINE19.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE19.png" />
+              <File Id="file_MAESTROBIN_351" Name="LINE20.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE20.png" />
+              <File Id="file_MAESTROBIN_352" Name="LINE21.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE21.png" />
+              <File Id="file_MAESTROBIN_353" Name="LINE22.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE22.png" />
+              <File Id="file_MAESTROBIN_354" Name="LINE23.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE23.png" />
+              <File Id="file_MAESTROBIN_355" Name="LINE24.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE24.png" />
+              <File Id="file_MAESTROBIN_356" Name="LINE25.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE25.png" />
+              <File Id="file_MAESTROBIN_357" Name="PHANTOM.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOM.png" />
+              <File Id="file_MAESTROBIN_358" Name="PHANTOM2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOM2.png" />
+              <File Id="file_MAESTROBIN_359" Name="PHANTOMX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOMX2.png" />
+              <File Id="file_MAESTROBIN_360" Name="Rail.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Rail.png" />
+              <File Id="file_MAESTROBIN_361" Name="Solid.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Solid.png" />
+              <File Id="file_MAESTROBIN_362" Name="TRACKS.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\TRACKS.png" />
             </Component>
           </Directory>
           <Directory Id="dir_MapGuideMaestro_WebStudio_points_7" Name="points">
-            <Component Id="comp_MAESTROBIN_362" DiskId="1" KeyPath="yes" Guid="A4115EF3-B628-4BCF-A36D-D4BC6655B31F">
-              <File Id="file_MAESTROBIN_362" Name="circle.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\circle.png" />
-              <File Id="file_MAESTROBIN_363" Name="cross.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\cross.png" />
-              <File Id="file_MAESTROBIN_364" Name="square.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\square.png" />
-              <File Id="file_MAESTROBIN_365" Name="star.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\star.png" />
-              <File Id="file_MAESTROBIN_366" Name="triangle.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\triangle.png" />
-              <File Id="file_MAESTROBIN_367" Name="x.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\x.png" />
+            <Component Id="comp_MAESTROBIN_363" DiskId="1" KeyPath="yes" Guid="AB919F9D-9A4E-43A0-AF61-548D9D137914">
+              <File Id="file_MAESTROBIN_363" Name="circle.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\circle.png" />
+              <File Id="file_MAESTROBIN_364" Name="cross.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\cross.png" />
+              <File Id="file_MAESTROBIN_365" Name="square.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\square.png" />
+              <File Id="file_MAESTROBIN_366" Name="star.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\star.png" />
+              <File Id="file_MAESTROBIN_367" Name="triangle.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\triangle.png" />
+              <File Id="file_MAESTROBIN_368" Name="x.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\x.png" />
             </Component>
           </Directory>
         </Directory>
Modified: trunk/Tools/Maestro/Installer/incLocFiles.da-DK.wxs
--- trunk/Tools/Maestro/Installer/incLocFiles.da-DK.wxs	2009-12-09 23:47:43 UTC (rev 4407)
+++ trunk/Tools/Maestro/Installer/incLocFiles.da-DK.wxs	2009-12-10 18:43:57 UTC (rev 4408)
@@ -3,10 +3,10 @@
   <!--<CommandLineOptions>
   <Producer>Autogenerated by Paraffin - Wintellect - John Robbins - john at wintellect.com</Producer>
   <WARNING>Manual changes to this file may cause incorrect behavior.</WARNING>
-  <CreatedOn>25-11-2009 20:57</CreatedOn>
-  <Directory>..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\</Directory>
+  <CreatedOn>10-12-2009 19:25</CreatedOn>
+  <Directory>compiled\da-DK\</Directory>
   <Custom>MAESTROBIN_da-DK</Custom>
-  <DirAlias>..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\</DirAlias>
+  <DirAlias>..\Localization\compiled\da-DK\</DirAlias>
   <Increment>1</Increment>
   <Guids>true</Guids>
   <Win64>false</Win64>
@@ -17,66 +17,24 @@
   </ExtensionExcludes>
   <DirExcludes>
     <Dir>.svn</Dir>
-    <Dir>Localization</Dir>
   </DirExcludes>
   <NextDirectoryNumber>1</NextDirectoryNumber>
-  <NextComponentNumber>48</NextComponentNumber>
+  <NextComponentNumber>7</NextComponentNumber>
 </CommandLineOptions>-->
   <Fragment>
     <ComponentGroup Id="group_MAESTROBIN_da_DK">
       <ComponentRef Id="comp_MAESTROBIN_da_DK_0" />
     </ComponentGroup>
-    <DirectoryRef Id="LANGLOCATION">
+    <DirectoryRef Id="dir_MapGuideMaestro_0">
       <Directory Id="dir_da_DK_0" Name="da-DK">
-        <Component Id="comp_MAESTROBIN_da_DK_0" DiskId="1" KeyPath="yes" Guid="E0465C31-5BB1-4824-8744-DE856A2673DF">
-          <File Id="file_MAESTROBIN_da_DK_0" Name="FusionEditor.ApplicationDefinitionEditor.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\FusionEditor.ApplicationDefinitionEditor.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_1" Name="FusionEditor.EditWidgets.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\FusionEditor.EditWidgets.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_2" Name="FusionEditor.SelectTemplate.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\FusionEditor.SelectTemplate.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_3" Name="Maestro.ApplicationSettings.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ApplicationSettings.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_4" Name="Maestro.BoundsPicker.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.BoundsPicker.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_5" Name="Maestro.BrowseResource.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.BrowseResource.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_6" Name="Maestro.EditorInterface.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.EditorInterface.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_7" Name="Maestro.ExceptionViewer.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ExceptionViewer.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_8" Name="Maestro.FormAbout.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.FormAbout.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_9" Name="Maestro.FormExpression.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.FormExpression.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_10" Name="Maestro.FormLogin.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.FormLogin.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_11" Name="Maestro.FormMain.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.FormMain.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_12" Name="Maestro.LengthyOperation.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.LengthyOperation.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_13" Name="Maestro.PackageManager.AddResourceEntry.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.PackageManager.AddResourceEntry.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_14" Name="Maestro.PackageManager.CreatePackage.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.PackageManager.CreatePackage.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_15" Name="Maestro.PackageManager.EditResourceDataEntry.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.PackageManager.EditResourceDataEntry.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_16" Name="Maestro.PackageManager.PackageEditor.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.PackageManager.PackageEditor.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_17" Name="Maestro.PackageManager.PackageProgress.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.PackageManager.PackageProgress.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_18" Name="Maestro.ResourceEditors.FeatureSourceEditorArcSDE.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.FeatureSourceEditorArcSDE.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_19" Name="Maestro.ResourceEditors.FeatureSourceEditorBase.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.FeatureSourceEditorBase.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_20" Name="Maestro.ResourceEditors.FeatureSourceEditorGdal.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.FeatureSourceEditorGdal.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_21" Name="Maestro.ResourceEditors.FeatureSourceEditorGeneric.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.FeatureSourceEditorGeneric.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_22" Name="Maestro.ResourceEditors.FeatureSourceEditorKingMSSql.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.FeatureSourceEditorKingMSSql.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_23" Name="Maestro.ResourceEditors.FeatureSourceEditorKingOracle.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.FeatureSourceEditorKingOracle.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_24" Name="Maestro.ResourceEditors.FeatureSourceEditorMSSQLSpatial.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.FeatureSourceEditorMSSQLSpatial.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_25" Name="Maestro.ResourceEditors.FeatureSourceEditorMySQL.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.FeatureSourceEditorMySQL.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_26" Name="Maestro.ResourceEditors.FeatureSourceEditorODBC.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.FeatureSourceEditorODBC.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_27" Name="Maestro.ResourceEditors.FeatureSourceEditorOGR.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.FeatureSourceEditorOGR.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_28" Name="Maestro.ResourceEditors.FeatureSourceEditorPostGIS.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.FeatureSourceEditorPostGIS.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_29" Name="Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Credentials.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Credentials.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_30" Name="Maestro.ResourceEditors.FeatureSourceEditorSDF.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.FeatureSourceEditorSDF.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_31" Name="Maestro.ResourceEditors.FeatureSourceEditorSHP.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.FeatureSourceEditorSHP.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_32" Name="Maestro.ResourceEditors.FeatureSourceEditorWFS.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.FeatureSourceEditorWFS.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_33" Name="Maestro.ResourceEditors.FeatureSourceEditorWMS.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.FeatureSourceEditorWMS.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_34" Name="Maestro.ResourceEditors.GeometryStyleEditors.AreaFeatureStyleEditor.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.GeometryStyleEditors.AreaFeatureStyleEditor.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_35" Name="Maestro.ResourceEditors.GeometryStyleEditors.FontStyleEditor.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.GeometryStyleEditors.FontStyleEditor.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_36" Name="Maestro.ResourceEditors.GeometryStyleEditors.LineFeatureStyleEditor.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.GeometryStyleEditors.LineFeatureStyleEditor.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_37" Name="Maestro.ResourceEditors.GeometryStyleEditors.PointFeatureStyleEditor.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.GeometryStyleEditors.PointFeatureStyleEditor.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_38" Name="Maestro.ResourceEditors.LayerEditor.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.LayerEditor.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_39" Name="Maestro.ResourceEditors.LayoutControls.BrowseLayers.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.LayoutControls.BrowseLayers.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_40" Name="Maestro.ResourceEditors.LayoutEditor.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.LayoutEditor.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_41" Name="Maestro.ResourceEditors.MapEditor.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.MapEditor.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_42" Name="Maestro.ResourceEditors.PlaceHolderEditor.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.PlaceHolderEditor.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_43" Name="Maestro.ResourceEditors.ResourceDataEditor.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.ResourceDataEditor.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_44" Name="Maestro.ResourceEditors.SelectCoordinateSystem.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.SelectCoordinateSystem.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_45" Name="Maestro.ResourceEditors.SelectDataprovider.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.SelectDataprovider.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_46" Name="Maestro.ResourceEditors.XmlEditorControl.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceEditors.XmlEditorControl.da-DK.resx" />
-          <File Id="file_MAESTROBIN_da_DK_47" Name="Maestro.ResourceProperties.da-DK.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\da-DK\Maestro.ResourceProperties.da-DK.resx" />
+        <Component Id="comp_MAESTROBIN_da_DK_0" DiskId="1" KeyPath="yes" Guid="94C8C4E2-75FD-444C-8A16-83DA7B11EF64">
+          <File Id="file_MAESTROBIN_da_DK_0" Name="Maestro.resources.dll" Source="..\Localization\compiled\da-DK\Maestro.resources.dll" />
+          <File Id="file_MAESTROBIN_da_DK_1" Name="OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" Source="..\Localization\compiled\da-DK\OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" />
+          <File Id="file_MAESTROBIN_da_DK_2" Name="OSGeo.MapGuide.Maestro.LoginForm.resources.dll" Source="..\Localization\compiled\da-DK\OSGeo.MapGuide.Maestro.LoginForm.resources.dll" />
+          <File Id="file_MAESTROBIN_da_DK_3" Name="OSGeo.MapGuide.Maestro.ResourceBrowser.resources.dll" Source="..\Localization\compiled\da-DK\OSGeo.MapGuide.Maestro.ResourceBrowser.resources.dll" />
+          <File Id="file_MAESTROBIN_da_DK_4" Name="OSGeo.MapGuide.Maestro.ResourceEditors.resources.dll" Source="..\Localization\compiled\da-DK\OSGeo.MapGuide.Maestro.ResourceEditors.resources.dll" />
+          <File Id="file_MAESTROBIN_da_DK_5" Name="OSGeo.MapGuide.Maestro.ResourceValidators.resources.dll" Source="..\Localization\compiled\da-DK\OSGeo.MapGuide.Maestro.ResourceValidators.resources.dll" />
+          <File Id="file_MAESTROBIN_da_DK_6" Name="OSGeo.MapGuide.MgCooker.resources.dll" Source="..\Localization\compiled\da-DK\OSGeo.MapGuide.MgCooker.resources.dll" />
         </Component>
       </Directory>
     </DirectoryRef>
Modified: trunk/Tools/Maestro/Installer/incLocFiles.es-ES.wxs
--- trunk/Tools/Maestro/Installer/incLocFiles.es-ES.wxs	2009-12-09 23:47:43 UTC (rev 4407)
+++ trunk/Tools/Maestro/Installer/incLocFiles.es-ES.wxs	2009-12-10 18:43:57 UTC (rev 4408)
@@ -3,10 +3,10 @@
-  <Directory>..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\</Directory>
+  <Directory>compiled\es-ES\</Directory>
   <Custom>MAESTROBIN_es-ES</Custom>
-  <DirAlias>..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\</DirAlias>
+  <DirAlias>..\Localization\compiled\es-ES\</DirAlias>
   <Guids>true</Guids>
@@ -17,66 +17,24 @@
   <DirExcludes>
     <Dir>.svn</Dir>
   </DirExcludes>
   <Fragment>
     <ComponentGroup Id="group_MAESTROBIN_es_ES">
       <ComponentRef Id="comp_MAESTROBIN_es_ES_0" />
     </ComponentGroup>
       <Directory Id="dir_es_ES_0" Name="es-ES">
-        <Component Id="comp_MAESTROBIN_es_ES_0" DiskId="1" KeyPath="yes" Guid="A4638A6C-F8A1-4E46-A286-80CBBD47A025">
-          <File Id="file_MAESTROBIN_es_ES_0" Name="FusionEditor.ApplicationDefinitionEditor.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\FusionEditor.ApplicationDefinitionEditor.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_1" Name="FusionEditor.EditWidgets.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\FusionEditor.EditWidgets.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_2" Name="FusionEditor.SelectTemplate.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\FusionEditor.SelectTemplate.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_3" Name="Maestro.ApplicationSettings.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ApplicationSettings.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_4" Name="Maestro.BoundsPicker.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.BoundsPicker.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_5" Name="Maestro.BrowseResource.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.BrowseResource.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_6" Name="Maestro.EditorInterface.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.EditorInterface.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_7" Name="Maestro.ExceptionViewer.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ExceptionViewer.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_8" Name="Maestro.FormAbout.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.FormAbout.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_9" Name="Maestro.FormExpression.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.FormExpression.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_10" Name="Maestro.FormLogin.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.FormLogin.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_11" Name="Maestro.FormMain.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.FormMain.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_12" Name="Maestro.LengthyOperation.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.LengthyOperation.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_13" Name="Maestro.PackageManager.AddResourceEntry.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.PackageManager.AddResourceEntry.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_14" Name="Maestro.PackageManager.CreatePackage.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.PackageManager.CreatePackage.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_15" Name="Maestro.PackageManager.EditResourceDataEntry.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.PackageManager.EditResourceDataEntry.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_16" Name="Maestro.PackageManager.PackageEditor.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.PackageManager.PackageEditor.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_17" Name="Maestro.PackageManager.PackageProgress.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.PackageManager.PackageProgress.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_18" Name="Maestro.ResourceEditors.FeatureSourceEditorArcSDE.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.FeatureSourceEditorArcSDE.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_19" Name="Maestro.ResourceEditors.FeatureSourceEditorBase.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.FeatureSourceEditorBase.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_20" Name="Maestro.ResourceEditors.FeatureSourceEditorGdal.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.FeatureSourceEditorGdal.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_21" Name="Maestro.ResourceEditors.FeatureSourceEditorGeneric.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.FeatureSourceEditorGeneric.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_22" Name="Maestro.ResourceEditors.FeatureSourceEditorKingMSSql.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.FeatureSourceEditorKingMSSql.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_23" Name="Maestro.ResourceEditors.FeatureSourceEditorKingOracle.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.FeatureSourceEditorKingOracle.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_24" Name="Maestro.ResourceEditors.FeatureSourceEditorMSSQLSpatial.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.FeatureSourceEditorMSSQLSpatial.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_25" Name="Maestro.ResourceEditors.FeatureSourceEditorMySQL.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.FeatureSourceEditorMySQL.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_26" Name="Maestro.ResourceEditors.FeatureSourceEditorODBC.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.FeatureSourceEditorODBC.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_27" Name="Maestro.ResourceEditors.FeatureSourceEditorOGR.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.FeatureSourceEditorOGR.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_28" Name="Maestro.ResourceEditors.FeatureSourceEditorPostGIS.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.FeatureSourceEditorPostGIS.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_29" Name="Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Credentials.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Credentials.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_30" Name="Maestro.ResourceEditors.FeatureSourceEditorSDF.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.FeatureSourceEditorSDF.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_31" Name="Maestro.ResourceEditors.FeatureSourceEditorSHP.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.FeatureSourceEditorSHP.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_32" Name="Maestro.ResourceEditors.FeatureSourceEditorWFS.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.FeatureSourceEditorWFS.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_33" Name="Maestro.ResourceEditors.FeatureSourceEditorWMS.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.FeatureSourceEditorWMS.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_34" Name="Maestro.ResourceEditors.GeometryStyleEditors.AreaFeatureStyleEditor.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.GeometryStyleEditors.AreaFeatureStyleEditor.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_35" Name="Maestro.ResourceEditors.GeometryStyleEditors.FontStyleEditor.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.GeometryStyleEditors.FontStyleEditor.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_36" Name="Maestro.ResourceEditors.GeometryStyleEditors.LineFeatureStyleEditor.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.GeometryStyleEditors.LineFeatureStyleEditor.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_37" Name="Maestro.ResourceEditors.GeometryStyleEditors.PointFeatureStyleEditor.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.GeometryStyleEditors.PointFeatureStyleEditor.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_38" Name="Maestro.ResourceEditors.LayerEditor.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.LayerEditor.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_39" Name="Maestro.ResourceEditors.LayoutControls.BrowseLayers.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.LayoutControls.BrowseLayers.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_40" Name="Maestro.ResourceEditors.LayoutEditor.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.LayoutEditor.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_41" Name="Maestro.ResourceEditors.MapEditor.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.MapEditor.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_42" Name="Maestro.ResourceEditors.PlaceHolderEditor.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.PlaceHolderEditor.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_43" Name="Maestro.ResourceEditors.ResourceDataEditor.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.ResourceDataEditor.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_44" Name="Maestro.ResourceEditors.SelectCoordinateSystem.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.SelectCoordinateSystem.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_45" Name="Maestro.ResourceEditors.SelectDataprovider.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.SelectDataprovider.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_46" Name="Maestro.ResourceEditors.XmlEditorControl.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceEditors.XmlEditorControl.es-ES.resx" />
-          <File Id="file_MAESTROBIN_es_ES_47" Name="Maestro.ResourceProperties.es-ES.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\es-ES\Maestro.ResourceProperties.es-ES.resx" />
+        <Component Id="comp_MAESTROBIN_es_ES_0" DiskId="1" KeyPath="yes" Guid="99E1C76F-42E8-4AE3-9566-F1DE9C36B174">
+          <File Id="file_MAESTROBIN_es_ES_0" Name="Maestro.resources.dll" Source="..\Localization\compiled\es-ES\Maestro.resources.dll" />
+          <File Id="file_MAESTROBIN_es_ES_1" Name="OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" Source="..\Localization\compiled\es-ES\OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" />
+          <File Id="file_MAESTROBIN_es_ES_2" Name="OSGeo.MapGuide.Maestro.LoginForm.resources.dll" Source="..\Localization\compiled\es-ES\OSGeo.MapGuide.Maestro.LoginForm.resources.dll" />
+          <File Id="file_MAESTROBIN_es_ES_3" Name="OSGeo.MapGuide.Maestro.ResourceBrowser.resources.dll" Source="..\Localization\compiled\es-ES\OSGeo.MapGuide.Maestro.ResourceBrowser.resources.dll" />
+          <File Id="file_MAESTROBIN_es_ES_4" Name="OSGeo.MapGuide.Maestro.ResourceEditors.resources.dll" Source="..\Localization\compiled\es-ES\OSGeo.MapGuide.Maestro.ResourceEditors.resources.dll" />
+          <File Id="file_MAESTROBIN_es_ES_5" Name="OSGeo.MapGuide.Maestro.ResourceValidators.resources.dll" Source="..\Localization\compiled\es-ES\OSGeo.MapGuide.Maestro.ResourceValidators.resources.dll" />
+          <File Id="file_MAESTROBIN_es_ES_6" Name="OSGeo.MapGuide.MgCooker.resources.dll" Source="..\Localization\compiled\es-ES\OSGeo.MapGuide.MgCooker.resources.dll" />
         </Component>
       </Directory>
     </DirectoryRef>
Modified: trunk/Tools/Maestro/Installer/incLocFiles.fr-FR.wxs
--- trunk/Tools/Maestro/Installer/incLocFiles.fr-FR.wxs	2009-12-09 23:47:43 UTC (rev 4407)
+++ trunk/Tools/Maestro/Installer/incLocFiles.fr-FR.wxs	2009-12-10 18:43:57 UTC (rev 4408)
@@ -3,10 +3,10 @@
-  <Directory>..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\</Directory>
+  <Directory>compiled\fr-FR\</Directory>
   <Custom>MAESTROBIN_fr-FR</Custom>
-  <DirAlias>..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\</DirAlias>
+  <DirAlias>..\Localization\compiled\fr-FR\</DirAlias>
   <Guids>true</Guids>
@@ -17,66 +17,24 @@
   <DirExcludes>
     <Dir>.svn</Dir>
   </DirExcludes>
   <Fragment>
     <ComponentGroup Id="group_MAESTROBIN_fr_FR">
       <ComponentRef Id="comp_MAESTROBIN_fr_FR_0" />
     </ComponentGroup>
       <Directory Id="dir_fr_FR_0" Name="fr-FR">
-        <Component Id="comp_MAESTROBIN_fr_FR_0" DiskId="1" KeyPath="yes" Guid="20214C27-15A4-4FE3-9546-F011A6396FEE">
-          <File Id="file_MAESTROBIN_fr_FR_0" Name="FusionEditor.ApplicationDefinitionEditor.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\FusionEditor.ApplicationDefinitionEditor.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_1" Name="FusionEditor.EditWidgets.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\FusionEditor.EditWidgets.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_2" Name="FusionEditor.SelectTemplate.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\FusionEditor.SelectTemplate.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_3" Name="Maestro.ApplicationSettings.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ApplicationSettings.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_4" Name="Maestro.BoundsPicker.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.BoundsPicker.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_5" Name="Maestro.BrowseResource.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.BrowseResource.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_6" Name="Maestro.EditorInterface.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.EditorInterface.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_7" Name="Maestro.ExceptionViewer.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ExceptionViewer.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_8" Name="Maestro.FormExpression.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.FormExpression.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_9" Name="Maestro.FormLogin.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.FormLogin.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_10" Name="Maestro.FormMain.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.FormMain.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_11" Name="Maestro.LengthyOperation.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.LengthyOperation.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_12" Name="Maestro.PackageManager.AddResourceEntry.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.PackageManager.AddResourceEntry.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_13" Name="Maestro.PackageManager.CreatePackage.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.PackageManager.CreatePackage.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_14" Name="Maestro.PackageManager.EditResourceDataEntry.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.PackageManager.EditResourceDataEntry.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_15" Name="Maestro.PackageManager.PackageEditor.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.PackageManager.PackageEditor.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_16" Name="Maestro.PackageManager.PackageProgress.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.PackageManager.PackageProgress.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_17" Name="Maestro.ResourceEditors.FeatureSourceEditorArcSDE.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditorArcSDE.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_18" Name="Maestro.ResourceEditors.FeatureSourceEditorBase.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditorBase.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_19" Name="Maestro.ResourceEditors.FeatureSourceEditorGdal.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditorGdal.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_20" Name="Maestro.ResourceEditors.FeatureSourceEditorGeneric.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditorGeneric.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_21" Name="Maestro.ResourceEditors.FeatureSourceEditorKingMSSql.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditorKingMSSql.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_22" Name="Maestro.ResourceEditors.FeatureSourceEditorKingOracle.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditorKingOracle.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_23" Name="Maestro.ResourceEditors.FeatureSourceEditorManagedFileControl.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditorManagedFileControl.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_24" Name="Maestro.ResourceEditors.FeatureSourceEditorMSSQLSpatial.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditorMSSQLSpatial.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_25" Name="Maestro.ResourceEditors.FeatureSourceEditorMySQL.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditorMySQL.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_26" Name="Maestro.ResourceEditors.FeatureSourceEditorODBC.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditorODBC.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_27" Name="Maestro.ResourceEditors.FeatureSourceEditorOGR.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditorOGR.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_28" Name="Maestro.ResourceEditors.FeatureSourceEditorPostGIS.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditorPostGIS.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_29" Name="Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Credentials.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Credentials.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_30" Name="Maestro.ResourceEditors.FeatureSourceEditorSDF.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditorSDF.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_31" Name="Maestro.ResourceEditors.FeatureSourceEditorSHP.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditorSHP.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_32" Name="Maestro.ResourceEditors.FeatureSourceEditorWFS.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditorWFS.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_33" Name="Maestro.ResourceEditors.FeatureSourceEditorWMS.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.FeatureSourceEditorWMS.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_34" Name="Maestro.ResourceEditors.GeometryStyleEditors.AreaFeatureStyleEditor.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.GeometryStyleEditors.AreaFeatureStyleEditor.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_35" Name="Maestro.ResourceEditors.GeometryStyleEditors.FontStyleEditor.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.GeometryStyleEditors.FontStyleEditor.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_36" Name="Maestro.ResourceEditors.GeometryStyleEditors.LineFeatureStyleEditor.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.GeometryStyleEditors.LineFeatureStyleEditor.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_37" Name="Maestro.ResourceEditors.GeometryStyleEditors.PointFeatureStyleEditor.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.GeometryStyleEditors.PointFeatureStyleEditor.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_38" Name="Maestro.ResourceEditors.LayerEditor.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.LayerEditor.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_39" Name="Maestro.ResourceEditors.LayoutControls.BrowseLayers.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.LayoutControls.BrowseLayers.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_40" Name="Maestro.ResourceEditors.LayoutEditor.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.LayoutEditor.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_41" Name="Maestro.ResourceEditors.MapEditor.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.MapEditor.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_42" Name="Maestro.ResourceEditors.PlaceHolderEditor.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.PlaceHolderEditor.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_43" Name="Maestro.ResourceEditors.ResourceDataEditor.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.ResourceDataEditor.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_44" Name="Maestro.ResourceEditors.SelectCoordinateSystem.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.SelectCoordinateSystem.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_45" Name="Maestro.ResourceEditors.SelectDataprovider.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.SelectDataprovider.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_46" Name="Maestro.ResourceEditors.XmlEditorControl.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceEditors.XmlEditorControl.fr-FR.resx" />
-          <File Id="file_MAESTROBIN_fr_FR_47" Name="Maestro.ResourceProperties.fr-FR.resx" Source="..\InstallerTempRelease\MapGuideMaestro\Localization\fr-FR\Maestro.ResourceProperties.fr-FR.resx" />
+        <Component Id="comp_MAESTROBIN_fr_FR_0" DiskId="1" KeyPath="yes" Guid="6B65CD45-1508-405B-912E-E55A4DAAB38D">
+          <File Id="file_MAESTROBIN_fr_FR_0" Name="Maestro.resources.dll" Source="..\Localization\compiled\fr-FR\Maestro.resources.dll" />
+          <File Id="file_MAESTROBIN_fr_FR_1" Name="OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" Source="..\Localization\compiled\fr-FR\OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" />
+          <File Id="file_MAESTROBIN_fr_FR_2" Name="OSGeo.MapGuide.Maestro.LoginForm.resources.dll" Source="..\Localization\compiled\fr-FR\OSGeo.MapGuide.Maestro.LoginForm.resources.dll" />
+          <File Id="file_MAESTROBIN_fr_FR_3" Name="OSGeo.MapGuide.Maestro.ResourceBrowser.resources.dll" Source="..\Localization\compiled\fr-FR\OSGeo.MapGuide.Maestro.ResourceBrowser.resources.dll" />
+          <File Id="file_MAESTROBIN_fr_FR_4" Name="OSGeo.MapGuide.Maestro.ResourceEditors.resources.dll" Source="..\Localization\compiled\fr-FR\OSGeo.MapGuide.Maestro.ResourceEditors.resources.dll" />
+          <File Id="file_MAESTROBIN_fr_FR_5" Name="OSGeo.MapGuide.Maestro.ResourceValidators.resources.dll" Source="..\Localization\compiled\fr-FR\OSGeo.MapGuide.Maestro.ResourceValidators.resources.dll" />
+          <File Id="file_MAESTROBIN_fr_FR_6" Name="OSGeo.MapGuide.MgCooker.resources.dll" Source="..\Localization\compiled\fr-FR\OSGeo.MapGuide.MgCooker.resources.dll" />
         </Component>
       </Directory>
     </DirectoryRef>
Modified: trunk/Tools/Maestro/Localization/LocalizationTool.exe
(Binary files differ)
Modified: trunk/Tools/Maestro/Maestro/Update DEBUG Environment.bat
--- trunk/Tools/Maestro/Maestro/Update DEBUG Environment.bat	2009-12-09 23:47:43 UTC (rev 4407)
+++ trunk/Tools/Maestro/Maestro/Update DEBUG Environment.bat	2009-12-10 18:43:57 UTC (rev 4408)
@@ -6,6 +6,4 @@
 xcopy /Y /E resourceeditors\templates bin\debug\Templates\
 xcopy /Y /E ..\maestroapi\Schemas bin\debug\Schemas\
-xcopy /Y /E Localization bin\debug\Localization\
-xcopy /Y license.txt bin\release\
+xcopy /Y license.txt bin\debug\
Modified: trunk/Tools/Maestro/Maestro/Update RELEASE Environment.bat
--- trunk/Tools/Maestro/Maestro/Update RELEASE Environment.bat	2009-12-09 23:47:43 UTC (rev 4407)
+++ trunk/Tools/Maestro/Maestro/Update RELEASE Environment.bat	2009-12-10 18:43:57 UTC (rev 4408)
@@ -6,6 +6,4 @@
 xcopy /Y /E resourceeditors\templates bin\release\Templates\
 xcopy /Y /E ..\maestroapi\Schemas bin\release\Schemas\
-xcopy /Y /E Localization bin\release\Localization\
Modified: trunk/Tools/Maestro/build.bat
--- trunk/Tools/Maestro/build.bat	2009-12-09 23:47:43 UTC (rev 4407)
+++ trunk/Tools/Maestro/build.bat	2009-12-10 18:43:57 UTC (rev 4408)
@@ -1,7 +1,8 @@
- at echo off
+rem @echo off
 rem MapGuide Maestro build script for windows
 rem
 rem Author: Jackie Ng (jumpinjackie at gmail.com)
+rem         Kenneth Skovhede (opensource at hexad.dk)
 rem
 rem This script will build all the MapGuide Maestro components, if the output path is specified
 rem it will also copy all binaries to the output path. Otherwise it will use the default
@@ -27,12 +28,15 @@
 SET OLDPATH=%PATH%
 SET TYPEACTION=build
 SET TYPEBUILD=Release
+SET ORIGDIR=%CD%
 rem ==================================================
 rem MapGuide Maestro vars
 SET MAESTRO_DEV=%CD%\Maestro
+SET MAESTRO_LOCALIZATION=%CD%\Localization
 SET MAESTRO_OUTPUT=%CD%\InstallerTemp%TYPEBUILD%\MapGuideMaestro
+SET OUTPUT_ZIPFILE=bin\%TYPEBUILD%\MapGuide Maestro.zip
 SET MAESTRO_WIX=%CD%\Installer
 SET PARAFFIN_PATH=%MAESTRO_WIX%\paraffin.exe
@@ -54,7 +58,10 @@
 SET XCOPY=xcopy /E /Y /I /Q
 SET MSBUILD=msbuild.exe /nologo /p:Configuration=%TYPEBUILD% %MSBUILD_VERBOSITY% %MSBUILD_LOG%
 SET MSBUILD_CLEAN=msbuild.exe /nologo /m:%CPU_CORES% /p:Configuration=%TYPEBUILD% /t:Clean %MSBUILD_VERBOSITY%
+SET ZIP=%PROGRAMFILES%\7-zip\7z.exe
+SET DELTREE=rmdir /S /Q
 :study_params
 if (%1)==() goto start_build
@@ -128,9 +135,15 @@
 :clean
 echo [Clean] MapGuide Maestro
-pushd %MAESTRO_DEV%
-%MSBUILD_CLEAN% OSGeo.MapGuide.Maestro.sln
+%DELTREE% "%MAESTRO_OUTPUT%"
+%MSBUILD_CLEAN% "MapGuide Maestro.sln"
+pushd %MAESTRO_LOCALIZATION%
+LocalizationTool.exe clean
 popd
 goto quit
 :update
@@ -138,40 +151,51 @@
 pushd %MAESTRO_DEV%
 call "Update %TYPEBUILD% Environment.bat"
 popd
+LocalizationTool.exe update
+popd
 if not "%TYPEACTION%"=="buildinstall" goto quit
 :build
 echo [build] MapGuide Maestro
-%MSBUILD% OSGeo.MapGuide.Maestro.sln
-popd
+%MSBUILD% "MapGuide Maestro.sln"
 if "%errorlevel%"=="1" goto error
 :install
 echo [install] MapGuide Maestro
 %XCOPY% "%MAESTRO_DEV%\bin\%TYPEBUILD%" "%MAESTRO_OUTPUT%"
 del /Q "%MAESTRO_OUTPUT%"\*.vshost.*
 del /Q "%MAESTRO_OUTPUT%"\*.pdb
-del /Q "%MAESTRO_OUTPUT%"\Localization\default
+%DELTREE% compiled
+LocalizationTool.exe build
+for /D %%d in ("compiled\*") do call :langbuild %%d
+popd
 pushd %MAESTRO_WIX%
-%PARAFFIN_PATH% -dir %MAESTRO_OUTPUT% -alias "%MAESTRO_OUTPUT%" -custom MAESTROBIN -dirref INSTALLLOCATION -multiple -guids incBinFiles.wxs -ext .pdb -direXclude .svn -direXclude Localization
+"%PARAFFIN_PATH%" -dir %MAESTRO_OUTPUT% -alias "%MAESTRO_OUTPUT%" -custom MAESTROBIN -dirref INSTALLLOCATION -multiple -guids incBinFiles.wxs -ext .pdb -direXclude .svn
-rem del /Q "%MAESTRO_WIX%\incLang.wxs"
+%MSBUILD% Installer.sln
+if "%errorlevel%"=="1" goto error
-for /D %%d in ("%MAESTRO_OUTPUT%\Localization\*") do call :langbuild %%d
+rem Move in localization files and build zip
+%XCOPY% "%MAESTRO_LOCALIZATION%\compiled\*" "%MAESTRO_OUTPUT%"
+del /Q "%OUTPUT_ZIPFILE%"
+"%ZIP%" a -r "bin\%TYPEBUILD%\MapGuide Maestro.zip" "%MAESTRO_OUTPUT%"
+popd
-%MSBUILD% Installer.sln
-popd
 goto quit
 :langbuild
 set FOLDERNAME=
 for /f "tokens=*" %%a in ("%1") do set FOLDERNAME=%%~na
-%PARAFFIN_PATH% -dir %1 -alias %1 -custom MAESTROBIN_%FOLDERNAME% -dirref LANGLOCATION -multiple -guids incLocFiles.%FOLDERNAME%.wxs -ext .pdb -direXclude .svn -direXclude Localization
-rem echo "<?include incLocFiles.%FOLDERNAME%.wxs ?>" >> "%MAESTRO_WIX%\incLang.wxs"
+"%PARAFFIN_PATH%" -dir %1 -alias ..\Localization\%1 -custom MAESTROBIN_%FOLDERNAME% -dirref dir_MapGuideMaestro_0 -multiple -guids "%MAESTRO_WIX%\incLocFiles.%FOLDERNAME%.wxs" -ext .pdb -direXclude .svn
 goto end_of_program
@@ -216,4 +240,5 @@
 SET MSBUILD=
 SET PARAFFIN_PATH=
 SET PATH=%OLDPATH%
+cd %ORIGDIR%"
 :end_of_program
\ No newline at end of file
More information about the mapguide-commits mailing list
