[mapguide-commits] r4526 - trunk/MgDev/Web/src/viewerfiles
svn_mapguide at osgeo.org
Tue Jan 12 21:23:10 EST 2010
Author: leaf
Date: 2010-01-12 21:23:10 -0500 (Tue, 12 Jan 2010)
New Revision: 4526
trunk/MgDev/Web/src/viewerfiles/util.js
Submit on behalf of Arthur Liu.
Fixed ticket #1191 Ajax viewer fail to display when map named with bracket.
In viewerfiles/utils.js brackets are replaced wih "%%28" and %%29", which should be "%28" and "%29". So, there will be a resource not found exception, because %%28 and %%29 will not be decoded to brackets
Modified: trunk/MgDev/Web/src/viewerfiles/util.js
--- trunk/MgDev/Web/src/viewerfiles/util.js 2010-01-13 02:22:50 UTC (rev 4525)
+++ trunk/MgDev/Web/src/viewerfiles/util.js 2010-01-13 02:23:10 UTC (rev 4526)
@@ -2,7 +2,7 @@
function encodeComponent(str) {
op = /\(/g; cp = /\)/g;
- return encodeURIComponent(str).replace(op, "%%28").replace(cp, "%%29");
+ return encodeURIComponent(str).replace(op, "%28").replace(cp, "%29");
function ParseLocalizedFloat(floatString) {
More information about the mapguide-commits
