[mapguide-commits] r4303 - in trunk/MgDev/Web/src/DotNetUnmanagedApi: Foundation Geometry MapGuideCommon PlatformBase Web
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Oct 17 01:28:49 EDT 2009
Author: waltweltonlair
Date: 2009-10-17 01:28:48 -0400 (Sat, 17 Oct 2009)
New Revision: 4303
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml
   trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml
Make formatting consistent...
Modified: trunk/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml
--- trunk/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml	2009-10-17 05:15:11 UTC (rev 4302)
+++ trunk/MgDev/Web/src/DotNetUnmanagedApi/Foundation/FoundationApiGen.xml	2009-10-17 05:28:48 UTC (rev 4303)
@@ -154,6 +154,7 @@
     <Header path="../../../../Common/Foundation/Exception/UnderflowException.h" />
     <Header path="../../../../Common/Foundation/Exception/XmlException.h" />
     <Header path="../../../../Common/Foundation/Exception/XmlParserException.h" />
 </Headers>
 </Parameters>
Modified: trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml
--- trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml	2009-10-17 05:15:11 UTC (rev 4302)
+++ trunk/MgDev/Web/src/DotNetUnmanagedApi/Geometry/GeometryApiGen.xml	2009-10-17 05:28:48 UTC (rev 4303)
@@ -52,21 +52,21 @@
   %include "language.i"   //typemaps specific for each language
   %include "../../../../Common/Geometry/GeometryClassId.h"
-  #if defined(PHPSWIG)
+#if defined(PHPSWIG)
   // We force UTF-8 encoding for PHP
   typedef char*         STRINGPARAM;
   typedef char*         STRING;
   typedef char*         BYTE_ARRAY_IN;
   typedef char*         BYTE_ARRAY_OUT;
   typedef unsigned char BYTE;
-  #elseif defined(JAVA)
+#elseif defined(JAVA)
   typedef std::wstring  STRINGPARAM;
   typedef signed char   BYTE;  //mapped to byte in Java
-  #else // .Net
+#else // .Net
   typedef unsigned char BYTE;    //mapped to byte in C#
-  #endif
+#endif
   typedef int           STATUS;
   typedef short         INT8;
@@ -81,6 +81,7 @@
    must also add them to Makefile.am in the JavaApi and PhpApi folders.
 <Headers>
     <!-- Geometry classes -->
     <Header path="../../../../Common/Geometry/GeometricEntity.h" />
Modified: trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml
--- trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml	2009-10-17 05:15:11 UTC (rev 4302)
+++ trunk/MgDev/Web/src/DotNetUnmanagedApi/MapGuideCommon/MapGuideCommonApiGen.xml	2009-10-17 05:28:48 UTC (rev 4303)
@@ -55,21 +55,21 @@
   %include "../../../../Common/MapGuideCommon/System/MapGuideCommonClassId.h"
-  #else // .Net
+#else // .Net
-  #endif
+#endif
   typedef int           STATUS;
   typedef short         INT8;
@@ -85,79 +85,80 @@
 <Headers>
-  <!-- MapGuideCommon classes -->
+    <!-- MapGuideCommon classes -->
-  <Header path="../../../../Common/MapGuideCommon/Exception/AuthenticationFailedException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/ConnectionFailedException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/ConnectionNotOpenException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/DbException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/DbXmlException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/DuplicateGroupException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/DuplicateNameException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/DuplicateParameterException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/DuplicateRepositoryException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/DuplicateRoleException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/DuplicateServerException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/DuplicateSessionException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/DuplicateUserException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/DwfException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/DwfSectionNotFoundException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/DwfSectionResourceNotFoundException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/EndOfStreamException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/GroupNotFoundException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/InvalidDwfPackageException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/InvalidDwfSectionException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/InvalidFeatureSourceException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/InvalidIpAddressException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/InvalidLicenseException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/InvalidLogEntryException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/InvalidPasswordException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutFontSizeUnitsException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutPositionUnitsException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutSizeUnitsException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/InvalidServerNameException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/LicenseException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/LicenseExpiredException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/OperationProcessingException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/ParameterNotFoundException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/PathTooLongException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/PortNotAvailableException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/PrintToScaleModeNotSelectedException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/RepositoryCreationFailedException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/RepositoryNotFoundException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/RepositoryNotOpenException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/RepositoryOpenFailedException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/RoleNotFoundException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/ServerNotFoundException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/ServerNotOnlineException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/SessionExpiredException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/SessionNotFoundException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/UnauthorizedAccessException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Exception/UriFormatException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/AuthenticationFailedException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/ConnectionFailedException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/ConnectionNotOpenException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/DbException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/DbXmlException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/DuplicateGroupException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/DuplicateNameException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/DuplicateParameterException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/DuplicateRepositoryException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/DuplicateRoleException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/DuplicateServerException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/DuplicateSessionException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/DuplicateUserException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/DwfException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/DwfSectionNotFoundException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/DwfSectionResourceNotFoundException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/EndOfStreamException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/GroupNotFoundException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/InvalidDwfPackageException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/InvalidDwfSectionException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/InvalidFeatureSourceException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/InvalidIpAddressException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/InvalidLicenseException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/InvalidLogEntryException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/InvalidPasswordException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutFontSizeUnitsException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutPositionUnitsException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/InvalidPrintLayoutSizeUnitsException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/InvalidServerNameException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/LicenseException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/LicenseExpiredException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/OperationProcessingException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/ParameterNotFoundException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/PathTooLongException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/PortNotAvailableException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/PrintToScaleModeNotSelectedException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/RepositoryCreationFailedException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/RepositoryNotFoundException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/RepositoryNotOpenException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/RepositoryOpenFailedException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/RoleNotFoundException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/ServerNotFoundException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/ServerNotOnlineException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/SessionExpiredException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/SessionNotFoundException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/UnauthorizedAccessException.h" />
+    <Header path="../../../../Common/MapGuideCommon/Exception/UriFormatException.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/DrawingService.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/DwfVersion.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/FeatureInformation.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/KmlService.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/Layout.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/MappingService.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/MapPlot.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/MapPlotCollection.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/PackageStatusInformation.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/PlotSpecification.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/RenderingOptions.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/RenderingService.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/ServerAdmin.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/Site.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/SiteConnection.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/SiteInfo.h" />
-  <Header path="../../../../Common/MapGuideCommon/Services/TileService.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/DrawingService.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/DwfVersion.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/FeatureInformation.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/KmlService.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/Layout.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/MappingService.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/MapPlot.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/MapPlotCollection.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/PackageStatusInformation.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/PlotSpecification.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/RenderingOptions.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/RenderingService.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/ServerAdmin.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/Site.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/SiteConnection.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/SiteInfo.h" />
+    <Header path="../../../../Common/MapGuideCommon/Services/TileService.h" />
-  <Header path="../../../../Common/MapGuideCommon/System/UserInformation.h" />
+    <Header path="../../../../Common/MapGuideCommon/System/UserInformation.h" />
-  <Header path="../../../../Common/MapGuideCommon/MapLayer/Layer.h" />
-  <Header path="../../../../Common/MapGuideCommon/MapLayer/Map.h" />
-  <Header path="../../../../Common/MapGuideCommon/MapLayer/Selection.h" />
+    <Header path="../../../../Common/MapGuideCommon/MapLayer/Layer.h" />
+    <Header path="../../../../Common/MapGuideCommon/MapLayer/Map.h" />
+    <Header path="../../../../Common/MapGuideCommon/MapLayer/Selection.h" />
 </Headers>
 </Parameters>
Modified: trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml
--- trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml	2009-10-17 05:15:11 UTC (rev 4302)
+++ trunk/MgDev/Web/src/DotNetUnmanagedApi/PlatformBase/PlatformBaseApiGen.xml	2009-10-17 05:28:48 UTC (rev 4303)
@@ -54,21 +54,21 @@
   %include "../../../../Common/PlatformBase/Services/PlatformBaseClassId.h"
-  #else // .Net
+#else // .Net
-  #endif
+#endif
   typedef int           STATUS;
   typedef short         INT8;
@@ -83,6 +83,7 @@
 <Headers>
     <!-- PlatformBase classes -->
     <Header path="../../../../Common/PlatformBase/Data/BlobProperty.h" />
@@ -161,9 +162,9 @@
     <Header path="../../../../Common/PlatformBase/Services/ResourceService.h" />
     <Header path="../../../../Common/PlatformBase/Services/SpatialContextReader.h" />
     <Header path="../../../../Common/PlatformBase/Services/SqlDataReader.h" />
+    <Header path="../../../../Common/PlatformBase/Services/Transaction.h" />
     <Header path="../../../../Common/PlatformBase/Services/UpdateFeatures.h" />
     <Header path="../../../../Common/PlatformBase/Services/Warnings.h" />
-    <Header path="../../../../Common/PlatformBase/Services/Transaction.h" />
     <Header path="../../../../Common/PlatformBase/MapLayer/LayerBase.h" />
     <Header path="../../../../Common/PlatformBase/MapLayer/LayerCollection.h" />
Modified: trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml
--- trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml	2009-10-17 05:15:11 UTC (rev 4302)
+++ trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/WebApiGen.xml	2009-10-17 05:28:48 UTC (rev 4303)
@@ -57,10 +57,6 @@
    Swig inline section.
 <SwigInline>
-   Imported interfaces
   %import "../Foundation/FoundationApi.i"
   %import "../Geometry/GeometryApi.i"
   %import "../PlatformBase/PlatformBaseApi.i"
@@ -70,21 +66,21 @@
   %include "../../WebApp/WebAppClassId.h"
   %include "../../HttpHandler/HttpHandlerClassId.h"
-  #else // .Net
+#else // .Net
-  #endif
+#endif
   typedef int           STATUS;
   typedef short         INT8;
@@ -99,46 +95,48 @@
 <Headers>
-  <!-- WebApp classes -->
-  <Header path="../../WebApp/WebCommand.h" />
-  <Header path="../../WebApp/WebUiTargetCommand.h" />
-  <Header path="../../WebApp/WebWidget.h" />
-  <Header path="../../WebApp/WebWidgetCollection.h" />
-  <Header path="../../WebApp/WebUiPane.h" />
-  <Header path="../../WebApp/WebUiSizablePane.h" />
-  <Header path="../../WebApp/WebBufferCommand.h" />
-  <Header path="../../WebApp/WebCommandCollection.h" />
-  <Header path="../../WebApp/WebCommandWidget.h" />
-  <Header path="../../WebApp/WebContextMenu.h" />
-  <Header path="../../WebApp/WebFlyoutWidget.h" />
-  <Header path="../../WebApp/WebGetPrintablePageCommand.h" />
-  <Header path="../../WebApp/WebHelpCommand.h" />
-  <Header path="../../WebApp/WebInformationPane.h" />
-  <Header path="../../WebApp/WebInvokeScriptCommand.h" />
-  <Header path="../../WebApp/WebInvokeUrlCommand.h" />
-  <Header path="../../WebApp/WebLayout.h" />
-  <Header path="../../WebApp/WebMeasureCommand.h" />
-  <Header path="../../WebApp/WebPrintCommand.h" />
-  <Header path="../../WebApp/WebSearchCommand.h" />
-  <Header path="../../WebApp/WebSelectWithinCommand.h" />
-  <Header path="../../WebApp/WebSeparatorWidget.h" />
-  <Header path="../../WebApp/WebTaskBar.h" />
-  <Header path="../../WebApp/WebTaskBarWidget.h" />
-  <Header path="../../WebApp/WebTaskPane.h" />
-  <Header path="../../WebApp/WebToolbar.h" />
-  <Header path="../../WebApp/WebViewOptionsCommand.h" />
+    <!-- WebApp classes -->
-  <!-- HttpHandler classes -->
+    <Header path="../../WebApp/WebCommand.h" />
+    <Header path="../../WebApp/WebUiTargetCommand.h" />
+    <Header path="../../WebApp/WebWidget.h" />
+    <Header path="../../WebApp/WebWidgetCollection.h" />
+    <Header path="../../WebApp/WebUiPane.h" />
+    <Header path="../../WebApp/WebUiSizablePane.h" />
-  <Header path="../../HttpHandler/HttpHeader.h" />
-  <Header path="../../HttpHandler/HttpPrimitiveValue.h" />
-  <Header path="../../HttpHandler/HttpRequest.h" />
-  <Header path="../../HttpHandler/HttpRequestMetadata.h" />
-  <Header path="../../HttpHandler/HttpRequestParam.h" />
-  <Header path="../../HttpHandler/HttpResponse.h" />
-  <Header path="../../HttpHandler/HttpResult.h" />
+    <Header path="../../WebApp/WebBufferCommand.h" />
+    <Header path="../../WebApp/WebCommandCollection.h" />
+    <Header path="../../WebApp/WebCommandWidget.h" />
+    <Header path="../../WebApp/WebContextMenu.h" />
+    <Header path="../../WebApp/WebFlyoutWidget.h" />
+    <Header path="../../WebApp/WebGetPrintablePageCommand.h" />
+    <Header path="../../WebApp/WebHelpCommand.h" />
+    <Header path="../../WebApp/WebInformationPane.h" />
+    <Header path="../../WebApp/WebInvokeScriptCommand.h" />
+    <Header path="../../WebApp/WebInvokeUrlCommand.h" />
+    <Header path="../../WebApp/WebLayout.h" />
+    <Header path="../../WebApp/WebMeasureCommand.h" />
+    <Header path="../../WebApp/WebPrintCommand.h" />
+    <Header path="../../WebApp/WebSearchCommand.h" />
+    <Header path="../../WebApp/WebSelectWithinCommand.h" />
+    <Header path="../../WebApp/WebSeparatorWidget.h" />
+    <Header path="../../WebApp/WebTaskBar.h" />
+    <Header path="../../WebApp/WebTaskBarWidget.h" />
+    <Header path="../../WebApp/WebTaskPane.h" />
+    <Header path="../../WebApp/WebToolbar.h" />
+    <Header path="../../WebApp/WebViewOptionsCommand.h" />
+    <!-- HttpHandler classes -->
+    <Header path="../../HttpHandler/HttpHeader.h" />
+    <Header path="../../HttpHandler/HttpPrimitiveValue.h" />
+    <Header path="../../HttpHandler/HttpRequest.h" />
+    <Header path="../../HttpHandler/HttpRequestMetadata.h" />
+    <Header path="../../HttpHandler/HttpRequestParam.h" />
+    <Header path="../../HttpHandler/HttpResponse.h" />
+    <Header path="../../HttpHandler/HttpResult.h" />
 </Headers>
 </Parameters>
More information about the mapguide-commits mailing list
