[mapguide-commits] r5446 - trunk/MgDev/Common/CoordinateSystem
svn_mapguide at osgeo.org
Tue Dec 7 19:00:49 EST 2010
Author: NormOlsen
Date: 2010-12-07 16:00:49 -0800 (Tue, 07 Dec 2010)
New Revision: 5446
trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp
Trac # 1555 -- Some special processing is required for SRID numbers. The slot in the CS-MAP structure is a signed short and there are some SRID values which are greater than 32767. SO we play some games to make the signed short the equivalent of an unsigned short.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp 2010-12-07 22:14:25 UTC (rev 5445)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp 2010-12-08 00:00:49 UTC (rev 5446)
@@ -1319,7 +1319,24 @@
/// </summary>
INT32 CCoordinateSystem::GetEpsgCode (void)
- return static_cast<INT32>(m_csprm.csdef.epsgNbr);
+ short sEpsg;
+ INT32 iEpsg;
+ sEpsg = m_csprm.csdef.epsgNbr;
+ if (sEpsg > 0)
+ iEpsg = sEpsg;
+ else if (sEpsg < 0)
+ sEpsg = -sEpsg;
+ iEpsg = 32768 + sEpsg;
+ else
+ iEpsg = 0;
+ return iEpsg;
/// <summary>
@@ -1327,7 +1344,24 @@
/// </summary>
INT32 CCoordinateSystem::GetSridCode (void)
- return static_cast<INT32>(m_csprm.csdef.srid);
+ short sSrid;
+ INT32 iSrid;
+ sSrid = m_csprm.csdef.srid;
+ if (sSrid > 0)
+ iSrid = sSrid;
+ else if (sSrid < 0)
+ sSrid = -sSrid;
+ iSrid = 32768 + sSrid;
+ else
+ iSrid = 0;
+ return iSrid;
/// <summary>
More information about the mapguide-commits
