[mapguide-commits] r5487 - in trunk/MgDev/Common: CoordinateSystem
Foundation/System Geometry Geometry/Buffer
MapGuideCommon/Controller MapGuideCommon/MapLayer
MapGuideCommon/Services MdfParser PlatformBase/Data
PlatformBase/MapLayer Renderers Stylization
svn_mapguide at osgeo.org
Wed Dec 29 01:32:51 EST 2010
Author: waltweltonlair
Date: 2010-12-28 22:32:51 -0800 (Tue, 28 Dec 2010)
New Revision: 5487
trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysCategory.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysCategoryDictionary.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysDatumDictionary.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysDictionary.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysEllipsoidDictionary.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysEnum.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysEnumCategory.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysEnumCoordinateSystemInCategory.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGrids.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysMgrs.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp
trunk/MgDev/Common/Foundation/System/Configuration.cpp
trunk/MgDev/Common/Foundation/System/Resources.cpp
trunk/MgDev/Common/Foundation/System/StreamData.cpp
trunk/MgDev/Common/Foundation/System/StreamReader.cpp
trunk/MgDev/Common/Geometry/Buffer/DumpFFGF.cpp
trunk/MgDev/Common/Geometry/Buffer/planeswp.cpp
trunk/MgDev/Common/Geometry/MultiCurveString.cpp
trunk/MgDev/Common/Geometry/MultiLineString.cpp
trunk/MgDev/Common/MapGuideCommon/Controller/DwfController.cpp
trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp
trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ConnectionProperties.cpp
trunk/MgDev/Common/MapGuideCommon/Services/PrintLayout.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ProxyDataReader.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureReader.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureTransaction.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ProxySqlDataReader.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ServerConnection.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionPool.cpp
trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionStack.cpp
trunk/MgDev/Common/MapGuideCommon/Services/Site.cpp
trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.cpp
trunk/MgDev/Common/MapGuideCommon/Services/SqlResult.cpp
trunk/MgDev/Common/MdfParser/SAX2ElementHandler.h
trunk/MgDev/Common/PlatformBase/Data/DateTimeProperty.cpp
trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.cpp
trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp
trunk/MgDev/Common/Renderers/AGGImageIO.cpp
trunk/MgDev/Common/Renderers/AGGRenderer.cpp
trunk/MgDev/Common/Renderers/AGGRenderer.h
trunk/MgDev/Common/Renderers/DWFRenderer.cpp
trunk/MgDev/Common/Renderers/EMapRenderer.cpp
trunk/MgDev/Common/Renderers/EMapUpdateRenderer.cpp
trunk/MgDev/Common/Renderers/EPlotRenderer.cpp
trunk/MgDev/Common/Renderers/FontManager.cpp
trunk/MgDev/Common/Renderers/KmlRenderer.cpp
trunk/MgDev/Common/Renderers/ObservationMesh.cpp
trunk/MgDev/Common/Stylization/Band.cpp
trunk/MgDev/Common/Stylization/DefaultStylizer.cpp
trunk/MgDev/Common/Stylization/GeometryAdapter.cpp
trunk/MgDev/Common/Stylization/LabelRenderer.h
trunk/MgDev/Common/Stylization/LabelRendererLocal.h
trunk/MgDev/Common/Stylization/LineStyleDef.cpp
trunk/MgDev/Common/Stylization/PointAdapter.cpp
trunk/MgDev/Common/Stylization/PolygonAdapter.cpp
trunk/MgDev/Common/Stylization/PolygonUtils.cpp
trunk/MgDev/Common/Stylization/PolylineAdapter.cpp
trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp
trunk/MgDev/Common/Stylization/SE_RenderProxies.h
trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h
trunk/MgDev/Common/Stylization/StylizationEngine.cpp
trunk/MgDev/Common/Stylization/StylizationUtil.cpp
I ran cppcheck (http://en.wikipedia.org/wiki/Cppcheck) against the MapGuide source code
(for now just the Common folder) and addressed some of the issues it pointed out:
- removed unused variables
- better initialization of some variables
- fixed a few memory leaks
- using prefix ++/-- operators for non-primitive types
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -737,7 +737,7 @@
assert(nNumErrs > 0);
//Make an array of integers to hold the error codes.
- int *pErrs = new int[nNumErrs];
+ pErrs = new int[nNumErrs];
if (NULL == pErrs)
throw new MgOutOfMemoryException(L"MgCoordinateSystem.GetErrors", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -3264,12 +3264,8 @@
throw new MgCoordinateSystemInitializationFailedException(L"MgCoordinateSystem.ConvertPoint", __LINE__, __WFILE__, NULL, L"MgCoordinateSystemNotReadyException", NULL);
- //If range checking is turned on, find out whether
- //we'll need to warn the caller later on.
- bool bWarn = false;
- int nResult;
//Do the conversion.
+ int nResult;
double dCoords[3] = { dSourceCoord1, dSourceCoord2, dSourceCoord3 };
CriticalClass.Enter();
nResult = convert(&m_csprm, dCoords, dCoords);
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysCatalog.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -303,7 +303,6 @@
wchar_t szFname[_MAX_FNAME] = {0};
wchar_t szExt[_MAX_EXT] = {0};
_tsplitpath(sDirPath.c_str(), szDrive, szDir, szFname, szExt);
- wchar_t* pNewDir=NULL;
if ((_tcslen(szFname) > 0) || (_tcslen(szExt) > 0))
//ABA: don't understand: if a filename or an extension has been found,
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysCategory.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysCategory.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysCategory.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -112,7 +112,7 @@
//Coordinate system names.
CSystemNameList::const_iterator iter;
- for (iter=m_listCoordinateSystemNames.begin(); iter!=m_listCoordinateSystemNames.end(); iter++)
+ for (iter=m_listCoordinateSystemNames.begin(); iter!=m_listCoordinateSystemNames.end(); ++iter)
CS_fwrite((*iter).Name(), sizeof(char), cs_KEYNM_DEF, pFile);
@@ -559,7 +559,7 @@
wchar_t *pName = Convert_Ascii_To_Wide((*iter).Name()); //need to delete [] pName
if (NULL == pName)
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysCategoryDictionary.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysCategoryDictionary.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysCategoryDictionary.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -200,7 +200,6 @@
MG_TRY()
assert(NULL != kpDefName);
- bool bReplace = (NULL != pDef);
STRING tempName;
STRING strPath=GetPath();
@@ -246,7 +245,6 @@
CCoordinateSystemCategory curDef(m_pCatalog);
CCoordinateSystemCategory *pDefToWrite;
bool bFound = false;
- bool bEndOfFileReached=false;
while (!feof(pFile))
//Get def from original file
@@ -863,7 +861,7 @@
throw new MgOutOfMemoryException(L"MgCoordinateSystemCategoryDictionary.Rename", __LINE__, __WFILE__, NULL, L"", NULL);
CCategoryNameList::iterator iterList;
- for (iterList = List().begin(); iterList != List().end(); iterList++)
+ for (iterList = List().begin(); iterList != List().end(); ++iterList)
if (oldCategory == *iterList)
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysDatumDictionary.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysDatumDictionary.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysDatumDictionary.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -267,6 +267,7 @@
csFILE *pFile=CS_fopen(kpName, szMode);
if (!pFile)
+ delete [] pBuf;
return NULL;
int nResult = CS_bins(
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysDictionary.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysDictionary.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysDictionary.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -267,6 +267,7 @@
if (!pFile)
+ delete [] pBuf;
return NULL;
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysEllipsoidDictionary.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysEllipsoidDictionary.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysEllipsoidDictionary.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -207,6 +207,7 @@
if (!pFile)
+ delete [] pBuf;
return NULL;
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysEnum.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysEnum.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysEnum.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -125,7 +125,7 @@
//default behavior - read each entry one by one and add it to the list to be returned
- for (; m_iter != m_pmapSystemNameDescription->end(); m_iter++)
+ for (; m_iter != m_pmapSystemNameDescription->end(); ++m_iter)
if (pOutput->GetCount() == ulCount)
@@ -175,7 +175,7 @@
throw new MgOutOfMemoryException(L"MgCoordinateSystemEnum.NextName", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -210,7 +210,7 @@
throw new MgOutOfMemoryException(L"MgCoordinateSystemEnum.NextDescription", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -244,7 +244,7 @@
MG_TRY()
UINT32 ulSkipped;
- for (ulSkipped=0; m_iter != m_pmapSystemNameDescription->end(); m_iter++)
+ for (ulSkipped=0; m_iter != m_pmapSystemNameDescription->end(); ++m_iter)
if (ulSkipped == ulSkipCount)
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysEnumCategory.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysEnumCategory.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysEnumCategory.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -167,7 +167,7 @@
wchar_t* pStr;
- for (; m_iter != m_pCategoryNameList->end(); m_iter++)
+ for (; m_iter != m_pCategoryNameList->end(); ++m_iter)
@@ -221,7 +221,7 @@
@@ -263,7 +263,7 @@
MG_TRY()
UINT32 ulSkipped;
- for (ulSkipped=0; m_iter != m_pCategoryNameList->end(); m_iter++)
+ for (ulSkipped=0; m_iter != m_pCategoryNameList->end(); ++m_iter)
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysEnumCoordinateSystemInCategory.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysEnumCoordinateSystemInCategory.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysEnumCoordinateSystemInCategory.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -102,7 +102,7 @@
wchar_t* pstr;
- for (; m_iter != m_kpListCoordinateSystemNames->end(); m_iter++)
+ for (; m_iter != m_kpListCoordinateSystemNames->end(); ++m_iter)
@@ -156,7 +156,7 @@
wchar_t* pstr;
@@ -205,7 +205,7 @@
wchar_t* pstr;
@@ -256,7 +256,7 @@
MG_TRY()
UINT32 ulSkipped;
- for (ulSkipped=0; m_iter != m_kpListCoordinateSystemNames->end(); m_iter++)
+ for (ulSkipped=0; m_iter != m_kpListCoordinateSystemNames->end(); ++m_iter)
@@ -309,7 +309,7 @@
throw new MgOutOfMemoryException(L"MgCoordinateSystemEnum.IsFilteredOut", __LINE__, __WFILE__, NULL, L"", NULL);
- bool bIsFiltered=IsFilteredOut(pStr);
+ bIsFiltered=IsFilteredOut(pStr);
delete[] pStr;
MG_CATCH_AND_THROW(L"MgCoordinateSystemEnum.IsFilteredOut")
return bIsFiltered;
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGrids.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGrids.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGrids.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -247,8 +247,6 @@
double precisionInCsUnits (1.0);
double precisionInMeters (1.0);
- double toMeters;
- double toDegrees;
Ptr<MgCoordinateSystemCatalog> catalogPtr = gridCS->GetCatalog ();
Ptr<MgCoordinateSystemUnitInformation> unitInfoPtr = catalogPtr->GetUnitInformation ();
@@ -265,13 +263,14 @@
else
+ double toMeters;
if (m_UnitType == MgCoordinateSystemUnitType::Linear)
toMeters = unitInfoPtr->GetLinearUnitScale (m_UnitCode);
else
- toDegrees = unitInfoPtr->GetAngularUnitScale (m_UnitCode);
+ double toDegrees = unitInfoPtr->GetAngularUnitScale (m_UnitCode);
toMeters = (6378137.0 * M_PI * 2.0 / 360.0) / toDegrees;
precisionInMeters = m_CurvePrecision * toMeters;
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysMgrs.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysMgrs.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysMgrs.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -308,8 +308,6 @@
void CCoordinateSystemMgrs::InitMgrsSpecification (MgCoordinateSystemGridSpecification* pSpecification,
INT32 mgrsGridLevel)
- double gridIncrement;
MG_TRY ()
// Initialize the standard stuff.
pSpecification->SetGridBase (0.0,0.0);
@@ -330,6 +328,7 @@
else if (mgrsGridLevel >= MgCoordinateSystemMgrsGridLevel::Mgrs100Km &&
mgrsGridLevel <= MgCoordinateSystemMgrsGridLevel::Mgrs1m)
+ double gridIncrement;
switch (mgrsGridLevel) {
case MgCoordinateSystemMgrsGridLevel::Mgrs100Km:
gridIncrement = 100000.0;
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysTransform.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -938,7 +938,6 @@
double delX, delX2, delY, delY2;
double dist2, chord2, maxChord;
- double wrkPntX, wrkPntY;
double midSrcX, midSrcY;
double midTrgX, midTrgY;
@@ -950,8 +949,8 @@
segList = new rx_Linseg_;
segList->next = NULL;
- wrkPntX = segList->srcX = segList->trgX = fromPnt->GetX ();
- wrkPntY = segList->srcY = segList->trgY = fromPnt->GetY ();
+ segList->srcX = segList->trgX = fromPnt->GetX ();
+ segList->srcY = segList->trgY = fromPnt->GetY ();
Transform (&segList->trgX,&segList->trgY);
// Allocate and populate the last point in the segment list.
@@ -959,8 +958,8 @@
curPtr->next = NULL;
segList->next = curPtr;
- wrkPntX = curPtr->srcX = curPtr->trgX = toPnt->GetX ();
- wrkPntY = curPtr->srcY = curPtr->trgY = toPnt->GetY ();
+ curPtr->srcX = curPtr->trgX = toPnt->GetX ();
+ curPtr->srcY = curPtr->trgY = toPnt->GetY ();
Transform (&curPtr->trgX,&curPtr->trgY);
// We now have the two end points of the line in the segment list. Start a
@@ -1317,7 +1316,6 @@
double z=0.;
int nResult = cs_CNVRT_NRML;
if (pdZ)
Modified: trunk/MgDev/Common/Foundation/System/Configuration.cpp
--- trunk/MgDev/Common/Foundation/System/Configuration.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Foundation/System/Configuration.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -639,8 +639,6 @@
if (NULL != validationInfoList)
- int i = 0;
while (!validationInfoList->m_propertyName.empty())
if (validationInfoList->m_propertyName == property)
Modified: trunk/MgDev/Common/Foundation/System/Resources.cpp
--- trunk/MgDev/Common/Foundation/System/Resources.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Foundation/System/Resources.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -182,7 +182,7 @@
// Clean up the resource cache
ResourceCache::iterator iterator;
- for(iterator = m_resourceCache.begin(); iterator != m_resourceCache.end(); iterator++)
+ for(iterator = m_resourceCache.begin(); iterator != m_resourceCache.end(); ++iterator)
DeleteResourceFile(iterator->second);
iterator->second = NULL;
@@ -487,7 +487,7 @@
void MgResources::DeleteResourceFile(ResourceFile* file)
- for (ResourceFile::iterator iter = file->begin(); iter != file->end(); iter++)
+ for (ResourceFile::iterator iter = file->begin(); iter != file->end(); ++iter)
if (NULL != iter->second)
Modified: trunk/MgDev/Common/Foundation/System/StreamData.cpp
--- trunk/MgDev/Common/Foundation/System/StreamData.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Foundation/System/StreamData.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -56,7 +56,7 @@
// </summary>
// <param name = "copy">
-// The MgStreamData objec to copy for the new object.
+// The MgStreamData object to copy for the new object.
// </param>
MgStreamData::MgStreamData( MgStreamData © ) :
m_Handle( copy.m_Handle ),
@@ -67,7 +67,7 @@
m_bError( copy.m_bError )
ACE_ASSERT( m_Handle != 0 );
- ACE_ASSERT( NULL != (MgStreamHelper*) m_pStreamHelper );
+ ACE_ASSERT( NULL != m_pStreamHelper.p );
Modified: trunk/MgDev/Common/Foundation/System/StreamReader.cpp
--- trunk/MgDev/Common/Foundation/System/StreamReader.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Foundation/System/StreamReader.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -572,7 +572,7 @@
Ptr<MgSerializable> obj = (MgSerializable*)MgUtil::CreateMgObject(classId); // throws NullPointerException
//deserialize the object
- (obj)->Deserialize((MgStream*)this);
+ obj->Deserialize((MgStream*)this);
return obj.Detach();
@@ -583,7 +583,7 @@
MgStreamHelper* MgStreamReader::GetStreamHelper()
- return SAFE_ADDREF((MgStreamHelper*)m_sHelper);
+ return SAFE_ADDREF(m_sHelper.p);
///<summary>
Modified: trunk/MgDev/Common/Geometry/Buffer/DumpFFGF.cpp
--- trunk/MgDev/Common/Geometry/Buffer/DumpFFGF.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Geometry/Buffer/DumpFFGF.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -35,14 +35,11 @@
BYTE bytes[1024];
int nRead = 0;
- int nTotalRead = 0;
do
nRead = byteReader->Read(bytes, 1024);
if (nRead > 0)
spBytes->Append(bytes, nRead);
- nTotalRead += nRead;
while (nRead > 0);
@@ -96,8 +93,6 @@
try
- int feat_num = featnum;
MgCoordinateCollection* coordinates = new MgCoordinateCollection();
MgGeometryFactory factory;
@@ -125,8 +120,6 @@
try
@@ -155,12 +148,6 @@
try
- MgCoordinateCollection* coordinates = new MgCoordinateCollection();
- MgGeometryFactory factory;
OpsFloatPoint pt(x, y);
// Create a point
Modified: trunk/MgDev/Common/Geometry/Buffer/planeswp.cpp
--- trunk/MgDev/Common/Geometry/Buffer/planeswp.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Geometry/Buffer/planeswp.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -1423,8 +1423,6 @@
// marked as interior (all the edge-sides must be exterior in order for
// the boundary to qualify for output)
- int j = 0;
do {
assert(!wEdge->EdgeDeleted());
Modified: trunk/MgDev/Common/Geometry/MultiCurveString.cpp
--- trunk/MgDev/Common/Geometry/MultiCurveString.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Geometry/MultiCurveString.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -140,11 +140,11 @@
//Deserialize from AGF format
INT32 type;
- ((MgStreamReader*)stream)->GetInt32(type);
+ reader->GetInt32(type);
assert(type == MgGeometryType::MultiCurveString);
INT32 numCurveStrings;
- ((MgStreamReader*)stream)->GetInt32(numCurveStrings);
+ reader->GetInt32(numCurveStrings);
m_curveStrings = new MgCurveStringCollection();
for(INT32 i = 0; i < numCurveStrings; i++)
Modified: trunk/MgDev/Common/Geometry/MultiLineString.cpp
--- trunk/MgDev/Common/Geometry/MultiLineString.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Geometry/MultiLineString.cpp 2010-12-29 06:32:51 UTC (rev 5487)
INT32 type;
assert(type == MgGeometryType::MultiLineString);
INT32 numLineStrings;
- ((MgStreamReader*)stream)->GetInt32(numLineStrings);
+ reader->GetInt32(numLineStrings);
m_lineStrings = new MgLineStringCollection();
for(INT32 i = 0; i < numLineStrings; i++)
Modified: trunk/MgDev/Common/MapGuideCommon/Controller/DwfController.cpp
--- trunk/MgDev/Common/MapGuideCommon/Controller/DwfController.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MapGuideCommon/Controller/DwfController.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -69,7 +69,7 @@
//save the map state in the session repository
Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(L"Session:" + sessionId + L"//" + mapDefinition->GetName() + L"." + MgResourceType::Map);
- map->Save((MgResourceService*)resourceService, (MgResourceIdentifier*)resId);
+ map->Save(resourceService.p, resId.p);
Ptr<MgDwfVersion> dwfv = new MgDwfVersion(dwfVersion, eMapVersion);
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Layer.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -173,7 +173,7 @@
helper->WriteUINT32(scaleValueCount);
if(scaleValueCount > 0)
- for(SCALERANGES::const_iterator it = m_scaleRanges.begin(); it != m_scaleRanges.end(); it++)
+ for(SCALERANGES::const_iterator it = m_scaleRanges.begin(); it != m_scaleRanges.end(); ++it)
helper->WriteBytes((const unsigned char*)&(*it), sizeof(double));
helper->WriteString(m_featureSourceId);
@@ -183,7 +183,7 @@
helper->WriteString(m_geometry);
helper->WriteUINT32((UINT32)m_idProps.size());
- for (IdPropertyList::iterator ids = m_idProps.begin(); ids != m_idProps.end(); ids++)
+ for (IdPropertyList::iterator ids = m_idProps.begin(); ids != m_idProps.end(); ++ids)
helper->WriteUINT16(ids->type);
helper->WriteString(ids->name);
Modified: trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp
--- trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MapGuideCommon/MapLayer/Map.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -99,7 +99,7 @@
if (MgServiceType::ResourceService == serviceType)
InitializeResourceService(NULL);
- return SAFE_ADDREF((MgResourceService*)m_resourceService);
+ return SAFE_ADDREF(m_resourceService.p);
else
@@ -234,7 +234,7 @@
if(unresolvedGroupLinks.size() > 0)
map<MgLayerGroup*, STRING>::const_iterator itUnres;
- for(itUnres = unresolvedGroupLinks.begin(); itUnres != unresolvedGroupLinks.end(); itUnres++)
+ for(itUnres = unresolvedGroupLinks.begin(); itUnres != unresolvedGroupLinks.end(); ++itUnres)
itKg = knownGroups.find(itUnres->second);
assert(itKg != knownGroups.end());
@@ -438,7 +438,7 @@
// load the sorted scales into the vector
- for (SORTEDSCALES::iterator sIter = sortedScales.begin(); sIter != sortedScales.end(); sIter++)
+ for (SORTEDSCALES::iterator sIter = sortedScales.begin(); sIter != sortedScales.end(); ++sIter)
m_finiteDisplayScales.push_back(sIter->second);
m_trackChangesDisabled = false;
@@ -872,7 +872,7 @@
stream->WriteInt32(scaleCount);
if (scaleCount > 0)
- for (FINITESCALES::const_iterator it = m_finiteDisplayScales.begin(); it != m_finiteDisplayScales.end(); it++)
+ for (FINITESCALES::const_iterator it = m_finiteDisplayScales.begin(); it != m_finiteDisplayScales.end(); ++it)
stream->WriteDouble(*it);
@@ -1086,7 +1086,7 @@
- for (LayerFeatureSourceMap::iterator fsIter = fsMap.begin(); fsIter != fsMap.end(); fsIter++)
+ for (LayerFeatureSourceMap::iterator fsIter = fsMap.begin(); fsIter != fsMap.end(); ++fsIter)
// Assumption: feature source is only referencing one schema
STRING featureSource = fsIter->first;
@@ -1094,7 +1094,7 @@
Ptr<MgResourceIdentifier> resId = new MgResourceIdentifier(featureSource);
LayerClassMap& classList = fsIter->second;
Ptr<MgStringCollection> classNames = new MgStringCollection();
- for (LayerClassMap::iterator cIter = classList.begin(); cIter != classList.end(); cIter++)
+ for (LayerClassMap::iterator cIter = classList.begin(); cIter != classList.end(); ++cIter)
classNames->Add(cIter->first);
@@ -1109,7 +1109,7 @@
STRING className = def->GetName();
LayerList& layers = fsMap[featureSource][className];
- for (LayerList::iterator lIter = layers.begin(); lIter != layers.end(); lIter++)
+ for (LayerList::iterator lIter = layers.begin(); lIter != layers.end(); ++lIter)
(*lIter)->PopulateIdentityProperties(def);
@@ -1148,7 +1148,7 @@
if (!newColorPalette.empty())
ColorStringList::iterator it = newColorPalette.begin();
- for (; it != newColorPalette.end(); it++)
+ for (; it != newColorPalette.end(); ++it)
if (*it != L"") // filter empty strings
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ConnectionProperties.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ConnectionProperties.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ConnectionProperties.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -193,5 +193,5 @@
MgUserInformation* MgConnectionProperties::GetUserInfo()
- return SAFE_ADDREF((MgUserInformation*)m_userInfo);
+ return SAFE_ADDREF(m_userInfo.p);
Modified: trunk/MgDev/Common/MapGuideCommon/Services/PrintLayout.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/PrintLayout.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MapGuideCommon/Services/PrintLayout.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -80,7 +80,7 @@
// Get the PrintLayout contents
byteReader = resourceService->GetResourceContent(layoutDefinition);
- Ptr<MgByteSink> byteSink = new MgByteSink((MgByteReader*)byteReader);
+ Ptr<MgByteSink> byteSink = new MgByteSink(byteReader.p);
string resourceContent;
byteSink->ToStringUtf8(resourceContent);
@@ -149,7 +149,7 @@
MgPlotSpecification* MgPrintLayout::GetPlotSize()
- return SAFE_ADDREF((MgPlotSpecification*)m_plotSpec);
+ return SAFE_ADDREF(m_plotSpec.p);
@@ -197,7 +197,7 @@
DOMElement* root = pXmlUtil->GetRootNode();
CHECKNULL(root, L"MgPrintLayout.GetLayoutProperitesFromXml()");
- DOMElement* pageProperties = pXmlUtil->GetElementNode(root, "PageProperties");
+// DOMElement* pageProperties = pXmlUtil->GetElementNode(root, "PageProperties");
DOMElement* backgroundColor = pXmlUtil->GetElementNode(root, "BackgroundColor");
@@ -409,7 +409,7 @@
if (customLogosCount > 0)
for (MgCustomLogoInfoVector::iterator iter = m_logos.begin();
- iter != m_logos.end(); iter++)
+ iter != m_logos.end(); ++iter)
MgCustomLogoInfo logoInfo = (MgCustomLogoInfo)(*iter);
@@ -430,7 +430,7 @@
if (customTextCount > 0)
for (MgCustomTextInfoVector::iterator iter = m_text.begin();
- iter != m_text.end(); iter++)
+ iter != m_text.end(); ++iter)
MgCustomTextInfo textInfo = (MgCustomTextInfo)(*iter);
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyDataReader.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyDataReader.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyDataReader.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -541,9 +541,7 @@
MgByteReader* MgProxyDataReader::GetBLOB(CREFSTRING propertyName)
Ptr<MgBlobProperty> ptrProp = (MgBlobProperty*)GetProperty(propertyName, MgPropertyType::Blob);
- Ptr<MgByteReader> retVal = ptrProp->GetValue();
- return SAFE_ADDREF((MgByteReader*)retVal);
+ return ptrProp->GetValue();
@@ -556,9 +554,7 @@
MgByteReader* MgProxyDataReader::GetBLOB(INT32 index)
Ptr<MgBlobProperty> ptrProp = (MgBlobProperty*)GetProperty(index, MgPropertyType::Blob);
@@ -571,9 +567,7 @@
MgByteReader* MgProxyDataReader::GetCLOB(CREFSTRING propertyName)
Ptr<MgClobProperty> ptrProp = (MgClobProperty*)GetProperty(propertyName, MgPropertyType::Clob);
@@ -586,9 +580,7 @@
MgByteReader* MgProxyDataReader::GetCLOB(INT32 index)
Ptr<MgClobProperty> ptrProp = (MgClobProperty*)GetProperty(index, MgPropertyType::Clob);
@@ -601,9 +593,7 @@
MgByteReader* MgProxyDataReader::GetGeometry(CREFSTRING propertyName)
Ptr<MgGeometryProperty> ptrProp = (MgGeometryProperty*)GetProperty(propertyName, MgPropertyType::Geometry);
@@ -616,9 +606,7 @@
MgByteReader* MgProxyDataReader::GetGeometry(INT32 index)
Ptr<MgGeometryProperty> ptrProp = (MgGeometryProperty*)GetProperty(index, MgPropertyType::Geometry);
@@ -685,8 +673,7 @@
Ptr<MgByteSource> byteSource = new MgByteSource((BYTE_ARRAY_IN)xmlStr.c_str(), (INT32)xmlStr.length());
byteSource->SetMimeType(MgMimeType::Xml);
- Ptr<MgByteReader> byteReader = byteSource->GetReader();
- return SAFE_ADDREF((MgByteReader*)byteReader);
+ return byteSource->GetReader();
void MgProxyDataReader::ToXml(string &str)
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureReader.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureReader.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureReader.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -43,7 +43,7 @@
m_currRecord = 0;
m_serverfeatReader = L"";
- m_set = SAFE_ADDREF((MgFeatureSet*)featureSet);
+ m_set = SAFE_ADDREF(featureSet);
m_service = NULL;
@@ -80,7 +80,7 @@
void MgProxyFeatureReader::AssignFeatureSet(MgFeatureSet* featureSet)
m_currRecord = 0;
@@ -569,9 +569,7 @@
MgByteReader* MgProxyFeatureReader::GetBLOB(CREFSTRING propertyName)
@@ -586,9 +584,7 @@
MgByteReader* MgProxyFeatureReader::GetBLOB(INT32 index)
@@ -603,9 +599,7 @@
MgByteReader* MgProxyFeatureReader::GetCLOB(CREFSTRING propertyName)
@@ -620,9 +614,7 @@
MgByteReader* MgProxyFeatureReader::GetCLOB(INT32 index)
@@ -638,9 +630,7 @@
MgFeatureReader* MgProxyFeatureReader::GetFeatureObject(CREFSTRING propertyName)
Ptr<MgFeatureProperty> ptrProp = (MgFeatureProperty*)GetProperty(propertyName, MgPropertyType::Feature);
- Ptr<MgFeatureReader> retVal = ptrProp->GetValue();
- return SAFE_ADDREF((MgFeatureReader*)retVal);
@@ -655,9 +645,7 @@
MgFeatureReader* MgProxyFeatureReader::GetFeatureObject(INT32 index)
Ptr<MgFeatureProperty> ptrProp = (MgFeatureProperty*)GetProperty(index, MgPropertyType::Feature);
@@ -672,9 +660,7 @@
MgByteReader* MgProxyFeatureReader::GetGeometry(CREFSTRING propertyName)
@@ -689,9 +675,7 @@
MgByteReader* MgProxyFeatureReader::GetGeometry(INT32 index)
// Get the property for the specified name
@@ -712,7 +696,7 @@
INT16 propType = ptrProp->GetPropertyType();
CHECK_PROPERTY_TYPE(propType, expectedType, L"MgProxyFeatureReader.GetProperty");
- return SAFE_ADDREF((MgProperty*)ptrProp);
+ return SAFE_ADDREF(ptrProp.p);
// Get the property for the specified index
@@ -735,7 +719,7 @@
@@ -750,7 +734,7 @@
Ptr<MgProperty> ptrProp = ptrCol->GetItem(propertyName);
CHECKNULL(ptrProp, L"MgProxyFeatureReader.GetProperty");
@@ -765,7 +749,7 @@
Ptr<MgProperty> ptrProp = ptrCol->GetItem(index);
@@ -792,7 +776,7 @@
if (operationCompleted)
stream->WriteString(m_serverfeatReader);
- stream->WriteObject((MgFeatureSet*)m_set); // Write the feature set
+ stream->WriteObject(m_set.p); // Write the feature set
@@ -834,8 +818,7 @@
this->ToXml(xmlStr);
void MgProxyFeatureReader::ToXml(string &str)
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureTransaction.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureTransaction.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureTransaction.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -85,7 +85,7 @@
- stream->WriteObject((MgResourceIdentifier*)m_resourceId);
+ stream->WriteObject(m_resourceId.p);
stream->WriteString(m_transactionId); // Get the transaction ID so we can use it
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyGwsFeatureReader.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -29,7 +29,7 @@
m_currRecord = 0;
m_serverGwsFeatureReader = L"";
m_service = NULL;
@@ -66,7 +66,7 @@
void MgProxyGwsFeatureReader::AssignFeatureSet(MgFeatureSet* featureSet)
m_currRecord = 0;
@@ -511,9 +511,7 @@
MgByteReader* MgProxyGwsFeatureReader::GetBLOB(CREFSTRING propertyName)
@@ -526,9 +524,7 @@
MgByteReader* MgProxyGwsFeatureReader::GetBLOB(INT32 index)
@@ -542,9 +538,7 @@
MgByteReader* MgProxyGwsFeatureReader::GetCLOB(CREFSTRING propertyName)
@@ -557,9 +551,7 @@
MgByteReader* MgProxyGwsFeatureReader::GetCLOB(INT32 index)
@@ -575,9 +567,7 @@
MgFeatureReader* MgProxyGwsFeatureReader::GetFeatureObject(CREFSTRING propertyName)
@@ -592,9 +582,7 @@
MgFeatureReader* MgProxyGwsFeatureReader::GetFeatureObject(INT32 index)
@@ -608,9 +596,7 @@
MgByteReader* MgProxyGwsFeatureReader::GetGeometry(CREFSTRING propertyName)
@@ -623,9 +609,7 @@
MgByteReader* MgProxyGwsFeatureReader::GetGeometry(INT32 index)
@@ -646,7 +630,7 @@
MG_CHECK_PROPERTY_TYPE(propType, expectedType, L"MgProxyGwsFeatureReader.GetProperty");
@@ -661,7 +645,7 @@
CHECKNULL(ptrProp, L"MgProxyGwsFeatureReader.GetProperty");
@@ -685,7 +669,7 @@
@@ -700,7 +684,7 @@
@@ -727,7 +711,7 @@
stream->WriteString(m_serverGwsFeatureReader);
@@ -771,8 +755,7 @@
void MgProxyGwsFeatureReader::ToXml(string &str)
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxySqlDataReader.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxySqlDataReader.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxySqlDataReader.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -547,9 +547,7 @@
MgByteReader* MgProxySqlDataReader::GetBLOB(CREFSTRING propertyName)
@@ -562,9 +560,7 @@
MgByteReader* MgProxySqlDataReader::GetBLOB(INT32 index)
@@ -578,9 +574,7 @@
MgByteReader* MgProxySqlDataReader::GetCLOB(CREFSTRING propertyName)
@@ -593,9 +587,7 @@
MgByteReader* MgProxySqlDataReader::GetCLOB(INT32 index)
@@ -608,9 +600,7 @@
MgByteReader* MgProxySqlDataReader::GetGeometry(CREFSTRING propertyName)
@@ -623,9 +613,7 @@
MgByteReader* MgProxySqlDataReader::GetGeometry(INT32 index)
@@ -683,8 +671,7 @@
void MgProxySqlDataReader::ToXml(string &str)
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerConnection.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerConnection.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerConnection.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -222,7 +222,7 @@
stream = new MgAceStreamHelper(handle);
- return SAFE_ADDREF((MgStreamHelper*)stream);
+ return SAFE_ADDREF(stream.p);
@@ -243,7 +243,7 @@
m_stream->SetConnection(this);
- return SAFE_ADDREF((MgStream*)m_stream);
+ return SAFE_ADDREF(m_stream.p);
@@ -286,7 +286,7 @@
MgServerConnection* MgServerConnection::Acquire(MgUserInformation* userInformation,
MgConnectionProperties* connProp)
- CHECKNULL((MgUserInformation*)userInformation, L"MgServerConnection.Acquire");
+ CHECKNULL(userInformation, L"MgServerConnection.Acquire");
CHECKNULL((MgConnectionProperties*)connProp, L"MgServerConnection.Acquire");
MgServerConnectionPool* connectionPool = MgServerConnectionPool::GetInstance();
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionPool.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionPool.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionPool.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -60,7 +60,7 @@
delete iter->second;
iter->second = NULL;
- iter++;
+ ++iter;
pool.clear();
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionStack.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionStack.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerConnectionStack.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -85,7 +85,7 @@
(*iter)->SetStack(NULL);
SAFE_RELEASE((*iter));
- iter++;
+ ++iter;
m_inUse->clear();
delete m_inUse;
Modified: trunk/MgDev/Common/MapGuideCommon/Services/Site.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/Site.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MapGuideCommon/Services/Site.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -1339,7 +1339,7 @@
MG_SITE_TRY()
- CHECKARGUMENTNULL((MgUserInformation*)userInformation, L"MgSite.Authenticate")
+ CHECKARGUMENTNULL(userInformation, L"MgSite.Authenticate")
assert(m_connProp == NULL);
MgSiteManager* siteManager = MgSiteManager::GetInstance();
Modified: trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MapGuideCommon/Services/SiteManager.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -169,7 +169,7 @@
ACE_MT(ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, m_mutex));
for (MgSiteVector::iterator iter = m_sites.begin();
- iter != m_sites.end(); iter++)
+ iter != m_sites.end(); ++iter)
SAFE_RELEASE(*iter);
Modified: trunk/MgDev/Common/MapGuideCommon/Services/SqlResult.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/SqlResult.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MapGuideCommon/Services/SqlResult.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -49,7 +49,7 @@
MgSqlDataReader * MgSqlResult::GetReader()
- return SAFE_ADDREF((MgSqlDataReader *)m_reader);
+ return SAFE_ADDREF(m_reader.p);
void MgSqlResult::Serialize(MgStream *stream)
Modified: trunk/MgDev/Common/MdfParser/SAX2ElementHandler.h
--- trunk/MgDev/Common/MdfParser/SAX2ElementHandler.h 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/MdfParser/SAX2ElementHandler.h 2010-12-29 06:32:51 UTC (rev 5487)
@@ -93,7 +93,7 @@
std::vector<std::wstring>::const_iterator iter = _elementMap.begin(); \
int id = 1; \
- for (iter++; iter != _elementMap.end(); iter++) \
+ for (++iter; iter != _elementMap.end(); ++iter) \
if (0 == ::wcscmp(iter->c_str(), name)) \
return id; \
Modified: trunk/MgDev/Common/PlatformBase/Data/DateTimeProperty.cpp
--- trunk/MgDev/Common/PlatformBase/Data/DateTimeProperty.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/PlatformBase/Data/DateTimeProperty.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -121,7 +121,6 @@
if (!this->IsNull())
str += "<Value>";
- char buf[128]; buf[0] = 0;
Ptr<MgDateTime> dtPtr = this->GetValue();
if (dtPtr != NULL)
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.cpp
--- trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/MapBase.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -743,7 +743,7 @@
INT32 count = 0;
double minDiff = -1.0;
double displayScale = *it;
double diff = fabs(scale - displayScale);
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp
--- trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -53,11 +53,11 @@
// Delete selection manually instead of relying on deep template deletion
SelectionMap::iterator lIter;
- for (lIter = m_selections.begin(); lIter != m_selections.end(); lIter++)
+ for (lIter = m_selections.begin(); lIter != m_selections.end(); ++lIter)
SelectedClassMap* clsmap = lIter->second;
SelectedClassMap::iterator cIter;
- for (cIter = clsmap->begin(); cIter != clsmap->end(); cIter++)
+ for (cIter = clsmap->begin(); cIter != clsmap->end(); ++cIter)
SelectionList* list = cIter->second;
cIter->second = NULL;
@@ -200,14 +200,14 @@
xml.append(L"<FeatureSet xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"FeatureSet-1.0.0.xsd\">");
xml.append(L" <Layer id=\"");
xml.append(lIter->first);
xml.append(L"\">");
- for (cIter = lIter->second->begin(); cIter != lIter->second->end(); cIter++)
+ for (cIter = lIter->second->begin(); cIter != lIter->second->end(); ++cIter)
xml.append(L" <Class id=\"");
xml.append(cIter->first);
@@ -223,7 +223,7 @@
SelectionList::iterator sIter;
- for (sIter = cIter->second->begin(); sIter != cIter->second->end(); sIter++)
+ for (sIter = cIter->second->begin(); sIter != cIter->second->end(); ++sIter)
selXml.append(L" <ID>");
selXml.append(*sIter);
@@ -262,7 +262,7 @@
m_stream->Clear();
MgLayerBase::IdPropertyList propList = layer->GetIdPropertyList();
- for (MgLayerBase::IdPropertyList::iterator idIter = propList.begin(); idIter != propList.end(); idIter++)
+ for (MgLayerBase::IdPropertyList::iterator idIter = propList.begin(); idIter != propList.end(); ++idIter)
switch (idIter->type)
@@ -311,7 +311,7 @@
MgLayerBase::IdPropertyList::iterator idIter;
- for (idIter = propList.begin(); idIter != propList.end(); idIter++)
+ for (idIter = propList.begin(); idIter != propList.end(); ++idIter)
Ptr<MgProperty> prop = props->GetItem(idIter->name);
@@ -473,7 +473,7 @@
SelectedClassMap* classMap = lIter->second;
- for (cIter = classMap->begin(); cIter != classMap->end(); cIter++)
+ for (cIter = classMap->begin(); cIter != classMap->end(); ++cIter)
strColl->Add(cIter->first);
@@ -535,7 +535,7 @@
bool bFirstSel = true;
- for (sIter = selList->begin(); sIter != selList->end(); sIter++)
+ for (sIter = selList->begin(); sIter != selList->end(); ++sIter)
m_stream->FromBase64(*sIter);
@@ -543,7 +543,7 @@
bool bFirstProp = true;
- for (idIter = idList.begin(); idIter != idList.end(); idIter++)
+ for (idIter = idList.begin(); idIter != idList.end(); ++idIter)
if (!bFirstProp)
@@ -945,17 +945,17 @@
void MgSelectionBase::Serialize(MgStream* stream)
stream->WriteInt32((INT32)m_selections.size());
- for(SelectionMap::iterator lIter = m_selections.begin(); lIter != m_selections.end(); lIter++)
+ for(SelectionMap::iterator lIter = m_selections.begin(); lIter != m_selections.end(); ++lIter)
stream->WriteString(lIter->first);
stream->WriteInt32((INT32)classMap->size());
- for(SelectedClassMap::iterator cIter = classMap->begin(); cIter != classMap->end(); cIter++)
+ for(SelectedClassMap::iterator cIter = classMap->begin(); cIter != classMap->end(); ++cIter)
stream->WriteString(cIter->first);
SelectionList* selectionList = cIter->second;
stream->WriteInt32((INT32)selectionList->size());
- for(SelectionList::iterator sIter = selectionList->begin(); sIter != selectionList->end(); sIter++)
+ for(SelectionList::iterator sIter = selectionList->begin(); sIter != selectionList->end(); ++sIter)
stream->WriteString(*sIter);
Modified: trunk/MgDev/Common/Renderers/AGGImageIO.cpp
--- trunk/MgDev/Common/Renderers/AGGImageIO.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Renderers/AGGImageIO.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -870,7 +870,7 @@
// add colors from the colorpalette (duplicate color entries make the used palette less than 256)
RS_ColorVector::iterator it;
- for (it = baseColorPalette->begin();it != baseColorPalette->end(); it++)
+ for (it = baseColorPalette->begin();it != baseColorPalette->end(); ++it)
gdImageColorAllocate(gdPPalette, (*it).red(), (*it).green(), (*it).blue());
Modified: trunk/MgDev/Common/Renderers/AGGRenderer.cpp
--- trunk/MgDev/Common/Renderers/AGGRenderer.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Renderers/AGGRenderer.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -115,6 +115,8 @@
m_mapInfo(NULL),
m_layerInfo(NULL),
m_fcInfo(NULL),
+m_bIsSymbolW2D(false),
+m_bHaveViewport(false),
m_bRequiresClipping(requiresClipping),
m_bLocalOverposting(localOverposting),
m_imsym(NULL),
Modified: trunk/MgDev/Common/Renderers/AGGRenderer.h
--- trunk/MgDev/Common/Renderers/AGGRenderer.h 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Renderers/AGGRenderer.h 2010-12-29 06:32:51 UTC (rev 5487)
@@ -75,16 +75,16 @@
// Renderer implementation
RENDERERS_API virtual void StartMap(RS_MapUIInfo* mapInfo,
- RS_Bounds& extents,
- double mapScale,
- double dpi,
- double metersPerUnit,
- CSysTransformer* xformToLL = NULL);
+ RS_Bounds& extents,
+ double mapScale,
+ double dpi,
+ double metersPerUnit,
+ CSysTransformer* xformToLL = NULL);
RENDERERS_API virtual void EndMap();
RENDERERS_API virtual void StartLayer(RS_LayerUIInfo* legendInfo,
- RS_FeatureClassInfo* classInfo);
+ RS_FeatureClassInfo* classInfo);
RENDERERS_API virtual void EndLayer();
@@ -158,20 +158,20 @@
RENDERERS_API void SetWorldToScreenTransform(SE_Matrix& xform);
RENDERERS_API void DrawString(const RS_String& s,
- double x,
- double y,
- double width,
- double height,
- const RS_Font* font,
- RS_Color& color,
- double angle);
+ double x,
+ double y,
+ double width,
+ double height,
+ const RS_Font* font,
+ RS_Color& color,
+ double angle);
RENDERERS_API void MeasureString(const RS_String& s,
- double height,
- double angleRad,
- RS_F_Point* res,
- float* offsets);
+ double height,
+ double angleRad,
+ RS_F_Point* res,
+ float* offsets);
RENDERERS_API const RS_Font* FindFont(RS_FontDef& def);
Modified: trunk/MgDev/Common/Renderers/DWFRenderer.cpp
--- trunk/MgDev/Common/Renderers/DWFRenderer.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Renderers/DWFRenderer.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -333,25 +333,25 @@
void DWFRenderer::EndMap()
for (stream_list::iterator iter = m_lLayerStreams.begin();
- iter != m_lLayerStreams.end(); iter++)
+ iter != m_lLayerStreams.end(); ++iter)
DWFCORE_FREE_OBJECT(*iter);
for (stream_list::iterator iter = m_lLabelStreams.begin();
- iter != m_lLabelStreams.end(); iter++)
+ iter != m_lLabelStreams.end(); ++iter)
for (stream_list::iterator iter = m_lLayoutStreams.begin();
- iter != m_lLayoutStreams.end(); iter++)
+ iter != m_lLayoutStreams.end(); ++iter)
for (stream_list::iterator iter = m_lLayoutLabelStreams.begin();
- iter != m_lLayoutLabelStreams.end(); iter++)
+ iter != m_lLayoutLabelStreams.end(); ++iter)
Modified: trunk/MgDev/Common/Renderers/EMapRenderer.cpp
--- trunk/MgDev/Common/Renderers/EMapRenderer.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Renderers/EMapRenderer.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -163,7 +163,7 @@
if (uiGraphics)
std::list<RS_UIGraphic>::iterator iter = uiGraphics->begin();
- for (; iter != uiGraphics->end(); iter++)
+ for (; iter != uiGraphics->end(); ++iter)
// no need to correlate the UIGraphic object ID with any other object ID
DWFUIGraphic* pGraphic = DWFCORE_ALLOC_OBJECT(
@@ -200,7 +200,7 @@
//parents' uuids. This is done as post-processing step
//so that we know all groups are defined first
for (layerinfo_map::iterator iter = m_hGroups.begin();
- iter != m_hGroups.end(); iter++)
+ iter != m_hGroups.end(); ++iter)
RS_LayerUIInfo layerinfo = iter->second;
Modified: trunk/MgDev/Common/Renderers/EMapUpdateRenderer.cpp
--- trunk/MgDev/Common/Renderers/EMapUpdateRenderer.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Renderers/EMapUpdateRenderer.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -132,7 +132,7 @@
objdefres_list::iterator oditer = m_lAttributeResources.begin();
layerinfo_list::iterator iditer = m_lLayerInfos.begin();
- iter != m_lLayerStreams.end(); iter++, iditer++, oditer++)
+ iter != m_lLayerStreams.end(); ++iter, ++iditer, ++oditer)
std::wstring layerid = (*iditer).guid();
if (m_bFirst)
@@ -164,7 +164,7 @@
- iter != m_lLabelStreams.end(); iter++, iditer++)
+ iter != m_lLabelStreams.end(); ++iter, ++iditer)
if (*iter)
@@ -549,7 +549,7 @@
if (uiGraphics)
Modified: trunk/MgDev/Common/Renderers/EPlotRenderer.cpp
--- trunk/MgDev/Common/Renderers/EPlotRenderer.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Renderers/EPlotRenderer.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -276,7 +276,7 @@
- for ( ; iter != m_lLayerStreams.end(); iter++, oditer++)
+ for ( ; iter != m_lLayerStreams.end(); iter++, ++oditer)
if (m_bFirst)
@@ -311,7 +311,7 @@
if (*iter)
@@ -329,7 +329,7 @@
AddW2DResource( *iter,
NULL,
@@ -340,7 +340,7 @@
if (NULL != *iter)
@@ -377,25 +377,25 @@
m_lSectionStreams.push_back(*iter);
m_lSectionLabelStreams.push_back(*iter);
m_lSectionLayoutStreams.push_back(*iter);
m_lSectionLayoutLabelStreams.push_back(*iter);
@@ -453,25 +453,25 @@
// now that we've created written out the map, we can clean up
// all the streams
for (stream_list::iterator iter = m_lSectionStreams.begin();
- iter != m_lSectionStreams.end(); iter++)
+ iter != m_lSectionStreams.end(); ++iter)
DWFCORE_FREE_OBJECT ( *iter);
for (stream_list::iterator iter = m_lSectionLabelStreams.begin();
- iter != m_lSectionLabelStreams.end(); iter++)
+ iter != m_lSectionLabelStreams.end(); ++iter)
for (stream_list::iterator iter = m_lSectionLayoutStreams.begin();
- iter != m_lSectionLayoutStreams.end(); iter++)
+ iter != m_lSectionLayoutStreams.end(); ++iter)
DWFCORE_FREE_OBJECT( *iter );
for (stream_list::iterator iter = m_lSectionLayoutLabelStreams.begin();
- iter != m_lSectionLayoutLabelStreams.end(); iter++)
+ iter != m_lSectionLayoutLabelStreams.end(); ++iter)
Modified: trunk/MgDev/Common/Renderers/FontManager.cpp
--- trunk/MgDev/Common/Renderers/FontManager.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Renderers/FontManager.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -69,7 +69,7 @@
AutoMutexLocker autoLocker(sm_mutex);
// free up font map entries
- for (FontMapIterator fmi = m_fontAliases.begin(); fmi != m_fontAliases.end(); fmi++)
+ for (FontMapIterator fmi = m_fontAliases.begin(); fmi != m_fontAliases.end(); ++fmi)
delete (*fmi).first;
delete (*fmi).second;
@@ -433,7 +433,7 @@
const wchar_t* fontname = sfontname.c_str();
// if there is an alias for the font use that instead
const wchar_t* alias = (*fmi).first->c_str();
if (wcscmp(alias, fontname) == 0)
Modified: trunk/MgDev/Common/Renderers/KmlRenderer.cpp
--- trunk/MgDev/Common/Renderers/KmlRenderer.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Renderers/KmlRenderer.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -106,7 +106,7 @@
m_kmlContent = m_mainContent;
//write out the features for each theme
- for (ThemeMap::iterator iter = m_themeMap.begin(); iter != m_themeMap.end(); iter++)
+ for (ThemeMap::iterator iter = m_themeMap.begin(); iter != m_themeMap.end(); ++iter)
m_kmlContent->WriteString("<Folder>");
m_kmlContent->WriteString("<name><![CDATA[", false);
@@ -242,7 +242,7 @@
WriteElevationSettings();
PolygonUtils::SORTEDRINGS rings;
PolygonUtils::DetermineInteriorAndExteriorPolygons(lb, rings);
- for (PolygonUtils::SORTEDRINGS::iterator sIter = rings.begin(); sIter != rings.end(); sIter++)
+ for (PolygonUtils::SORTEDRINGS::iterator sIter = rings.begin(); sIter != rings.end(); ++sIter)
RingData* pRingData = sIter->second;
@@ -498,7 +498,7 @@
void KmlRenderer::ClearThemes()
delete (*iter).second;
Modified: trunk/MgDev/Common/Renderers/ObservationMesh.cpp
--- trunk/MgDev/Common/Renderers/ObservationMesh.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Renderers/ObservationMesh.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -262,7 +262,7 @@
int p0i=-1;
for (std::map<int, std::vector<HullEdge> >::iterator iter = edges.begin();
- iter != edges.end(); iter++)
+ iter != edges.end(); ++iter)
std::vector<HullEdge>& ei = iter->second;
for (unsigned j=0; j<ei.size(); j++)
Modified: trunk/MgDev/Common/Stylization/Band.cpp
--- trunk/MgDev/Common/Stylization/Band.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Stylization/Band.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -842,7 +842,11 @@
if (memcmp(&fbottom, &m_nullValue, 4) == 0)
fbottom = fcenter;
#else
- // Linux implementation
+ // TODO: Linux implementation
+ fleft = 0.0f;
+ fright = 0.0f;
+ ftop = 0.0f;
+ fbottom = 0.0f;
#endif
left = fleft;
Modified: trunk/MgDev/Common/Stylization/DefaultStylizer.cpp
--- trunk/MgDev/Common/Stylization/DefaultStylizer.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Stylization/DefaultStylizer.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -525,7 +525,7 @@
std::map<int, GeometryAdapter*>::iterator sgiter = m_hGeomStylizers.begin();
// free the stylizer objects
- for (; sgiter!=m_hGeomStylizers.end(); sgiter++)
+ for (; sgiter!=m_hGeomStylizers.end(); ++sgiter)
delete sgiter->second;
Modified: trunk/MgDev/Common/Stylization/GeometryAdapter.cpp
--- trunk/MgDev/Common/Stylization/GeometryAdapter.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Stylization/GeometryAdapter.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -38,7 +38,7 @@
// free up cached fdo filters
for (std::map<const void*, FdoFilter*>::iterator iter = m_hFilterCache.begin();
- iter != m_hFilterCache.end(); iter++)
+ iter != m_hFilterCache.end(); ++iter)
if (iter->second)
iter->second->Release();
@@ -48,7 +48,7 @@
// free up cached fdo expressions
for (std::map<const void*, FdoExpression*>::iterator iter = m_hExpressionCache.begin();
- iter != m_hExpressionCache.end(); iter++)
+ iter != m_hExpressionCache.end(); ++iter)
if (iter->second)
Modified: trunk/MgDev/Common/Stylization/LabelRenderer.h
--- trunk/MgDev/Common/Stylization/LabelRenderer.h 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Stylization/LabelRenderer.h 2010-12-29 06:32:51 UTC (rev 5487)
@@ -30,7 +30,7 @@
// of them on top of geometry in the end.
struct LabelInfo
- LabelInfo(double x, double y, const RS_String& text, const RS_TextDef tdef)
+ LabelInfo(double x, double y, const RS_String& text, const RS_TextDef& tdef)
: m_x(x),
m_y(y),
m_text(text),
Modified: trunk/MgDev/Common/Stylization/LabelRendererLocal.h
--- trunk/MgDev/Common/Stylization/LabelRendererLocal.h 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Stylization/LabelRendererLocal.h 2010-12-29 06:32:51 UTC (rev 5487)
@@ -30,7 +30,7 @@
struct LabelInfoLocal
- LabelInfoLocal(double x, double y, const RS_String& text, const RS_TextDef tdef)
+ LabelInfoLocal(double x, double y, const RS_String& text, const RS_TextDef& tdef)
: m_x(x),
m_y(y),
m_text(text),
Modified: trunk/MgDev/Common/Stylization/LineStyleDef.cpp
--- trunk/MgDev/Common/Stylization/LineStyleDef.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Stylization/LineStyleDef.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -822,7 +822,7 @@
// add the user-defined names
CUSTOMSTYLES::iterator iter = s_customStyles.begin();
- for (; iter != s_customStyles.end(); iter++)
+ for (; iter != s_customStyles.end(); ++iter)
std::wstring name = iter->first;
names.push_back(name);
Modified: trunk/MgDev/Common/Stylization/PointAdapter.cpp
--- trunk/MgDev/Common/Stylization/PointAdapter.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Stylization/PointAdapter.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -33,7 +33,7 @@
//free up cached point styles
for (std::map<void*, RS_MarkerDef*>::iterator iter = m_hPointSymCache.begin();
- iter != m_hPointSymCache.end(); iter++)
+ iter != m_hPointSymCache.end(); ++iter)
Modified: trunk/MgDev/Common/Stylization/PolygonAdapter.cpp
--- trunk/MgDev/Common/Stylization/PolygonAdapter.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Stylization/PolygonAdapter.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -33,7 +33,7 @@
//free up cached area styles
for (std::map<void*, RS_FillStyle*>::iterator iter = m_hAreaSymCache.begin();
- iter != m_hAreaSymCache.end(); iter++)
+ iter != m_hAreaSymCache.end(); ++iter)
Modified: trunk/MgDev/Common/Stylization/PolygonUtils.cpp
--- trunk/MgDev/Common/Stylization/PolygonUtils.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Stylization/PolygonUtils.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -43,7 +43,7 @@
void PolygonUtils::Cleanup(SORTEDRINGS& rings)
// cleanup
- for (SORTEDRINGS::iterator sIter = rings.begin(); sIter != rings.end(); sIter++)
+ for (SORTEDRINGS::iterator sIter = rings.begin(); sIter != rings.end(); ++sIter)
delete pRingData;
@@ -157,7 +157,7 @@
RINGVECTOR processedRings;
// loop over the sorted list
- for (SORTEDRINGS::iterator sIter = sortedRings.begin(); sIter != sortedRings.end(); sIter++)
+ for (SORTEDRINGS::iterator sIter = sortedRings.begin(); sIter != sortedRings.end(); ++sIter)
// ring A is the one we're going to process
RingData* pRingDataA = sIter->second;
Modified: trunk/MgDev/Common/Stylization/PolylineAdapter.cpp
--- trunk/MgDev/Common/Stylization/PolylineAdapter.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Stylization/PolylineAdapter.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -33,7 +33,7 @@
//free up cached line styles
for (std::map<void*, RS_LineStroke*>::iterator iter = m_hLineSymCache.begin();
- iter != m_hLineSymCache.end(); iter++)
+ iter != m_hLineSymCache.end(); ++iter)
Modified: trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp
--- trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Stylization/SE_PositioningAlgorithms.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -779,8 +779,7 @@
for (shieldIndex=0; shieldIndex<shieldCount; ++shieldIndex)
for (SE_RenderPrimitiveList::iterator iter = symbolVectors[shieldIndex].begin();
- iter != symbolVectors[shieldIndex].end();
- iter++)
+ iter != symbolVectors[shieldIndex].end(); ++iter)
// necessary since destructor of SE_RenderPrimitive is not virtual
switch ((*iter)->type)
Modified: trunk/MgDev/Common/Stylization/SE_RenderProxies.h
--- trunk/MgDev/Common/Stylization/SE_RenderProxies.h 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Stylization/SE_RenderProxies.h 2010-12-29 06:32:51 UTC (rev 5487)
@@ -186,7 +186,7 @@
~SE_RenderStyle()
- for (SE_RenderPrimitiveList::iterator iter = symbol.begin(); iter != symbol.end(); iter++)
+ for (SE_RenderPrimitiveList::iterator iter = symbol.begin(); iter != symbol.end(); ++iter)
@@ -208,7 +208,8 @@
break;
default:
- throw; // means there is a bug
+ _ASSERT(false); // means there is a bug
+ break;
Modified: trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp
--- trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -65,7 +65,7 @@
SE_Style::~SE_Style()
- for (SE_PrimitiveList::iterator iter = symbol.begin(); iter != symbol.end(); iter++)
+ for (SE_PrimitiveList::iterator iter = symbol.begin(); iter != symbol.end(); ++iter)
delete *iter;
delete rstyle;
@@ -590,7 +590,7 @@
maxy0 = maxy1 = rs_max(ptAy, ptBy);
- for (SE_PrimitiveList::const_iterator src = symbol.begin(); src != symbol.end(); src++)
+ for (SE_PrimitiveList::const_iterator src = symbol.begin(); src != symbol.end(); ++src)
SE_Primitive* sym = *src;
@@ -688,7 +688,7 @@
SE_Matrix totalxf(*ctx->xform);
totalxf.premultiply(growxf);
- for (SE_RenderPrimitiveList::iterator rs = rstyle->symbol.begin(); rs != rstyle->symbol.end(); rs++)
+ for (SE_RenderPrimitiveList::iterator rs = rstyle->symbol.begin(); rs != rstyle->symbol.end(); ++rs)
SE_RenderPrimitive* rsym = *rs;
if (rsym->resizeControl == SE_ResizeControl_AdjustToResizeBox)
Modified: trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h
--- trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Stylization/SE_SymbolDefProxies.h 2010-12-29 06:32:51 UTC (rev 5487)
@@ -271,7 +271,7 @@
~SE_SymbolInstance()
- for (std::vector<SE_Style*>::iterator iter = styles.begin(); iter != styles.end(); iter++)
+ for (std::vector<SE_Style*>::iterator iter = styles.begin(); iter != styles.end(); ++iter)
delete *iter;
styles.clear();
@@ -294,7 +294,7 @@
if (filter)
filter->Release();
- for (std::vector<SE_SymbolInstance*>::iterator iter = symbolInstances.begin(); iter != symbolInstances.end(); iter++)
+ for (std::vector<SE_SymbolInstance*>::iterator iter = symbolInstances.begin(); iter != symbolInstances.end(); ++iter)
delete *iter;
symbolInstances.clear();
Modified: trunk/MgDev/Common/Stylization/StylizationEngine.cpp
--- trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Stylization/StylizationEngine.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -1357,7 +1357,7 @@
std::map<CompositeTypeStyle*, SE_Rule*>::iterator iter = m_rules.begin();
- for (; iter != m_rules.end(); iter++)
+ for (; iter != m_rules.end(); ++iter)
delete [] iter->second;
m_rules.clear();
Modified: trunk/MgDev/Common/Stylization/StylizationUtil.cpp
--- trunk/MgDev/Common/Stylization/StylizationUtil.cpp 2010-12-28 02:17:46 UTC (rev 5486)
+++ trunk/MgDev/Common/Stylization/StylizationUtil.cpp 2010-12-29 06:32:51 UTC (rev 5487)
@@ -587,7 +587,7 @@
// step 4 - re-evaluate and draw all the symbol instances
- for (std::vector<SE_SymbolInstance*>::const_iterator iter = symbolInstances.begin(); iter != symbolInstances.end(); iter++)
+ for (std::vector<SE_SymbolInstance*>::const_iterator iter = symbolInstances.begin(); iter != symbolInstances.end(); ++iter)
// one per symbol instance
SE_SymbolInstance* sym = *iter;
@@ -641,7 +641,7 @@
applyCtx.xform = &xform;
applyCtx.sizeContext = sym->sizeContext;
- for (std::vector<SE_Style*>::const_iterator siter = sym->styles.begin(); siter != sym->styles.end(); siter++)
+ for (std::vector<SE_Style*>::const_iterator siter = sym->styles.begin(); siter != sym->styles.end(); ++siter)
// have one style per simple symbol definition
SE_Style* style = *siter;
@@ -768,7 +768,7 @@
// step 5 - final clean up
delete *iter;
@@ -796,7 +796,7 @@
RS_Bounds fullBounds(DBL_MAX, DBL_MAX, -DBL_MAX, -DBL_MAX);
@@ -826,7 +826,7 @@
evalCtx.xform = &xformScale;
evalCtx.resources = sman;
@@ -962,7 +962,7 @@
GetCompositeSymbolizationBoundsInternal(symbolInstances, pSERenderer, sman, exec, symBounds);
// clean up
delete *iter;
@@ -989,7 +989,7 @@
double mm2sud = pSERenderer->GetScreenUnitsPerMillimeterDevice();
double mm2suw = pSERenderer->GetScreenUnitsPerMillimeterWorld();
@@ -1019,7 +1019,7 @@
More information about the mapguide-commits
