[mapguide-commits] r4815 - in trunk/Tools/Maestro/Maestro: .
ResourceValidators Strings
svn_mapguide at osgeo.org
Wed Apr 28 03:56:57 EDT 2010
Author: jng
Date: 2010-04-28 03:56:53 -0400 (Wed, 28 Apr 2010)
New Revision: 4815
trunk/Tools/Maestro/Maestro/FormMain.cs
trunk/Tools/Maestro/Maestro/ResourceValidators/FeatureSourceValidator.cs
trunk/Tools/Maestro/Maestro/Strings/FormMain.Designer.cs
trunk/Tools/Maestro/Maestro/Strings/FormMain.resx
Fix #1335: Context menu issues when selected node is the root (Library://), this also fixes some commands that didn't work when the selected node was the root, as the root should've been treated as a folder resource.
Also included is a small fix for the feature source validator. It turns out a spatial context extent returned from the mapagent can be null, but can have null LL/UR coordinates (huh?)
Modified: trunk/Tools/Maestro/Maestro/FormMain.cs
--- trunk/Tools/Maestro/Maestro/FormMain.cs 2010-04-27 02:35:28 UTC (rev 4814)
+++ trunk/Tools/Maestro/Maestro/FormMain.cs 2010-04-28 07:56:53 UTC (rev 4815)
@@ -1368,19 +1368,6 @@
private void TreeContextMenu_Popup(object sender, CancelEventArgs e)
- if (ResourceTree.SelectedNode == null || ResourceTree.SelectedNode.Tag == null)
- foreach(ToolStripItem m in TreeContextMenu.Items)
- if (m as ToolStripMenuItem != null)
- m.Enabled = false;
- else
- foreach (ToolStripItem m in TreeContextMenu.Items)
- m.Enabled = true;
var selNode = ResourceTree.SelectedNode;
PropertiesMenu.Enabled =
@@ -1388,7 +1375,8 @@
PasteMenu.Enabled = (selNode != null && m_clipboardBuffer != null);
NewMenu.Enabled = true;
- bool isFolder = (selNode != null && selNode.Tag.GetType() == typeof(MaestroAPI.ResourceListResourceFolder));
+ bool isRoot = (selNode != null && selNode.Level == 0);
+ bool isFolder = isRoot || (selNode != null && selNode.Tag.GetType() == typeof(MaestroAPI.ResourceListResourceFolder));
EditAsXmlMenu.Enabled = EditAsXmlButton.Enabled = !isFolder;
@@ -1401,6 +1389,9 @@
FindReplaceMenu.Enabled = !isFolder;
FindReplaceChildrenMenu.Enabled = isFolder;
+ DeleteMenu.Enabled = !isRoot; //Can't delete the root of the repo
+ RenameMenu.Enabled = !isRoot; //Can't rename either
private void SaveXmlAsMenu_Click(object sender, System.EventArgs e)
@@ -2136,55 +2127,87 @@
try
- if (ResourceTree.SelectedNode != null && ResourceTree.SelectedNode.Tag != null)
+ bool isRoot = (ResourceTree.SelectedNode != null && ResourceTree.SelectedNode.Level == 0);
+ if (ResourceTree.SelectedNode != null && (ResourceTree.SelectedNode.Tag != null || isRoot))
- if (ResourceTree.SelectedNode.Tag.GetType() == typeof(OSGeo.MapGuide.MaestroAPI.ResourceListResourceDocument))
- OSGeo.MapGuide.MaestroAPI.ResourceListResourceDocument document = (OSGeo.MapGuide.MaestroAPI.ResourceListResourceDocument)ResourceTree.SelectedNode.Tag;
- if (m_userControls.ContainsKey(document.ResourceId))
- EditorInterface edi = (EditorInterface)m_userControls[document.ResourceId];
- if (!edi.Close(true))
- return;
+ if (!isRoot)
+ if (ResourceTree.SelectedNode.Tag.GetType() == typeof(OSGeo.MapGuide.MaestroAPI.ResourceListResourceDocument))
+ OSGeo.MapGuide.MaestroAPI.ResourceListResourceDocument document = (OSGeo.MapGuide.MaestroAPI.ResourceListResourceDocument)ResourceTree.SelectedNode.Tag;
+ if (m_userControls.ContainsKey(document.ResourceId))
+ EditorInterface edi = (EditorInterface)m_userControls[document.ResourceId];
+ if (!edi.Close(true))
+ return;
- if (!String.IsNullOrEmpty(szFind))
- OpenResource(document.ResourceId, typeof(OSGeo.MapGuide.Maestro.ResourceEditors.XmlEditorControl), szFind, szReplace);
- else
- OpenResource(document.ResourceId, typeof(OSGeo.MapGuide.Maestro.ResourceEditors.XmlEditorControl));
- else
- if (ResourceTree.SelectedNode.Tag.GetType() == typeof(OSGeo.MapGuide.MaestroAPI.ResourceListResourceFolder))
- if (!ResourceTree.SelectedNode.IsExpanded)
- ResourceTree.SelectedNode.Expand();
+ if (!String.IsNullOrEmpty(szFind))
+ OpenResource(document.ResourceId, typeof(OSGeo.MapGuide.Maestro.ResourceEditors.XmlEditorControl), szFind, szReplace);
+ else
+ OpenResource(document.ResourceId, typeof(OSGeo.MapGuide.Maestro.ResourceEditors.XmlEditorControl));
+ else
+ if (ResourceTree.SelectedNode.Tag.GetType() == typeof(OSGeo.MapGuide.MaestroAPI.ResourceListResourceFolder))
+ if (!ResourceTree.SelectedNode.IsExpanded)
+ ResourceTree.SelectedNode.Expand();
- int iCount = ResourceTree.SelectedNode.Nodes.Count;
- if (DialogResult.Yes != MessageBox.Show(this, "Are You Sure You Want to Open " + iCount + " Items?", Application.ProductName, MessageBoxButtons.YesNo, MessageBoxIcon.Question))
- return;
+ int iCount = GetDocumentNodeCount(ResourceTree.SelectedNode);
+ string msg = string.Format(Strings.FormMain.ConfirmMultipleOpen, iCount);
+ if (DialogResult.Yes != MessageBox.Show(this, msg, Application.ProductName, MessageBoxButtons.YesNo, MessageBoxIcon.Question))
+ return;
- foreach (TreeNode tnThis in ResourceTree.SelectedNode.Nodes)
- // only deal with documents
- if (tnThis.Tag.GetType() == typeof(OSGeo.MapGuide.MaestroAPI.ResourceListResourceDocument))
- OSGeo.MapGuide.MaestroAPI.ResourceListResourceDocument document = (OSGeo.MapGuide.MaestroAPI.ResourceListResourceDocument)tnThis.Tag;
- return;
+ foreach (TreeNode tnThis in ResourceTree.SelectedNode.Nodes)
+ // Document nodes are tagged with the ResourceListResourceDocument class
+ if (tnThis.Tag.GetType() == typeof(OSGeo.MapGuide.MaestroAPI.ResourceListResourceDocument))
+ OSGeo.MapGuide.MaestroAPI.ResourceListResourceDocument document = (OSGeo.MapGuide.MaestroAPI.ResourceListResourceDocument)tnThis.Tag;
+ return;
- else
+ else
+ else
+ return;
+ // only deal with documents
+ return;
+ else
catch (Exception ex)
@@ -2195,6 +2218,20 @@
+ private static int GetDocumentNodeCount(TreeNode treeNode)
+ int i = 0;
+ foreach (TreeNode tnThis in treeNode.Nodes)
+ if (tnThis.Tag != null && tnThis.Tag.GetType() == typeof(OSGeo.MapGuide.MaestroAPI.ResourceListResourceDocument))
+ i++;
+ return i;
private void LoadFromXmlMenu_Click(object sender, System.EventArgs e)
using(new WaitCursor(this))
@@ -2924,6 +2961,8 @@
resid = (ResourceTree.SelectedNode.Tag as MaestroAPI.ResourceListResourceDocument).ResourceId;
else if (ResourceTree.SelectedNode.Tag as MaestroAPI.ResourceListResourceFolder != null)
resid = (ResourceTree.SelectedNode.Tag as MaestroAPI.ResourceListResourceFolder).ResourceId;
+ else if (ResourceTree.SelectedNode.Level == 0)
+ resid = "Library://";
if (resid == null)
return;
@@ -2971,10 +3010,12 @@
return;
string resid = null;
- if (nodeSel.Tag as MaestroAPI.ResourceListResourceDocument != null)
- resid = (nodeSel.Tag as MaestroAPI.ResourceListResourceDocument).ResourceId;
- else if (nodeSel.Tag as MaestroAPI.ResourceListResourceFolder != null)
- resid = (nodeSel.Tag as MaestroAPI.ResourceListResourceFolder).ResourceId;
+ if (nodeSel.Tag as MaestroAPI.ResourceListResourceDocument != null)
+ resid = (nodeSel.Tag as MaestroAPI.ResourceListResourceDocument).ResourceId;
+ else if (nodeSel.Tag as MaestroAPI.ResourceListResourceFolder != null)
+ resid = (nodeSel.Tag as MaestroAPI.ResourceListResourceFolder).ResourceId;
+ else if (nodeSel.Level == 0)
if (null == resid)
return;
Modified: trunk/Tools/Maestro/Maestro/ResourceValidators/FeatureSourceValidator.cs
--- trunk/Tools/Maestro/Maestro/ResourceValidators/FeatureSourceValidator.cs 2010-04-27 02:35:28 UTC (rev 4814)
+++ trunk/Tools/Maestro/Maestro/ResourceValidators/FeatureSourceValidator.cs 2010-04-28 07:56:53 UTC (rev 4815)
@@ -49,7 +49,7 @@
issues.Add(new ValidationIssue(feature, ValidationStatus.Warning, Strings.FeatureSourceValidator.NoSpatialContextWarning));
else
foreach (MaestroAPI.FdoSpatialContextListSpatialContext c in lst.SpatialContext)
- if (c.Extent == null)
+ if (c.Extent == null || c.Extent.LowerLeftCoordinate == null || c.Extent.UpperRightCoordinate == null)
issues.Add(new ValidationIssue(feature, ValidationStatus.Warning, Strings.FeatureSourceValidator.EmptySpatialContextWarning));
else if (double.Parse(c.Extent.LowerLeftCoordinate.X, ci) <= -1000000 && double.Parse(c.Extent.LowerLeftCoordinate.Y, ci) <= -1000000 && double.Parse(c.Extent.UpperRightCoordinate.X, ci) >= 1000000 && double.Parse(c.Extent.UpperRightCoordinate.Y, ci) >= 1000000)
issues.Add(new ValidationIssue(feature, ValidationStatus.Warning, Strings.FeatureSourceValidator.DefaultSpatialContextWarning));
Modified: trunk/Tools/Maestro/Maestro/Strings/FormMain.Designer.cs
--- trunk/Tools/Maestro/Maestro/Strings/FormMain.Designer.cs 2010-04-27 02:35:28 UTC (rev 4814)
+++ trunk/Tools/Maestro/Maestro/Strings/FormMain.Designer.cs 2010-04-28 07:56:53 UTC (rev 4815)
@@ -61,6 +61,15 @@
/// <summary>
+ /// Looks up a localized string similar to Are you sure you want to open {0} items?.
+ /// </summary>
+ internal static string ConfirmMultipleOpen {
+ get {
+ return ResourceManager.GetString("ConfirmMultipleOpen", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Copy {0} of {1}.
/// </summary>
internal static string CopyOfName {
Modified: trunk/Tools/Maestro/Maestro/Strings/FormMain.resx
--- trunk/Tools/Maestro/Maestro/Strings/FormMain.resx 2010-04-27 02:35:28 UTC (rev 4814)
+++ trunk/Tools/Maestro/Maestro/Strings/FormMain.resx 2010-04-28 07:56:53 UTC (rev 4815)
@@ -117,6 +117,10 @@
<resheader name="writer">
<value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
+ <data name="ConfirmMultipleOpen" xml:space="preserve">
+ <value>Are you sure you want to open {0} items?</value>
+ <comment>A confirmation message that is displayed when opening multiple items for editing</comment>
+ </data>
<data name="CopyOfName" xml:space="preserve">
<value>Copy {0} of {1}</value>
<comment>The name of a new item that is a copy of an existing item</comment>
More information about the mapguide-commits
