[mapguide-commits] r4465 - trunk/Tools/Maestro/Maestro/ResourceEditors
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Dec 23 15:51:50 EST 2009
Author: ksgeograf
Date: 2009-12-23 15:51:49 -0500 (Wed, 23 Dec 2009)
New Revision: 4465
   trunk/Tools/Maestro/Maestro/ResourceEditors/SelectCoordinateSystem.resx
   trunk/Tools/Maestro/Maestro/ResourceEditors/XmlEditorControl.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/XmlEditorControl.resx
Maestro:
Fixed issue #1200
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/SelectCoordinateSystem.resx
--- trunk/Tools/Maestro/Maestro/ResourceEditors/SelectCoordinateSystem.resx	2009-12-23 19:52:00 UTC (rev 4464)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/SelectCoordinateSystem.resx	2009-12-23 20:51:49 UTC (rev 4465)
@@ -772,7 +772,7 @@
     <value>528, 333</value>
   </data>
   <data name="$this.Text" xml:space="preserve">
-    <value>SelectCoordinateSystem</value>
+    <value>Select coordinate system</value>
   </data>
   <data name="&gt;&gt;$this.Name" xml:space="preserve">
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/XmlEditorControl.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/XmlEditorControl.cs	2009-12-23 19:52:00 UTC (rev 4464)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/XmlEditorControl.cs	2009-12-23 20:51:49 UTC (rev 4465)
@@ -62,7 +62,9 @@
 		private string m_resourceId = null;
         private GroupBox ResourceDataGroup;
         private ResourceDataEditor resourceDataEditor;
+        private ToolStripLabel toolStripLabel1;
         private bool m_modified = false;
+        private string m_positionTemplate;
 		public XmlEditorControl(EditorInterface editor, string item)
 			: this(editor, editor.CurrentConnection.TryGetResourceType(item) == null ? editor.CurrentConnection.GetResourceXmlData(item) : editor.CurrentConnection.GetResource(item), item)
@@ -169,6 +171,9 @@
 			// Required for Windows Form Designer support
 			InitializeComponent();
+            m_positionTemplate = toolStripLabel1.Text;
+            toolStripLabel1.Text = String.Format(m_positionTemplate, 0, 0);
 		//TODO: Add syntax higlighting for the editor
@@ -216,6 +221,7 @@
             this.toolStripSeparator3 = new System.Windows.Forms.ToolStripSeparator();
             this.LaunchExternalEditorButton = new System.Windows.Forms.ToolStripButton();
             this.toolbarImages = new System.Windows.Forms.ImageList(this.components);
+            this.toolStripLabel1 = new System.Windows.Forms.ToolStripLabel();
             this.resourceDataEditor = new OSGeo.MapGuide.Maestro.ResourceEditors.ResourceDataEditor();
             this.panel2.SuspendLayout();
             this.ResourceDataGroup.SuspendLayout();
@@ -239,7 +245,9 @@
             resources.ApplyResources(this.textEditor, "textEditor");
             this.textEditor.Name = "textEditor";
             this.textEditor.TextChanged += new System.EventHandler(this.textEditor_TextChanged);
+            this.textEditor.MouseMove += new System.Windows.Forms.MouseEventHandler(this.textEditor_MouseMove);
             this.textEditor.KeyUp += new System.Windows.Forms.KeyEventHandler(this.textEditor_KeyUp);
+            this.textEditor.MouseUp += new System.Windows.Forms.MouseEventHandler(this.textEditor_MouseUp);
             // ResourceDataGroup
@@ -284,7 +292,8 @@
             this.toolStripSeparator2,
             this.ValidateButton,
             this.toolStripSeparator3,
-            this.LaunchExternalEditorButton});
+            this.LaunchExternalEditorButton,
+            this.toolStripLabel1});
             resources.ApplyResources(this.toolBar, "toolBar");
             this.toolBar.Name = "toolBar";
             this.toolBar.RenderMode = System.Windows.Forms.ToolStripRenderMode.System;
@@ -365,6 +374,12 @@
             this.toolbarImages.Images.SetKeyName(5, "");
             this.toolbarImages.Images.SetKeyName(6, "");
+            // toolStripLabel1
+            this.toolStripLabel1.Alignment = System.Windows.Forms.ToolStripItemAlignment.Right;
+            this.toolStripLabel1.Name = "toolStripLabel1";
+            resources.ApplyResources(this.toolStripLabel1, "toolStripLabel1");
             // resourceDataEditor
             resources.ApplyResources(this.resourceDataEditor, "resourceDataEditor");
@@ -646,8 +661,18 @@
             if (e.Control && e.KeyCode == Keys.A)
                 textEditor.SelectAll();
+            UpdateTextPosition();
+        private void UpdateTextPosition()
+            int line = textEditor.GetLineFromCharIndex(textEditor.SelectionStart + textEditor.SelectionLength);
+            int col = (textEditor.SelectionStart + textEditor.SelectionLength) - textEditor.GetFirstCharIndexFromLine(line);
+            toolStripLabel1.Text = String.Format(m_positionTemplate, line + 1, col + 1);
         public bool Modified { get { return m_modified; } }
         public object SerializedObject { get { return m_serializedObject; } }
@@ -662,5 +687,16 @@
             resourceDataEditor.SaveChanges();
+        private void textEditor_MouseUp(object sender, MouseEventArgs e)
+        private void textEditor_MouseMove(object sender, MouseEventArgs e)
+            if (e.Button != MouseButtons.None)
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/XmlEditorControl.resx
--- trunk/Tools/Maestro/Maestro/ResourceEditors/XmlEditorControl.resx	2009-12-23 19:52:00 UTC (rev 4464)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/XmlEditorControl.resx	2009-12-23 20:51:49 UTC (rev 4465)
@@ -175,7 +175,7 @@
     <value>resourceDataEditor</value>
   </data>
   <data name="&gt;&gt;resourceDataEditor.Type" xml:space="preserve">
-    <value>OSGeo.MapGuide.Maestro.ResourceEditors.ResourceDataEditor, OSGeo.MapGuide.Maestro.ResourceEditors, Version=1.1.0.4358, Culture=neutral, PublicKeyToken=null</value>
+    <value>OSGeo.MapGuide.Maestro.ResourceEditors.ResourceDataEditor, OSGeo.MapGuide.Maestro.ResourceEditors, Version=1.1.0.4437, Culture=neutral, PublicKeyToken=null</value>
   </data>
   <data name="&gt;&gt;resourceDataEditor.Parent" xml:space="preserve">
     <value>ResourceDataGroup</value>
@@ -484,6 +484,12 @@
   <data name="LaunchExternalEditorButton.ToolTipText" xml:space="preserve">
     <value>Launch the system editor associated with xml files</value>
   </data>
+  <data name="toolStripLabel1.Size" type="System.Drawing.Size, System.Drawing">
+    <value>110, 22</value>
+  </data>
+  <data name="toolStripLabel1.Text" xml:space="preserve">
+    <value>Line {0}, column {1}</value>
+  </data>
   <data name="toolBar.Location" type="System.Drawing.Point, System.Drawing">
     <value>0, 0</value>
   </data>
@@ -537,139 +543,139 @@
         AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
         LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
         ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAA6
-        IQAAAk1TRnQBSQFMAgEBBwEAATQBAAE0AQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
-        AwABIAMAAQEBAAEgBgABIGYAAYQBygGEAf8BVAG3AVcB//QAAYQBygGEAf8BUgHUAYAB/wFyAfQBpQH/
-        AT4BuAFQAf8kAAGhAZ4BnQH/AaEBngGdAf8BoQGeAZ0B/wGfApwB/wGfApwB/wGfApwB/wGbApgB/wGb
-        ApgB/wGbApgB/wGWApQB/wGWApQB/wGWApQB/wGWApQB/wGWApQB/5AAAY0B0QGNAf8BSgHMAWsB/wF0
-        AfABlwH/AXcB8AGMAf8BYwHmAZIB/wFpAb4BagH/HAABpAKgAf8B9wHvAewB/wH0AegB4wH/AfQB5wHi
+        IQAAAk1TRnQBSQFMAgEBBwEAAUQBAAFEAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
+        AwABIAMAAQEBAAEgBgABIGYAAYQBygGEAf8BUgG3AVUB//QAAYQBygGEAf8BUAHUAYAB/wFwAfQBpQH/
+        ATwBuAFOAf8kAAGhAZ4BnQH/AaEBngGdAf8BoQGeAZ0B/wGfApwB/wGfApwB/wGfApwB/wGbApgB/wGb
+        ApgB/wGbApgB/wGWApQB/wGWApQB/wGWApQB/wGWApQB/wGWApQB/5AAAY0B0QGNAf8BSAHMAWkB/wFy
+        AfABlwH/AXUB8AGMAf8BYQHmAZIB/wFnAb4BaAH/HAABpAKgAf8B9wHvAewB/wH0AegB4wH/AfQB5wHi
         Af8B9AHnAeIB/wH0AecB4gH/AfIB4gHcAf8B8gHiAdwB/wHyAeIB3AH/AfIB4gHcAf8B8gHiAdwB/wHy
-        AeIB3AH/AfIB4gHcAf8B8gHiAdwB/wH0AegB4wH/AZYClAH/WAABqwFHAT8B/wG0AVYBQQH/AbQBVgFB
-        Af8BsAFRAT0B/wGwAVEBPQH/Aa4BTgE8Af8BrgFOATwB/wGuAU4BPAH/Aa4BTgE8Af8BrgFVAVkB/wgA
-        AYQBygGEAf8BSgHMAWsB/wFvAesBlAH/AXYB7gGKAf8BdwHwAYwB/wF0AfABlwH/AUQBxQFeAf8cAAGk
+        AeIB3AH/AfIB4gHcAf8B8gHiAdwB/wH0AegB4wH/AZYClAH/WAABqwFFAT0B/wG0AVQBPwH/AbQBVAE/
+        Af8BsAFPATsB/wGwAU8BOwH/Aa4BTAE6Af8BrgFMAToB/wGuAUwBOgH/Aa4BTAE6Af8BrgFTAVcB/wgA
+        AYQBygGEAf8BSAHMAWkB/wFtAesBlAH/AXQB7gGKAf8BdQHwAYwB/wFyAfABlwH/AUIBxQFcAf8cAAGk
         AqAB/wH0AegB4wH/AeUB1gHQAf8B0QHFAcEB/wHRAcUBwQH/Ac4BwQG9Af8BzgHBAb0B/wHOAcEBvQH/
         Ac0BwAG7Af8BzQHAAbsB/wHNAcABuwH/AcsBvAG4Af8BzQHAAbsB/wHgAc0BxgH/AfIB4gHcAf8BlgKU
-        Af9cAAHHAXUBRQH/AeMBnwFYAf8B2QGKAU4B/wHVAYUBSgH/AdUBhQFKAf8B1QGFAUoB/wHVAYUBSgH/
-        AdwBmQFRAf8BuwFvAXMB/wQAAYEBzAGBAf8BSQHRAW8B/wFpAeQBiwH/AXAB5wGFAf8BcwHxAZwB/wFz
-        AfEBnAH/AXIB7wGIAf8BZQHqAZQB/wFNAbYBUQH/GAABqQGmAaUB/wH3Ae8B7AH/AfIB4gHcAf8B7gHe
+        Af9cAAHHAXMBQwH/AeMBnwFWAf8B2QGKAUwB/wHVAYUBSAH/AdUBhQFIAf8B1QGFAUgB/wHVAYUBSAH/
+        AdwBmQFPAf8BuwFtAXEB/wQAAYEBzAGBAf8BRwHRAW0B/wFnAeQBiwH/AW4B5wGFAf8BcQHxAZwB/wFx
+        AfEBnAH/AXAB7wGIAf8BYwHqAZQB/wFLAbYBTwH/GAABqQGmAaUB/wH3Ae8B7AH/AfIB4gHcAf8B7gHe
         AdkB/wHuAd4B2QH/AewB2gHUAf8B7AHaAdQB/wHsAdoB1AH/Ae0B1wHPAf8B6QHVAc4B/wHpAdUBzgH/
-        AekB1QHOAf8B6QHVAc4B/wHpAdUBzgH/AfIB4gHcAf8BmwKYAf9cAAHHAYQBgQH/AdUBiQFOAf8B1QGF
-        AUoB/wHNAXEBRAH/AcwBbgFCAf8BzAFuAUIB/wHMAW4BQgH/Ac4BggFKAf8EAAGVAdcBlQH/AUoBzAFr
-        Af8BYQHaAYEB/wFoAd4BgQH/AW8B6wGUAf8BPgG4AVAB/wFEAcUBXgH/AXQB8AGXAf8BaAHpAYIB/wFJ
-        AdEBbwH/GAABqQGmAaUB/wH3Ae8B7AH/AeUB2QHVAf8B0wHIAcUB/wHRAcUBwQH/AdEBxQHBAf8BzwHD
+        AekB1QHOAf8B6QHVAc4B/wHpAdUBzgH/AfIB4gHcAf8BmwKYAf9cAAHHAYQBgQH/AdUBiQFMAf8B1QGF
+        AUgB/wHNAW8BQgH/AcwBbAFAAf8BzAFsAUAB/wHMAWwBQAH/Ac4BggFIAf8EAAGVAdcBlQH/AUgBzAFp
+        Af8BXwHaAYEB/wFmAd4BgQH/AW0B6wGUAf8BPAG4AU4B/wFCAcUBXAH/AXIB8AGXAf8BZgHpAYIB/wFH
+        AdEBbQH/GAABqQGmAaUB/wH3Ae8B7AH/AeUB2QHVAf8B0wHIAcUB/wHRAcUBwQH/AdEBxQHBAf8BzwHD
         AcAB/wHOAcEBvQH/Ac4BwQG9Af8BzgHBAb0B/wHNAcABuwH/Ac0BwAG7Af8BywG8AbgB/wHgAc0BxgH/
-        AfIB4gHcAf8BlgKUAf9gAAGuAUgBNQH/AeMBnwFYAf8B0gF2AUoB/wHNAXEBRAH/AcwBbgFCAf8BzQFx
-        AUQB/wHHAXUBRQH/BAABUwHDAVcB/wFcAdgBhwH/AV8B1AFzAf8BYwHmAZIB/wFBAb0BUAH/BAABgQHM
-        AYEB/wFgAeQBjgH/AWgB6AGBAf8BXwHmAYYB/wE9AbgBTQH/FAABqQGmAaUB/wH3Ae8B7AH/AfQB5wHi
+        AfIB4gHcAf8BlgKUAf9gAAGuAUYBMwH/AeMBnwFWAf8B0gF0AUgB/wHNAW8BQgH/AcwBbAFAAf8BzQFv
+        AUIB/wHHAXMBQwH/BAABUQHDAVUB/wFaAdgBhwH/AV0B1AFxAf8BYQHmAZIB/wE/Ab0BTgH/BAABgQHM
+        AYEB/wFeAeQBjgH/AWYB6AGBAf8BXQHmAYYB/wE7AbgBSwH/FAABqQGmAaUB/wH3Ae8B7AH/AfQB5wHi
         Af8B7gHeAdkB/wHuAd4B2QH/AeUB2QHVAf8B5QHZAdUB/wHlAdYB0AH/AeUB1gHQAf8B5QHWAdAB/wHk
-        AdIBzAH/AeQB0gHMAf8B5AHSAcwB/wHpAdUBzgH/AfIB4gHcAf8BmwKYAf9cAAG8AWEBQwH/AeYBogFg
-        Af8B4wGMAV8B/wHZAYEBVAH/AdIBdgFKAf8BzQFxAUQB/wHSAYEBRwH/AbYBWgE7Af8EAAGBAdABgQH/
-        AUkB0QFvAf8BVQHYAYEB/wFBAb0BUAH/DAABPQG4AU0B/wFvAesBlAH/AVsB3wFvAf8BUwHcAYEB/wFc
-        AbsBXgH/EAABqQGmAaUB/wH4AfEB7gH/AegB3wHcAf8B3gHUAdAB/wHbAdABzQH/AdsB0AHNAf8B3AHO
+        AdIBzAH/AeQB0gHMAf8B5AHSAcwB/wHpAdUBzgH/AfIB4gHcAf8BmwKYAf9cAAG8AV8BQQH/AeYBogFe
+        Af8B4wGMAV0B/wHZAYEBUgH/AdIBdAFIAf8BzQFvAUIB/wHSAYEBRQH/AbYBWAE5Af8EAAGBAdABgQH/
+        AUcB0QFtAf8BUwHYAYEB/wE/Ab0BTgH/DAABOwG4AUsB/wFtAesBlAH/AVkB3wFtAf8BUQHcAYEB/wFa
+        AbsBXAH/EAABqQGmAaUB/wH4AfEB7gH/AegB3wHcAf8B3gHUAdAB/wHbAdABzQH/AdsB0AHNAf8B3AHO
         AcoB/wHcAc4BygH/AdwBzgHKAf8B0wHIAcUB/wHgAc0BxgH/AdEBxQHBAf8B1wHIAcQB/wHkAdIBzAH/
-        AfIB4gHcAf8BmwKYAf9UAAHBAWsBUgH/AdYBigFSAf8B8gGrAXEB/wHuAZUBcAH/AecBjQFnAf8B4AGF
-        AV0B/wHZAYEBVAH/AdIBdgFKAf8B2QGKAU4B/wGxAVUBSQH/DAABlQHXAZUB/xAAAZUB1wGVAf8BTQHY
-        AXkB/wFbAeABcwH/AVEB2QFqAf8BRAHKAWgB/xAAAawBqQGoAf8B+QHyAfAB/wHuAeQB4QH/AeUB2QHV
+        AfIB4gHcAf8BmwKYAf9UAAHBAWkBUAH/AdYBigFQAf8B8gGrAW8B/wHuAZUBbgH/AecBjQFlAf8B4AGF
+        AVsB/wHZAYEBUgH/AdIBdAFIAf8B2QGKAUwB/wGxAVMBRwH/DAABlQHXAZUB/xAAAZUB1wGVAf8BSwHY
+        AXcB/wFZAeABcQH/AU8B2QFoAf8BQgHKAWYB/xAAAawBqQGoAf8B+QHyAfAB/wHuAeQB4QH/AeUB2QHV
         Af8B4QHXAdQB/wHeAdQB0AH/Ad4B1AHQAf8B2wHQAc0B/wHbAdABzQH/AdsB0AHNAf8B3AHOAcoB/wHc
-        Ac4BygH/AeABzQHGAf8B5QHWAdAB/wH0AecB4gH/AZ8CnAH/QAAB0gGPAXUB/wG/AV4BNwH/AcYBbgFA
-        Af8BzQFxAUQB/wHaAZABVAH/Ae0BpwFsAf8B7wGZAXUB/wHwAZYBdgH/AfABlgF2Af8B7gGVAXAB/wHq
-        AaUBZAH/AdoBkAFUAf8B3QGMAVQB/wHeAZcBUwH/AbwBbwFsAf8kAAFOAbwBUwH/AWAB5AGOAf8BTgHV
-        AV8B/wFNAdkBcwH/AT0BuAFNAf8MAAGsAakBqAH/AfkB8gHwAf8B9AHoAeMB/wHoAd8B3AH/AegB3wHc
+        Ac4BygH/AeABzQHGAf8B5QHWAdAB/wH0AecB4gH/AZ8CnAH/QAAB0gGPAXMB/wG/AVwBNQH/AcYBbAE+
+        Af8BzQFvAUIB/wHaAZABUgH/Ae0BpwFqAf8B7wGZAXMB/wHwAZYBdAH/AfABlgF0Af8B7gGVAW4B/wHq
+        AaUBYgH/AdoBkAFSAf8B3QGMAVIB/wHeAZcBUQH/AbwBbQFqAf8kAAFMAbwBUQH/AV4B5AGOAf8BTAHV
+        AV0B/wFLAdkBcQH/ATsBuAFLAf8MAAGsAakBqAH/AfkB8gHwAf8B9AHoAeMB/wHoAd8B3AH/AegB3wHc
         Af8B6AHfAdwB/wHlAdkB1QH/AeUB2QHVAf8B5QHZAdUB/wHlAdYB0AH/AeUB1gHQAf8B5QHWAdAB/wHb
-        AdABzQH/AewB2gHUAf8B9AHnAeIB/wGfApwB/0QAAc0BggFkAf8B1QGJAU4B/wHmAaIBYAH/Ad4BiAFm
-        Af8B4wGJAW0B/wHuAZUBcAH/Ae8BmQF1Af8B8gGrAXEB/wHdAYwBVAH/AbsBYgFNAf8BvAFvAWwB/wHV
-        AYkBTgH/AdoBkAFUAf8sAAE/AcIBVgH/AVMB3AF2Af8BQwHNAVUB/wFNAdgBeQH/AU0BtgFRAf8IAAGq
+        AdABzQH/AewB2gHUAf8B9AHnAeIB/wGfApwB/0QAAc0BggFiAf8B1QGJAUwB/wHmAaIBXgH/Ad4BiAFk
+        Af8B4wGJAWsB/wHuAZUBbgH/Ae8BmQFzAf8B8gGrAW8B/wHdAYwBUgH/AbsBYAFLAf8BvAFtAWoB/wHV
+        AYkBTAH/AdoBkAFSAf8sAAE9AcIBVAH/AVEB3AF0Af8BQQHNAVMB/wFLAdgBdwH/AUsBtgFPAf8IAAGq
         AZ0BnAH/AewB2gHUAf8B5QHZAdUB/wHsAdoB1AH/AeUB1gHQAf8B7QHXAc8B/wHlAdkB1QH/Ae0B1wHP
         Af8B5QHWAdAB/wHlAdYB0AH/AeUB1gHQAf8B5QHWAdAB/wHtAdcBzwH/AeUB1gHQAf8B5QHWAdAB/wGc
-        AZABjgH/TAABxgFwAUgB/wHQAYEBRwH/AdUBiQFOAf8B1QGJAU4B/wHNAXEBRAH/AcIBcAFYAf8MAAG9
-        AWkBXQH/AcYBbgFAAf8sAAGNAdEBjQH/AUkB0QFvAf8BRwHRAV8B/wFDAc0BVQH/AUkB0QFvAf8BcQHF
-        AXIB/wQAAb0BYgFQAf8ByAFsAVgB/wHIAWwBWAH/AcgBbAFYAf8ByAFsAVgB/wHIAWwBWAH/AcgBbAFY
-        Af8ByAFsAVgB/wHIAWwBWAH/AcgBbAFYAf8BwgFpAVYB/wHCAWYBVAH/AcIBZgFUAf8BvQFiAVAB/wG9
-        AWIBUAH/AbgBXQFLAf90AAGwAU8BQwH/MAABXQHBAV8B/wFNAdgBeQH/AUMBzQFVAf8BRwHSAWIB/wFB
-        AcYBYQH/BAABwgFmAVQB/wHRAXcBUwH/AdEBdwFTAf8B1QGAAVwB/wHVAYABXAH/AdYBgQFeAf8B0gF3
-        AVwB/wHQAXUBWQH/AcgBbAFYAf8BzwGMAXkB/wHIAYEBbwH/AcYBhAF0Af8BvgF1AWQB/wHPAZ8BlQH/
-        AbIBWQFIAf8BvQFiAVAB/6wAAUUBvAFOAf8BTQHYAXkB/wFDAc0BVQH/AU0B2AF5Af8BUgG6AVYB/wHI
-        AWwBWAH/AdEBeAFWAf8B0QF3AVMB/wHVAYABXAH/AdUBgAFcAf8B1gGBAV4B/wHWAYEBXgH/AdYBgQFe
-        Af8B1QGAAVwB/wHQAXUBWQH/AckBbQFWAf8B0gGZAYsB/wHIAYEBbwH/Ac8BlQGIAf8BvQFiAVAB/wHI
-        AWwBWAH/sAABPQG4AU0B/wFPAdsBgQH/AUkB0QFvAf8BcQHFAXIB/wQAAcgBbAFYAf8BwAFrAVkB/wHC
-        AWYBVAH/AcgBbAFYAf8ByAFsAVgB/wHAAWsBWQH/AcgBbAFYAf8BvgFnAVYB/wHCAWYBVAH/AcgBbAFY
-        Af8BvQFiAVAB/wHIAWwBWAH/Ab0BYgFQAf8BvgF1AWQB/7gAAWoBxQFqAf8BhgHOAYUB/5wAAc4CzAH/
+        AZABjgH/TAABxgFuAUYB/wHQAYEBRQH/AdUBiQFMAf8B1QGJAUwB/wHNAW8BQgH/AcIBbgFWAf8MAAG9
+        AWcBWwH/AcYBbAE+Af8sAAGNAdEBjQH/AUcB0QFtAf8BRQHRAV0B/wFBAc0BUwH/AUcB0QFtAf8BbwHF
+        AXAB/wQAAb0BYAFOAf8ByAFqAVYB/wHIAWoBVgH/AcgBagFWAf8ByAFqAVYB/wHIAWoBVgH/AcgBagFW
+        Af8ByAFqAVYB/wHIAWoBVgH/AcgBagFWAf8BwgFnAVQB/wHCAWQBUgH/AcIBZAFSAf8BvQFgAU4B/wG9
+        AWABTgH/AbgBWwFJAf90AAGwAU0BQQH/MAABWwHBAV0B/wFLAdgBdwH/AUEBzQFTAf8BRQHSAWAB/wE/
+        AcYBXwH/BAABwgFkAVIB/wHRAXUBUQH/AdEBdQFRAf8B1QGAAVoB/wHVAYABWgH/AdYBgQFcAf8B0gF1
+        AVoB/wHQAXMBVwH/AcgBagFWAf8BzwGMAXcB/wHIAYEBbQH/AcYBhAFyAf8BvgFzAWIB/wHPAZ8BlQH/
+        AbIBVwFGAf8BvQFgAU4B/6wAAUMBvAFMAf8BSwHYAXcB/wFBAc0BUwH/AUsB2AF3Af8BUAG6AVQB/wHI
+        AWoBVgH/AdEBdgFUAf8B0QF1AVEB/wHVAYABWgH/AdUBgAFaAf8B1gGBAVwB/wHWAYEBXAH/AdYBgQFc
+        Af8B1QGAAVoB/wHQAXMBVwH/AckBawFUAf8B0gGZAYsB/wHIAYEBbQH/Ac8BlQGIAf8BvQFgAU4B/wHI
+        AWoBVgH/sAABOwG4AUsB/wFNAdsBgQH/AUcB0QFtAf8BbwHFAXAB/wQAAcgBagFWAf8BwAFpAVcB/wHC
+        AWQBUgH/AcgBagFWAf8ByAFqAVYB/wHAAWkBVwH/AcgBagFWAf8BvgFlAVQB/wHCAWQBUgH/AcgBagFW
+        Af8BvQFgAU4B/wHIAWoBVgH/Ab0BYAFOAf8BvgFzAWIB/7gAAWgBxQFoAf8BhgHOAYUB/5wAAc4CzAH/
         Ac4CzAH/Ac4CzAH/Ac4CzAH/AcoByAHHAf8BzgLMAf8BygHIAccB/wHKAcgBxwH/AcoByAHHAf8QAAHI
-        AYEBaAH/AcIBbAFQAf8BxQGBAWwB/xAAAbsBbAFoAf8BsgFVAUcB/wG3AWYBZAH/JAAByQHHAcgB/wHK
+        AYEBZgH/AcIBagFOAf8BxQGBAWoB/xAAAbsBagFmAf8BsgFTAUUB/wG3AWQBYgH/JAAByQHHAcgB/wHK
         AsgB/wHKAsgB/wHJAccByAH/AckBxwHIAf8ByQHHAcgB/wHGAsUB/wHGAsUB/wHGAsUB/1wAAfoB9gH1
         Af8B9wHwAe0B/wH2Ae0B6QH/AfYB7QHpAf8B9gHtAekB/wH0AeYB4QH/AfQB5gHhAf8B9AHmAeEB/wH3
-        AfMB8gH/DAAByAF1AVgB/wHrAZUBbQH/AdgBgQFVAf8B2gGEAVUB/wG8AV4BQQH/CAABsgFVAUcB/wHM
-        AXMBRAH/AcABYgE+Af8BzAFzAUQB/wGyAVcBUgH/DAABTAGbAdsB/wE9AZEB2QH/AT0BkQHZAf8BPQGP
-        AdkB/wFAAY8B2AH/Ac0BzwHTAf8B9gHtAekB/wH0AekB5QH/AfIB5gHiAf8B8gHkAd4B/wHyAeQB3gH/
+        AfMB8gH/DAAByAFzAVYB/wHrAZUBawH/AdgBgQFTAf8B2gGEAVMB/wG8AVwBPwH/CAABsgFTAUUB/wHM
+        AXEBQgH/AcABYAE8Af8BzAFxAUIB/wGyAVUBUAH/DAABSgGbAdsB/wE7AZEB2QH/ATsBkQHZAf8BOwGP
+        AdkB/wE+AY8B2AH/Ac0BzwHTAf8B9gHtAekB/wH0AekB5QH/AfIB5gHiAf8B8gHkAd4B/wHyAeQB3gH/
         AfEB4AHaAf8B8gHkAd4B/wH0AekB5QH/XAAB+gH2AfUB/wH2Ae0B6QH/AfQB5gHhAf8B8QHfAdgB/wHv
-        AdsB1AH/Ae8B2wHUAf8B7wHbAdQB/wHuAdgB0AH/AfYB7QHpAf8MAAHSAXYBTgH/AdQBeAFSAf8EAAHC
-        AWwBUAH/AdoBhAFVAf8ByQGGAYEB/wQAAcwBcwFEAf8BtgFdAVAB/wQAAbgBVwE6Af8BswFQATgB/wgA
-        AXABsAHhAf8BcQHcAfYB/wFxAeoC/wFqAd8C/wFlAdUB/gH/AWEBzgL/AdAB0wHVAf8B9gHtAekB/wHy
+        AdsB1AH/Ae8B2wHUAf8B7wHbAdQB/wHuAdgB0AH/AfYB7QHpAf8MAAHSAXQBTAH/AdQBdgFQAf8EAAHC
+        AWoBTgH/AdoBhAFTAf8ByQGGAYEB/wQAAcwBcQFCAf8BtgFbAU4B/wQAAbgBVQE4Af8BswFOATYB/wgA
+        AW4BsAHhAf8BbwHcAfYB/wFvAeoC/wFoAd8C/wFjAdUB/gH/AV8BzgL/AdAB0wHVAf8B9gHtAekB/wHy
         AeYB4gH/AfIB5AHeAf8B7gHfAdkB/wHtAdsB1QH/Ae0B1wHQAf8B7QHXAdAB/wHwAecB5AH/WAABxwLF
         Af8B+gH2AfUB/wHlAdsB1wH/AdgBzwHNAf8B1QHLAcgB/wHTAckBxgH/AdEBxQHCAf8B0QHDAb8B/wHb
-        AcoBxQH/AfYB7QHpAf8MAAHPAXQBTAH/AdQBeAFSAf8IAAHaAYQBVQH/AcIBbAFQAf8BwgF1AWQB/wHI
-        AW4BQQH/CAABugFaATsB/wGzAVABOAH/CAABYgGqAd4B/wGAAe8B/AH/AWcB9AL/AV8B5wL/AVYB2AL/
-        AU0BygL/AdAB0wHVAf8B9AHpAeUB/wHcAdQB0gH/AdkB0AHNAf8B2QHOAcsB/wHXAcsByAH/AdUByAHE
-        Af8B4wHSAcwB/wH0AekB5QH/BAABvgFlAU8B/wHAAWUBPwH/Ab4BZAE/Af8BvgFkAT8B/wG5AV0BQAH/
-        AbkBXQFAAf8BtwFZAUAB/wG0AVcBQQH/AbQBVwFBAf8BqAFEAUMB/xgAAcEBvwG+Af8B3QHYAdYB/wHa
+        AcoBxQH/AfYB7QHpAf8MAAHPAXIBSgH/AdQBdgFQAf8IAAHaAYQBUwH/AcIBagFOAf8BwgFzAWIB/wHI
+        AWwBPwH/CAABugFYATkB/wGzAU4BNgH/CAABYAGqAd4B/wGAAe8B/AH/AWUB9AL/AV0B5wL/AVQB2AL/
+        AUsBygL/AdAB0wHVAf8B9AHpAeUB/wHcAdQB0gH/AdkB0AHNAf8B2QHOAcsB/wHXAcsByAH/AdUByAHE
+        Af8B4wHSAcwB/wH0AekB5QH/BAABvgFjAU0B/wHAAWMBPQH/Ab4BYgE9Af8BvgFiAT0B/wG5AVsBPgH/
+        AbkBWwE+Af8BtwFXAT4B/wG0AVUBPwH/AbQBVQE/Af8BqAFCAUEB/xgAAcEBvwG+Af8B3QHYAdYB/wHa
         AdUB1AH/AdoB1QHUAf8B2gHVAdQB/wHFAcABvwH/AfoB9gH1Af8B8AHoAeUB/wHoAeEB3gH/Ae4B5QHi
-        Af8B5QHbAdcB/wHjAdcB0wH/AeIB1AHPAf8B5gHWAdAB/wH2Ae0B6QH/DAAB0AGIAWoB/wHlAZABaQH/
-        AckBeQFcAf8BywGEAW4B/wHkAY0BYwH/AcgBagFGAf8BvAFeAUEB/wHMAXMBRAH/Ab8BcQFnAf8BuAFj
-        AVYB/wHMAXMBRAH/AbsBbAFoAf8IAAFiAaoB3gH/AYEB8AH8Af8BbgH9Av8BZwH0Av8BXwHnAv8BVgHY
+        Af8B5QHbAdcB/wHjAdcB0wH/AeIB1AHPAf8B5gHWAdAB/wH2Ae0B6QH/DAAB0AGIAWgB/wHlAZABZwH/
+        AckBdwFaAf8BywGEAWwB/wHkAY0BYQH/AcgBaAFEAf8BvAFcAT8B/wHMAXEBQgH/Ab8BbwFlAf8BuAFh
+        AVQB/wHMAXEBQgH/AbsBagFmAf8IAAFgAaoB3gH/AYEB8AH8Af8BbAH9Av8BZQH0Av8BXQHnAv8BVAHY
         Av8B0AHTAdUB/wHwAekB5gH/AdwB1AHSAf8B5AHdAdoB/wHhAdgB1QH/AdwB1AHSAf8B2QHQAc0B/wHk
-        AdYB0QH/AfYB7QHpAf8EAAHIAYEBaAH/AfABsQFtAf8B8QGhAXUB/wHxAaEBdQH/AfIBpgFyAf8B7wGj
-        AW0B/wHqAZ0BZQH/AeoBpwFgAf8BwAFqAUEB/xwAAcoByAHHAf8B6AHhAd4B/wHqAdwB2AH/Ae8B2wHU
+        AdYB0QH/AfYB7QHpAf8EAAHIAYEBZgH/AfABsQFrAf8B8QGhAXMB/wHxAaEBcwH/AfIBpgFwAf8B7wGj
+        AWsB/wHqAZ0BYwH/AeoBpwFeAf8BwAFoAT8B/xwAAcoByAHHAf8B6AHhAd4B/wHqAdwB2AH/Ae8B2wHU
         Af8B5gHWAdAB/wHMAcEBvQH/AfoB9gH1Af8B9gHtAekB/wHoAeEB3gH/AfYB7QHpAf8B2gHVAdQB/wHu
-        AeUB4gH/AegB4QHeAf8B2AHPAc0B/wH4AfAB7QH/EAAB0gF4AU4B/wHpAZIBcAH/AesBlQFtAf8B8AGa
-        AXIB/wHYAYEBVQH/AcwBcAFIAf8B2gGEAVUB/wHMAXMBRAH/AcwBcwFEAf8BugFaATsB/wwAAWIBqgHe
-        Af8BgQHwAfwB/wFuAf0C/wFuAf0C/wFnAfQC/wFfAecC/wHTAdcB2AH/AfYB7QHpAf8B8AHnAeQB/wHw
+        AeUB4gH/AegB4QHeAf8B2AHPAc0B/wH4AfAB7QH/EAAB0gF2AUwB/wHpAZIBbgH/AesBlQFrAf8B8AGa
+        AXAB/wHYAYEBUwH/AcwBbgFGAf8B2gGEAVMB/wHMAXEBQgH/AcwBcQFCAf8BugFYATkB/wwAAWABqgHe
+        Af8BgQHwAfwB/wFsAf0C/wFsAf0C/wFlAfQC/wFdAecC/wHTAdcB2AH/AfYB7QHpAf8B8AHnAeQB/wHw
         AekB5gH/AeQB3QHaAf8B9gHtAekB/wH0AekB5QH/AdwB1AHSAf8B9gHtAekB/wQAAdcBoAGRAf8B4wGc
-        AV8B/wHrAZABdAH/AesBkAF0Af8B8AGYAXUB/wHvAZUBcwH/Ae0BmQFtAf8B0wGHAU8B/wHMAY8BiwH/
+        AV0B/wHrAZABcgH/AesBkAFyAf8B8AGYAXMB/wHvAZUBcQH/Ae0BmQFrAf8B0wGHAU0B/wHMAY8BiwH/
         HAABygHIAccB/wHwAegB5QH/AdUBywHIAf8B0wHJAcYB/wHKAcgBxwH/AcEBuQG2Af8B+gH2AfUB/wHl
         AdsB1wH/AdgB0QHPAf8B5QHbAdcB/wHdAdgB1gH/AfgB8AHtAf8B+AHwAe0B/wHiAdQBzwH/AfoB9gH1
-        Af8UAAHOAYEBXgH/Ac4BgQFeAf8BwAFmAUcB/wHtAZ0BbQH/AegBmAFlAf8BvAFeAUEB/wHDAXIBWwH/
-        Ab8BbQFXAf8QAAFiAbIB3gH/AYAB7wH8Af8BbgH9Av8BbgH9Av8BbgH9Av8BZwH0Av8B0wHXAdgB/wH2
+        Af8UAAHOAYEBXAH/Ac4BgQFcAf8BwAFkAUUB/wHtAZ0BawH/AegBmAFjAf8BvAFcAT8B/wHDAXABWQH/
+        Ab8BawFVAf8QAAFgAbIB3gH/AYAB7wH8Af8BbAH9Av8BbAH9Av8BbAH9Av8BZQH0Av8B0wHXAdgB/wH2
         Ae0B6QH/AeQB3QHaAf8B8AHnAeQB/wHfAdgB1gH/AfgB8AHtAf8B+AHwAe0B/wHhAdgB1QH/AfUB8AHu
-        Af8IAAHYAYwBUQH/AegBjQFxAf8B6wGQAXQB/wHwAZUBdgH/AfABlQF2Af8B8gGuAW4B/wGvAUoBOAH/
+        Af8IAAHYAYwBTwH/AegBjQFvAf8B6wGQAXIB/wHwAZUBdAH/AfABlQF0Af8B8gGuAWwB/wGvAUgBNgH/
         IAABygHIAccB/wHwAegB5QH/AegB4QHeAf8B5QHbAdcB/wHjAdcB0wH/AcoByAHHAf8B+gH2AfUB/wH2
         Ae0B6QH/AegB4QHeAf8B9gHtAekB/wHaAdUB1AH/AfQB5gHhAf8B7gHlAeIB/wHaAdUB1AH/AfoB9gH1
-        Af8cAAG6AYoBgQH/AckBiwF5Af8BxwGJAXgB/wG0AYQBeQH/GAABYgGqAd4B/wGAAecB/AH/AW4B8wL/
-        AW4B/QL/AW4B/QL/AW4B/QL/AdMC2AH/AfAB6QHmAf8B3AHUAdIB/wHkAd0B2gH/Ad8B2AHWAf8B3wHY
-        AdYB/wHcAdQB0gH/AecB4AHeAf8B9QHxAfAB/wgAAc4BgQFFAf8B4gGMAWoB/wHoAY0BcQH/AesBkAF0
-        Af8B8AGVAXYB/wHxAZ0BdQH/AecBowFiAf8BuQFdAUAB/xwAAc4CzAH/Ae4B5QHiAf8B1QHLAcgB/wHV
+        Af8cAAG6AYoBgQH/AckBiwF3Af8BxwGJAXYB/wG0AYQBdwH/GAABYAGqAd4B/wGAAecB/AH/AWwB8wL/
+        AWwB/QL/AWwB/QL/AWwB/QL/AdMC2AH/AfAB6QHmAf8B3AHUAdIB/wHkAd0B2gH/Ad8B2AHWAf8B3wHY
+        AdYB/wHcAdQB0gH/AecB4AHeAf8B9QHxAfAB/wgAAc4BgQFDAf8B4gGMAWgB/wHoAY0BbwH/AesBkAFy
+        Af8B8AGVAXQB/wHxAZ0BcwH/AecBowFgAf8BuQFbAT4B/xwAAc4CzAH/Ae4B5QHiAf8B1QHLAcgB/wHV
         AcsByAH/AdoB1QHUAf8BwQG5AbYB/wH6AfYB9QH/Ae4B5QHiAf8B6AHhAd4B/wHuAeUB4gH/Ae4B5QHi
         Af8B5QHbAdcB/wHoAeEB3gH/Ae4B5QHiAf8B9wHzAfIB/xgAAbkBtQG0Af8B6AHcAdcB/wHSAckBxgH/
-        AdIByQHGAf8B5QHXAdMB/wG1ArIB/xQAAWIBsgHeAf8BgAHnAfwB/wFsAeoC/wFuAfMC/wFuAf0C/wFu
+        AdIByQHGAf8B5QHXAdMB/wG1ArIB/xQAAWABsgHeAf8BgAHnAfwB/wFqAeoC/wFsAfMC/wFsAf0C/wFs
         Af0C/wHTAtgB/wH4AfAB7QH/AfgB8AHtAf8B+AHwAe0B/wH4AfAB7QH/AfgB8AHtAf8B9gHtAekB/wHZ
-        AdABzQH/AdwB1AHSAf8IAAHGAXABRQH/AeABkAFmAf8B4AGDAWsB/wHoAY0BcQH/AesBkAF0Af8B8AGV
-        AXYB/wHwAZgBdQH/AfIBpgFyAf8BzwGBAUwB/wG5AWIBVAH/FAABzgLMAf8B7gHlAeIB/wHaAdUB1AH/
+        AdABzQH/AdwB1AHSAf8IAAHGAW4BQwH/AeABkAFkAf8B4AGDAWkB/wHoAY0BbwH/AesBkAFyAf8B8AGV
+        AXQB/wHwAZgBcwH/AfIBpgFwAf8BzwGBAUoB/wG5AWABUgH/FAABzgLMAf8B7gHlAeIB/wHaAdUB1AH/
         AdUBzgHMAf8B3QHYAdYB/wHFAcABvwH/AfoB9gH1Af8B9wHwAe0B/wH4AfAB7QH/AfoB9gH1Af8B9gHt
         AekB/wH6AfYB9QH/AeUB2wHXAf8BwAK6Af8BwQG/Ab4B/xgAAdQBzAHKAf8B6gHeAdoB/wG5AbUBtAH/
-        AbkBtQG0Af8B6AHcAdcB/wHRAccBxQH/FAABYgGyAd4B/wF1AdgB/AH/AWoB3wL/AWwB6gL/AW4B8wL/
-        AW4B/QL/AdMB1wHYAf8B+AHwAe0B/wH4AfAB7QH/AfgB8AHtAf8B+AHwAe0B/wH1AfAB7gH/AdwB1AHS
-        Af8ByQHHAcgB/wGrAqgB/wgAAcsBgQFjAf8B4AGYAWEB/wHgAZABZgH/Ad0BlwFYAf8B7QGnAW0B/wHu
-        AZUBdgH/AfABmAF1Af8B7wGVAXMB/wHtAZkBbQH/AeoBpwFgAf8B1QGIAVAB/wG+AWQBPwH/AbUBVgE+
-        Af8BpQE7ATMB/wHEAoEB/wHOAswB/wHwAegB5QH/AeUB2wHXAf8B6AHhAd4B/wHlAdsB1wH/AcUBwAG/
+        AbkBtQG0Af8B6AHcAdcB/wHRAccBxQH/FAABYAGyAd4B/wFzAdgB/AH/AWgB3wL/AWoB6gL/AWwB8wL/
+        AWwB/QL/AdMB1wHYAf8B+AHwAe0B/wH4AfAB7QH/AfgB8AHtAf8B+AHwAe0B/wH1AfAB7gH/AdwB1AHS
+        Af8ByQHHAcgB/wGrAqgB/wgAAcsBgQFhAf8B4AGYAV8B/wHgAZABZAH/Ad0BlwFWAf8B7QGnAWsB/wHu
+        AZUBdAH/AfABmAFzAf8B7wGVAXEB/wHtAZkBawH/AeoBpwFeAf8B1QGIAU4B/wG+AWIBPQH/AbUBVAE8
+        Af8BpQE5ATEB/wHEAoEB/wHOAswB/wHwAegB5QH/AeUB2wHXAf8B6AHhAd4B/wHlAdsB1wH/AcUBwAG/
         Af8B+gH2AfUB/wH4AfAB7QH/AfgB8AHtAf8B+AHwAe0B/wH4AfAB7QH/AfgB8AHtAf8B1QHOAcwB/wHa
         AdgB2QH/AbMCsAH/FAABuQG1AbQB/wH0AegB4wH/AbkBtQG0Af8IAAG0AbABrwH/AfIB4wHdAf8BtAGw
-        Aa8B/xAAAWIBsgHeAf8BdQHYAfwB/wFlAdUB/gH/AWoB3wL/AWwB6gL/AW4B8wL/AdMC2AH/AfkB9QHz
+        Aa8B/xAAAWABsgHeAf8BcwHYAfwB/wFjAdUB/gH/AWgB3wL/AWoB6gL/AWwB8wL/AdMC2AH/AfkB9QHz
         Af8B+QH1AfMB/wH5AfUB8wH/AfkB9QHzAf8B+QH1AfMB/wHfAdoB2QH/AbUBsQGyAf8MAAHYAZ8BigH/
-        Ad0BlwFYAf8B1gGLAU8B/wHNAYYBcAH/AcMBbAFKAf8B3QGXAVgB/wHyAaYBcgH/AfMBpgF1Af8B8QGd
-        AXUB/wHrAZABdAH/AeABkAFmAf8B6gGpAWAB/wHMAYEBSAH/Ab0BcAFqAf8EAAHOAswB/wHwAegB5QH/
+        Ad0BlwFWAf8B1gGLAU0B/wHNAYYBbgH/AcMBagFIAf8B3QGXAVYB/wHyAaYBcAH/AfMBpgFzAf8B8QGd
+        AXMB/wHrAZABcgH/AeABkAFkAf8B6gGpAV4B/wHMAYEBRgH/Ab0BbgFoAf8EAAHOAswB/wHwAegB5QH/
         AdUBywHIAf8BzgLMAf8B4wHXAdMB/wHHAsUB/wH6AfYB9QH/AfoB9gH1Af8B+gH2AfUB/wH6AfYB9QH/
         AfoB9gH1Af8B+wL5Af8B2gHVAdQB/wGzArAB/xgAAeEB2QHWAf8B1AHMAcoB/xAAAdIByQHGAf8B3gHU
-        AdAB/xAAAWIBsgHeAf8BdAHUAfwB/wFhAc4C/wFlAdUB/gH/AWQB1gHzAf8BZgHfAfIB/wGJAcYBzQH/
-        AZABzAHOAf8BjwLOAf8BkALQAf8BkAHVAdgB/wGEAbUBzQH/AasBuQHHAf8UAAHOAYEBRQH/Ac0BgwFo
-        Af8MAAHDAXABVAH/AcoBdgFGAf8B1QGIAVAB/wHWAYsBTwH/Ac4BgQFFAf8BuAFeAUoB/wwAAc4CzAH/
+        AdAB/xAAAWABsgHeAf8BcgHUAfwB/wFfAc4C/wFjAdUB/gH/AWIB1gHzAf8BZAHfAfIB/wGJAcYBzQH/
+        AZABzAHOAf8BjwLOAf8BkALQAf8BkAHVAdgB/wGEAbUBzQH/AasBuQHHAf8UAAHOAYEBQwH/Ac0BgwFm
+        Af8MAAHDAW4BUgH/AcoBdAFEAf8B1QGIAU4B/wHWAYsBTQH/Ac4BgQFDAf8BuAFcAUgB/wwAAc4CzAH/
         AfAB6AHlAf8B8AHoAeUB/wHwAegB5QH/Ae4B5QHiAf8B3QHYAdYB/wHVAcsByAH/AcEBvwG+Af8BtQGx
-        AbAB/wGzArAB/yQAAb0CuQH/Ae4B5gHjAf8BvQK5Af8QAAG1ArIB/wHsAeEB3AH/AbQBsAGvAf8MAAFi
-        AbIB3gH/AXQB1AH8Af8BYQHOAv8BagG1AdcB/wFlAZoBqQH/AWUBmgGpAf8BZQGeAacB/wFlAaEBpQH/
-        AWUBoQGlAf8BWAK2Af8BaQHzAfUB/wFRAboB6AH/GAABwwFsAUoB/zQAAc4CzAH/Ae4B5QHiAf8B8AHo
+        AbAB/wGzArAB/yQAAb0CuQH/Ae4B5gHjAf8BvQK5Af8QAAG1ArIB/wHsAeEB3AH/AbQBsAGvAf8MAAFg
+        AbIB3gH/AXIB1AH8Af8BXwHOAv8BaAG1AdcB/wFjAZoBqQH/AWMBmgGpAf8BYwGeAacB/wFjAaEBpQH/
+        AWMBoQGlAf8BVgK2Af8BZwHzAfUB/wFPAboB6AH/GAABwwFqAUgB/zQAAc4CzAH/Ae4B5QHiAf8B8AHo
         AeUB/wHuAeUB4gH/AfAB6AHlAf8B8AHoAeUB/wHuAeUB4gH/AbUBsQGwAf8BwQG/Ab4B/wGjAqAB/yQA
-        AcsBxgHFAf8BwAG7AboB/xgAAbkBtQG0Af8BwAG7AboB/wwAAWoBtwHfAf8BdAHUAfwB/wFpAc4C/wGf
-        AagBrgH/AbwCugH/AbECrwH/AasCqAH/AbECrwH/AbECrwH/AXYBqAGqAf8BdAH3AfoB/wFNAbUB5QH/
+        AcsBxgHFAf8BwAG7AboB/xgAAbkBtQG0Af8BwAG7AboB/wwAAWgBtwHfAf8BcgHUAfwB/wFnAc4C/wGf
+        AagBrgH/AbwCugH/AbECrwH/AasCqAH/AbECrwH/AbECrwH/AXQBqAGqAf8BcgH3AfoB/wFLAbUB5QH/
         UAABzgLMAf8B7wHqAegB/wHvAeoB6AH/Ae8B6gHoAf8B8AHoAeUB/wHvAeoB6AH/Ae8B6gHoAf8BwQG/
-        Ab4B/wGzArAB/ygAAbkBtQG0Af8gAAG0AbABrwH/EAABNAGgAdYB/wEwAaMB2QH/AU8BmAG9Af8BxgLF
-        Af8B3wHaAdkB/wHfAdoB2QH/Ad8B2gHZAf8BnAGeAaEB/wEvAYUBtwH/ATEBnAHYAf8BVAGkAdwB/1QA
+        Ab4B/wGzArAB/ygAAbkBtQG0Af8gAAG0AbABrwH/EAABMgGgAdYB/wEuAaMB2QH/AU0BmAG9Af8BxgLF
+        Af8B3wHaAdkB/wHfAdoB2QH/Ad8B2gHZAf8BnAGeAaEB/wEtAYUBtwH/AS8BnAHYAf8BUgGkAdwB/1QA
         Ac4CzAH/Ac4CzAH/AcgCxgH/AcgCxgH/Ac4CzAH/AccCxQH/AcACugH/LAABwAG7AboB/yAAAbUCsgH/
         HAABtQGxAbIB/wG1AbEBsgH/AbUBsQGyAf8BsQKvAf8BqwKoAf9cAAFCAU0BPgcAAT4DAAEoAwABQAMA
         ASADAAEBAQABAQYAAQEWAAP/AQAC/wH5A/8CAAL/AfAB/wGAAQECAAL/AeABfwQAAfwBAAHAAX8EAAH+
@@ -753,6 +759,12 @@
   <data name="&gt;&gt;toolbarImages.Type" xml:space="preserve">
     <value>System.Windows.Forms.ImageList, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </data>
+  <data name="&gt;&gt;toolStripLabel1.Name" xml:space="preserve">
+    <value>toolStripLabel1</value>
+  </data>
+  <data name="&gt;&gt;toolStripLabel1.Type" xml:space="preserve">
+    <value>System.Windows.Forms.ToolStripLabel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </data>
     <value>XmlEditorControl</value>
   </data>
More information about the mapguide-commits mailing list
