[mapguide-commits] r5453 - in sandbox/maestro-3.0: Maestro.Base
Maestro.Base/Properties
Maestro.Base/Services/DragDropHandlers Maestro.Editors/Common
Maestro.Editors/Properties
svn_mapguide at osgeo.org
Thu Dec 9 05:57:00 EST 2010
Author: jng
Date: 2010-12-09 02:57:00 -0800 (Thu, 09 Dec 2010)
New Revision: 5453
Added:
sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/PackageFileHandler.cs
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
sandbox/maestro-3.0/Maestro.Editors/Common/ResourceDataCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
3.0 sandbox changes:
- #1564: Implement drag/drop package loading
- #1565: Resource Data UI improvements
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-12-09 08:31:01 UTC (rev 5452)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-12-09 10:57:00 UTC (rev 5453)
@@ -31,6 +31,7 @@
<!-- Registered drop handlers -->
<Path name="/Maestro/DragDropHandlers">
+ <Class id="MgpHandler" class="Maestro.Base.Services.DragDropHandlers.PackageFileHandler" />
<Class id="SdfHandler" class="Maestro.Base.Services.DragDropHandlers.SdfFileHandler" />
<Class id="ShpHandler" class="Maestro.Base.Services.DragDropHandlers.ShpFileHandler" />
<Class id="SltHandler" class="Maestro.Base.Services.DragDropHandlers.SltFileHandler" />
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-12-09 08:31:01 UTC (rev 5452)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-12-09 10:57:00 UTC (rev 5453)
@@ -212,6 +212,7 @@
</Compile>
<Compile Include="Services\ClipboardService.cs" />
<Compile Include="Services\DragDropHandlerService.cs" />
+ <Compile Include="Services\DragDropHandlers\PackageFileHandler.cs" />
<Compile Include="Services\DragDropHandlers\SltFileHandler.cs" />
<Compile Include="Services\DragDropHandlers\SdfFileHandler.cs" />
<Compile Include="Services\DragDropHandlers\ShpFileHandler.cs" />
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-12-09 08:31:01 UTC (rev 5452)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-12-09 10:57:00 UTC (rev 5453)
@@ -292,6 +292,15 @@
/// <summary>
+ /// Looks up a localized string similar to Confirm.
+ /// </summary>
+ internal static string Confirm {
+ get {
+ return ResourceManager.GetString("Confirm", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to You have open editors with unsaved changes. Continue anyway?.
/// </summary>
internal static string ConfirmCloseEditors {
@@ -319,6 +328,15 @@
/// <summary>
+ /// Looks up a localized string similar to Are you sure you want to load this package file?.
+ /// </summary>
+ internal static string ConfirmLoadPackage {
+ get {
+ return ResourceManager.GetString("ConfirmLoadPackage", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Are you sure you want to move the following resources?.
/// </summary>
internal static string ConfirmMove {
@@ -961,6 +979,15 @@
/// <summary>
+ /// Looks up a localized string similar to Load this package file.
+ /// </summary>
+ internal static string MgpHandlerAction {
+ get {
+ return ResourceManager.GetString("MgpHandlerAction", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Failed to move {0} to {1}.
/// </summary>
internal static string MoveFailure {
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-12-09 08:31:01 UTC (rev 5452)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-12-09 10:57:00 UTC (rev 5453)
@@ -799,4 +799,13 @@
<data name="Menu_Window" xml:space="preserve">
<value>Window</value>
</data>
+ <data name="MgpHandlerAction" xml:space="preserve">
+ <value>Load this package file</value>
+ </data>
+ <data name="Confirm" xml:space="preserve">
+ <value>Confirm</value>
+ </data>
+ <data name="ConfirmLoadPackage" xml:space="preserve">
+ <value>Are you sure you want to load this package file?</value>
+ </data>
</root>
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/PackageFileHandler.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/PackageFileHandler.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Services/DragDropHandlers/PackageFileHandler.cs 2010-12-09 10:57:00 UTC (rev 5453)
@@ -0,0 +1,72 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using System.IO;
+using ICSharpCode.Core;
+using Maestro.Packaging;
+namespace Maestro.Base.Services.DragDropHandlers
+ public class PackageFileHandler : IDragDropHandler
+ public string HandlerAction
+ get { return Properties.Resources.MgpHandlerAction; }
+ string[] extensions = { ".mgp" };
+ public string[] FileExtensions
+ get { return extensions; }
+ public bool HandleDrop(string file, string folderId)
+ try
+ if (!MessageService.AskQuestion(Properties.Resources.ConfirmLoadPackage, Properties.Resources.Confirm))
+ return false;
+ var wb = Workbench.Instance;
+ var exp = wb.ActiveSiteExplorer;
+ var mgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ var conn = mgr.GetConnection(exp.ConnectionName);
+ var res = PackageProgress.UploadPackage(
+ wb,
+ conn,
+ file);
+ if (res == System.Windows.Forms.DialogResult.OK)
+ exp.RefreshModel();
+ return false; //Already refreshed if successful
+ catch (Exception ex)
+ MessageService.ShowError(ex);
+ return false;
Modified: sandbox/maestro-3.0/Maestro.Editors/Common/ResourceDataCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/Common/ResourceDataCtrl.cs 2010-12-09 08:31:01 UTC (rev 5452)
+++ sandbox/maestro-3.0/Maestro.Editors/Common/ResourceDataCtrl.cs 2010-12-09 10:57:00 UTC (rev 5453)
@@ -197,6 +197,9 @@
var item = this.SelectedItem;
if (item != null)
+ if (MessageBox.Show(Properties.Resources.ConfirmDeleteResourceData, Properties.Resources.Confirm, MessageBoxButtons.YesNo) == DialogResult.No)
+ return;
try
using (new WaitCursor(this))
@@ -225,6 +228,7 @@
using (var save = DialogFactory.SaveFile())
+ save.FileName = item.Name;
if (save.ShowDialog() == DialogResult.OK)
try
@@ -239,7 +243,7 @@
Utility.CopyStream(stream, fs);
- MessageBox.Show(Properties.Resources.FileDownloaded);
+ MessageBox.Show(string.Format(Properties.Resources.FileDownloaded, save.FileName));
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs 2010-12-09 08:31:01 UTC (rev 5452)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs 2010-12-09 10:57:00 UTC (rev 5453)
@@ -319,6 +319,15 @@
/// <summary>
+ /// Looks up a localized string similar to Are you sure you want to delete this resource data?.
+ /// </summary>
+ internal static string ConfirmDeleteResourceData {
+ get {
+ return ResourceManager.GetString("ConfirmDeleteResourceData", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to The content file does not exist.
/// </summary>
internal static string ContentFileMissing {
@@ -550,7 +559,7 @@
/// <summary>
- /// Looks up a localized string similar to File Downloaded.
+ /// Looks up a localized string similar to File Downloaded to {0}.
/// </summary>
internal static string FileDownloaded {
get {
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx 2010-12-09 08:31:01 UTC (rev 5452)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx 2010-12-09 10:57:00 UTC (rev 5453)
@@ -517,7 +517,7 @@
<value>..\Resources\icon_copy_disabled.gif;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="FileDownloaded" xml:space="preserve">
- <value>File Downloaded</value>
+ <value>File Downloaded to {0}</value>
</data>
<data name="ColumnHasNoValidDataError" xml:space="preserve">
<value>The selected column had no non-null values and cannot be used.</value>
@@ -1061,4 +1061,7 @@
<data name="FilterXml" xml:space="preserve">
<value>XML Files (.xml)|*.xml</value>
</data>
+ <data name="ConfirmDeleteResourceData" xml:space="preserve">
+ <value>Are you sure you want to delete this resource data?</value>
+ </data>
</root>
More information about the mapguide-commits
