[mapguide-commits] r4291 - in trunk/MgDev: Common/Renderers Server/src/Gws/GwsQueryEngine Server/src/Services/Mapping Server/src/UnitTesting
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Oct 8 15:13:00 EDT 2009
Author: brucedechant
Date: 2009-10-08 15:12:59 -0400 (Thu, 08 Oct 2009)
New Revision: 4291
   trunk/MgDev/Common/Renderers/AGGRenderer.cpp
   trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFlatFdoReader.cpp
   trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
   trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
Fix for trac ticket 1116 - GetTickCount() debugging/unit testing method on Linux is not returning correct results
http://trac.osgeo.org/mapguide/ticket/1116
Notes:
- Update GetTickCount() method on Linux to return milliseconds instead of clock ticks
- There were several GetTickCount() Linux methods defined in several different files and the duplicates have been removed
Modified: trunk/MgDev/Common/Renderers/AGGRenderer.cpp
--- trunk/MgDev/Common/Renderers/AGGRenderer.cpp	2009-10-07 21:10:32 UTC (rev 4290)
+++ trunk/MgDev/Common/Renderers/AGGRenderer.cpp	2009-10-08 19:12:59 UTC (rev 4291)
@@ -74,12 +74,19 @@
 #ifndef _WIN32
 // Linux version of GetTickCount()
+// Note: The Windows version of GetTickCount() returns the results in milliseconds.
 #include <sys/times.h>
 long GetTickCount()
-    tms tm;
-    return times(&tm);
+    struct timeval time;
+    long mtime, seconds, useconds;
+    gettimeofday(&time, NULL);
+    seconds  = time.tv_sec;
+    useconds = time.tv_usec;
+    mtime = ((seconds) * 1000 + (long)(useconds/1000.0));
+    return mtime;
 #endif
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFlatFdoReader.cpp
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFlatFdoReader.cpp	2009-10-07 21:10:32 UTC (rev 4290)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsFlatFdoReader.cpp	2009-10-08 19:12:59 UTC (rev 4291)
@@ -26,15 +26,7 @@
 #include "GwsQueryEngineImp.h"
 #ifndef _WIN32
-// Linux version of GetTickCount()
-#include <sys/times.h>
-long GetTickCount()
-    tms tm;
+extern long GetTickCount();
 #endif
Modified: trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp
--- trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp	2009-10-07 21:10:32 UTC (rev 4290)
+++ trunk/MgDev/Server/src/Services/Mapping/MappingUtil.cpp	2009-10-08 19:12:59 UTC (rev 4291)
@@ -38,14 +38,7 @@
 #ifndef _WIN32
 #define _wcsnicmp wcsncasecmp
-    tms tm;
 #endif
Modified: trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp
--- trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp	2009-10-07 21:10:32 UTC (rev 4290)
+++ trunk/MgDev/Server/src/UnitTesting/TestCoordinateSystem.cpp	2009-10-08 19:12:59 UTC (rev 4291)
@@ -22,14 +22,7 @@
 #ifndef _WIN32
 #define stricmp strcasecmp
-    tms tm;
 #endif
 #ifdef _WIN32
@@ -117,6 +110,8 @@
         int nCoordinateSystemsTested = 0;
         int nCoordinateSystemsPassed = 0;
+        long lStart = GetTickCount();
         // Open the test file and read the OGC WKT.
         // If the test file cannot be opened return an error.
         FILE* stream = NULL;
@@ -186,6 +181,7 @@
         ACE_DEBUG((LM_INFO, ACE_TEXT("\nTotal coordinate system OGC WKTs tested: %d/%d (Passed/Total)\n"), nCoordinateSystemsPassed, nCoordinateSystemsTested));
+        ACE_DEBUG((LM_INFO, ACE_TEXT("Total Processing Time: = %6.4f (s)\n"), ((GetTickCount()-lStart)/1000.0)));
     catch(MgException* e)
@@ -322,6 +318,7 @@
         int nTotalCoordinateSystemsTested = 0;
         int nTotalCoordinateSystemsPassed = 0;
         MgCoordinateSystemFactory factory;
         Ptr<MgStringCollection> categories;
@@ -399,6 +396,7 @@
         ACE_DEBUG((LM_INFO, ACE_TEXT("\nTotal coordinate systems tested: %d/%d (Passed/Total)\n"), nTotalCoordinateSystemsPassed, nTotalCoordinateSystemsTested));
@@ -5826,6 +5824,8 @@
         INT32 epsg = factory->ConvertWktToEpsgCode(EPSG_4326_Wkt);
         CPPUNIT_ASSERT(epsg == 4326);
         // Test all supported EPSG codes
         // Open the test file and read the EPSG codes.
@@ -5906,6 +5906,7 @@
         ACE_DEBUG((LM_INFO, ACE_TEXT("\nTotal EPSG codes tested: %d/%d (Passed/Total)\n"), nEpsgCodesPassed, nEpsgCodesTested));
More information about the mapguide-commits mailing list
