[mapguide-commits] r4429 - in trunk/Tools/Maestro/Maestro: . ResourceEditors/LayerEditorControls ResourceEditors/LayerEditorControls/ScaleControls ResourceEditors/LayerEditorControls/Strings
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Dec 12 18:29:29 EST 2009
Author: ksgeograf
Date: 2009-12-12 18:29:28 -0500 (Sat, 12 Dec 2009)
New Revision: 4429
   trunk/Tools/Maestro/Maestro/FormMain.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/ScaleControls/ScaleRange.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/ScaleControls/ScaleRangeConditions.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/ScaleControls/ScaleRangeList.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/Strings/VectorLayer.Designer.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/Strings/VectorLayer.resx
   trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/VectorLayer.cs
Fixed issue #1170.
Also fixed a bug with loading resources from xml files.
Modified: trunk/Tools/Maestro/Maestro/FormMain.cs
--- trunk/Tools/Maestro/Maestro/FormMain.cs	2009-12-12 23:01:21 UTC (rev 4428)
+++ trunk/Tools/Maestro/Maestro/FormMain.cs	2009-12-12 23:29:28 UTC (rev 4429)
@@ -2022,24 +2022,17 @@
 									return;
-							object item = null;
-							using(System.IO.FileStream fs = System.IO.File.Open(OpenXmlFileDialog.FileName, System.IO.FileMode.Open, System.IO.FileAccess.Read, System.IO.FileShare.Read))
-								item = m_connection.DeserializeObject(m_editors.GetResourceInstanceTypeFromResourceID(document.ResourceId), fs);
-							EditorInterface edir = new EditorInterface(this, new TabPage(m_editors.GetResourceNameFromResourceID(document.ResourceId)), document.ResourceId, true);
-							OSGeo.MapGuide.Maestro.ResourceEditors.XmlEditorControl c = new OSGeo.MapGuide.Maestro.ResourceEditors.XmlEditorControl(edir);
-							c.Resource = item;
-							c.ResourceId = document.ResourceId;
-							edir.Page.Controls.Add(c);
-							c.Dock = DockStyle.Fill;
-							tabItems.TabPages.Add(edir.Page);
-							tabItems.SelectedTab = edir.Page;
-							edir.HasChanged();
-							m_userControls.Add(document.ResourceId, edir);
-                            tabItems_SelectedIndexChanged(sender, e);
+                            string tmpid = "Session:" + m_connection.SessionID + "//" + Guid.NewGuid().ToString() + "." + new MaestroAPI.ResourceIdentifier(document.ResourceId).Extension;
+                            using (System.IO.FileStream fs = System.IO.File.Open(OpenXmlFileDialog.FileName, System.IO.FileMode.Open, System.IO.FileAccess.Read, System.IO.FileShare.Read))
+                                m_connection.SetResourceXmlData(tmpid, fs);
+                            OpenResource(tmpid, typeof(ResourceEditors.XmlEditorControl));
 				catch (Exception ex)
+                    LastException = ex;
 					MessageBox.Show(this, string.Format(Strings.FormMain.XmlEditorError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/ScaleControls/ScaleRange.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/ScaleControls/ScaleRange.cs	2009-12-12 23:01:21 UTC (rev 4428)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/ScaleControls/ScaleRange.cs	2009-12-12 23:29:28 UTC (rev 4429)
@@ -37,6 +37,8 @@
         private VectorLayer m_owner;
+        public bool HasUnsupportedItems { get { return scaleRangeConditions.HasUnsupportedItems; } }
         public VectorLayer Owner
             get { return m_owner; }
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/ScaleControls/ScaleRangeConditions.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/ScaleControls/ScaleRangeConditions.cs	2009-12-12 23:01:21 UTC (rev 4428)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/ScaleControls/ScaleRangeConditions.cs	2009-12-12 23:29:28 UTC (rev 4429)
@@ -34,7 +34,9 @@
         private VectorScaleRangeType m_vsc;
         private bool m_isUpdating = false;
+        private bool m_hasUnsupportedItems = false;
+        public bool HasUnsupportedItems { get { return m_hasUnsupportedItems; } }
@@ -65,6 +67,7 @@
                 bool hasPoints = false;
                 bool hasLines = false;
                 bool hasAreas = false;
+                m_hasUnsupportedItems = false;
                 if (m_vsc.Items != null)
                     foreach (object o in m_vsc.Items)
@@ -83,6 +86,8 @@
                             hasAreas = true;
                             areaConditionList.SetItem(m_vsc, o as AreaTypeStyleType);
+                        else
+                            m_hasUnsupportedItems = true;
                 DisplayPoints.Checked = hasPoints;
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/ScaleControls/ScaleRangeList.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/ScaleControls/ScaleRangeList.cs	2009-12-12 23:01:21 UTC (rev 4428)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/ScaleControls/ScaleRangeList.cs	2009-12-12 23:29:28 UTC (rev 4429)
@@ -36,6 +36,18 @@
         private VectorScaleRangeType m_selectedItem;
+            get
+                foreach (ScaleRange sr in this.ControlList.Controls)
+                    if (sr.HasUnsupportedItems)
+                        return true;
+                return false;
@@ -43,7 +55,7 @@
                 m_owner = value;
-                    sr.Owner = m_owner; ;
+                    sr.Owner = m_owner;
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/Strings/VectorLayer.Designer.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/Strings/VectorLayer.Designer.cs	2009-12-12 23:01:21 UTC (rev 4428)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/Strings/VectorLayer.Designer.cs	2009-12-12 23:29:28 UTC (rev 4429)
@@ -77,5 +77,16 @@
                 return ResourceManager.GetString("SchemaMissingError", resourceCulture);
+        /// <summary>
+        ///   Looks up a localized string similar to This layer contains items that are not supported by the editor.
+        ///If you save this layer they may be removed.
+        ///It is recommended that you open this layer with the xml editor instead..
+        /// </summary>
+        internal static string UnsupportedItemsDetectedWarning {
+            get {
+                return ResourceManager.GetString("UnsupportedItemsDetectedWarning", resourceCulture);
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/Strings/VectorLayer.resx
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/Strings/VectorLayer.resx	2009-12-12 23:01:21 UTC (rev 4428)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/Strings/VectorLayer.resx	2009-12-12 23:29:28 UTC (rev 4429)
@@ -125,4 +125,10 @@
     <value>Cannot display editor, because no schema was selected</value>
     <comment>An error message that is displayed when the user attempts to perform an action that requires a schema present, but none is selected</comment>
   </data>
+  <data name="UnsupportedItemsDetectedWarning" xml:space="preserve">
+    <value>This layer contains items that are not supported by the editor.
+If you save this layer they may be removed.
+It is recommended that you open this layer with the xml editor instead.</value>
+    <comment>A warning message that is displayed if the layer has unsupported items</comment>
+  </data>
 </root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/VectorLayer.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/VectorLayer.cs	2009-12-12 23:01:21 UTC (rev 4428)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/VectorLayer.cs	2009-12-12 23:29:28 UTC (rev 4429)
@@ -92,6 +92,7 @@
         private ToolStripButton SortScalesByDisplayRangeButton;
         private FeatureSourceDescription.FeatureSourceSchema m_selectedSchema;
+        private bool m_hasReportedUnsupportedItems = false;
     	public VectorLayer()
@@ -614,6 +615,12 @@
                     scaleRangeList.SetItem(vl);
                     scaleRangeList.ResizeAuto();
+                    if (!m_hasReportedUnsupportedItems && scaleRangeList.HasUnsupportedItems)
+                        m_hasReportedUnsupportedItems = true;
+                        MessageBox.Show(this, Strings.VectorLayer.UnsupportedItemsDetectedWarning, Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Warning);
 			finally
More information about the mapguide-commits mailing list
