[mapguide-commits] r5482 - in sandbox/maestro-3.0: Maestro Maestro.Editors/MapDefinition Maestro.Editors/Properties OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/CoordinateSystem
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Dec 22 01:37:17 EST 2010
Author: jng
Date: 2010-12-21 22:37:17 -0800 (Tue, 21 Dec 2010)
New Revision: 5482
Added:
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/ISimpleTransform.cs
   sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs
   sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
   sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
   sandbox/maestro-3.0/Maestro/Maestro_All.sln
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
Fix #1578: Attempt re-projection of extents when changing coordinate systems in Map Editor. Note we're not using CS-Map due to the desire of maintaining Mono compatibility, but instead using a pre-existing coordinate transformation functionality of the TF.NET library we're using, so some transformations will fail.
Modified: sandbox/maestro-3.0/Maestro/Maestro_All.sln
--- sandbox/maestro-3.0/Maestro/Maestro_All.sln	2010-12-22 04:40:33 UTC (rev 5481)
+++ sandbox/maestro-3.0/Maestro/Maestro_All.sln	2010-12-22 06:37:17 UTC (rev 5482)
@@ -1,6 +1,6 @@
 Microsoft Visual Studio Solution File, Format Version 10.00
-# Visual C# Express 2008
+# Visual Studio 2008
 Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Maestro", "Maestro.csproj", "{E0C36475-2B70-4F6D-ACE0-8943167806DC}"
 EndProject
 Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "ICSharpCode.Core", "..\Thirdparty\SharpDevelop\ICSharpCode.Core\ICSharpCode.Core.csproj", "{35CEF10F-2D4C-45F2-9DD1-161E0FEC583C}"
@@ -9,8 +9,6 @@
 EndProject
 Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Maestro.Base", "..\Maestro.Base\Maestro.Base.csproj", "{F1E2F468-5030-4DBA-968C-9620284AFAA1}"
 EndProject
-Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "MaestroBaseTests", "..\MaestroBaseTests\MaestroBaseTests.csproj", "{CE5F281C-0162-4832-87BB-A677D13D116F}"
-EndProject
 Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "MaestroFsPreview", "..\MaestroFsPreview\MaestroFsPreview.csproj", "{59BE5E18-17B6-431D-836E-C0AABA6D69E8}"
 EndProject
 Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Maestro.AddIn.ExtendedObjectModels", "..\Maestro.AddIn.ExtendedObjectModels\Maestro.AddIn.ExtendedObjectModels.csproj", "{32BA7DF6-1AFA-441D-9231-5624C5920706}"
@@ -71,10 +69,6 @@
 		{F1E2F468-5030-4DBA-968C-9620284AFAA1}.Debug|Any CPU.Build.0 = Debug|Any CPU
 		{F1E2F468-5030-4DBA-968C-9620284AFAA1}.Release|Any CPU.ActiveCfg = Release|Any CPU
 		{F1E2F468-5030-4DBA-968C-9620284AFAA1}.Release|Any CPU.Build.0 = Release|Any CPU
-		{CE5F281C-0162-4832-87BB-A677D13D116F}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
-		{CE5F281C-0162-4832-87BB-A677D13D116F}.Debug|Any CPU.Build.0 = Debug|Any CPU
-		{CE5F281C-0162-4832-87BB-A677D13D116F}.Release|Any CPU.ActiveCfg = Release|Any CPU
-		{CE5F281C-0162-4832-87BB-A677D13D116F}.Release|Any CPU.Build.0 = Release|Any CPU
 		{59BE5E18-17B6-431D-836E-C0AABA6D69E8}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
 		{59BE5E18-17B6-431D-836E-C0AABA6D69E8}.Debug|Any CPU.Build.0 = Debug|Any CPU
 		{59BE5E18-17B6-431D-836E-C0AABA6D69E8}.Release|Any CPU.ActiveCfg = Release|Any CPU
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs	2010-12-22 04:40:33 UTC (rev 5481)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs	2010-12-22 06:37:17 UTC (rev 5482)
@@ -31,6 +31,7 @@
 using OSGeo.MapGuide.MaestroAPI;
 using OSGeo.MapGuide.ObjectModels.MapDefinition;
 using System.Globalization;
+using OSGeo.MapGuide.MaestroAPI.CoordinateSystem;
 namespace Maestro.Editors.MapDefinition
@@ -152,7 +153,11 @@
                     _map.Extents.MaxY = d;
-            _map.Extents.PropertyChanged += (sender, e) => { OnResourceChanged(); };
+            _map.Extents.PropertyChanged += (sender, e) =>
+                UpdateExtentsFromMap();
+                OnResourceChanged();
         private void UpdateExtentsFromMap()
@@ -176,7 +181,35 @@
             string cs = _service.GetCoordinateSystem();
             if (!string.IsNullOrEmpty(cs))
+                string oldCs = txtCoordinateSystem.Text;
                 txtCoordinateSystem.Text = cs;
+                if (_map.Extents != null && !string.IsNullOrEmpty(oldCs) && !string.IsNullOrEmpty(cs) && !oldCs.Equals(cs))
+                    //Transform current extents
+                    try
+                        var trans = new DefaultSimpleTransform(oldCs, cs);
+                        var oldExt = _map.Extents;
+                        double llx;
+                        double lly;
+                        double urx;
+                        double ury;
+                        trans.Transform(oldExt.MinX, oldExt.MinY, out llx, out lly);
+                        trans.Transform(oldExt.MaxX, oldExt.MaxY, out urx, out ury);
+                        _map.Extents.MinX = llx;
+                        _map.Extents.MinY = lly;
+                        _map.Extents.MaxX = urx;
+                        _map.Extents.MaxY = ury;
+                    catch (Exception ex)
+                        MessageBox.Show(string.Format(Properties.Resources.CoordinateTransformationFailed, ex.Message));
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs	2010-12-22 04:40:33 UTC (rev 5481)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs	2010-12-22 06:37:17 UTC (rev 5482)
@@ -231,22 +231,22 @@
         /// <summary>
-        ///   Looks up a localized string similar to &quot;ColorName&quot;,&quot;NumOfColors&quot;,&quot;Type&quot;,&quot;CritVal&quot;,&quot;ColorNum&quot;,&quot;ColorLetter&quot;,&quot;R&quot;,&quot;G&quot;,&quot;B&quot;,&quot;SchemeType&quot;
-        ///&quot;Accent&quot;,3,&quot;qual&quot;,,1,&quot;A&quot;,127,201,127,&quot;Qualitative&quot;
-        ///,,,,2,&quot;B&quot;,190,174,212,
-        ///,,,,3,&quot;C&quot;,253,192,134,
-        ///&quot;Accent&quot;,4,&quot;qual&quot;,,1,&quot;A&quot;,127,201,127,
-        ///,,,,4,&quot;D&quot;,255,255,153,
-        ///&quot;Accent&quot;,5,&quot;qual&quot;,,1,&quot;A&quot;,127,201,127,
-        ///,,,,5,&quot;E&quot;,56,108,176,
-        ///&quot;Accent&quot;,6,&quot;qual&quot;,,1,&quot;A&quot;,127,201,127,
+        ///   Looks up a localized string similar to &quot;ColorName&quot;,&quot;NumOfColors&quot;,&quot;Type&quot;,&quot;CritVal&quot;,&quot;ColorNum&quot;,&quot;ColorLetter&quot;,&quot;R&quot;,&quot;G&quot;,&quot;B&quot;,&quot;SchemeType&quot;
+        ///&quot;Accent&quot;,3,&quot;qual&quot;,,1,&quot;A&quot;,127,201,127,&quot;Qualitative&quot;
+        ///,,,,2,&quot;B&quot;,190,174,212,
+        ///,,,,3,&quot;C&quot;,253,192,134,
+        ///&quot;Accent&quot;,4,&quot;qual&quot;,,1,&quot;A&quot;,127,201,127,
+        ///,,,,4,&quot;D&quot;,255,255,153,
+        ///&quot;Accent&quot;,5,&quot;qual&quot;,,1,&quot;A&quot;,127,201,127,
+        ///,,,,5,&quot;E&quot;,56,108,176,
+        ///&quot;Accent&quot;,6,&quot;qual&quot;,,1,&quot;A&quot;,127,201,127,
         ///,, [rest of string was truncated]&quot;;.
         /// </summary>
         internal static string ColorBrewer {
@@ -350,6 +350,15 @@
+        /// <summary>
+        ///   Looks up a localized string similar to Failed to transform coordinates: {0}.
+        /// </summary>
+        internal static string CoordinateTransformationFailed {
+            get {
+                return ResourceManager.GetString("CoordinateTransformationFailed", resourceCulture);
         internal static System.Drawing.Bitmap cross {
             get {
                 object obj = ResourceManager.GetObject("cross", resourceCulture);
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx	2010-12-22 04:40:33 UTC (rev 5481)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx	2010-12-22 06:37:17 UTC (rev 5482)
@@ -1070,4 +1070,7 @@
   <data name="SelectLayerFirst" xml:space="preserve">
     <value>Please select the layer first</value>
   </data>
+  <data name="CoordinateTransformationFailed" xml:space="preserve">
+    <value>Failed to transform coordinates: {0}</value>
+  </data>
 </root>
\ No newline at end of file
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/ISimpleTransform.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/ISimpleTransform.cs	                        (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/CoordinateSystem/ISimpleTransform.cs	2010-12-22 06:37:17 UTC (rev 5482)
@@ -0,0 +1,84 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+namespace OSGeo.MapGuide.MaestroAPI.CoordinateSystem
+    /// <summary>
+    /// A simple coordinate transformation interface
+    /// </summary>
+    public interface ISimpleTransform
+        /// <summary>
+        /// Transforms the specified point
+        /// </summary>
+        /// <param name="x">The X coordinate</param>
+        /// <param name="y">The Y coordinate</param>
+        /// <param name="tx">The transformed X coordinate</param>
+        /// <param name="ty">The transformed Y coordinate</param>
+        void Transform(double x, double y, out double tx, out double ty);
+    /// <summary>
+    /// A simple transform that wraps the NTS coordinate system transformation APIs
+    /// This does not handle some of the more complex transformations like CS-Map can,
+    /// such as WGS84.PseudoMercator (required for Google/Yahoo/Bing underlays in fusion)
+    /// </summary>
+    public class DefaultSimpleTransform : ISimpleTransform
+        private Topology.CoordinateSystems.ICoordinateSystem _source;
+        private Topology.CoordinateSystems.ICoordinateSystem _target;
+        private Topology.CoordinateSystems.Transformations.ICoordinateTransformation _trans;
+        /// <summary>
+        /// Initializes a new instance of the <see cref="DefaultSimpleTransform"/> class.
+        /// </summary>
+        /// <param name="sourceCsWkt">The source cs WKT.</param>
+        /// <param name="targetCsWkt">The target cs WKT.</param>
+        public DefaultSimpleTransform(string sourceCsWkt, string targetCsWkt)
+            var fact = new Topology.CoordinateSystems.CoordinateSystemFactory();
+            _source = fact.CreateFromWkt(sourceCsWkt);
+            _target = fact.CreateFromWkt(targetCsWkt);
+            var tfact = new Topology.CoordinateSystems.Transformations.CoordinateTransformationFactory();
+            _trans = tfact.CreateFromCoordinateSystems(_source, _target);
+        /// <summary>
+        /// </summary>
+        public void Transform(double x, double y, out double tx, out double ty)
+            tx = Double.NaN;
+            ty = Double.NaN;
+            double [] pts = _trans.MathTransform.Transform(new double[] { x, y });
+            tx = pts[0];
+            ty = pts[1];
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj	2010-12-22 04:40:33 UTC (rev 5481)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj	2010-12-22 06:37:17 UTC (rev 5482)
@@ -184,6 +184,7 @@
     <Compile Include="CoordinateSystem\DegreeBasedCoordinateSystem.cs" />
     <Compile Include="CoordinateSystem\CoordinateSystemBase.cs" />
     <Compile Include="CoordinateSystem\FeetBasedCoordinateSystem.cs" />
+    <Compile Include="CoordinateSystem\ISimpleTransform.cs" />
     <Compile Include="CoordinateSystem\MeterBasedCoordinateSystem.cs" />
     <Compile Include="Exceptions\CustomPropertyNotFoundException.cs" />
     <Compile Include="Exceptions\ExpressionException.cs" />
More information about the mapguide-commits mailing list
