[mapguide-commits] r5424 - in sandbox/maestro-3.0:
Maestro.Editors/Properties Maestro.Editors/WebLayout
OSGeo.MapGuide.MaestroAPI/ObjectModels
svn_mapguide at osgeo.org
Wed Dec 1 05:26:47 EST 2010
Author: jng
Date: 2010-12-01 02:26:47 -0800 (Wed, 01 Dec 2010)
New Revision: 5424
sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
sandbox/maestro-3.0/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/WebLayout.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/WebLayoutInterfaces.cs
3.0 sandbox changes:
- #1352: Implement import/export of custom web layout commands
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs 2010-12-01 10:26:39 UTC (rev 5423)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs 2010-12-01 10:26:47 UTC (rev 5424)
@@ -362,6 +362,24 @@
+ /// <summary>
+ /// Looks up a localized string similar to Custom commands exported to {0}.
+ /// </summary>
+ internal static string CustomCommandsExported {
+ get {
+ return ResourceManager.GetString("CustomCommandsExported", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to {0} custom commands imported from {1}. The following commands had to be renamed to prevent clashes: {2}.
+ /// </summary>
+ internal static string CustomCommandsImported {
+ get {
+ return ResourceManager.GetString("CustomCommandsImported", resourceCulture);
internal static System.Drawing.Bitmap database__plus {
get {
object obj = ResourceManager.GetObject("database--plus", resourceCulture);
@@ -478,6 +496,24 @@
/// <summary>
+ /// Looks up a localized string similar to No commands selected. Nothing to export.
+ /// </summary>
+ internal static string ExportNoCommandsSelected {
+ get {
+ return ResourceManager.GetString("ExportNoCommandsSelected", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No custom commands selected. Nothing to export.
+ /// </summary>
+ internal static string ExportNoCustomCommandsSelected {
+ get {
+ return ResourceManager.GetString("ExportNoCustomCommandsSelected", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Expression....
/// </summary>
internal static string ExpressionItem {
@@ -604,6 +640,15 @@
/// <summary>
+ /// Looks up a localized string similar to XML Files (.xml)|*.xml.
+ /// </summary>
+ internal static string FilterXml {
+ get {
+ return ResourceManager.GetString("FilterXml", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Cannot Find an Empty String.
/// </summary>
internal static string FindEmptyString {
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx 2010-12-01 10:26:39 UTC (rev 5423)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx 2010-12-01 10:26:47 UTC (rev 5424)
@@ -1046,4 +1046,19 @@
<data name="Separator" xml:space="preserve">
<value>Separator</value>
</data>
+ <data name="CustomCommandsExported" xml:space="preserve">
+ <value>Custom commands exported to {0}</value>
+ </data>
+ <data name="CustomCommandsImported" xml:space="preserve">
+ <value>{0} custom commands imported from {1}. The following commands had to be renamed to prevent clashes: {2}</value>
+ </data>
+ <data name="ExportNoCommandsSelected" xml:space="preserve">
+ <value>No commands selected. Nothing to export</value>
+ </data>
+ <data name="ExportNoCustomCommandsSelected" xml:space="preserve">
+ <value>No custom commands selected. Nothing to export</value>
+ </data>
+ <data name="FilterXml" xml:space="preserve">
+ <value>XML Files (.xml)|*.xml</value>
+ </data>
</root>
\ No newline at end of file
Modified: sandbox/maestro-3.0/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.Designer.cs 2010-12-01 10:26:39 UTC (rev 5423)
+++ sandbox/maestro-3.0/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.Designer.cs 2010-12-01 10:26:47 UTC (rev 5424)
@@ -97,6 +97,7 @@
this.grdCommands.Size = new System.Drawing.Size(427, 228);
this.grdCommands.TabIndex = 1;
this.grdCommands.CellClick += new System.Windows.Forms.DataGridViewCellEventHandler(this.grdCommands_CellContentClick);
+ this.grdCommands.SelectionChanged += new System.EventHandler(this.grdCommands_SelectionChanged);
this.grdCommands.CellContentClick += new System.Windows.Forms.DataGridViewCellEventHandler(this.grdCommands_CellContentClick);
// toolStrip1
@@ -121,14 +122,14 @@
this.btnAdd.Image = global::Maestro.Editors.Properties.Resources.application__plus;
this.btnAdd.ImageTransparentColor = System.Drawing.Color.Magenta;
this.btnAdd.Name = "btnAdd";
- this.btnAdd.Size = new System.Drawing.Size(55, 22);
+ this.btnAdd.Size = new System.Drawing.Size(58, 22);
this.btnAdd.Text = "Add";
// invokeURLToolStripMenuItem
this.invokeURLToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.icon_invokeurl;
this.invokeURLToolStripMenuItem.Name = "invokeURLToolStripMenuItem";
- this.invokeURLToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.invokeURLToolStripMenuItem.Size = new System.Drawing.Size(142, 22);
this.invokeURLToolStripMenuItem.Text = "Invoke URL";
this.invokeURLToolStripMenuItem.Click += new System.EventHandler(this.invokeURLToolStripMenuItem_Click);
@@ -136,7 +137,7 @@
this.invokeScriptToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.icon_invokescript;
this.invokeScriptToolStripMenuItem.Name = "invokeScriptToolStripMenuItem";
- this.invokeScriptToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.invokeScriptToolStripMenuItem.Size = new System.Drawing.Size(142, 22);
this.invokeScriptToolStripMenuItem.Text = "Invoke Script";
this.invokeScriptToolStripMenuItem.Click += new System.EventHandler(this.invokeScriptToolStripMenuItem_Click);
@@ -144,7 +145,7 @@
this.searchToolStripMenuItem.Image = global::Maestro.Editors.Properties.Resources.icon_search;
this.searchToolStripMenuItem.Name = "searchToolStripMenuItem";
- this.searchToolStripMenuItem.Size = new System.Drawing.Size(152, 22);
+ this.searchToolStripMenuItem.Size = new System.Drawing.Size(142, 22);
this.searchToolStripMenuItem.Text = "Search";
this.searchToolStripMenuItem.Click += new System.EventHandler(this.searchToolStripMenuItem_Click);
@@ -154,7 +155,7 @@
this.btnDelete.Image = global::Maestro.Editors.Properties.Resources.application__minus;
this.btnDelete.ImageTransparentColor = System.Drawing.Color.Magenta;
this.btnDelete.Name = "btnDelete";
- this.btnDelete.Size = new System.Drawing.Size(58, 22);
+ this.btnDelete.Size = new System.Drawing.Size(60, 22);
this.btnDelete.Text = "Delete";
this.btnDelete.ToolTipText = "Delete selected command";
this.btnDelete.Click += new System.EventHandler(this.btnDelete_Click);
@@ -165,7 +166,7 @@
this.btnExport.Image = global::Maestro.Editors.Properties.Resources.application_export;
this.btnExport.ImageTransparentColor = System.Drawing.Color.Magenta;
this.btnExport.Name = "btnExport";
- this.btnExport.Size = new System.Drawing.Size(59, 22);
+ this.btnExport.Size = new System.Drawing.Size(60, 22);
this.btnExport.Text = "Export";
this.btnExport.ToolTipText = "Export commands to a XML file";
this.btnExport.Click += new System.EventHandler(this.btnExport_Click);
@@ -175,7 +176,7 @@
this.btnImport.Image = global::Maestro.Editors.Properties.Resources.application_import;
this.btnImport.ImageTransparentColor = System.Drawing.Color.Magenta;
this.btnImport.Name = "btnImport";
- this.btnImport.Size = new System.Drawing.Size(59, 22);
+ this.btnImport.Size = new System.Drawing.Size(63, 22);
this.btnImport.Text = "Import";
this.btnImport.ToolTipText = "Import commands from an XML file";
this.btnImport.Click += new System.EventHandler(this.btnImport_Click);
@@ -194,7 +195,6 @@
// WebLayoutCommandsCtrl
- this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.None;
this.HeaderText = "Commands";
this.Name = "WebLayoutCommandsCtrl";
Modified: sandbox/maestro-3.0/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.cs 2010-12-01 10:26:39 UTC (rev 5423)
+++ sandbox/maestro-3.0/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.cs 2010-12-01 10:26:47 UTC (rev 5424)
@@ -67,8 +67,13 @@
base.UnsubscribeEventHandlers();
+ private bool listChangedDisabled = false;
void OnCommandSetListChanged(object sender, ListChangedEventArgs e)
+ if (listChangedDisabled)
+ return;
switch (e.ListChangedType)
case ListChangedType.ItemAdded:
@@ -268,12 +273,82 @@
private void btnExport_Click(object sender, EventArgs e)
+ if (grdCommands.SelectedRows.Count == 0)
+ MessageBox.Show(Properties.Resources.ExportNoCommandsSelected);
+ return;
+ else
+ List<string> selectedCmds = new List<string>();
+ foreach (DataGridViewRow row in grdCommands.SelectedRows)
+ var cmd = (ICommand)row.DataBoundItem;
+ var cmdType = cmd.GetType();
+ if (typeof(IInvokeScriptCommand).IsAssignableFrom(cmdType))
+ selectedCmds.Add(cmd.Name);
+ else if (typeof(IInvokeUrlCommand).IsAssignableFrom(cmdType))
+ else if (typeof(ISearchCommand).IsAssignableFrom(cmdType))
+ if (selectedCmds.Count == 0)
+ MessageBox.Show(Properties.Resources.ExportNoCustomCommandsSelected);
+ return;
+ using (var save = DialogFactory.SaveFile())
+ save.Filter = Properties.Resources.FilterXml;
+ if (save.ShowDialog() == DialogResult.OK)
+ _wl.ExportCustomCommands(save.FileName, selectedCmds.ToArray());
+ MessageBox.Show(string.Format(Properties.Resources.CustomCommandsExported, save.FileName));
private void btnImport_Click(object sender, EventArgs e)
+ using (var open = DialogFactory.OpenFile())
+ if (open.ShowDialog() == DialogResult.OK)
+ listChangedDisabled = true;
+ try
+ var cmds = _wl.ImportCustomCommands(open.FileName);
+ StringBuilder sb = new StringBuilder();
+ foreach (var imported in cmds)
+ ICommand cmd = _wl.GetCommandByName(imported.ImportedName);
+ _commands.Add(cmd);
+ if (imported.NameChanged)
+ sb.AppendLine(imported.ToString());
+ MessageBox.Show(string.Format(Properties.Resources.CustomCommandsImported, cmds.Length, open.FileName, sb.ToString()));
+ catch (Exception ex)
+ MessageBox.Show(ex.Message, Properties.Resources.TitleError, MessageBoxButtons.OK, MessageBoxIcon.Error);
+ finally
+ listChangedDisabled = false;
+ private void grdCommands_SelectionChanged(object sender, EventArgs e)
+ EvaluateCommands();
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/WebLayout.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/WebLayout.cs 2010-12-01 10:26:39 UTC (rev 5423)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/WebLayout.cs 2010-12-01 10:26:47 UTC (rev 5424)
@@ -54,6 +54,13 @@
+ [Serializable]
+ public class WebLayoutCustomCommandList
+ [XmlArrayItem("CustomCommands")]
+ public CommandType[] Commands { get; set; }
partial class WebLayoutType : IWebLayout, ICommandSet
internal WebLayoutType() { }
@@ -749,6 +756,57 @@
return new SeparatorItemType() { Function = UIItemFunctionType.Separator };
+ public void ExportCustomCommands(string file, string[] cmdNames)
+ WebLayoutCustomCommandList list = new WebLayoutCustomCommandList();
+ List<CommandType> commands = new List<CommandType>();
+ foreach (var name in cmdNames)
+ var cmd = (CommandType)GetCommandByName(name);
+ if (cmd != null)
+ commands.Add(cmd);
+ list.Commands = commands.ToArray();
+ using (var fs = File.OpenWrite(file))
+ new XmlSerializer(typeof(WebLayoutCustomCommandList)).Serialize(fs, list);
+ public ImportedCommandResult[] ImportCustomCommands(string file)
+ List<ImportedCommandResult> clashes = new List<ImportedCommandResult>();
+ using (var fs = File.OpenRead(file))
+ var list = (WebLayoutCustomCommandList)(new XmlSerializer(typeof(WebLayoutCustomCommandList)).Deserialize(fs));
+ foreach (var importCmd in list.Commands)
+ int counter = 0;
+ string oldName = importCmd.Name;
+ string newName = oldName;
+ ICommand cmd = this.GetCommandByName(newName);
+ while (cmd != null)
+ counter++;
+ newName = oldName + counter;
+ cmd = this.GetCommandByName(newName);
+ this.commandSetField.Add(importCmd);
+ clashes.Add(new ImportedCommandResult() { OriginalName = oldName, ImportedName = newName });
+ return clashes.ToArray();
[XmlIgnore]
ICommandSet IWebLayout.CommandSet
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/WebLayoutInterfaces.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/WebLayoutInterfaces.cs 2010-12-01 10:26:39 UTC (rev 5423)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/WebLayoutInterfaces.cs 2010-12-01 10:26:47 UTC (rev 5424)
@@ -266,11 +266,28 @@
All,
+ public class ImportedCommandResult
+ public string OriginalName { get; set; }
+ public string ImportedName { get; set; }
+ public bool NameChanged { get { return !this.ImportedName.Equals(this.OriginalName); } }
+ public override string ToString()
+ return string.Format("{0} => {1}", this.OriginalName, this.ImportedName);
/// <summary>
/// The Web Layout
/// </summary>
public interface IWebLayout : IResource, INotifyPropertyChanged
+ void ExportCustomCommands(string file, string[] cmdNames);
+ ImportedCommandResult[] ImportCustomCommands(string file);
/// <summary>
/// Determines whether the specified command name is referenced in any regions
/// </summary>
More information about the mapguide-commits
