[mapguide-commits] r4280 - trunk/MgDev/Common/MapGuideCommon/System
svn_mapguide at osgeo.org
Fri Oct 2 15:54:41 EDT 2009
Author: brucedechant
Date: 2009-10-02 15:54:40 -0400 (Fri, 02 Oct 2009)
New Revision: 4280
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
Code cleanup
Notes:
- Change the extra worker thread pool size from 10 to 1 instead of removing the code as this additional thread pool is not used at this time, but is consuming resources.
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2009-10-02 17:55:48 UTC (rev 4279)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2009-10-02 19:54:40 UTC (rev 4280)
@@ -158,7 +158,7 @@
const STRING MgConfigProperties::GeneralPropertyWmsDocumentPath = L"WmsDocumentPath";
const STRING MgConfigProperties::DefaultGeneralPropertyWmsDocumentPath = L"Wms/";
const STRING MgConfigProperties::GeneralPropertyWorkerThreadPoolSize = L"WorkerThreadPoolSize"; // for internal use only
-const INT32 MgConfigProperties::DefaultGeneralPropertyWorkerThreadPoolSize = 10;
+const INT32 MgConfigProperties::DefaultGeneralPropertyWorkerThreadPoolSize = 1;
const STRING MgConfigProperties::GeneralPropertyRenderer = L"Renderer";
const STRING MgConfigProperties::DefaultGeneralPropertyRenderer = L"GD";
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2009-10-02 17:55:48 UTC (rev 4279)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.h 2009-10-02 19:54:40 UTC (rev 4280)
@@ -133,7 +133,7 @@
INTERNAL_API:
static const STRING GeneralPropertyWorkerThreadPoolSize; /// value("WorkerThreadPoolSize")
- static const INT32 DefaultGeneralPropertyWorkerThreadPoolSize; /// value(10)
+ static const INT32 DefaultGeneralPropertyWorkerThreadPoolSize; /// value(1)
EXTERNAL_API:
More information about the mapguide-commits
