[mapguide-commits] r4542 - trunk/MgDev/Common/CoordinateSystem
svn_mapguide at osgeo.org
Wed Jan 20 16:32:05 EST 2010
Author: NormOlsen
Date: 2010-01-20 16:32:05 -0500 (Wed, 20 Jan 2010)
New Revision: 4542
trunk/MgDev/Common/CoordinateSystem/CoordSysGrids.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysGrids.h
trunk/MgDev/Common/CoordinateSystem/CoordSysMgrsZone.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysOneGrid.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSysOneGrid.h
Improves the situation described by Trac # 1248. The MGRS 100KM labels looked like they were reversed, but actually the positions of the labels were being positioned out without the benefit of recognizing the truncation of the region due to the UTM Zone boundary.
The solution to this problem is beyond the current design of the API. The solution hereby submitted simply causes the labels which would be positioned incorrectly to be suppressed. It is likely that a legitimate label or two may also be suppressed. However, it was decided that no information is better than incorrect information.
Please note, that a real correction will require a major overall to the MgCoordinateSystemGridRegion object and its API will be subject to a complete redesign. Also submitted to sandbox/acad/2.2gp this date.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGrids.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGrids.cpp 2010-01-20 21:29:08 UTC (rev 4541)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGrids.cpp 2010-01-20 21:32:05 UTC (rev 4542)
@@ -698,6 +698,22 @@
// CCoordinateSystemGridRegion -- Associates a label/designation with a
// MgPolygon object.
+// This API has been found to be problematical in the initial release. It
+// will be deprecated in the next release.
+CCoordinateSystemGridRegion::CCoordinateSystemGridRegion (STRING label)
+ MgCoordinateSystemGridRegion (),
+ m_RegionLabel (label),
+ m_RegionCenter (),
+ m_RegionBoundary (),
+ m_SouthLine (),
+ m_EastLine (),
+ m_NorthLine (),
+ m_WestLine ()
CCoordinateSystemGridRegion::CCoordinateSystemGridRegion (STRING label,
MgCoordinateSystemGridBoundary* frameBoundary,
MgCoordinateSystemTransform* gridToFrame,
@@ -776,22 +792,34 @@
return SAFE_ADDREF(m_RegionBoundary.p);
MgLineStringCollection* CCoordinateSystemGridRegion::GetSouthLine (void)
return SAFE_ADDREF(m_SouthLine.p);
MgLineStringCollection* CCoordinateSystemGridRegion::GetEastLine (void)
return SAFE_ADDREF(m_EastLine.p);
MgLineStringCollection* CCoordinateSystemGridRegion::GetNorthLine (void)
return SAFE_ADDREF(m_NorthLine.p);
MgLineStringCollection* CCoordinateSystemGridRegion::GetWestLine (void)
return SAFE_ADDREF(m_WestLine.p);
+void CCoordinateSystemGridRegion::SetRegionCenter (MgCoordinate* regionCenter)
+ m_RegionCenter = SAFE_ADDREF (regionCenter);
void CCoordinateSystemGridRegion::SetRegionBoundary (MgPolygon* boundary)
m_RegionBoundary = SAFE_ADDREF (boundary);
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysGrids.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysGrids.h 2010-01-20 21:29:08 UTC (rev 4541)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysGrids.h 2010-01-20 21:32:05 UTC (rev 4542)
@@ -305,9 +305,13 @@
// CCoordinateSystemGridregion -- Implements MgCoordinateSystemGridRegion
class CCoordinateSystemGridRegion : public MgCoordinateSystemGridRegion
public:
+ CCoordinateSystemGridRegion (STRING label);
CCoordinateSystemGridRegion (STRING label,MgCoordinateSystemGridBoundary* frameBoundary,
MgCoordinate* southwest,
@@ -327,6 +331,7 @@
MgLineStringCollection* GetNorthLine (void);
MgLineStringCollection* GetWestLine (void);
+ void SetRegionCenter (MgCoordinate* regionCenter);
void SetRegionBoundary (MgPolygon* boundary);
void SetSouthLine (MgLineStringCollection* southLine);
void SetEastLine (MgLineStringCollection* eastLine);
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysMgrsZone.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysMgrsZone.cpp 2010-01-20 21:29:08 UTC (rev 4541)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysMgrsZone.cpp 2010-01-20 21:32:05 UTC (rev 4542)
@@ -21,6 +21,7 @@
#include "CriticalSection.h" //for SmartCriticalClass
#include "Spatial/MathUtility.h"
+#include "Spatial/SpatialUtility.h"
#include "CoordSysGrids.h"
#include "CoordSysOneGrid.h"
#include "CoordSysMgrsZone.h"
@@ -471,8 +472,15 @@
double curvePrecision)
- const INT32 maxPoints = 512;
+ static const INT32 iK100Km = 100000;
+ static const double rK100Km = 100000.0;
+ const INT32 maxPoints = 254;
+ bool swPntIsIn;
+ bool sePntIsIn;
+ bool nePntIsIn;
+ bool nwPntIsIn;
INT32 beginEast, endEast;
INT32 beginNorth, endNorth;
INT32 eastIndex, northIndex;
@@ -481,17 +489,14 @@
double eastMin, eastMax;
double northMin, northMax;
- Ptr<MgCoordinate> southwest;
- Ptr<MgCoordinate> northeast;
Ptr<MgCoordinateSystemTransform> gridToFrameXfrom;
- Ptr<CCoordinateSystemGridBoundary> rgnBoundary;
+ Ptr<MgCoordinateSystemGridBoundary> rgnBoundary;
Ptr<CCoordinateSystemGridRegion> pMnrRegion;
MgCoordinateSystemFactory csFactory;
+ MgGeometryFactory mgFactory;
MG_TRY ()
- southwest = new MgCoordinateXY ();
- northeast = new MgCoordinateXY ();
// This function is in the OneGrid base class. We call it just in case
// the grid boundary has not been generated for this object yet.
GetGridExtents (eastMin,eastMax,northMin,northMax,curvePrecision);
@@ -503,27 +508,32 @@
// Expand the min/max values to the 100K boundaries of the minor regions.
// A little overkill here as the extent values should never be negative.
- delta = fabs (fmod (eastMin,100000.0));
- beginEast = static_cast<INT32>(eastMin - ((eastMin >= 0.0) ? delta : (100000.0 - delta)));
- delta = fabs (fmod (eastMax,100000.0));
- endEast = static_cast<INT32>(eastMax + ((eastMax >= 0.0) ? (100000.0 - delta) : -delta));
+ delta = fabs (fmod (eastMin,rK100Km));
+ beginEast = static_cast<INT32>(eastMin - ((eastMin >= 0.0) ? delta : (rK100Km - delta)));
+ delta = fabs (fmod (eastMax,rK100Km));
+ endEast = static_cast<INT32>(eastMax + ((eastMax >= 0.0) ? (rK100Km - delta) : -delta));
- delta = fabs (fmod (northMin,100000.0));
- beginNorth = static_cast<INT32>(northMin - ((northMin >= 0.0) ? delta : (100000.0 - delta)));
- delta = fabs (fmod (northMax,100000.0));
- endNorth = static_cast<INT32>(northMax + ((northMax >= 0.0) ? (100000.0 - delta) : -delta));
+ delta = fabs (fmod (northMin,rK100Km));
+ beginNorth = static_cast<INT32>(northMin - ((northMin >= 0.0) ? delta : (rK100Km - delta)));
+ delta = fabs (fmod (northMax,rK100Km));
+ endNorth = static_cast<INT32>(northMax + ((northMax >= 0.0) ? (rK100Km - delta) : -delta));
// We'll move from south to north, doing each west to east row in turn.
- for (northIndex = beginNorth;northIndex < endNorth;northIndex += 100000)
+ for (northIndex = beginNorth;northIndex < endNorth;northIndex += iK100Km)
- for (eastIndex = beginEast;eastIndex < endEast;eastIndex += 100000)
+ for (eastIndex = beginEast;eastIndex < endEast;eastIndex += iK100Km)
+ Ptr<MgCoordinate> southwest;
+ Ptr<MgCoordinate> southeast;
+ Ptr<MgCoordinate> northeast;
+ Ptr<MgCoordinate> northwest;
// Use the current eastIndex and northIndex values to generate
// a 100KM sqaure.
- southwest->SetX (static_cast<double>(eastIndex));
- southwest->SetY (static_cast<double>(northIndex));
- northeast->SetX (static_cast<double>(eastIndex + 100000));
- northeast->SetY (static_cast<double>(northIndex + 100000));
+ southwest = mgFactory.CreateCoordinateXY (static_cast<double>(eastIndex),static_cast<double>(northIndex));
+ southeast = mgFactory.CreateCoordinateXY (static_cast<double>(eastIndex + iK100Km),static_cast<double>(northIndex));
+ northeast = mgFactory.CreateCoordinateXY (static_cast<double>(eastIndex + iK100Km),static_cast<double>(northIndex + iK100Km));
+ northwest = mgFactory.CreateCoordinateXY (static_cast<double>(eastIndex),static_cast<double>(northIndex + iK100Km));
// Now we need the designation. The comes from the MgCoordinateSystemMgrs
// object that knows about the lettering scheme. Unfortunately, we don't
@@ -535,12 +545,59 @@
if (!designation.empty ())
// Construct the region object and add it to the region collection.
- pMnrRegion = new CCoordinateSystemGridRegion (designation,frameBoundary,
- gridToFrameXfrom,
- southwest,
- northeast,
- curvePrecision,
- maxPoints);
+ pMnrRegion = new CCoordinateSystemGridRegion (designation);
+ double xx = static_cast<double>(eastIndex + (iK100Km / 2));
+ double yy = static_cast<double>(northIndex + (iK100Km / 2));
+ gridToFrameXfrom->Transform (&xx,&yy);
+ Ptr<MgCoordinate> rgnCenter = mgFactory.CreateCoordinateXY (xx,yy);
+ pMnrRegion->SetRegionCenter (rgnCenter);
+ // Generate the region boundary polygon; then convert to frame coordinates.
+ rgnBoundary = csFactory.GridBoundary (southwest,northeast);
+ rgnBoundary->SetMaxCurvePoints (maxPoints);
+ Ptr<MgPolygon> rgnPolygon = rgnBoundary->GetBoundary (gridToFrameXfrom,curvePrecision);
+ pMnrRegion->SetRegionBoundary (rgnPolygon);
+ // Get a coordinate iterator which represents the grid boundary.
+ // Note, that this boundary is the Intersection of the UTM zone
+ // boundary and the viewport frame boundary.
+ Ptr<MgCoordinateSystemGridBoundary> gridBoundary = GetGridBoundary ();
+ Ptr<MgPolygon> gridPolygon = gridBoundary->GetBoundary ();
+ Ptr<MgLinearRing> gridExteriorRing = gridPolygon->GetExteriorRing ();
+ Ptr<MgCoordinateIterator> gridBoundaryItr = gridExteriorRing->GetCoordinates ();
+ // Generate the four lines.
+ swPntIsIn = MgSpatialUtility::PointIsInPolygon (gridBoundaryItr,southwest);
+ sePntIsIn = MgSpatialUtility::PointIsInPolygon (gridBoundaryItr,southeast);
+ nePntIsIn = MgSpatialUtility::PointIsInPolygon (gridBoundaryItr,northeast);
+ nwPntIsIn = MgSpatialUtility::PointIsInPolygon (gridBoundaryItr,northwest);
+ if (swPntIsIn || sePntIsIn)
+ Ptr<MgLineString> lineString = gridToFrameXfrom->GridLine (southwest,southeast,curvePrecision,maxPoints);
+ Ptr<MgLineStringCollection> rgnLine = frameBoundary->ClipLineString (lineString);
+ pMnrRegion->SetSouthLine (rgnLine);
+ if (sePntIsIn || nePntIsIn)
+ Ptr<MgLineString> lineString = gridToFrameXfrom->GridLine (southeast,northeast,curvePrecision,maxPoints);
+ pMnrRegion->SetEastLine (rgnLine);
+ if (nePntIsIn || nwPntIsIn)
+ Ptr<MgLineString> lineString = gridToFrameXfrom->GridLine (northeast,northwest,curvePrecision,maxPoints);
+ pMnrRegion->SetNorthLine (rgnLine);
+ if (nwPntIsIn || swPntIsIn)
+ Ptr<MgLineString> lineString = gridToFrameXfrom->GridLine (northwest,southwest,curvePrecision,maxPoints);
+ pMnrRegion->SetWestLine (rgnLine);
regionCollection->Add (pMnrRegion);
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysOneGrid.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSysOneGrid.cpp 2010-01-20 21:29:08 UTC (rev 4541)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysOneGrid.cpp 2010-01-20 21:32:05 UTC (rev 4542)
@@ -527,6 +527,10 @@
return SAFE_ADDREF (m_FrameBoundary.p);
+MgCoordinateSystemGridBoundary* CCoordinateSystemOneGrid::GetGridBoundary (void)
+ return SAFE_ADDREF (m_GridBoundary.p);
MgCoordinateSystem* CCoordinateSystemOneGrid::GetFrameCRS ()
return SAFE_ADDREF (m_FrameCRS.p);
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSysOneGrid.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSysOneGrid.h 2010-01-20 21:29:08 UTC (rev 4541)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSysOneGrid.h 2010-01-20 21:32:05 UTC (rev 4542)
@@ -77,6 +77,7 @@
protected:
MgCoordinateSystemGridBoundary* GetFrameBoundary (void);
+ MgCoordinateSystemGridBoundary* GetGridBoundary (void);
MgCoordinateSystem* GetFrameCRS (void);
MgCoordinateSystem* GetGridCRS (void);
MgCoordinateSystemTransform* GetGridToFrameXform (void);
More information about the mapguide-commits
