[mapguide-commits] r4437 - in trunk/Tools/Maestro: Installer Localization/ConvertResX/ConvertResX/Properties Localization/da-DK/Maestro/Strings Localization/es-ES/Maestro/Strings Localization/fr-FR/Maestro/Strings Maestro Maestro/FusionEditor Maestro/LoginForm/Properties Maestro/MaestroEditorInterface Maestro/ResourceBrowser/Properties Maestro/ResourceEditors Maestro/ResourceValidators Maestro/Strings MaestroAPI MaestroAPI/PackageBuilder/Properties MaestroAPI/XsdGenerator new w generics/Properties MgCooker/MgCookerCommandline/Properties MgCooker/Properties
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Dec 14 17:32:39 EST 2009
Author: ksgeograf
Date: 2009-12-14 17:32:39 -0500 (Mon, 14 Dec 2009)
New Revision: 4437
   trunk/Tools/Maestro/Installer/UpgradeData.wxi
   trunk/Tools/Maestro/Installer/incBinFiles.wxs
   trunk/Tools/Maestro/Installer/incLocFiles.da-DK.wxs
   trunk/Tools/Maestro/Installer/incLocFiles.es-ES.wxs
   trunk/Tools/Maestro/Installer/incLocFiles.fr-FR.wxs
   trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/Localization/da-DK/Maestro/Strings/TemplateNames.da-DK.resx
   trunk/Tools/Maestro/Localization/es-ES/Maestro/Strings/TemplateNames.es-ES.resx
   trunk/Tools/Maestro/Localization/fr-FR/Maestro/Strings/TemplateNames.fr-FR.resx
   trunk/Tools/Maestro/Maestro/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs
   trunk/Tools/Maestro/Maestro/Strings/TemplateNames.resx
   trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs
   trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs
Maestro Build 4437.
Modified: trunk/Tools/Maestro/Installer/UpgradeData.wxi
--- trunk/Tools/Maestro/Installer/UpgradeData.wxi	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Installer/UpgradeData.wxi	2009-12-14 22:32:39 UTC (rev 4437)
@@ -3,7 +3,7 @@
   <?define UpgradeCode="A7C2ECB3-1991-47B9-A22E-8844BB95CAE2" ?>
   <!-- Remember to change product version on each install -->
-  <?define ProductVersion="1.1.0.4431" ?>
+  <?define ProductVersion="1.1.0.4437" ?>
   <?define Manufacturer="HexaD" ?>
Modified: trunk/Tools/Maestro/Installer/incBinFiles.wxs
--- trunk/Tools/Maestro/Installer/incBinFiles.wxs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Installer/incBinFiles.wxs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -3,7 +3,7 @@
   <!--<CommandLineOptions>
   <Producer>Autogenerated by Paraffin - Wintellect - John Robbins - john at wintellect.com</Producer>
   <WARNING>Manual changes to this file may cause incorrect behavior.</WARNING>
-  <CreatedOn>13-12-2009 02:08</CreatedOn>
+  <CreatedOn>14-12-2009 23:27</CreatedOn>
   <Directory>C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\</Directory>
   <Custom>MAESTROBIN</Custom>
   <DirAlias>C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\</DirAlias>
@@ -19,7 +19,7 @@
     <Dir>.svn</Dir>
   </DirExcludes>
   <NextDirectoryNumber>8</NextDirectoryNumber>
-  <NextComponentNumber>368</NextComponentNumber>
+  <NextComponentNumber>369</NextComponentNumber>
 </CommandLineOptions>-->
   <Fragment>
     <ComponentGroup Id="group_MAESTROBIN">
@@ -27,14 +27,14 @@
       <ComponentRef Id="comp_MAESTROBIN_21" />
       <ComponentRef Id="comp_MAESTROBIN_68" />
       <ComponentRef Id="comp_MAESTROBIN_147" />
-      <ComponentRef Id="comp_MAESTROBIN_155" />
       <ComponentRef Id="comp_MAESTROBIN_156" />
-      <ComponentRef Id="comp_MAESTROBIN_292" />
-      <ComponentRef Id="comp_MAESTROBIN_362" />
+      <ComponentRef Id="comp_MAESTROBIN_157" />
+      <ComponentRef Id="comp_MAESTROBIN_293" />
+      <ComponentRef Id="comp_MAESTROBIN_363" />
     </ComponentGroup>
     <DirectoryRef Id="INSTALLLOCATION">
       <Directory Id="dir_MapGuideMaestro_0" Name="MapGuideMaestro">
-        <Component Id="comp_MAESTROBIN_0" DiskId="1" KeyPath="yes" Guid="8539349F-6E57-4345-9F9A-44672EA2E7FA">
+        <Component Id="comp_MAESTROBIN_0" DiskId="1" KeyPath="yes" Guid="4A93FC9C-5165-43F7-B5C3-4DB6100DE412">
           <File Id="file_MAESTROBIN_0" Name="ColorBrewer.csv" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\ColorBrewer.csv" />
           <File Id="file_MAESTROBIN_1" Name="EditorMap.xml" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\EditorMap.xml" />
           <File Id="file_MAESTROBIN_2" Name="ICSharpCode.SharpZipLib.dll" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\ICSharpCode.SharpZipLib.dll" />
@@ -58,7 +58,7 @@
           <File Id="file_MAESTROBIN_20" Name="Topology.IO.MapGuide.dll" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Topology.IO.MapGuide.dll" />
         </Component>
         <Directory Id="dir_MapGuideMaestro_Schemas_1" Name="Schemas">
-          <Component Id="comp_MAESTROBIN_21" DiskId="1" KeyPath="yes" Guid="D2AB7B86-B58A-46F4-AB72-25E5A9F3491B">
+          <Component Id="comp_MAESTROBIN_21" DiskId="1" KeyPath="yes" Guid="4C467D40-0237-476F-99F2-2EDBAD6B4E8C">
             <File Id="file_MAESTROBIN_21" Name="ApplicationDefinition-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\ApplicationDefinition-1.0.0.xsd" />
             <File Id="file_MAESTROBIN_22" Name="ApplicationDefinitionInfo-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\ApplicationDefinitionInfo-1.0.0.xsd" />
             <File Id="file_MAESTROBIN_23" Name="DataStoreList-1.0.0.xsd" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Schemas\DataStoreList-1.0.0.xsd" />
@@ -109,7 +109,7 @@
           </Component>
         </Directory>
         <Directory Id="dir_MapGuideMaestro_stdicons_2" Name="stdicons">
-          <Component Id="comp_MAESTROBIN_68" DiskId="1" KeyPath="yes" Guid="1AC13C49-05B5-4C82-BCCB-65BEBDA528A3">
+          <Component Id="comp_MAESTROBIN_68" DiskId="1" KeyPath="yes" Guid="CE0C39CE-6986-426F-8CFE-E128EFA6B6CA">
             <File Id="file_MAESTROBIN_68" Name="copyright.txt" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\copyright.txt" />
             <File Id="file_MAESTROBIN_69" Name="icon_back.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_back.gif" />
             <File Id="file_MAESTROBIN_70" Name="icon_back_disabled.gif" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\stdicons\icon_back_disabled.gif" />
@@ -192,243 +192,244 @@
           </Component>
         </Directory>
         <Directory Id="dir_MapGuideMaestro_Templates_3" Name="Templates">
-          <Component Id="comp_MAESTROBIN_147" DiskId="1" KeyPath="yes" Guid="6F783FAF-92BB-45D9-B37E-6DA1E57A70E4">
-            <File Id="file_MAESTROBIN_147" Name="Dataconnection.FeatureSource" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Dataconnection.FeatureSource" />
-            <File Id="file_MAESTROBIN_148" Name="Fusion Application.ApplicationDefinition" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Fusion Application.ApplicationDefinition" />
-            <File Id="file_MAESTROBIN_149" Name="Layer.LayerDefinition" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Layer.LayerDefinition" />
-            <File Id="file_MAESTROBIN_150" Name="Layout.WebLayout" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Layout.WebLayout" />
-            <File Id="file_MAESTROBIN_151" Name="Map.MapDefinition" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Map.MapDefinition" />
-            <File Id="file_MAESTROBIN_152" Name="Print Layout.PrintLayout" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Print Layout.PrintLayout" />
-            <File Id="file_MAESTROBIN_153" Name="Symbol Definition.SymbolDefinition" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Symbol Definition.SymbolDefinition" />
-            <File Id="file_MAESTROBIN_154" Name="Symbol Library.SymbolLibrary" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Symbol Library.SymbolLibrary" />
+          <Component Id="comp_MAESTROBIN_147" DiskId="1" KeyPath="yes" Guid="44F7C37A-C3D1-4E2C-9C2F-86EB6442E1E1">
+            <File Id="file_MAESTROBIN_147" Name="Compound Symbol.SymbolDefinition" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Compound Symbol.SymbolDefinition" />
+            <File Id="file_MAESTROBIN_148" Name="Dataconnection.FeatureSource" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Dataconnection.FeatureSource" />
+            <File Id="file_MAESTROBIN_149" Name="Fusion Application.ApplicationDefinition" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Fusion Application.ApplicationDefinition" />
+            <File Id="file_MAESTROBIN_150" Name="Layer.LayerDefinition" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Layer.LayerDefinition" />
+            <File Id="file_MAESTROBIN_151" Name="Layout.WebLayout" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Layout.WebLayout" />
+            <File Id="file_MAESTROBIN_152" Name="Map.MapDefinition" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Map.MapDefinition" />
+            <File Id="file_MAESTROBIN_153" Name="Print Layout.PrintLayout" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Print Layout.PrintLayout" />
+            <File Id="file_MAESTROBIN_154" Name="Symbol Definition.SymbolDefinition" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Symbol Definition.SymbolDefinition" />
+            <File Id="file_MAESTROBIN_155" Name="Symbol Library.SymbolLibrary" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\Templates\Symbol Library.SymbolLibrary" />
           </Component>
         </Directory>
         <Directory Id="dir_MapGuideMaestro_WebStudio_4" Name="WebStudio">
-          <Component Id="comp_MAESTROBIN_155" DiskId="1" KeyPath="yes" Guid="CA150D19-B32A-46AF-B807-A511CCEF4D0B">
-            <File Id="file_MAESTROBIN_155" Name="copyright.txt" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\copyright.txt" />
+          <Component Id="comp_MAESTROBIN_156" DiskId="1" KeyPath="yes" Guid="F989DA0F-62FE-460C-98DE-260D6238F5E9">
+            <File Id="file_MAESTROBIN_156" Name="copyright.txt" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\copyright.txt" />
           </Component>
           <Directory Id="dir_MapGuideMaestro_WebStudio_areas_5" Name="areas">
-            <Component Id="comp_MAESTROBIN_156" DiskId="1" KeyPath="yes" Guid="3658E467-B29D-47E6-8C8E-00EE1C7230B8">
-              <File Id="file_MAESTROBIN_156" Name="Acad_iso02w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso02w100.png" />
-              <File Id="file_MAESTROBIN_157" Name="Acad_iso03w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso03w100.png" />
-              <File Id="file_MAESTROBIN_158" Name="Acad_iso04w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso04w100.png" />
-              <File Id="file_MAESTROBIN_159" Name="Acad_iso05w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso05w100.png" />
-              <File Id="file_MAESTROBIN_160" Name="Acad_iso06w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso06w100.png" />
-              <File Id="file_MAESTROBIN_161" Name="Acad_iso07w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso07w100.png" />
-              <File Id="file_MAESTROBIN_162" Name="Acad_iso08w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso08w100.png" />
-              <File Id="file_MAESTROBIN_163" Name="Acad_iso09w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso09w100.png" />
-              <File Id="file_MAESTROBIN_164" Name="Acad_iso10w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso10w100.png" />
-              <File Id="file_MAESTROBIN_165" Name="Acad_iso11w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso11w100.png" />
-              <File Id="file_MAESTROBIN_166" Name="Acad_iso12w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso12w100.png" />
-              <File Id="file_MAESTROBIN_167" Name="Acad_iso13w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso13w100.png" />
-              <File Id="file_MAESTROBIN_168" Name="Acad_iso14w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso14w100.png" />
-              <File Id="file_MAESTROBIN_169" Name="Acad_iso15w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso15w100.png" />
-              <File Id="file_MAESTROBIN_170" Name="Angle.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Angle.png" />
-              <File Id="file_MAESTROBIN_171" Name="Ansi31.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi31.png" />
-              <File Id="file_MAESTROBIN_172" Name="Ansi32.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi32.png" />
-              <File Id="file_MAESTROBIN_173" Name="Ansi33.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi33.png" />
-              <File Id="file_MAESTROBIN_174" Name="Ansi34.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi34.png" />
-              <File Id="file_MAESTROBIN_175" Name="Ansi35.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi35.png" />
-              <File Id="file_MAESTROBIN_176" Name="Ansi36.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi36.png" />
-              <File Id="file_MAESTROBIN_177" Name="Ansi37.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi37.png" />
-              <File Id="file_MAESTROBIN_178" Name="Ansi38.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi38.png" />
-              <File Id="file_MAESTROBIN_179" Name="Ar_b816.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b816.png" />
-              <File Id="file_MAESTROBIN_180" Name="Ar_b816c.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b816c.png" />
-              <File Id="file_MAESTROBIN_181" Name="Ar_b88.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b88.png" />
-              <File Id="file_MAESTROBIN_182" Name="Ar_brelm.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_brelm.png" />
-              <File Id="file_MAESTROBIN_183" Name="Ar_brstd.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_brstd.png" />
-              <File Id="file_MAESTROBIN_184" Name="Ar_conc.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_conc.png" />
-              <File Id="file_MAESTROBIN_185" Name="Ar_hbone.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_hbone.png" />
-              <File Id="file_MAESTROBIN_186" Name="Ar_parq1.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_parq1.png" />
-              <File Id="file_MAESTROBIN_187" Name="Ar_rroof.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rroof.png" />
-              <File Id="file_MAESTROBIN_188" Name="Ar_rroof_90.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rroof_90.png" />
-              <File Id="file_MAESTROBIN_189" Name="Ar_rshke.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke.png" />
-              <File Id="file_MAESTROBIN_190" Name="Ar_rshke_180.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_180.png" />
-              <File Id="file_MAESTROBIN_191" Name="Ar_rshke_270.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_270.png" />
-              <File Id="file_MAESTROBIN_192" Name="Ar_rshke_90.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_90.png" />
-              <File Id="file_MAESTROBIN_193" Name="Ar_sand.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_sand.png" />
-              <File Id="file_MAESTROBIN_194" Name="Box.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Box.png" />
-              <File Id="file_MAESTROBIN_195" Name="Brass.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brass.png" />
-              <File Id="file_MAESTROBIN_196" Name="Brick.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brick.png" />
-              <File Id="file_MAESTROBIN_197" Name="Brstone.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brstone.png" />
-              <File Id="file_MAESTROBIN_198" Name="Clay.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Clay.png" />
-              <File Id="file_MAESTROBIN_199" Name="Cork.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Cork.png" />
-              <File Id="file_MAESTROBIN_200" Name="Cross.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Cross.png" />
-              <File Id="file_MAESTROBIN_201" Name="Dash.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dash.png" />
-              <File Id="file_MAESTROBIN_202" Name="Dolmit.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dolmit.png" />
-              <File Id="file_MAESTROBIN_203" Name="Dots.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dots.png" />
-              <File Id="file_MAESTROBIN_204" Name="Earth.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Earth.png" />
-              <File Id="file_MAESTROBIN_205" Name="Escher.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Escher.png" />
-              <File Id="file_MAESTROBIN_206" Name="Flex.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Flex.png" />
-              <File Id="file_MAESTROBIN_207" Name="Grass.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Grass.png" />
-              <File Id="file_MAESTROBIN_208" Name="Grate.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Grate.png" />
-              <File Id="file_MAESTROBIN_209" Name="Hex.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Hex.png" />
-              <File Id="file_MAESTROBIN_210" Name="Honey.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Honey.png" />
-              <File Id="file_MAESTROBIN_211" Name="Hound.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Hound.png" />
-              <File Id="file_MAESTROBIN_212" Name="Insul.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Insul.png" />
-              <File Id="file_MAESTROBIN_213" Name="Line.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line.png" />
-              <File Id="file_MAESTROBIN_214" Name="Line_135.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_135.png" />
-              <File Id="file_MAESTROBIN_215" Name="Line_45.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_45.png" />
-              <File Id="file_MAESTROBIN_216" Name="Line_90.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_90.png" />
-              <File Id="file_MAESTROBIN_217" Name="Mudst.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Mudst.png" />
-              <File Id="file_MAESTROBIN_218" Name="Net.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net.png" />
-              <File Id="file_MAESTROBIN_219" Name="Net3.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net3.png" />
-              <File Id="file_MAESTROBIN_220" Name="Net_45.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net_45.png" />
-              <File Id="file_MAESTROBIN_221" Name="Plast.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Plast.png" />
-              <File Id="file_MAESTROBIN_222" Name="Plasti.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Plasti.png" />
-              <File Id="file_MAESTROBIN_223" Name="Sacncr.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Sacncr.png" />
-              <File Id="file_MAESTROBIN_224" Name="Shapefill12.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill12.png" />
-              <File Id="file_MAESTROBIN_225" Name="Shapefill13.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill13.png" />
-              <File Id="file_MAESTROBIN_226" Name="Shapefill14.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill14.png" />
-              <File Id="file_MAESTROBIN_227" Name="Shapefill15.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill15.png" />
-              <File Id="file_MAESTROBIN_228" Name="Shapefill16.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill16.png" />
-              <File Id="file_MAESTROBIN_229" Name="Shapefill17.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill17.png" />
-              <File Id="file_MAESTROBIN_230" Name="Shapefill18.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill18.png" />
-              <File Id="file_MAESTROBIN_231" Name="Shapefill19.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill19.png" />
-              <File Id="file_MAESTROBIN_232" Name="Shapefill20.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill20.png" />
-              <File Id="file_MAESTROBIN_233" Name="Shapefill21.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill21.png" />
-              <File Id="file_MAESTROBIN_234" Name="Shapefill22.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill22.png" />
-              <File Id="file_MAESTROBIN_235" Name="Shapefill23.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill23.png" />
-              <File Id="file_MAESTROBIN_236" Name="Shapefill24.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill24.png" />
-              <File Id="file_MAESTROBIN_237" Name="Shapefill25.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill25.png" />
-              <File Id="file_MAESTROBIN_238" Name="Shapefill26.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill26.png" />
-              <File Id="file_MAESTROBIN_239" Name="Shapefill27.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill27.png" />
-              <File Id="file_MAESTROBIN_240" Name="Shapefill28.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill28.png" />
-              <File Id="file_MAESTROBIN_241" Name="Shapefill29.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill29.png" />
-              <File Id="file_MAESTROBIN_242" Name="Shapefill30.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill30.png" />
-              <File Id="file_MAESTROBIN_243" Name="Shapefill31.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill31.png" />
-              <File Id="file_MAESTROBIN_244" Name="Shapefill32.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill32.png" />
-              <File Id="file_MAESTROBIN_245" Name="Shapefill33.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill33.png" />
-              <File Id="file_MAESTROBIN_246" Name="Shapefill34.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill34.png" />
-              <File Id="file_MAESTROBIN_247" Name="Shapefill35.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill35.png" />
-              <File Id="file_MAESTROBIN_248" Name="Shapefill36.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill36.png" />
-              <File Id="file_MAESTROBIN_249" Name="Shapefill37.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill37.png" />
-              <File Id="file_MAESTROBIN_250" Name="Shapefill38.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill38.png" />
-              <File Id="file_MAESTROBIN_251" Name="Shapefill39.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill39.png" />
-              <File Id="file_MAESTROBIN_252" Name="Shapefill40.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill40.png" />
-              <File Id="file_MAESTROBIN_253" Name="Shapefill41.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill41.png" />
-              <File Id="file_MAESTROBIN_254" Name="Shapefill42.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill42.png" />
-              <File Id="file_MAESTROBIN_255" Name="Shapefill43.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill43.png" />
-              <File Id="file_MAESTROBIN_256" Name="Shapefill44.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill44.png" />
-              <File Id="file_MAESTROBIN_257" Name="Shapefill45.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill45.png" />
-              <File Id="file_MAESTROBIN_258" Name="Shapefill46.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill46.png" />
-              <File Id="file_MAESTROBIN_259" Name="Shapefill47.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill47.png" />
-              <File Id="file_MAESTROBIN_260" Name="Shapefill48.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill48.png" />
-              <File Id="file_MAESTROBIN_261" Name="Shapefill49.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill49.png" />
-              <File Id="file_MAESTROBIN_262" Name="Shapefill50.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill50.png" />
-              <File Id="file_MAESTROBIN_263" Name="Shapefill51.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill51.png" />
-              <File Id="file_MAESTROBIN_264" Name="Shapefill52.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill52.png" />
-              <File Id="file_MAESTROBIN_265" Name="Shapefill53.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill53.png" />
-              <File Id="file_MAESTROBIN_266" Name="Shapefill54.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill54.png" />
-              <File Id="file_MAESTROBIN_267" Name="Shapefill55.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill55.png" />
-              <File Id="file_MAESTROBIN_268" Name="Shapefill56.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill56.png" />
-              <File Id="file_MAESTROBIN_269" Name="Shapefill57.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill57.png" />
-              <File Id="file_MAESTROBIN_270" Name="Shapefill58.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill58.png" />
-              <File Id="file_MAESTROBIN_271" Name="Shapefill59.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill59.png" />
-              <File Id="file_MAESTROBIN_272" Name="Shapefill60.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill60.png" />
-              <File Id="file_MAESTROBIN_273" Name="Shapefill61.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill61.png" />
-              <File Id="file_MAESTROBIN_274" Name="Shapefill62.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill62.png" />
-              <File Id="file_MAESTROBIN_275" Name="Shapefill63.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill63.png" />
-              <File Id="file_MAESTROBIN_276" Name="Shapefill64.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill64.png" />
-              <File Id="file_MAESTROBIN_277" Name="Shapefill65.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill65.png" />
-              <File Id="file_MAESTROBIN_278" Name="Shapefill66.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill66.png" />
-              <File Id="file_MAESTROBIN_279" Name="Shapefill67.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill67.png" />
-              <File Id="file_MAESTROBIN_280" Name="Shapefill68.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill68.png" />
-              <File Id="file_MAESTROBIN_281" Name="Shapefill69.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill69.png" />
-              <File Id="file_MAESTROBIN_282" Name="Shapefill70.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill70.png" />
-              <File Id="file_MAESTROBIN_283" Name="Shapefill71.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill71.png" />
-              <File Id="file_MAESTROBIN_284" Name="Solid.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Solid.png" />
-              <File Id="file_MAESTROBIN_285" Name="Square.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Square.png" />
-              <File Id="file_MAESTROBIN_286" Name="Stars.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Stars.png" />
-              <File Id="file_MAESTROBIN_287" Name="Steel.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Steel.png" />
-              <File Id="file_MAESTROBIN_288" Name="Swamp.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Swamp.png" />
-              <File Id="file_MAESTROBIN_289" Name="Trans.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Trans.png" />
-              <File Id="file_MAESTROBIN_290" Name="Triang.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Triang.png" />
-              <File Id="file_MAESTROBIN_291" Name="Zigzag.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Zigzag.png" />
+            <Component Id="comp_MAESTROBIN_157" DiskId="1" KeyPath="yes" Guid="D1DC796B-8D85-4400-BC6A-F895CB8C08E4">
+              <File Id="file_MAESTROBIN_157" Name="Acad_iso02w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso02w100.png" />
+              <File Id="file_MAESTROBIN_158" Name="Acad_iso03w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso03w100.png" />
+              <File Id="file_MAESTROBIN_159" Name="Acad_iso04w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso04w100.png" />
+              <File Id="file_MAESTROBIN_160" Name="Acad_iso05w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso05w100.png" />
+              <File Id="file_MAESTROBIN_161" Name="Acad_iso06w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso06w100.png" />
+              <File Id="file_MAESTROBIN_162" Name="Acad_iso07w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso07w100.png" />
+              <File Id="file_MAESTROBIN_163" Name="Acad_iso08w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso08w100.png" />
+              <File Id="file_MAESTROBIN_164" Name="Acad_iso09w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso09w100.png" />
+              <File Id="file_MAESTROBIN_165" Name="Acad_iso10w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso10w100.png" />
+              <File Id="file_MAESTROBIN_166" Name="Acad_iso11w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso11w100.png" />
+              <File Id="file_MAESTROBIN_167" Name="Acad_iso12w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso12w100.png" />
+              <File Id="file_MAESTROBIN_168" Name="Acad_iso13w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso13w100.png" />
+              <File Id="file_MAESTROBIN_169" Name="Acad_iso14w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso14w100.png" />
+              <File Id="file_MAESTROBIN_170" Name="Acad_iso15w100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Acad_iso15w100.png" />
+              <File Id="file_MAESTROBIN_171" Name="Angle.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Angle.png" />
+              <File Id="file_MAESTROBIN_172" Name="Ansi31.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi31.png" />
+              <File Id="file_MAESTROBIN_173" Name="Ansi32.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi32.png" />
+              <File Id="file_MAESTROBIN_174" Name="Ansi33.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi33.png" />
+              <File Id="file_MAESTROBIN_175" Name="Ansi34.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi34.png" />
+              <File Id="file_MAESTROBIN_176" Name="Ansi35.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi35.png" />
+              <File Id="file_MAESTROBIN_177" Name="Ansi36.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi36.png" />
+              <File Id="file_MAESTROBIN_178" Name="Ansi37.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi37.png" />
+              <File Id="file_MAESTROBIN_179" Name="Ansi38.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ansi38.png" />
+              <File Id="file_MAESTROBIN_180" Name="Ar_b816.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b816.png" />
+              <File Id="file_MAESTROBIN_181" Name="Ar_b816c.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b816c.png" />
+              <File Id="file_MAESTROBIN_182" Name="Ar_b88.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_b88.png" />
+              <File Id="file_MAESTROBIN_183" Name="Ar_brelm.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_brelm.png" />
+              <File Id="file_MAESTROBIN_184" Name="Ar_brstd.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_brstd.png" />
+              <File Id="file_MAESTROBIN_185" Name="Ar_conc.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_conc.png" />
+              <File Id="file_MAESTROBIN_186" Name="Ar_hbone.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_hbone.png" />
+              <File Id="file_MAESTROBIN_187" Name="Ar_parq1.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_parq1.png" />
+              <File Id="file_MAESTROBIN_188" Name="Ar_rroof.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rroof.png" />
+              <File Id="file_MAESTROBIN_189" Name="Ar_rroof_90.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rroof_90.png" />
+              <File Id="file_MAESTROBIN_190" Name="Ar_rshke.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke.png" />
+              <File Id="file_MAESTROBIN_191" Name="Ar_rshke_180.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_180.png" />
+              <File Id="file_MAESTROBIN_192" Name="Ar_rshke_270.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_270.png" />
+              <File Id="file_MAESTROBIN_193" Name="Ar_rshke_90.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_rshke_90.png" />
+              <File Id="file_MAESTROBIN_194" Name="Ar_sand.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Ar_sand.png" />
+              <File Id="file_MAESTROBIN_195" Name="Box.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Box.png" />
+              <File Id="file_MAESTROBIN_196" Name="Brass.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brass.png" />
+              <File Id="file_MAESTROBIN_197" Name="Brick.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brick.png" />
+              <File Id="file_MAESTROBIN_198" Name="Brstone.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Brstone.png" />
+              <File Id="file_MAESTROBIN_199" Name="Clay.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Clay.png" />
+              <File Id="file_MAESTROBIN_200" Name="Cork.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Cork.png" />
+              <File Id="file_MAESTROBIN_201" Name="Cross.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Cross.png" />
+              <File Id="file_MAESTROBIN_202" Name="Dash.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dash.png" />
+              <File Id="file_MAESTROBIN_203" Name="Dolmit.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dolmit.png" />
+              <File Id="file_MAESTROBIN_204" Name="Dots.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Dots.png" />
+              <File Id="file_MAESTROBIN_205" Name="Earth.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Earth.png" />
+              <File Id="file_MAESTROBIN_206" Name="Escher.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Escher.png" />
+              <File Id="file_MAESTROBIN_207" Name="Flex.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Flex.png" />
+              <File Id="file_MAESTROBIN_208" Name="Grass.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Grass.png" />
+              <File Id="file_MAESTROBIN_209" Name="Grate.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Grate.png" />
+              <File Id="file_MAESTROBIN_210" Name="Hex.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Hex.png" />
+              <File Id="file_MAESTROBIN_211" Name="Honey.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Honey.png" />
+              <File Id="file_MAESTROBIN_212" Name="Hound.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Hound.png" />
+              <File Id="file_MAESTROBIN_213" Name="Insul.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Insul.png" />
+              <File Id="file_MAESTROBIN_214" Name="Line.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line.png" />
+              <File Id="file_MAESTROBIN_215" Name="Line_135.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_135.png" />
+              <File Id="file_MAESTROBIN_216" Name="Line_45.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_45.png" />
+              <File Id="file_MAESTROBIN_217" Name="Line_90.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Line_90.png" />
+              <File Id="file_MAESTROBIN_218" Name="Mudst.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Mudst.png" />
+              <File Id="file_MAESTROBIN_219" Name="Net.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net.png" />
+              <File Id="file_MAESTROBIN_220" Name="Net3.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net3.png" />
+              <File Id="file_MAESTROBIN_221" Name="Net_45.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Net_45.png" />
+              <File Id="file_MAESTROBIN_222" Name="Plast.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Plast.png" />
+              <File Id="file_MAESTROBIN_223" Name="Plasti.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Plasti.png" />
+              <File Id="file_MAESTROBIN_224" Name="Sacncr.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Sacncr.png" />
+              <File Id="file_MAESTROBIN_225" Name="Shapefill12.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill12.png" />
+              <File Id="file_MAESTROBIN_226" Name="Shapefill13.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill13.png" />
+              <File Id="file_MAESTROBIN_227" Name="Shapefill14.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill14.png" />
+              <File Id="file_MAESTROBIN_228" Name="Shapefill15.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill15.png" />
+              <File Id="file_MAESTROBIN_229" Name="Shapefill16.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill16.png" />
+              <File Id="file_MAESTROBIN_230" Name="Shapefill17.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill17.png" />
+              <File Id="file_MAESTROBIN_231" Name="Shapefill18.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill18.png" />
+              <File Id="file_MAESTROBIN_232" Name="Shapefill19.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill19.png" />
+              <File Id="file_MAESTROBIN_233" Name="Shapefill20.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill20.png" />
+              <File Id="file_MAESTROBIN_234" Name="Shapefill21.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill21.png" />
+              <File Id="file_MAESTROBIN_235" Name="Shapefill22.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill22.png" />
+              <File Id="file_MAESTROBIN_236" Name="Shapefill23.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill23.png" />
+              <File Id="file_MAESTROBIN_237" Name="Shapefill24.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill24.png" />
+              <File Id="file_MAESTROBIN_238" Name="Shapefill25.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill25.png" />
+              <File Id="file_MAESTROBIN_239" Name="Shapefill26.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill26.png" />
+              <File Id="file_MAESTROBIN_240" Name="Shapefill27.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill27.png" />
+              <File Id="file_MAESTROBIN_241" Name="Shapefill28.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill28.png" />
+              <File Id="file_MAESTROBIN_242" Name="Shapefill29.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill29.png" />
+              <File Id="file_MAESTROBIN_243" Name="Shapefill30.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill30.png" />
+              <File Id="file_MAESTROBIN_244" Name="Shapefill31.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill31.png" />
+              <File Id="file_MAESTROBIN_245" Name="Shapefill32.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill32.png" />
+              <File Id="file_MAESTROBIN_246" Name="Shapefill33.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill33.png" />
+              <File Id="file_MAESTROBIN_247" Name="Shapefill34.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill34.png" />
+              <File Id="file_MAESTROBIN_248" Name="Shapefill35.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill35.png" />
+              <File Id="file_MAESTROBIN_249" Name="Shapefill36.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill36.png" />
+              <File Id="file_MAESTROBIN_250" Name="Shapefill37.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill37.png" />
+              <File Id="file_MAESTROBIN_251" Name="Shapefill38.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill38.png" />
+              <File Id="file_MAESTROBIN_252" Name="Shapefill39.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill39.png" />
+              <File Id="file_MAESTROBIN_253" Name="Shapefill40.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill40.png" />
+              <File Id="file_MAESTROBIN_254" Name="Shapefill41.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill41.png" />
+              <File Id="file_MAESTROBIN_255" Name="Shapefill42.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill42.png" />
+              <File Id="file_MAESTROBIN_256" Name="Shapefill43.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill43.png" />
+              <File Id="file_MAESTROBIN_257" Name="Shapefill44.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill44.png" />
+              <File Id="file_MAESTROBIN_258" Name="Shapefill45.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill45.png" />
+              <File Id="file_MAESTROBIN_259" Name="Shapefill46.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill46.png" />
+              <File Id="file_MAESTROBIN_260" Name="Shapefill47.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill47.png" />
+              <File Id="file_MAESTROBIN_261" Name="Shapefill48.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill48.png" />
+              <File Id="file_MAESTROBIN_262" Name="Shapefill49.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill49.png" />
+              <File Id="file_MAESTROBIN_263" Name="Shapefill50.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill50.png" />
+              <File Id="file_MAESTROBIN_264" Name="Shapefill51.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill51.png" />
+              <File Id="file_MAESTROBIN_265" Name="Shapefill52.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill52.png" />
+              <File Id="file_MAESTROBIN_266" Name="Shapefill53.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill53.png" />
+              <File Id="file_MAESTROBIN_267" Name="Shapefill54.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill54.png" />
+              <File Id="file_MAESTROBIN_268" Name="Shapefill55.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill55.png" />
+              <File Id="file_MAESTROBIN_269" Name="Shapefill56.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill56.png" />
+              <File Id="file_MAESTROBIN_270" Name="Shapefill57.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill57.png" />
+              <File Id="file_MAESTROBIN_271" Name="Shapefill58.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill58.png" />
+              <File Id="file_MAESTROBIN_272" Name="Shapefill59.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill59.png" />
+              <File Id="file_MAESTROBIN_273" Name="Shapefill60.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill60.png" />
+              <File Id="file_MAESTROBIN_274" Name="Shapefill61.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill61.png" />
+              <File Id="file_MAESTROBIN_275" Name="Shapefill62.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill62.png" />
+              <File Id="file_MAESTROBIN_276" Name="Shapefill63.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill63.png" />
+              <File Id="file_MAESTROBIN_277" Name="Shapefill64.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill64.png" />
+              <File Id="file_MAESTROBIN_278" Name="Shapefill65.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill65.png" />
+              <File Id="file_MAESTROBIN_279" Name="Shapefill66.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill66.png" />
+              <File Id="file_MAESTROBIN_280" Name="Shapefill67.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill67.png" />
+              <File Id="file_MAESTROBIN_281" Name="Shapefill68.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill68.png" />
+              <File Id="file_MAESTROBIN_282" Name="Shapefill69.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill69.png" />
+              <File Id="file_MAESTROBIN_283" Name="Shapefill70.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill70.png" />
+              <File Id="file_MAESTROBIN_284" Name="Shapefill71.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Shapefill71.png" />
+              <File Id="file_MAESTROBIN_285" Name="Solid.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Solid.png" />
+              <File Id="file_MAESTROBIN_286" Name="Square.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Square.png" />
+              <File Id="file_MAESTROBIN_287" Name="Stars.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Stars.png" />
+              <File Id="file_MAESTROBIN_288" Name="Steel.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Steel.png" />
+              <File Id="file_MAESTROBIN_289" Name="Swamp.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Swamp.png" />
+              <File Id="file_MAESTROBIN_290" Name="Trans.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Trans.png" />
+              <File Id="file_MAESTROBIN_291" Name="Triang.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Triang.png" />
+              <File Id="file_MAESTROBIN_292" Name="Zigzag.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\areas\Zigzag.png" />
             </Component>
           </Directory>
           <Directory Id="dir_MapGuideMaestro_WebStudio_lines_6" Name="lines">
-            <Component Id="comp_MAESTROBIN_292" DiskId="1" KeyPath="yes" Guid="7AFB2FB6-B323-451A-BB87-16895E5B925E">
-              <File Id="file_MAESTROBIN_292" Name="ACAD_ISO02W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO02W100.png" />
-              <File Id="file_MAESTROBIN_293" Name="ACAD_ISO03W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO03W100.png" />
-              <File Id="file_MAESTROBIN_294" Name="ACAD_ISO04W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO04W100.png" />
-              <File Id="file_MAESTROBIN_295" Name="ACAD_ISO05W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO05W100.png" />
-              <File Id="file_MAESTROBIN_296" Name="ACAD_ISO06W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO06W100.png" />
-              <File Id="file_MAESTROBIN_297" Name="ACAD_ISO07W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO07W100.png" />
-              <File Id="file_MAESTROBIN_298" Name="ACAD_ISO08W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO08W100.png" />
-              <File Id="file_MAESTROBIN_299" Name="ACAD_ISO09W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO09W100.png" />
-              <File Id="file_MAESTROBIN_300" Name="ACAD_ISO10W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO10W100.png" />
-              <File Id="file_MAESTROBIN_301" Name="ACAD_ISO11W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO11W100.png" />
-              <File Id="file_MAESTROBIN_302" Name="ACAD_ISO12W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO12W100.png" />
-              <File Id="file_MAESTROBIN_303" Name="ACAD_ISO13W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO13W100.png" />
-              <File Id="file_MAESTROBIN_304" Name="ACAD_ISO14W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO14W100.png" />
-              <File Id="file_MAESTROBIN_305" Name="ACAD_ISO15W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO15W100.png" />
-              <File Id="file_MAESTROBIN_306" Name="BORDER.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDER.png" />
-              <File Id="file_MAESTROBIN_307" Name="BORDER2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDER2.png" />
-              <File Id="file_MAESTROBIN_308" Name="BORDERX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDERX2.png" />
-              <File Id="file_MAESTROBIN_309" Name="CENTER.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTER.png" />
-              <File Id="file_MAESTROBIN_310" Name="CENTER2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTER2.png" />
-              <File Id="file_MAESTROBIN_311" Name="CENTERX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTERX2.png" />
-              <File Id="file_MAESTROBIN_312" Name="Dash.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Dash.png" />
-              <File Id="file_MAESTROBIN_313" Name="DashDot.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DashDot.png" />
-              <File Id="file_MAESTROBIN_314" Name="DASHDOT2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOT2.png" />
-              <File Id="file_MAESTROBIN_315" Name="DASHDOT3.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOT3.png" />
-              <File Id="file_MAESTROBIN_316" Name="DashDotDot.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DashDotDot.png" />
-              <File Id="file_MAESTROBIN_317" Name="DASHDOTX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOTX2.png" />
-              <File Id="file_MAESTROBIN_318" Name="DASHED.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHED.png" />
-              <File Id="file_MAESTROBIN_319" Name="DASHED2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHED2.png" />
-              <File Id="file_MAESTROBIN_320" Name="DASHEDX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHEDX2.png" />
-              <File Id="file_MAESTROBIN_321" Name="DIVIDE.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDE.png" />
-              <File Id="file_MAESTROBIN_322" Name="DIVIDE2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDE2.png" />
-              <File Id="file_MAESTROBIN_323" Name="DIVIDEX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDEX2.png" />
-              <File Id="file_MAESTROBIN_324" Name="Dot.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Dot.png" />
-              <File Id="file_MAESTROBIN_325" Name="DOT2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOT2.png" />
-              <File Id="file_MAESTROBIN_326" Name="DOT3.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOT3.png" />
-              <File Id="file_MAESTROBIN_327" Name="DOTX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOTX2.png" />
-              <File Id="file_MAESTROBIN_328" Name="FENCELINE1.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\FENCELINE1.png" />
-              <File Id="file_MAESTROBIN_329" Name="FENCELINE2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\FENCELINE2.png" />
-              <File Id="file_MAESTROBIN_330" Name="HIDDEN.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDEN.png" />
-              <File Id="file_MAESTROBIN_331" Name="HIDDEN2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDEN2.png" />
-              <File Id="file_MAESTROBIN_332" Name="HIDDENX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDENX2.png" />
-              <File Id="file_MAESTROBIN_333" Name="LINE03.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE03.png" />
-              <File Id="file_MAESTROBIN_334" Name="LINE04.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE04.png" />
-              <File Id="file_MAESTROBIN_335" Name="LINE05.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE05.png" />
-              <File Id="file_MAESTROBIN_336" Name="LINE06.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE06.png" />
-              <File Id="file_MAESTROBIN_337" Name="LINE07.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE07.png" />
-              <File Id="file_MAESTROBIN_338" Name="LINE08.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE08.png" />
-              <File Id="file_MAESTROBIN_339" Name="LINE09.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE09.png" />
-              <File Id="file_MAESTROBIN_340" Name="LINE10.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE10.png" />
-              <File Id="file_MAESTROBIN_341" Name="LINE11.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE11.png" />
-              <File Id="file_MAESTROBIN_342" Name="LINE12.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE12.png" />
-              <File Id="file_MAESTROBIN_343" Name="LINE13.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE13.png" />
-              <File Id="file_MAESTROBIN_344" Name="LINE14.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE14.png" />
-              <File Id="file_MAESTROBIN_345" Name="LINE15.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE15.png" />
-              <File Id="file_MAESTROBIN_346" Name="LINE16.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE16.png" />
-              <File Id="file_MAESTROBIN_347" Name="LINE17.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE17.png" />
-              <File Id="file_MAESTROBIN_348" Name="LINE18.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE18.png" />
-              <File Id="file_MAESTROBIN_349" Name="LINE19.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE19.png" />
-              <File Id="file_MAESTROBIN_350" Name="LINE20.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE20.png" />
-              <File Id="file_MAESTROBIN_351" Name="LINE21.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE21.png" />
-              <File Id="file_MAESTROBIN_352" Name="LINE22.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE22.png" />
-              <File Id="file_MAESTROBIN_353" Name="LINE23.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE23.png" />
-              <File Id="file_MAESTROBIN_354" Name="LINE24.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE24.png" />
-              <File Id="file_MAESTROBIN_355" Name="LINE25.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE25.png" />
-              <File Id="file_MAESTROBIN_356" Name="PHANTOM.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOM.png" />
-              <File Id="file_MAESTROBIN_357" Name="PHANTOM2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOM2.png" />
-              <File Id="file_MAESTROBIN_358" Name="PHANTOMX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOMX2.png" />
-              <File Id="file_MAESTROBIN_359" Name="Rail.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Rail.png" />
-              <File Id="file_MAESTROBIN_360" Name="Solid.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Solid.png" />
-              <File Id="file_MAESTROBIN_361" Name="TRACKS.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\TRACKS.png" />
+            <Component Id="comp_MAESTROBIN_293" DiskId="1" KeyPath="yes" Guid="5C5124DE-35FC-4376-92D4-B41FCC14DBAF">
+              <File Id="file_MAESTROBIN_293" Name="ACAD_ISO02W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO02W100.png" />
+              <File Id="file_MAESTROBIN_294" Name="ACAD_ISO03W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO03W100.png" />
+              <File Id="file_MAESTROBIN_295" Name="ACAD_ISO04W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO04W100.png" />
+              <File Id="file_MAESTROBIN_296" Name="ACAD_ISO05W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO05W100.png" />
+              <File Id="file_MAESTROBIN_297" Name="ACAD_ISO06W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO06W100.png" />
+              <File Id="file_MAESTROBIN_298" Name="ACAD_ISO07W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO07W100.png" />
+              <File Id="file_MAESTROBIN_299" Name="ACAD_ISO08W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO08W100.png" />
+              <File Id="file_MAESTROBIN_300" Name="ACAD_ISO09W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO09W100.png" />
+              <File Id="file_MAESTROBIN_301" Name="ACAD_ISO10W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO10W100.png" />
+              <File Id="file_MAESTROBIN_302" Name="ACAD_ISO11W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO11W100.png" />
+              <File Id="file_MAESTROBIN_303" Name="ACAD_ISO12W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO12W100.png" />
+              <File Id="file_MAESTROBIN_304" Name="ACAD_ISO13W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO13W100.png" />
+              <File Id="file_MAESTROBIN_305" Name="ACAD_ISO14W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO14W100.png" />
+              <File Id="file_MAESTROBIN_306" Name="ACAD_ISO15W100.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\ACAD_ISO15W100.png" />
+              <File Id="file_MAESTROBIN_307" Name="BORDER.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDER.png" />
+              <File Id="file_MAESTROBIN_308" Name="BORDER2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDER2.png" />
+              <File Id="file_MAESTROBIN_309" Name="BORDERX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\BORDERX2.png" />
+              <File Id="file_MAESTROBIN_310" Name="CENTER.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTER.png" />
+              <File Id="file_MAESTROBIN_311" Name="CENTER2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTER2.png" />
+              <File Id="file_MAESTROBIN_312" Name="CENTERX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\CENTERX2.png" />
+              <File Id="file_MAESTROBIN_313" Name="Dash.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Dash.png" />
+              <File Id="file_MAESTROBIN_314" Name="DashDot.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DashDot.png" />
+              <File Id="file_MAESTROBIN_315" Name="DASHDOT2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOT2.png" />
+              <File Id="file_MAESTROBIN_316" Name="DASHDOT3.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOT3.png" />
+              <File Id="file_MAESTROBIN_317" Name="DashDotDot.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DashDotDot.png" />
+              <File Id="file_MAESTROBIN_318" Name="DASHDOTX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHDOTX2.png" />
+              <File Id="file_MAESTROBIN_319" Name="DASHED.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHED.png" />
+              <File Id="file_MAESTROBIN_320" Name="DASHED2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHED2.png" />
+              <File Id="file_MAESTROBIN_321" Name="DASHEDX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DASHEDX2.png" />
+              <File Id="file_MAESTROBIN_322" Name="DIVIDE.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDE.png" />
+              <File Id="file_MAESTROBIN_323" Name="DIVIDE2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDE2.png" />
+              <File Id="file_MAESTROBIN_324" Name="DIVIDEX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DIVIDEX2.png" />
+              <File Id="file_MAESTROBIN_325" Name="Dot.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Dot.png" />
+              <File Id="file_MAESTROBIN_326" Name="DOT2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOT2.png" />
+              <File Id="file_MAESTROBIN_327" Name="DOT3.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOT3.png" />
+              <File Id="file_MAESTROBIN_328" Name="DOTX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\DOTX2.png" />
+              <File Id="file_MAESTROBIN_329" Name="FENCELINE1.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\FENCELINE1.png" />
+              <File Id="file_MAESTROBIN_330" Name="FENCELINE2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\FENCELINE2.png" />
+              <File Id="file_MAESTROBIN_331" Name="HIDDEN.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDEN.png" />
+              <File Id="file_MAESTROBIN_332" Name="HIDDEN2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDEN2.png" />
+              <File Id="file_MAESTROBIN_333" Name="HIDDENX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\HIDDENX2.png" />
+              <File Id="file_MAESTROBIN_334" Name="LINE03.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE03.png" />
+              <File Id="file_MAESTROBIN_335" Name="LINE04.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE04.png" />
+              <File Id="file_MAESTROBIN_336" Name="LINE05.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE05.png" />
+              <File Id="file_MAESTROBIN_337" Name="LINE06.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE06.png" />
+              <File Id="file_MAESTROBIN_338" Name="LINE07.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE07.png" />
+              <File Id="file_MAESTROBIN_339" Name="LINE08.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE08.png" />
+              <File Id="file_MAESTROBIN_340" Name="LINE09.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE09.png" />
+              <File Id="file_MAESTROBIN_341" Name="LINE10.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE10.png" />
+              <File Id="file_MAESTROBIN_342" Name="LINE11.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE11.png" />
+              <File Id="file_MAESTROBIN_343" Name="LINE12.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE12.png" />
+              <File Id="file_MAESTROBIN_344" Name="LINE13.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE13.png" />
+              <File Id="file_MAESTROBIN_345" Name="LINE14.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE14.png" />
+              <File Id="file_MAESTROBIN_346" Name="LINE15.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE15.png" />
+              <File Id="file_MAESTROBIN_347" Name="LINE16.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE16.png" />
+              <File Id="file_MAESTROBIN_348" Name="LINE17.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE17.png" />
+              <File Id="file_MAESTROBIN_349" Name="LINE18.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE18.png" />
+              <File Id="file_MAESTROBIN_350" Name="LINE19.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE19.png" />
+              <File Id="file_MAESTROBIN_351" Name="LINE20.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE20.png" />
+              <File Id="file_MAESTROBIN_352" Name="LINE21.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE21.png" />
+              <File Id="file_MAESTROBIN_353" Name="LINE22.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE22.png" />
+              <File Id="file_MAESTROBIN_354" Name="LINE23.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE23.png" />
+              <File Id="file_MAESTROBIN_355" Name="LINE24.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE24.png" />
+              <File Id="file_MAESTROBIN_356" Name="LINE25.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\LINE25.png" />
+              <File Id="file_MAESTROBIN_357" Name="PHANTOM.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOM.png" />
+              <File Id="file_MAESTROBIN_358" Name="PHANTOM2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOM2.png" />
+              <File Id="file_MAESTROBIN_359" Name="PHANTOMX2.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\PHANTOMX2.png" />
+              <File Id="file_MAESTROBIN_360" Name="Rail.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Rail.png" />
+              <File Id="file_MAESTROBIN_361" Name="Solid.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\Solid.png" />
+              <File Id="file_MAESTROBIN_362" Name="TRACKS.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\lines\TRACKS.png" />
             </Component>
           </Directory>
           <Directory Id="dir_MapGuideMaestro_WebStudio_points_7" Name="points">
-            <Component Id="comp_MAESTROBIN_362" DiskId="1" KeyPath="yes" Guid="DBAB720C-ED4E-4055-8151-5B09500CCD37">
-              <File Id="file_MAESTROBIN_362" Name="circle.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\circle.png" />
-              <File Id="file_MAESTROBIN_363" Name="cross.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\cross.png" />
-              <File Id="file_MAESTROBIN_364" Name="square.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\square.png" />
-              <File Id="file_MAESTROBIN_365" Name="star.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\star.png" />
-              <File Id="file_MAESTROBIN_366" Name="triangle.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\triangle.png" />
-              <File Id="file_MAESTROBIN_367" Name="x.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\x.png" />
+            <Component Id="comp_MAESTROBIN_363" DiskId="1" KeyPath="yes" Guid="BF5DAE1F-EA4B-423A-B213-4D42087A8AC6">
+              <File Id="file_MAESTROBIN_363" Name="circle.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\circle.png" />
+              <File Id="file_MAESTROBIN_364" Name="cross.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\cross.png" />
+              <File Id="file_MAESTROBIN_365" Name="square.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\square.png" />
+              <File Id="file_MAESTROBIN_366" Name="star.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\star.png" />
+              <File Id="file_MAESTROBIN_367" Name="triangle.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\triangle.png" />
+              <File Id="file_MAESTROBIN_368" Name="x.png" Source="C:\Users\Kenneth\Documents\Maestro-build\InstallerTempRelease\MapGuideMaestro\WebStudio\points\x.png" />
             </Component>
           </Directory>
         </Directory>
Modified: trunk/Tools/Maestro/Installer/incLocFiles.da-DK.wxs
--- trunk/Tools/Maestro/Installer/incLocFiles.da-DK.wxs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Installer/incLocFiles.da-DK.wxs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -3,7 +3,7 @@
   <!--<CommandLineOptions>
   <Producer>Autogenerated by Paraffin - Wintellect - John Robbins - john at wintellect.com</Producer>
   <WARNING>Manual changes to this file may cause incorrect behavior.</WARNING>
-  <CreatedOn>13-12-2009 02:08</CreatedOn>
+  <CreatedOn>14-12-2009 23:27</CreatedOn>
   <Directory>compiled\da-DK\</Directory>
   <Custom>MAESTROBIN_da-DK</Custom>
   <DirAlias>..\Localization\compiled\da-DK\</DirAlias>
@@ -27,7 +27,7 @@
     </ComponentGroup>
     <DirectoryRef Id="dir_MapGuideMaestro_0">
       <Directory Id="dir_da_DK_0" Name="da-DK">
-        <Component Id="comp_MAESTROBIN_da_DK_0" DiskId="1" KeyPath="yes" Guid="A001569B-9492-480C-8FF7-0426933F35CA">
+        <Component Id="comp_MAESTROBIN_da_DK_0" DiskId="1" KeyPath="yes" Guid="F9FD8BB0-DAFF-4475-A760-DCE426722B2C">
           <File Id="file_MAESTROBIN_da_DK_0" Name="Maestro.resources.dll" Source="..\Localization\compiled\da-DK\Maestro.resources.dll" />
           <File Id="file_MAESTROBIN_da_DK_1" Name="OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" Source="..\Localization\compiled\da-DK\OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" />
           <File Id="file_MAESTROBIN_da_DK_2" Name="OSGeo.MapGuide.Maestro.LoginForm.resources.dll" Source="..\Localization\compiled\da-DK\OSGeo.MapGuide.Maestro.LoginForm.resources.dll" />
Modified: trunk/Tools/Maestro/Installer/incLocFiles.es-ES.wxs
--- trunk/Tools/Maestro/Installer/incLocFiles.es-ES.wxs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Installer/incLocFiles.es-ES.wxs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -3,7 +3,7 @@
   <Directory>compiled\es-ES\</Directory>
   <Custom>MAESTROBIN_es-ES</Custom>
   <DirAlias>..\Localization\compiled\es-ES\</DirAlias>
@@ -27,7 +27,7 @@
     </ComponentGroup>
       <Directory Id="dir_es_ES_0" Name="es-ES">
-        <Component Id="comp_MAESTROBIN_es_ES_0" DiskId="1" KeyPath="yes" Guid="BF3A8362-3184-4976-B61A-7867CF6C3667">
+        <Component Id="comp_MAESTROBIN_es_ES_0" DiskId="1" KeyPath="yes" Guid="DA92A686-0C1A-4A6F-B87B-EB0FBE490DD8">
           <File Id="file_MAESTROBIN_es_ES_0" Name="Maestro.resources.dll" Source="..\Localization\compiled\es-ES\Maestro.resources.dll" />
           <File Id="file_MAESTROBIN_es_ES_1" Name="OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" Source="..\Localization\compiled\es-ES\OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" />
           <File Id="file_MAESTROBIN_es_ES_2" Name="OSGeo.MapGuide.Maestro.LoginForm.resources.dll" Source="..\Localization\compiled\es-ES\OSGeo.MapGuide.Maestro.LoginForm.resources.dll" />
Modified: trunk/Tools/Maestro/Installer/incLocFiles.fr-FR.wxs
--- trunk/Tools/Maestro/Installer/incLocFiles.fr-FR.wxs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Installer/incLocFiles.fr-FR.wxs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -3,7 +3,7 @@
   <Directory>compiled\fr-FR\</Directory>
   <Custom>MAESTROBIN_fr-FR</Custom>
   <DirAlias>..\Localization\compiled\fr-FR\</DirAlias>
@@ -27,7 +27,7 @@
     </ComponentGroup>
       <Directory Id="dir_fr_FR_0" Name="fr-FR">
-        <Component Id="comp_MAESTROBIN_fr_FR_0" DiskId="1" KeyPath="yes" Guid="1FE6962E-F205-42CA-85FA-7A0DAA748272">
+        <Component Id="comp_MAESTROBIN_fr_FR_0" DiskId="1" KeyPath="yes" Guid="A98F3D85-86CA-4468-8DA5-715B671F3D84">
           <File Id="file_MAESTROBIN_fr_FR_0" Name="Maestro.resources.dll" Source="..\Localization\compiled\fr-FR\Maestro.resources.dll" />
           <File Id="file_MAESTROBIN_fr_FR_1" Name="OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" Source="..\Localization\compiled\fr-FR\OSGeo.MapGuide.Maestro.FusionEditor.resources.dll" />
           <File Id="file_MAESTROBIN_fr_FR_2" Name="OSGeo.MapGuide.Maestro.LoginForm.resources.dll" Source="..\Localization\compiled\fr-FR\OSGeo.MapGuide.Maestro.LoginForm.resources.dll" />
Modified: trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -32,5 +32,5 @@
 // You can specify all the values or you can default the Build and Revision Numbers
 // by using the '*' as shown below:
 // [assembly: AssemblyVersion("1.0.*")]
-[assembly: AssemblyVersion("1.1.0.4431")]
-[assembly: AssemblyFileVersion("1.1.0.4431")]
+[assembly: AssemblyVersion("1.1.0.4437")]
+[assembly: AssemblyFileVersion("1.1.0.4437")]
Modified: trunk/Tools/Maestro/Localization/da-DK/Maestro/Strings/TemplateNames.da-DK.resx
--- trunk/Tools/Maestro/Localization/da-DK/Maestro/Strings/TemplateNames.da-DK.resx	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Localization/da-DK/Maestro/Strings/TemplateNames.da-DK.resx	2009-12-14 22:32:39 UTC (rev 4437)
@@ -149,4 +149,8 @@
     <value>Symbolsamling</value>
     <comment>The name of the default Symbol Library template</comment>
   </data>
+  <data name="Compound_Symbol" xml:space="preserve">
+    <value>Sammensat symbol</value>
+    <comment>The name of the compound Symbol Definition template</comment>
+  </data>
 </root>
\ No newline at end of file
Modified: trunk/Tools/Maestro/Localization/es-ES/Maestro/Strings/TemplateNames.es-ES.resx
--- trunk/Tools/Maestro/Localization/es-ES/Maestro/Strings/TemplateNames.es-ES.resx	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Localization/es-ES/Maestro/Strings/TemplateNames.es-ES.resx	2009-12-14 22:32:39 UTC (rev 4437)
@@ -149,4 +149,8 @@
     <value>Librería de Símbolos</value>
   </data>
+  </data>
 </root>
Modified: trunk/Tools/Maestro/Localization/fr-FR/Maestro/Strings/TemplateNames.fr-FR.resx
--- trunk/Tools/Maestro/Localization/fr-FR/Maestro/Strings/TemplateNames.fr-FR.resx	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Localization/fr-FR/Maestro/Strings/TemplateNames.fr-FR.resx	2009-12-14 22:32:39 UTC (rev 4437)
@@ -149,4 +149,8 @@
     <value>Librairie de symboles</value>
   </data>
+  </data>
 </root>
Modified: trunk/Tools/Maestro/Maestro/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/AssemblyInfo.cs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Maestro/AssemblyInfo.cs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -45,7 +45,7 @@
 // You can specify all the values or you can default the Revision and Build Numbers
 // In order to sign your assembly you must specify a key to use. Refer to the
@@ -75,4 +75,4 @@
 [assembly: AssemblyDelaySign(false)]
 [assembly: AssemblyKeyFile("")]
 [assembly: AssemblyKeyName("")]
-[assembly: AssemblyFileVersionAttribute("1.1.0.4431")]
+[assembly: AssemblyFileVersionAttribute("1.1.0.4437")]
Modified: trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -32,5 +32,5 @@
Modified: trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -45,7 +45,7 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -50,5 +50,5 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/Maestro/Strings/TemplateNames.resx
--- trunk/Tools/Maestro/Maestro/Strings/TemplateNames.resx	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/Maestro/Strings/TemplateNames.resx	2009-12-14 22:32:39 UTC (rev 4437)
@@ -118,7 +118,7 @@
     <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
-    <value>Sammensat symbol</value>
+    <value>Compound symbol definition</value>
   </data>
   <data name="Dataconnection" xml:space="preserve">
Modified: trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
 [assembly: AssemblyKeyFile("..\\..\\maestroapi.key")]
Modified: trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -48,5 +48,5 @@
 //      Build Number
 //      Revision
Modified: trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -48,5 +48,5 @@
 //      Build Number
 //      Revision
Modified: trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -48,5 +48,5 @@
 //      Build Number
 //      Revision
Modified: trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs	2009-12-14 22:07:25 UTC (rev 4436)
+++ trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs	2009-12-14 22:32:39 UTC (rev 4437)
@@ -48,5 +48,5 @@
 //      Build Number
 //      Revision
More information about the mapguide-commits mailing list
