[mapguide-commits] r4603 - trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/PostGIS
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Feb 20 18:42:11 EST 2010
Author: ksgeograf
Date: 2010-02-20 18:42:11 -0500 (Sat, 20 Feb 2010)
New Revision: 4603
   trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/PostGIS/FeatureSourceEditorPostGIS.cs
   trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/PostGIS/FeatureSourceEditorPostGIS.resx
Maestro: Fixed issue #1275.
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/PostGIS/FeatureSourceEditorPostGIS.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/PostGIS/FeatureSourceEditorPostGIS.cs	2010-02-20 23:34:35 UTC (rev 4602)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/PostGIS/FeatureSourceEditorPostGIS.cs	2010-02-20 23:42:11 UTC (rev 4603)
@@ -59,6 +59,9 @@
 			m_editor = editor;
 			m_feature = feature;
+            if (!m_editor.Existing && string.IsNullOrEmpty(m_feature.Parameter["DataStore"]))
+                m_feature.Parameter["DataStore"] = "public";
 			UpdateDisplay();
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/PostGIS/FeatureSourceEditorPostGIS.resx
--- trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/PostGIS/FeatureSourceEditorPostGIS.resx	2010-02-20 23:34:35 UTC (rev 4602)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/FeatureSourceEditors/PostGIS/FeatureSourceEditorPostGIS.resx	2010-02-20 23:42:11 UTC (rev 4603)
@@ -142,7 +142,7 @@
     <value>credentials</value>
   </data>
   <data name="&gt;&gt;credentials.Type" xml:space="preserve">
-    <value>OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Credentials, OSGeo.MapGuide.Maestro.ResourceEditors, Version=1.1.0.4347, Culture=neutral, PublicKeyToken=null</value>
+    <value>OSGeo.MapGuide.Maestro.ResourceEditors.FeatureSourceEditors.ODBC.Credentials, OSGeo.MapGuide.Maestro.ResourceEditors, Version=2.0.0.4513, Culture=neutral, PublicKeyToken=null</value>
   </data>
   <data name="&gt;&gt;credentials.Parent" xml:space="preserve">
     <value>$this</value>
@@ -150,9 +150,6 @@
   <data name="&gt;&gt;credentials.ZOrder" xml:space="preserve">
     <value>8</value>
   </data>
-  <metadata name="toolTips.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
-    <value>17, 17</value>
-  </metadata>
   <data name="Database.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
     <value>Top, Left, Right</value>
   </data>
@@ -165,6 +162,9 @@
   <data name="Database.TabIndex" type="System.Int32, mscorlib">
     <value>31</value>
   </data>
+  <metadata name="toolTips.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+    <value>17, 17</value>
+  </metadata>
   <data name="Database.ToolTip" xml:space="preserve">
     <value>Enter the database name here</value>
   </data>
@@ -180,11 +180,14 @@
   <data name="&gt;&gt;Database.ZOrder" xml:space="preserve">
     <value>4</value>
   </data>
+  <data name="label3.AutoSize" type="System.Boolean, mscorlib">
+    <value>True</value>
+  </data>
   <data name="label3.Location" type="System.Drawing.Point, System.Drawing">
     <value>8, 8</value>
   </data>
   <data name="label3.Size" type="System.Drawing.Size, System.Drawing">
-    <value>96, 16</value>
+    <value>53, 13</value>
   </data>
   <data name="label3.TabIndex" type="System.Int32, mscorlib">
     <value>30</value>
@@ -204,9 +207,6 @@
   <data name="&gt;&gt;label3.ZOrder" xml:space="preserve">
     <value>5</value>
   </data>
-  </metadata>
   <data name="Server.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
   </data>
@@ -234,11 +234,14 @@
   <data name="&gt;&gt;Server.ZOrder" xml:space="preserve">
     <value>6</value>
   </data>
+  <data name="label1.AutoSize" type="System.Boolean, mscorlib">
+  </data>
   <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
     <value>8, 40</value>
   </data>
   <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
+    <value>38, 13</value>
   </data>
   <data name="label1.TabIndex" type="System.Int32, mscorlib">
     <value>28</value>
@@ -258,9 +261,6 @@
   <data name="&gt;&gt;label1.ZOrder" xml:space="preserve">
     <value>7</value>
   </data>
-  </metadata>
   <data name="Port.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
   </data>
@@ -288,11 +288,14 @@
   <data name="&gt;&gt;Port.ZOrder" xml:space="preserve">
     <value>2</value>
   </data>
+  <data name="label2.AutoSize" type="System.Boolean, mscorlib">
+  </data>
   <data name="label2.Location" type="System.Drawing.Point, System.Drawing">
     <value>8, 72</value>
   </data>
   <data name="label2.Size" type="System.Drawing.Size, System.Drawing">
+    <value>26, 13</value>
   </data>
   <data name="label2.TabIndex" type="System.Int32, mscorlib">
     <value>32</value>
@@ -312,9 +315,6 @@
   <data name="&gt;&gt;label2.ZOrder" xml:space="preserve">
     <value>3</value>
   </data>
-  </metadata>
   <data name="Datastore.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
   </data>
@@ -342,17 +342,20 @@
   <data name="&gt;&gt;Datastore.ZOrder" xml:space="preserve">
     <value>0</value>
   </data>
+  <data name="label4.AutoSize" type="System.Boolean, mscorlib">
+  </data>
   <data name="label4.Location" type="System.Drawing.Point, System.Drawing">
     <value>8, 104</value>
   </data>
   <data name="label4.Size" type="System.Drawing.Size, System.Drawing">
+    <value>99, 13</value>
   </data>
   <data name="label4.TabIndex" type="System.Int32, mscorlib">
     <value>34</value>
   </data>
   <data name="label4.Text" xml:space="preserve">
-    <value>Datastore</value>
+    <value>Datastore (schema)</value>
   </data>
   <data name="&gt;&gt;label4.Name" xml:space="preserve">
     <value>label4</value>
More information about the mapguide-commits mailing list
