[mapguide-commits] r5475 - in sandbox/maestro-3.0: Maestro
Properties
svn_mapguide at osgeo.org
Mon Dec 13 07:47:42 EST 2010
Author: jng
Date: 2010-12-13 04:47:42 -0800 (Mon, 13 Dec 2010)
New Revision: 5475
sandbox/maestro-3.0/Maestro/changelog.txt
sandbox/maestro-3.0/Properties/GlobalAssemblyInfo.cs
Prep for test build #4
Modified: sandbox/maestro-3.0/Maestro/changelog.txt
--- sandbox/maestro-3.0/Maestro/changelog.txt 2010-12-13 12:33:52 UTC (rev 5474)
+++ sandbox/maestro-3.0/Maestro/changelog.txt 2010-12-13 12:47:42 UTC (rev 5475)
@@ -1,6 +1,25 @@
-Test Build 3
+Test Build 4
+ - Added drag/drop package loading
+ - Added resource re-pointer function as suggested by Jason Birch
+ - Added warnings about tiled map invalidation when saving any possible affected resource
+ - Add API to create runtime map and infer the meters-per-unit value. Uses TF.net for HTTP implementation and MgCoordinateSystem for Local implementation
+ - Resource Data UI prompts confirmation on delete and when downloading, will show the downloaded location.
+ - Fix layer up/down drag/drop reordering in Map Definition editor
+ - Fix Coodinate System not being set in SHP load procedure editor
+ - Fix feature source extension nodes not being deleted on remove
+ - More fusion editor progress:
+ - Drag/drop map support
+ - Remaining missing functionality:
+ - Add/Remove/Edit containers
+ - Widget set configuration
+ - Add new widget from WidgetInfo
+ - Edit widget parameters
+ - Remove widget from widget set
+Test Build 3
- Migrated: Runtime Map API, with batched layer loading support improving create performance
- Specialized SQLite editor
- Partially migrated Fusion editor w/ Commerical Map Layer support
Modified: sandbox/maestro-3.0/Properties/GlobalAssemblyInfo.cs
--- sandbox/maestro-3.0/Properties/GlobalAssemblyInfo.cs 2010-12-13 12:33:52 UTC (rev 5474)
+++ sandbox/maestro-3.0/Properties/GlobalAssemblyInfo.cs 2010-12-13 12:47:42 UTC (rev 5475)
@@ -35,5 +35,5 @@
// You can specify all the values or you can default the Build and Revision Numbers
// by using the '*' as shown below:
// [assembly: AssemblyVersion("1.0.*")]
-[assembly: AssemblyVersion("3.0.0.5334")]
-[assembly: AssemblyFileVersion("3.0.0.5334")]
+[assembly: AssemblyVersion("3.0.0.5475")]
+[assembly: AssemblyFileVersion("3.0.0.5475")]
More information about the mapguide-commits
