[mapguide-commits] r5434 - sandbox/maestro-3.0/Maestro
svn_mapguide at osgeo.org
Fri Dec 3 07:46:27 EST 2010
Author: jng
Date: 2010-12-03 04:46:27 -0800 (Fri, 03 Dec 2010)
New Revision: 5434
sandbox/maestro-3.0/Maestro/changelog.txt
update changelog.txt
Modified: sandbox/maestro-3.0/Maestro/changelog.txt
--- sandbox/maestro-3.0/Maestro/changelog.txt 2010-12-03 12:34:10 UTC (rev 5433)
+++ sandbox/maestro-3.0/Maestro/changelog.txt 2010-12-03 12:46:27 UTC (rev 5434)
@@ -1,6 +1,33 @@
-3.0 Alpha 1
+Test Build 3
+ - Migrated: Runtime Map API, with batched layer loading support improving create performance
+ - Specialized SQLite editor
+ - Partially migrated Fusion editor w/ Commerical Map Layer support
+ - API: Resource change events for IResourceService
+ - API: IGetResourceContents custom command
+Test Build 2
+ - Drag and drop support
+ - Create feature sources from dropped SDF/SHP/SQLite files
+ - Create matching resource from dropped XML document
+ - Migrated: MgCooker.exe
+ - Migrated: Offical MapGuide API support.
+ - Migrated: Server Status Monitor
+ - Added drag/drop support for Resource Data UI
+ - New validation rules for DWF-based layers
+ - Make creating a new resource remember where you right-click so speed up the saving process.
+ - Resource Dialog fixes and UX enhancements
+ - Mono fixes related to XML and UI sizing.
+ - Added inter-server migration tools
+ - Move/Copy resources to a folder on another server with option to overwrite existing resources
+ - Copy selected resource (and its dependencies) to the same path on another server, with choices of which dependent resources to copy and whether to overwrite existing resources.
+Test Build 1
First public preview release of Maestro 3.0.
- Redesigned User Interface
More information about the mapguide-commits
