[mapguide-commits] r4581 - trunk/MgDev/Server/src/Core
svn_mapguide at osgeo.org
Wed Feb 3 14:57:36 EST 2010
Author: waltweltonlair
Date: 2010-02-03 14:57:35 -0500 (Wed, 03 Feb 2010)
New Revision: 4581
trunk/MgDev/Server/src/Core/Makefile.am
Add trailing slashes to paths that get written out in the serverconfig_linux.ini.
Modified: trunk/MgDev/Server/src/Core/Makefile.am
--- trunk/MgDev/Server/src/Core/Makefile.am 2010-02-03 18:29:47 UTC (rev 4580)
+++ trunk/MgDev/Server/src/Core/Makefile.am 2010-02-03 19:57:35 UTC (rev 4581)
@@ -282,20 +282,20 @@
serverconfig_linux.ini :
@sed -e 's#^FdoPath.*=.*#FdoPath = $(map_fdo_lib)#' \
- -e 's#^LogsPath.*=.*#LogsPath = Logs#' \
- -e 's#^ResourcesPath.*=.*#ResourcesPath = Resources#' \
- -e 's#^TempPath.*=.*#TempPath = Temp#' \
- -e 's#^WmsDocumentPath.*=.*#WmsDocumentPath = Wms#' \
- -e 's#^WfsDocumentPath.*=.*#WfsDocumentPath = Wfs#' \
- -e 's#^TileCachePath.*=.*#TileCachePath = Repositories/TileCache#' \
- -e 's#^LibraryResourceDataFilePath.*=.*#LibraryResourceDataFilePath = Repositories/Library/DataFiles#' \
- -e 's#^LibraryRepositoryPath.*=.*#LibraryRepositoryPath = Repositories/Library#' \
- -e 's#^SessionResourceDataFilePath.*=.*#SessionResourceDataFilePath = Repositories/Session/DataFiles#' \
- -e 's#^SessionRepositoryPath.*=.*#SessionRepositoryPath = Repositories/Session#' \
- -e 's#^SiteRepositoryPath.*=.*#SiteRepositoryPath = Repositories/Site#' \
- -e 's#^PackagesPath.*=.*#PackagesPath = Packages#' \
- -e 's#^ResourceSchemaFilePath.*=.*#ResourceSchemaFilePath = ../../../Common/Schema#' \
- -e 's#^ResourceDataFileTrashFolderName.*=.*#ResourceDataFileTrashFolderName = Trash#' \
+ -e 's#^LogsPath.*=.*#LogsPath = Logs/#' \
+ -e 's#^ResourcesPath.*=.*#ResourcesPath = Resources/#' \
+ -e 's#^TempPath.*=.*#TempPath = Temp/#' \
+ -e 's#^WmsDocumentPath.*=.*#WmsDocumentPath = Wms/#' \
+ -e 's#^WfsDocumentPath.*=.*#WfsDocumentPath = Wfs/#' \
+ -e 's#^TileCachePath.*=.*#TileCachePath = Repositories/TileCache/#' \
+ -e 's#^LibraryResourceDataFilePath.*=.*#LibraryResourceDataFilePath = Repositories/Library/DataFiles/#' \
+ -e 's#^LibraryRepositoryPath.*=.*#LibraryRepositoryPath = Repositories/Library/#' \
+ -e 's#^SessionResourceDataFilePath.*=.*#SessionResourceDataFilePath = Repositories/Session/DataFiles/#' \
+ -e 's#^SessionRepositoryPath.*=.*#SessionRepositoryPath = Repositories/Session/#' \
+ -e 's#^SiteRepositoryPath.*=.*#SiteRepositoryPath = Repositories/Site/#' \
+ -e 's#^PackagesPath.*=.*#PackagesPath = Packages/#' \
+ -e 's#^ResourceSchemaFilePath.*=.*#ResourceSchemaFilePath = ../../../Common/Schema/#' \
+ -e 's#^ResourceDataFileTrashFolderName.*=.*#ResourceDataFileTrashFolderName = Trash/#' \
-e 's#^LegendFont.*=.*#LegendFont = Complex#' \
serverconfig.ini > serverconfig_linux.ini
@cp -f serverconfig_linux.ini serverconfig.ini
More information about the mapguide-commits
