[mapguide-commits] r4431 - in trunk/Tools/Maestro: . Installer Localization Localization/ConvertResX/ConvertResX/Properties Maestro Maestro/FusionEditor Maestro/LoginForm/Properties Maestro/MaestroEditorInterface Maestro/ResourceBrowser/Properties Maestro/ResourceEditors Maestro/ResourceValidators MaestroAPI MaestroAPI/PackageBuilder/Properties MaestroAPI/XsdGenerator new w generics/Properties MgCooker/MgCookerCommandline/Properties MgCooker/Properties
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Dec 12 20:14:26 EST 2009
Author: ksgeograf
Date: 2009-12-12 20:14:26 -0500 (Sat, 12 Dec 2009)
New Revision: 4431
   trunk/Tools/Maestro/Installer/Maestro.wxs
   trunk/Tools/Maestro/Installer/UpgradeData.wxi
   trunk/Tools/Maestro/Installer/incBinFiles.wxs
   trunk/Tools/Maestro/Installer/incLocFiles.da-DK.wxs
   trunk/Tools/Maestro/Installer/incLocFiles.es-ES.wxs
   trunk/Tools/Maestro/Installer/incLocFiles.fr-FR.wxs
   trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/Localization/configuration.xml
   trunk/Tools/Maestro/Maestro/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs
   trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs
   trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/build.bat
Maestro:
Build r4431, minor fixes to build file.
Modified: trunk/Tools/Maestro/Installer/Maestro.wxs
--- trunk/Tools/Maestro/Installer/Maestro.wxs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/Installer/Maestro.wxs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -78,10 +78,10 @@
     <!-- Launch Maestro setup -->
     <Property Id="WIXUI_EXITDIALOGOPTIONALCHECKBOXTEXT" Value="Launch MapGuide Maestro now" />
     <Property Id="WIXUI_EXITDIALOGOPTIONALCHECKBOX" Value="1" />
-    <CustomAction Id="LaunchApplication" FileKey="file_MAESTROBIN_5" Impersonate="yes" ExeCommand="" Return="asyncNoWait" />
+    <CustomAction Id="LaunchApplication" FileKey="file_MAESTROBIN_4" Impersonate="yes" ExeCommand="" Return="asyncNoWait" />
     <!-- TODO: Figure out why this does not work...
-    <Property Id="WixShellExecTarget" Value="[#comp_MAESTROBIN_5]" />
+    <Property Id="WixShellExecTarget" Value="[#comp_MAESTROBIN_4]" />
     <CustomAction Id="LaunchApplication" BinaryKey="WixCA" DllEntry="WixShellExec" Impersonate="yes" />
Modified: trunk/Tools/Maestro/Installer/UpgradeData.wxi
--- trunk/Tools/Maestro/Installer/UpgradeData.wxi	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/Installer/UpgradeData.wxi	2009-12-13 01:14:26 UTC (rev 4431)
@@ -3,7 +3,7 @@
   <?define UpgradeCode="A7C2ECB3-1991-47B9-A22E-8844BB95CAE2" ?>
   <!-- Remember to change product version on each install -->
-  <?define ProductVersion="1.1.0.4358" ?>
+  <?define ProductVersion="1.1.0.4431" ?>
   <?define Manufacturer="HexaD" ?>
Modified: trunk/Tools/Maestro/Installer/incBinFiles.wxs
--- trunk/Tools/Maestro/Installer/incBinFiles.wxs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/Installer/incBinFiles.wxs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -3,10 +3,10 @@
   <!--<CommandLineOptions>
   <Producer>Autogenerated by Paraffin - Wintellect - John Robbins - john at wintellect.com</Producer>
   <WARNING>Manual changes to this file may cause incorrect behavior.</WARNING>
-  <CreatedOn>10-12-2009 19:25</CreatedOn>
-  <Directory>..\InstallerTempRelease\MapGuideMaestro\</Directory>
+  <CreatedOn>13-12-2009 02:08</CreatedOn>
+  <Directory>C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\</Directory>
   <Custom>MAESTROBIN</Custom>
-  <DirAlias>..\InstallerTempRelease\MapGuideMaestro\</DirAlias>
+  <DirAlias>C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\</DirAlias>
   <Increment>1</Increment>
   <Guids>true</Guids>
   <Win64>false</Win64>
@@ -19,417 +19,416 @@
     <Dir>.svn</Dir>
   </DirExcludes>
   <NextDirectoryNumber>8</NextDirectoryNumber>
-  <NextComponentNumber>369</NextComponentNumber>
+  <NextComponentNumber>368</NextComponentNumber>
 </CommandLineOptions>-->
   <Fragment>
     <ComponentGroup Id="group_MAESTROBIN">
       <ComponentRef Id="comp_MAESTROBIN_0" />
-      <ComponentRef Id="comp_MAESTROBIN_22" />
-      <ComponentRef Id="comp_MAESTROBIN_69" />
-      <ComponentRef Id="comp_MAESTROBIN_148" />
+      <ComponentRef Id="comp_MAESTROBIN_21" />
+      <ComponentRef Id="comp_MAESTROBIN_68" />
+      <ComponentRef Id="comp_MAESTROBIN_147" />
+      <ComponentRef Id="comp_MAESTROBIN_155" />
       <ComponentRef Id="comp_MAESTROBIN_156" />
-      <ComponentRef Id="comp_MAESTROBIN_157" />
-      <ComponentRef Id="comp_MAESTROBIN_293" />
-      <ComponentRef Id="comp_MAESTROBIN_363" />
+      <ComponentRef Id="comp_MAESTROBIN_292" />
+      <ComponentRef Id="comp_MAESTROBIN_362" />
     </ComponentGroup>
     <DirectoryRef Id="INSTALLLOCATION">
       <Directory Id="dir_MapGuideMaestro_0" Name="MapGuideMaestro">
-        <Component Id="comp_MAESTROBIN_0" DiskId="1" KeyPath="yes" Guid="8BCB4EA8-D508-41F4-94FC-E978DF2460C7">
-          <File Id="file_MAESTROBIN_0" Name="ColorBrewer.csv" Source="..\InstallerTempRelease\MapGuideMaestro\ColorBrewer.csv" />
-          <File Id="file_MAESTROBIN_1" Name="EditorMap.xml" Source="..\InstallerTempRelease\MapGuideMaestro\EditorMap.xml" />
-          <File Id="file_MAESTROBIN_2" Name="Globalizator.dll" Source="..\InstallerTempRelease\MapGuideMaestro\Globalizator.dll" />
-          <File Id="file_MAESTROBIN_3" Name="ICSharpCode.SharpZipLib.dll" Source="..\InstallerTempRelease\MapGuideMaestro\ICSharpCode.SharpZipLib.dll" />
-          <File Id="file_MAESTROBIN_4" Name="license.txt" Source="..\InstallerTempRelease\MapGuideMaestro\license.txt" />
-          <File Id="file_MAESTROBIN_5" Name="Maestro.exe" Source="..\InstallerTempRelease\MapGuideMaestro\Maestro.exe" />
-          <File Id="file_MAESTROBIN_6" Name="Maestro.exe.config" Source="..\InstallerTempRelease\MapGuideMaestro\Maestro.exe.config" />
-          <File Id="file_MAESTROBIN_7" Name="MapGuideDotNetApi.dll" Source="..\InstallerTempRelease\MapGuideMaestro\MapGuideDotNetApi.dll" />
-          <File Id="file_MAESTROBIN_8" Name="MgCooker.exe" Source="..\InstallerTempRelease\MapGuideMaestro\MgCooker.exe" />
-          <File Id="file_MAESTROBIN_9" Name="MgCookerCommandline.exe" Source="..\InstallerTempRelease\MapGuideMaestro\MgCookerCommandline.exe" />
-          <File Id="file_MAESTROBIN_10" Name="OSGeo.MapGuide.Maestro.FusionEditor.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.FusionEditor.dll" />
-          <File Id="file_MAESTROBIN_11" Name="OSGeo.MapGuide.Maestro.LoginForm.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.LoginForm.dll" />
-          <File Id="file_MAESTROBIN_12" Name="OSGeo.MapGuide.Maestro.MaestroEditorInterface.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.MaestroEditorInterface.dll" />
-          <File Id="file_MAESTROBIN_13" Name="OSGeo.MapGuide.Maestro.ResourceBrowser.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.ResourceBrowser.dll" />
-          <File Id="file_MAESTROBIN_14" Name="OSGeo.MapGuide.Maestro.ResourceEditors.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.ResourceEditors.dll" />
-          <File Id="file_MAESTROBIN_15" Name="OSGeo.MapGuide.Maestro.ResourceValidators.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.ResourceValidators.dll" />
-          <File Id="file_MAESTROBIN_16" Name="OSGeo.MapGuide.MaestroAPI.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.MaestroAPI.dll" />
-          <File Id="file_MAESTROBIN_17" Name="OSGeo.MapGuide.MaestroAPI.PackageBuilder.dll" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.MaestroAPI.PackageBuilder.dll" />
-          <File Id="file_MAESTROBIN_18" Name="OSGeo.MapGuide.MaestroAPI.xml" Source="..\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.MaestroAPI.xml" />
-          <File Id="file_MAESTROBIN_19" Name="ProviderMap.xml" Source="..\InstallerTempRelease\MapGuideMaestro\ProviderMap.xml" />
-          <File Id="file_MAESTROBIN_20" Name="Topology.dll" Source="..\InstallerTempRelease\MapGuideMaestro\Topology.dll" />
-          <File Id="file_MAESTROBIN_21" Name="Topology.IO.MapGuide.dll" Source="..\InstallerTempRelease\MapGuideMaestro\Topology.IO.MapGuide.dll" />
+        <Component Id="comp_MAESTROBIN_0" DiskId="1" KeyPath="yes" Guid="8539349F-6E57-4345-9F9A-44672EA2E7FA">
+          <File Id="file_MAESTROBIN_0" Name="ColorBrewer.csv" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\ColorBrewer.csv" />
+          <File Id="file_MAESTROBIN_1" Name="EditorMap.xml" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\EditorMap.xml" />
+          <File Id="file_MAESTROBIN_2" Name="ICSharpCode.SharpZipLib.dll" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\ICSharpCode.SharpZipLib.dll" />
+          <File Id="file_MAESTROBIN_3" Name="license.txt" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\license.txt" />
+          <File Id="file_MAESTROBIN_4" Name="Maestro.exe" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Maestro.exe" />
+          <File Id="file_MAESTROBIN_5" Name="Maestro.exe.config" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Maestro.exe.config" />
+          <File Id="file_MAESTROBIN_6" Name="MapGuideDotNetApi.dll" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\MapGuideDotNetApi.dll" />
+          <File Id="file_MAESTROBIN_7" Name="MgCooker.exe" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\MgCooker.exe" />
+          <File Id="file_MAESTROBIN_8" Name="MgCookerCommandline.exe" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\MgCookerCommandline.exe" />
+          <File Id="file_MAESTROBIN_9" Name="OSGeo.MapGuide.Maestro.FusionEditor.dll" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.FusionEditor.dll" />
+          <File Id="file_MAESTROBIN_10" Name="OSGeo.MapGuide.Maestro.LoginForm.dll" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.LoginForm.dll" />
+          <File Id="file_MAESTROBIN_11" Name="OSGeo.MapGuide.Maestro.MaestroEditorInterface.dll" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.MaestroEditorInterface.dll" />
+          <File Id="file_MAESTROBIN_12" Name="OSGeo.MapGuide.Maestro.ResourceBrowser.dll" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.ResourceBrowser.dll" />
+          <File Id="file_MAESTROBIN_13" Name="OSGeo.MapGuide.Maestro.ResourceEditors.dll" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.ResourceEditors.dll" />
+          <File Id="file_MAESTROBIN_14" Name="OSGeo.MapGuide.Maestro.ResourceValidators.dll" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.Maestro.ResourceValidators.dll" />
+          <File Id="file_MAESTROBIN_15" Name="OSGeo.MapGuide.MaestroAPI.dll" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.MaestroAPI.dll" />
+          <File Id="file_MAESTROBIN_16" Name="OSGeo.MapGuide.MaestroAPI.PackageBuilder.dll" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.MaestroAPI.PackageBuilder.dll" />
+          <File Id="file_MAESTROBIN_17" Name="OSGeo.MapGuide.MaestroAPI.xml" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\OSGeo.MapGuide.MaestroAPI.xml" />
+          <File Id="file_MAESTROBIN_18" Name="ProviderMap.xml" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\ProviderMap.xml" />
+          <File Id="file_MAESTROBIN_19" Name="Topology.dll" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Topology.dll" />
+          <File Id="file_MAESTROBIN_20" Name="Topology.IO.MapGuide.dll" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Topology.IO.MapGuide.dll" />
         </Component>
         <Directory Id="dir_MapGuideMaestro_Schemas_1" Name="Schemas">
-          <Component Id="comp_MAESTROBIN_22" DiskId="1" KeyPath="yes" Guid="3D801BF7-F3D7-4009-A056-EAA954B1C8DC">
-            <File Id="file_MAESTROBIN_22" Name="ApplicationDefinition-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ApplicationDefinition-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_23" Name="ApplicationDefinitionInfo-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ApplicationDefinitionInfo-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_24" Name="DataStoreList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\DataStoreList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_25" Name="DrawingSectionList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\DrawingSectionList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_26" Name="DrawingSectionResourceList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\DrawingSectionResourceList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_27" Name="DrawingSource-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\DrawingSource-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_28" Name="Envelope-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\Envelope-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_29" Name="FdoLongTransactionList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FdoLongTransactionList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_30" Name="FdoProviderCapabilities-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FdoProviderCapabilities-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_31" Name="FdoSpatialContextList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FdoSpatialContextList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_32" Name="FeatureProviderRegistry-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FeatureProviderRegistry-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_33" Name="FeatureProviders-0.0.1.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FeatureProviders-0.0.1.xsd" />
-            <File Id="file_MAESTROBIN_34" Name="FeatureSet-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FeatureSet-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_35" Name="FeatureSource-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\FeatureSource-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_36" Name="Group-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\Group-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_37" Name="GroupList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\GroupList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_38" Name="LayerDefinition-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\LayerDefinition-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_39" Name="LayerDefinition-1.1.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\LayerDefinition-1.1.0.xsd" />
-            <File Id="file_MAESTROBIN_40" Name="LayerDefinition-1.2.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\LayerDefinition-1.2.0.xsd" />
-            <File Id="file_MAESTROBIN_41" Name="LayerDefinition-1.3.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\LayerDefinition-1.3.0.xsd" />
-            <File Id="file_MAESTROBIN_42" Name="LoadProcedure-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\LoadProcedure-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_43" Name="MapDefinition-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\MapDefinition-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_44" Name="PlatformCommon-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\PlatformCommon-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_45" Name="PrintLayout-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\PrintLayout-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_46" Name="RepositoryContent-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\RepositoryContent-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_47" Name="RepositoryList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\RepositoryList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_48" Name="ResourceDataList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceDataList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_49" Name="ResourceDocumentHeader-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceDocumentHeader-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_50" Name="ResourceFolderHeader-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceFolderHeader-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_51" Name="ResourceList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_52" Name="ResourcePackageManifest-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourcePackageManifest-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_53" Name="ResourceReferenceList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceReferenceList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_54" Name="ResourceSecurity-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceSecurity-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_55" Name="Role-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\Role-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_56" Name="SelectAggregate-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SelectAggregate-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_57" Name="Server-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\Server-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_58" Name="ServerList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\ServerList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_59" Name="SiteInformation-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SiteInformation-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_60" Name="SiteVersion-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SiteVersion-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_61" Name="SqlSelect-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SqlSelect-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_62" Name="SymbolDefinition-1.1.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SymbolDefinition-1.1.0.xsd" />
-            <File Id="file_MAESTROBIN_63" Name="SymbolLibrary-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\SymbolLibrary-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_64" Name="Types-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\Types-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_65" Name="UnmanagedDataList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\UnmanagedDataList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_66" Name="User-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\User-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_67" Name="UserList-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\UserList-1.0.0.xsd" />
-            <File Id="file_MAESTROBIN_68" Name="WebLayout-1.0.0.xsd" Source="..\InstallerTempRelease\MapGuideMaestro\Schemas\WebLayout-1.0.0.xsd" />
+          <Component Id="comp_MAESTROBIN_21" DiskId="1" KeyPath="yes" Guid="D2AB7B86-B58A-46F4-AB72-25E5A9F3491B">
+            <File Id="file_MAESTROBIN_21" Name="ApplicationDefinition-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\ApplicationDefinition-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_22" Name="ApplicationDefinitionInfo-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\ApplicationDefinitionInfo-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_23" Name="DataStoreList-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\DataStoreList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_24" Name="DrawingSectionList-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\DrawingSectionList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_25" Name="DrawingSectionResourceList-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\DrawingSectionResourceList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_26" Name="DrawingSource-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\DrawingSource-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_27" Name="Envelope-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\Envelope-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_28" Name="FdoLongTransactionList-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\FdoLongTransactionList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_29" Name="FdoProviderCapabilities-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\FdoProviderCapabilities-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_30" Name="FdoSpatialContextList-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\FdoSpatialContextList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_31" Name="FeatureProviderRegistry-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\FeatureProviderRegistry-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_32" Name="FeatureProviders-0.0.1.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\FeatureProviders-0.0.1.xsd" />
+            <File Id="file_MAESTROBIN_33" Name="FeatureSet-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\FeatureSet-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_34" Name="FeatureSource-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\FeatureSource-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_35" Name="Group-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\Group-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_36" Name="GroupList-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\GroupList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_37" Name="LayerDefinition-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\LayerDefinition-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_38" Name="LayerDefinition-1.1.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\LayerDefinition-1.1.0.xsd" />
+            <File Id="file_MAESTROBIN_39" Name="LayerDefinition-1.2.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\LayerDefinition-1.2.0.xsd" />
+            <File Id="file_MAESTROBIN_40" Name="LayerDefinition-1.3.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\LayerDefinition-1.3.0.xsd" />
+            <File Id="file_MAESTROBIN_41" Name="LoadProcedure-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\LoadProcedure-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_42" Name="MapDefinition-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\MapDefinition-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_43" Name="PlatformCommon-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\PlatformCommon-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_44" Name="PrintLayout-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\PrintLayout-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_45" Name="RepositoryContent-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\RepositoryContent-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_46" Name="RepositoryList-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\RepositoryList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_47" Name="ResourceDataList-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceDataList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_48" Name="ResourceDocumentHeader-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceDocumentHeader-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_49" Name="ResourceFolderHeader-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceFolderHeader-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_50" Name="ResourceList-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_51" Name="ResourcePackageManifest-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\ResourcePackageManifest-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_52" Name="ResourceReferenceList-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceReferenceList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_53" Name="ResourceSecurity-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\ResourceSecurity-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_54" Name="Role-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\Role-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_55" Name="SelectAggregate-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\SelectAggregate-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_56" Name="Server-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\Server-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_57" Name="ServerList-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\ServerList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_58" Name="SiteInformation-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\SiteInformation-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_59" Name="SiteVersion-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\SiteVersion-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_60" Name="SqlSelect-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\SqlSelect-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_61" Name="SymbolDefinition-1.1.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\SymbolDefinition-1.1.0.xsd" />
+            <File Id="file_MAESTROBIN_62" Name="SymbolLibrary-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\SymbolLibrary-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_63" Name="Types-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\Types-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_64" Name="UnmanagedDataList-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\UnmanagedDataList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_65" Name="User-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\User-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_66" Name="UserList-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\UserList-1.0.0.xsd" />
+            <File Id="file_MAESTROBIN_67" Name="WebLayout-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\WebLayout-1.0.0.xsd" />
           </Component>
         </Directory>
         <Directory Id="dir_MapGuideMaestro_stdicons_2" Name="stdicons">
-          <Component Id="comp_MAESTROBIN_69" DiskId="1" KeyPath="yes" Guid="DB8686D0-98E2-41D0-9E3E-AC4DC6CEF101">
-            <File Id="file_MAESTROBIN_69" Name="copyright.txt" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\copyright.txt" />
-            <File Id="file_MAESTROBIN_70" Name="icon_back.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_back.gif" />
-            <File Id="file_MAESTROBIN_71" Name="icon_back_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_back_disabled.gif" />
-            <File Id="file_MAESTROBIN_72" Name="icon_buffer.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_buffer.gif" />
-            <File Id="file_MAESTROBIN_73" Name="icon_buffer_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_buffer_disabled.gif" />
-            <File Id="file_MAESTROBIN_74" Name="icon_clearselect.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_clearselect.gif" />
-            <File Id="file_MAESTROBIN_75" Name="icon_clearselect_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_clearselect_disabled.gif" />
-            <File Id="file_MAESTROBIN_76" Name="icon_copy.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_copy.gif" />
-            <File Id="file_MAESTROBIN_77" Name="icon_copy_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_copy_disabled.gif" />
-            <File Id="file_MAESTROBIN_78" Name="icon_ctxarrow.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_ctxarrow.gif" />
-            <File Id="file_MAESTROBIN_79" Name="icon_fitwindow.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_fitwindow.gif" />
-            <File Id="file_MAESTROBIN_80" Name="icon_fitwindow_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_fitwindow_disabled.gif" />
-            <File Id="file_MAESTROBIN_81" Name="icon_forward.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_forward.gif" />
-            <File Id="file_MAESTROBIN_82" Name="icon_forward_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_forward_disabled.gif" />
-            <File Id="file_MAESTROBIN_83" Name="icon_help.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_help.gif" />
-            <File Id="file_MAESTROBIN_84" Name="icon_help_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_help_disabled.gif" />
-            <File Id="file_MAESTROBIN_85" Name="icon_home.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_home.gif" />
-            <File Id="file_MAESTROBIN_86" Name="icon_home_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_home_disabled.gif" />
-            <File Id="file_MAESTROBIN_87" Name="icon_invokescript.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_invokescript.gif" />
-            <File Id="file_MAESTROBIN_88" Name="icon_invokescript_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_invokescript_disabled.gif" />
-            <File Id="file_MAESTROBIN_89" Name="icon_invokeurl.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_invokeurl.gif" />
-            <File Id="file_MAESTROBIN_90" Name="icon_invokeurl_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_invokeurl_disabled.gif" />
-            <File Id="file_MAESTROBIN_91" Name="icon_loading.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_loading.gif" />
-            <File Id="file_MAESTROBIN_92" Name="icon_measure.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_measure.gif" />
-            <File Id="file_MAESTROBIN_93" Name="icon_measure_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_measure_disabled.gif" />
-            <File Id="file_MAESTROBIN_94" Name="icon_menuarrow.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_menuarrow.gif" />
-            <File Id="file_MAESTROBIN_95" Name="icon_menuarrowup.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_menuarrowup.gif" />
-            <File Id="file_MAESTROBIN_96" Name="icon_menuarrowup_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_menuarrowup_disabled.gif" />
-            <File Id="file_MAESTROBIN_97" Name="icon_menuarrow_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_menuarrow_disabled.gif" />
-            <File Id="file_MAESTROBIN_98" Name="icon_null.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_null.gif" />
-            <File Id="file_MAESTROBIN_99" Name="icon_pan.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_pan.gif" />
-            <File Id="file_MAESTROBIN_100" Name="icon_pandown.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_pandown.gif" />
-            <File Id="file_MAESTROBIN_101" Name="icon_pandown_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_pandown_disabled.gif" />
-            <File Id="file_MAESTROBIN_102" Name="icon_panleft.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panleft.gif" />
-            <File Id="file_MAESTROBIN_103" Name="icon_panleft_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panleft_disabled.gif" />
-            <File Id="file_MAESTROBIN_104" Name="icon_panright.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panright.gif" />
-            <File Id="file_MAESTROBIN_105" Name="icon_panright_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panright_disabled.gif" />
-            <File Id="file_MAESTROBIN_106" Name="icon_panup.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panup.gif" />
-            <File Id="file_MAESTROBIN_107" Name="icon_panup_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panup_disabled.gif" />
-            <File Id="file_MAESTROBIN_108" Name="icon_pan_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_pan_disabled.gif" />
-            <File Id="file_MAESTROBIN_109" Name="icon_plotdwf.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_plotdwf.gif" />
-            <File Id="file_MAESTROBIN_110" Name="icon_plotdwf_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_plotdwf_disabled.gif" />
-            <File Id="file_MAESTROBIN_111" Name="icon_popupscrolldown.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_popupscrolldown.gif" />
-            <File Id="file_MAESTROBIN_112" Name="icon_print.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_print.gif" />
-            <File Id="file_MAESTROBIN_113" Name="icon_printablepage.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_printablepage.gif" />
-            <File Id="file_MAESTROBIN_114" Name="icon_printablepage_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_printablepage_disabled.gif" />
-            <File Id="file_MAESTROBIN_115" Name="icon_print_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_print_disabled.gif" />
-            <File Id="file_MAESTROBIN_116" Name="icon_refreshmap.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_refreshmap.gif" />
-            <File Id="file_MAESTROBIN_117" Name="icon_refreshmap_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_refreshmap_disabled.gif" />
-            <File Id="file_MAESTROBIN_118" Name="icon_restorecenter.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_restorecenter.gif" />
-            <File Id="file_MAESTROBIN_119" Name="icon_restorecenter_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_restorecenter_disabled.gif" />
-            <File Id="file_MAESTROBIN_120" Name="icon_search.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_search.gif" />
-            <File Id="file_MAESTROBIN_121" Name="icon_search_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_search_disabled.gif" />
-            <File Id="file_MAESTROBIN_122" Name="icon_select.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_select.gif" />
-            <File Id="file_MAESTROBIN_123" Name="icon_selectpolygon.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectpolygon.gif" />
-            <File Id="file_MAESTROBIN_124" Name="icon_selectpolygon_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectpolygon_disabled.gif" />
-            <File Id="file_MAESTROBIN_125" Name="icon_selectradius.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectradius.gif" />
-            <File Id="file_MAESTROBIN_126" Name="icon_selectradius_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectradius_disabled.gif" />
-            <File Id="file_MAESTROBIN_127" Name="icon_selectwithin.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectwithin.gif" />
-            <File Id="file_MAESTROBIN_128" Name="icon_selectwithin_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectwithin_disabled.gif" />
-            <File Id="file_MAESTROBIN_129" Name="icon_select_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_select_disabled.gif" />
-            <File Id="file_MAESTROBIN_130" Name="icon_tasks.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_tasks.gif" />
-            <File Id="file_MAESTROBIN_131" Name="icon_tasks_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_tasks_disabled.gif" />
-            <File Id="file_MAESTROBIN_132" Name="icon_viewoptions.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_viewoptions.gif" />
-            <File Id="file_MAESTROBIN_133" Name="icon_viewoptions_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_viewoptions_disabled.gif" />
-            <File Id="file_MAESTROBIN_134" Name="icon_zoom.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoom.gif" />
-            <File Id="file_MAESTROBIN_135" Name="icon_zoomin.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomin.gif" />
-            <File Id="file_MAESTROBIN_136" Name="icon_zoomin_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomin_disabled.gif" />
-            <File Id="file_MAESTROBIN_137" Name="icon_zoomnext.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomnext.gif" />
-            <File Id="file_MAESTROBIN_138" Name="icon_zoomnext_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomnext_disabled.gif" />
-            <File Id="file_MAESTROBIN_139" Name="icon_zoomout.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomout.gif" />
-            <File Id="file_MAESTROBIN_140" Name="icon_zoomout_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomout_disabled.gif" />
-            <File Id="file_MAESTROBIN_141" Name="icon_zoomprev.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomprev.gif" />
-            <File Id="file_MAESTROBIN_142" Name="icon_zoomprev_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomprev_disabled.gif" />
-            <File Id="file_MAESTROBIN_143" Name="icon_zoomrect.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomrect.gif" />
-            <File Id="file_MAESTROBIN_144" Name="icon_zoomrect_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomrect_disabled.gif" />
-            <File Id="file_MAESTROBIN_145" Name="icon_zoomselect.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomselect.gif" />
-            <File Id="file_MAESTROBIN_146" Name="icon_zoomselect_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomselect_disabled.gif" />
-            <File Id="file_MAESTROBIN_147" Name="icon_zoom_disabled.gif" Source="..\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoom_disabled.gif" />
+          <Component Id="comp_MAESTROBIN_68" DiskId="1" KeyPath="yes" Guid="1AC13C49-05B5-4C82-BCCB-65BEBDA528A3">
+            <File Id="file_MAESTROBIN_68" Name="copyright.txt" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\copyright.txt" />
+            <File Id="file_MAESTROBIN_69" Name="icon_back.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_back.gif" />
+            <File Id="file_MAESTROBIN_70" Name="icon_back_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_back_disabled.gif" />
+            <File Id="file_MAESTROBIN_71" Name="icon_buffer.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_buffer.gif" />
+            <File Id="file_MAESTROBIN_72" Name="icon_buffer_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_buffer_disabled.gif" />
+            <File Id="file_MAESTROBIN_73" Name="icon_clearselect.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_clearselect.gif" />
+            <File Id="file_MAESTROBIN_74" Name="icon_clearselect_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_clearselect_disabled.gif" />
+            <File Id="file_MAESTROBIN_75" Name="icon_copy.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_copy.gif" />
+            <File Id="file_MAESTROBIN_76" Name="icon_copy_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_copy_disabled.gif" />
+            <File Id="file_MAESTROBIN_77" Name="icon_ctxarrow.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_ctxarrow.gif" />
+            <File Id="file_MAESTROBIN_78" Name="icon_fitwindow.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_fitwindow.gif" />
+            <File Id="file_MAESTROBIN_79" Name="icon_fitwindow_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_fitwindow_disabled.gif" />
+            <File Id="file_MAESTROBIN_80" Name="icon_forward.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_forward.gif" />
+            <File Id="file_MAESTROBIN_81" Name="icon_forward_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_forward_disabled.gif" />
+            <File Id="file_MAESTROBIN_82" Name="icon_help.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_help.gif" />
+            <File Id="file_MAESTROBIN_83" Name="icon_help_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_help_disabled.gif" />
+            <File Id="file_MAESTROBIN_84" Name="icon_home.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_home.gif" />
+            <File Id="file_MAESTROBIN_85" Name="icon_home_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_home_disabled.gif" />
+            <File Id="file_MAESTROBIN_86" Name="icon_invokescript.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_invokescript.gif" />
+            <File Id="file_MAESTROBIN_87" Name="icon_invokescript_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_invokescript_disabled.gif" />
+            <File Id="file_MAESTROBIN_88" Name="icon_invokeurl.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_invokeurl.gif" />
+            <File Id="file_MAESTROBIN_89" Name="icon_invokeurl_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_invokeurl_disabled.gif" />
+            <File Id="file_MAESTROBIN_90" Name="icon_loading.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_loading.gif" />
+            <File Id="file_MAESTROBIN_91" Name="icon_measure.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_measure.gif" />
+            <File Id="file_MAESTROBIN_92" Name="icon_measure_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_measure_disabled.gif" />
+            <File Id="file_MAESTROBIN_93" Name="icon_menuarrow.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_menuarrow.gif" />
+            <File Id="file_MAESTROBIN_94" Name="icon_menuarrowup.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_menuarrowup.gif" />
+            <File Id="file_MAESTROBIN_95" Name="icon_menuarrowup_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_menuarrowup_disabled.gif" />
+            <File Id="file_MAESTROBIN_96" Name="icon_menuarrow_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_menuarrow_disabled.gif" />
+            <File Id="file_MAESTROBIN_97" Name="icon_null.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_null.gif" />
+            <File Id="file_MAESTROBIN_98" Name="icon_pan.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_pan.gif" />
+            <File Id="file_MAESTROBIN_99" Name="icon_pandown.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_pandown.gif" />
+            <File Id="file_MAESTROBIN_100" Name="icon_pandown_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_pandown_disabled.gif" />
+            <File Id="file_MAESTROBIN_101" Name="icon_panleft.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panleft.gif" />
+            <File Id="file_MAESTROBIN_102" Name="icon_panleft_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panleft_disabled.gif" />
+            <File Id="file_MAESTROBIN_103" Name="icon_panright.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panright.gif" />
+            <File Id="file_MAESTROBIN_104" Name="icon_panright_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panright_disabled.gif" />
+            <File Id="file_MAESTROBIN_105" Name="icon_panup.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panup.gif" />
+            <File Id="file_MAESTROBIN_106" Name="icon_panup_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_panup_disabled.gif" />
+            <File Id="file_MAESTROBIN_107" Name="icon_pan_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_pan_disabled.gif" />
+            <File Id="file_MAESTROBIN_108" Name="icon_plotdwf.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_plotdwf.gif" />
+            <File Id="file_MAESTROBIN_109" Name="icon_plotdwf_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_plotdwf_disabled.gif" />
+            <File Id="file_MAESTROBIN_110" Name="icon_popupscrolldown.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_popupscrolldown.gif" />
+            <File Id="file_MAESTROBIN_111" Name="icon_print.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_print.gif" />
+            <File Id="file_MAESTROBIN_112" Name="icon_printablepage.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_printablepage.gif" />
+            <File Id="file_MAESTROBIN_113" Name="icon_printablepage_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_printablepage_disabled.gif" />
+            <File Id="file_MAESTROBIN_114" Name="icon_print_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_print_disabled.gif" />
+            <File Id="file_MAESTROBIN_115" Name="icon_refreshmap.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_refreshmap.gif" />
+            <File Id="file_MAESTROBIN_116" Name="icon_refreshmap_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_refreshmap_disabled.gif" />
+            <File Id="file_MAESTROBIN_117" Name="icon_restorecenter.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_restorecenter.gif" />
+            <File Id="file_MAESTROBIN_118" Name="icon_restorecenter_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_restorecenter_disabled.gif" />
+            <File Id="file_MAESTROBIN_119" Name="icon_search.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_search.gif" />
+            <File Id="file_MAESTROBIN_120" Name="icon_search_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_search_disabled.gif" />
+            <File Id="file_MAESTROBIN_121" Name="icon_select.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_select.gif" />
+            <File Id="file_MAESTROBIN_122" Name="icon_selectpolygon.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectpolygon.gif" />
+            <File Id="file_MAESTROBIN_123" Name="icon_selectpolygon_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectpolygon_disabled.gif" />
+            <File Id="file_MAESTROBIN_124" Name="icon_selectradius.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectradius.gif" />
+            <File Id="file_MAESTROBIN_125" Name="icon_selectradius_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectradius_disabled.gif" />
+            <File Id="file_MAESTROBIN_126" Name="icon_selectwithin.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectwithin.gif" />
+            <File Id="file_MAESTROBIN_127" Name="icon_selectwithin_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_selectwithin_disabled.gif" />
+            <File Id="file_MAESTROBIN_128" Name="icon_select_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_select_disabled.gif" />
+            <File Id="file_MAESTROBIN_129" Name="icon_tasks.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_tasks.gif" />
+            <File Id="file_MAESTROBIN_130" Name="icon_tasks_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_tasks_disabled.gif" />
+            <File Id="file_MAESTROBIN_131" Name="icon_viewoptions.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_viewoptions.gif" />
+            <File Id="file_MAESTROBIN_132" Name="icon_viewoptions_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_viewoptions_disabled.gif" />
+            <File Id="file_MAESTROBIN_133" Name="icon_zoom.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoom.gif" />
+            <File Id="file_MAESTROBIN_134" Name="icon_zoomin.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomin.gif" />
+            <File Id="file_MAESTROBIN_135" Name="icon_zoomin_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomin_disabled.gif" />
+            <File Id="file_MAESTROBIN_136" Name="icon_zoomnext.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomnext.gif" />
+            <File Id="file_MAESTROBIN_137" Name="icon_zoomnext_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomnext_disabled.gif" />
+            <File Id="file_MAESTROBIN_138" Name="icon_zoomout.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomout.gif" />
+            <File Id="file_MAESTROBIN_139" Name="icon_zoomout_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomout_disabled.gif" />
+            <File Id="file_MAESTROBIN_140" Name="icon_zoomprev.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomprev.gif" />
+            <File Id="file_MAESTROBIN_141" Name="icon_zoomprev_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomprev_disabled.gif" />
+            <File Id="file_MAESTROBIN_142" Name="icon_zoomrect.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomrect.gif" />
+            <File Id="file_MAESTROBIN_143" Name="icon_zoomrect_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomrect_disabled.gif" />
+            <File Id="file_MAESTROBIN_144" Name="icon_zoomselect.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomselect.gif" />
+            <File Id="file_MAESTROBIN_145" Name="icon_zoomselect_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoomselect_disabled.gif" />
+            <File Id="file_MAESTROBIN_146" Name="icon_zoom_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_zoom_disabled.gif" />
           </Component>
         </Directory>
         <Directory Id="dir_MapGuideMaestro_Templates_3" Name="Templates">
-          <Component Id="comp_MAESTROBIN_148" DiskId="1" KeyPath="yes" Guid="7D523846-878A-4D79-86BE-93DC837966DE">
-            <File Id="file_MAESTROBIN_148" Name="Dataconnection.FeatureSource" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Dataconnection.FeatureSource" />
-            <File Id="file_MAESTROBIN_149" Name="Fusion Application.ApplicationDefinition" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Fusion Application.ApplicationDefinition" />
-            <File Id="file_MAESTROBIN_150" Name="Layer.LayerDefinition" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Layer.LayerDefinition" />
-            <File Id="file_MAESTROBIN_151" Name="Layout.WebLayout" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Layout.WebLayout" />
-            <File Id="file_MAESTROBIN_152" Name="Map.MapDefinition" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Map.MapDefinition" />
-            <File Id="file_MAESTROBIN_153" Name="Print Layout.PrintLayout" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Print Layout.PrintLayout" />
-            <File Id="file_MAESTROBIN_154" Name="Symbol Definition.SymbolDefinition" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Symbol Definition.SymbolDefinition" />
-            <File Id="file_MAESTROBIN_155" Name="Symbol Library.SymbolLibrary" Source="..\InstallerTempRelease\MapGuideMaestro\Templates\Symbol Library.SymbolLibrary" />
+          <Component Id="comp_MAESTROBIN_147" DiskId="1" KeyPath="yes" Guid="6F783FAF-92BB-45D9-B37E-6DA1E57A70E4">
+            <File Id="file_MAESTROBIN_147" Name="Dataconnection.FeatureSource" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Dataconnection.FeatureSource" />
+            <File Id="file_MAESTROBIN_148" Name="Fusion Application.ApplicationDefinition" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Fusion Application.ApplicationDefinition" />
+            <File Id="file_MAESTROBIN_149" Name="Layer.LayerDefinition" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Layer.LayerDefinition" />
+            <File Id="file_MAESTROBIN_150" Name="Layout.WebLayout" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Layout.WebLayout" />
+            <File Id="file_MAESTROBIN_151" Name="Map.MapDefinition" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Map.MapDefinition" />
+            <File Id="file_MAESTROBIN_152" Name="Print Layout.PrintLayout" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Print Layout.PrintLayout" />
+            <File Id="file_MAESTROBIN_153" Name="Symbol Definition.SymbolDefinition" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Symbol Definition.SymbolDefinition" />
+            <File Id="file_MAESTROBIN_154" Name="Symbol Library.SymbolLibrary" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Symbol Library.SymbolLibrary" />
           </Component>
         </Directory>
         <Directory Id="dir_MapGuideMaestro_WebStudio_4" Name="WebStudio">
-          <Component Id="comp_MAESTROBIN_156" DiskId="1" KeyPath="yes" Guid="BF1E1737-C128-468E-B761-AE841B9E862B">
-            <File Id="file_MAESTROBIN_156" Name="copyright.txt" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\copyright.txt" />
+          <Component Id="comp_MAESTROBIN_155" DiskId="1" KeyPath="yes" Guid="CA150D19-B32A-46AF-B807-A511CCEF4D0B">
+            <File Id="file_MAESTROBIN_155" Name="copyright.txt" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\copyright.txt" />
           </Component>
           <Directory Id="dir_MapGuideMaestro_WebStudio_areas_5" Name="areas">
-            <Component Id="comp_MAESTROBIN_157" DiskId="1" KeyPath="yes" Guid="51AE0BB4-7969-4D39-B049-FD5741321E37">
-              <File Id="file_MAESTROBIN_157" Name="Acad_iso02w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso02w100.png" />
-              <File Id="file_MAESTROBIN_158" Name="Acad_iso03w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso03w100.png" />
-              <File Id="file_MAESTROBIN_159" Name="Acad_iso04w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso04w100.png" />
-              <File Id="file_MAESTROBIN_160" Name="Acad_iso05w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso05w100.png" />
-              <File Id="file_MAESTROBIN_161" Name="Acad_iso06w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso06w100.png" />
-              <File Id="file_MAESTROBIN_162" Name="Acad_iso07w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso07w100.png" />
-              <File Id="file_MAESTROBIN_163" Name="Acad_iso08w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso08w100.png" />
-              <File Id="file_MAESTROBIN_164" Name="Acad_iso09w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso09w100.png" />
-              <File Id="file_MAESTROBIN_165" Name="Acad_iso10w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso10w100.png" />
-              <File Id="file_MAESTROBIN_166" Name="Acad_iso11w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso11w100.png" />
-              <File Id="file_MAESTROBIN_167" Name="Acad_iso12w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso12w100.png" />
-              <File Id="file_MAESTROBIN_168" Name="Acad_iso13w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso13w100.png" />
-              <File Id="file_MAESTROBIN_169" Name="Acad_iso14w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso14w100.png" />
-              <File Id="file_MAESTROBIN_170" Name="Acad_iso15w100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso15w100.png" />
-              <File Id="file_MAESTROBIN_171" Name="Angle.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Angle.png" />
-              <File Id="file_MAESTROBIN_172" Name="Ansi31.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi31.png" />
-              <File Id="file_MAESTROBIN_173" Name="Ansi32.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi32.png" />
-              <File Id="file_MAESTROBIN_174" Name="Ansi33.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi33.png" />
-              <File Id="file_MAESTROBIN_175" Name="Ansi34.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi34.png" />
-              <File Id="file_MAESTROBIN_176" Name="Ansi35.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi35.png" />
-              <File Id="file_MAESTROBIN_177" Name="Ansi36.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi36.png" />
-              <File Id="file_MAESTROBIN_178" Name="Ansi37.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi37.png" />
-              <File Id="file_MAESTROBIN_179" Name="Ansi38.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi38.png" />
-              <File Id="file_MAESTROBIN_180" Name="Ar_b816.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b816.png" />
-              <File Id="file_MAESTROBIN_181" Name="Ar_b816c.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b816c.png" />
-              <File Id="file_MAESTROBIN_182" Name="Ar_b88.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b88.png" />
-              <File Id="file_MAESTROBIN_183" Name="Ar_brelm.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_brelm.png" />
-              <File Id="file_MAESTROBIN_184" Name="Ar_brstd.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_brstd.png" />
-              <File Id="file_MAESTROBIN_185" Name="Ar_conc.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_conc.png" />
-              <File Id="file_MAESTROBIN_186" Name="Ar_hbone.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_hbone.png" />
-              <File Id="file_MAESTROBIN_187" Name="Ar_parq1.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_parq1.png" />
-              <File Id="file_MAESTROBIN_188" Name="Ar_rroof.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rroof.png" />
-              <File Id="file_MAESTROBIN_189" Name="Ar_rroof_90.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rroof_90.png" />
-              <File Id="file_MAESTROBIN_190" Name="Ar_rshke.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke.png" />
-              <File Id="file_MAESTROBIN_191" Name="Ar_rshke_180.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_180.png" />
-              <File Id="file_MAESTROBIN_192" Name="Ar_rshke_270.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_270.png" />
-              <File Id="file_MAESTROBIN_193" Name="Ar_rshke_90.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_90.png" />
-              <File Id="file_MAESTROBIN_194" Name="Ar_sand.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_sand.png" />
-              <File Id="file_MAESTROBIN_195" Name="Box.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Box.png" />
-              <File Id="file_MAESTROBIN_196" Name="Brass.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brass.png" />
-              <File Id="file_MAESTROBIN_197" Name="Brick.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brick.png" />
-              <File Id="file_MAESTROBIN_198" Name="Brstone.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brstone.png" />
-              <File Id="file_MAESTROBIN_199" Name="Clay.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Clay.png" />
-              <File Id="file_MAESTROBIN_200" Name="Cork.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Cork.png" />
-              <File Id="file_MAESTROBIN_201" Name="Cross.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Cross.png" />
-              <File Id="file_MAESTROBIN_202" Name="Dash.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dash.png" />
-              <File Id="file_MAESTROBIN_203" Name="Dolmit.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dolmit.png" />
-              <File Id="file_MAESTROBIN_204" Name="Dots.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dots.png" />
-              <File Id="file_MAESTROBIN_205" Name="Earth.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Earth.png" />
-              <File Id="file_MAESTROBIN_206" Name="Escher.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Escher.png" />
-              <File Id="file_MAESTROBIN_207" Name="Flex.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Flex.png" />
-              <File Id="file_MAESTROBIN_208" Name="Grass.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Grass.png" />
-              <File Id="file_MAESTROBIN_209" Name="Grate.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Grate.png" />
-              <File Id="file_MAESTROBIN_210" Name="Hex.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Hex.png" />
-              <File Id="file_MAESTROBIN_211" Name="Honey.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Honey.png" />
-              <File Id="file_MAESTROBIN_212" Name="Hound.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Hound.png" />
-              <File Id="file_MAESTROBIN_213" Name="Insul.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Insul.png" />
-              <File Id="file_MAESTROBIN_214" Name="Line.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line.png" />
-              <File Id="file_MAESTROBIN_215" Name="Line_135.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_135.png" />
-              <File Id="file_MAESTROBIN_216" Name="Line_45.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_45.png" />
-              <File Id="file_MAESTROBIN_217" Name="Line_90.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_90.png" />
-              <File Id="file_MAESTROBIN_218" Name="Mudst.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Mudst.png" />
-              <File Id="file_MAESTROBIN_219" Name="Net.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net.png" />
-              <File Id="file_MAESTROBIN_220" Name="Net3.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net3.png" />
-              <File Id="file_MAESTROBIN_221" Name="Net_45.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net_45.png" />
-              <File Id="file_MAESTROBIN_222" Name="Plast.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Plast.png" />
-              <File Id="file_MAESTROBIN_223" Name="Plasti.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Plasti.png" />
-              <File Id="file_MAESTROBIN_224" Name="Sacncr.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Sacncr.png" />
-              <File Id="file_MAESTROBIN_225" Name="Shapefill12.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill12.png" />
-              <File Id="file_MAESTROBIN_226" Name="Shapefill13.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill13.png" />
-              <File Id="file_MAESTROBIN_227" Name="Shapefill14.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill14.png" />
-              <File Id="file_MAESTROBIN_228" Name="Shapefill15.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill15.png" />
-              <File Id="file_MAESTROBIN_229" Name="Shapefill16.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill16.png" />
-              <File Id="file_MAESTROBIN_230" Name="Shapefill17.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill17.png" />
-              <File Id="file_MAESTROBIN_231" Name="Shapefill18.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill18.png" />
-              <File Id="file_MAESTROBIN_232" Name="Shapefill19.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill19.png" />
-              <File Id="file_MAESTROBIN_233" Name="Shapefill20.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill20.png" />
-              <File Id="file_MAESTROBIN_234" Name="Shapefill21.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill21.png" />
-              <File Id="file_MAESTROBIN_235" Name="Shapefill22.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill22.png" />
-              <File Id="file_MAESTROBIN_236" Name="Shapefill23.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill23.png" />
-              <File Id="file_MAESTROBIN_237" Name="Shapefill24.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill24.png" />
-              <File Id="file_MAESTROBIN_238" Name="Shapefill25.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill25.png" />
-              <File Id="file_MAESTROBIN_239" Name="Shapefill26.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill26.png" />
-              <File Id="file_MAESTROBIN_240" Name="Shapefill27.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill27.png" />
-              <File Id="file_MAESTROBIN_241" Name="Shapefill28.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill28.png" />
-              <File Id="file_MAESTROBIN_242" Name="Shapefill29.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill29.png" />
-              <File Id="file_MAESTROBIN_243" Name="Shapefill30.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill30.png" />
-              <File Id="file_MAESTROBIN_244" Name="Shapefill31.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill31.png" />
-              <File Id="file_MAESTROBIN_245" Name="Shapefill32.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill32.png" />
-              <File Id="file_MAESTROBIN_246" Name="Shapefill33.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill33.png" />
-              <File Id="file_MAESTROBIN_247" Name="Shapefill34.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill34.png" />
-              <File Id="file_MAESTROBIN_248" Name="Shapefill35.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill35.png" />
-              <File Id="file_MAESTROBIN_249" Name="Shapefill36.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill36.png" />
-              <File Id="file_MAESTROBIN_250" Name="Shapefill37.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill37.png" />
-              <File Id="file_MAESTROBIN_251" Name="Shapefill38.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill38.png" />
-              <File Id="file_MAESTROBIN_252" Name="Shapefill39.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill39.png" />
-              <File Id="file_MAESTROBIN_253" Name="Shapefill40.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill40.png" />
-              <File Id="file_MAESTROBIN_254" Name="Shapefill41.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill41.png" />
-              <File Id="file_MAESTROBIN_255" Name="Shapefill42.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill42.png" />
-              <File Id="file_MAESTROBIN_256" Name="Shapefill43.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill43.png" />
-              <File Id="file_MAESTROBIN_257" Name="Shapefill44.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill44.png" />
-              <File Id="file_MAESTROBIN_258" Name="Shapefill45.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill45.png" />
-              <File Id="file_MAESTROBIN_259" Name="Shapefill46.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill46.png" />
-              <File Id="file_MAESTROBIN_260" Name="Shapefill47.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill47.png" />
-              <File Id="file_MAESTROBIN_261" Name="Shapefill48.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill48.png" />
-              <File Id="file_MAESTROBIN_262" Name="Shapefill49.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill49.png" />
-              <File Id="file_MAESTROBIN_263" Name="Shapefill50.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill50.png" />
-              <File Id="file_MAESTROBIN_264" Name="Shapefill51.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill51.png" />
-              <File Id="file_MAESTROBIN_265" Name="Shapefill52.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill52.png" />
-              <File Id="file_MAESTROBIN_266" Name="Shapefill53.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill53.png" />
-              <File Id="file_MAESTROBIN_267" Name="Shapefill54.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill54.png" />
-              <File Id="file_MAESTROBIN_268" Name="Shapefill55.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill55.png" />
-              <File Id="file_MAESTROBIN_269" Name="Shapefill56.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill56.png" />
-              <File Id="file_MAESTROBIN_270" Name="Shapefill57.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill57.png" />
-              <File Id="file_MAESTROBIN_271" Name="Shapefill58.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill58.png" />
-              <File Id="file_MAESTROBIN_272" Name="Shapefill59.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill59.png" />
-              <File Id="file_MAESTROBIN_273" Name="Shapefill60.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill60.png" />
-              <File Id="file_MAESTROBIN_274" Name="Shapefill61.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill61.png" />
-              <File Id="file_MAESTROBIN_275" Name="Shapefill62.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill62.png" />
-              <File Id="file_MAESTROBIN_276" Name="Shapefill63.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill63.png" />
-              <File Id="file_MAESTROBIN_277" Name="Shapefill64.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill64.png" />
-              <File Id="file_MAESTROBIN_278" Name="Shapefill65.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill65.png" />
-              <File Id="file_MAESTROBIN_279" Name="Shapefill66.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill66.png" />
-              <File Id="file_MAESTROBIN_280" Name="Shapefill67.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill67.png" />
-              <File Id="file_MAESTROBIN_281" Name="Shapefill68.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill68.png" />
-              <File Id="file_MAESTROBIN_282" Name="Shapefill69.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill69.png" />
-              <File Id="file_MAESTROBIN_283" Name="Shapefill70.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill70.png" />
-              <File Id="file_MAESTROBIN_284" Name="Shapefill71.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill71.png" />
-              <File Id="file_MAESTROBIN_285" Name="Solid.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Solid.png" />
-              <File Id="file_MAESTROBIN_286" Name="Square.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Square.png" />
-              <File Id="file_MAESTROBIN_287" Name="Stars.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Stars.png" />
-              <File Id="file_MAESTROBIN_288" Name="Steel.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Steel.png" />
-              <File Id="file_MAESTROBIN_289" Name="Swamp.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Swamp.png" />
-              <File Id="file_MAESTROBIN_290" Name="Trans.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Trans.png" />
-              <File Id="file_MAESTROBIN_291" Name="Triang.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Triang.png" />
-              <File Id="file_MAESTROBIN_292" Name="Zigzag.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Zigzag.png" />
+            <Component Id="comp_MAESTROBIN_156" DiskId="1" KeyPath="yes" Guid="3658E467-B29D-47E6-8C8E-00EE1C7230B8">
+              <File Id="file_MAESTROBIN_156" Name="Acad_iso02w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso02w100.png" />
+              <File Id="file_MAESTROBIN_157" Name="Acad_iso03w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso03w100.png" />
+              <File Id="file_MAESTROBIN_158" Name="Acad_iso04w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso04w100.png" />
+              <File Id="file_MAESTROBIN_159" Name="Acad_iso05w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso05w100.png" />
+              <File Id="file_MAESTROBIN_160" Name="Acad_iso06w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso06w100.png" />
+              <File Id="file_MAESTROBIN_161" Name="Acad_iso07w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso07w100.png" />
+              <File Id="file_MAESTROBIN_162" Name="Acad_iso08w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso08w100.png" />
+              <File Id="file_MAESTROBIN_163" Name="Acad_iso09w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso09w100.png" />
+              <File Id="file_MAESTROBIN_164" Name="Acad_iso10w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso10w100.png" />
+              <File Id="file_MAESTROBIN_165" Name="Acad_iso11w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso11w100.png" />
+              <File Id="file_MAESTROBIN_166" Name="Acad_iso12w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso12w100.png" />
+              <File Id="file_MAESTROBIN_167" Name="Acad_iso13w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso13w100.png" />
+              <File Id="file_MAESTROBIN_168" Name="Acad_iso14w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso14w100.png" />
+              <File Id="file_MAESTROBIN_169" Name="Acad_iso15w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso15w100.png" />
+              <File Id="file_MAESTROBIN_170" Name="Angle.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Angle.png" />
+              <File Id="file_MAESTROBIN_171" Name="Ansi31.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi31.png" />
+              <File Id="file_MAESTROBIN_172" Name="Ansi32.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi32.png" />
+              <File Id="file_MAESTROBIN_173" Name="Ansi33.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi33.png" />
+              <File Id="file_MAESTROBIN_174" Name="Ansi34.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi34.png" />
+              <File Id="file_MAESTROBIN_175" Name="Ansi35.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi35.png" />
+              <File Id="file_MAESTROBIN_176" Name="Ansi36.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi36.png" />
+              <File Id="file_MAESTROBIN_177" Name="Ansi37.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi37.png" />
+              <File Id="file_MAESTROBIN_178" Name="Ansi38.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi38.png" />
+              <File Id="file_MAESTROBIN_179" Name="Ar_b816.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b816.png" />
+              <File Id="file_MAESTROBIN_180" Name="Ar_b816c.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b816c.png" />
+              <File Id="file_MAESTROBIN_181" Name="Ar_b88.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b88.png" />
+              <File Id="file_MAESTROBIN_182" Name="Ar_brelm.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_brelm.png" />
+              <File Id="file_MAESTROBIN_183" Name="Ar_brstd.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_brstd.png" />
+              <File Id="file_MAESTROBIN_184" Name="Ar_conc.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_conc.png" />
+              <File Id="file_MAESTROBIN_185" Name="Ar_hbone.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_hbone.png" />
+              <File Id="file_MAESTROBIN_186" Name="Ar_parq1.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_parq1.png" />
+              <File Id="file_MAESTROBIN_187" Name="Ar_rroof.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rroof.png" />
+              <File Id="file_MAESTROBIN_188" Name="Ar_rroof_90.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rroof_90.png" />
+              <File Id="file_MAESTROBIN_189" Name="Ar_rshke.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke.png" />
+              <File Id="file_MAESTROBIN_190" Name="Ar_rshke_180.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_180.png" />
+              <File Id="file_MAESTROBIN_191" Name="Ar_rshke_270.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_270.png" />
+              <File Id="file_MAESTROBIN_192" Name="Ar_rshke_90.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_90.png" />
+              <File Id="file_MAESTROBIN_193" Name="Ar_sand.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_sand.png" />
+              <File Id="file_MAESTROBIN_194" Name="Box.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Box.png" />
+              <File Id="file_MAESTROBIN_195" Name="Brass.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brass.png" />
+              <File Id="file_MAESTROBIN_196" Name="Brick.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brick.png" />
+              <File Id="file_MAESTROBIN_197" Name="Brstone.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brstone.png" />
+              <File Id="file_MAESTROBIN_198" Name="Clay.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Clay.png" />
+              <File Id="file_MAESTROBIN_199" Name="Cork.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Cork.png" />
+              <File Id="file_MAESTROBIN_200" Name="Cross.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Cross.png" />
+              <File Id="file_MAESTROBIN_201" Name="Dash.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dash.png" />
+              <File Id="file_MAESTROBIN_202" Name="Dolmit.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dolmit.png" />
+              <File Id="file_MAESTROBIN_203" Name="Dots.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dots.png" />
+              <File Id="file_MAESTROBIN_204" Name="Earth.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Earth.png" />
+              <File Id="file_MAESTROBIN_205" Name="Escher.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Escher.png" />
+              <File Id="file_MAESTROBIN_206" Name="Flex.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Flex.png" />
+              <File Id="file_MAESTROBIN_207" Name="Grass.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Grass.png" />
+              <File Id="file_MAESTROBIN_208" Name="Grate.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Grate.png" />
+              <File Id="file_MAESTROBIN_209" Name="Hex.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Hex.png" />
+              <File Id="file_MAESTROBIN_210" Name="Honey.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Honey.png" />
+              <File Id="file_MAESTROBIN_211" Name="Hound.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Hound.png" />
+              <File Id="file_MAESTROBIN_212" Name="Insul.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Insul.png" />
+              <File Id="file_MAESTROBIN_213" Name="Line.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line.png" />
+              <File Id="file_MAESTROBIN_214" Name="Line_135.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_135.png" />
+              <File Id="file_MAESTROBIN_215" Name="Line_45.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_45.png" />
+              <File Id="file_MAESTROBIN_216" Name="Line_90.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_90.png" />
+              <File Id="file_MAESTROBIN_217" Name="Mudst.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Mudst.png" />
+              <File Id="file_MAESTROBIN_218" Name="Net.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net.png" />
+              <File Id="file_MAESTROBIN_219" Name="Net3.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net3.png" />
+              <File Id="file_MAESTROBIN_220" Name="Net_45.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net_45.png" />
+              <File Id="file_MAESTROBIN_221" Name="Plast.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Plast.png" />
+              <File Id="file_MAESTROBIN_222" Name="Plasti.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Plasti.png" />
+              <File Id="file_MAESTROBIN_223" Name="Sacncr.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Sacncr.png" />
+              <File Id="file_MAESTROBIN_224" Name="Shapefill12.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill12.png" />
+              <File Id="file_MAESTROBIN_225" Name="Shapefill13.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill13.png" />
+              <File Id="file_MAESTROBIN_226" Name="Shapefill14.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill14.png" />
+              <File Id="file_MAESTROBIN_227" Name="Shapefill15.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill15.png" />
+              <File Id="file_MAESTROBIN_228" Name="Shapefill16.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill16.png" />
+              <File Id="file_MAESTROBIN_229" Name="Shapefill17.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill17.png" />
+              <File Id="file_MAESTROBIN_230" Name="Shapefill18.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill18.png" />
+              <File Id="file_MAESTROBIN_231" Name="Shapefill19.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill19.png" />
+              <File Id="file_MAESTROBIN_232" Name="Shapefill20.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill20.png" />
+              <File Id="file_MAESTROBIN_233" Name="Shapefill21.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill21.png" />
+              <File Id="file_MAESTROBIN_234" Name="Shapefill22.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill22.png" />
+              <File Id="file_MAESTROBIN_235" Name="Shapefill23.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill23.png" />
+              <File Id="file_MAESTROBIN_236" Name="Shapefill24.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill24.png" />
+              <File Id="file_MAESTROBIN_237" Name="Shapefill25.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill25.png" />
+              <File Id="file_MAESTROBIN_238" Name="Shapefill26.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill26.png" />
+              <File Id="file_MAESTROBIN_239" Name="Shapefill27.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill27.png" />
+              <File Id="file_MAESTROBIN_240" Name="Shapefill28.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill28.png" />
+              <File Id="file_MAESTROBIN_241" Name="Shapefill29.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill29.png" />
+              <File Id="file_MAESTROBIN_242" Name="Shapefill30.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill30.png" />
+              <File Id="file_MAESTROBIN_243" Name="Shapefill31.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill31.png" />
+              <File Id="file_MAESTROBIN_244" Name="Shapefill32.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill32.png" />
+              <File Id="file_MAESTROBIN_245" Name="Shapefill33.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill33.png" />
+              <File Id="file_MAESTROBIN_246" Name="Shapefill34.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill34.png" />
+              <File Id="file_MAESTROBIN_247" Name="Shapefill35.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill35.png" />
+              <File Id="file_MAESTROBIN_248" Name="Shapefill36.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill36.png" />
+              <File Id="file_MAESTROBIN_249" Name="Shapefill37.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill37.png" />
+              <File Id="file_MAESTROBIN_250" Name="Shapefill38.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill38.png" />
+              <File Id="file_MAESTROBIN_251" Name="Shapefill39.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill39.png" />
+              <File Id="file_MAESTROBIN_252" Name="Shapefill40.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill40.png" />
+              <File Id="file_MAESTROBIN_253" Name="Shapefill41.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill41.png" />
+              <File Id="file_MAESTROBIN_254" Name="Shapefill42.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill42.png" />
+              <File Id="file_MAESTROBIN_255" Name="Shapefill43.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill43.png" />
+              <File Id="file_MAESTROBIN_256" Name="Shapefill44.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill44.png" />
+              <File Id="file_MAESTROBIN_257" Name="Shapefill45.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill45.png" />
+              <File Id="file_MAESTROBIN_258" Name="Shapefill46.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill46.png" />
+              <File Id="file_MAESTROBIN_259" Name="Shapefill47.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill47.png" />
+              <File Id="file_MAESTROBIN_260" Name="Shapefill48.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill48.png" />
+              <File Id="file_MAESTROBIN_261" Name="Shapefill49.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill49.png" />
+              <File Id="file_MAESTROBIN_262" Name="Shapefill50.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill50.png" />
+              <File Id="file_MAESTROBIN_263" Name="Shapefill51.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill51.png" />
+              <File Id="file_MAESTROBIN_264" Name="Shapefill52.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill52.png" />
+              <File Id="file_MAESTROBIN_265" Name="Shapefill53.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill53.png" />
+              <File Id="file_MAESTROBIN_266" Name="Shapefill54.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill54.png" />
+              <File Id="file_MAESTROBIN_267" Name="Shapefill55.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill55.png" />
+              <File Id="file_MAESTROBIN_268" Name="Shapefill56.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill56.png" />
+              <File Id="file_MAESTROBIN_269" Name="Shapefill57.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill57.png" />
+              <File Id="file_MAESTROBIN_270" Name="Shapefill58.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill58.png" />
+              <File Id="file_MAESTROBIN_271" Name="Shapefill59.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill59.png" />
+              <File Id="file_MAESTROBIN_272" Name="Shapefill60.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill60.png" />
+              <File Id="file_MAESTROBIN_273" Name="Shapefill61.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill61.png" />
+              <File Id="file_MAESTROBIN_274" Name="Shapefill62.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill62.png" />
+              <File Id="file_MAESTROBIN_275" Name="Shapefill63.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill63.png" />
+              <File Id="file_MAESTROBIN_276" Name="Shapefill64.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill64.png" />
+              <File Id="file_MAESTROBIN_277" Name="Shapefill65.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill65.png" />
+              <File Id="file_MAESTROBIN_278" Name="Shapefill66.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill66.png" />
+              <File Id="file_MAESTROBIN_279" Name="Shapefill67.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill67.png" />
+              <File Id="file_MAESTROBIN_280" Name="Shapefill68.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill68.png" />
+              <File Id="file_MAESTROBIN_281" Name="Shapefill69.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill69.png" />
+              <File Id="file_MAESTROBIN_282" Name="Shapefill70.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill70.png" />
+              <File Id="file_MAESTROBIN_283" Name="Shapefill71.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill71.png" />
+              <File Id="file_MAESTROBIN_284" Name="Solid.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Solid.png" />
+              <File Id="file_MAESTROBIN_285" Name="Square.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Square.png" />
+              <File Id="file_MAESTROBIN_286" Name="Stars.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Stars.png" />
+              <File Id="file_MAESTROBIN_287" Name="Steel.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Steel.png" />
+              <File Id="file_MAESTROBIN_288" Name="Swamp.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Swamp.png" />
+              <File Id="file_MAESTROBIN_289" Name="Trans.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Trans.png" />
+              <File Id="file_MAESTROBIN_290" Name="Triang.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Triang.png" />
+              <File Id="file_MAESTROBIN_291" Name="Zigzag.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Zigzag.png" />
             </Component>
           </Directory>
           <Directory Id="dir_MapGuideMaestro_WebStudio_lines_6" Name="lines">
-            <Component Id="comp_MAESTROBIN_293" DiskId="1" KeyPath="yes" Guid="2FD3170C-89D4-484D-BD8B-E4FBAD466F1A">
-              <File Id="file_MAESTROBIN_293" Name="ACAD_ISO02W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO02W100.png" />
-              <File Id="file_MAESTROBIN_294" Name="ACAD_ISO03W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO03W100.png" />
-              <File Id="file_MAESTROBIN_295" Name="ACAD_ISO04W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO04W100.png" />
-              <File Id="file_MAESTROBIN_296" Name="ACAD_ISO05W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO05W100.png" />
-              <File Id="file_MAESTROBIN_297" Name="ACAD_ISO06W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO06W100.png" />
-              <File Id="file_MAESTROBIN_298" Name="ACAD_ISO07W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO07W100.png" />
-              <File Id="file_MAESTROBIN_299" Name="ACAD_ISO08W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO08W100.png" />
-              <File Id="file_MAESTROBIN_300" Name="ACAD_ISO09W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO09W100.png" />
-              <File Id="file_MAESTROBIN_301" Name="ACAD_ISO10W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO10W100.png" />
-              <File Id="file_MAESTROBIN_302" Name="ACAD_ISO11W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO11W100.png" />
-              <File Id="file_MAESTROBIN_303" Name="ACAD_ISO12W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO12W100.png" />
-              <File Id="file_MAESTROBIN_304" Name="ACAD_ISO13W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO13W100.png" />
-              <File Id="file_MAESTROBIN_305" Name="ACAD_ISO14W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO14W100.png" />
-              <File Id="file_MAESTROBIN_306" Name="ACAD_ISO15W100.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO15W100.png" />
-              <File Id="file_MAESTROBIN_307" Name="BORDER.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDER.png" />
-              <File Id="file_MAESTROBIN_308" Name="BORDER2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDER2.png" />
-              <File Id="file_MAESTROBIN_309" Name="BORDERX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDERX2.png" />
-              <File Id="file_MAESTROBIN_310" Name="CENTER.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTER.png" />
-              <File Id="file_MAESTROBIN_311" Name="CENTER2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTER2.png" />
-              <File Id="file_MAESTROBIN_312" Name="CENTERX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTERX2.png" />
-              <File Id="file_MAESTROBIN_313" Name="Dash.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Dash.png" />
-              <File Id="file_MAESTROBIN_314" Name="DashDot.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DashDot.png" />
-              <File Id="file_MAESTROBIN_315" Name="DASHDOT2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOT2.png" />
-              <File Id="file_MAESTROBIN_316" Name="DASHDOT3.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOT3.png" />
-              <File Id="file_MAESTROBIN_317" Name="DashDotDot.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DashDotDot.png" />
-              <File Id="file_MAESTROBIN_318" Name="DASHDOTX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOTX2.png" />
-              <File Id="file_MAESTROBIN_319" Name="DASHED.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHED.png" />
-              <File Id="file_MAESTROBIN_320" Name="DASHED2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHED2.png" />
-              <File Id="file_MAESTROBIN_321" Name="DASHEDX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHEDX2.png" />
-              <File Id="file_MAESTROBIN_322" Name="DIVIDE.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDE.png" />
-              <File Id="file_MAESTROBIN_323" Name="DIVIDE2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDE2.png" />
-              <File Id="file_MAESTROBIN_324" Name="DIVIDEX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDEX2.png" />
-              <File Id="file_MAESTROBIN_325" Name="Dot.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Dot.png" />
-              <File Id="file_MAESTROBIN_326" Name="DOT2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOT2.png" />
-              <File Id="file_MAESTROBIN_327" Name="DOT3.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOT3.png" />
-              <File Id="file_MAESTROBIN_328" Name="DOTX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOTX2.png" />
-              <File Id="file_MAESTROBIN_329" Name="FENCELINE1.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\FENCELINE1.png" />
-              <File Id="file_MAESTROBIN_330" Name="FENCELINE2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\FENCELINE2.png" />
-              <File Id="file_MAESTROBIN_331" Name="HIDDEN.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDEN.png" />
-              <File Id="file_MAESTROBIN_332" Name="HIDDEN2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDEN2.png" />
-              <File Id="file_MAESTROBIN_333" Name="HIDDENX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDENX2.png" />
-              <File Id="file_MAESTROBIN_334" Name="LINE03.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE03.png" />
-              <File Id="file_MAESTROBIN_335" Name="LINE04.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE04.png" />
-              <File Id="file_MAESTROBIN_336" Name="LINE05.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE05.png" />
-              <File Id="file_MAESTROBIN_337" Name="LINE06.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE06.png" />
-              <File Id="file_MAESTROBIN_338" Name="LINE07.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE07.png" />
-              <File Id="file_MAESTROBIN_339" Name="LINE08.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE08.png" />
-              <File Id="file_MAESTROBIN_340" Name="LINE09.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE09.png" />
-              <File Id="file_MAESTROBIN_341" Name="LINE10.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE10.png" />
-              <File Id="file_MAESTROBIN_342" Name="LINE11.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE11.png" />
-              <File Id="file_MAESTROBIN_343" Name="LINE12.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE12.png" />
-              <File Id="file_MAESTROBIN_344" Name="LINE13.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE13.png" />
-              <File Id="file_MAESTROBIN_345" Name="LINE14.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE14.png" />
-              <File Id="file_MAESTROBIN_346" Name="LINE15.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE15.png" />
-              <File Id="file_MAESTROBIN_347" Name="LINE16.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE16.png" />
-              <File Id="file_MAESTROBIN_348" Name="LINE17.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE17.png" />
-              <File Id="file_MAESTROBIN_349" Name="LINE18.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE18.png" />
-              <File Id="file_MAESTROBIN_350" Name="LINE19.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE19.png" />
-              <File Id="file_MAESTROBIN_351" Name="LINE20.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE20.png" />
-              <File Id="file_MAESTROBIN_352" Name="LINE21.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE21.png" />
-              <File Id="file_MAESTROBIN_353" Name="LINE22.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE22.png" />
-              <File Id="file_MAESTROBIN_354" Name="LINE23.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE23.png" />
-              <File Id="file_MAESTROBIN_355" Name="LINE24.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE24.png" />
-              <File Id="file_MAESTROBIN_356" Name="LINE25.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE25.png" />
-              <File Id="file_MAESTROBIN_357" Name="PHANTOM.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOM.png" />
-              <File Id="file_MAESTROBIN_358" Name="PHANTOM2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOM2.png" />
-              <File Id="file_MAESTROBIN_359" Name="PHANTOMX2.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOMX2.png" />
-              <File Id="file_MAESTROBIN_360" Name="Rail.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Rail.png" />
-              <File Id="file_MAESTROBIN_361" Name="Solid.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Solid.png" />
-              <File Id="file_MAESTROBIN_362" Name="TRACKS.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\TRACKS.png" />
+            <Component Id="comp_MAESTROBIN_292" DiskId="1" KeyPath="yes" Guid="7AFB2FB6-B323-451A-BB87-16895E5B925E">
+              <File Id="file_MAESTROBIN_292" Name="ACAD_ISO02W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO02W100.png" />
+              <File Id="file_MAESTROBIN_293" Name="ACAD_ISO03W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO03W100.png" />
+              <File Id="file_MAESTROBIN_294" Name="ACAD_ISO04W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO04W100.png" />
+              <File Id="file_MAESTROBIN_295" Name="ACAD_ISO05W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO05W100.png" />
+              <File Id="file_MAESTROBIN_296" Name="ACAD_ISO06W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO06W100.png" />
+              <File Id="file_MAESTROBIN_297" Name="ACAD_ISO07W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO07W100.png" />
+              <File Id="file_MAESTROBIN_298" Name="ACAD_ISO08W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO08W100.png" />
+              <File Id="file_MAESTROBIN_299" Name="ACAD_ISO09W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO09W100.png" />
+              <File Id="file_MAESTROBIN_300" Name="ACAD_ISO10W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO10W100.png" />
+              <File Id="file_MAESTROBIN_301" Name="ACAD_ISO11W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO11W100.png" />
+              <File Id="file_MAESTROBIN_302" Name="ACAD_ISO12W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO12W100.png" />
+              <File Id="file_MAESTROBIN_303" Name="ACAD_ISO13W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO13W100.png" />
+              <File Id="file_MAESTROBIN_304" Name="ACAD_ISO14W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO14W100.png" />
+              <File Id="file_MAESTROBIN_305" Name="ACAD_ISO15W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO15W100.png" />
+              <File Id="file_MAESTROBIN_306" Name="BORDER.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDER.png" />
+              <File Id="file_MAESTROBIN_307" Name="BORDER2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDER2.png" />
+              <File Id="file_MAESTROBIN_308" Name="BORDERX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDERX2.png" />
+              <File Id="file_MAESTROBIN_309" Name="CENTER.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTER.png" />
+              <File Id="file_MAESTROBIN_310" Name="CENTER2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTER2.png" />
+              <File Id="file_MAESTROBIN_311" Name="CENTERX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTERX2.png" />
+              <File Id="file_MAESTROBIN_312" Name="Dash.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Dash.png" />
+              <File Id="file_MAESTROBIN_313" Name="DashDot.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DashDot.png" />
+              <File Id="file_MAESTROBIN_314" Name="DASHDOT2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOT2.png" />
+              <File Id="file_MAESTROBIN_315" Name="DASHDOT3.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOT3.png" />
+              <File Id="file_MAESTROBIN_316" Name="DashDotDot.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DashDotDot.png" />
+              <File Id="file_MAESTROBIN_317" Name="DASHDOTX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOTX2.png" />
+              <File Id="file_MAESTROBIN_318" Name="DASHED.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHED.png" />
+              <File Id="file_MAESTROBIN_319" Name="DASHED2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHED2.png" />
+              <File Id="file_MAESTROBIN_320" Name="DASHEDX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHEDX2.png" />
+              <File Id="file_MAESTROBIN_321" Name="DIVIDE.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDE.png" />
+              <File Id="file_MAESTROBIN_322" Name="DIVIDE2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDE2.png" />
+              <File Id="file_MAESTROBIN_323" Name="DIVIDEX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDEX2.png" />
+              <File Id="file_MAESTROBIN_324" Name="Dot.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Dot.png" />
+              <File Id="file_MAESTROBIN_325" Name="DOT2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOT2.png" />
+              <File Id="file_MAESTROBIN_326" Name="DOT3.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOT3.png" />
+              <File Id="file_MAESTROBIN_327" Name="DOTX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOTX2.png" />
+              <File Id="file_MAESTROBIN_328" Name="FENCELINE1.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\FENCELINE1.png" />
+              <File Id="file_MAESTROBIN_329" Name="FENCELINE2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\FENCELINE2.png" />
+              <File Id="file_MAESTROBIN_330" Name="HIDDEN.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDEN.png" />
+              <File Id="file_MAESTROBIN_331" Name="HIDDEN2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDEN2.png" />
+              <File Id="file_MAESTROBIN_332" Name="HIDDENX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDENX2.png" />
+              <File Id="file_MAESTROBIN_333" Name="LINE03.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE03.png" />
+              <File Id="file_MAESTROBIN_334" Name="LINE04.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE04.png" />
+              <File Id="file_MAESTROBIN_335" Name="LINE05.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE05.png" />
+              <File Id="file_MAESTROBIN_336" Name="LINE06.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE06.png" />
+              <File Id="file_MAESTROBIN_337" Name="LINE07.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE07.png" />
+              <File Id="file_MAESTROBIN_338" Name="LINE08.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE08.png" />
+              <File Id="file_MAESTROBIN_339" Name="LINE09.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE09.png" />
+              <File Id="file_MAESTROBIN_340" Name="LINE10.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE10.png" />
+              <File Id="file_MAESTROBIN_341" Name="LINE11.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE11.png" />
+              <File Id="file_MAESTROBIN_342" Name="LINE12.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE12.png" />
+              <File Id="file_MAESTROBIN_343" Name="LINE13.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE13.png" />
+              <File Id="file_MAESTROBIN_344" Name="LINE14.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE14.png" />
+              <File Id="file_MAESTROBIN_345" Name="LINE15.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE15.png" />
+              <File Id="file_MAESTROBIN_346" Name="LINE16.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE16.png" />
+              <File Id="file_MAESTROBIN_347" Name="LINE17.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE17.png" />
+              <File Id="file_MAESTROBIN_348" Name="LINE18.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE18.png" />
+              <File Id="file_MAESTROBIN_349" Name="LINE19.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE19.png" />
+              <File Id="file_MAESTROBIN_350" Name="LINE20.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE20.png" />
+              <File Id="file_MAESTROBIN_351" Name="LINE21.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE21.png" />
+              <File Id="file_MAESTROBIN_352" Name="LINE22.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE22.png" />
+              <File Id="file_MAESTROBIN_353" Name="LINE23.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE23.png" />
+              <File Id="file_MAESTROBIN_354" Name="LINE24.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE24.png" />
+              <File Id="file_MAESTROBIN_355" Name="LINE25.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE25.png" />
+              <File Id="file_MAESTROBIN_356" Name="PHANTOM.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOM.png" />
+              <File Id="file_MAESTROBIN_357" Name="PHANTOM2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOM2.png" />
+              <File Id="file_MAESTROBIN_358" Name="PHANTOMX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOMX2.png" />
+              <File Id="file_MAESTROBIN_359" Name="Rail.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Rail.png" />
+              <File Id="file_MAESTROBIN_360" Name="Solid.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Solid.png" />
+              <File Id="file_MAESTROBIN_361" Name="TRACKS.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\TRACKS.png" />
             </Component>
           </Directory>
           <Directory Id="dir_MapGuideMaestro_WebStudio_points_7" Name="points">
-            <Component Id="comp_MAESTROBIN_363" DiskId="1" KeyPath="yes" Guid="AB919F9D-9A4E-43A0-AF61-548D9D137914">
-              <File Id="file_MAESTROBIN_363" Name="circle.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\circle.png" />
-              <File Id="file_MAESTROBIN_364" Name="cross.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\cross.png" />
-              <File Id="file_MAESTROBIN_365" Name="square.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\square.png" />
-              <File Id="file_MAESTROBIN_366" Name="star.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\star.png" />
-              <File Id="file_MAESTROBIN_367" Name="triangle.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\triangle.png" />
-              <File Id="file_MAESTROBIN_368" Name="x.png" Source="..\InstallerTempRelease\MapGuideMaestro\WebStudio\points\x.png" />
+            <Component Id="comp_MAESTROBIN_362" DiskId="1" KeyPath="yes" Guid="DBAB720C-ED4E-4055-8151-5B09500CCD37">
+              <File Id="file_MAESTROBIN_362" Name="circle.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\circle.png" />
+              <File Id="file_MAESTROBIN_363" Name="cross.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\cross.png" />
+              <File Id="file_MAESTROBIN_364" Name="square.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\square.png" />
+              <File Id="file_MAESTROBIN_365" Name="star.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\star.png" />
+              <File Id="file_MAESTROBIN_366" Name="triangle.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\triangle.png" />
+              <File Id="file_MAESTROBIN_367" Name="x.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\x.png" />
             </Component>
           </Directory>
         </Directory>
Modified: trunk/Tools/Maestro/Installer/incLocFiles.da-DK.wxs
--- trunk/Tools/Maestro/Installer/incLocFiles.da-DK.wxs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/Installer/incLocFiles.da-DK.wxs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -3,7 +3,7 @@
   <!--<CommandLineOptions>
   <Producer>Autogenerated by Paraffin - Wintellect - John Robbins - john at wintellect.com</Producer>
   <WARNING>Manual changes to this file may cause incorrect behavior.</WARNING>
-  <CreatedOn>10-12-2009 19:25</CreatedOn>
+  <CreatedOn>13-12-2009 02:08</CreatedOn>
   <Directory>compiled\da-DK\</Directory>
   <Custom>MAESTROBIN_da-DK</Custom>
   <DirAlias>..\Localization\compiled\da-DK\</DirAlias>
@@ -27,7 +27,7 @@
     </ComponentGroup>
     <DirectoryRef Id="dir_MapGuideMaestro_0">
       <Directory Id="dir_da_DK_0" Name="da-DK">
-        <Component Id="comp_MAESTROBIN_da_DK_0" DiskId="1" KeyPath="yes" Guid="94C8C4E2-75FD-444C-8A16-83DA7B11EF64">
+        <Component Id="comp_MAESTROBIN_da_DK_0" DiskId="1" KeyPath="yes" Guid="A001569B-9492-480C-8FF7-0426933F35CA">
           <File Id="file_MAESTROBIN_da_DK_0" Name="Maestro.resources.dll" Source="..\Localization\compiled\da-DK\Maestro.resources.dll" />
           <File Id="file_MAESTROBIN_da_DK_1" Name="OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" Source="..\Localization\compiled\da-DK\OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" />
           <File Id="file_MAESTROBIN_da_DK_2" Name="OSGeo.MapGuide.Maestro.LoginForm.resources.dll" Source="..\Localization\compiled\da-DK\OSGeo.MapGuide.Maestro.LoginForm.resources.dll" />
Modified: trunk/Tools/Maestro/Installer/incLocFiles.es-ES.wxs
--- trunk/Tools/Maestro/Installer/incLocFiles.es-ES.wxs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/Installer/incLocFiles.es-ES.wxs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -3,7 +3,7 @@
   <Directory>compiled\es-ES\</Directory>
   <Custom>MAESTROBIN_es-ES</Custom>
   <DirAlias>..\Localization\compiled\es-ES\</DirAlias>
@@ -27,7 +27,7 @@
     </ComponentGroup>
       <Directory Id="dir_es_ES_0" Name="es-ES">
-        <Component Id="comp_MAESTROBIN_es_ES_0" DiskId="1" KeyPath="yes" Guid="99E1C76F-42E8-4AE3-9566-F1DE9C36B174">
+        <Component Id="comp_MAESTROBIN_es_ES_0" DiskId="1" KeyPath="yes" Guid="BF3A8362-3184-4976-B61A-7867CF6C3667">
           <File Id="file_MAESTROBIN_es_ES_0" Name="Maestro.resources.dll" Source="..\Localization\compiled\es-ES\Maestro.resources.dll" />
           <File Id="file_MAESTROBIN_es_ES_1" Name="OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" Source="..\Localization\compiled\es-ES\OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" />
           <File Id="file_MAESTROBIN_es_ES_2" Name="OSGeo.MapGuide.Maestro.LoginForm.resources.dll" Source="..\Localization\compiled\es-ES\OSGeo.MapGuide.Maestro.LoginForm.resources.dll" />
Modified: trunk/Tools/Maestro/Installer/incLocFiles.fr-FR.wxs
--- trunk/Tools/Maestro/Installer/incLocFiles.fr-FR.wxs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/Installer/incLocFiles.fr-FR.wxs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -3,7 +3,7 @@
   <Directory>compiled\fr-FR\</Directory>
   <Custom>MAESTROBIN_fr-FR</Custom>
   <DirAlias>..\Localization\compiled\fr-FR\</DirAlias>
@@ -27,7 +27,7 @@
     </ComponentGroup>
       <Directory Id="dir_fr_FR_0" Name="fr-FR">
-        <Component Id="comp_MAESTROBIN_fr_FR_0" DiskId="1" KeyPath="yes" Guid="6B65CD45-1508-405B-912E-E55A4DAAB38D">
+        <Component Id="comp_MAESTROBIN_fr_FR_0" DiskId="1" KeyPath="yes" Guid="1FE6962E-F205-42CA-85FA-7A0DAA748272">
           <File Id="file_MAESTROBIN_fr_FR_0" Name="Maestro.resources.dll" Source="..\Localization\compiled\fr-FR\Maestro.resources.dll" />
           <File Id="file_MAESTROBIN_fr_FR_1" Name="OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" Source="..\Localization\compiled\fr-FR\OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" />
           <File Id="file_MAESTROBIN_fr_FR_2" Name="OSGeo.MapGuide.Maestro.LoginForm.resources.dll" Source="..\Localization\compiled\fr-FR\OSGeo.MapGuide.Maestro.LoginForm.resources.dll" />
Modified: trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -1,4 +1,4 @@
-using System.Reflection;
+using System.Reflection;
 using System.Runtime.CompilerServices;
 using System.Runtime.InteropServices;
@@ -32,5 +32,5 @@
 // You can specify all the values or you can default the Build and Revision Numbers
 // by using the '*' as shown below:
 // [assembly: AssemblyVersion("1.0.*")]
-[assembly: AssemblyVersion("1.0.0.0")]
-[assembly: AssemblyFileVersion("1.0.0.0")]
+[assembly: AssemblyVersion("1.1.0.4431")]
+[assembly: AssemblyFileVersion("1.1.0.4431")]
Modified: trunk/Tools/Maestro/Localization/configuration.xml
--- trunk/Tools/Maestro/Localization/configuration.xml	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/Localization/configuration.xml	2009-12-13 01:14:26 UTC (rev 4431)
@@ -23,7 +23,7 @@
 		<assembly name="OSGeo.MapGuide.Maestro.ResourceValidators" folder="Maestro\ResourceValidators" namespace="OSGeo.MapGuide.Maestro.ResourceValidators" />
 		<!-- <keyfile>..\MaestroAPI\Maestroapi.key</keyfile> -->
-		<versionassembly>..\Maestro\bin\debug\Maestro.exe</versionassembly>
+		<versionassembly>..\Maestro\bin\release\Maestro.exe</versionassembly>
 		<sourcefolder>..</sourcefolder>
 		<outputfolder>compiled</outputfolder>
 		<productname>Maestro</productname>
Modified: trunk/Tools/Maestro/Maestro/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/AssemblyInfo.cs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/Maestro/AssemblyInfo.cs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -45,7 +45,7 @@
 // You can specify all the values or you can default the Revision and Build Numbers
-[assembly: AssemblyVersion("1.1.0.4358")]
 // In order to sign your assembly you must specify a key to use. Refer to the
@@ -75,4 +75,4 @@
 [assembly: AssemblyDelaySign(false)]
 [assembly: AssemblyKeyFile("")]
 [assembly: AssemblyKeyName("")]
-[assembly: AssemblyFileVersionAttribute("1.1.0.4358")]
+[assembly: AssemblyFileVersionAttribute("1.1.0.4431")]
Modified: trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -1,4 +1,4 @@
@@ -32,5 +32,5 @@
-[assembly: AssemblyFileVersion("1.1.0.4358")]
Modified: trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -45,7 +45,7 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -50,5 +50,5 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
 [assembly: AssemblyKeyFile("..\\..\\maestroapi.key")]
Modified: trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -48,5 +48,5 @@
 //      Build Number
 //      Revision
Modified: trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -48,5 +48,5 @@
 //      Build Number
 //      Revision
Modified: trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -48,5 +48,5 @@
 //      Build Number
 //      Revision
Modified: trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs	2009-12-13 01:14:26 UTC (rev 4431)
@@ -48,5 +48,5 @@
 //      Build Number
 //      Revision
Modified: trunk/Tools/Maestro/build.bat
--- trunk/Tools/Maestro/build.bat	2009-12-13 00:16:45 UTC (rev 4430)
+++ trunk/Tools/Maestro/build.bat	2009-12-13 01:14:26 UTC (rev 4431)
@@ -1,4 +1,4 @@
-rem @echo off
+ at echo off
 rem MapGuide Maestro build script for windows
 rem
 rem Author: Jackie Ng (jumpinjackie at gmail.com)
More information about the mapguide-commits mailing list
