[mapguide-commits] r4277 - in trunk/MgDev: Common/Foundation/System
Common/MapGuideCommon/Services Server/src/Common/Base
Server/src/Core
svn_mapguide at osgeo.org
Fri Oct 2 12:28:32 EDT 2009
Author: brucedechant
Date: 2009-10-02 12:28:31 -0400 (Fri, 02 Oct 2009)
New Revision: 4277
trunk/MgDev/Common/Foundation/System/StreamHelper.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionImp.cpp
trunk/MgDev/Common/MapGuideCommon/Services/SiteConnection.cpp
trunk/MgDev/Common/MapGuideCommon/Services/SiteConnection.h
trunk/MgDev/Server/src/Common/Base/ClientHandler.cpp
trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp
trunk/MgDev/Server/src/Common/Base/ServiceOperation.h
trunk/MgDev/Server/src/Core/TimedEventHandler.cpp
Fix for trac ticket 1110 - Stability improvements
http://trac.osgeo.org/mapguide/ticket/1110
Notes:
- Added check for 0 length strings
- Added missing stream close_writer(), close_reader() and close() methods.
Note: This sometimes caused a TCP/IP mismatch error even though web and server were the same.
- Removed unused TLS
- Adjusted guards around thread data
Modified: trunk/MgDev/Common/Foundation/System/StreamHelper.cpp
--- trunk/MgDev/Common/Foundation/System/StreamHelper.cpp 2009-09-30 22:59:49 UTC (rev 4276)
+++ trunk/MgDev/Common/Foundation/System/StreamHelper.cpp 2009-10-02 16:28:31 UTC (rev 4277)
@@ -79,6 +79,13 @@
if (mssDone != stat) return stat;
+ // Check for 0 length string
+ if(len == 0)
+ wcStr = L"";
+ return stat;
UINT8 currSize = sizeof(wchar_t);
if (currSize == charSize)
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionImp.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionImp.cpp 2009-09-30 22:59:49 UTC (rev 4276)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionImp.cpp 2009-10-02 16:28:31 UTC (rev 4277)
@@ -105,7 +105,14 @@
int err = ACE_OS::last_error();
MG_UNUSED_ARG(err);
- // Could not connect
+ // We failed to connect so we must clean this up differently then just relying on the
+ // desturctor because the Disconnect() method called by the destructor will try and
+ // send a control packet which we don't want.
+ mServer->close_writer();
+ mServer->close_reader();
+ mServer->close();
delete mServer;
mServer = NULL;
return false;
@@ -149,6 +156,7 @@
// Long enough. Bail.
mServer->close();
delete mServer;
Modified: trunk/MgDev/Common/MapGuideCommon/Services/SiteConnection.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/SiteConnection.cpp 2009-09-30 22:59:49 UTC (rev 4276)
+++ trunk/MgDev/Common/MapGuideCommon/Services/SiteConnection.cpp 2009-10-02 16:28:31 UTC (rev 4277)
@@ -21,8 +21,6 @@
#undef CreateService
#endif
-static ACE_thread_key_t g_threadLocalSiteConnection = 0;
/// <summary>
/// Creates a site connection. The local site defined
@@ -572,55 +570,6 @@
return site.Detach();
-///<summary>
-///Sets the site connection for the current thread. This
-///function uses thread local storage.
-///</summary>
-void MgSiteConnection::SetCurrentConnection(MgSiteConnection* siteConnection)
- if (0 == g_threadLocalSiteConnection)
- // Perform Double-Checked Locking Optimization.
- ACE_MT (ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, *ACE_Static_Object_Lock::instance ()));
- if (ACE_OS::thr_keycreate(&g_threadLocalSiteConnection, NULL) < 0)
- g_threadLocalSiteConnection = 0;
- if (0 != g_threadLocalSiteConnection)
- ACE_OS::thr_setspecific(g_threadLocalSiteConnection, siteConnection);
-///<summary>
-///Gets the site connection for the current thread which was
-///set previously using SetCurrentConnection. This
-///</summary>
-MgSiteConnection* MgSiteConnection::GetCurrentConnection()
- MgSiteConnection* connection = NULL;
- ACE_OS::thr_getspecific(g_threadLocalSiteConnection, (void**) &connection);
- if (NULL == connection)
- // No site connection means that we not have opened the connection to the site server yet.
- throw new MgConnectionNotOpenException(L"MgSiteConnection.GetCurrentConnection", __LINE__, __WFILE__, NULL, L"", NULL);
- return connection;
MgUserInformation* MgSiteConnection::GetUserInfo()
if (NULL == m_connProp.p)
Modified: trunk/MgDev/Common/MapGuideCommon/Services/SiteConnection.h
--- trunk/MgDev/Common/MapGuideCommon/Services/SiteConnection.h 2009-09-30 22:59:49 UTC (rev 4276)
+++ trunk/MgDev/Common/MapGuideCommon/Services/SiteConnection.h 2009-10-02 16:28:31 UTC (rev 4277)
@@ -269,33 +269,6 @@
/// \brief
- /// Sets the site connection for the current thread. This
- /// function uses thread local storage.
- /// \param siteConnection
- /// Site connection to assign to the current thread
- /// \return
- /// Nothing
- static void SetCurrentConnection(MgSiteConnection* siteConnection);
- /// \brief
- /// Gets the site connection for the current thread which was
- /// set previously using SetCurrentConnection. This
- /// \return
- /// Site connection for currently executing thread
- /// \exception MgConnectionNotOpenException if the site connection has not been set
- static MgSiteConnection* GetCurrentConnection();
- /// \brief
/// Gets the user info for this site
/// \return
Modified: trunk/MgDev/Server/src/Common/Base/ClientHandler.cpp
--- trunk/MgDev/Server/src/Common/Base/ClientHandler.cpp 2009-09-30 22:59:49 UTC (rev 4276)
+++ trunk/MgDev/Server/src/Common/Base/ClientHandler.cpp 2009-10-02 16:28:31 UTC (rev 4277)
@@ -76,6 +76,7 @@
// clearing out buffer
+ m_SockStream.close_reader();
m_SockStream.close();
m_pMessageQueue = NULL;
@@ -199,6 +200,8 @@
stream->WriteObject(mgException);
stream->WriteStreamEnd();
+ m_SockStream.close_writer();
@@ -258,6 +261,8 @@
mask = ACE_Event_Handler::ALL_EVENTS_MASK | ACE_Event_Handler::DONT_CALL;
reactor()->remove_handler(this, mask);
MgServerManager* pServerManager = MgServerManager::GetInstance();
Modified: trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp
--- trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp 2009-09-30 22:59:49 UTC (rev 4276)
+++ trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp 2009-10-02 16:28:31 UTC (rev 4277)
@@ -62,6 +62,7 @@
m_currConnection->SetSessionId(L"");
+ m_currConnection = NULL;
MgUserInformation::SetCurrentUserInfo(NULL);
@@ -152,6 +153,7 @@
void MgServiceOperation::Initialize(MgStreamData* data,
const MgOperationPacket& packet)
+ ACE_MT(ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, m_mutex));
ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) MgServiceOperation::Init()\n" )));
ACE_ASSERT(NULL != data);
@@ -206,6 +208,7 @@
bool MgServiceOperation::HandleException(MgException* except)
+ ACE_MT(ACE_GUARD_RETURN(ACE_Recursive_Thread_Mutex, ace_mon, m_mutex, false));
ACE_ASSERT(!m_opCompleted);
MG_TRY()
@@ -267,6 +270,7 @@
void MgServiceOperation::EndExecution()
ACE_DEBUG((LM_DEBUG, ACE_TEXT(" (%t) MgServiceOperation::EndExecution()\n" )));
ACE_ASSERT(m_argsRead && !m_opCompleted && m_stream != NULL && NULL != m_currConnection);
@@ -276,7 +280,6 @@
ACE_ASSERT(NULL != serverStreamData);
Ptr<MgClientHandler> clientHandler = serverStreamData->GetClientHandler();
ACE_ASSERT(NULL != clientHandler.p);
- ACE_MT(ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, clientHandler.p->m_mutex));
MgService* service = GetService();
assert(NULL != service);
@@ -311,6 +314,7 @@
void MgServiceOperation::EndExecution(bool value)
@@ -320,7 +324,6 @@
@@ -357,6 +360,7 @@
void MgServiceOperation::EndExecution(INT32 value)
@@ -366,7 +370,6 @@
@@ -403,6 +406,7 @@
void MgServiceOperation::EndExecution(INT64 value)
@@ -412,7 +416,6 @@
@@ -449,6 +452,7 @@
void MgServiceOperation::EndExecution(STRING value)
@@ -458,7 +462,6 @@
@@ -495,6 +498,7 @@
void MgServiceOperation::EndExecution(MgSerializable* obj)
// ACE_ASSERT(NULL != obj);
@@ -505,7 +509,6 @@
@@ -542,6 +545,7 @@
void MgServiceOperation::EndExecution(MgStringCollection* stringCollection)
// ACE_ASSERT(NULL != stringCollection);
@@ -552,7 +556,6 @@
@@ -589,6 +592,7 @@
void MgServiceOperation::EndExecution(MgException* except)
ACE_ASSERT(NULL != except && m_argsRead && !m_opCompleted && m_stream != NULL);
@@ -598,7 +602,6 @@
if (NULL != m_currConnection)
Modified: trunk/MgDev/Server/src/Common/Base/ServiceOperation.h
--- trunk/MgDev/Server/src/Common/Base/ServiceOperation.h 2009-09-30 22:59:49 UTC (rev 4276)
+++ trunk/MgDev/Server/src/Common/Base/ServiceOperation.h 2009-10-02 16:28:31 UTC (rev 4277)
@@ -89,6 +89,7 @@
private:
bool m_opCompleted;
+ ACE_Recursive_Thread_Mutex m_mutex;
/// Inline Methods
Modified: trunk/MgDev/Server/src/Core/TimedEventHandler.cpp
--- trunk/MgDev/Server/src/Core/TimedEventHandler.cpp 2009-09-30 22:59:49 UTC (rev 4276)
+++ trunk/MgDev/Server/src/Core/TimedEventHandler.cpp 2009-10-02 16:28:31 UTC (rev 4277)
@@ -35,7 +35,6 @@
MgTimedEventHandler::~MgTimedEventHandler()
- MgUserInformation::SetCurrentUserInfo(NULL);
More information about the mapguide-commits
