[mapguide-commits] r4586 - in trunk/Tools/Maestro/Maestro: . ResourceEditors ResourceEditors/FeatureSourceEditors/Gdal ResourceEditors/FeatureSourceEditors/ODBC ResourceEditors/LayerEditorControls/ScaleControls ResourceEditors/LayoutControls
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Feb 4 13:35:35 EST 2010
Author: ksgeograf
Date: 2010-02-04 13:35:34 -0500 (Thu, 04 Feb 2010)
New Revision: 4586
   trunk/Tools/Maestro/Maestro/FormMain.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/CoordinateSystemOverride.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditorBase.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/Gdal/Composite.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/ODBC/FeatureSourceEditorODBC.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditor.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/ScaleControls/ConditionListButtons.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutControls/InvokeURL.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/MapEditor.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/ResourceDataEditor.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/XmlEditorControl.cs
Maestro:
Pick up LastException in more places.
Modified: trunk/Tools/Maestro/Maestro/FormMain.cs
--- trunk/Tools/Maestro/Maestro/FormMain.cs	2010-02-04 03:25:50 UTC (rev 4585)
+++ trunk/Tools/Maestro/Maestro/FormMain.cs	2010-02-04 18:35:34 UTC (rev 4586)
@@ -1194,7 +1194,10 @@
                         while (iex is System.Reflection.TargetInvocationException && iex.InnerException != null)
                             iex = iex.InnerException;
                         if (!(iex is CancelException))
+                            LastException = ex;
                             MessageBox.Show(this, string.Format(Strings.FormMain.OpenFailedError, resourceID, iex.ToString()), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
                 else
@@ -1307,6 +1310,7 @@
 			catch (Exception ex)
 				MessageBox.Show(this, string.Format(Strings.FormMain.SaveResourceError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
@@ -1338,6 +1342,7 @@
                 MessageBox.Show(this, string.Format(Strings.FormMain.TemplateLoadError, ex.ToString()), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
                 return;
@@ -1384,6 +1389,7 @@
 				catch(Exception ex)
 					MessageBox.Show(this, string.Format(Strings.FormMain.DeleteFolderError, ex.ToString()), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
@@ -1406,6 +1412,7 @@
 				catch(Exception ex)
 					MessageBox.Show(this, string.Format(Strings.FormMain.DeleteResourceError, ex.ToString()), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
@@ -1781,6 +1788,7 @@
                         MessageBox.Show(this, string.Format(Strings.FormMain.PreviewFailedError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
 					break;
@@ -2024,6 +2032,7 @@
 					MessageBox.Show(this, string.Format(Strings.FormMain.XmlEditorError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
@@ -2095,6 +2104,7 @@
 			catch(Exception ex)
 				MessageBox.Show(this, string.Format(Strings.FormMain.OpenResourceError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
@@ -2134,6 +2144,7 @@
 			catch(Exception ex)
@@ -2327,6 +2338,8 @@
             catch(Exception ex)
                 if (ex is System.Reflection.TargetInvocationException && ex.InnerException != null)
                     ex = ex.InnerException;
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/CoordinateSystemOverride.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/CoordinateSystemOverride.cs	2010-02-04 03:25:50 UTC (rev 4585)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/CoordinateSystemOverride.cs	2010-02-04 18:35:34 UTC (rev 4586)
@@ -426,6 +426,7 @@
+                m_editor.SetLastException(ex);
                 MessageBox.Show(this, string.Format(Strings.CoordinateSystemOverride.CoordinateSystemLoadError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
@@ -471,6 +472,7 @@
@@ -554,6 +556,7 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditorBase.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditorBase.cs	2010-02-04 03:25:50 UTC (rev 4585)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditorBase.cs	2010-02-04 18:35:34 UTC (rev 4586)
@@ -490,6 +490,7 @@
                 MessageBox.Show(string.Format(Strings.FeatureSourceEditorBase.ResourceSaveError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
                 return false;
@@ -540,6 +541,7 @@
                 MessageBox.Show(this, string.Format(Strings.FeatureSourceEditorBase.XmlUpdateError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/Gdal/Composite.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/Gdal/Composite.cs	2010-02-04 03:25:50 UTC (rev 4585)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/Gdal/Composite.cs	2010-02-04 18:35:34 UTC (rev 4586)
@@ -407,6 +407,7 @@
                 MessageBox.Show(this, string.Format(Strings.Composite.FileLoadError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
                 return;
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/ODBC/FeatureSourceEditorODBC.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/ODBC/FeatureSourceEditorODBC.cs	2010-02-04 03:25:50 UTC (rev 4585)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/ODBC/FeatureSourceEditorODBC.cs	2010-02-04 18:35:34 UTC (rev 4586)
@@ -202,6 +202,7 @@
                         MessageBox.Show(this, string.Format(OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Strings.FeatureSourceEditorODBC.CoordinateSystemError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
@@ -450,6 +451,7 @@
@@ -545,7 +547,8 @@
-				MessageBox.Show(this, string.Format(OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Strings.FeatureSourceEditorODBC.SchemaRefreshError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+                MessageBox.Show(this, string.Format(OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Strings.FeatureSourceEditorODBC.SchemaRefreshError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
@@ -850,7 +853,8 @@
 				catch(Exception ex)
-					MessageBox.Show(this, string.Format(OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Strings.FeatureSourceEditorODBC.ConfigurationReadError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+                    MessageBox.Show(this, string.Format(OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Strings.FeatureSourceEditorODBC.ConfigurationReadError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
 					return;
@@ -874,7 +878,8 @@
 			catch(Exception ex)
-				MessageBox.Show(this, string.Format(OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Strings.FeatureSourceEditorODBC.DatasourceLayoutReadError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+                MessageBox.Show(this, string.Format(OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Strings.FeatureSourceEditorODBC.DatasourceLayoutReadError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
 				return;
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditor.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditor.cs	2010-02-04 03:25:50 UTC (rev 4585)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditor.cs	2010-02-04 18:35:34 UTC (rev 4586)
@@ -122,7 +122,8 @@
-				MessageBox.Show(this, string.Format(Strings.LayerEditor.SchemaReadError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+                MessageBox.Show(this, string.Format(Strings.LayerEditor.SchemaReadError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
@@ -610,7 +611,8 @@
 			catch(Exception ex)
-				MessageBox.Show(this, string.Format(Strings.LayerEditor.MapPreviewError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+                MessageBox.Show(this, string.Format(Strings.LayerEditor.MapPreviewError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
             return true;
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/ScaleControls/ConditionListButtons.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/ScaleControls/ConditionListButtons.cs	2010-02-04 03:25:50 UTC (rev 4585)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayerEditorControls/ScaleControls/ConditionListButtons.cs	2010-02-04 18:35:34 UTC (rev 4586)
@@ -135,7 +135,6 @@
             try
                 object owner = null;
-                object item = null;
                 if (m_point != null)
                     owner = m_point;
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutControls/InvokeURL.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutControls/InvokeURL.cs	2010-02-04 03:25:50 UTC (rev 4585)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutControls/InvokeURL.cs	2010-02-04 18:35:34 UTC (rev 4586)
@@ -372,7 +372,8 @@
-				MessageBox.Show(this, string.Format(Strings.InvokeURL.LayerListReadError, mapname, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+                MessageBox.Show(this, string.Format(Strings.InvokeURL.LayerListReadError, mapname, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
 				return;
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.cs	2010-02-04 03:25:50 UTC (rev 4585)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.cs	2010-02-04 18:35:34 UTC (rev 4586)
@@ -1998,7 +1998,8 @@
-				MessageBox.Show(this, String.Format(Strings.LayoutEditor.BrowserLaunchError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+                MessageBox.Show(this, String.Format(Strings.LayoutEditor.BrowserLaunchError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/MapEditor.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/MapEditor.cs	2010-02-04 03:25:50 UTC (rev 4585)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/MapEditor.cs	2010-02-04 18:35:34 UTC (rev 4586)
@@ -1239,6 +1239,7 @@
                 MessageBox.Show(this, string.Format(Strings.MapEditor.LayerProjectionReadError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
@@ -1724,7 +1725,8 @@
 			catch(Exception ex)
-				MessageBox.Show(this, string.Format(Strings.MapEditor.MapPreviewError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+                MessageBox.Show(this, string.Format(Strings.MapEditor.MapPreviewError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
 			return true;
@@ -1883,6 +1885,7 @@
@@ -1893,7 +1896,8 @@
-				MessageBox.Show(this, string.Format(Strings.MapEditor.LayerExtentReadError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+                MessageBox.Show(this, string.Format(Strings.MapEditor.LayerExtentReadError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/ResourceDataEditor.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/ResourceDataEditor.cs	2010-02-04 03:25:50 UTC (rev 4585)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/ResourceDataEditor.cs	2010-02-04 18:35:34 UTC (rev 4586)
@@ -500,7 +500,7 @@
-							switch(MessageBox.Show(owner, string.Format(Strings.ResourceDataEditor.DeleteFailedQuestion, resourcename, ex.Message), Application.ProductName, MessageBoxButtons.AbortRetryIgnore, MessageBoxIcon.Error))
+                            switch (MessageBox.Show(owner, string.Format(Strings.ResourceDataEditor.DeleteFailedQuestion, resourcename, ex.Message), Application.ProductName, MessageBoxButtons.AbortRetryIgnore, MessageBoxIcon.Error))
 								case DialogResult.Abort:
 									return res;
@@ -560,7 +560,7 @@
 						catch(Exception ex)
-							switch(MessageBox.Show(owner, string.Format(Strings.ResourceDataEditor.DownloadFailedQuestion, items[0], ex.Message), Application.ProductName, MessageBoxButtons.AbortRetryIgnore, MessageBoxIcon.Error))
+                            switch (MessageBox.Show(owner, string.Format(Strings.ResourceDataEditor.DownloadFailedQuestion, items[0], ex.Message), Application.ProductName, MessageBoxButtons.AbortRetryIgnore, MessageBoxIcon.Error))
 									return res;
@@ -607,7 +607,7 @@
 							catch(Exception ex)
-								switch(MessageBox.Show(owner, string.Format(Strings.ResourceDataEditor.DownloadFailedQuestion, item, ex.Message), Application.ProductName, MessageBoxButtons.AbortRetryIgnore, MessageBoxIcon.Error))
+                                switch (MessageBox.Show(owner, string.Format(Strings.ResourceDataEditor.DownloadFailedQuestion, item, ex.Message), Application.ProductName, MessageBoxButtons.AbortRetryIgnore, MessageBoxIcon.Error))
 										return res;
@@ -673,7 +673,8 @@
 					catch(Exception ex)
-						switch(MessageBox.Show(this, string.Format(Strings.ResourceDataEditor.DownloadFailedQuestion, i.Text, ex.Message), Application.ProductName, MessageBoxButtons.AbortRetryIgnore, MessageBoxIcon.Error))
+                        switch (MessageBox.Show(this, string.Format(Strings.ResourceDataEditor.DownloadFailedQuestion, i.Text, ex.Message), Application.ProductName, MessageBoxButtons.AbortRetryIgnore, MessageBoxIcon.Error))
 								RefreshFileList();
@@ -847,6 +848,7 @@
                 MessageBox.Show(this, string.Format(Strings.ResourceDataEditor.UpdateXmlDataError, ex.Message), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/XmlEditorControl.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/XmlEditorControl.cs	2010-02-04 03:25:50 UTC (rev 4585)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/XmlEditorControl.cs	2010-02-04 18:35:34 UTC (rev 4586)
@@ -489,7 +489,9 @@
-				MessageBox.Show(this, string.Format(Strings.XmlEditorControl.SerializeError, ex.ToString()), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
+                if (m_editor != null)
+                MessageBox.Show(this, string.Format(Strings.XmlEditorControl.SerializeError, ex.ToString()), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
 				return false;
@@ -646,6 +648,8 @@
                 EndExternalEditing(false);
                 MessageBox.Show(this, string.Format(Strings.XmlEditorControl.ExternalEditorError, ex.ToString()), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
More information about the mapguide-commits mailing list
