[mapguide-commits] r4289 - in trunk/MgDev/Server/src: Common/Base
UnitTesting
svn_mapguide at osgeo.org
Wed Oct 7 17:05:52 EDT 2009
Author: brucedechant
Date: 2009-10-07 17:05:51 -0400 (Wed, 07 Oct 2009)
New Revision: 4289
trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp
trunk/MgDev/Server/src/UnitTesting/TestKmlService.cpp
trunk/MgDev/Server/src/UnitTesting/TestMappingService.cpp
trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp
trunk/MgDev/Server/src/UnitTesting/TestTileService.cpp
Fix for trac ticket 1110 - Stability improvements
http://trac.osgeo.org/mapguide/ticket/1110
Notes:
- Update usage of SetCurrentUserInfo() because of the TLS now having a copy of the MgUserInformation
Modified: trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp
--- trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp 2009-10-07 19:08:19 UTC (rev 4288)
+++ trunk/MgDev/Server/src/Common/Base/ServiceOperation.cpp 2009-10-07 21:05:51 UTC (rev 4289)
@@ -176,6 +176,10 @@
Ptr<MgUserInformation> currUserInfo = dynamic_cast<MgUserInformation*>(m_stream->GetObject());
assert(currUserInfo != NULL);
+ // Update the API version
+ currUserInfo->SetApiVersion(m_packet.m_OperationVersion);
+ // Set the current MgUserInformation - this makes a TLS copy of the MgUserInformation object
MgUserInformation::SetCurrentUserInfo(currUserInfo);
m_packet.m_UserInfo = NULL;
@@ -185,7 +189,6 @@
m_currConnection->SetUserName(currUserInfo->GetUserName());
m_currConnection->SetSessionId(currUserInfo->GetMgSessionId());
m_currConnection->SetCurrentOperationStatus(MgConnection::OpUnknown);
- currUserInfo->SetApiVersion(m_packet.m_OperationVersion);
// Decrement number of arguments since we have pulled the first one.
m_packet.m_NumArguments--;
Modified: trunk/MgDev/Server/src/UnitTesting/TestKmlService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestKmlService.cpp 2009-10-07 19:08:19 UTC (rev 4288)
+++ trunk/MgDev/Server/src/UnitTesting/TestKmlService.cpp 2009-10-07 21:05:51 UTC (rev 4289)
@@ -48,12 +48,18 @@
Ptr<MgUserInformation> userInfo = new MgUserInformation(
L"Administrator", L"admin");
userInfo->SetLocale(TEST_LOCALE);
+ // This must be done before calling CreateSession()
MgUserInformation::SetCurrentUserInfo(userInfo);
STRING session = svcSite->CreateSession();
assert(!session.empty());
userInfo->SetMgSessionId(session);
+ MgUserInformation::SetCurrentUserInfo(userInfo);
m_siteConnection = new MgSiteConnection();
m_siteConnection->Open(userInfo);
Modified: trunk/MgDev/Server/src/UnitTesting/TestMappingService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestMappingService.cpp 2009-10-07 19:08:19 UTC (rev 4288)
+++ trunk/MgDev/Server/src/UnitTesting/TestMappingService.cpp 2009-10-07 21:05:51 UTC (rev 4289)
@@ -50,12 +50,18 @@
Modified: trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp 2009-10-07 19:08:19 UTC (rev 4288)
+++ trunk/MgDev/Server/src/UnitTesting/TestRenderingService.cpp 2009-10-07 21:05:51 UTC (rev 4289)
@@ -50,12 +50,18 @@
Modified: trunk/MgDev/Server/src/UnitTesting/TestTileService.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestTileService.cpp 2009-10-07 19:08:19 UTC (rev 4288)
+++ trunk/MgDev/Server/src/UnitTesting/TestTileService.cpp 2009-10-07 21:05:51 UTC (rev 4289)
@@ -58,12 +58,18 @@
More information about the mapguide-commits
