[mapguide-commits] r5451 - in sandbox/maestro-3.0: Maestro.Base
Maestro.Base/Editor Maestro.Base/UI Maestro.Editors/Common
MaestroAPITests MaestroFsPreview OSGeo.MapGuide.MaestroAPI
OSGeo.MapGuide.MaestroAPI/CoordinateSystem
OSGeo.MapGuide.MaestroAPI/Services OSGeo.MapGuide.MaestroAPI.Http
OSGeo.MapGuide.MaestroAPI.Native
svn_mapguide at osgeo.org
Thu Dec 9 02:21:20 EST 2010
Author: jng
Date: 2010-12-08 23:21:20 -0800 (Wed, 08 Dec 2010)
New Revision: 5451
Added:
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ArgumentParser.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/ActualCoordinateSystem.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystemBase.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/DegreeBasedCoordinateSystem.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/FeetBasedCoordinateSystem.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/MeterBasedCoordinateSystem.cs
sandbox/maestro-3.0/Maestro.Base/Editor/FsEditorOptionPanel.cs
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
sandbox/maestro-3.0/Maestro.Base/UI/ResourcePropertiesDialog.cs
sandbox/maestro-3.0/Maestro.Editors/Common/CoordinateSystemPicker.cs
sandbox/maestro-3.0/MaestroAPITests/MaestroAPITests.csproj
sandbox/maestro-3.0/MaestroAPITests/ObjectTests.cs
sandbox/maestro-3.0/MaestroAPITests/RuntimeMapTests.cs
sandbox/maestro-3.0/MaestroFsPreview/
sandbox/maestro-3.0/MaestroFsPreview/Program.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpCoordinateSystem.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpCoordinateSystemCatalog.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeCoordinateSystem.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeCoordinateSystemCatalog.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystem.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystemCatalog.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystemCategory.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/ICoordinateSystemCatalog.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/IServerConnection.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs
3.0 sandbox changes:
- Add overloads of IMappingService.CreateMap that do not require a meters-per-unit value. This value is derived from the Map Definition's WKT using:
- TF.NET's Coordinate System APIs (http)
- The computed values differ from the values produced by MgCoordinateSystem, but feeding this runtime map to the rendering APIs produces no discernible difference.
- MgCoordinateSystem API (local)
- Add an ArgumentParser class for processing arguments for command-line applications
- Clean up and have a consistent naming scheme for custom connection properties and connection string parameters. Unit test provided.
- Add new APIs to IServerConnection that provide enough information to recreate the same connection via the ConnectionProviderRegistry
- Rename the existing CoordinateSystemBase class to CoordinateSystemDefinitionBase to avoid naming collision with the new CoordinateSystemBase class (with several derived versions) that provide the necessary logic for calculating meters-per-unit (adapted from the LittleSharpRenderEngine project)
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/FsEditorOptionPanel.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/FsEditorOptionPanel.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/FsEditorOptionPanel.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -30,6 +30,11 @@
using OSGeo.MapGuide.ObjectModels.Capabilities;
using OSGeo.MapGuide.MaestroAPI.Services;
using Maestro.Editors;
+using Maestro.Base.UI.Preferences;
+using ICSharpCode.Core;
+using System.IO;
+using System.Diagnostics;
+using OSGeo.MapGuide.MaestroAPI;
namespace Maestro.Base.Editor
@@ -72,9 +77,42 @@
private void btnLocalPreview_Click(object sender, EventArgs e)
+ //TODO: We really want to do this as an external process
var dlg = new MaestroFsPreview.MainForm(_fsvc, _rsvc);
dlg.FeatureSourceID = _fs.ResourceID;
dlg.ShowDialog();
+ string exe = PropertyService.Get(ConfigProperties.LocalFsPreviewPath, "");
+ if (!File.Exists(exe))
+ using (var dlg = DialogFactory.OpenFile())
+ dlg.Title = string.Format(Properties.Resources.LocateExecutable, "MaestroFsPreview.exe");
+ dlg.Filter = Properties.Resources.FilterExecutables;
+ if (dlg.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ exe = dlg.FileName;
+ PropertyService.Set(ConfigProperties.LocalFsPreviewPath, exe);
+ var procInfo = new ProcessStartInfo(exe);
+ procInfo.WorkingDirectory = Path.GetDirectoryName(exe);
+ var conn = _fs.CurrentConnection;
+ var clonep = conn.CloneParameters;
+ List<string> args = new List<string>();
+ foreach (string key in clonep.Keys)
+ args.Add("-" + key + ":" + clonep[key]);
+ procInfo.Arguments = string.Join(" ", args.ToArray());
+ var proc = Process.Start(procInfo);
private void btnEditConfiguration_Click(object sender, EventArgs e)
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-12-09 07:21:20 UTC (rev 5451)
@@ -507,7 +507,6 @@
<ProjectReference Include="..\MaestroFsPreview\MaestroFsPreview.csproj">
<Project>{59BE5E18-17B6-431D-836E-C0AABA6D69E8}</Project>
<Name>MaestroFsPreview</Name>
- <Private>False</Private>
</ProjectReference>
<ProjectReference Include="..\Thirdparty\SharpDevelop\ICSharpCode.Core.WinForms\ICSharpCode.Core.WinForms.csproj">
<Project>{857CA1A3-FC88-4BE0-AB6A-D1EE772AB288}</Project>
Modified: sandbox/maestro-3.0/Maestro.Base/UI/ResourcePropertiesDialog.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/ResourcePropertiesDialog.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/Maestro.Base/UI/ResourcePropertiesDialog.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -493,7 +493,7 @@
try
List<string> items = new List<string>();
- foreach (OSGeo.MapGuide.MaestroAPI.CoordinateSystem.CoordinateSystemBase c in m_connection.CoordinateSystemCatalog.Coordsys)
+ foreach (OSGeo.MapGuide.MaestroAPI.CoordinateSystem.CoordinateSystemDefinitionBase c in m_connection.CoordinateSystemCatalog.Coordsys)
if (c.Code.StartsWith("EPSG:"))
items.Add(c.Code);
@@ -775,7 +775,7 @@
if (m_srslist == null)
items.Add(c.Code);
Modified: sandbox/maestro-3.0/Maestro.Editors/Common/CoordinateSystemPicker.cs
--- sandbox/maestro-3.0/Maestro.Editors/Common/CoordinateSystemPicker.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/Maestro.Editors/Common/CoordinateSystemPicker.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -38,10 +38,10 @@
InitializeComponent();
- private CoordinateSystemBase m_wktCoordSys = null;
- private CoordinateSystemBase m_epsgCoordSys = null;
- private CoordinateSystemBase m_coordsysCodeCoordSys = null;
- private CoordinateSystemBase m_selectedCoordsys = null;
+ private CoordinateSystemDefinitionBase m_wktCoordSys = null;
+ private CoordinateSystemDefinitionBase m_epsgCoordSys = null;
+ private CoordinateSystemDefinitionBase m_coordsysCodeCoordSys = null;
+ private CoordinateSystemDefinitionBase m_selectedCoordsys = null;
private bool m_isUpdating = false;
@@ -80,21 +80,21 @@
this.Refresh();
_cat.FindCoordSys("");
- CoordinateSystemBase[] items = null;
+ CoordinateSystemDefinitionBase[] items = null;
try
items = _cat.Coordsys;
catch
- items = new CoordinateSystemBase[0];
+ items = new CoordinateSystemDefinitionBase[0];
EPSGCodeText.BeginUpdate();
try
EPSGCodeText.Items.Clear();
- foreach (CoordinateSystemBase c in items)
+ foreach (CoordinateSystemDefinitionBase c in items)
EPSGCodeText.Items.Add(c.EPSG);
@@ -109,7 +109,7 @@
try
CoordSysCodeText.Items.Clear();
CoordSysCodeText.Items.Add(c.Code);
@@ -215,7 +215,7 @@
private void OKBtn_Click(object sender, EventArgs e)
if (SelectByList.Checked)
- m_selectedCoordsys = CoordinateSystem.SelectedItem as CoordinateSystemBase;
+ m_selectedCoordsys = CoordinateSystem.SelectedItem as CoordinateSystemDefinitionBase;
else if (SelectByCoordSysCode.Checked)
m_selectedCoordsys = m_coordsysCodeCoordSys;
else if (SelectByWKT.Checked && _cat == null)
@@ -237,7 +237,7 @@
/// Gets the selected coord sys.
/// </summary>
/// <value>The selected coord sys.</value>
- public CoordinateSystemBase SelectedCoordSys
+ public CoordinateSystemDefinitionBase SelectedCoordSys
get { return m_selectedCoordsys; }
@@ -320,9 +320,9 @@
private void UpdateOthers()
- CoordinateSystemBase selectedCoordsys;
+ CoordinateSystemDefinitionBase selectedCoordsys;
- selectedCoordsys = CoordinateSystem.SelectedItem as CoordinateSystemBase;
+ selectedCoordsys = CoordinateSystem.SelectedItem as CoordinateSystemDefinitionBase;
else if (SelectByWKT.Checked)
Modified: sandbox/maestro-3.0/MaestroAPITests/MaestroAPITests.csproj
--- sandbox/maestro-3.0/MaestroAPITests/MaestroAPITests.csproj 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/MaestroAPITests/MaestroAPITests.csproj 2010-12-09 07:21:20 UTC (rev 5451)
@@ -58,6 +58,10 @@
<Reference Include="System.Data" />
<Reference Include="System.Drawing" />
<Reference Include="System.Xml" />
+ <Reference Include="Topology, Version=1.0.8.24721, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
+ <SpecificVersion>False</SpecificVersion>
+ <HintPath>..\Thirdparty\TF.NET\Topology.dll</HintPath>
+ </Reference>
</ItemGroup>
<ItemGroup>
<Compile Include="CapabilityTests.cs" />
Modified: sandbox/maestro-3.0/MaestroAPITests/ObjectTests.cs
--- sandbox/maestro-3.0/MaestroAPITests/ObjectTests.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/MaestroAPITests/ObjectTests.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -22,17 +22,34 @@
using System.Text;
using NUnit.Framework;
using OSGeo.MapGuide.ObjectModels;
namespace MaestroAPITests
/// <summary>
/// This test fixture is to ensure all objects created by <see cref="ObjectFactory"/> have no
/// null child object properties where there shouldn't be any.
+ /// Also tests for various classes (not belonging to any particular group) reside here
/// </summary>
[TestFixture]
public class ObjectTests
[Test]
+ public void TestArgParser()
+ string[] args = new string[] { "-foo", "-bar:snafu", "-whatever:" };
+ var parser = new ArgumentParser(args);
+ Assert.IsFalse(parser.IsDefined("snafu"));
+ Assert.IsTrue(parser.IsDefined("foo"));
+ Assert.IsTrue(parser.IsDefined("bar"));
+ Assert.IsTrue(parser.IsDefined("whatever"));
+ Assert.AreEqual(string.Empty, parser.GetValue("whatever"));
+ Assert.AreEqual(parser.GetValue("bar"), "snafu");
+ [Test]
public void TestEnvelope()
var env = ObjectFactory.CreateEnvelope(-.1, -.1, .1, .1);
Modified: sandbox/maestro-3.0/MaestroAPITests/RuntimeMapTests.cs
--- sandbox/maestro-3.0/MaestroAPITests/RuntimeMapTests.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/MaestroAPITests/RuntimeMapTests.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -42,6 +42,7 @@
using OSGeo.MapGuide.MaestroAPI.Resource;
using OSGeo.MapGuide.ObjectModels.LoadProcedure;
+ using OSGeo.MapGuide.MaestroAPI.CoordinateSystem;
[SetUpFixture]
public class TestBootstrap
@@ -310,6 +311,9 @@
//The hard-coded value here was the output of MgCoordinateSystem.ConvertCoordinateSystemUnitsToMeters(1.0)
//for this particular map.
double metersPerUnit = 111319.490793274;
+ var cs = CoordinateSystemBase.Create(mdf.CoordinateSystem);
+ metersPerUnit = cs.MetersPerUnitX;
+ Trace.TraceInformation("Using MPU of: {0}", metersPerUnit);
var mid = "Session:" + _conn.SessionID + "//TestRender75k.Map";
var map = mapSvc.CreateMap(mid, mdf, metersPerUnit);
@@ -478,6 +482,9 @@
var mid = "Session:" + _conn.SessionID + "//TestRender12k.Map";
@@ -608,7 +615,7 @@
- [TestFixture(Ignore = true)]
+ [TestFixture]
public class HttpRuntimeMapTests : RuntimeMapTests
protected override IServerConnection CreateTestConnection()
@@ -656,7 +663,7 @@
- [TestFixture]
+ [TestFixture(Ignore = true)]
public class LocalRuntimeMapTests : RuntimeMapTests
Property changes on: sandbox/maestro-3.0/MaestroFsPreview
___________________________________________________________________
Modified: svn:ignore
- obj
bin
+ obj
bin
*.user
Modified: sandbox/maestro-3.0/MaestroFsPreview/Program.cs
--- sandbox/maestro-3.0/MaestroFsPreview/Program.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/MaestroFsPreview/Program.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -31,19 +31,28 @@
/// The main entry point for the application.
/// </summary>
[STAThread]
- static void Main()
+ static void Main(string [] args)
Application.EnableVisualStyles();
Application.SetCompatibleTextRenderingDefault(false);
PreferredSiteList.InitCulture();
IServerConnection conn = null;
- var login = new LoginDialog();
- if (login.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ if (!parser.IsDefined(CommandLineArguments.Provider) || !parser.IsDefined(CommandLineArguments.Session))
- conn = login.Connection;
+ var login = new LoginDialog();
+ if (login.ShowDialog() == System.Windows.Forms.DialogResult.OK)
+ conn = login.Connection;
+ else
+ string prov = parser.GetValue(CommandLineArguments.Provider);
+ conn = ConnectionProviderRegistry.CreateConnection(prov, parser.GetAllArgumentsWithValues());
if (conn == null)
return;
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ArgumentParser.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ArgumentParser.cs (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ArgumentParser.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -0,0 +1,129 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using System.Collections.Specialized;
+namespace OSGeo.MapGuide.MaestroAPI
+ /// <summary>
+ /// A helper class to parse command-line arguments
+ /// </summary>
+ /// <remarks>
+ /// Command-line arguments use the following format:
+ /// -name1 -name2[:value2] -name3[:value3]
+ /// </remarks>
+ public class ArgumentParser
+ private Dictionary<string, string> _values;
+ /// <summary>
+ /// Constructs a new instance
+ /// </summary>
+ /// <param name="args"></param>
+ public ArgumentParser(string[] args)
+ _values = new Dictionary<string, string>();
+ foreach (var arg in args)
+ if (arg.Length > 0 && arg[0] == '-')
+ string name = arg.Substring(1);
+ string value = string.Empty;
+ var cidx = arg.IndexOf(':');
+ if (cidx >= 0)
+ name = arg.Substring(1, cidx - 1);
+ value = arg.Substring(cidx + 1);
+ _values[name] = value;
+ /// <summary>
+ /// Gets a collection of name-value pairs of arguments with values
+ /// </summary>
+ /// <returns></returns>
+ public NameValueCollection GetAllArgumentsWithValues()
+ var nvc = new NameValueCollection();
+ foreach (var key in _values.Keys)
+ if (!string.IsNullOrEmpty(_values[key]))
+ nvc[key] = _values[key];
+ return nvc;
+ /// <summary>
+ /// Gets whether the particular switch has been defined
+ /// </summary>
+ /// <param name="name"></param>
+ public bool IsDefined(string name)
+ return _values.ContainsKey(name);
+ /// <summary>
+ /// Gets the value of the specified switch
+ /// </summary>
+ public string GetValue(string name)
+ return _values[name];
+ /// <summary>
+ /// A set of common command-line arguments
+ /// </summary>
+ public static class CommandLineArguments
+ /// <summary>
+ /// The name of the API provider
+ /// </summary>
+ public const string Provider = "Provider";
+ /// <summary>
+ /// The session id
+ /// </summary>
+ public const string Session = "SessionId";
+ /// <summary>
+ /// The username
+ /// </summary>
+ public const string Username = "Username";
+ /// <summary>
+ /// The password
+ /// </summary>
+ public const string Password = "Password";
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/ActualCoordinateSystem.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/ActualCoordinateSystem.cs (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/ActualCoordinateSystem.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -0,0 +1,61 @@
+using System;
+using System.Text;
+using Topology.CoordinateSystems;
+using Topology.CoordinateSystems.Transformations;
+namespace OSGeo.MapGuide.MaestroAPI.CoordinateSystem
+ public class ActualCoordinateSystem : MeterBasedCoordinateSystem
+ private Topology.CoordinateSystems.Transformations.ICoordinateTransformation m_transform;
+ private const string XY_M = "LOCAL_CS[\"Non-Earth (Meter)\",LOCAL_DATUM[\"Local Datum\",0],UNIT[\"Meter\", 1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
+ internal ActualCoordinateSystem(Topology.CoordinateSystems.ICoordinateSystem coordinateSystem)
+ if (coordinateSystem == null)
+ throw new ArgumentNullException("coordinateSystem");
+ CoordinateTransformationFactory f = new CoordinateTransformationFactory();
+ CoordinateSystemFactory cf = new CoordinateSystemFactory();
+ /*Topology.CoordinateSystems.ICoordinateSystem local = cf.CreateLocalCoordinateSystem(
+ "Non-Earth (Meter)",
+ cf.CreateLocalDatum("Local Datum", Topology.CoordinateSystems.DatumType.VD_Normal),
+ new Topology.CoordinateSystems.LinearUnit(1.0, "Meter", "", 0, "", "", ""),
+ new List<Topology.CoordinateSystems.AxisInfo>(new Topology.CoordinateSystems.AxisInfo[] {
+ new Topology.CoordinateSystems.AxisInfo("X", Topology.CoordinateSystems.AxisOrientationEnum.East),
+ new Topology.CoordinateSystems.AxisInfo("Y", Topology.CoordinateSystems.AxisOrientationEnum.North)
+ string s = cf.ToString();*/
+ m_transform = f.CreateFromCoordinateSystems(coordinateSystem, cf.CreateFromWkt(XY_M));
+ protected override double CalculateScale(Topology.Geometries.IEnvelope bbox, System.Drawing.Size size)
+ double[] points = m_transform.MathTransform.Transform(new double[] { bbox.MinX, bbox.MinY, bbox.MaxX, bbox.MaxY });
+ Topology.Geometries.IEnvelope localEnv = new Topology.Geometries.Envelope(points[0], points[2], points[1], points[3]);
+ return base.CalculateScale(localEnv, size);
+ protected override Topology.Geometries.IEnvelope AdjustBoundingBox(Topology.Geometries.IEnvelope bbox, double scale, System.Drawing.Size size)
+ localEnv = base.AdjustBoundingBox(localEnv, scale, size);
+ points = m_transform.MathTransform.Inverse().Transform(new double[] { localEnv.MinX, localEnv.MinY, localEnv.MaxX, localEnv.MaxY });
+ return new Topology.Geometries.Envelope(points[0], points[2], points[1], points[3]);
+ protected override double DistanceInMeters(Topology.Geometries.IPoint p1, Topology.Geometries.IPoint p2)
+ double[] points = m_transform.MathTransform.Transform(new double[] { p1.X, p1.Y, p2.X, p2.Y });
+ return base.DistanceInMeters(new Topology.Geometries.Point(points[0], points[1]), new Topology.Geometries.Point(points[2], points[3]));
+ //public override Topology.CoordinateSystems.ICoordinateSystem CoordinateSystem { get { return m_transform.SourceCS; } }
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystem.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystem.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystem.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -27,7 +27,7 @@
/// <summary>
/// Represents a coordinate system definition
/// </summary>
- public abstract class CoordinateSystemBase
+ public abstract class CoordinateSystemDefinitionBase
/// <summary>
/// The parent category
@@ -78,17 +78,26 @@
/// <summary>
/// Initializes a new instance of the <see cref="CoordinateSystemBase"/> class.
/// </summary>
- protected CoordinateSystemBase() { }
+ protected CoordinateSystemDefinitionBase() { }
/// <summary>
/// </summary>
/// <param name="parent">The parent.</param>
- protected CoordinateSystemBase(CoordinateSystemCategory parent)
+ protected CoordinateSystemDefinitionBase(CoordinateSystemCategory parent)
m_parent = parent;
+ internal CoordinateSystemCategory Parent
+ get { return m_parent; }
+ set
+ m_parent = value;
/// <summary>
/// Gets or sets the code.
/// </summary>
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystemBase.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystemBase.cs (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystemBase.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -0,0 +1,152 @@
+#endregion
+using System;
+using System.Text;
+using Topology.Geometries;
+using System.Drawing;
+ /// <summary>
+ /// Represents a coordinate system instance
+ /// </summary>
+ public abstract class CoordinateSystemBase
+ static ICoordinateSystemFactory _csFact;
+ static CoordinateSystemBase()
+ _csFact = new CoordinateSystemFactory();
+ public static CoordinateSystemBase Create(CoordinateSystemDefinitionBase csDef)
+ Check.NotNull(csDef, "csDef");
+ return Create(csDef.WKT);
+ public static CoordinateSystemBase Create(string csWkt)
+ Check.NotEmpty(csWkt, "csWkt");
+ return Create(_csFact.CreateFromWkt(csWkt));
+ internal static CoordinateSystemBase Create(ICoordinateSystem coordSys)
+ CoordinateSystemBase csb = null;
+ try
+ //This fails because the XY-M projection is not supported
+ csb = new ActualCoordinateSystem(coordSys);
+ catch { }
+ if (csb == null && coordSys != null)
+ Topology.CoordinateSystems.IUnit unit = coordSys.GetUnits(0);
+ if (unit is Topology.CoordinateSystems.IAngularUnit)
+ double radians = (unit as Topology.CoordinateSystems.IAngularUnit).RadiansPerUnit;
+ csb = new DegreeBasedCoordinateSystem();
+ else if (unit is Topology.CoordinateSystems.ILinearUnit)
+ csb = new MeterBasedCoordinateSystem(((Topology.CoordinateSystems.ILinearUnit)unit).MetersPerUnit, ((Topology.CoordinateSystems.ILinearUnit)unit).MetersPerUnit);
+ return csb;
+ if (csb == null)
+ csb = new MeterBasedCoordinateSystem();
+ public abstract double MetersPerUnitX { get; }
+ public abstract double MetersPerUnitY { get; }
+ /// <summary>
+ /// Calculates the scale of the map, given the bounding box and image size
+ /// </summary>
+ /// <param name="bbox">The map bounding box</param>
+ /// <param name="size">The size of the image</param>
+ /// <returns>The scale</returns>
+ public double CalculateScale(ObjectModels.Common.IEnvelope bbox, Size size)
+ Check.NotNull(bbox, "bbox");
+ return CalculateScale(new Envelope(bbox.MinX, bbox.MaxX, bbox.MinY, bbox.MaxY), size);
+ /// <summary>
+ /// </summary>
+ protected abstract double CalculateScale(IEnvelope bbox, Size size);
+ /// <summary>
+ /// Adjusts the boundingbox to equal proportions
+ /// </summary>
+ /// <param name="bbox">The actual bounding box</param>
+ /// <param name="scale">The scale to fit</param>
+ /// <param name="size">The size to fit to</param>
+ /// <returns>A bounding box with the correct ratio</returns>
+ public ObjectModels.Common.IEnvelope AdjustBoundingBox(ObjectModels.Common.IEnvelope bbox, double scale, Size size)
+ var env = AdjustBoundingBox(new Envelope(bbox.MinX, bbox.MaxX, bbox.MinY, bbox.MaxY), scale, size);
+ return OSGeo.MapGuide.ObjectModels.ObjectFactory.CreateEnvelope(env.MinX, env.MinY, env.MaxX, env.MaxY);
+ /// <summary>
+ /// </summary>
+ protected abstract IEnvelope AdjustBoundingBox(IEnvelope bbox, double scale, Size size);
+ /// <summary>
+ /// Calculates the distance from one point to another, in meters
+ /// </summary>
+ /// <param name="x1"></param>
+ /// <param name="y1"></param>
+ /// <param name="x2"></param>
+ /// <param name="y2"></param>
+ public double DistanceInMeters(double x1, double y1, double x2, double y2)
+ return DistanceInMeters(
+ new Topology.Geometries.Point(x1, y1),
+ new Topology.Geometries.Point(x2, y2));
+ /// <summary>
+ /// </summary>
+ /// <param name="p1">One point</param>
+ /// <param name="p2">Another point</param>
+ /// <returns>The distance in meters</returns>
+ protected abstract double DistanceInMeters(IPoint p1, IPoint p2);
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystemCatalog.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystemCatalog.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystemCatalog.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -32,14 +32,14 @@
/// Gets an array of all coordinate systems in this catalog
/// </summary>
/// <value></value>
- public virtual CoordinateSystemBase[] Coordsys
+ public virtual CoordinateSystemDefinitionBase[] Coordsys
get
- List<CoordinateSystemBase> items = new List<CoordinateSystemBase>();
+ List<CoordinateSystemDefinitionBase> items = new List<CoordinateSystemDefinitionBase>();
foreach (CoordinateSystemCategory cat in this.Categories)
- foreach (CoordinateSystemBase coord in cat.Items)
+ foreach (CoordinateSystemDefinitionBase coord in cat.Items)
items.Add(coord);
@@ -53,13 +53,13 @@
/// </summary>
/// <param name="coordcode"></param>
- public virtual CoordinateSystemBase FindCoordSys(string coordcode)
+ public virtual CoordinateSystemDefinitionBase FindCoordSys(string coordcode)
try
if (coord.Code == coordcode)
return coord;
@@ -77,7 +77,7 @@
/// Gets an empty coordinate system
/// </summary>
- public abstract CoordinateSystemBase CreateEmptyCoordinateSystem();
+ public abstract CoordinateSystemDefinitionBase CreateEmptyCoordinateSystem();
/// <summary>
/// Gets an array of coordinate system categories
@@ -124,7 +124,7 @@
/// </summary>
/// <param name="category"></param>
- public abstract CoordinateSystemBase[] EnumerateCoordinateSystems(string category);
+ public abstract CoordinateSystemDefinitionBase[] EnumerateCoordinateSystems(string category);
/// <summary>
/// Checks if the specified WKT is valid
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystemCategory.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystemCategory.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/CoordinateSystemCategory.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -30,7 +30,7 @@
private ICoordinateSystemCatalog _parent;
private string m_name;
- private CoordinateSystemBase[] m_items;
+ private CoordinateSystemDefinitionBase[] m_items;
/// <summary>
/// Initializes a new instance of the <see cref="CoordinateSystemCategory"/> class.
@@ -54,7 +54,7 @@
/// <summary>
/// Gets an array of all coordinate systems in this category
/// </summary>
- public CoordinateSystemBase[] Items
+ public CoordinateSystemDefinitionBase[] Items
get
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/DegreeBasedCoordinateSystem.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/DegreeBasedCoordinateSystem.cs (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/DegreeBasedCoordinateSystem.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -0,0 +1,33 @@
+#endregion
+using System;
+using System.Text;
+ public class DegreeBasedCoordinateSystem : MeterBasedCoordinateSystem
+ internal DegreeBasedCoordinateSystem()
+ : base(10000000 / 90, 10000000 / 90)
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/FeetBasedCoordinateSystem.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/FeetBasedCoordinateSystem.cs (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/FeetBasedCoordinateSystem.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -0,0 +1,34 @@
+#endregion
+using System;
+using System.Text;
+ public class FeetBasedCoordinateSystem : MeterBasedCoordinateSystem
+ internal FeetBasedCoordinateSystem()
+ : base(0.3048, 0.3048)
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/ICoordinateSystemCatalog.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/ICoordinateSystemCatalog.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/ICoordinateSystemCatalog.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -61,27 +61,27 @@
/// <summary>
/// </summary>
- CoordinateSystemBase[] Coordsys { get; }
+ CoordinateSystemDefinitionBase[] Coordsys { get; }
/// <summary>
/// Gets an array of all coordinate systems in the specified category
/// </summary>
- CoordinateSystemBase[] EnumerateCoordinateSystems(string category);
+ CoordinateSystemDefinitionBase[] EnumerateCoordinateSystems(string category);
/// <summary>
/// Gets the coordinate system that matches the specified code
/// </summary>
- CoordinateSystemBase FindCoordSys(string coordcode);
+ CoordinateSystemDefinitionBase FindCoordSys(string coordcode);
/// <summary>
/// </summary>
- CoordinateSystemBase CreateEmptyCoordinateSystem();
+ CoordinateSystemDefinitionBase CreateEmptyCoordinateSystem();
/// <summary>
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/MeterBasedCoordinateSystem.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/MeterBasedCoordinateSystem.cs (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/MeterBasedCoordinateSystem.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -0,0 +1,86 @@
+#endregion
+using System;
+using System.Text;
+ public class MeterBasedCoordinateSystem : CoordinateSystemBase
+ //Dots pr inch
+ protected const double DPI = 96;
+ //Inches pr meter
+ protected const double IPM = 39.3700787;
+ //Coordsys distance pr unit in meters, X/Y axis
+ protected readonly double UDM_X = 1;
+ protected readonly double UDM_Y = 1;
+ internal MeterBasedCoordinateSystem() { }
+ internal MeterBasedCoordinateSystem(double meters_pr_x_unit, double meters_pr_y_unit)
+ : this()
+ UDM_X = meters_pr_x_unit;
+ UDM_Y = meters_pr_y_unit;
+ public override double MetersPerUnitX { get { return UDM_X; } }
+ public override double MetersPerUnitY { get { return UDM_Y; } }
+ protected override double CalculateScale(IEnvelope bbox, Size size)
+ double picture_width_in_meters = (size.Width / DPI) / IPM;
+ double picture_height_in_meters = (size.Height / DPI) / IPM;
+ double map_width_in_meters = bbox.Width * UDM_X;
+ double map_height_in_meters = bbox.Height * UDM_Y;
+ double width_scale = map_width_in_meters / picture_width_in_meters;
+ double height_scale = map_height_in_meters / picture_height_in_meters;
+ return Math.Max(width_scale, height_scale);
+ protected override Topology.Geometries.IEnvelope AdjustBoundingBox(IEnvelope bbox, double scale, Size size)
+ double picture_width_in_meters = ((size.Width / DPI) / IPM) * scale;
+ double picture_height_in_meters = ((size.Height / DPI) / IPM) * scale;
+ double width_extent = picture_width_in_meters / UDM_X;
+ double height_extent = picture_height_in_meters / UDM_Y;
+ return new Envelope(bbox.Centre.X - (width_extent / 2), bbox.Centre.X + (width_extent / 2), bbox.Centre.Y - (height_extent / 2), bbox.Centre.Y + (height_extent / 2));
+ double xdist = Math.Abs(p1.X - p2.X);
+ double ydist = Math.Abs(p1.Y - p2.Y);
+ return Math.Sqrt((xdist * xdist) + (ydist * ydist));
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/IServerConnection.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/IServerConnection.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/IServerConnection.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -24,6 +24,7 @@
using OSGeo.MapGuide.MaestroAPI.Commands;
@@ -46,6 +47,18 @@
public interface IServerConnection
/// <summary>
+ /// Gets the name of the provider of this implementation
+ /// </summary>
+ string ProviderName { get; }
+ /// <summary>
+ /// Gets a collection of name-value parameters required to create another copy
+ /// of this connection via the <see cref="T:OSGeo.MapGuide.MaestroAPI.ConnectionProviderRegistry"/>
+ /// </summary>
+ NameValueCollection CloneParameters { get; }
+ /// <summary>
/// Returns a clone copy of this connection
/// </summary>
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-12-09 07:21:20 UTC (rev 5451)
@@ -166,6 +166,7 @@
<Compile Include="..\Properties\GlobalAssemblyInfo.cs">
<Link>GlobalAssemblyInfo.cs</Link>
</Compile>
+ <Compile Include="ArgumentParser.cs" />
<Compile Include="BindingListExtensions.cs" />
<Compile Include="Commands\IGetResourceContents.cs" />
<Compile Include="Capability\ConnectionCapabilities.cs" />
@@ -173,6 +174,11 @@
<Compile Include="Commands\CommandType.cs" />
<Compile Include="Commands\ExecuteLoadProcedure.cs" />
<Compile Include="Commands\ICommand.cs" />
+ <Compile Include="CoordinateSystem\ActualCoordinateSystem.cs" />
+ <Compile Include="CoordinateSystem\DegreeBasedCoordinateSystem.cs" />
+ <Compile Include="CoordinateSystem\CoordinateSystemBase.cs" />
+ <Compile Include="CoordinateSystem\FeetBasedCoordinateSystem.cs" />
+ <Compile Include="CoordinateSystem\MeterBasedCoordinateSystem.cs" />
<Compile Include="Exceptions\CustomPropertyNotFoundException.cs" />
<Compile Include="Exceptions\ExpressionException.cs" />
<Compile Include="Exceptions\MaestroException.cs" />
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/PlatformConnectionBase.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -29,10 +29,11 @@
using OSGeo.MapGuide.MaestroAPI.Mapping;
+using OSGeo.MapGuide.MaestroAPI.Serialization;
+using OSGeo.MapGuide.MaestroAPI.CoordinateSystem;
using OSGeo.MapGuide.ObjectModels.MapDefinition;
-using OSGeo.MapGuide.MaestroAPI.Serialization;
using OSGeo.MapGuide.ObjectModels.Common;
-using CS = Topology.CoordinateSystems;
@@ -234,6 +235,18 @@
#endregion
/// <summary>
+ /// </summary>
+ public abstract string ProviderName { get; }
+ /// <summary>
+ /// </summary>
+ public abstract NameValueCollection CloneParameters { get; }
+ /// <summary>
/// Gets the current SessionID.
/// </summary>
abstract public string SessionID { get; }
@@ -1679,27 +1692,32 @@
#endregion
#region runtime map
- private static string ParseUnit(string wkt)
+ protected virtual double InferMPU(string csWkt, double units)
- if (string.IsNullOrEmpty(wkt))
- return null;
- int index = wkt.IndexOf("UNIT[\"");
- if (index >= 0)
- int end = wkt.IndexOf("\"", index);
- return wkt.Substring(index, end - index).ToUpper();
- return null;
+ var cs = CoordinateSystemBase.Create(csWkt);
+ return cs.MetersPerUnitX * units;
+ public RuntimeMap CreateMap(string runtimeMapResourceId, string baseMapDefinitionId)
+ var mdf = (IMapDefinition)GetResource(baseMapDefinitionId);
+ var mpu = InferMPU(mdf.CoordinateSystem, 1.0);
+ return CreateMap(runtimeMapResourceId, mdf, mpu);
public virtual RuntimeMap CreateMap(string runtimeMapResourceId, string baseMapDefinitionId, double metersPerUnit)
return CreateMap(runtimeMapResourceId, mdf, metersPerUnit);
+ public RuntimeMap CreateMap(string runtimeMapResourceId, IMapDefinition mdf)
public virtual RuntimeMap CreateMap(string runtimeMapResourceId, IMapDefinition mdf, double metersPerUnit)
var map = new RuntimeMap(mdf, metersPerUnit);
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Services/IMappingService.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -31,6 +31,22 @@
public interface IMappingService : IService
/// <summary>
+ /// Creates a new runtime map instance from an existing map definition. Meters per unit
+ /// is calculated from the Coordinate System WKT of the map definition.
+ /// </summary>
+ /// <remarks>
+ /// Calculation of meters-per-unit may differ between implementations. This may have an adverse
+ /// effect on things such as rendering and measuring depending on the underlying implementation
+ /// If you are certain of the meters-per-unit value required, use the overloaded method that
+ /// accepts a metersPerUnit parameter.
+ /// </remarks>
+ /// <param name="runtimeMapResourceId"></param>
+ /// <param name="baseMapDefinitionId"></param>
+ RuntimeMap CreateMap(string runtimeMapResourceId, string baseMapDefinitionId);
+ /// <summary>
/// </summary>
@@ -40,6 +56,22 @@
RuntimeMap CreateMap(string runtimeMapResourceId, string baseMapDefinitionId, double metersPerUnit);
/// <summary>
+ /// </summary>
+ /// <remarks>
+ /// </remarks>
+ /// <param name="mdf"></param>
+ RuntimeMap CreateMap(string runtimeMapResourceId, IMapDefinition mdf);
+ /// <summary>
/// </summary>
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpCoordinateSystem.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpCoordinateSystem.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpCoordinateSystem.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -29,11 +29,11 @@
/// Interface to MapGuide coordinate system functions.
/// Only works with server > 1.2, since the coordinate mapping is not avalible through Http on older versions
/// </summary>
- public class HttpCoordinateSystem : CoordinateSystem.CoordinateSystemBase
+ public class HttpCoordinateSystemDefinition : CoordinateSystem.CoordinateSystemDefinitionBase
- internal HttpCoordinateSystem() : base() { }
+ internal HttpCoordinateSystemDefinition() : base() { }
- internal HttpCoordinateSystem(CoordinateSystemCategory parent, XmlNode topnode) : base(parent)
+ internal HttpCoordinateSystemDefinition(CoordinateSystemCategory parent, XmlNode topnode) : base(parent)
foreach (XmlNode node in topnode.ChildNodes)
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpCoordinateSystemCatalog.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpCoordinateSystemCatalog.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpCoordinateSystemCatalog.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -106,7 +106,7 @@
public override bool IsLoaded { get { return m_categories != null; } }
- public override CoordinateSystem.CoordinateSystemBase[] EnumerateCoordinateSystems(string category)
+ public override CoordinateSystem.CoordinateSystemDefinitionBase[] EnumerateCoordinateSystems(string category)
CoordinateSystemCategory cat = null;
foreach (CoordinateSystemCategory csc in this.Categories)
@@ -119,22 +119,22 @@
if (cat == null)
- return new CoordinateSystemBase[0];
+ return new CoordinateSystemDefinitionBase[0];
string req = this.RequestBuilder.EnumerateCoordinateSystems(category);
XmlDocument doc = new XmlDocument();
doc.Load(m_con.OpenRead(req));
XmlNodeList lst = doc.SelectNodes("BatchPropertyCollection/PropertyCollection");
- CoordinateSystemBase[] data = new CoordinateSystemBase[lst.Count];
+ CoordinateSystemDefinitionBase[] data = new CoordinateSystemDefinitionBase[lst.Count];
for (int i = 0; i < lst.Count; i++)
- data[i] = new HttpCoordinateSystem(cat, lst[i]);
+ data[i] = new HttpCoordinateSystemDefinition(cat, lst[i]);
return data;
- public override CoordinateSystem.CoordinateSystemBase CreateEmptyCoordinateSystem()
+ public override CoordinateSystem.CoordinateSystemDefinitionBase CreateEmptyCoordinateSystem()
- return new HttpCoordinateSystem();
+ return new HttpCoordinateSystemDefinition();
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -78,6 +78,23 @@
m_reqBuilder = builder;
+ public override NameValueCollection CloneParameters
+ get
+ nvc["Url"] = this.BaseURL;
+ nvc[CommandLineArguments.Provider] = this.ProviderName;
+ nvc[CommandLineArguments.Session] = this.SessionID;
+ return nvc;
+ public override string ProviderName
+ get { return "Maestro.Http"; }
/// <summary>
/// Gets whether this connection was initialised with an Anonymous login. If it was, it will return true.
/// If this was not, or it was initialised from an existing session id, then it will return false.
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeConnection.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -99,6 +99,23 @@
+ get { return "Maestro.LocalNative"; }
+ get
+ nvc[PARAM_CONFIG] = m_webconfig;
+ return nvc;
private void InitConnection(string sessionid)
MgUserInformation mgui = new MgUserInformation(sessionid);
@@ -141,6 +158,25 @@
+ protected override double InferMPU(string csWkt, double units)
+ try
+ MgCoordinateSystemFactory csFact = new MgCoordinateSystemFactory();
+ MgCoordinateSystem cs = csFact.Create(csWkt);
+ return cs.ConvertMetersToCoordinateSystemUnits(units);
+ catch (MgException ex) //Not implemented due to wrapping Proj.4?
+ ex.Dispose();
+ return base.InferMPU(csWkt, units);
+ catch (Exception ex) //Binding to assembly with pre-refactored CS API?
public override ResourceList GetRepositoryResources(string startingpoint, string type, int depth, bool computeChildren)
if (type == null)
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeCoordinateSystem.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeCoordinateSystem.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeCoordinateSystem.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -25,11 +25,11 @@
namespace OSGeo.MapGuide.MaestroAPI.Native
- public class LocalNativeCoordinateSystem : CoordinateSystemBase
+ public class LocalNativeCoordinateSystemDefinition : CoordinateSystemDefinitionBase
- internal LocalNativeCoordinateSystem() : base() { }
+ internal LocalNativeCoordinateSystemDefinition() : base() { }
- internal LocalNativeCoordinateSystem(CoordinateSystemCategory parent, MgPropertyCollection props)
+ internal LocalNativeCoordinateSystemDefinition(CoordinateSystemCategory parent, MgPropertyCollection props)
: base(parent)
for (int i = 0; i < props.Count; i++)
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeCoordinateSystemCatalog.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeCoordinateSystemCatalog.cs 2010-12-09 01:19:32 UTC (rev 5450)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Native/LocalNativeCoordinateSystemCatalog.cs 2010-12-09 07:21:20 UTC (rev 5451)
@@ -92,7 +92,7 @@
- public override CoordinateSystemBase[] EnumerateCoordinateSystems(string category)
+ public override CoordinateSystemDefinitionBase[] EnumerateCoordinateSystems(string category)
@@ -105,19 +105,19 @@
if (cat == null)
MgBatchPropertyCollection bp = m_cf.EnumerateCoordinateSystems(category);
- List<CoordinateSystemBase> lst = new List<CoordinateSystemBase>();
+ List<CoordinateSystemDefinitionBase> lst = new List<CoordinateSystemDefinitionBase>();
for (int i = 0; i < bp.Count; i++)
- lst.Add(new LocalNativeCoordinateSystem(cat, bp[i]));
+ lst.Add(new LocalNativeCoordinateSystemDefinition(cat, bp[i]));
return lst.ToArray();
- public override CoordinateSystemBase CreateEmptyCoordinateSystem()
+ public override CoordinateSystemDefinitionBase CreateEmptyCoordinateSystem()
- return new LocalNativeCoordinateSystem();
+ return new LocalNativeCoordinateSystemDefinition();
More information about the mapguide-commits
