[mapguide-commits] r4517 - trunk/Tools/Maestro/Maestro/ResourceEditors
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sun Jan 10 10:10:01 EST 2010
Author: ksgeograf
Date: 2010-01-10 10:10:00 -0500 (Sun, 10 Jan 2010)
New Revision: 4517
   trunk/Tools/Maestro/Maestro/ResourceEditors/MapEditor.cs
Maestro:
Better support for metadata on a MapDefinition
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/MapEditor.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/MapEditor.cs	2010-01-10 13:15:18 UTC (rev 4516)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/MapEditor.cs	2010-01-10 15:10:00 UTC (rev 4517)
@@ -181,7 +181,20 @@
 				m_isUpdating = true;
-				txtDescription.Text = m_map.Metadata.Replace("<MapDescription>", "").Replace("</MapDescription>", "");
+                try
+                    System.Xml.XmlDocument doc = new System.Xml.XmlDocument();
+                    doc.LoadXml("<root>" + m_map.Metadata + "</root>");
+                    if (doc["root"]["MapDescription"] != null)
+                        txtDescription.Text = doc["root"]["MapDescription"].InnerText;
+                    else
+                        txtDescription.Text = "";
+                catch
+                    txtDescription.Text = m_map.Metadata.Replace("<MapDescription>", "").Replace("</MapDescription>", "");
 				if (m_editor.CurrentConnection.CoordinateSystem == null || m_map.CoordinateSystem == null || m_map.CoordinateSystem.Length == 0 || !m_editor.CurrentConnection.CoordinateSystem.IsLoaded)
 					txtCoordsys.Text = m_map.CoordinateSystem;
 				else
@@ -1139,7 +1152,20 @@
 			if (m_isUpdating)
 				return;
-			m_map.Metadata = "<MapDescription>" + txtDescription.Text + "</MapDescription>";
+            try
+                doc.LoadXml("<root>" + System.Web.HttpUtility.HtmlDecode(m_map.Metadata) + "</root>");
+                if (doc["root"]["MapDescription"] == null)
+                    doc["root"].AppendChild(doc.CreateElement("MapDescription"));
+                doc["root"]["MapDescription"].InnerText = txtDescription.Text;
+                m_map.Metadata = doc["root"].InnerXml;
+            catch
+                m_map.Metadata = "<MapDescription>" + txtDescription.Text + "</MapDescription>";
 			m_editor.HasChanged();
More information about the mapguide-commits mailing list
