[mapguide-commits] r4775 - in trunk/MgDev/Web/src: PhpApi
PhpMapGuideApiEnvConfig
svn_mapguide at osgeo.org
Thu Apr 8 23:51:38 EDT 2010
Author: waltweltonlair
Date: 2010-04-08 23:51:37 -0400 (Thu, 08 Apr 2010)
New Revision: 4775
trunk/MgDev/Web/src/PhpApi/PhpApi.vcproj
trunk/MgDev/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.cpp
trunk/MgDev/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.vcproj
Fix Windows build...
Modified: trunk/MgDev/Web/src/PhpApi/PhpApi.vcproj
--- trunk/MgDev/Web/src/PhpApi/PhpApi.vcproj 2010-04-09 03:28:45 UTC (rev 4774)
+++ trunk/MgDev/Web/src/PhpApi/PhpApi.vcproj 2010-04-09 03:51:37 UTC (rev 4775)
@@ -68,7 +68,7 @@
AdditionalDependencies="ACEd.lib xerces-c_2D.lib php5ts.lib"
OutputFile="$(OutDir)\php_MapGuideApid.dll"
LinkIncremental="2"
- AdditionalLibraryDirectories="..\..\..\Oem\ACE\ACE_wrappers\lib;..\..\..\Oem\dbxml-2.3.10\lib;..\..\..\Oem\php\dev"
+ AdditionalLibraryDirectories="..\..\..\Oem\ACE\ACE_wrappers\lib;"..\..\..\Oem\dbxml-2.3.10\lib";..\..\..\Oem\php\Release_TS"
GenerateDebugInformation="true"
ProgramDatabaseFile="$(OutDir)\php_MapGuideApid.pdb"
SubSystem="2"
@@ -148,7 +148,7 @@
LinkIncremental="2"
- AdditionalLibraryDirectories="..\..\..\Oem\ACE\ACE_wrappers\lib64;"..\..\..\Oem\dbxml-2.3.10\lib64";"..\..\..\Oem\php-5.2.5 (x64)\dev""
+ AdditionalLibraryDirectories="..\..\..\Oem\ACE\ACE_wrappers\lib64;"..\..\..\Oem\dbxml-2.3.10\lib64";..\..\..\Oem\php\x64\Release_TS"
SubSystem="2"
@@ -226,7 +226,7 @@
AdditionalDependencies="ACE.lib xerces-c_2.lib php5ts.lib"
OutputFile="$(OutDir)\php_MapGuideApi.dll"
LinkIncremental="1"
ProgramDatabaseFile="$(OutDir)\php_MapGuideApi.pdb"
SubSystem="2"
@@ -306,7 +306,7 @@
LinkIncremental="1"
SubSystem="2"
Modified: trunk/MgDev/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.cpp
--- trunk/MgDev/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.cpp 2010-04-09 03:28:45 UTC (rev 4774)
+++ trunk/MgDev/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.cpp 2010-04-09 03:51:37 UTC (rev 4775)
@@ -36,10 +36,10 @@
hModule = GetModuleHandle(L"php5ts.dll");
GetModuleFileName(hModule, phpPath, MAX_PATH);
wcsrchr(phpPath, '\\')[0] = '\0';
- // FreeLibrary(hModule); -- DO NOT CALL FreeLibrary() when using GetModuleHandle() as the reference count is not increased
+// FreeLibrary(hModule); -- DO NOT CALL FreeLibrary() when using GetModuleHandle() as the reference count is not increased
// Prepend to process PATH environment string
- wchar_t ePath[1024*4] = L"";
+ wchar_t ePath[1024*4] = L"";
wcscpy(ePath, phpPath);
wcscat(ePath, L";");
DWORD dw = (DWORD)wcslen(ePath);
@@ -71,30 +71,30 @@
return SUCCESS;
-PHP_MSHUTDOWN_FUNCTION(MapGuideApiEnvConfig)
- return SUCCESS;
+PHP_MSHUTDOWN_FUNCTION(MapGuideApiEnvConfig)
+ return SUCCESS;
-PHP_MINFO_FUNCTION(MapGuideApiEnvConfig)
- php_info_print_table_start();
- php_info_print_table_row(2, "MapGuideApiEnvConfig", "enabled");
- php_info_print_table_end();
+PHP_MINFO_FUNCTION(MapGuideApiEnvConfig)
+ php_info_print_table_start();
+ php_info_print_table_row(2, "MapGuideApiEnvConfig", "enabled");
+ php_info_print_table_end();
/* compiled module information */
zend_module_entry MapGuideApiEnvConfig_module_entry = {
STANDARD_MODULE_HEADER,
- "MapGuideApiEnvConfig",
- MapGuideApiEnvConfig_functions,
- PHP_MINIT(MapGuideApiEnvConfig),
- PHP_MSHUTDOWN(MapGuideApiEnvConfig),
- NULL,
- NULL,
- PHP_MINFO(MapGuideApiEnvConfig),
- NO_VERSION_YET,
- STANDARD_MODULE_PROPERTIES
+ "MapGuideApiEnvConfig",
+ MapGuideApiEnvConfig_functions,
+ PHP_MINIT(MapGuideApiEnvConfig),
+ PHP_MSHUTDOWN(MapGuideApiEnvConfig),
+ NULL,
+ NULL,
+ PHP_MINFO(MapGuideApiEnvConfig),
+ NO_VERSION_YET,
+ STANDARD_MODULE_PROPERTIES
Modified: trunk/MgDev/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.vcproj
--- trunk/MgDev/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.vcproj 2010-04-09 03:28:45 UTC (rev 4774)
+++ trunk/MgDev/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.vcproj 2010-04-09 03:51:37 UTC (rev 4775)
@@ -66,7 +66,7 @@
AdditionalDependencies="php5ts.lib"
OutputFile="$(OutDir)\php_MapGuideApiEnvConfigd.dll"
LinkIncremental="2"
- AdditionalLibraryDirectories="..\..\..\Oem\php\dev"
+ AdditionalLibraryDirectories="..\..\..\Oem\php\Release_TS"
ProgramDatabaseFile="$(OutDir)\php_MapGuideApiEnvConfigd.pdb"
SubSystem="2"
@@ -144,7 +144,7 @@
LinkIncremental="2"
- AdditionalLibraryDirectories="..\..\..\Oem\php-5.2.5 (x64)\dev"
+ AdditionalLibraryDirectories="..\..\..\Oem\php\x64\Release_TS"
SubSystem="2"
@@ -222,7 +222,7 @@
OutputFile="$(OutDir)\php_MapGuideApiEnvConfig.dll"
LinkIncremental="1"
SubSystem="2"
OptimizeReferences="2"
@@ -301,7 +301,7 @@
LinkIncremental="1"
SubSystem="2"
More information about the mapguide-commits
