[mapguide-commits] FW: r5466 - in sandbox/maestro-3.0: Maestro.Base
Maestro.Base/Editor Maestro.Base/Services Maestro.Base/UI
Maestro.Base/UI/Packaging Maestro.Base/UI/Preferences Maestro.Editors
Maestro.Editors/Common Maestro.Editors/Diagnostics
Maestro.Editors/DrawingSour
Tom Fukushima
tom.fukushima at autodesk.com
Fri Dec 10 12:36:03 EST 2010
-----Original Message-----
From: svn_mapguide at osgeo.org [mailto:svn_mapguide at osgeo.org]
Sent: Friday, December 10, 2010 4:40 AM
To: mapguide-commits at lists.osgeo.org
Subject: r5466 - in sandbox/maestro-3.0: Maestro.Base Maestro.Base/Editor Maestro.Base/Services Maestro.Base/UI Maestro.Base/UI/Packaging Maestro.Base/UI/Preferences Maestro.Editors Maestro.Editors/Common Maestro.Editors/Diagnostics Maestro.Editors/DrawingSourc...
Author: jng
Date: 2010-12-10 03:39:50 -0800 (Fri, 10 Dec 2010)
New Revision: 5466
Added:
sandbox/maestro-3.0/Maestro.Base/Editor/SymbolDefinitionEditor.resx
sandbox/maestro-3.0/Maestro.Base/UI/SingletonViewContent.resx
sandbox/maestro-3.0/Maestro.Base/ViewContentBase.resx
sandbox/maestro-3.0/Maestro.Editors/Common/EditorBindableCollapsiblePanel.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/MySqlCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/PostgreSqlCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/CenterSelectionWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/ClearSelectionCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/LinkToViewWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/NavigatorWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/PanWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/RefreshMapWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/SelectionPanelWidgetCtrl.resx
Removed:
sandbox/maestro-3.0/Maestro.Base/UI/EmbeddedWebBrowser.Designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/EmbeddedWebBrowser.cs
sandbox/maestro-3.0/Maestro.Base/UI/EmbeddedWebBrowser.resx
sandbox/maestro-3.0/Maestro.Base/UI/WelcomeScreen.Designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/WelcomeScreen.cs
sandbox/maestro-3.0/Maestro.Base/UI/WelcomeScreen.resx
sandbox/maestro-3.0/Maestro.Editors/Common/DataFilesCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Common/DataFilesCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/Common/DataFilesCtrl.resx
sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.resx
sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.resx
sandbox/maestro-3.0/Maestro.Base/Editor/FeatureSourceEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/FeatureSourceEditor.resx
sandbox/maestro-3.0/Maestro.Base/Editor/FsEditorOptionPanel.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/FsEditorOptionPanel.resx
sandbox/maestro-3.0/Maestro.Base/Editor/FusionEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/FusionEditor.resx
sandbox/maestro-3.0/Maestro.Base/Editor/LayerDefinitionEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/LayerDefinitionEditor.resx
sandbox/maestro-3.0/Maestro.Base/Editor/LoadProcedureEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/LoadProcedureEditor.resx
sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.resx
sandbox/maestro-3.0/Maestro.Base/Editor/PrintLayoutEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/PrintLayoutEditor.resx
sandbox/maestro-3.0/Maestro.Base/Editor/SymbolDefinitionEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/WebLayoutEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/WebLayoutEditor.resx
sandbox/maestro-3.0/Maestro.Base/Editor/XmlEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/XmlEditor.resx
sandbox/maestro-3.0/Maestro.Base/Editor/XmlEditorDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/XmlEditorDialog.resx
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
sandbox/maestro-3.0/Maestro.Base/Services/UrlLauncherService.cs
sandbox/maestro-3.0/Maestro.Base/UI/MessageViewer.Designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/MessageViewer.resx
sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.resx
sandbox/maestro-3.0/Maestro.Base/UI/OutboundRequestViewer.Designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/OutboundRequestViewer.resx
sandbox/maestro-3.0/Maestro.Base/UI/Packaging/CreatePackageDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/Packaging/CreatePackageDialog.resx
sandbox/maestro-3.0/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/Preferences/GeneralPreferencesCtrl.resx
sandbox/maestro-3.0/Maestro.Base/UI/Preferences/OptionsDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/Preferences/OptionsDialog.resx
sandbox/maestro-3.0/Maestro.Base/UI/RenameItemDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/RenameItemDialog.resx
sandbox/maestro-3.0/Maestro.Base/UI/ResourcePropertiesDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/ResourcePropertiesDialog.resx
sandbox/maestro-3.0/Maestro.Base/UI/SingletonViewContent.Designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.Designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.resx
sandbox/maestro-3.0/Maestro.Base/ViewContentBase.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Workbench.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Workbench.resx
sandbox/maestro-3.0/Maestro.Base/ZonedContainer.Designer.cs
sandbox/maestro-3.0/Maestro.Base/ZonedContainer.resx
sandbox/maestro-3.0/Maestro.Editors/Common/ColorComboWithTransparency.designer.cs
sandbox/maestro-3.0/Maestro.Editors/Common/ColorComboWithTransparency.resx
sandbox/maestro-3.0/Maestro.Editors/Common/CoordinateSystemPicker.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Common/CoordinateSystemPicker.resx
sandbox/maestro-3.0/Maestro.Editors/Common/EditorBindableCollapsiblePanel.cs
sandbox/maestro-3.0/Maestro.Editors/Common/GenericItemSelectionDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Common/GenericItemSelectionDialog.resx
sandbox/maestro-3.0/Maestro.Editors/Common/ResourceDataCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Common/ResourceDataCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.resx
sandbox/maestro-3.0/Maestro.Editors/Common/SourceDataCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Common/SourceDataCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Common/SymbolPicker.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Common/SymbolPicker.resx
sandbox/maestro-3.0/Maestro.Editors/Common/UnmanagedFileBrowser.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Common/UnmanagedFileBrowser.resx
sandbox/maestro-3.0/Maestro.Editors/Diagnostics/ServerStatusMonitor.designer.cs
sandbox/maestro-3.0/Maestro.Editors/Diagnostics/ServerStatusMonitor.resx
sandbox/maestro-3.0/Maestro.Editors/DrawingSource/DrawingSourceEditorCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/DrawingSource/DrawingSourceEditorCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/DrawingSource/SourceSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/DrawingSource/SourceSectionCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/CoordSys/CoordSysOverrideDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/CoordSys/CoordSysOverrideDialog.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/CoordSysOverrideCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/CoordSysOverrideCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/CalculationSettings.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/CalculationSettings.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/SelectJoinKeyDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/SelectJoinKeyDialog.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/ExtensionsCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/ExtensionsCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/FeatureSourceEditorCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/FeatureSourceEditorCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Preview/LocalFeatureSourcePreviewCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Preview/PreviewPane.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Preview/PreviewPane.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Preview/SqlQueryCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Preview/SqlQueryCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Preview/StandardQueryCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Preview/StandardQueryCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/FileBasedCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/FileBasedCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/GenericCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/GenericCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/MySqlCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/PostgreSqlCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/SqlServerSpatialCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/SqlServerSpatialCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/SQLite/SQLiteFileCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/SQLite/SQLiteFileCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Sdf/SdfFileCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Sdf/SdfFileCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Shp/ShpFileCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Shp/ShpFileCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexLayoutSettingsCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexLayoutSettingsCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexibleLayoutEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/FlexibleLayoutEditor.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/MapCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/MapCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/MapSettingsCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/AboutWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/AboutWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/ActivityIndicatorWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/ActivityIndicatorWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/BufferPanelWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/BufferPanelWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/BufferWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/BufferWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/CenterSelectionWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/ClearSelectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/ColorPickerWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/ColorPickerWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/CursorPositionWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/CursorPositionWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/EditableScaleWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/EditableScaleWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/ExtentHistoryWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/ExtentHistoryWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/FeatureInfoWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/FeatureInfoWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/GenericWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/GenericWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/HelpWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/HelpWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/InitialMapViewWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/InitialMapViewWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/InvokeScriptWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/InvokeScriptWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/LegendWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/LegendWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/LinkToViewWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/MapMenuWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/MapMenuWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/MapTipWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/MapTipWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/MeasureWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/MeasureWidgetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/NavigatorWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/PanWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/RefreshMapWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/SelectionPanelWidgetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/WidgetEditorBase.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetEditors/WidgetEditorBase.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetReferenceCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetReferenceCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetSettingsCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Fusion/WidgetSettingsCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Generic/ResourceDataPanel.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Generic/ResourceDataPanel.resx
sandbox/maestro-3.0/Maestro.Editors/Generic/XmlEditorCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Generic/XmlEditorCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Generic/XmlValidationResult.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Generic/XmlValidationResult.resx
sandbox/maestro-3.0/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/LayerDefinition/Drawing/DrawingLayerSettingsCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/LayerDefinition/DrawingLayerEditorCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/LayerDefinition/DrawingLayerEditorCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/LayerDefinition/LayerPropertiesSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/LayerDefinition/LayerPropertiesSectionCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/LayerDefinition/Vector/VectorLayerStyleSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/LayerDefinition/Vector/VectorLayerStyleSectionCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/LayerDefinition/VectorLayerEditorCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/LoadProcedure/DwfTransformationCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/LoadProcedure/DwfTransformationCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/LoadProcedure/ExecuteCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/LoadProcedure/ExecuteCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/LoadProcedure/InputFilesCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/LoadProcedure/InputFilesCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/LoadProcedure/LoadProcedureEditorCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/LoadProcedure/LoadProcedureEditorCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/LoadProcedure/LoadTargetCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/LoadProcedure/LoadTargetCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/LoadProcedure/SdfTransformationCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/LoadProcedure/SdfTransformationCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/LoadProcedure/ShpTransformationCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/LoadProcedure/ShpTransformationCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/LoadProcedure/SqliteTransformationCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/LoadProcedure/SqliteTransformationCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/FiniteScaleListCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ManualScaleEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/ManualScaleEditor.resx
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/Migration/CopyMoveToServerDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Migration/CopyMoveToServerDialog.resx
sandbox/maestro-3.0/Maestro.Editors/Migration/MigrateDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Migration/MigrateDialog.resx
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/LogoDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/LogoDialog.resx
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomLogosSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomLogosSectionCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomTextSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintCustomTextSectionCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintLayoutEditorCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintLayoutEditorCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintPagePropertiesSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/PrintPagePropertiesSectionCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/TextDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/PrintLayout/TextDialog.resx
sandbox/maestro-3.0/Maestro.Editors/WebLayout/Commands/InvokeScriptCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/WebLayout/Commands/InvokeScriptCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/WebLayout/Commands/InvokeURLCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/WebLayout/Commands/InvokeURLCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/WebLayout/Commands/SearchCmdCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/WebLayout/Commands/SearchCmdCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/WebLayout/CustomCommandPropertyCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/WebLayout/CustomCommandPropertyCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/WebLayout/MenuEditorCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/WebLayout/MenuEditorCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/WebLayout/WebLayoutCommandsCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/WebLayout/WebLayoutEditorCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/WebLayout/WebLayoutEditorCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/WebLayout/WebLayoutMenusCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/WebLayout/WebLayoutMenusCtrl.resx
sandbox/maestro-3.0/Maestro.Editors/WebLayout/WebLayoutSettingsCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/WebLayout/WebLayoutSettingsCtrl.resx
sandbox/maestro-3.0/Maestro.Login/HttpLoginCtrl.designer.cs
sandbox/maestro-3.0/Maestro.Login/HttpLoginCtrl.resx
sandbox/maestro-3.0/Maestro.Login/LocalNativeLoginCtrl.designer.cs
sandbox/maestro-3.0/Maestro.Login/LocalNativeLoginCtrl.resx
sandbox/maestro-3.0/Maestro.Login/LoginDialog.designer.cs
sandbox/maestro-3.0/Maestro.Login/LoginDialog.resx
sandbox/maestro-3.0/Maestro.Shared.UI/CollapsiblePanel.designer.cs
sandbox/maestro-3.0/Maestro.Shared.UI/CollapsiblePanel.resx
sandbox/maestro-3.0/MaestroFsPreview/MainForm.Designer.cs
sandbox/maestro-3.0/MaestroFsPreview/MainForm.resx
3.0 sandbox changes:
- Remove unused UI controls
- Set Localizable = true to all UI components and set AutoScaleMode = None (for Mono)
More information about the mapguide-commits
