[mapguide-commits] r4459 - trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Dec 21 16:28:00 EST 2009
Author: ksgeograf
Date: 2009-12-21 16:28:00 -0500 (Mon, 21 Dec 2009)
New Revision: 4459
   trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/SchemaSelector.cs
Maestro:
Fixed issue #1215.
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/SchemaSelector.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/SchemaSelector.cs	2009-12-21 21:20:24 UTC (rev 4458)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/SchemaSelector.cs	2009-12-21 21:28:00 UTC (rev 4459)
@@ -98,7 +98,7 @@
 							(m_layer.Item as OSGeo.MapGuide.MaestroAPI.GridLayerDefinitionType).FeatureName = schemaName;
 						if (SchemaChanged != null && Schema.SelectedIndex >= 0)
-							SchemaChanged(false, m_schemas[Schema.SelectedIndex]);
+							SchemaChanged(false, this.SelectedSchema);
@@ -194,7 +194,7 @@
 					(m_layer.Item as OSGeo.MapGuide.MaestroAPI.GridLayerDefinitionType).FeatureName = Schema.Text;
 				if (SchemaChanged != null)
-					SchemaChanged(true, m_schemas[Schema.SelectedIndex]);
+					SchemaChanged(true, this.SelectedSchema);
 				UpdateGeometry(true);
 				m_editor.HasChanged();
@@ -203,10 +203,24 @@
 				Geometry.Enabled = false;
+        [Browsable(false)]
+        public MaestroAPI.FeatureSourceDescription.FeatureSourceSchema SelectedSchema
+            get
+                if (Schema.SelectedIndex < 0)
+                    return null;
+                foreach (MaestroAPI.FeatureSourceDescription.FeatureSourceSchema s in m_schemas.Schemas)
+                    if (OSGeo.MapGuide.MaestroAPI.Utility.DecodeFDOName(s.Fullname) == Schema.Text)
+                        return s;
+                return null;
 		public bool IsRaster
 			get { return m_isRaster; }
@@ -232,7 +246,7 @@
 				Geometry.Enabled = true;
-				foreach(OSGeo.MapGuide.MaestroAPI.FeatureSetColumn col in m_schemas[Schema.SelectedIndex].Columns)
+				foreach(OSGeo.MapGuide.MaestroAPI.FeatureSetColumn col in SelectedSchema.Columns)
 					if (!m_isRaster && col.Type == OSGeo.MapGuide.MaestroAPI.Utility.GeometryType)
 						Geometry.Items.Add(col.Name);
More information about the mapguide-commits mailing list
