[mapguide-commits] r4503 - in trunk/MgDev: Common/Geometry/Parse
Server/RepositoryAdmin
UnitTest/Common/FoundationTest/DotNetUnmanagedApi
UnitTest/WebTier/MapAgent/MapAgentForms
Web/src/DotNetUnmanagedApi Web/src/DotNetUnmanagedApi/Web
Web/src/JavaApi Web/src/PhpApi Web/src/localized
Web/src/mapadmin/HelpDocs/Templates Web/src/viewerfiles
svn_mapguide at osgeo.org
Fri Jan 8 23:21:37 EST 2010
Author: waltweltonlair
Date: 2010-01-08 23:21:37 -0500 (Fri, 08 Jan 2010)
New Revision: 4503
trunk/MgDev/Common/Geometry/Parse/yyAwkt.y
trunk/MgDev/Server/RepositoryAdmin/COPYRIGHT
trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/COPYRIGHT
trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/dotnet.i
trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/COPYRIGHT
trunk/MgDev/Web/src/DotNetUnmanagedApi/COPYRIGHT
trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/InitializeWebTier.i
trunk/MgDev/Web/src/JavaApi/COPYRIGHT
trunk/MgDev/Web/src/JavaApi/java.i
trunk/MgDev/Web/src/PhpApi/COPYRIGHT
trunk/MgDev/Web/src/PhpApi/php.i
trunk/MgDev/Web/src/localized/en
trunk/MgDev/Web/src/mapadmin/HelpDocs/Templates/ServerAdminHelp with autodesk logo.dwt
trunk/MgDev/Web/src/viewerfiles/COPYRIGHT
Update copyright year to 2010
Modified: trunk/MgDev/Common/Geometry/Parse/yyAwkt.y
--- trunk/MgDev/Common/Geometry/Parse/yyAwkt.y 2010-01-09 04:15:37 UTC (rev 4502)
+++ trunk/MgDev/Common/Geometry/Parse/yyAwkt.y 2010-01-09 04:21:37 UTC (rev 4503)
@@ -1,5 +1,5 @@
-// Copyright (C) 2001-2009 by Autodesk, Inc. All Rights Reserved.
+// Copyright (C) 2001-2010 by Autodesk, Inc. All Rights Reserved.
// By using this code, you are agreeing to the terms and conditions of
// the License Agreement included in the documentation for this code.
Modified: trunk/MgDev/Server/RepositoryAdmin/COPYRIGHT
--- trunk/MgDev/Server/RepositoryAdmin/COPYRIGHT 2010-01-09 04:15:37 UTC (rev 4502)
+++ trunk/MgDev/Server/RepositoryAdmin/COPYRIGHT 2010-01-09 04:21:37 UTC (rev 4503)
@@ -2,7 +2,7 @@
copyright shall be used for all source files in this directory
and subdirectories.
-Copyright (C) 2004-2009 by Autodesk, Inc.
+Copyright (C) 2004-2010 by Autodesk, Inc.
This library is free software; you can redistribute it and/or
modify it under the terms of version 2.1 of the GNU Lesser
Modified: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/COPYRIGHT
--- trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/COPYRIGHT 2010-01-09 04:15:37 UTC (rev 4502)
+++ trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/COPYRIGHT 2010-01-09 04:21:37 UTC (rev 4503)
@@ -2,7 +2,7 @@
and subdirectories.
Modified: trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/dotnet.i
--- trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/dotnet.i 2010-01-09 04:15:37 UTC (rev 4502)
+++ trunk/MgDev/UnitTest/Common/FoundationTest/DotNetUnmanagedApi/dotnet.i 2010-01-09 04:21:37 UTC (rev 4503)
@@ -1,5 +1,5 @@
-// Copyright (C) 2004-2009 by Autodesk, Inc.
+// Copyright (C) 2004-2010 by Autodesk, Inc.
// This library is free software; you can redistribute it and/or
// modify it under the terms of version 2.1 of the GNU Lesser
Modified: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/COPYRIGHT
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/COPYRIGHT 2010-01-09 04:15:37 UTC (rev 4502)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/COPYRIGHT 2010-01-09 04:21:37 UTC (rev 4503)
@@ -2,7 +2,7 @@
and subdirectories.
Modified: trunk/MgDev/Web/src/DotNetUnmanagedApi/COPYRIGHT
--- trunk/MgDev/Web/src/DotNetUnmanagedApi/COPYRIGHT 2010-01-09 04:15:37 UTC (rev 4502)
+++ trunk/MgDev/Web/src/DotNetUnmanagedApi/COPYRIGHT 2010-01-09 04:21:37 UTC (rev 4503)
@@ -2,7 +2,7 @@
and subdirectories.
Modified: trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/InitializeWebTier.i
--- trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/InitializeWebTier.i 2010-01-09 04:15:37 UTC (rev 4502)
+++ trunk/MgDev/Web/src/DotNetUnmanagedApi/Web/InitializeWebTier.i 2010-01-09 04:21:37 UTC (rev 4503)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/JavaApi/COPYRIGHT
--- trunk/MgDev/Web/src/JavaApi/COPYRIGHT 2010-01-09 04:15:37 UTC (rev 4502)
+++ trunk/MgDev/Web/src/JavaApi/COPYRIGHT 2010-01-09 04:21:37 UTC (rev 4503)
@@ -2,7 +2,7 @@
and subdirectories.
Modified: trunk/MgDev/Web/src/JavaApi/java.i
--- trunk/MgDev/Web/src/JavaApi/java.i 2010-01-09 04:15:37 UTC (rev 4502)
+++ trunk/MgDev/Web/src/JavaApi/java.i 2010-01-09 04:21:37 UTC (rev 4503)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/PhpApi/COPYRIGHT
--- trunk/MgDev/Web/src/PhpApi/COPYRIGHT 2010-01-09 04:15:37 UTC (rev 4502)
+++ trunk/MgDev/Web/src/PhpApi/COPYRIGHT 2010-01-09 04:21:37 UTC (rev 4503)
@@ -2,7 +2,7 @@
and subdirectories.
Modified: trunk/MgDev/Web/src/PhpApi/php.i
--- trunk/MgDev/Web/src/PhpApi/php.i 2010-01-09 04:15:37 UTC (rev 4502)
+++ trunk/MgDev/Web/src/PhpApi/php.i 2010-01-09 04:21:37 UTC (rev 4503)
@@ -1,5 +1,5 @@
Modified: trunk/MgDev/Web/src/localized/en
--- trunk/MgDev/Web/src/localized/en 2010-01-09 04:15:37 UTC (rev 4502)
+++ trunk/MgDev/Web/src/localized/en 2010-01-09 04:21:37 UTC (rev 4503)
@@ -138,7 +138,7 @@
HTMLABOUTVIEWERTITLE = MapGuide Viewer
HTMLABOUTSERVERVERSION = %s (Version %s)
HTMLABOUTVIEWERVERSION = %s (Version %s)
-HTMLABOUTTEXT = <br>This product is made available subject to the terms of GNU Lesser General Public License Version 2.1 ("LGPL"). A copy of the LGPL, as well as additional copyright notices and license terms applicable to portions of this product are set forth in the <a href="../localized/license_en.htm" target="blank">license</a> file.<br><br>All trademarks and registered trademarks mentioned herein are the property of their respective owners.<br><br>Copyright © 2008-2009 by Autodesk, Inc.<br><br>
+HTMLABOUTTEXT = <br>This product is made available subject to the terms of GNU Lesser General Public License Version 2.1 ("LGPL"). A copy of the LGPL, as well as additional copyright notices and license terms applicable to portions of this product are set forth in the <a href="../localized/license_en.htm" target="blank">license</a> file.<br><br>All trademarks and registered trademarks mentioned herein are the property of their respective owners.<br><br>Copyright © 2008-2010 by Autodesk, Inc.<br><br>
HTMLABOUTLICENSE = license file
HTMLABOUTLICENSEFILE = license_en.htm
Modified: trunk/MgDev/Web/src/mapadmin/HelpDocs/Templates/ServerAdminHelp with autodesk logo.dwt
--- trunk/MgDev/Web/src/mapadmin/HelpDocs/Templates/ServerAdminHelp with autodesk logo.dwt 2010-01-09 04:15:37 UTC (rev 4502)
+++ trunk/MgDev/Web/src/mapadmin/HelpDocs/Templates/ServerAdminHelp with autodesk logo.dwt 2010-01-09 04:21:37 UTC (rev 4503)
@@ -136,7 +136,7 @@
</td>
<tr class="main">
<td class="lhsash" width="159"> </td>
- <td class="footer" width="725"> © Copyright 2008-2009 by Autodesk, Inc. All rights
+ <td class="footer" width="725"> © Copyright 2008-2010 by Autodesk, Inc. All rights
reserved. Reproduction or copying of images is prohibited.<br>
<a href="http://www.autodesk.com/trademark" class="ftnav">Legal Notices
& Trademarks</a> - <a href="http://www.autodesk.com/privacy" class="ftnav">Privacy
Modified: trunk/MgDev/Web/src/viewerfiles/COPYRIGHT
--- trunk/MgDev/Web/src/viewerfiles/COPYRIGHT 2010-01-09 04:15:37 UTC (rev 4502)
+++ trunk/MgDev/Web/src/viewerfiles/COPYRIGHT 2010-01-09 04:21:37 UTC (rev 4503)
@@ -2,7 +2,7 @@
and subdirectories.
More information about the mapguide-commits
