[mapguide-commits] r5459 - trunk/MgDev/Common/Schema
svn_mapguide at osgeo.org
Thu Dec 9 21:56:39 EST 2010
Author: waltweltonlair
Date: 2010-12-09 18:56:39 -0800 (Thu, 09 Dec 2010)
New Revision: 5459
trunk/MgDev/Common/Schema/MapDefinition-2.3.0.xsd
Small schema comment fix...
Modified: trunk/MgDev/Common/Schema/MapDefinition-2.3.0.xsd
--- trunk/MgDev/Common/Schema/MapDefinition-2.3.0.xsd 2010-12-10 01:44:16 UTC (rev 5458)
+++ trunk/MgDev/Common/Schema/MapDefinition-2.3.0.xsd 2010-12-10 02:56:39 UTC (rev 5459)
@@ -150,7 +150,7 @@
</xs:complexType>
<xs:complexType name="BaseMapLayerGroupType">
<xs:annotation>
- <xs:documentation>BaseMapLayerGroupCommonType encapsulates the properties of a BaseMapLayerGroup. It extends MapLayerGroupCommonType by holding the layers in the group. The base map layer groups defines what layers are used to render a tile set in the HTML viewer.</xs:documentation>
+ <xs:documentation>BaseMapLayerGroupType encapsulates the properties of a BaseMapLayerGroup. It extends MapLayerGroupCommonType by holding the layers in the group. The base map layer groups defines what layers are used to render a tile set in the HTML viewer.</xs:documentation>
</xs:annotation>
<xs:complexContent>
<xs:extension base="MapLayerGroupCommonType">
More information about the mapguide-commits
