[mapguide-commits] r4535 - in trunk/MgDev: Common/Geometry/Buffer
Common/Geometry/Parse Common/Stylization
Server/src/Gws/GwsCommon Server/src/Gws/GwsCommon/inc
Server/src/Gws/GwsQueryEngine
Server/src/Gws/GwsQueryEngine/inc Server/src/Gws/GwsResource
Server/src/Gws/Include Server/src/Services/Feature
svn_mapguide at osgeo.org
Thu Jan 14 01:21:48 EST 2010
Author: waltweltonlair
Date: 2010-01-14 01:21:48 -0500 (Thu, 14 Jan 2010)
New Revision: 4535
trunk/MgDev/Common/Geometry/Buffer/performanceOptions.h
trunk/MgDev/Common/Geometry/Parse/yyAwkt.y
trunk/MgDev/Common/Stylization/ExpressionFunctionArgb.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionArgb.h
trunk/MgDev/Common/Stylization/ExpressionFunctionDecap.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionDecap.h
trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureClass.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureClass.h
trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureId.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureId.h
trunk/MgDev/Common/Stylization/ExpressionFunctionIf.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionIf.h
trunk/MgDev/Common/Stylization/ExpressionFunctionLayerId.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionLayerId.h
trunk/MgDev/Common/Stylization/ExpressionFunctionLookup.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionLookup.h
trunk/MgDev/Common/Stylization/ExpressionFunctionMapName.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionMapName.h
trunk/MgDev/Common/Stylization/ExpressionFunctionRange.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionRange.h
trunk/MgDev/Common/Stylization/ExpressionFunctionSession.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionSession.h
trunk/MgDev/Common/Stylization/ExpressionFunctionUrlEncode.cpp
trunk/MgDev/Common/Stylization/ExpressionFunctionUrlEncode.h
trunk/MgDev/Common/Stylization/ExpressionHelper.cpp
trunk/MgDev/Common/Stylization/ExpressionHelper.h
trunk/MgDev/Common/Stylization/GridStatusReporter.h
trunk/MgDev/Common/Stylization/GridStyleHandler.h
trunk/MgDev/Common/Stylization/GridStyleSurfaceColorHandler.cpp
trunk/MgDev/Common/Stylization/GridStylizerReactor.cpp
trunk/MgDev/Common/Stylization/GridStylizerReactor.h
trunk/MgDev/Common/Stylization/GridTheme.cpp
trunk/MgDev/Common/Stylization/GridThemeParser.cpp
trunk/MgDev/Common/Stylization/ThemeParameters.cpp
trunk/MgDev/Common/Stylization/ThemeParameters.h
trunk/MgDev/Server/src/Gws/GwsCommon/GwsCommon.cpp
trunk/MgDev/Server/src/Gws/GwsCommon/inc/GwsOperationHandler.h
trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsQueryEngine.def
trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsBinaryFeatureReader.h
trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsBinaryFeatureWriter.h
trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsBinaryReader.h
trunk/MgDev/Server/src/Gws/GwsResource/GwsResourceLinux.cpp
trunk/MgDev/Server/src/Gws/GwsResource/GwsResourceLinux.h
trunk/MgDev/Server/src/Gws/Include/GwsCommon.h
trunk/MgDev/Server/src/Gws/Include/GwsQueryEngine.h
trunk/MgDev/Server/src/Services/Feature/ByteSourceRasterStreamImpl.cpp
trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.cpp
trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.h
trunk/MgDev/Server/src/Services/Feature/FdoFilterCollection.cpp
trunk/MgDev/Server/src/Services/Feature/FdoFilterCollection.h
trunk/MgDev/Server/src/Services/Feature/FdoReaderCollection.cpp
trunk/MgDev/Server/src/Services/Feature/FdoReaderCollection.h
trunk/MgDev/Server/src/Services/Feature/FilterUtil.cpp
trunk/MgDev/Server/src/Services/Feature/GwsConnectionPool.cpp
trunk/MgDev/Server/src/Services/Feature/GwsConnectionPool.h
trunk/MgDev/Server/src/Services/Feature/ServerApplySchema.cpp
trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.cpp
Fix headers
Modified: trunk/MgDev/Common/Geometry/Buffer/performanceOptions.h
--- trunk/MgDev/Common/Geometry/Buffer/performanceOptions.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Geometry/Buffer/performanceOptions.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,5 +1,3 @@
-#ifndef _PERFORMANCEOPTIONS_H_
-#define _PERFORMANCEOPTIONS_H_
// Copyright (C) 2004-2010 by Autodesk, Inc.
@@ -17,9 +15,9 @@
// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
+#ifndef _PERFORMANCEOPTIONS_H_
+#define _PERFORMANCEOPTIONS_H_
// FOR DEBUGGING A CERTAIN POLYGON BUFFERING FAILURE, SET THE FOLLOWING:
// Dump intermediate data to .ffgf files (the winged edges). Set these flags in the compiler's command line:
Modified: trunk/MgDev/Common/Geometry/Parse/yyAwkt.y
--- trunk/MgDev/Common/Geometry/Parse/yyAwkt.y 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Geometry/Parse/yyAwkt.y 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,19 +1,19 @@
-// Copyright (C) 2001-2010 by Autodesk, Inc. All Rights Reserved.
-// By using this code, you are agreeing to the terms and conditions of
-// the License Agreement included in the documentation for this code.
-// AUTODESK MAKES NO WARRANTIES, EXPRESS OR IMPLIED, AS TO THE
-// CORRECTNESS OF THIS CODE OR ANY DERIVATIVE WORKS WHICH INCORPORATE
-// IT. AUTODESK PROVIDES THE CODE ON AN "AS-IS" BASIS AND EXPLICITLY
-// DISCLAIMS ANY LIABILITY, INCLUDING CONSEQUENTIAL AND INCIDENTAL
-// DAMAGES FOR ERRORS, OMISSIONS, AND OTHER PROBLEMS IN THE CODE.
-// Use, duplication, or disclosure by the U.S. Government is subject
-// to restrictions set forth in FAR 52.227-19 (Commercial Computer
-// Software Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
-// (Rights in Technical Data and Computer Software), as applicable.
+// Copyright (C) 2004-2010 by Autodesk, Inc.
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of version 2.1 of the GNU Lesser
+// General Public License as published by the Free Software Foundation.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
// Name
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionArgb.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionArgb.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionArgb.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
- * Copyright (C) 2007-2010 by Autodesk, Inc. All Rights Reserved.
- * By using this code, you are agreeing to the terms and conditions of
- * the License Agreement included in the documentation for this code.
- * AUTODESK MAKES NO WARRANTIES, EXPRESS OR IMPLIED, AS TO THE
- * CORRECTNESS OF THIS CODE OR ANY DERIVATIVE WORKS WHICH INCORPORATE
- * IT. AUTODESK PROVIDES THE CODE ON AN "AS-IS" BASIS AND EXPLICITLY
- * DISCLAIMS ANY LIABILITY, INCLUDING CONSEQUENTIAL AND INCIDENTAL
- * DAMAGES FOR ERRORS, OMISSIONS, AND OTHER PROBLEMS IN THE CODE.
- * Use, duplication, or disclosure by the U.S. Government is subject
- * to restrictions set forth in FAR 52.227-19 (Commercial Computer
- * Software Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
- * (Rights in Technical Data and Computer Software), as applicable.
+// Copyright (C) 2007-2010 by Autodesk, Inc.
#include "stdafx.h"
#include "ExpressionFunctionArgb.h"
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionArgb.h
--- trunk/MgDev/Common/Stylization/ExpressionFunctionArgb.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionArgb.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#ifndef EXPRESSION_FUNCTION_ARGB_H_
#define EXPRESSION_FUNCTION_ARGB_H_
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionDecap.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionDecap.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionDecap.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#include "stdafx.h"
#include "ExpressionFunctionDecap.h"
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionDecap.h
--- trunk/MgDev/Common/Stylization/ExpressionFunctionDecap.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionDecap.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#ifndef EXPRESSION_FUNCTION_DECAP_H_
#define EXPRESSION_FUNCTION_DECAP_H_
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureClass.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureClass.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureClass.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#include "stdafx.h"
#include "ExpressionFunctionFeatureClass.h"
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureClass.h
--- trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureClass.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureClass.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#ifndef EXPRESSION_FUNCTION_FEATURECLASS_H_
#define EXPRESSION_FUNCTION_FEATURECLASS_H_
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureId.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureId.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureId.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#include "stdafx.h"
#include "ExpressionFunctionFeatureId.h"
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureId.h
--- trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureId.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionFeatureId.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#ifndef EXPRESSION_FUNCTION_FEATUREID_H_
#define EXPRESSION_FUNCTION_FEATUREID_H_
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionIf.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionIf.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionIf.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#include "stdafx.h"
#include "ExpressionFunctionIf.h"
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionIf.h
--- trunk/MgDev/Common/Stylization/ExpressionFunctionIf.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionIf.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#ifndef EXPRESSION_FUNCTION_IF_H_
#define EXPRESSION_FUNCTION_IF_H_
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionLayerId.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionLayerId.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionLayerId.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#include "stdafx.h"
#include "ExpressionFunctionLayerId.h"
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionLayerId.h
--- trunk/MgDev/Common/Stylization/ExpressionFunctionLayerId.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionLayerId.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#ifndef EXPRESSION_FUNCTION_LAYERID_H_
#define EXPRESSION_FUNCTION_LAYERID_H_
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionLookup.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionLookup.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionLookup.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#include "stdafx.h"
#include "ExpressionFunctionLookup.h"
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionLookup.h
--- trunk/MgDev/Common/Stylization/ExpressionFunctionLookup.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionLookup.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#ifndef EXPRESSION_FUNCTION_LOOKUP_H_
#define EXPRESSION_FUNCTION_LOOKUP_H_
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionMapName.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionMapName.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionMapName.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#include "stdafx.h"
#include "ExpressionFunctionMapName.h"
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionMapName.h
--- trunk/MgDev/Common/Stylization/ExpressionFunctionMapName.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionMapName.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#ifndef EXPRESSION_FUNCTION_MAPNAME_H_
#define EXPRESSION_FUNCTION_MAPNAME_H_
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionRange.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionRange.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionRange.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#include "stdafx.h"
#include "ExpressionFunctionRange.h"
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionRange.h
--- trunk/MgDev/Common/Stylization/ExpressionFunctionRange.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionRange.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#ifndef EXPRESSION_FUNCTION_RANGE_H_
#define EXPRESSION_FUNCTION_RANGE_H_
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionSession.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionSession.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionSession.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#include "stdafx.h"
#include "ExpressionFunctionSession.h"
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionSession.h
--- trunk/MgDev/Common/Stylization/ExpressionFunctionSession.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionSession.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,21 +1,21 @@
#ifndef EXPRESSION_FUNCTION_SESSION_H_
#define EXPRESSION_FUNCTION_SESSION_H_
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionUrlEncode.cpp
--- trunk/MgDev/Common/Stylization/ExpressionFunctionUrlEncode.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionUrlEncode.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#include "stdafx.h"
#include "ExpressionFunctionUrlEncode.h"
Modified: trunk/MgDev/Common/Stylization/ExpressionFunctionUrlEncode.h
--- trunk/MgDev/Common/Stylization/ExpressionFunctionUrlEncode.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionFunctionUrlEncode.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#ifndef EXPRESSION_FUNCTION_URLENCODE_H_
#define EXPRESSION_FUNCTION_URLENCODE_H_
Modified: trunk/MgDev/Common/Stylization/ExpressionHelper.cpp
--- trunk/MgDev/Common/Stylization/ExpressionHelper.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionHelper.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#include "stdafx.h"
#include "ExpressionHelper.h"
Modified: trunk/MgDev/Common/Stylization/ExpressionHelper.h
--- trunk/MgDev/Common/Stylization/ExpressionHelper.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ExpressionHelper.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#ifndef EXPRESSION_HELPER_H_
#define EXPRESSION_HELPER_H_
Modified: trunk/MgDev/Common/Stylization/GridStatusReporter.h
--- trunk/MgDev/Common/Stylization/GridStatusReporter.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/GridStatusReporter.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,18 @@
-// $Header: //GBU/Metropolis/Main/Server/Common/Stylization/GridStatusReporter.h#1 $
-// Copyright (C) 2005-2010 by Autodesk, Inc. All Rights Reserved.
+// Copyright (C) 2005-2010 by Autodesk, Inc.
#ifndef GRIDSTATUSREPORTER_H_
Modified: trunk/MgDev/Common/Stylization/GridStyleHandler.h
--- trunk/MgDev/Common/Stylization/GridStyleHandler.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/GridStyleHandler.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,18 @@
-// $Header: //GBU/Metropolis/Main/Server/Common/Stylization/GridStyleHandler.h#1 $
#ifndef GRIDSTYLEHANDLER_H_
Modified: trunk/MgDev/Common/Stylization/GridStyleSurfaceColorHandler.cpp
--- trunk/MgDev/Common/Stylization/GridStyleSurfaceColorHandler.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/GridStyleSurfaceColorHandler.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,18 @@
-// $Header: //GBU/Metropolis/Main/Server/Common/Stylization/GridStyleSurfaceColorHandler.cpp#1 $
#include "stdafx.h"
Modified: trunk/MgDev/Common/Stylization/GridStylizerReactor.cpp
--- trunk/MgDev/Common/Stylization/GridStylizerReactor.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/GridStylizerReactor.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,18 @@
-// $Header: //GBU/Metropolis/Main/Server/Common/Stylization/GridStylizerReactor.cpp#1 $
#include "stdafx.h"
Modified: trunk/MgDev/Common/Stylization/GridStylizerReactor.h
--- trunk/MgDev/Common/Stylization/GridStylizerReactor.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/GridStylizerReactor.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,18 @@
-// $Header: //GBU/Metropolis/Main/Server/Common/Stylization/GridStylizerReactor.h#1 $
//#pragma once
Modified: trunk/MgDev/Common/Stylization/GridTheme.cpp
--- trunk/MgDev/Common/Stylization/GridTheme.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/GridTheme.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,18 @@
-// $Header: //GBU/Metropolis/Main/Server/Common/Stylization/GridTheme.cpp#1 $
#include "stdafx.h"
Modified: trunk/MgDev/Common/Stylization/GridThemeParser.cpp
--- trunk/MgDev/Common/Stylization/GridThemeParser.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/GridThemeParser.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,18 @@
-// $Header: //GBU/Metropolis/Main/Server/Common/Stylization/GridThemeParser.cpp#1 $
#include "stdafx.h"
Modified: trunk/MgDev/Common/Stylization/ThemeParameters.cpp
--- trunk/MgDev/Common/Stylization/ThemeParameters.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ThemeParameters.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#include "stdafx.h"
#include "ThemeParameters.h"
Modified: trunk/MgDev/Common/Stylization/ThemeParameters.h
--- trunk/MgDev/Common/Stylization/ThemeParameters.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Common/Stylization/ThemeParameters.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,20 +1,19 @@
#ifndef THEME_PARAMETERS_H_
#define THEME_PARAMETERS_H_
Modified: trunk/MgDev/Server/src/Gws/GwsCommon/GwsCommon.cpp
--- trunk/MgDev/Server/src/Gws/GwsCommon/GwsCommon.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Gws/GwsCommon/GwsCommon.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -17,6 +17,7 @@
#include "stdafx.h"
#include "GWSCommonImp.h"
BOOL APIENTRY DllMain( HANDLE hModule,
DWORD ul_reason_for_call,
LPVOID lpReserved
Modified: trunk/MgDev/Server/src/Gws/GwsCommon/inc/GwsOperationHandler.h
--- trunk/MgDev/Server/src/Gws/GwsCommon/inc/GwsOperationHandler.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Gws/GwsCommon/inc/GwsOperationHandler.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,18 +1,18 @@
-// Copyright (C) 2004-2010 by Autodesk, Inc.
-// This library is free software; you can redistribute it and/or
-// modify it under the terms of version 2.1 of the GNU Lesser
-// General Public License as published by the Free Software Foundation.
-// This library is distributed in the hope that it will be useful,
-// but WITHOUT ANY WARRANTY; without even the implied warranty of
-// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-// Lesser General Public License for more details.
-// You should have received a copy of the GNU Lesser General Public
-// License along with this library; if not, write to the Free Software
-// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include "GwsObjectImpl.h"
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsQueryEngine.def
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsQueryEngine.def 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/GwsQueryEngine.def 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,16 +1,16 @@
-; Copyright (C) 2004-2010 by Autodesk, Inc.
+; Copyright (C) 2007-2010 by Autodesk, Inc.
-; By using this code, you are agreeing to the terms and conditions of
-; the License Agreement included in the documentation for this code.
+; This library is free software; you can redistribute it and/or
+; modify it under the terms of version 2.1 of the GNU Lesser
+; General Public License as published by the Free Software Foundation.
-; AUTODESK MAKES NO WARRANTIES, EXPRESS OR IMPLIED, AS TO THE
-; CORRECTNESS OF THIS CODE OR ANY DERIVATIVE WORKS WHICH INCORPORATE
-; IT. AUTODESK PROVIDES THE CODE ON AN "AS-IS" BASIS AND EXPLICITLY
-; DISCLAIMS ANY LIABILITY, INCLUDING CONSEQUENTIAL AND INCIDENTAL
-; DAMAGES FOR ERRORS, OMISSIONS, AND OTHER PROBLEMS IN THE CODE.
+; This library is distributed in the hope that it will be useful,
+; but WITHOUT ANY WARRANTY; without even the implied warranty of
+; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+; Lesser General Public License for more details.
-; Use, duplication, or disclosure by the U.S. Government is subject
-; to restrictions set forth in FAR 52.227-19 (Commercial Computer
-; Software Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
-; (Rights in Technical Data and Computer Software), as applicable.
+; You should have received a copy of the GNU Lesser General Public
+; License along with this library; if not, write to the Free Software
+; Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsBinaryFeatureReader.h
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsBinaryFeatureReader.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsBinaryFeatureReader.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,17 +1,19 @@
#ifndef GWS_BINARYFEATUREWRITER_H
#define GWS_BINARYFEATUREWRITER_H
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsBinaryFeatureWriter.h
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsBinaryFeatureWriter.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsBinaryFeatureWriter.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,17 +1,19 @@
Modified: trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsBinaryReader.h
--- trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsBinaryReader.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Gws/GwsQueryEngine/inc/GwsBinaryReader.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,5 +1,3 @@
-#ifndef _BINARYREADER_H
-#define _BINARYREADER_H
@@ -15,7 +13,11 @@
+#ifndef _BINARYREADER_H
+#define _BINARYREADER_H
#ifdef _WIN32
#include <hash_map>
#else
Modified: trunk/MgDev/Server/src/Gws/GwsResource/GwsResourceLinux.cpp
--- trunk/MgDev/Server/src/Gws/GwsResource/GwsResourceLinux.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Gws/GwsResource/GwsResourceLinux.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,17 +1,19 @@
// This file was generated from the GWSResource.rc file
Modified: trunk/MgDev/Server/src/Gws/GwsResource/GwsResourceLinux.h
--- trunk/MgDev/Server/src/Gws/GwsResource/GwsResourceLinux.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Gws/GwsResource/GwsResourceLinux.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,17 +1,19 @@
Modified: trunk/MgDev/Server/src/Gws/Include/GwsCommon.h
--- trunk/MgDev/Server/src/Gws/Include/GwsCommon.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Gws/Include/GwsCommon.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,21 +1,23 @@
-#ifndef GWSCommon_H
-#define GWSCommon_H
+#ifndef GWSCommon_H
+#define GWSCommon_H
#ifdef _WIN32
#ifdef GWSCOMMON_EXPORTS
#define GWS_COMMON_API __declspec(dllexport)
Modified: trunk/MgDev/Server/src/Gws/Include/GwsQueryEngine.h
--- trunk/MgDev/Server/src/Gws/Include/GwsQueryEngine.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Gws/Include/GwsQueryEngine.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,21 +1,23 @@
-#ifndef GwsQueryEngine_h
-#define GwsQueryEngine_h
+#ifndef GwsQueryEngine_h
+#define GwsQueryEngine_h
#ifdef _WIN32
#ifdef GWSQUERYENGINE_EXPORTS
#define GWS_QUERYENGINE_API __declspec(dllexport)
Modified: trunk/MgDev/Server/src/Services/Feature/ByteSourceRasterStreamImpl.cpp
--- trunk/MgDev/Server/src/Services/Feature/ByteSourceRasterStreamImpl.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Services/Feature/ByteSourceRasterStreamImpl.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -20,6 +20,7 @@
#include "MapGuideCommon.h"
#include "ServerFeatureServiceDefs.h"
#include "ByteSourceRasterStreamImpl.h"
///<summary>
/// Construct a ByteSourceRasterStreamImpl object
Modified: trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.cpp
--- trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,21 +1,20 @@
-* Copyright (C) 2004-2010 by Autodesk, Inc.
-* This library is free software; you can redistribute it and/or
-* modify it under the terms of version 2.1 of the GNU Lesser
-* General Public License as published by the Free Software Foundation.
-* This library is distributed in the hope that it will be useful,
-* but WITHOUT ANY WARRANTY; without even the implied warranty of
-* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-* Lesser General Public License for more details.
-* You should have received a copy of the GNU Lesser General Public
-* License along with this library; if not, write to the Free Software
-* Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include "stdafx.h"
#include <assert.h>
#include "Fdo.h"
Modified: trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.h
--- trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Services/Feature/FdoFeatureReader.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,21 +1,22 @@
#ifndef _MGFDOFEATUREREADER_H
#define _MGFDOFEATUREREADER_H
- * Copyright (C) 2004-2010 by Autodesk, Inc.
- * This library is free software; you can redistribute it and/or
- * modify it under the terms of version 2.1 of the GNU Lesser
- * General Public License as published by the Free Software Foundation.
- * This library is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
- * Lesser General Public License for more details.
- * You should have received a copy of the GNU Lesser General Public
- * License along with this library; if not, write to the Free Software
- * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include "FdoReaderCollection.h"
@@ -96,4 +97,3 @@
#endif // _MGFDOFEATUREREADER_H
Modified: trunk/MgDev/Server/src/Services/Feature/FdoFilterCollection.cpp
--- trunk/MgDev/Server/src/Services/Feature/FdoFilterCollection.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Services/Feature/FdoFilterCollection.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,5 +1,4 @@
@@ -15,6 +14,7 @@
#include "stdafx.h"
#include "FdoFilterCollection.h"
@@ -22,4 +22,3 @@
return new MgFdoFilterCollection();
Modified: trunk/MgDev/Server/src/Services/Feature/FdoFilterCollection.h
--- trunk/MgDev/Server/src/Services/Feature/FdoFilterCollection.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Services/Feature/FdoFilterCollection.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,27 +1,22 @@
-#ifndef _MGFDOFILTERCOLLECTION_H_
-#define _MGFDOFILTERCOLLECTION_H_
-#ifdef _WIN32
-#pragma once
-#endif
+#ifndef _MGFDOFILTERCOLLECTION_H_
+#define _MGFDOFILTERCOLLECTION_H_
#include <FdoStd.h>
@@ -57,5 +52,3 @@
/*FDO_API*/ static MgFdoFilterCollection* Create();
#endif
Modified: trunk/MgDev/Server/src/Services/Feature/FdoReaderCollection.cpp
--- trunk/MgDev/Server/src/Services/Feature/FdoReaderCollection.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Services/Feature/FdoReaderCollection.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,5 +1,4 @@
@@ -15,6 +14,7 @@
#include "stdafx.h"
@@ -22,4 +22,3 @@
return new MgFdoReaderCollection();
Modified: trunk/MgDev/Server/src/Services/Feature/FdoReaderCollection.h
--- trunk/MgDev/Server/src/Services/Feature/FdoReaderCollection.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Services/Feature/FdoReaderCollection.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -1,27 +1,22 @@
-#ifndef _MGFDOREADERCOLLECTION_H_
-#define _MGFDOREADERCOLLECTION_H_
-#ifdef _WIN32
-#pragma once
-#endif
+#ifndef _MGFDOREADERCOLLECTION_H_
+#define _MGFDOREADERCOLLECTION_H_
#include <FdoStd.h>
@@ -57,5 +52,3 @@
/*FDO_API*/ static MgFdoReaderCollection* Create();
#endif
Modified: trunk/MgDev/Server/src/Services/Feature/FilterUtil.cpp
--- trunk/MgDev/Server/src/Services/Feature/FilterUtil.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Services/Feature/FilterUtil.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -921,4 +921,3 @@
return ret;
Modified: trunk/MgDev/Server/src/Services/Feature/GwsConnectionPool.cpp
--- trunk/MgDev/Server/src/Services/Feature/GwsConnectionPool.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Services/Feature/GwsConnectionPool.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -141,5 +141,3 @@
m_connections.erase (iter);
Modified: trunk/MgDev/Server/src/Services/Feature/GwsConnectionPool.h
--- trunk/MgDev/Server/src/Services/Feature/GwsConnectionPool.h 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Services/Feature/GwsConnectionPool.h 2010-01-14 06:21:48 UTC (rev 4535)
@@ -30,7 +30,6 @@
typedef MgGwsConnectionMap::value_type MgGwsConnectionMapValue;
class MgGwsConnectionPool : public IGWSConnectionPool
public:
Modified: trunk/MgDev/Server/src/Services/Feature/ServerApplySchema.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerApplySchema.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Services/Feature/ServerApplySchema.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -105,5 +105,3 @@
MG_FEATURE_SERVICE_CHECK_CONNECTION_CATCH_AND_THROW(resource, L"MgServerDescribeSchema.ApplySchema")
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.cpp 2010-01-14 05:04:09 UTC (rev 4534)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureReader.cpp 2010-01-14 06:21:48 UTC (rev 4535)
@@ -21,6 +21,7 @@
#include "Envelope.h"
#include "ServiceManager.h"
#include "ServerFeatureUtil.h"
///<summary>
/// Construct a MgServerFeatureReader object from a byte source
@@ -1232,4 +1233,3 @@
STRING propertyName = GetPropertyName(index);
return GetRaster(propertyName);
More information about the mapguide-commits
