[mapguide-commits] r4323 - in sandbox/adsk/2.1: Common Common/MapGuideCommon/Services Common/MapGuideCommon/System Server/src/Common/Manager Server/src/Services/ServerAdmin UnitTest/WebTier/MapAgent/MapAgentForms Web/src/ApacheAgent Web/src/CgiAgent Web/src/HttpHandler Web/src/IsapiAgent Web/src/viewerfiles
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Oct 27 20:17:23 EDT 2009
Author: brucedechant
Date: 2009-10-27 20:17:22 -0400 (Tue, 27 Oct 2009)
New Revision: 4323
Added:
   sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteStatus.cpp
   sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteStatus.h
   sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteVersion.cpp
   sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteVersion.h
   sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/getsitestatusform.html
   sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteStatus.cpp
   sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteStatus.h
   sandbox/adsk/2.1/Common/MapGuideCommon/Services/Command.cpp
   sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerAdmin.cpp
   sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerAdmin.h
   sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerAdminDefs.cpp
   sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerAdminDefs.h
   sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerConnection.cpp
   sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerConnection.h
   sandbox/adsk/2.1/Common/MapGuideCommon/Services/SiteConnection.cpp
   sandbox/adsk/2.1/Common/MapGuideCommon/Services/SiteManager.cpp
   sandbox/adsk/2.1/Common/MapGuideCommon/Services/SiteManager.h
   sandbox/adsk/2.1/Common/MapGuideCommon/System/ConfigProperties.cpp
   sandbox/adsk/2.1/Common/MapGuideCommon/System/ConfigProperties.h
   sandbox/adsk/2.1/Common/ProductVersion.h
   sandbox/adsk/2.1/Server/src/Common/Manager/ServerManager.cpp
   sandbox/adsk/2.1/Server/src/Common/Manager/ServerManager.h
   sandbox/adsk/2.1/Server/src/Services/ServerAdmin/Makefile.am
   sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminOperationFactory.cpp
   sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminService.cpp
   sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminService.h
   sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminService.vcproj
   sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminServiceBuild.cpp
   sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteinfoform.html
   sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteversionform.html
   sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/siteserviceapi.html
   sandbox/adsk/2.1/Web/src/ApacheAgent/ApacheAgent.cpp
   sandbox/adsk/2.1/Web/src/CgiAgent/CgiAgent.cpp
   sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteInfo.cpp
   sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteInfo.h
   sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteVersion.cpp
   sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteVersion.h
   sandbox/adsk/2.1/Web/src/HttpHandler/HttpHandler.vcproj
   sandbox/adsk/2.1/Web/src/HttpHandler/HttpHandlerBuild.cpp
   sandbox/adsk/2.1/Web/src/HttpHandler/HttpRequest.cpp
   sandbox/adsk/2.1/Web/src/HttpHandler/HttpRequestResponseHandler.cpp
   sandbox/adsk/2.1/Web/src/HttpHandler/HttpResourceStrings.cpp
   sandbox/adsk/2.1/Web/src/HttpHandler/HttpResourceStrings.h
   sandbox/adsk/2.1/Web/src/HttpHandler/Makefile.am
   sandbox/adsk/2.1/Web/src/IsapiAgent/IsapiAgent.cpp
   sandbox/adsk/2.1/Web/src/viewerfiles/ajaxmappane.templ
Fix for trac ticket 1131 - Load balancing doesn't support failover
http://trac.osgeo.org/mapguide/ticket/1131
Notes:
- Updated load balancing algorithm to remove failed servers and periodically add them back in when they are up and running again
- Added NEW ServerAdmin HTTP/API GetSiteStatus - supports multiple servers
- Updated ServerAdmin HTTP GetSiteInfo to support multiple servers
- Updated ServerAdmin HTTP GetSiteVersion to support multiple servers
- Updated web tier test pages to use new version of above APIs
Modified: sandbox/adsk/2.1/Common/MapGuideCommon/Services/Command.cpp
--- sandbox/adsk/2.1/Common/MapGuideCommon/Services/Command.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Common/MapGuideCommon/Services/Command.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -34,6 +34,8 @@
         //TODO:  Parse url and pull machine name into target
+    MG_TRY()
     Ptr<MgUserInformation> userInfo = connProp->GetUserInfo();
     Ptr<MgServerConnection> serviceConn = MgServerConnection::Acquire(userInfo, connProp);
     Ptr<MgStream> stream = serviceConn->GetStream();
@@ -114,6 +116,29 @@
     stream->WriteStreamEnd();
     GetResponse(serviceConn, retType);
+    MG_CATCH(L"MgCommand.ExecuteCommand")
+    if (NULL != mgException)
+        if (mgException->IsOfClass(MapGuide_Exception_MgConnectionFailedException))
+            // The server didn't respond so it needs to be marked as unavailable in the list of servers.
+            // We will check to see if it can be made available later.
+            MgSiteManager* siteManager = MgSiteManager::GetInstance();
+            Ptr<MgSiteInfo> badSite = siteManager->GetSiteInfo(connProp->GetTarget(), connProp->GetPort());
+            if(NULL != badSite.p)
+                // Update the status of the failed server
+                badSite->SetStatus(MgSiteInfo::UnableToConnect);
+            // Need to remove the server connection from the pool
+            MgServerConnection::Remove(connProp);
+        MG_THROW();
Modified: sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerAdmin.cpp
--- sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerAdmin.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerAdmin.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -622,6 +622,63 @@
 /// <summary>
+/// Gets the site version.
+/// </summary>
+/// <returns>
+/// The site version.
+/// </returns>
+/// EXCEPTIONS:
+/// MgConnectionNotOpenException
+STRING MgServerAdmin::GetSiteVersion()
+    MgCommand cmd;
+    cmd.ExecuteCommand(m_connProp,                              // Connection
+                        MgCommand::knString,                    // Return type expected
+                        MgServerAdminServiceOpId::GetSiteVersion, // Command Code
+                        0,                                      // No of arguments
+                        ServerAdmin_Service,                    // Service Id
+                        BUILD_VERSION(1,0,0),                   // Operation version
+                        MgCommand::knNone);
+    SetWarning(cmd.GetWarningObject());
+    STRING retVal = *(cmd.GetReturnValue().val.m_str);
+    delete cmd.GetReturnValue().val.m_str;
+    return retVal;
+/// <summary>
+/// Gets the status properties for the server.
+/// </summary>
+/// <returns>
+/// The collection of status properties.
+/// </returns>
+/// EXCEPTIONS:
+MgPropertyCollection* MgServerAdmin::GetSiteStatus()
+    MgCommand cmd;
+                        MgCommand::knObject,                    // Return type expected
+                        MgServerAdminServiceOpId::GetSiteStatus, // Command Code
+                        BUILD_VERSION(2,1,0),                   // Operation version
+    return (MgPropertyCollection*)cmd.GetReturnValue().val.m_obj;
+/// <summary>
 /// Delete the specified package, if able.
 /// </summary>
Modified: sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerAdmin.h
--- sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerAdmin.h	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerAdmin.h	2009-10-28 00:17:22 UTC (rev 4323)
@@ -365,6 +365,28 @@
     /// \brief
+    /// Gets the site version.
+    /// \return
+    /// The site version.
+    /// \exception MgConnectionNotOpenException
+    STRING GetSiteVersion();
+    /// \brief
+    /// Gets the status properties for the server.
+    /// \return
+    /// The collection of status properties.
+    MgPropertyCollection* GetSiteStatus();
+    /// \brief
     /// \param packageName
Modified: sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerAdminDefs.cpp
--- sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerAdminDefs.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerAdminDefs.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -76,3 +76,5 @@
 const STRING MgServerInformationProperties::TotalConnections            = L"TotalConnections";
 const STRING MgServerInformationProperties::TotalActiveConnections      = L"TotalActiveConnections";
 const STRING MgServerInformationProperties::OperatingSystemVersion      = L"OperatingSystemVersion";
+const STRING MgServerInformationProperties::ApiVersion                  = L"ApiVersion";
+const STRING MgServerInformationProperties::MachineIp                   = L"MachineIp";
Modified: sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerAdminDefs.h
--- sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerAdminDefs.h	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerAdminDefs.h	2009-10-28 00:17:22 UTC (rev 4323)
@@ -114,6 +114,8 @@
     /// The server's version
     static const STRING ServerVersion;              /// value("ServerVersion")
+    /// The API version
+    static const STRING ApiVersion;                 /// value("ApiVersion")
     /// STATISTIC PROPERTIES SECTION -----------------------------------------------------------------------------------
@@ -156,6 +158,9 @@
     /// Gets the server display name
     static const STRING DisplayName;                /// value("DisplayName")
+    /// Gets the server machine Ip
+    static const STRING MachineIp;                  /// value("MachineIp")
     /// Gets the total operations received
     static const STRING TotalReceivedOperations;    /// value("TotalReceivedOperations")
@@ -209,6 +214,8 @@
     static const int NotifyResourcesChanged         = 0x1111EA1A;
     static const int MakePackage                    = 0x1111EA1B;
     static const int RemoveConfigurationProperties  = 0x1111EA1C;
+    static const int GetSiteVersion                 = 0x1111EA1D;
+    static const int GetSiteStatus                  = 0x1111EA1E;
 /// \endcond
Modified: sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerConnection.cpp
--- sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerConnection.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerConnection.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -275,10 +275,10 @@
 /// </summary>
 /// <param name="userInformation">
-/// User information to authenticate against
+/// User information to authenticate against.
 /// </param>
-/// <param name="target">
-/// Target server.  NULL or "" indicates local server
+/// <param name="connProp">
+/// Connection properties for the server to connect to.
 /// </param>
 /// <returns>
 /// Nothing
@@ -342,3 +342,28 @@
     return msc.Detach();
+/// <summary>
+/// Removes a connection to a Mg server
+/// </summary>
+/// Connection properties of the server to remove.
+/// </param>
+/// <returns>
+/// Nothing
+/// </returns>
+/// EXCEPTIONS:
+/// AuthorizationFailed
+/// TargetNotFound
+void MgServerConnection::Remove(MgConnectionProperties* connProp)
+    CHECKNULL((MgConnectionProperties*)connProp, L"MgServerConnection.Remove");
+        ACE_MT(ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, sm_mutex));
+        wstring hash = connProp->Hash();
+        g_connectionPool->pool.erase(hash);
Modified: sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerConnection.h
--- sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerConnection.h	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Common/MapGuideCommon/Services/ServerConnection.h	2009-10-28 00:17:22 UTC (rev 4323)
@@ -105,6 +105,19 @@
     /// \brief
+    /// Removes the TCP/IP connection to a MapGuide server from the
+    /// internal connection pool.
+    /// \param connProp
+    /// Connection properties for target server
+    /// \return
+    /// Nothing
+    static void Remove(MgConnectionProperties* connProp);
+    /// \brief
     /// Internal method used for getting stream helper
     /// which will then be used in serialize/deserialize
Modified: sandbox/adsk/2.1/Common/MapGuideCommon/Services/SiteConnection.cpp
--- sandbox/adsk/2.1/Common/MapGuideCommon/Services/SiteConnection.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Common/MapGuideCommon/Services/SiteConnection.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -129,7 +129,8 @@
     if (m_connProp == NULL)
-        throw new MgLogicException(L"MgSiteConnection.Open",
+        // There might not be any MapGuide servers running for the site
+        throw new MgConnectionFailedException(L"MgSiteConnection.Open",
             __LINE__, __WFILE__, NULL, L"", NULL);
Modified: sandbox/adsk/2.1/Common/MapGuideCommon/Services/SiteManager.cpp
--- sandbox/adsk/2.1/Common/MapGuideCommon/Services/SiteManager.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Common/MapGuideCommon/Services/SiteManager.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -19,6 +19,79 @@
 // Process-wide MgSiteManager
 Ptr<MgSiteManager> MgSiteManager::sm_siteManager = (MgSiteManager*)NULL;
+// Background thread function
+ACE_THR_FUNC_RETURN CheckServers(void* param)
+    SMThreadData* threadData = (SMThreadData*)param;
+    // Store our unique thread ID
+    threadData->threadId = ACE_Thread::self();
+    bool bDone = false;
+    while(!bDone)
+        MgSiteVector* sites = siteManager->GetSites();
+        if(sites)
+            for(size_t i=0;i<sites->size();i++)
+                MgSiteInfo* siteInfo = sites->at(i);
+                // Check the server status
+                if (MgSiteInfo::Ok != siteInfo->GetStatus())
+                    // This is an unavailable server so we need to check if it is now available
+                    MG_TRY()
+                    // Send a simple request to the server to see if it can respond
+                    Ptr<MgUserInformation> userInformation = new MgUserInformation(L"Administrator", L"admin");
+                    Ptr<MgConnectionProperties> connProp = siteManager->GetConnectionProperties(userInformation, siteInfo, MgSiteInfo::Admin);
+                    // Use GetSiteStatus because it doesn't require authentication
+                    MgCommand cmd;
+                    cmd.ExecuteCommand(connProp,                               // Connection
+                    // The server responded so update the status if the server is online
+                    Ptr<MgPropertyCollection> properties = (MgPropertyCollection*)cmd.GetReturnValue().val.m_obj;
+                    if(properties.p)
+                        // Check the status of the server
+                        Ptr<MgBooleanProperty> boolProp = (MgBooleanProperty*)properties->GetItem(MgServerInformationProperties::Status);
+                        if(boolProp->GetValue())
+                            // Server is there and "Online"
+                            ACE_MT(ACE_GUARD_RETURN(ACE_Recursive_Thread_Mutex, ace_mon, siteManager->m_mutex, NULL));
+                            siteInfo->SetStatus(MgSiteInfo::Ok);
+                    MG_CATCH_AND_RELEASE()
+                    if(NULL != mgException.p)
+                        // Exception was thrown
+                        STRING message = mgException->GetMessage();
+        // Sleep the thread as thread resume/suspend is not supported on all platforms
+        ACE_OS::sleep(threadData->failoverRetryTime);
+        // Update whether we are done or not
+        bDone = siteManager->GetCheckServersThreadDone();
+    return 0;
 /// <summary>
 /// Constructs the object.
@@ -47,6 +120,10 @@
     ClearSiteInfo();
+    // Block any threads as we are updating the thread done
+    ACE_MT(ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, m_mutex));
+    m_bCheckServersThreadDone = true;
     MG_CATCH(L"MgSiteManager.~MgSiteManager")
@@ -187,6 +264,24 @@
         m_sites.push_back(siteInfo.Detach());
+    // Create background thread that will check any unavailable servers to see if their status has changed
+    INT32 failoverRetryTime = MgConfigProperties::DefaultGeneralPropertyFailoverRetryTime;
+    configuration->GetIntValue(
+        MgConfigProperties::GeneralPropertiesSection,
+        MgConfigProperties::GeneralPropertyFailoverRetryTime,
+        failoverRetryTime,
+        MgConfigProperties::DefaultGeneralPropertyFailoverRetryTime);
+    m_threadData.failoverRetryTime = failoverRetryTime;
+    m_bCheckServersThreadDone = false;
+    // Need a thread manager
+    ACE_Thread_Manager* manager = ACE_Thread_Manager::instance();
+    // Create the background thread
+    manager->spawn(ACE_THR_FUNC(CheckServers), &m_threadData);
     MG_CATCH_AND_THROW(L"MgSiteManager.Initialize")
@@ -221,12 +316,19 @@
             STRING siteHexString = sessionId.substr(
                 length - MgSiteInfo::HexStringLength, MgSiteInfo::HexStringLength);
-            Ptr<MgSiteInfo> siteInfo = new MgSiteInfo(siteHexString);
+            Ptr<MgSiteInfo> siteInfo = GetSiteInfo(siteHexString);
             if (MgSiteInfo::Ok == siteInfo->GetStatus())
                 connProps = GetConnectionProperties(userInfo, siteInfo, portType);
+            else
+                // This site is not currently working
+                // We have a session, but it will not exist on any other machine so we force the session exception
+                throw new MgSessionExpiredException(L"MgSiteManager.GetConnectionProperties",__LINE__,__WFILE__, NULL, L"", NULL);
     else
@@ -241,7 +343,8 @@
     if (NULL == connProps.p)
@@ -379,3 +482,64 @@
     return SAFE_ADDREF(matchingSiteInfo);
+/// <summary>
+/// Retrieves site info for the site server matching the specified target and port
+/// contained within the specifed hex string.
+/// </summary>
+MgSiteInfo* MgSiteManager::GetSiteInfo(CREFSTRING hexString)
+    MgSiteInfo* matchingSiteInfo = NULL;
+    if(hexString.length() >= MgSiteInfo::HexStringLength)
+        UINT32 n1, n2, n3, n4;
+        INT32 sitePort, clientPort, adminPort;
+        STRING target;
+        // Read the IP parts into their variables
+        if(::swscanf(hexString.c_str(), L"%2X%2X%2X%2X%4X%4X%4X", &n1, &n2, &n3, &n4, &sitePort, &clientPort, &adminPort) == 7)
+            // Write the 4 'n' values into an IP string
+            wchar_t buffer[20];
+            swprintf(buffer, 20, L"%u.%u.%u.%u", n1, n2, n3, n4);
+            target = buffer;
+        ACE_MT(ACE_GUARD_RETURN(ACE_Recursive_Thread_Mutex, ace_mon, m_mutex, NULL));
+        for (INT32 i = 0; i < (INT32)m_sites.size(); i++)
+            MgSiteInfo* siteInfo = m_sites.at(i);
+            if (siteInfo->GetTarget() == target
+                && (siteInfo->GetPort(MgSiteInfo::Site)   == sitePort ||
+                    siteInfo->GetPort(MgSiteInfo::Client) == clientPort ||
+                    siteInfo->GetPort(MgSiteInfo::Admin)  == adminPort))
+                matchingSiteInfo = siteInfo;
+                break;
+    return SAFE_ADDREF(matchingSiteInfo);
+MgSiteVector* MgSiteManager::GetSites()
+    return &m_sites;
+bool MgSiteManager::GetCheckServersThreadDone()
+    return m_bCheckServersThreadDone;
+void MgSiteManager::SetCheckServersThreadDone(bool bDone)
+    m_bCheckServersThreadDone = bDone;
Modified: sandbox/adsk/2.1/Common/MapGuideCommon/Services/SiteManager.h
--- sandbox/adsk/2.1/Common/MapGuideCommon/Services/SiteManager.h	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Common/MapGuideCommon/Services/SiteManager.h	2009-10-28 00:17:22 UTC (rev 4323)
@@ -21,6 +21,13 @@
 class MgSiteInfo;
 typedef std::vector<MgSiteInfo*> MgSiteVector;
+// Data structure which is passed to thread
+struct SMThreadData
+    ACE_thread_t threadId;
+    INT32 failoverRetryTime;
 class MG_MAPGUIDE_API MgSiteManager : public MgGuardDisposable
 DECLARE_CLASSNAME(MgSiteManager)
@@ -63,9 +70,16 @@
     MgSiteInfo* GetSiteInfo(INT32 index);
     MgSiteInfo* GetSiteInfo(CREFSTRING target, INT32 port);
+    MgSiteInfo* GetSiteInfo(CREFSTRING hexString);
     INT32 GetSiteCount();
+    MgSiteVector* GetSites();
+    ACE_Recursive_Thread_Mutex m_mutex;
+    bool GetCheckServersThreadDone();
+    void SetCheckServersThreadDone(bool bDone);
 private:
     void Initialize();
@@ -79,9 +93,10 @@
     static Ptr<MgSiteManager> sm_siteManager;
-    ACE_Recursive_Thread_Mutex m_mutex;
     INT32 m_index;
     MgSiteVector m_sites;
+    SMThreadData m_threadData;
+    bool m_bCheckServersThreadDone;
 #endif // MG_SITEMANAGER_H_
Modified: sandbox/adsk/2.1/Common/MapGuideCommon/System/ConfigProperties.cpp
--- sandbox/adsk/2.1/Common/MapGuideCommon/System/ConfigProperties.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Common/MapGuideCommon/System/ConfigProperties.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -155,6 +155,8 @@
 const INT32  MgConfigProperties::DefaultGeneralPropertyWorkerThreadPoolSize                 = 10;
 const STRING MgConfigProperties::GeneralPropertyRenderer                                    = L"Renderer";
 const STRING MgConfigProperties::DefaultGeneralPropertyRenderer                             = L"GD";
+const STRING MgConfigProperties::GeneralPropertyFailoverRetryTime                           = L"FailoverRetryTime"; // for internal use only
+const INT32  MgConfigProperties::DefaultGeneralPropertyFailoverRetryTime                    = 60;
 // Administrative Connection Properties
@@ -491,6 +493,7 @@
     { MgConfigProperties::GeneralPropertyWfsDocumentPath                            , MgPropertyType::String    , MG_CONFIG_MIN_PATH_LENGTH             , MG_CONFIG_MAX_PATH_LENGTH             , MG_CONFIG_PATH_RESERVED_CHARACTERS        },
     { MgConfigProperties::GeneralPropertyWmsDocumentPath                            , MgPropertyType::String    , MG_CONFIG_MIN_PATH_LENGTH             , MG_CONFIG_MAX_PATH_LENGTH             , MG_CONFIG_PATH_RESERVED_CHARACTERS        },
     { MgConfigProperties::GeneralPropertyWorkerThreadPoolSize                       , MgPropertyType::Int32     , MG_CONFIG_MIN_THREAD_POOL_SIZE        , MG_CONFIG_MAX_THREAD_POOL_SIZE        , L""                                       },
+    { MgConfigProperties::GeneralPropertyFailoverRetryTime                          , MgPropertyType::Int32     , MG_CONFIG_MIN_TIMER_INTERVAL          , MG_CONFIG_MAX_TIMER_INTERVAL          , L""                                       },
     { L""        , 0                         , 0.0                                   , 0.0                                   , L""                                       }
Modified: sandbox/adsk/2.1/Common/MapGuideCommon/System/ConfigProperties.h
--- sandbox/adsk/2.1/Common/MapGuideCommon/System/ConfigProperties.h	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Common/MapGuideCommon/System/ConfigProperties.h	2009-10-28 00:17:22 UTC (rev 4323)
@@ -135,6 +135,10 @@
     static const STRING GeneralPropertyWorkerThreadPoolSize;            /// value("WorkerThreadPoolSize")
     static const INT32 DefaultGeneralPropertyWorkerThreadPoolSize;      /// value(10)
+    /// Sets the failover retry time
+    static const STRING GeneralPropertyFailoverRetryTime;               /// value("FailoverRetryTime")
+    static const INT32 DefaultGeneralPropertyFailoverRetryTime;         /// value(60)
 EXTERNAL_API:
     /// ADMINISTRATIVE CONNECTION PROPERTIES SECTION ---------------------------------------------------------------------
Modified: sandbox/adsk/2.1/Common/ProductVersion.h
--- sandbox/adsk/2.1/Common/ProductVersion.h	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Common/ProductVersion.h	2009-10-28 00:17:22 UTC (rev 4323)
@@ -18,6 +18,8 @@
 #ifndef PRODUCTVERSION_H_
 #define PRODUCTVERSION_H_
-const STRING ProductVersion = L"7.0.0.1";
+// These versions must be updated for each release of the product
+const STRING ProductVersion = L"2.1.0.0";
+const STRING ApiVersion = L"2.1";  // Major.Minor only
 #endif // PRODUCTVERSION_H_
Modified: sandbox/adsk/2.1/Server/src/Common/Manager/ServerManager.cpp
--- sandbox/adsk/2.1/Server/src/Common/Manager/ServerManager.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Server/src/Common/Manager/ServerManager.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -494,6 +494,10 @@
     pProperty = new MgStringProperty(MgServerInformationProperties::DisplayName, m_displayName);
     pProperties->Add(pProperty);
+    // Add the MachineIp
+    pProperty = new MgStringProperty(MgServerInformationProperties::MachineIp, m_localServerAddress);
+    pProperties->Add(pProperty);
      // Add the Operations info
     INT32 nTotalReceivedOperations = GetTotalReceivedOperations();
     pProperty = new MgInt32Property(MgServerInformationProperties::TotalReceivedOperations, nTotalReceivedOperations);
@@ -572,6 +576,51 @@
     return pProperties.Detach();
+/// <summary>
+/// </summary>
+STRING MgServerManager::GetSiteVersion()
+    return ProductVersion;
+/// <summary>
+/// </summary>
+MgPropertyCollection* MgServerManager::GetSiteStatus()
+    Ptr<MgPropertyCollection> pProperties;
+    pProperties = NULL;
+    MG_TRY()
+    MG_LOG_TRACE_ENTRY(L"MgServerManager::GetSiteStatus()");
+    pProperties = new MgPropertyCollection();
+    // Add the information properties
+    Ptr<MgProperty> pProperty;
+    // Add the DisplayName
+    pProperty = new MgStringProperty(MgServerInformationProperties::DisplayName, m_displayName);
+    // Add the Status
+    bool bOnline = IsOnline();
+    pProperty = new MgBooleanProperty(MgServerInformationProperties::Status, bOnline);
+    // Add the API Version
+    pProperty = new MgStringProperty(MgServerInformationProperties::ApiVersion, ApiVersion);
+    MG_CATCH_AND_THROW(L"MgServerManager.GetSiteStatus")
+    return pProperties.Detach();
 MgByteReader* MgServerManager::GetDocument(CREFSTRING identifier)
     Ptr<MgByteReader> pByteReader;
Modified: sandbox/adsk/2.1/Server/src/Common/Manager/ServerManager.h
--- sandbox/adsk/2.1/Server/src/Common/Manager/ServerManager.h	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Server/src/Common/Manager/ServerManager.h	2009-10-28 00:17:22 UTC (rev 4323)
@@ -60,6 +60,8 @@
     void RemoveConfigurationProperties(CREFSTRING propertySection, MgPropertyCollection* properties);
     MgPropertyCollection* GetInformationProperties();
     MgByteReader* GetDocument(CREFSTRING identifier);
     void SetDocument(CREFSTRING identifier, MgByteReader* data);
Modified: sandbox/adsk/2.1/Server/src/Services/ServerAdmin/Makefile.am
--- sandbox/adsk/2.1/Server/src/Services/ServerAdmin/Makefile.am	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Server/src/Services/ServerAdmin/Makefile.am	2009-10-28 00:17:22 UTC (rev 4323)
@@ -34,6 +34,8 @@
   OpGetLogFile.cpp \
   OpGetPackageLog.cpp \
   OpGetPackageStatus.cpp \
+  OpGetSiteStatus.cpp \
+  OpGetSiteVersion.cpp \
   OpIsMaximumLogSizeEnabled.cpp \
   OpIsOnline.cpp \
   OpLoadPackage.cpp \
@@ -68,6 +70,8 @@
   OpGetLogFile.h \
   OpGetPackageLog.h \
   OpGetPackageStatus.h \
+  OpGetSiteStatus.h \
+  OpGetSiteVersion.h \
   OpIsMaximumLogSizeEnabled.h \
   OpIsOnline.h \
   OpLoadPackage.h \
Added: sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteStatus.cpp
--- sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteStatus.cpp	                        (rev 0)
+++ sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteStatus.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -0,0 +1,117 @@
+//  Copyright (C) 2004-2009 by Autodesk, Inc.
+//  This library is free software; you can redistribute it and/or
+//  modify it under the terms of version 2.1 of the GNU Lesser
+//  General Public License as published by the Free Software Foundation.
+//  This library is distributed in the hope that it will be useful,
+//  but WITHOUT ANY WARRANTY; without even the implied warranty of
+//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+//  Lesser General Public License for more details.
+//  You should have received a copy of the GNU Lesser General Public
+//  License along with this library; if not, write to the Free Software
+//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+#include "MapGuideCommon.h"
+#include "ServerAdminService.h"
+#include "OpGetSiteStatus.h"
+#include "LogManager.h"
+/// <summary>
+/// Constructs the object.
+/// </summary>
+MgOpGetSiteStatus::MgOpGetSiteStatus()
+/// <summary>
+/// Destructs the object.
+/// </summary>
+MgOpGetSiteStatus::~MgOpGetSiteStatus()
+/// <summary>
+/// Gets the role(s) required to perform this operation.
+/// </summary>
+MgStringCollection* MgOpGetSiteStatus::GetRoles() const
+    return NULL; // for anonymous/everyone
+/// <summary>
+/// Executes the operation.
+/// </summary>
+/// <exceptions>
+/// MgException
+/// </exceptions>
+void MgOpGetSiteStatus::Execute()
+    ACE_DEBUG((LM_DEBUG, ACE_TEXT("  (%t) MgOpGetSiteStatus::Execute()\n")));
+    MG_LOG_OPERATION_MESSAGE(L"MgOpGetSiteStatus");
+    MG_TRY()
+    MG_LOG_OPERATION_MESSAGE_INIT(m_packet.m_OperationVersion, m_packet.m_NumArguments);
+    ACE_ASSERT(m_stream != NULL);
+    if (0 == m_packet.m_NumArguments)
+        BeginExecution();
+        MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
+        MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
+        // Authentication not required for this operation
+        //Validate();
+        Ptr<MgPropertyCollection> propertyCollection = m_service->GetSiteStatus();
+        EndExecution(propertyCollection);
+    else
+    if (!m_argsRead)
+        throw new MgOperationProcessingException(L"MgOpGetSiteStatus.Execute",
+            __LINE__, __WFILE__, NULL, L"", NULL);
+    // Successful operation
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Success.c_str());
+    MG_CATCH(L"MgOpGetSiteStatus.Execute")
+    if (mgException != NULL)
+        // Failed operation
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Failure.c_str());
+    // Add admin log entry for operation
+    MG_LOG_OPERATION_MESSAGE_ADMIN_ENTRY();
+    MG_THROW()
Property changes on: sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteStatus.cpp
___________________________________________________________________
Added: svn:eol-style
   + native
Added: sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteStatus.h
--- sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteStatus.h	                        (rev 0)
+++ sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteStatus.h	2009-10-28 00:17:22 UTC (rev 4323)
@@ -0,0 +1,36 @@
+#ifndef MGOPGETSITESTATUS_H_
+#define MGOPGETSITESTATUS_H_
+#include "ServerAdminOperation.h"
+class MgOpGetSiteStatus : public MgServerAdminOperation
+    public:
+        MgOpGetSiteStatus();
+        virtual ~MgOpGetSiteStatus();
+    public:
+        virtual void Execute();
+    protected:
+        virtual MgStringCollection* GetRoles() const;
+#endif
Property changes on: sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteStatus.h
   + native
Added: sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteVersion.cpp
--- sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteVersion.cpp	                        (rev 0)
+++ sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteVersion.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -0,0 +1,116 @@
+#include "OpGetSiteVersion.h"
+/// <summary>
+/// </summary>
+MgOpGetSiteVersion::MgOpGetSiteVersion()
+/// <summary>
+/// </summary>
+MgOpGetSiteVersion::~MgOpGetSiteVersion()
+/// <summary>
+/// </summary>
+MgStringCollection* MgOpGetSiteVersion::GetRoles() const
+/// <summary>
+/// </summary>
+/// <exceptions>
+/// MgException
+/// </exceptions>
+void MgOpGetSiteVersion::Execute()
+    ACE_DEBUG((LM_DEBUG, ACE_TEXT("  (%t) MgOpGetSiteVersion::Execute()\n")));
+    MG_LOG_OPERATION_MESSAGE(L"MgOpGetSiteVersion");
+    MG_TRY()
+        BeginExecution();
+        Validate();
+        STRING version = m_service->GetSiteVersion();
+        EndExecution(version);
+    else
+    if (!m_argsRead)
+        throw new MgOperationProcessingException(L"MgOpGetSiteVersion.Execute",
+    MG_CATCH(L"MgOpGetSiteVersion.Execute")
+    MG_THROW()
Property changes on: sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteVersion.cpp
   + native
Added: sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteVersion.h
--- sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteVersion.h	                        (rev 0)
+++ sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteVersion.h	2009-10-28 00:17:22 UTC (rev 4323)
@@ -0,0 +1,36 @@
+#ifndef MGOPGETSITEVERSION_H_
+#define MGOPGETSITEVERSION_H_
+class MgOpGetSiteVersion : public MgServerAdminOperation
+    public:
+        MgOpGetSiteVersion();
+        virtual ~MgOpGetSiteVersion();
+    public:
+    protected:
+#endif
Property changes on: sandbox/adsk/2.1/Server/src/Services/ServerAdmin/OpGetSiteVersion.h
   + native
Modified: sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminOperationFactory.cpp
--- sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminOperationFactory.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminOperationFactory.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -35,6 +35,8 @@
 #include "OpGetLogFile.h"
 #include "OpGetPackageLog.h"
 #include "OpGetPackageStatus.h"
 #include "OpIsMaximumLogSizeEnabled.h"
 #include "OpIsOnline.h"
 #include "OpLoadPackage.h"
@@ -301,6 +303,28 @@
         break;
+    case MgServerAdminServiceOpId::GetSiteVersion:
+        switch (VERSION_NO_PHASE(operationVersion))
+        case VERSION_SUPPORTED(1,0):    // Original 1.0 operation actually called GetInformationProperties
+            handler.reset(new MgOpGetSiteVersion());
+            break;
+        default:
+            break;
+        break;
+    case MgServerAdminServiceOpId::GetSiteStatus:
+        case VERSION_SUPPORTED(2,1):
+            handler.reset(new MgOpGetSiteStatus());
+            break;
+        default:
+            break;
+        break;
     case MgServerAdminServiceOpId::RegisterServicesOnServers :
Modified: sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminService.cpp
--- sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminService.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminService.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -550,6 +550,57 @@
+/// <summary>
+/// </summary>
+STRING MgServerAdminService::GetSiteVersion()
+    STRING version = L"";
+    MG_TRY()
+    MG_LOG_TRACE_ENTRY(L"MgServerAdminService::GetSiteVersion()");
+    MgServerManager* pMan = MgServerManager::GetInstance();
+    if (NULL == pMan)
+        throw new MgNullReferenceException(L"MgServerAdminService::GetSiteVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+    version = pMan->GetSiteVersion();
+    MG_CATCH_AND_THROW(L"MgServerAdminService.GetSiteVersion");
+    return version;
+/// <summary>
+/// </summary>
+MgPropertyCollection* MgServerAdminService::GetSiteStatus()
+    MG_TRY()
+    MG_LOG_TRACE_ENTRY(L"MgServerAdminService::GetSiteStatus()");
+    if (NULL == pMan)
+        throw new MgNullReferenceException(L"MgServerAdminService::GetSiteStatus", __LINE__, __WFILE__, NULL, L"", NULL);
+    pProperties = pMan->GetSiteStatus();
+    MG_CATCH_AND_THROW(L"MgServerAdminService.GetSiteStatus");
 /// <summary>
 /// Registers services on the specified servers.
Modified: sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminService.h
--- sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminService.h	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminService.h	2009-10-28 00:17:22 UTC (rev 4323)
@@ -62,6 +62,8 @@
     // Service Management Methods
Modified: sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminService.vcproj
--- sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminService.vcproj	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminService.vcproj	2009-10-28 00:17:22 UTC (rev 4323)
@@ -955,6 +955,86 @@
 			</File>
 			<File
+				RelativePath=".\OpGetSiteStatus.cpp"
+				<FileConfiguration
+					Name="Debug|Win32"
+					ExcludedFromBuild="true"
+					<Tool
+						Name="VCCLCompilerTool"
+				</FileConfiguration>
+					Name="Debug|x64"
+					<Tool
+					Name="Release|Win32"
+					<Tool
+					Name="Release|x64"
+					<Tool
+			</File>
+			<File
+				RelativePath=".\OpGetSiteStatus.h"
+			</File>
+			<File
+				RelativePath=".\OpGetSiteVersion.cpp"
+					<Tool
+					Name="Debug|x64"
+					<Tool
+					<Tool
+					<Tool
+			</File>
+			<File
+				RelativePath=".\OpGetSiteVersion.h"
+			</File>
+			<File
 				RelativePath=".\OpIsMaximumLogSizeEnabled.cpp"
 				<FileConfiguration
Modified: sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminServiceBuild.cpp
--- sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminServiceBuild.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Server/src/Services/ServerAdmin/ServerAdminServiceBuild.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -32,6 +32,8 @@
 #include "OpGetLogFile.cpp"
 #include "OpGetPackageLog.cpp"
 #include "OpGetPackageStatus.cpp"
+#include "OpGetSiteStatus.cpp"
+#include "OpGetSiteVersion.cpp"
 #include "OpIsOnline.cpp"
 #include "OpIsMaximumLogSizeEnabled.cpp"
 #include "OpLoadPackage.cpp"
Modified: sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteinfoform.html
--- sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteinfoform.html	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteinfoform.html	2009-10-28 00:17:22 UTC (rev 4323)
@@ -13,7 +13,7 @@
         <b>Operation:</b>
         <input type="text" name="OPERATION" value="GETSITEINFO" size="50" ID="Text1">
         <p> Version:
-        <input type="text" name="VERSION" value="1.0.0" size="10" ID="Text2">
+        <input type="text" name="VERSION" value="2.1.0" size="10" ID="Text2">
         <p> Locale:
         <input type="text" name="LOCALE" value="en" size="10" ID="Text4">
         <p> Client Agent:
Added: sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/getsitestatusform.html
--- sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/getsitestatusform.html	                        (rev 0)
+++ sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/getsitestatusform.html	2009-10-28 00:17:22 UTC (rev 4323)
@@ -0,0 +1,25 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
+<html>
+    <head>
+        <title></title>
+        <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+        <meta name="GENERATOR" content="Microsoft Visual Studio .NET 7.1">
+        <meta name="vs_targetSchema" content="http://schemas.microsoft.com/intellisense/ie5">
+        <script type="text/javascript" src="setactiontarget.js" >
+        </script>
+    </head>
+    <body>
+        <form name="input" action="" method="get" ID="Form1">
+        <b>Operation:</b>
+        <input type="text" name="OPERATION" value="GETSITESTATUS" size="50" ID="Text1">
+        <p> Version:
+        <p> Locale:
+        <input type="text" name="LOCALE" value="en" size="10" ID="Text4">
+        <p> Client Agent:
+        <input type="text" name="CLIENTAGENT" value="MapGuide Developer" size="100">
+        <p>
+        <input type="submit" value="Submit" onclick="SetActionTarget()"> <input type="reset">
+        </form>
+    </body>
+</html>
Property changes on: sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/getsitestatusform.html
   + native
Modified: sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteversionform.html
--- sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteversionform.html	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteversionform.html	2009-10-28 00:17:22 UTC (rev 4323)
@@ -13,7 +13,7 @@
         <b>Operation:</b>
         <input type="text" name="OPERATION" value="GETSITEVERSION" size="50" ID="Text1">
         <p> Version:
         <p> Locale:
         <p> Client Agent:
Modified: sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/siteserviceapi.html
--- sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/siteserviceapi.html	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/UnitTest/WebTier/MapAgent/MapAgentForms/siteserviceapi.html	2009-10-28 00:17:22 UTC (rev 4323)
@@ -10,8 +10,9 @@
 <ul>
 <li><a href="enumerateusersform.html" target="showform">EnumerateUsers</a>
 <li><a href="enumerategroupsform.html" target="showform">EnumerateGroups</a>
+<li><a href="getsiteinfoform.html" target="showform">GetSiteInfo</a>
+<li><a href="getsitestatusform.html" target="showform">GetSiteStatus</a>
 <li><a href="getsiteversionform.html" target="showform">GetSiteVersion</a>
-<li><a href="getsiteinfoform.html" target="showform">GetSiteInfo</a>
 </ul>
 </body>
Modified: sandbox/adsk/2.1/Web/src/ApacheAgent/ApacheAgent.cpp
--- sandbox/adsk/2.1/Web/src/ApacheAgent/ApacheAgent.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Web/src/ApacheAgent/ApacheAgent.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -202,6 +202,13 @@
         if (!bValid)
             bValid = params->GetXmlPostData().length() != 0;
+        // Certain operations do not require authentication
+        STRING operation = params->GetParameterValue(L"OPERATION");
+        if((_wcsicmp(operation.c_str(), L"GETSITESTATUS") == 0))
+            bValid = true;
         if (!bValid)
             // Invalid authentication information is not fatal, we should continue.
Modified: sandbox/adsk/2.1/Web/src/CgiAgent/CgiAgent.cpp
--- sandbox/adsk/2.1/Web/src/CgiAgent/CgiAgent.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Web/src/CgiAgent/CgiAgent.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -210,6 +210,13 @@
             if (!bValid)
+                bValid = true;
             if (!bValid)
Modified: sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteInfo.cpp
--- sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteInfo.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteInfo.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -52,14 +52,79 @@
     // Check common parameters
     ValidateCommonParameters();
-    // Create ServerAdmin object
-    Ptr<MgServerAdmin> serverAdmin = new MgServerAdmin();
-    serverAdmin->Open(m_userInfo);
+    STRING xml;
+    xml += BeginXml();
-    // call the C++ APIs
-    Ptr<MgPropertyCollection> properties = serverAdmin->GetInformationProperties();
-    STRING xml = GetXml(properties);
+    if (m_userInfo->GetApiVersion() == MG_API_VERSION(2,1,0))
+        if(siteManager)
+            if(sites)
+                    // Check the server status - though this status could be out of date and an exception might be thrown
+                    bool bHaveSiteInfo = false;
+                    STRING message = MgResources::Unknown;
+                    if (MgSiteInfo::Ok == siteInfo->GetStatus())
+                        MG_HTTP_HANDLER_TRY()
+                        // Create ServerAdmin object
+                        Ptr<MgServerAdmin> serverAdmin = new MgServerAdmin();
+                        serverAdmin->Open(siteInfo->GetTarget(), m_userInfo);
+                        // call the C++ APIs
+                        Ptr<MgPropertyCollection> properties = serverAdmin->GetInformationProperties();
+                        xml += GetXml(properties);
+                        bHaveSiteInfo = true;
+                        MG_HTTP_HANDLER_CATCH(L"MgHttpGetSiteInfo.Execute")
+                            message = mgException->GetMessage();
+                    if(!bHaveSiteInfo)
+                        // This server is not available
+                        xml += L"\t<Server>\n";
+                        xml += L"\t\t<IpAddress>";
+                        xml += siteInfo->GetTarget();
+                        xml += L"</IpAddress>\n";
+                        xml += L"\t\t<DisplayName></DisplayName>\n";
+                        xml += L"\t\t<Status>";
+                        xml += message;
+                        xml += L"</Status>\n";
+                        xml += L"\t\t<Version></Version>\n";
+                        xml += L"\t\t<OperatingSystem></OperatingSystem>\n";
+                        xml += L"\t\t<Statistics></Statistics>\n";
+                        xml += L"\t</Server>\n";
+    else
+        serverAdmin->Open(m_userInfo);
+    xml += EndXml();
     Ptr<MgHttpPrimitiveValue> value = new MgHttpPrimitiveValue(xml);
     if(!value)
         throw new MgOutOfMemoryException(L"", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -69,6 +134,32 @@
     MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGetSiteInfo.Execute")
+STRING MgHttpGetSiteInfo::BeginXml()
+    STRING xml = L"";
+    xml += L"<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n";
+        xml += L"<SiteInformation xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"SiteInformation-2.1.0.xsd\">\n";
+    else
+        xml += L"<SiteInformation xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"SiteInformation-1.0.0.xsd\">\n";
+    return xml;
+STRING MgHttpGetSiteInfo::EndXml()
+    STRING xml = L"";
+    xml = L"</SiteInformation>\n";
+    return xml;
 STRING MgHttpGetSiteInfo::GetXml(MgPropertyCollection* properties)
     STRING xml;
@@ -78,18 +169,23 @@
     Ptr<MgInt32Property> int32Prop;
     Ptr<MgBooleanProperty> boolProp;
-    // this XML follows the SiteInformation-1.0.0.xsd or 2.0.0.xsd schema
-    xml += L"<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n";
-    if (m_userInfo->GetApiVersion() == MG_API_VERSION(2,0,0))
-        xml += L"<SiteInformation xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"SiteInformation-2.0.0.xsd\">\n";
     else
-        xml += L"<SiteInformation xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"SiteInformation-1.0.0.xsd\">\n";
+        xml += L"\t<SiteServer>\n";
-    xml += L"\t<SiteServer>\n";
+        strProp = (MgStringProperty*)properties->GetItem(MgServerInformationProperties::MachineIp);
+        xml += strProp->GetValue();
     xml += L"\t\t<DisplayName>";
     strProp = (MgStringProperty*)properties->GetItem(MgServerInformationProperties::DisplayName);
@@ -138,7 +234,10 @@
     xml += L"\t\t</OperatingSystem>\n";
-    xml += L"\t</SiteServer>\n";
+    if (m_userInfo->GetApiVersion() == MG_API_VERSION(1,0,0))
+        xml += L"\t</SiteServer>\n";
     xml += L"\t<Statistics>\n";
@@ -172,7 +271,7 @@
     xml += MgUtil::MultiByteToWideChar(tmpStr);
     xml += L"</CpuUtilization>\n";
         xml += L"\t\t<WorkingSet>";
         int64Prop = (MgInt64Property*)properties->GetItem(L"WorkingSet");
@@ -225,7 +324,10 @@
     xml += L"\t</Statistics>\n";
-    xml += L"</SiteInformation>\n";
     return xml;
Modified: sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteInfo.h
--- sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteInfo.h	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteInfo.h	2009-10-28 00:17:22 UTC (rev 4323)
@@ -46,6 +46,9 @@
 private:
     STRING GetXml(MgPropertyCollection* properties);
+    STRING BeginXml();
+    STRING EndXml();
 #endif
Added: sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteStatus.cpp
--- sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteStatus.cpp	                        (rev 0)
+++ sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteStatus.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -0,0 +1,163 @@
+#include "HttpHandler.h"
+#include "HttpGetSiteStatus.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGetSiteStatus)
+/// <summary>
+/// Initializes the common parameters and parameters specific to this request.
+/// </summary>
+/// <param name="name">Input
+/// MgHttpRequest
+/// This contains all the parameters of the request.
+/// </param>
+/// <returns>
+/// nothing
+/// </returns>
+MgHttpGetSiteStatus::MgHttpGetSiteStatus(MgHttpRequest *hRequest)
+    InitializeCommonParameters(hRequest);
+/// <summary>
+/// Executes the specific request.
+/// </summary>
+/// <returns>
+/// MgHttpResponse
+/// This contains the response (including MgHttpResult and StatusCode) from the server.
+/// </returns>
+void MgHttpGetSiteStatus::Execute(MgHttpResponse& hResponse)
+    Ptr<MgHttpResult> hResult = hResponse.GetResult();
+    // Check common parameters
+    ValidateCommonParameters();
+    STRING xml = BeginXml();
+    if(siteManager)
+        if(sites)
+                bool bHaveSiteStatus = false;
+                    Ptr<MgPropertyCollection> properties = serverAdmin->GetSiteStatus();
+                    bHaveSiteStatus = true;
+                    MG_HTTP_HANDLER_CATCH(L"MgHttpGetSiteStatus.Execute")
+                if(!bHaveSiteStatus)
+                    xml += message;
+                    xml += L"\t\t<ApiVersion></ApiVersion>\n";
+    xml += EndXml();
+    Ptr<MgHttpPrimitiveValue> value = new MgHttpPrimitiveValue(xml);
+    if(!value)
+        throw new MgOutOfMemoryException(L"", __LINE__, __WFILE__, NULL, L"", NULL);
+    hResult->SetResultObject(value, MgMimeType::Xml);
+    MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGetSiteStatus.Execute")
+STRING MgHttpGetSiteStatus::BeginXml()
+    STRING xml = L"";
+    // this XML follows the SiteStatus-1.0.0.xsd schema
+    xml += L"<SiteStatus xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"SiteStatus-2.1.0.xsd\">\n";
+    return xml;
+STRING MgHttpGetSiteStatus::EndXml()
+    STRING xml = L"";
+    xml = L"</SiteStatus>\n";
+    return xml;
+STRING MgHttpGetSiteStatus::GetXml(MgPropertyCollection* properties)
+    STRING xml = L"";
+    Ptr<MgStringProperty> strProp;
+    Ptr<MgBooleanProperty> boolProp;
+    xml += L"\t\t<DisplayName>";
+    strProp = (MgStringProperty*)properties->GetItem(MgServerInformationProperties::DisplayName);
+    xml += L"</DisplayName>\n";
+    boolProp = (MgBooleanProperty*)properties->GetItem(MgServerInformationProperties::Status);
+    xml += boolProp->GetValue() ? L"Online" : L"Offline";
+    xml += L"\t\t<ApiVersion>";
+    strProp = (MgStringProperty*)properties->GetItem(MgServerInformationProperties::ApiVersion);
+    xml += L"</ApiVersion>\n";
+    return xml;
Property changes on: sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteStatus.cpp
   + native
Added: sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteStatus.h
--- sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteStatus.h	                        (rev 0)
+++ sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteStatus.h	2009-10-28 00:17:22 UTC (rev 4323)
@@ -0,0 +1,52 @@
+#ifndef _S_GET_SITE_STATUS_H
+#define _S_GET_SITE_STATUS_H
+class MgHttpGetSiteStatus : public MgHttpRequestResponseHandler
+HTTP_DECLARE_CREATE_OBJECT()
+public:
+    /// <summary>
+    /// Initializes the common parameters of the request.
+    /// </summary>
+    /// <param name="name">Input
+    /// MgHttpRequest
+    /// This contains all the parameters of the request.
+    /// </param>
+    /// <returns>
+    /// nothing
+    /// </returns>
+    MgHttpGetSiteStatus(MgHttpRequest *hRequest);
+    /// <summary>
+    /// Executes the specific request.
+    /// </summary>
+    /// <param name="hResponse">Input
+    /// This contains the response (including MgHttpResult and StatusCode) from the server.
+    /// </param>
+    void Execute(MgHttpResponse& hResponse);
+private:
+    STRING GetXml(MgPropertyCollection* properties);
+    STRING EndXml();
+#endif
Property changes on: sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteStatus.h
   + native
Modified: sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteVersion.cpp
--- sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteVersion.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteVersion.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -51,14 +51,72 @@
+    STRING xml;
+        if(siteManager)
+            if(sites)
+                    bool bHaveSiteVersion = false;
+                        STRING version = serverAdmin->GetSiteVersion();
+                        xml += GetXml(version);
+                        bHaveSiteVersion = true;
+                    if(!bHaveSiteVersion)
+                        xml += L"\t\t<Version>";
+                        xml += message;
+                        xml += L"</Version>\n";
+    else
+    xml += EndXml();
     if(!value)
@@ -68,18 +126,49 @@
     MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGetSiteVersion.Execute")
-STRING MgHttpGetSiteVersion::GetXml(MgPropertyCollection* properties)
+STRING MgHttpGetSiteVersion::BeginXml()
-    Ptr<MgStringProperty> property = (MgStringProperty*)properties->GetItem(L"ServerVersion");
     STRING xml = L"";
-    // this XML follows the SiteVersion-1.0.0.xsd schema
-    xml += L"<SiteVersion xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"SiteVersion-1.0.0.xsd\">\n";
+        xml += L"<SiteVersion xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"SiteVersion-2.1.0.xsd\">\n";
+    else
+        xml += L"<SiteVersion xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"SiteVersion-1.0.0.xsd\">\n";
+    return xml;
+STRING MgHttpGetSiteVersion::EndXml()
+    STRING xml = L"";
+    xml += L"</SiteVersion>\n";
+    return xml;
+STRING MgHttpGetSiteVersion::GetXml(CREFSTRING version)
+    STRING xml = L"";
     xml += L"\t<Version>";
-    xml += property->GetValue();
+    xml += version;
-    xml += L"</SiteVersion>\n";
     return xml;
Modified: sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteVersion.h
--- sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteVersion.h	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Web/src/HttpHandler/HttpGetSiteVersion.h	2009-10-28 00:17:22 UTC (rev 4323)
@@ -44,7 +44,9 @@
 private:
-    STRING GetXml(MgPropertyCollection* properties);
+    STRING GetXml(CREFSTRING version);
+    STRING EndXml();
Modified: sandbox/adsk/2.1/Web/src/HttpHandler/HttpHandler.vcproj
--- sandbox/adsk/2.1/Web/src/HttpHandler/HttpHandler.vcproj	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Web/src/HttpHandler/HttpHandler.vcproj	2009-10-28 00:17:22 UTC (rev 4323)
@@ -100,9 +100,9 @@
 		</Configuration>
 		<Configuration
-			Name="Release|Win32"
-			OutputDirectory="..\..\bin\release"
-			IntermediateDirectory="..\..\obj\release\HttpHandler"
+			Name="Debug|x64"
+			OutputDirectory="$(PlatformName)\$(ConfigurationName)"
+			IntermediateDirectory="$(PlatformName)\$(ConfigurationName)"
 			ConfigurationType="2"
 			CharacterSet="1"
@@ -120,14 +120,17 @@
 			<Tool
 				Name="VCMIDLTool"
+				TargetEnvironment="3"
 			<Tool
-				Optimization="2"
+				Optimization="0"
 				AdditionalIncludeDirectories="..\..\..\Common\Foundation;..\..\..\Common\Geometry;..\..\..\Common\PlatformBase;..\..\..\Common\MapGuideCommon;..\..\..\Oem\ACE\ACE_wrappers;&quot;..\..\..\Oem\dbxml-2.3.10\xerces-c-src\src&quot;;..\..\..\Oem\jsoncpp\include"
-				PreprocessorDefinitions="WIN32;NDEBUG;_WINDOWS;_USRDLL;MG_MAPAGENT_API_EXPORT"
+				PreprocessorDefinitions="WIN32;_DEBUG;_WINDOWS;_USRDLL;MG_MAPAGENT_API_EXPORT"
+				MinimalRebuild="true"
 				ExceptionHandling="2"
-				RuntimeLibrary="2"
+				BasicRuntimeChecks="3"
+				RuntimeLibrary="3"
 				WarningLevel="3"
 				Detect64BitPortabilityProblems="true"
 				DebugInformationFormat="3"
@@ -143,19 +146,17 @@
 			<Tool
 				Name="VCLinkerTool"
-				AdditionalDependencies="ACE.lib lib_json.lib"
-				OutputFile="$(OutDir)\MgHttpHandler.dll"
-				LinkIncremental="1"
+				AdditionalDependencies="ACEd.lib lib_jsond.lib"
+				OutputFile="$(OutDir)\MgHttpHandlerd.dll"
+				LinkIncremental="2"
 				AdditionalLibraryDirectories="..\..\..\Oem\ACE\ACE_wrappers\lib;&quot;..\..\..\Oem\dbxml-2.3.10\lib&quot;;..\..\..\Oem\jsoncpp\lib"
 				GenerateDebugInformation="true"
-				ProgramDatabaseFile="$(OutDir)\MgHttpHandler.pdb"
+				ProgramDatabaseFile="$(OutDir)\MgHttpHandlerd.pdb"
 				SubSystem="2"
-				OptimizeReferences="2"
-				EnableCOMDATFolding="2"
 				RandomizedBaseAddress="1"
 				DataExecutionPrevention="0"
-				ImportLibrary="..\..\lib\release\HttpHandler.lib"
-				TargetMachine="1"
+				ImportLibrary="..\..\lib\debug\HttpHandlerd.lib"
+				TargetMachine="17"
 			<Tool
 				Name="VCALinkTool"
@@ -180,9 +181,9 @@
 		</Configuration>
 		<Configuration
-			Name="Debug|x64"
-			OutputDirectory="$(PlatformName)\$(ConfigurationName)"
-			IntermediateDirectory="$(PlatformName)\$(ConfigurationName)"
+			OutputDirectory="..\..\bin\release"
+			IntermediateDirectory="..\..\obj\release\HttpHandler"
 			CharacterSet="1"
@@ -200,17 +201,14 @@
 			<Tool
 				Name="VCMIDLTool"
-				TargetEnvironment="3"
 			<Tool
-				Optimization="0"
+				Optimization="2"
-				PreprocessorDefinitions="WIN32;_DEBUG;_WINDOWS;_USRDLL;MG_MAPAGENT_API_EXPORT"
-				MinimalRebuild="true"
+				PreprocessorDefinitions="WIN32;NDEBUG;_WINDOWS;_USRDLL;MG_MAPAGENT_API_EXPORT"
-				BasicRuntimeChecks="3"
-				RuntimeLibrary="3"
+				RuntimeLibrary="2"
 				WarningLevel="3"
@@ -226,17 +224,19 @@
 			<Tool
 				Name="VCLinkerTool"
-				AdditionalDependencies="ACEd.lib lib_jsond.lib"
-				OutputFile="$(OutDir)\MgHttpHandlerd.dll"
-				LinkIncremental="2"
+				AdditionalDependencies="ACE.lib lib_json.lib"
+				OutputFile="$(OutDir)\MgHttpHandler.dll"
+				LinkIncremental="1"
-				ProgramDatabaseFile="$(OutDir)\MgHttpHandlerd.pdb"
+				ProgramDatabaseFile="$(OutDir)\MgHttpHandler.pdb"
 				SubSystem="2"
+				OptimizeReferences="2"
+				EnableCOMDATFolding="2"
-				ImportLibrary="..\..\lib\debug\HttpHandlerd.lib"
-				TargetMachine="17"
+				ImportLibrary="..\..\lib\release\HttpHandler.lib"
+				TargetMachine="1"
 			<Tool
 				Name="VCALinkTool"
@@ -360,7 +360,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -368,7 +368,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -400,7 +400,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -408,7 +408,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -440,7 +440,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -448,7 +448,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -480,7 +480,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -488,7 +488,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -520,7 +520,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -528,7 +528,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -560,7 +560,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -568,7 +568,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -600,7 +600,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -608,7 +608,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -640,7 +640,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -648,7 +648,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -680,7 +680,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -688,7 +688,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -720,7 +720,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -728,7 +728,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -760,7 +760,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -768,7 +768,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -800,7 +800,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -808,7 +808,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -840,7 +840,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -848,7 +848,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -880,7 +880,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -888,7 +888,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -920,7 +920,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -928,7 +928,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -960,7 +960,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -968,7 +968,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1000,7 +1000,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1008,7 +1008,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1040,7 +1040,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1048,7 +1048,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1080,7 +1080,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1088,7 +1088,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1120,7 +1120,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1128,7 +1128,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1160,7 +1160,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1168,7 +1168,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1200,7 +1200,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1208,7 +1208,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1240,7 +1240,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1248,7 +1248,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1280,7 +1280,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1288,7 +1288,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1324,7 +1324,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1332,7 +1332,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1364,7 +1364,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1372,7 +1372,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1404,7 +1404,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1412,7 +1412,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1444,7 +1444,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1452,7 +1452,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1484,7 +1484,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1492,7 +1492,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1524,7 +1524,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1532,7 +1532,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1564,7 +1564,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1572,7 +1572,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1604,7 +1604,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1612,7 +1612,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1644,7 +1644,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1652,7 +1652,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1684,7 +1684,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1692,7 +1692,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1724,7 +1724,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1732,7 +1732,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1764,7 +1764,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1772,7 +1772,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1804,7 +1804,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1812,7 +1812,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1844,7 +1844,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1852,7 +1852,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1884,7 +1884,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1892,7 +1892,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1924,7 +1924,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1932,7 +1932,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -1964,7 +1964,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -1972,7 +1972,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2008,7 +2008,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2016,7 +2016,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2048,7 +2048,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2056,7 +2056,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2088,7 +2088,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2096,7 +2096,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2128,7 +2128,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2136,7 +2136,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2168,7 +2168,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2176,7 +2176,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2208,7 +2208,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2216,7 +2216,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2248,7 +2248,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2256,7 +2256,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2288,7 +2288,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2296,7 +2296,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2328,7 +2328,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2336,7 +2336,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2372,7 +2372,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2380,7 +2380,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2412,7 +2412,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2420,7 +2420,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2452,7 +2452,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2460,7 +2460,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2492,7 +2492,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2500,7 +2500,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2533,20 +2533,20 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
+						GeneratePreprocessedFile="0"
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
-						GeneratePreprocessedFile="0"
 				<FileConfiguration
@@ -2578,7 +2578,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2586,7 +2586,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2618,7 +2618,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2626,7 +2626,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2658,7 +2658,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2666,7 +2666,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2687,7 +2687,7 @@
 			</File>
 			<File
-				RelativePath=".\HttpGetSiteVersion.cpp"
+				RelativePath=".\HttpGetSiteStatus.cpp"
 				<FileConfiguration
 					Name="Debug|Win32"
@@ -2698,6 +2698,14 @@
 				<FileConfiguration
+					Name="Debug|x64"
+					<Tool
@@ -2706,6 +2714,30 @@
 				<FileConfiguration
+					<Tool
+			</File>
+			<File
+				RelativePath=".\HttpGetSiteStatus.h"
+			</File>
+			<File
+				RelativePath=".\HttpGetSiteVersion.cpp"
+					<Tool
 					Name="Debug|x64"
@@ -2714,6 +2746,14 @@
 				<FileConfiguration
+					<Tool
 					Name="Release|x64"
@@ -2742,7 +2782,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2750,7 +2790,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2782,7 +2822,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2790,7 +2830,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2822,7 +2862,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2830,7 +2870,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2866,7 +2906,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2874,7 +2914,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2906,7 +2946,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2914,7 +2954,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2946,7 +2986,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2954,7 +2994,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -2986,7 +3026,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -2994,7 +3034,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3026,7 +3066,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3034,7 +3074,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3070,7 +3110,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3078,7 +3118,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3110,7 +3150,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3118,7 +3158,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3150,7 +3190,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3158,7 +3198,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3190,7 +3230,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3198,7 +3238,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3230,7 +3270,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3238,7 +3278,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3270,7 +3310,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3278,7 +3318,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3310,7 +3350,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3318,7 +3358,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3350,7 +3390,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3358,7 +3398,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3390,7 +3430,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3398,7 +3438,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3430,7 +3470,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3438,7 +3478,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3482,7 +3522,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3490,7 +3530,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3522,7 +3562,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3530,7 +3570,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3562,7 +3602,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3570,7 +3610,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3602,7 +3642,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3610,7 +3650,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3642,7 +3682,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3650,7 +3690,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3694,7 +3734,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3702,7 +3742,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3734,7 +3774,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3742,7 +3782,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3774,7 +3814,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3782,7 +3822,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3814,7 +3854,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3822,7 +3862,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3854,7 +3894,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3862,7 +3902,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3894,7 +3934,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3902,7 +3942,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3934,7 +3974,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3942,7 +3982,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -3978,7 +4018,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -3986,7 +4026,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4022,7 +4062,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -4030,7 +4070,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4062,7 +4102,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -4070,7 +4110,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4106,7 +4146,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -4114,7 +4154,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4146,7 +4186,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -4154,7 +4194,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4186,7 +4226,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -4194,7 +4234,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4230,7 +4270,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -4238,7 +4278,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4270,7 +4310,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -4278,7 +4318,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4310,7 +4350,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -4318,7 +4358,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4350,7 +4390,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -4358,7 +4398,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4390,7 +4430,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -4398,7 +4438,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4430,7 +4470,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -4438,7 +4478,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4470,7 +4510,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -4478,7 +4518,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4510,7 +4550,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -4518,7 +4558,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4554,7 +4594,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -4562,7 +4602,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4594,7 +4634,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -4602,7 +4642,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4634,7 +4674,7 @@
 				<FileConfiguration
+					Name="Debug|x64"
 					<Tool
@@ -4642,7 +4682,7 @@
 				<FileConfiguration
-					Name="Debug|x64"
 					<Tool
@@ -4695,7 +4735,7 @@
 			<FileConfiguration
+				Name="Debug|x64"
 				<Tool
@@ -4703,7 +4743,7 @@
 			<FileConfiguration
-				Name="Debug|x64"
 				<Tool
@@ -4735,7 +4775,7 @@
 			<FileConfiguration
+				Name="Debug|x64"
 				<Tool
@@ -4743,7 +4783,7 @@
 			<FileConfiguration
-				Name="Debug|x64"
 				<Tool
@@ -4779,7 +4819,7 @@
 			<FileConfiguration
+				Name="Debug|x64"
 				<Tool
@@ -4787,7 +4827,7 @@
 			<FileConfiguration
-				Name="Debug|x64"
 				<Tool
@@ -4819,7 +4859,7 @@
 			<FileConfiguration
+				Name="Debug|x64"
 				<Tool
@@ -4827,7 +4867,7 @@
 			<FileConfiguration
-				Name="Debug|x64"
 				<Tool
@@ -4859,7 +4899,7 @@
 			<FileConfiguration
+				Name="Debug|x64"
 				<Tool
@@ -4867,7 +4907,7 @@
 			<FileConfiguration
-				Name="Debug|x64"
 				<Tool
@@ -4899,7 +4939,7 @@
 			<FileConfiguration
+				Name="Debug|x64"
 				<Tool
@@ -4907,7 +4947,7 @@
 			<FileConfiguration
-				Name="Debug|x64"
 				<Tool
@@ -4939,7 +4979,7 @@
 			<FileConfiguration
+				Name="Debug|x64"
 				<Tool
@@ -4947,7 +4987,7 @@
 			<FileConfiguration
-				Name="Debug|x64"
 				<Tool
@@ -4979,7 +5019,7 @@
 			<FileConfiguration
+				Name="Debug|x64"
 				<Tool
@@ -4987,7 +5027,7 @@
 			<FileConfiguration
-				Name="Debug|x64"
 				<Tool
@@ -5019,7 +5059,7 @@
 			<FileConfiguration
+				Name="Debug|x64"
 				<Tool
@@ -5027,7 +5067,7 @@
 			<FileConfiguration
-				Name="Debug|x64"
 				<Tool
@@ -5063,7 +5103,7 @@
 			<FileConfiguration
+				Name="Debug|x64"
 				<Tool
@@ -5071,7 +5111,7 @@
 			<FileConfiguration
-				Name="Debug|x64"
 				<Tool
@@ -5103,7 +5143,7 @@
 			<FileConfiguration
+				Name="Debug|x64"
 				<Tool
@@ -5111,7 +5151,7 @@
 			<FileConfiguration
-				Name="Debug|x64"
 				<Tool
@@ -5143,7 +5183,7 @@
 			<FileConfiguration
+				Name="Debug|x64"
 				<Tool
@@ -5151,7 +5191,7 @@
 			<FileConfiguration
-				Name="Debug|x64"
 				<Tool
Modified: sandbox/adsk/2.1/Web/src/HttpHandler/HttpHandlerBuild.cpp
--- sandbox/adsk/2.1/Web/src/HttpHandler/HttpHandlerBuild.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Web/src/HttpHandler/HttpHandlerBuild.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -84,6 +84,7 @@
 #include "HttpGetIdentityProperties.cpp"
 #include "HttpGetSchemaMapping.cpp"
 #include "HttpGetSiteInfo.cpp"
+#include "HttpGetSiteStatus.cpp"
 #include "HttpGetSiteVersion.cpp"
 #include "HttpGetSpatialContexts.cpp"
 #include "HttpGetTileImage.cpp"
Modified: sandbox/adsk/2.1/Web/src/HttpHandler/HttpRequest.cpp
--- sandbox/adsk/2.1/Web/src/HttpHandler/HttpRequest.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Web/src/HttpHandler/HttpRequest.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -352,6 +352,7 @@
     httpClassCreators[MgHttpResourceStrings::opEnumerateGroups] = MgHttpEnumerateGroups::CreateObject;
     httpClassCreators[MgHttpResourceStrings::opGetSiteVersion] = MgHttpGetSiteVersion::CreateObject;
     httpClassCreators[MgHttpResourceStrings::opGetSiteInfo] = MgHttpGetSiteInfo::CreateObject;
+    httpClassCreators[MgHttpResourceStrings::opGetSiteStatus] = MgHttpGetSiteStatus::CreateObject;
     httpClassCreators[MgHttpResourceStrings::opGetDrawingCoordinateSpace] = MgHttpGetDrawingCoordinateSpace::CreateObject;
     httpClassCreators[MgHttpResourceStrings::opCreateSession] = MgHttpCreateSession::CreateObject;
     httpClassCreators[MgHttpResourceStrings::opGetDwfViewerPage] = MgHttpGetDwfViewerPage::CreateObject;
Modified: sandbox/adsk/2.1/Web/src/HttpHandler/HttpRequestResponseHandler.cpp
--- sandbox/adsk/2.1/Web/src/HttpHandler/HttpRequestResponseHandler.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Web/src/HttpHandler/HttpRequestResponseHandler.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -230,7 +230,8 @@
     INT32 version = m_userInfo->GetApiVersion();
     if (version != MG_API_VERSION(1,0,0) &&
         version != MG_API_VERSION(1,2,0) &&
-        version != MG_API_VERSION(2,0,0))
+        version != MG_API_VERSION(2,0,0) &&
+        version != MG_API_VERSION(2,1,0))
         throw new MgInvalidOperationVersionException(
         L"MgHttpRequestResponseHandler.ValidateOperationVersion", __LINE__, __WFILE__, NULL, L"", NULL);
Modified: sandbox/adsk/2.1/Web/src/HttpHandler/HttpResourceStrings.cpp
--- sandbox/adsk/2.1/Web/src/HttpHandler/HttpResourceStrings.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Web/src/HttpHandler/HttpResourceStrings.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -321,6 +321,7 @@
 const STRING MgHttpResourceStrings::opEnumerateGroups = L"ENUMERATEGROUPS";
 const STRING MgHttpResourceStrings::opGetSiteVersion = L"GETSITEVERSION";
 const STRING MgHttpResourceStrings::opGetSiteInfo = L"GETSITEINFO";
+const STRING MgHttpResourceStrings::opGetSiteStatus = L"GETSITESTATUS";
 // Other requests
 const STRING MgHttpResourceStrings::opCreateSession = L"CREATESESSION";
Modified: sandbox/adsk/2.1/Web/src/HttpHandler/HttpResourceStrings.h
--- sandbox/adsk/2.1/Web/src/HttpHandler/HttpResourceStrings.h	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Web/src/HttpHandler/HttpResourceStrings.h	2009-10-28 00:17:22 UTC (rev 4323)
@@ -326,6 +326,7 @@
     static const STRING opEnumerateGroups;
     static const STRING opGetSiteVersion;
     static const STRING opGetSiteInfo;
+    static const STRING opGetSiteStatus;
     // Other requests
     static const STRING opCreateSession;
Modified: sandbox/adsk/2.1/Web/src/HttpHandler/Makefile.am
--- sandbox/adsk/2.1/Web/src/HttpHandler/Makefile.am	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Web/src/HttpHandler/Makefile.am	2009-10-28 00:17:22 UTC (rev 4323)
@@ -83,6 +83,7 @@
   HttpGetSchemaMapping.cpp \
   HttpGetSchemas.cpp \
   HttpGetSiteInfo.cpp \
+  HttpGetSiteStatus.cpp \
   HttpGetSiteVersion.cpp \
   HttpGetSpatialContexts.cpp \
   HttpGetTileImage.cpp \
@@ -203,6 +204,7 @@
   HttpGetSchemaMapping.h \
   HttpGetSchemas.h \
   HttpGetSiteInfo.h \
+  HttpGetSiteStatus.h \
   HttpGetSiteVersion.h \
   HttpGetSpatialContexts.h \
   HttpGetTileImage.h \
Modified: sandbox/adsk/2.1/Web/src/IsapiAgent/IsapiAgent.cpp
--- sandbox/adsk/2.1/Web/src/IsapiAgent/IsapiAgent.cpp	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Web/src/IsapiAgent/IsapiAgent.cpp	2009-10-28 00:17:22 UTC (rev 4323)
@@ -169,6 +169,13 @@
         if (!bValid)
+            bValid = true;
         if (!bValid)
Modified: sandbox/adsk/2.1/Web/src/viewerfiles/ajaxmappane.templ
--- sandbox/adsk/2.1/Web/src/viewerfiles/ajaxmappane.templ	2009-10-27 19:04:39 UTC (rev 4322)
+++ sandbox/adsk/2.1/Web/src/viewerfiles/ajaxmappane.templ	2009-10-28 00:17:22 UTC (rev 4323)
@@ -1662,7 +1662,7 @@
     url = webAgent + "?OPERATION=GETDYNAMICMAPOVERLAYIMAGE&FORMAT=PNG&VERSION=2.1.0&SESSION=" + sessionId + "&MAPNAME=" + encodeComponent(mapName) + "&SEQ=" + Math.random() + "&CLIENTAGENT=" + encodeComponent(clientAgent) + "&BEHAVIOR=2";
     url += viewParams;
     document.getElementById("overlay").innerHTML =
-            '<img class="mapImage" name="' + reqId + '" id="mapImage" src="' + url + '" width=' + mapDevW + ' height=' + mapDevH + ' border=0 vspace=0 hspace=0 style="visibility: hidden; width: ' + mapDevW + 'px; height: ' + mapDevH + 'px;" onload="return OnMapOverlayImageLoaded(event)">';
+            '<img class="mapImage" name="' + reqId + '" id="mapImage" src="' + url + '" width=' + mapDevW + ' height=' + mapDevH + ' border=0 vspace=0 hspace=0 style="visibility: hidden; width: ' + mapDevW + 'px; height: ' + mapDevH + 'px;" onload="return OnMapOverlayImageLoaded(event)" onerror="return OnMapOverlayImageLoadedError(event)">';
     if (opera)
         document.getElementById("mapImage").src = document.getElementById("mapImage").src;
@@ -1672,7 +1672,7 @@
     url = webAgent + "?OPERATION=GETDYNAMICMAPOVERLAYIMAGE&FORMAT=PNG&VERSION=2.1.0&SESSION=" + sessionId + "&MAPNAME=" + encodeComponent(mapName) + "&SEQ=" + Math.random() + "&CLIENTAGENT=" + encodeComponent(clientAgent) + "&BEHAVIOR=5&SELECTIONCOLOR=" + selectionColor;
     url += viewParams;
     document.getElementById('selOverlay').innerHTML =
-        '<img class="mapImage" name="' + reqId + '" id="selectionImage" src="' + url + '" width=' + mapDevW + ' height=' + mapDevH + ' border=0 vspace=0 hspace=0 style="visibility: hidden; width: ' + mapDevW + 'px; height: ' + mapDevH + 'px;" onload="return OnSelectionOverlayImageLoaded(event)">';
+        '<img class="mapImage" name="' + reqId + '" id="selectionImage" src="' + url + '" width=' + mapDevW + ' height=' + mapDevH + ' border=0 vspace=0 hspace=0 style="visibility: hidden; width: ' + mapDevW + 'px; height: ' + mapDevH + 'px;" onload="return OnSelectionOverlayImageLoaded(event)" onerror="return OnSelectionOverlayImageLoadedError(event)">';
     if (opera)
         document.getElementById("selectionImage").src = document.getElementById("selectionImage").src;
@@ -1737,6 +1737,28 @@
     return false;
+function OnMapOverlayImageLoadedError(e)
+    var frmParent = parent.frames["tbFrame"];
+    var objDivRefresh = frmParent.document.getElementById("divRefresh");
+    if(objDivRefresh != null)
+        objDivRefresh.style.display='none';
+    mapLoading = false;
+    var text = this.req.responseText;
+    var startPos = text.indexOf("<h2>");
+    startPos = startPos + 4;
+    var endPos = text.indexOf("</h2>", startPos);
+    var message = text.substring(startPos, endPos);
+    alert(message);
+    return false;
 function OnSelectionOverlayImageLoaded(e)
     if(msie)
@@ -1785,6 +1807,20 @@
     return false;
+function OnSelectionOverlayImageLoadedError(e)
+    alert(message);
+    return false;
 function OnAlternateImageLoaded()
     altimg = document.getElementById(curimg == "mapImage1"? "mapImage2": "mapImage1");
@@ -1821,7 +1857,12 @@
 function RequestFailed(text)
-    //placeholder for debugging output
+    alert(message);
 function DraggingShape(e)
@@ -2646,12 +2687,12 @@
     selRequest.setRequestHeader("Content-Type", "application/x-www-form-urlencoded");
     selRequest.send(reqParams);
-    if(selRequest.responseXML)
+    if(selRequest.status == 200)
         ProcessFeatureInfo(selRequest.responseXML.documentElement, append, which);
     else
-        RequestFailed("No response");
+        RequestFailed(selRequest.responseText);
 function CompareProperties(p1, p2)
@@ -2838,8 +2879,14 @@
     reqHandler.open("POST", setSelScript, false);
     reqHandler.setRequestHeader("Content-Type", "application/x-www-form-urlencoded");
     reqHandler.send(reqParams);
-    if(requery)
-        return reqHandler.responseXML;
+    if(reqHandler.status == 200)
+        if(requery)
+            return reqHandler.responseXML;
+    else
+        RequestFailed(reqHandler.responseText);
 function ZoomSelection()
@@ -2855,7 +2902,7 @@
     dr.setRequestHeader("Content-Type", "application/x-www-form-urlencoded");
     dr.send(reqParams);
-    if(dr.responseXML)
+    if(dr.status == 200)
         var env = ParseEnvelope(dr.responseXML.documentElement);
         if(env != null)
@@ -2868,6 +2915,8 @@
             GotoView(centerX, centerY, scale, true, true);
+    else
+        RequestFailed(dr.responseText);
 function ParseEnvelope(xmlRoot)
More information about the mapguide-commits mailing list
