[mapguide-commits] r4293 - trunk/MgDev/Server/src/PostBuild
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Oct 9 10:39:22 EDT 2009
Author: waltweltonlair
Date: 2009-10-09 10:39:20 -0400 (Fri, 09 Oct 2009)
New Revision: 4293
   trunk/MgDev/Server/src/PostBuild/PostBuild.mak
A recent change in the server's PostBuild.mak file caused providers.xml to always be copied.  It should only be copied if the file is newer.
Modified: trunk/MgDev/Server/src/PostBuild/PostBuild.mak
--- trunk/MgDev/Server/src/PostBuild/PostBuild.mak	2009-10-08 20:07:08 UTC (rev 4292)
+++ trunk/MgDev/Server/src/PostBuild/PostBuild.mak	2009-10-09 14:39:20 UTC (rev 4293)
@@ -96,7 +96,7 @@
     xcopy /r /d /y /s ..\..\..\Oem\FDO\bin\Release ..\..\bin\debug\FDO\
 CopyFdoProvidersDebug : ..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml
-    xcopy /r /y "..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml" ..\..\bin\debug\FDO\
+    xcopy /r /d /y "..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml" ..\..\bin\debug\FDO\
 CopySchemaDebug : ..\..\..\Common\Schema\*.xsd
     if NOT EXIST ..\..\bin\debug\Schema\nul mkdir ..\..\bin\debug\Schema
@@ -344,7 +344,7 @@
     xcopy /r /d /y /s ..\..\..\Oem\FDO\bin\release64 ..\..\bin\debug64\FDO\
 CopyFdoProvidersDebug64 : ..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml
-    xcopy /r /y "..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml" ..\..\bin\debug64\FDO\
+    xcopy /r /d /y "..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml" ..\..\bin\debug64\FDO\
 CopySchemaDebug64 : ..\..\..\Common\Schema\*.xsd
     if NOT EXIST ..\..\bin\debug64\Schema\nul mkdir ..\..\bin\debug64\Schema
@@ -592,7 +592,7 @@
     xcopy /r /d /y /s ..\..\..\Oem\FDO\bin\Release ..\..\bin\release\FDO\
 CopyFdoProvidersRelease : ..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml
-    xcopy /r /y "..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml" ..\..\bin\release\FDO\
+    xcopy /r /d /y "..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml" ..\..\bin\release\FDO\
 CopySchemaRelease : ..\..\..\Common\Schema\*.xsd
     if NOT EXIST ..\..\bin\release\Schema\nul mkdir ..\..\bin\release\Schema
@@ -840,7 +840,7 @@
     xcopy /r /d /y /s ..\..\..\Oem\FDO\bin\release64 ..\..\bin\release64\FDO\
 CopyFdoProvidersRelease64 : ..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml
-    xcopy /r /y "..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml" ..\..\bin\release64\FDO\
+    xcopy /r /d /y "..\..\..\Oem\FDO\ProviderList\ServerCommunity\providers.xml" ..\..\bin\release64\FDO\
 CopySchemaRelease64 : ..\..\..\Common\Schema\*.xsd
     if NOT EXIST ..\..\bin\release64\Schema\nul mkdir ..\..\bin\release64\Schema
More information about the mapguide-commits mailing list
