[mapguide-commits] r4420 - trunk/Tools/Maestro/MaestroAPI
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Dec 12 04:54:02 EST 2009
Author: ksgeograf
Date: 2009-12-12 04:54:00 -0500 (Sat, 12 Dec 2009)
New Revision: 4420
   trunk/Tools/Maestro/MaestroAPI/FeatureSourceDescription.cs
Maestro:
Fixed issue #1189.
The DescribeSchema output XSD contains inherited abstract classes from a WMS source.
The FeatureSourceDescription parser has been updated to handle these as well.
Modified: trunk/Tools/Maestro/MaestroAPI/FeatureSourceDescription.cs
--- trunk/Tools/Maestro/MaestroAPI/FeatureSourceDescription.cs	2009-12-12 01:27:59 UTC (rev 4419)
+++ trunk/Tools/Maestro/MaestroAPI/FeatureSourceDescription.cs	2009-12-12 09:54:00 UTC (rev 4420)
@@ -38,7 +38,6 @@
 		public FeatureSourceDescription(System.IO.Stream stream)
-            bool usingFdoSchema;
 			XmlDocument doc = new XmlDocument();
 			doc.Load(stream);
@@ -59,9 +58,8 @@
 			mgr.AddNamespace("fdo", "http://fdo.osgeo.org/schemas");
 			XmlNodeList lst = root.SelectNodes("xs:schema/xs:complexType[@abstract='false']", mgr);
 			m_schemas = new FeatureSourceSchema[lst.Count];
-			for(int i = 0;i<lst.Count;i++)
+            for (int i = 0; i < m_schemas.Length; i++)
 				m_schemas[i] = new FeatureSourceSchema(lst[i], mgr);
@@ -109,9 +107,27 @@
 				else
 					lst = node.SelectNodes("xs:complexContent/xs:extension/xs:sequence/xs:element", mgr);
 				m_columns = new FeatureSetColumn[lst.Count];
 					m_columns[i] = new FeatureSetColumn(lst[i]);
+                XmlNode extension = node.SelectSingleNode("xs:complexContent/xs:extension", mgr);
+                if (extension != null && extension.Attributes["base"] != null)
+                    string extTypeName = extension.Attributes["base"].Value;
+                    extTypeName = extTypeName.Substring(extTypeName.IndexOf(":") + 1);
+                    XmlNode baseEl = node.ParentNode.SelectSingleNode("xs:complexType[@name='" + extTypeName + "']", mgr);
+                    if (baseEl != null)
+                        FeatureSourceSchema tmpScm = new FeatureSourceSchema(baseEl, mgr);
+                        FeatureSetColumn[] tmpCol = new FeatureSetColumn[m_columns.Length + tmpScm.m_columns.Length];
+                        Array.Copy(m_columns, tmpCol, m_columns.Length);
+                        Array.Copy(tmpScm.m_columns, 0, tmpCol, m_columns.Length, tmpScm.m_columns.Length);
+                        m_columns = tmpCol;
 			public string Name { get { return m_name; } }
More information about the mapguide-commits mailing list
