[mapguide-commits] r4591 - trunk/MgDev/Server/src/Wms
svn_mapguide at osgeo.org
Tue Feb 9 12:52:21 EST 2010
Author: brucedechant
Date: 2010-02-09 12:52:20 -0500 (Tue, 09 Feb 2010)
New Revision: 4591
trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd
Fix for trac ticket 1266 - Fix errors in OgcWmsService.config.awd file
http://trac.osgeo.org/mapguide/ticket/1266
Notes:
- Removed comment tag at the end of line 235
- Updated the coordinate system WKT on line 238
Modified: trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd
--- trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd 2010-02-09 17:49:55 UTC (rev 4590)
+++ trunk/MgDev/Server/src/Wms/OgcWmsService.config.awd 2010-02-09 17:52:20 UTC (rev 4591)
@@ -232,10 +232,10 @@
<!-- Add translate elements here to map any particularly -->
<!-- troublesome SRS to some appropriate WKT. -->
<Define item="SRS.WKT.map">
- <!-- This example fixes a problem with EPSG:21781 not -->
+ <!-- This example fixes a problem with EPSG:21781 not
finding the WKT for EPSG:21781 in the CS library.
- <translate from="EPSG:21781">PROJCS["CH1903.LV03",GEOGCS["LLCH1903",DATUM["CH-1903",SPHEROID["BESSEL",6377397.155,299.15281535],TOWGS84[660.0770,13.5510,369.3440,0.804816,0.577692,0.952236,5.66000000]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Swiss_Oblique_Cylindrical"],PARAMETER["central_meridian",7.43958333333333],PARAMETER["latitude_of_origin",46.95240555555556],PARAMETER["false_easting",600000.000],PARAMETER["false_northing",200000.000],UNIT["Meter",1.00000000000000],AXIS["Y",NORTH],AXIS["X",EAST]]"</translate>
+ <translate from="EPSG:21781">PROJCS["CH1903.LV03/01",GEOGCS["LLCH1903",DATUM["CH-1903",SPHEROID["BESSEL",6377397.155,299.15281535],TOWGS84[660.0770,13.5510,369.3440,0.804816,0.577692,0.952236,5.66000000]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Swiss_Oblique_Cylindrical"],PARAMETER["false_easting",600000.000],PARAMETER["false_northing",200000.000],PARAMETER["latitude_of_origin",46.95240555555556],PARAMETER["central_meridian",7.43958333333333],UNIT["Meter",1.00000000000000]]</translate>
</Define>
More information about the mapguide-commits
