[mapguide-commits] r4753 - trunk/MgDev
svn_mapguide at osgeo.org
Wed Apr 7 14:59:17 EDT 2010
Author: trevorwekel
Date: 2010-04-07 14:59:15 -0400 (Wed, 07 Apr 2010)
New Revision: 4753
Added:
trunk/MgDev/License.txt
Ticket #1295 Improve build scripts for 2.2 release cycle
- Added plain text conversion of License.html for Ubuntu packaging
Added: trunk/MgDev/License.txt
--- trunk/MgDev/License.txt (rev 0)
+++ trunk/MgDev/License.txt 2010-04-07 18:59:15 UTC (rev 4753)
@@ -0,0 +1,1329 @@
+Copyright and Licensing Information for MapGuide Open Source
+Copyright (C) 2004-2010 by Autodesk, Inc.
+ MapGuide Open Source is free software; you can redistribute it
+ and/or modify it under the terms of version 2.1 of the GNU Lesser
+ General Public License (LGPL) as published by the Free Software
+ Foundation. It is distributed in the hope that it will be useful,
+ but WITHOUT ANY WARRANTY; without even the implied warranty of
+ MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
+ The full text of the LGPL can be found at the bottom of this file.
+ "Autodesk MapGuide" is a registered trademark of Autodesk, Inc.
+ and nothing herein shall grant any license or permission to use
+ such trademark.
+***Third Party Credits***
+MapGuide Open Source also contains third party software that is
+licensed by the copyright holder on terms specific to that software.
+You are responsible for complying with the terms of these licenses.
+For ease of reference, this file contains information on all of these
+third party licenses.
+Simplified Wrapper and Interface Generator (SWIG)
+ SWIG is distributed under the following terms:
+ I.
+ This software includes contributions that are Copyright (c) 1998-2002
+ University of Chicago.
+ All rights reserved.
+ Redistribution and use in source and binary forms, with or without
+ modification, are permitted provided that the following conditions are
+ met:
+ Redistributions of source code must retain the above copyright notice,
+ this list of conditions and the following disclaimer. Redistributions
+ in binary form must reproduce the above copyright notice, this list of
+ conditions and the following disclaimer in the documentation and/or
+ other materials provided with the distribution. Neither the name of
+ the University of Chicago nor the names of its contributors may be
+ used to endorse or promote products derived from this software without
+ specific prior written permission.
+ THIS SOFTWARE IS PROVIDED BY THE UNIVERSITY OF CHICAGO AND CONTRIBUTORS
+ "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
+ PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE UNIVERSITY OF
+ CHICAGO OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED
+ TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
+ PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
+ LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
+ NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
+ SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ II.
+ Copyright (c) 1995-1998
+ The University of Utah and the Regents of the University of California
+ All Rights Reserved
+ Permission is hereby granted, without written agreement and without
+ license or royalty fees, to use, copy, modify, and distribute this
+ software and its documentation for any purpose, provided that
+ (1) The above copyright notice and the following two paragraphs
+ appear in all copies of the source code and (2) redistributions
+ including binaries reproduces these notices in the supporting
+ documentation. Substantial modifications to this software may be
+ copyrighted by their authors and need not follow the licensing terms
+ described here, provided that the new terms are clearly indicated in
+ all files where they apply.
+ IN NO EVENT SHALL THE AUTHOR, THE UNIVERSITY OF CALIFORNIA, THE
+ UNIVERSITY OF UTAH OR DISTRIBUTORS OF THIS SOFTWARE BE LIABLE TO ANY
+ PARTY FOR DIRECT, INDIRECT, SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
+ DAMAGES ARISING OUT OF THE USE OF THIS SOFTWARE AND ITS DOCUMENTATION,
+ EVEN IF THE AUTHORS OR ANY OF THE ABOVE PARTIES HAVE BEEN ADVISED OF
+ THE POSSIBILITY OF SUCH DAMAGE.
+ THE AUTHOR, THE UNIVERSITY OF CALIFORNIA, AND THE UNIVERSITY OF UTAH
+ SPECIFICALLY DISCLAIM ANY WARRANTIES,INCLUDING, BUT NOT LIMITED TO,
+ THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
+ PURPOSE. THE SOFTWARE PROVIDED HEREUNDER IS ON AN "AS IS" BASIS, AND
+ THE AUTHORS AND DISTRIBUTORS HAVE NO OBLIGATION TO PROVIDE MAINTENANCE,
+ SUPPORT, UPDATES, ENHANCEMENTS, OR MODIFICATIONS.
+Copyright and Licensing Information for ACE(TM)
+ACE(TM), TAO(TM), CIAO(TM), and CoSMIC(TM) (henceforth referred to as "DOC
+software") are copyrighted by Douglas C. Schmidt and his research group at
+Washington University, University of California, Irvine, and Vanderbilt
+University, Copyright (c) 1993-2005, all rights reserved. Since DOC software is
+open-source, freely available software, you are free to use, modify, copy, and
+distribute--perpetually and irrevocably--the DOC software source code and object
+code produced from the source, as well as copy and distribute modified versions
+of this software. You must, however, include this copyright statement along with
+code built using DOC software.
+You can use DOC software in commercial and/or binary software releases and are
+under no obligation to redistribute any of your source code that is built using
+DOC software. Note, however, that you may not do anything to the DOC software
+code, such as copyrighting it yourself or claiming authorship of the DOC
+software code, that will prevent DOC software from being distributed freely
+using an open-source development model. You needn't inform anyone that you're
+using DOC software in your software, though we encourage you to let us know so
+we can promote your project in the DOC software success stories.
+Berkeley DB
+ * Copyright (c) 1990-2004
+ * Sleepycat Software. All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following conditions
+ * are met:
+ * 1. Redistributions of source code must retain the above copyright
+ * notice, this list of conditions and the following disclaimer.
+ * 2. Redistributions in binary form must reproduce the above copyright
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * 3. Redistributions in any form must be accompanied by information on
+ * how to obtain complete source code for the DB software and any
+ * accompanying software that uses the DB software. The source code
+ * must either be included in the distribution or be available for no
+ * more than the cost of distribution plus a nominal fee, and must be
+ * freely redistributable under reasonable conditions. For an
+ * executable file, complete source code means the source code for all
+ * modules it contains. It does not include source code for modules or
+ * files that typically accompany the major components of the operating
+ * system on which the executable file runs.
+ * THIS SOFTWARE IS PROVIDED BY SLEEPYCAT SOFTWARE ``AS IS'' AND ANY EXPRESS
+ * OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
+ * WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR
+ * NON-INFRINGEMENT, ARE DISCLAIMED. IN NO EVENT SHALL SLEEPYCAT SOFTWARE
+ * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+ * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+ * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+ * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+ * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
+ * THE POSSIBILITY OF SUCH DAMAGE.
+ * Copyright (c) 1990, 1993, 1994, 1995
+ * The Regents of the University of California. All rights reserved.
+ * are met:
+ * 3. Neither the name of the University nor the names of its contributors
+ * may be used to endorse or promote products derived from this software
+ * without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+ * ARE DISCLAIMED. IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * Copyright (c) 1995, 1996
+ * The President and Fellows of Harvard University. All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY HARVARD AND ITS CONTRIBUTORS ``AS IS'' AND
+ * ARE DISCLAIMED. IN NO EVENT SHALL HARVARD OR ITS CONTRIBUTORS BE LIABLE
+ * SUCH DAMAGE.
+Berkeley DB XML
+ * Copyright (c) 2001-2005
+ * are met:
+ * The Apache Software License, Version 1.1
+ * Copyright (c) 2000 The Apache Software Foundation. All rights
+ * reserved.
+ * are met:
+ * the documentation and/or other materials provided with the
+ * distribution.
+ * 3. The end-user documentation included with the redistribution,
+ * if any, must include the following acknowledgment:
+ * "This product includes software developed by the
+ * Apache Software Foundation (http://www.apache.org/)."
+ * Alternately, this acknowledgment may appear in the software itself,
+ * if and wherever such third-party acknowledgments normally appear.
+ * 4. The names "Apache" and "Apache Software Foundation" must
+ * not be used to endorse or promote products derived from this
+ * software without prior written permission. For written
+ * permission, please contact apache at apache.org.
+ * 5. Products derived from this software may not be called "Apache",
+ * nor may "Apache" appear in their name, without prior written
+ * permission of the Apache Software Foundation.
+ * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
+ * DISCLAIMED. IN NO EVENT SHALL THE APACHE SOFTWARE FOUNDATION OR
+ * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
+ * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
+ * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
+ * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * This software consists of voluntary contributions made by many
+ * individuals on behalf of the Apache Software Foundation. For more
+ * information on the Apache Software Foundation, please see
+ * Portions of this software are based upon public domain software
+ * originally written at the National Center for Supercomputing Applications,
+ * University of Illinois, Urbana-Champaign.
+Xerxes, Xalan & Apache Tomcat
+ Apache License
+ Version 2.0, January 2004
+ http://www.apache.org/licenses/
+ TERMS AND CONDITIONS FOR USE, REPRODUCTION, AND DISTRIBUTION
+ 1. Definitions.
+ "License" shall mean the terms and conditions for use, reproduction,
+ and distribution as defined by Sections 1 through 9 of this document.
+ "Licensor" shall mean the copyright owner or entity authorized by
+ the copyright owner that is granting the License.
+ "Legal Entity" shall mean the union of the acting entity and all
+ other entities that control, are controlled by, or are under common
+ control with that entity. For the purposes of this definition,
+ "control" means (i) the power, direct or indirect, to cause the
+ direction or management of such entity, whether by contract or
+ otherwise, or (ii) ownership of fifty percent (50%) or more of the
+ outstanding shares, or (iii) beneficial ownership of such entity.
+ "You" (or "Your") shall mean an individual or Legal Entity
+ exercising permissions granted by this License.
+ "Source" form shall mean the preferred form for making modifications,
+ including but not limited to software source code, documentation
+ source, and configuration files.
+ "Object" form shall mean any form resulting from mechanical
+ transformation or translation of a Source form, including but
+ not limited to compiled object code, generated documentation,
+ and conversions to other media types.
+ "Work" shall mean the work of authorship, whether in Source or
+ Object form, made available under the License, as indicated by a
+ copyright notice that is included in or attached to the work
+ (an example is provided in the Appendix below).
+ "Derivative Works" shall mean any work, whether in Source or Object
+ form, that is based on (or derived from) the Work and for which the
+ editorial revisions, annotations, elaborations, or other modifications
+ represent, as a whole, an original work of authorship. For the purposes
+ of this License, Derivative Works shall not include works that remain
+ separable from, or merely link (or bind by name) to the interfaces of,
+ the Work and Derivative Works thereof.
+ "Contribution" shall mean any work of authorship, including
+ the original version of the Work and any modifications or additions
+ to that Work or Derivative Works thereof, that is intentionally
+ submitted to Licensor for inclusion in the Work by the copyright owner
+ or by an individual or Legal Entity authorized to submit on behalf of
+ the copyright owner. For the purposes of this definition, "submitted"
+ means any form of electronic, verbal, or written communication sent
+ to the Licensor or its representatives, including but not limited to
+ communication on electronic mailing lists, source code control systems,
+ and issue tracking systems that are managed by, or on behalf of, the
+ Licensor for the purpose of discussing and improving the Work, but
+ excluding communication that is conspicuously marked or otherwise
+ designated in writing by the copyright owner as "Not a Contribution."
+ "Contributor" shall mean Licensor and any individual or Legal Entity
+ on behalf of whom a Contribution has been received by Licensor and
+ subsequently incorporated within the Work.
+ 2. Grant of Copyright License. Subject to the terms and conditions of
+ this License, each Contributor hereby grants to You a perpetual,
+ worldwide, non-exclusive, no-charge, royalty-free, irrevocable
+ copyright license to reproduce, prepare Derivative Works of,
+ publicly display, publicly perform, sublicense, and distribute the
+ Work and such Derivative Works in Source or Object form.
+ 3. Grant of Patent License. Subject to the terms and conditions of
+ (except as stated in this section) patent license to make, have made,
+ use, offer to sell, sell, import, and otherwise transfer the Work,
+ where such license applies only to those patent claims licensable
+ by such Contributor that are necessarily infringed by their
+ Contribution(s) alone or by combination of their Contribution(s)
+ with the Work to which such Contribution(s) was submitted. If You
+ institute patent litigation against any entity (including a
+ cross-claim or counterclaim in a lawsuit) alleging that the Work
+ or a Contribution incorporated within the Work constitutes direct
+ or contributory patent infringement, then any patent licenses
+ granted to You under this License for that Work shall terminate
+ as of the date such litigation is filed.
+ 4. Redistribution. You may reproduce and distribute copies of the
+ Work or Derivative Works thereof in any medium, with or without
+ modifications, and in Source or Object form, provided that You
+ meet the following conditions:
+ (a) You must give any other recipients of the Work or
+ Derivative Works a copy of this License; and
+ (b) You must cause any modified files to carry prominent notices
+ stating that You changed the files; and
+ (c) You must retain, in the Source form of any Derivative Works
+ that You distribute, all copyright, patent, trademark, and
+ attribution notices from the Source form of the Work,
+ excluding those notices that do not pertain to any part of
+ the Derivative Works; and
+ (d) If the Work includes a "NOTICE" text file as part of its
+ distribution, then any Derivative Works that You distribute must
+ include a readable copy of the attribution notices contained
+ within such NOTICE file, excluding those notices that do not
+ pertain to any part of the Derivative Works, in at least one
+ of the following places: within a NOTICE text file distributed
+ as part of the Derivative Works; within the Source form or
+ documentation, if provided along with the Derivative Works; or,
+ within a display generated by the Derivative Works, if and
+ wherever such third-party notices normally appear. The contents
+ of the NOTICE file are for informational purposes only and
+ do not modify the License. You may add Your own attribution
+ notices within Derivative Works that You distribute, alongside
+ or as an addendum to the NOTICE text from the Work, provided
+ that such additional attribution notices cannot be construed
+ as modifying the License.
+ You may add Your own copyright statement to Your modifications and
+ may provide additional or different license terms and conditions
+ for use, reproduction, or distribution of Your modifications, or
+ for any such Derivative Works as a whole, provided Your use,
+ reproduction, and distribution of the Work otherwise complies with
+ the conditions stated in this License.
+ 5. Submission of Contributions. Unless You explicitly state otherwise,
+ any Contribution intentionally submitted for inclusion in the Work
+ by You to the Licensor shall be under the terms and conditions of
+ this License, without any additional terms or conditions.
+ Notwithstanding the above, nothing herein shall supersede or modify
+ the terms of any separate license agreement you may have executed
+ with Licensor regarding such Contributions.
+ 6. Trademarks. This License does not grant permission to use the trade
+ names, trademarks, service marks, or product names of the Licensor,
+ except as required for reasonable and customary use in describing the
+ origin of the Work and reproducing the content of the NOTICE file.
+ 7. Disclaimer of Warranty. Unless required by applicable law or
+ agreed to in writing, Licensor provides the Work (and each
+ Contributor provides its Contributions) on an "AS IS" BASIS,
+ WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or
+ implied, including, without limitation, any warranties or conditions
+ of TITLE, NON-INFRINGEMENT, MERCHANTABILITY, or FITNESS FOR A
+ PARTICULAR PURPOSE. You are solely responsible for determining the
+ appropriateness of using or redistributing the Work and assume any
+ risks associated with Your exercise of permissions under this License.
+ 8. Limitation of Liability. In no event and under no legal theory,
+ whether in tort (including negligence), contract, or otherwise,
+ unless required by applicable law (such as deliberate and grossly
+ negligent acts) or agreed to in writing, shall any Contributor be
+ liable to You for damages, including any direct, indirect, special,
+ incidental, or consequential damages of any character arising as a
+ result of this License or out of the use or inability to use the
+ Work (including but not limited to damages for loss of goodwill,
+ work stoppage, computer failure or malfunction, or any and all
+ other commercial damages or losses), even if such Contributor
+ has been advised of the possibility of such damages.
+ 9. Accepting Warranty or Additional Liability. While redistributing
+ the Work or Derivative Works thereof, You may choose to offer,
+ and charge a fee for, acceptance of support, warranty, indemnity,
+ or other liability obligations and/or rights consistent with this
+ License. However, in accepting such obligations, You may act only
+ on Your own behalf and on Your sole responsibility, not on behalf
+ of any other Contributor, and only if You agree to indemnify,
+ defend, and hold each Contributor harmless for any liability
+ incurred by, or claims asserted against, such Contributor by reason
+ of your accepting any such warranty or additional liability.
+ END OF TERMS AND CONDITIONS
+Pathan
+The DecisionSoft Open Source Licence
+This licence is based on the BSD Licence template.
+Copyright (c) 2001, DecisionSoft Limited
+All rights reserved.
+Redistribution and use in source and binary forms, with or without
+modification, are permitted provided that the following conditions are
+met:
+* Redistributions of source code must retain the above copyright
+notice, this list of conditions and the following disclaimer.
+* Redistributions in binary form must reproduce the above copyright
+notice, this list of conditions and the following disclaimer in the
+documentation and/or other materials provided with the distribution.
+* Neither the name of DecisionSoft Limited nor the names of its
+contributors may be used to endorse or promote products derived from
+this software without specific prior written permission.
+THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+"AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
+A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
+HOLDERS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
+ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR
+TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE
+USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH
+DAMAGE
+Berkeley DB XML XQuery
+ * are met:
+ * Copyright (c) 2005
+ * Progress Software Corporation. All rights reserved.
+ * are met:
+ * 3. The end-user documentation included with the redistribution, if any,
+ * must include the following acknowledgment: "This product includes
+ * software developed by Progress Software Corporation." Alternately,
+ * this acknowledgment may appear in the software itself, if and wherever
+ * such third-party acknowledgments normally appear.
+ * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN
+ * NO EVENT SHALL PROGRESS SOFTWARE CORPORATION BE LIABLE FOR ANY DIRECT,
+ * INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
+ * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
+ * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING
+ * IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+ * POSSIBILITY OF SUCH DAMAGE.
+Proj.4 and GDAL
+Copyright (c) 2000, Frank Warmerdam
+ Permission is hereby granted, free of charge, to any person obtaining a
+ copy of this software and associated documentation files (the "Software"),
+ to deal in the Software without restriction, including without limitation
+ the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ and/or sell copies of the Software, and to permit persons to whom the
+ Software is furnished to do so, subject to the following conditions:
+ The above copyright notice and this permission notice shall be included
+ in all copies or substantial portions of the Software.
+ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS
+ OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ DEALINGS IN THE SOFTWARE.
+GD Graphics Library
+Portions copyright 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002,
+2003, 2004 by Cold Spring Harbor Laboratory. Funded under Grant P41-RR02188
+by the National Institutes of Health.
+Portions copyright 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, 2004
+by Boutell.Com, Inc.
+Portions relating to GD2 format copyright 1999, 2000, 2001, 2002, 2003,
+2004 Philip Warner.
+Portions relating to PNG copyright 1999, 2000, 2001, 2002, 2003, 2004
+Greg Roelofs.
+Portions relating to gdttf.c copyright 1999, 2000, 2001, 2002, 2003,
+2004 John Ellson (ellson at graphviz.org).
+Portions relating to gdft.c copyright 2001, 2002, 2003, 2004 John Ellson
+(ellson at graphviz.org).
+Portions relating to JPEG and to color quantization copyright 2000, 2001,
+2002, 2003, 2004, Doug Becker and copyright (C) 1994, 1995, 1996, 1997,
+1998, 1999, 2000, 2001, 2002, 2003, 2004 Thomas G. Lane.
+This software is based in part on the work of the Independent JPEG Group.
+See the file README-JPEG.TXT in the GD Source Code for more information.
+Portions relating to GIF compression copyright 1989 by Jef Poskanzer and
+David Rowley, with modifications for thread safety by Thomas Boutell.
+Portions relating to GIF decompression copyright 1990, 1991, 1993 by
+David Koblas, with modifications for thread safety by Thomas Boutell.
+Portions relating to WBMP copyright 2000, 2001, 2002, 2003, 2004
+Maurice Szmurlo and Johan Van den Brande.
+Portions relating to GIF animations copyright 2004 Jaakko Hyvätti
+(jaakko.hyvatti at iki.fi)
+Permission has been granted to copy, distribute and modify gd in any context
+without fee, including a commercial application, provided that this notice
+is present in user-accessible supporting documentation.
+This does not affect your ownership of the derived work itself, and the
+intent is to assure proper credit for the authors of gd, not to interfere
+with your productive use of gd. If you have questions, ask. "Derived works"
+includes all programs that utilize the library. Credit must be given in
+user-accessible documentation.
+This software is provided "AS IS." The copyright holders disclaim all warranties,
+either express or implied, including but not limited to implied warranties
+of merchantability and fitness for a particular purpose, with respect to this
+code and accompanying documentation.
+Although their code does not appear in the current release, the authors also
+wish to thank Hutchison Avenue Software Corporation for their prior contributions.
+FastCGI
+This FastCGI application library source and object code (the
+"Software") and its documentation (the "Documentation") are
+copyrighted by Open Market, Inc ("Open Market"). The following terms
+apply to all files associated with the Software and Documentation
+unless explicitly disclaimed in individual files.
+Open Market permits you to use, copy, modify, distribute, and license
+this Software and the Documentation solely for the purpose of
+implementing the FastCGI specification defined by Open Market or
+derivative specifications publicly endorsed by Open Market and
+promulgated by an open standards organization and for no other
+purpose, provided that existing copyright notices are retained in all
+copies and that this notice is included verbatim in any distributions.
+No written agreement, license, or royalty fee is required for any of
+the authorized uses. Modifications to this Software and Documentation
+may be copyrighted by their authors and need not follow the licensing
+terms described here, but the modified Software and Documentation must
+be used for the sole purpose of implementing the FastCGI specification
+defined by Open Market or derivative specifications publicly endorsed
+by Open Market and promulgated by an open standards organization and
+for no other purpose. If modifications to this Software and
+Documentation have new licensing terms, the new terms must protect Open
+Market's proprietary rights in the Software and Documentation to the
+same extent as these licensing terms and must be clearly indicated on
+the first page of each file where they apply.
+Open Market shall retain all right, title and interest in and to the
+Software and Documentation, including without limitation all patent,
+copyright, trade secret and other proprietary rights.
+OPEN MARKET MAKES NO EXPRESS OR IMPLIED WARRANTY WITH RESPECT TO THE
+SOFTWARE OR THE DOCUMENTATION, INCLUDING WITHOUT LIMITATION ANY
+WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. IN
+NO EVENT SHALL OPEN MARKET BE LIABLE TO YOU OR ANY THIRD PARTY FOR ANY
+DAMAGES ARISING FROM OR RELATING TO THIS SOFTWARE OR THE
+DOCUMENTATION, INCLUDING, WITHOUT LIMITATION, ANY INDIRECT, SPECIAL OR
+CONSEQUENTIAL DAMAGES OR SIMILAR DAMAGES, INCLUDING LOST PROFITS OR
+LOST DATA, EVEN IF OPEN MARKET HAS BEEN ADVISED OF THE POSSIBILITY OF
+SUCH DAMAGES. THE SOFTWARE AND DOCUMENTATION ARE PROVIDED "AS IS".
+OPEN MARKET HAS NO LIABILITY IN CONTRACT, TORT, NEGLIGENCE OR
+OTHERWISE ARISING OUT OF THIS SOFTWARE OR THE DOCUMENTATION.
+PHP
+ The PHP License, version 3.0
+Copyright (c) 1999 - 2005 The PHP Group. All rights reserved.
+modification, is permitted provided that the following conditions
+are met:
+ 1. Redistributions of source code must retain the above copyright
+ notice, this list of conditions and the following disclaimer.
+ 2. Redistributions in binary form must reproduce the above copyright
+ notice, this list of conditions and the following disclaimer in
+ the documentation and/or other materials provided with the
+ distribution.
+ 3. The name "PHP" must not be used to endorse or promote products
+ derived from this software without prior written permission. For
+ written permission, please contact group at php.net.
+ 4. Products derived from this software may not be called "PHP", nor
+ may "PHP" appear in their name, without prior written permission
+ from group at php.net. You may indicate that your software works in
+ conjunction with PHP by saying "Foo for PHP" instead of calling
+ it "PHP Foo" or "phpfoo"
+ 5. The PHP Group may publish revised and/or new versions of the
+ license from time to time. Each version will be given a
+ distinguishing version number.
+ Once covered code has been published under a particular version
+ of the license, you may always continue to use it under the terms
+ of that version. You may also choose to use such covered code
+ under the terms of any subsequent version of the license
+ published by the PHP Group. No one other than the PHP Group has
+ the right to modify the terms applicable to covered code created
+ under this License.
+ 6. Redistributions of any form whatsoever must retain the following
+ acknowledgment:
+ "This product includes PHP, freely available from
+ <http://www.php.net/>".
+THIS SOFTWARE IS PROVIDED BY THE PHP DEVELOPMENT TEAM ``AS IS'' AND
+ANY EXPRESSED OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
+THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
+PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE PHP
+DEVELOPMENT TEAM OR ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
+INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
+(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
+SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
+STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
+OF THE POSSIBILITY OF SUCH DAMAGE.
+This software consists of voluntary contributions made by many
+individuals on behalf of the PHP Group.
+The PHP Group can be contacted via Email at group at php.net.
+For more information on the PHP Group and the PHP project,
+please see <http://www.php.net>.
+This product includes the Zend Engine, freely available at
+<http://www.zend.com>.
+StampVer
+StampVer - Win32 Version Resource Stamping
+Written by Paul Dixon (paul at elphin.com) Jan 1998
+http://www.elphin.com/products/stampver.html
+MapGuide Open Source, CppUnit, GEOS, SQLite, FDO and the Javascript Vector Graphics
+Library are each licensed under the GNU Lesser General Public License.
+GNU Lesser General Public License
+ GNU LESSER GENERAL PUBLIC LICENSE
+ Version 2.1, February 1999
+ Copyright (C) 1991, 1999 Free Software Foundation, Inc.
+ 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+ Everyone is permitted to copy and distribute verbatim copies
+ of this license document, but changing it is not allowed.
+[This is the first released version of the Lesser GPL. It also counts
+ as the successor of the GNU Library Public License, version 2, hence
+ the version number 2.1.]
+ Preamble
+ The licenses for most software are designed to take away your
+freedom to share and change it. By contrast, the GNU General Public
+Licenses are intended to guarantee your freedom to share and change
+free software--to make sure the software is free for all its users.
+ This license, the Lesser General Public License, applies to some
+specially designated software packages--typically libraries--of the
+Free Software Foundation and other authors who decide to use it. You
+can use it too, but we suggest you first think carefully about whether
+this license or the ordinary General Public License is the better
+strategy to use in any particular case, based on the explanations below.
+ When we speak of free software, we are referring to freedom of use,
+not price. Our General Public Licenses are designed to make sure that
+you have the freedom to distribute copies of free software (and charge
+for this service if you wish); that you receive source code or can get
+it if you want it; that you can change the software and use pieces of
+it in new free programs; and that you are informed that you can do
+these things.
+ To protect your rights, we need to make restrictions that forbid
+distributors to deny you these rights or to ask you to surrender these
+rights. These restrictions translate to certain responsibilities for
+you if you distribute copies of the library or if you modify it.
+ For example, if you distribute copies of the library, whether gratis
+or for a fee, you must give the recipients all the rights that we gave
+you. You must make sure that they, too, receive or can get the source
+code. If you link other code with the library, you must provide
+complete object files to the recipients, so that they can relink them
+with the library after making changes to the library and recompiling
+it. And you must show them these terms so they know their rights.
+ We protect your rights with a two-step method: (1) we copyright the
+library, and (2) we offer you this license, which gives you legal
+permission to copy, distribute and/or modify the library.
+ To protect each distributor, we want to make it very clear that
+there is no warranty for the free library. Also, if the library is
+modified by someone else and passed on, the recipients should know
+that what they have is not the original version, so that the original
+author's reputation will not be affected by problems that might be
+introduced by others.
+ Finally, software patents pose a constant threat to the existence of
+any free program. We wish to make sure that a company cannot
+effectively restrict the users of a free program by obtaining a
+restrictive license from a patent holder. Therefore, we insist that
+any patent license obtained for a version of the library must be
+consistent with the full freedom of use specified in this license.
+ Most GNU software, including some libraries, is covered by the
+ordinary GNU General Public License. This license, the GNU Lesser
+General Public License, applies to certain designated libraries, and
+is quite different from the ordinary General Public License. We use
+this license for certain libraries in order to permit linking those
+libraries into non-free programs.
+ When a program is linked with a library, whether statically or using
+a shared library, the combination of the two is legally speaking a
+combined work, a derivative of the original library. The ordinary
+General Public License therefore permits such linking only if the
+entire combination fits its criteria of freedom. The Lesser General
+Public License permits more lax criteria for linking other code with
+the library.
+ We call this license the "Lesser" General Public License because it
+does Less to protect the user's freedom than the ordinary General
+Public License. It also provides other free software developers Less
+of an advantage over competing non-free programs. These disadvantages
+are the reason we use the ordinary General Public License for many
+libraries. However, the Lesser license provides advantages in certain
+special circumstances.
+ For example, on rare occasions, there may be a special need to
+encourage the widest possible use of a certain library, so that it becomes
+a de-facto standard. To achieve this, non-free programs must be
+allowed to use the library. A more frequent case is that a free
+library does the same job as widely used non-free libraries. In this
+case, there is little to gain by limiting the free library to free
+software only, so we use the Lesser General Public License.
+ In other cases, permission to use a particular library in non-free
+programs enables a greater number of people to use a large body of
+free software. For example, permission to use the GNU C Library in
+non-free programs enables many more people to use the whole GNU
+operating system, as well as its variant, the GNU/Linux operating
+system.
+ Although the Lesser General Public License is Less protective of the
+users' freedom, it does ensure that the user of a program that is
+linked with the Library has the freedom and the wherewithal to run
+that program using a modified version of the Library.
+ The precise terms and conditions for copying, distribution and
+modification follow. Pay close attention to the difference between a
+"work based on the library" and a "work that uses the library". The
+former contains code derived from the library, whereas the latter must
+be combined with the library in order to run.
+ TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION
+ 0. This License Agreement applies to any software library or other
+program which contains a notice placed by the copyright holder or
+other authorized party saying it may be distributed under the terms of
+this Lesser General Public License (also called "this License").
+Each licensee is addressed as "you".
+ A "library" means a collection of software functions and/or data
+prepared so as to be conveniently linked with application programs
+(which use some of those functions and data) to form executables.
+ The "Library", below, refers to any such software library or work
+which has been distributed under these terms. A "work based on the
+Library" means either the Library or any derivative work under
+copyright law: that is to say, a work containing the Library or a
+portion of it, either verbatim or with modifications and/or translated
+straightforwardly into another language. (Hereinafter, translation is
+included without limitation in the term "modification".)
+ "Source code" for a work means the preferred form of the work for
+making modifications to it. For a library, complete source code means
+all the source code for all modules it contains, plus any associated
+interface definition files, plus the scripts used to control compilation
+and installation of the library.
+ Activities other than copying, distribution and modification are not
+covered by this License; they are outside its scope. The act of
+running a program using the Library is not restricted, and output from
+such a program is covered only if its contents constitute a work based
+on the Library (independent of the use of the Library in a tool for
+writing it). Whether that is true depends on what the Library does
+and what the program that uses the Library does.
+ 1. You may copy and distribute verbatim copies of the Library's
+complete source code as you receive it, in any medium, provided that
+you conspicuously and appropriately publish on each copy an
+appropriate copyright notice and disclaimer of warranty; keep intact
+all the notices that refer to this License and to the absence of any
+warranty; and distribute a copy of this License along with the
+Library.
+ You may charge a fee for the physical act of transferring a copy,
+and you may at your option offer warranty protection in exchange for a
+fee.
+ 2. You may modify your copy or copies of the Library or any portion
+of it, thus forming a work based on the Library, and copy and
+distribute such modifications or work under the terms of Section 1
+above, provided that you also meet all of these conditions:
+ a) The modified work must itself be a software library.
+ b) You must cause the files modified to carry prominent notices
+ stating that you changed the files and the date of any change.
+ c) You must cause the whole of the work to be licensed at no
+ charge to all third parties under the terms of this License.
+ d) If a facility in the modified Library refers to a function or a
+ table of data to be supplied by an application program that uses
+ the facility, other than as an argument passed when the facility
+ is invoked, then you must make a good faith effort to ensure that,
+ in the event an application does not supply such function or
+ table, the facility still operates, and performs whatever part of
+ its purpose remains meaningful.
+ (For example, a function in a library to compute square roots has
+ a purpose that is entirely well-defined independent of the
+ application. Therefore, Subsection 2d requires that any
+ application-supplied function or table used by this function must
+ be optional: if the application does not supply it, the square
+ root function must still compute square roots.)
+These requirements apply to the modified work as a whole. If
+identifiable sections of that work are not derived from the Library,
+and can be reasonably considered independent and separate works in
+themselves, then this License, and its terms, do not apply to those
+sections when you distribute them as separate works. But when you
+distribute the same sections as part of a whole which is a work based
+on the Library, the distribution of the whole must be on the terms of
+this License, whose permissions for other licensees extend to the
+entire whole, and thus to each and every part regardless of who wrote
+it.
+Thus, it is not the intent of this section to claim rights or contest
+your rights to work written entirely by you; rather, the intent is to
+exercise the right to control the distribution of derivative or
+collective works based on the Library.
+In addition, mere aggregation of another work not based on the Library
+with the Library (or with a work based on the Library) on a volume of
+a storage or distribution medium does not bring the other work under
+the scope of this License.
+ 3. You may opt to apply the terms of the ordinary GNU General Public
+License instead of this License to a given copy of the Library. To do
+this, you must alter all the notices that refer to this License, so
+that they refer to the ordinary GNU General Public License, version 2,
+instead of to this License. (If a newer version than version 2 of the
+ordinary GNU General Public License has appeared, then you can specify
+that version instead if you wish.) Do not make any other change in
+these notices.
+ Once this change is made in a given copy, it is irreversible for
+that copy, so the ordinary GNU General Public License applies to all
+subsequent copies and derivative works made from that copy.
+ This option is useful when you wish to copy part of the code of
+the Library into a program that is not a library.
+ 4. You may copy and distribute the Library (or a portion or
+derivative of it, under Section 2) in object code or executable form
+under the terms of Sections 1 and 2 above provided that you accompany
+it with the complete corresponding machine-readable source code, which
+must be distributed under the terms of Sections 1 and 2 above on a
+medium customarily used for software interchange.
+ If distribution of object code is made by offering access to copy
+from a designated place, then offering equivalent access to copy the
+source code from the same place satisfies the requirement to
+distribute the source code, even though third parties are not
+compelled to copy the source along with the object code.
+ 5. A program that contains no derivative of any portion of the
+Library, but is designed to work with the Library by being compiled or
+linked with it, is called a "work that uses the Library". Such a
+work, in isolation, is not a derivative work of the Library, and
+therefore falls outside the scope of this License.
+ However, linking a "work that uses the Library" with the Library
+creates an executable that is a derivative of the Library (because it
+contains portions of the Library), rather than a "work that uses the
+library". The executable is therefore covered by this License.
+Section 6 states terms for distribution of such executables.
+ When a "work that uses the Library" uses material from a header file
+that is part of the Library, the object code for the work may be a
+derivative work of the Library even though the source code is not.
+Whether this is true is especially significant if the work can be
+linked without the Library, or if the work is itself a library. The
+threshold for this to be true is not precisely defined by law.
+ If such an object file uses only numerical parameters, data
+structure layouts and accessors, and small macros and small inline
+functions (ten lines or less in length), then the use of the object
+file is unrestricted, regardless of whether it is legally a derivative
+work. (Executables containing this object code plus portions of the
+Library will still fall under Section 6.)
+ Otherwise, if the work is a derivative of the Library, you may
+distribute the object code for the work under the terms of Section 6.
+Any executables containing that work also fall under Section 6,
+whether or not they are linked directly with the Library itself.
+ 6. As an exception to the Sections above, you may also combine or
+link a "work that uses the Library" with the Library to produce a
+work containing portions of the Library, and distribute that work
+under terms of your choice, provided that the terms permit
+modification of the work for the customer's own use and reverse
+engineering for debugging such modifications.
+ You must give prominent notice with each copy of the work that the
+Library is used in it and that the Library and its use are covered by
+this License. You must supply a copy of this License. If the work
+during execution displays copyright notices, you must include the
+copyright notice for the Library among them, as well as a reference
+directing the user to the copy of this License. Also, you must do one
+of these things:
+ a) Accompany the work with the complete corresponding
+ machine-readable source code for the Library including whatever
+ changes were used in the work (which must be distributed under
+ Sections 1 and 2 above); and, if the work is an executable linked
+ with the Library, with the complete machine-readable "work that
+ uses the Library", as object code and/or source code, so that the
+ user can modify the Library and then relink to produce a modified
+ executable containing the modified Library. (It is understood
+ that the user who changes the contents of definitions files in the
+ Library will not necessarily be able to recompile the application
+ to use the modified definitions.)
+ b) Use a suitable shared library mechanism for linking with the
+ Library. A suitable mechanism is one that (1) uses at run time a
+ copy of the library already present on the user's computer system,
+ rather than copying library functions into the executable, and (2)
+ will operate properly with a modified version of the library, if
+ the user installs one, as long as the modified version is
+ interface-compatible with the version that the work was made with.
+ c) Accompany the work with a written offer, valid for at
+ least three years, to give the same user the materials
+ specified in Subsection 6a, above, for a charge no more
+ than the cost of performing this distribution.
+ d) If distribution of the work is made by offering access to copy
+ from a designated place, offer equivalent access to copy the above
+ specified materials from the same place.
+ e) Verify that the user has already received a copy of these
+ materials or that you have already sent this user a copy.
+ For an executable, the required form of the "work that uses the
+Library" must include any data and utility programs needed for
+reproducing the executable from it. However, as a special exception,
+the materials to be distributed need not include anything that is
+normally distributed (in either source or binary form) with the major
+components (compiler, kernel, and so on) of the operating system on
+which the executable runs, unless that component itself accompanies
+the executable.
+ It may happen that this requirement contradicts the license
+restrictions of other proprietary libraries that do not normally
+accompany the operating system. Such a contradiction means you cannot
+use both them and the Library together in an executable that you
+distribute.
+ 7. You may place library facilities that are a work based on the
+Library side-by-side in a single library together with other library
+facilities not covered by this License, and distribute such a combined
+library, provided that the separate distribution of the work based on
+the Library and of the other library facilities is otherwise
+permitted, and provided that you do these two things:
+ a) Accompany the combined library with a copy of the same work
+ based on the Library, uncombined with any other library
+ facilities. This must be distributed under the terms of the
+ Sections above.
+ b) Give prominent notice with the combined library of the fact
+ that part of it is a work based on the Library, and explaining
+ where to find the accompanying uncombined form of the same work.
+ 8. You may not copy, modify, sublicense, link with, or distribute
+the Library except as expressly provided under this License. Any
+attempt otherwise to copy, modify, sublicense, link with, or
+distribute the Library is void, and will automatically terminate your
+rights under this License. However, parties who have received copies,
+or rights, from you under this License will not have their licenses
+terminated so long as such parties remain in full compliance.
+ 9. You are not required to accept this License, since you have not
+signed it. However, nothing else grants you permission to modify or
+distribute the Library or its derivative works. These actions are
+prohibited by law if you do not accept this License. Therefore, by
+modifying or distributing the Library (or any work based on the
+Library), you indicate your acceptance of this License to do so, and
+all its terms and conditions for copying, distributing or modifying
+the Library or works based on it.
+ 10. Each time you redistribute the Library (or any work based on the
+Library), the recipient automatically receives a license from the
+original licensor to copy, distribute, link with or modify the Library
+subject to these terms and conditions. You may not impose any further
+restrictions on the recipients' exercise of the rights granted herein.
+You are not responsible for enforcing compliance by third parties with
+this License.
+ 11. If, as a consequence of a court judgment or allegation of patent
+infringement or for any other reason (not limited to patent issues),
+conditions are imposed on you (whether by court order, agreement or
+otherwise) that contradict the conditions of this License, they do not
+excuse you from the conditions of this License. If you cannot
+distribute so as to satisfy simultaneously your obligations under this
+License and any other pertinent obligations, then as a consequence you
+may not distribute the Library at all. For example, if a patent
+license would not permit royalty-free redistribution of the Library by
+all those who receive copies directly or indirectly through you, then
+the only way you could satisfy both it and this License would be to
+refrain entirely from distribution of the Library.
+If any portion of this section is held invalid or unenforceable under any
+particular circumstance, the balance of the section is intended to apply,
+and the section as a whole is intended to apply in other circumstances.
+It is not the purpose of this section to induce you to infringe any
+patents or other property right claims or to contest validity of any
+such claims; this section has the sole purpose of protecting the
+integrity of the free software distribution system which is
+implemented by public license practices. Many people have made
+generous contributions to the wide range of software distributed
+through that system in reliance on consistent application of that
+system; it is up to the author/donor to decide if he or she is willing
+to distribute software through any other system and a licensee cannot
+impose that choice.
+This section is intended to make thoroughly clear what is believed to
+be a consequence of the rest of this License.
+ 12. If the distribution and/or use of the Library is restricted in
+certain countries either by patents or by copyrighted interfaces, the
+original copyright holder who places the Library under this License may add
+an explicit geographical distribution limitation excluding those countries,
+so that distribution is permitted only in or among countries not thus
+excluded. In such case, this License incorporates the limitation as if
+written in the body of this License.
+ 13. The Free Software Foundation may publish revised and/or new
+versions of the Lesser General Public License from time to time.
+Such new versions will be similar in spirit to the present version,
+but may differ in detail to address new problems or concerns.
+Each version is given a distinguishing version number. If the Library
+specifies a version number of this License which applies to it and
+"any later version", you have the option of following the terms and
+conditions either of that version or of any later version published by
+the Free Software Foundation. If the Library does not specify a
+license version number, you may choose any version ever published by
+ 14. If you wish to incorporate parts of the Library into other free
+programs whose distribution conditions are incompatible with these,
+write to the author to ask for permission. For software which is
+copyrighted by the Free Software Foundation, write to the Free
+Software Foundation; we sometimes make exceptions for this. Our
+decision will be guided by the two goals of preserving the free status
+of all derivatives of our free software and of promoting the sharing
+and reuse of software generally.
+ NO WARRANTY
+ 15. BECAUSE THE LIBRARY IS LICENSED FREE OF CHARGE, THERE IS NO
+WARRANTY FOR THE LIBRARY, TO THE EXTENT PERMITTED BY APPLICABLE LAW.
+EXCEPT WHEN OTHERWISE STATED IN WRITING THE COPYRIGHT HOLDERS AND/OR
+OTHER PARTIES PROVIDE THE LIBRARY "AS IS" WITHOUT WARRANTY OF ANY
+KIND, EITHER EXPRESSED OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, THE
+IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
+PURPOSE. THE ENTIRE RISK AS TO THE QUALITY AND PERFORMANCE OF THE
+LIBRARY IS WITH YOU. SHOULD THE LIBRARY PROVE DEFECTIVE, YOU ASSUME
+THE COST OF ALL NECESSARY SERVICING, REPAIR OR CORRECTION.
+ 16. IN NO EVENT UNLESS REQUIRED BY APPLICABLE LAW OR AGREED TO IN
+WRITING WILL ANY COPYRIGHT HOLDER, OR ANY OTHER PARTY WHO MAY MODIFY
+AND/OR REDISTRIBUTE THE LIBRARY AS PERMITTED ABOVE, BE LIABLE TO YOU
+FOR DAMAGES, INCLUDING ANY GENERAL, SPECIAL, INCIDENTAL OR
+CONSEQUENTIAL DAMAGES ARISING OUT OF THE USE OR INABILITY TO USE THE
+LIBRARY (INCLUDING BUT NOT LIMITED TO LOSS OF DATA OR DATA BEING
+RENDERED INACCURATE OR LOSSES SUSTAINED BY YOU OR THIRD PARTIES OR A
+FAILURE OF THE LIBRARY TO OPERATE WITH ANY OTHER SOFTWARE), EVEN IF
+SUCH HOLDER OR OTHER PARTY HAS BEEN ADVISED OF THE POSSIBILITY OF SUCH
+DAMAGES.
+License for DWF Toolkit 7
+NOTICE TO USER:
+THIS LICENSE AGREEMENT ("AGREEMENT") IS A LEGAL AGREEMENT BETWEEN YOU (EITHER AN INDIVIDUAL OR A SINGLE ENTITY) AND AUTODESK, INC. FOR THE DWF TOOLKIT 7, WHICH INCLUDES COMPUTER SOFTWARE AND MAY INCLUDE ASSOCIATED MEDIA, PRINTED MATERIALS AND ONLINE OR ELECTRONIC DOCUMENTATION ("LICENSED SOFTWARE"). BY INSTALLING THE LICENSED SOFTWARE YOU ACCEPT ALL THE TERMS AND CONDITIONS OF THIS AGREEMENT. IF YOU DO NOT AGREE TO BE BOUND BY THE TERMS OF THIS AGREEMENT, DO NOT INSTALL OR USE THE LICENSED SOFTWARE.
+1 LICENSE GRANT
+1.1 Autodesk grants to you ("Licensee") a perpetual, nontransferable, nonexclusive, royalty-free, limited license to:
+1.1.1 (a) Use the Licensed Software for development, research, internal, educational, or commercial purposes; (b) Modify the Licensed Software to create derivative works and applications, including ports; and (c) Compile the Licensed Software, derivative works and applications prepared in accordance with subsection 1.1.1(b) into binary code.
+1.1.2 Reproduce, distribute and sublicense free of charge or for a fee the Licensed Software in binary code form in conjunction with derivative works or applications created by Licensee or licensed from third parties by Licensee, provided, that: (a) Licensee makes no use of Autodesks trademarks, trade names, or trade dress; (b) In the event Licensee makes any modification to the Licensed Software, Licensee must publish the specification for such modifications for use by third party developers and provide Autodesk with a copy thereof; and (c) The Licensee must sublicense the Licensed Software as is, without warranty of any kind.
+1.1.3 Reproduce, distribute and sublicense free of charge to sublicensees the source code of the unmodified Licensed Software, provided that (a) Licensee must state in its sublicenses that the Licensed Software is being distributed pursuant to a license granted by Autodesk, Inc.; (b)The terms of sublicenses granted by Licensee must (i) contain all applicable terms of this Agreement, and (ii) not be broader than the terms of the license granted by this Agreement; (c) Licensee must exactly reproduce Autodesks copyright and other proprietary rights notices which accompany the copy of the Licensed Software licensed by Autodesk to Licensee; and (d) Licensee shall conspicuously state in its sublicenses that the Licensed Software is offered as is, without warranty of any kind.
+1.1.4 Reproduce, distribute and sublicense the source code of the Licensed Software as modified by Licensee, provided that (a) Licensee must state in its sublicense that the Licensed Software has been modified by Licensee; (b) Licensee must exactly reproduce Autodesks copyright and other proprietary rights notices which accompany the copy of the Licensed Software licensed by Autodesk to Licensee; (c) As to the unmodified portions of the Licensed Software, the terms of the sublicenses granted by Licensee must (i) contain all applicable terms of this Agreement, and (ii) not be broader than the terms of the license granted by this Agreement; (d) Licensee must conspicuously state in its sublicenses that the original, unmodified portions of the Licensed Software are offered as is, without warranty of any kind; and (e) Licensee must (i) publish the modified Licensed Software to the Worldwide Web, (ii) make available with the modified Licensed Software documentation which describes in detail the modifications which Licensee has made to the Licensed Software, and (iii) provide to Autodesk a copy of the modified Licensed Software and the documentation.
+1.2 Licensee acquires no right, title, or interest in or to the Licensed Software,
+1.3 Licensee shall retain all rights to any independently developed software, such as applications, developed by or for Licensee.
+1.4 Autodesk is under no obligation to provide maintenance, support, or upgrades for the Licensed Software.
+2 COPYRIGHTS AND TRADEMARKS
+Licensee shall reproduce and apply any copyright or other proprietary rights notices included on or embedded in the Licensed Software to any copies of the Licensed Software or to applications created using the Licensed Software, in any form. Licensee shall have no right to use any Autodesk trademarks, trade names or trade dress absent a separate written agreement between Autodesk and Licensee. Licensee hereby understands and agrees that Autodesk is not granting any rights to Autodesk patents, copyrights, trademarks or trade secret information to Licensee by this Agreement.
+3 FEES
+Use of the Licensed Software in accordance with the terms of this Agreement shall not require payment of a license fee.
+4 TERM AND TERMINATION
+The grant of a perpetual license notwithstanding, Autodesk may immediately terminate this Agreement and revoke the license granted to Licensee upon written notice to Licensee if Licensee fails to comply with any of the terms or conditions of this Agreement. Upon termination of this Agreement, Licensee shall immediately cease using, reproducing and distributing the Licensed Software, the license and rights granted hereunder shall expire, and Licensee shall immediately destroy or return to Autodesk the Licensed Software and all related documentation, materials or copies thereof.
+5 DISCLAIMER OF WARRANTY
+5.1 The Licensed Software is provided "AS IS" and without any warranty of any kind.
+5.2 AUTODESK DOES NOT MAKE AND HEREBY DISCLAIMS ANY EXPRESS OR IMPLIED WARRANTIES INCLUDING, BUT NOT LIMITED TO, THE WARRANTIES OF NON-INFRINGEMENT, MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE, OR ARISING FROM A COURSE OF DEALING, USAGE, OR TRADE PRACTICE.
+6 LIMITATION OF LIABILITY
+6.1 In no event will Autodesk be liable for any lost revenues, data, or profits, or special, indirect, or consequential damages, even if Autodesk has been advised of the possibility or probability of such damages. Autodesks maximum liability for damages shall be limited to the fees, if any, required under Section 3 for the particular Licensed Software which caused the damages.
+6.2 The Licensed Software is not fault-tolerant and is not designed, manufactured, or intended for use or resale as online control equipment in hazardous environments requiring fail-safe performance, such as in the operation of nuclear facilities, aircraft navigation or communication systems, air traffic control, direct life support machines, or weapons systems, in which the failure of the Licensed Software or derived binaries could lead directly to death, personal injury, or severe physical or environmental damage ("High Risk Activities"). Autodesk specifically disclaims any express or implied warranty of fitness for High Risk Activities. Licensee will not knowingly use, distribute, or sublicense the Licensed Software or derived binaries for High Risk Activities and will ensure that its customers and end-users of Licensee's products are provided with a copy of the notice specified in the first sentence of this Section 6.2.
+7 PROPRIETARY INFORMATION
+The Licensed Software is the proprietary information of Autodesk, Inc. ("Confidential Information"). Except as permitted by this Agreement, Licensee shall not disclose Confidential Information and shall use it only for purposes specifically contemplated by this Agreement. This Agreement will not affect any non-disclosure agreement between the parties.
+8 EXPORT
+Unless properly authorized by the U.S. Government, Licensee shall not export, re-export or transfer, whether directly or indirectly, the Licensed Software or binary derivative or direct products thereof, to any person or company who is (a) present in or controlled by a legal resident of any proscribed country listed in the U.S. Export Administration Regulations (or any equivalent thereof ), or (b) a person or entity named in the entity lists, denied persons lists or specially designated nationals lists maintained by the U.S. Government.
+9 U.S. GOVERNMENT RESTRICTED RIGHTS
+This Licensed Software is provided with RESTRICTED RIGHTS. Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c)(1)(ii) of the Rights in Technical Data and Computer Software Clause as DFARS 252.227-7013 and FAR 52.227-19 as applicable. Manufacturer is Autodesk, Inc., 111 McInnis Parkway, San Rafael, California 94903.
+10 GOVERNING LAW
+Any action related to this Agreement will be governed by California law, excluding choice of law rules.
More information about the mapguide-commits
