[mapguide-commits] r4410 - in trunk/MgDev/Oem/fusionMG/templates/mapguide: aqua limegold maroon preview slate turquoiseyellow
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Dec 10 22:09:48 EST 2009
Author: leaf
Date: 2009-12-10 22:09:47 -0500 (Thu, 10 Dec 2009)
New Revision: 4410
   trunk/MgDev/Oem/fusionMG/templates/mapguide/aqua/ApplicationDefinition.xml
   trunk/MgDev/Oem/fusionMG/templates/mapguide/limegold/ApplicationDefinition.xml
   trunk/MgDev/Oem/fusionMG/templates/mapguide/maroon/ApplicationDefinition.xml
   trunk/MgDev/Oem/fusionMG/templates/mapguide/preview/ApplicationDefinition.xml
   trunk/MgDev/Oem/fusionMG/templates/mapguide/slate/ApplicationDefinition.xml
   trunk/MgDev/Oem/fusionMG/templates/mapguide/turquoiseyellow/ApplicationDefinition.xml
Submit on behalf of Arthur Liu.
Fixed Ticket https://trac.osgeo.org/mapguide/ticket/1163
Since Fusion has extended the functionality of Measure widget this release, which is able to measure areas besides distances, wed better to update its tooltips and descriptions from Measure distances on the map to Measure distances and areas on the map.
Modified: trunk/MgDev/Oem/fusionMG/templates/mapguide/aqua/ApplicationDefinition.xml
--- trunk/MgDev/Oem/fusionMG/templates/mapguide/aqua/ApplicationDefinition.xml	2009-12-10 19:30:41 UTC (rev 4409)
+++ trunk/MgDev/Oem/fusionMG/templates/mapguide/aqua/ApplicationDefinition.xml	2009-12-11 03:09:47 UTC (rev 4410)
@@ -695,7 +695,7 @@
     <Widget xsi:type="UiWidgetType">
       <Name>menuMeasure</Name>
       <Type>Measure</Type>
-      <StatusItem>Measure distances on the map.</StatusItem>
+      <StatusItem>Measure distances and areas on the map.</StatusItem>
       <Extension xsi:type="CustomContentType">
         <Type>both</Type>
         <MeasureTooltipContainer>MeasureResult</MeasureTooltipContainer>
@@ -835,7 +835,7 @@
       <Name>toolbarMeasure</Name>
         <Type>both</Type>
Modified: trunk/MgDev/Oem/fusionMG/templates/mapguide/limegold/ApplicationDefinition.xml
--- trunk/MgDev/Oem/fusionMG/templates/mapguide/limegold/ApplicationDefinition.xml	2009-12-10 19:30:41 UTC (rev 4409)
+++ trunk/MgDev/Oem/fusionMG/templates/mapguide/limegold/ApplicationDefinition.xml	2009-12-11 03:09:47 UTC (rev 4410)
@@ -690,7 +690,7 @@
         <Type>both</Type>
@@ -762,7 +762,7 @@
         <Type>both</Type>
Modified: trunk/MgDev/Oem/fusionMG/templates/mapguide/maroon/ApplicationDefinition.xml
--- trunk/MgDev/Oem/fusionMG/templates/mapguide/maroon/ApplicationDefinition.xml	2009-12-10 19:30:41 UTC (rev 4409)
+++ trunk/MgDev/Oem/fusionMG/templates/mapguide/maroon/ApplicationDefinition.xml	2009-12-11 03:09:47 UTC (rev 4410)
@@ -695,7 +695,7 @@
         <Type>both</Type>
@@ -835,7 +835,7 @@
         <Type>both</Type>
Modified: trunk/MgDev/Oem/fusionMG/templates/mapguide/preview/ApplicationDefinition.xml
--- trunk/MgDev/Oem/fusionMG/templates/mapguide/preview/ApplicationDefinition.xml	2009-12-10 19:30:41 UTC (rev 4409)
+++ trunk/MgDev/Oem/fusionMG/templates/mapguide/preview/ApplicationDefinition.xml	2009-12-11 03:09:47 UTC (rev 4410)
@@ -683,7 +683,7 @@
         <Type>both</Type>
@@ -795,7 +795,7 @@
         <Type>both</Type>
Modified: trunk/MgDev/Oem/fusionMG/templates/mapguide/slate/ApplicationDefinition.xml
--- trunk/MgDev/Oem/fusionMG/templates/mapguide/slate/ApplicationDefinition.xml	2009-12-10 19:30:41 UTC (rev 4409)
+++ trunk/MgDev/Oem/fusionMG/templates/mapguide/slate/ApplicationDefinition.xml	2009-12-11 03:09:47 UTC (rev 4410)
@@ -690,7 +690,7 @@
         <Type>both</Type>
@@ -762,7 +762,7 @@
         <Type>both</Type>
Modified: trunk/MgDev/Oem/fusionMG/templates/mapguide/turquoiseyellow/ApplicationDefinition.xml
--- trunk/MgDev/Oem/fusionMG/templates/mapguide/turquoiseyellow/ApplicationDefinition.xml	2009-12-10 19:30:41 UTC (rev 4409)
+++ trunk/MgDev/Oem/fusionMG/templates/mapguide/turquoiseyellow/ApplicationDefinition.xml	2009-12-11 03:09:47 UTC (rev 4410)
@@ -671,7 +671,7 @@
         <Type>both</Type>
@@ -728,7 +728,7 @@
         <Type>both</Type>
More information about the mapguide-commits mailing list
