[mapguide-commits] r4572 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Mon Feb 1 16:15:33 EST 2010
Author: waltweltonlair
Date: 2010-02-01 16:15:33 -0500 (Mon, 01 Feb 2010)
New Revision: 4572
trunk/MgDev/Common/Stylization/mtext_parser.cpp
Fix #1260 (MText stack code draws invalid line)
Fixed the logic in MTextParseInstance::Parse_S_OverUnder to correctly
handle underlines and overlines.
Modified: trunk/MgDev/Common/Stylization/mtext_parser.cpp
--- trunk/MgDev/Common/Stylization/mtext_parser.cpp 2010-01-31 06:17:51 UTC (rev 4571)
+++ trunk/MgDev/Common/Stylization/mtext_parser.cpp 2010-02-01 21:15:33 UTC (rev 4572)
@@ -389,6 +389,13 @@
if(eOldJustification != ATOM::Justification::keCentered)
Run.Style().AddDelta(ATOM::JustificationStyleParticle(ATOM::Justification::keCentered));
+ // also get the current underline / overline settings
+ ATOM::UnderlineStyleParticle* pOldUnderline = (ATOM::UnderlineStyleParticle*)(Run.Style().GetDescriptionParticle(ATOM::StyleParticle::keUnderline));
+ ATOM::TextLine::Type eOldUnderline = (pOldUnderline != NULL)? pOldUnderline->Value() : ATOM::TextLine::keNone;
+ ATOM::OverlineStyleParticle* pOldOverline = (ATOM::OverlineStyleParticle*)(Run.Style().GetDescriptionParticle(ATOM::StyleParticle::keOverline));
+ ATOM::TextLine::Type eOldOverline = (pOldOverline != NULL)? pOldOverline->Value() : ATOM::TextLine::keNone;
bool bHasNumer = sNumer.Length() > 0;
bool bHasDenom = sDenom.Length() > 0;
@@ -411,7 +418,7 @@
// Short-term hack, instead of relying on BorderLineStyleParticle.
// See the OverlineStyleParticle in the corresponding code below for notes.
- if(sDenom.Length() < sNumer.Length()) {
+ if(sDenom.Length() < sNumer.Length() && eOldUnderline != ATOM::TextLine::keSingle) {
Run.Style().AddDelta(ATOM::UnderlineStyleParticle(ATOM::TextLine::keSingle));
bNumerLine = true;
@@ -435,6 +442,13 @@
// Prepare for what follows
+ // Disable any underline from the short-term hack
+ if(bNumerLine)
+ Run.Style().AddDelta(ATOM::UnderlineStyleParticle(eOldUnderline));
+ bNumerLine = false;
// End of superscript
Run.Location().AddSemantic(ATOM::ILocation::keEndSuperscript);
// This location stuff is subject to some fiddling (part 2)
@@ -462,9 +476,9 @@
// ... instead, we temporarily do this. We assume, based on some use-case knowledge
// of the stacked fraction, that these are likely to be numeric, and numbers are usually
// fixed-width, even in variable-width fonts.
- if(sDenom.Length() >= sNumer.Length()) {
- Run.Style().AddDelta(ATOM::OverlineStyleParticle(ATOM::TextLine::keSingle));
- bDenomLine = true;
+ if(sDenom.Length() >= sNumer.Length() && eOldOverline != ATOM::TextLine::keSingle) {
+ Run.Style().AddDelta(ATOM::OverlineStyleParticle(ATOM::TextLine::keSingle));
+ bDenomLine = true;
@@ -485,6 +499,13 @@
+ // Disable any overline from the short-term hack
+ if(bDenomLine)
+ Run.Style().AddDelta(ATOM::OverlineStyleParticle(eOldOverline));
+ bDenomLine = false;
// End of subscript
Run.Location().AddSemantic(ATOM::ILocation::keEndSubscript);
// This location stuff is subject to some fiddling (part 4)
@@ -500,16 +521,9 @@
// End the line
// Removed, for now. See above.
//Run.Style().AddDelta(ATOM::TopBorderLineStyleParticle(ATOM::BorderLine::keNoBorder));
- // ... instead, we disable the hacked Under/Over
- if(bNumerLine)
- Run.Style().AddDelta(ATOM::UnderlineStyleParticle(ATOM::TextLine::keNone));
- if(bDenomLine)
- Run.Style().AddDelta(ATOM::OverlineStyleParticle(ATOM::TextLine::keNone));
Run.Style().AddDelta(ATOM::JustificationStyleParticle(eOldJustification));
More information about the mapguide-commits
