[mapguide-commits] r4550 - trunk/MgDev/Common/Geometry/CoordinateSystem
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Jan 28 15:10:43 EST 2010
Author: NormOlsen
Date: 2010-01-28 15:10:42 -0500 (Thu, 28 Jan 2010)
New Revision: 4550
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGrids.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrs.h
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridLevel.h
Trac Ticket 1251 -- Adjust source code files tso as to produce correct documentation.
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h	2010-01-28 07:19:33 UTC (rev 4549)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridOrientation.h	2010-01-28 20:10:42 UTC (rev 4550)
@@ -18,6 +18,10 @@
 #ifndef _MGCOORDINATESYSTEMGRIDORIENTATION_H_
 #define _MGCOORDINATESYSTEMGRIDORIENTATION_H_
+/// \defgroup MgCoordinateSystemGridOrientation MgCoordinateSystemGridOrientation
+/// \ingroup Coordinate_System_classes
 /// <summary>
 /// An enumeration of the supported values for the <c>m_Orientation</c> member
@@ -48,4 +52,6 @@
     static const INT8 Unknown = 3;          // indicates a failure of an algorithm
 #endif //_MGCOORDINATESYSTEMGRIDORIENTATION_H_
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h	2010-01-28 07:19:33 UTC (rev 4549)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGridSpecializationType.h	2010-01-28 20:10:42 UTC (rev 4550)
@@ -18,6 +18,10 @@
 #ifndef _MGCOORDINATESYSTEMGRIDSPECIALIZATIONTYPE_H_
 #define _MGCOORDINATESYSTEMGRIDSPECIALIZATIONTYPE_H_
+/// \defgroup MgCoordinateSystemGridSpecializationType MgCoordinateSystemGridSpecializationType
 /// <summary>
 /// An enumeration of the various types of specialized grids/graticules
@@ -52,4 +56,6 @@
     static const INT32 Unknown           = 65366;
 #endif //_MGCOORDINATESYSTEMGRIDSPECIALIZATIONTYPE_H_
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGrids.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGrids.h	2010-01-28 07:19:33 UTC (rev 4549)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemGrids.h	2010-01-28 20:10:42 UTC (rev 4550)
@@ -49,6 +49,9 @@
 class MgCoordinateSystemGridTick;               // a position in viewport coordinates and a grid value
                                                 // as a double
+/// \defgroup MgCoordinateSystemGridSpecification MgCoordinateSystemGridSpecification
 /// <summary>
@@ -666,7 +669,12 @@
 CLASS_ID:
     static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGridSpecification;
+/// \defgroup MgCoordinateSystemGridBoundary MgCoordinateSystemGridBoundary
 // External to this interface, boundary objects are always in the viewport
 // (i.e. target) coordinate system.
@@ -702,6 +710,12 @@
     static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGridBoundary;
+/// \defgroup MgCoordinateSystemGridBase MgCoordinateSystemGridBase
 // Abstract base class for all grid generation objects (generic and
 // specialized).
@@ -758,7 +772,12 @@
 CLASS_ID:
     static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGridBase;
+/// \defgroup MgCoordinateSystemGridLine MgCoordinateSystemGridLine
 // An MgCoordinateSystemGridLine object is a grid value (as a double) and a
 // collection of line strings, where each individual line string being
@@ -781,11 +800,25 @@
 CLASS_ID:
     static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGridLine;
+/// \defgroup MgCoordinateSystemGridRegion MgCoordinateSystemGridRegion
 // An MgCoordinateSystemGridRegion object consists of a label and a polygon.
 // The polygon is always in the viewport coordinate system.  Such an object
 // is used, for example, to label and delineate an MGRS 100Km UTM grid zone.
+// This API has been found to be problematical in the initial release.  It   //
+// will be deprecated in the next release.                                   //
 class MG_GEOMETRY_API MgCoordinateSystemGridRegion : public MgGuardDisposable
 PUBLISHED_API:
@@ -808,7 +841,12 @@
 CLASS_ID:
     static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGridRegion;
+/// \defgroup MgCoordinateSystemGridTick MgCoordinateSystemGridTick
 // An MgCoordinateSystemGridTick object consists of a grid value, a tick
 // location point in viewport coordinates, and a 2D unit direction vector.
@@ -831,7 +869,11 @@
 CLASS_ID:
     static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGridTick;
+/// \defgroup MgCoordinateSystemGridLineCollection MgCoordinateSystemGridLineCollection
 // An MgCoordinateSystemGridLineCollection is collection of
 // MgCoordinateSystemGridLine objects.  As manufactured, grid horizontal lines
@@ -856,7 +898,11 @@
 CLASS_ID:
     static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGridLineCollection;
+/// \defgroup MgCoordinateSystemGridRegionCollection MgCoordinateSystemGridRegionCollection
 // An MgCoordinateSystemGridRegionCollection is collection of
 // MgCoordinateSystemGridRegion objects.
@@ -876,7 +922,11 @@
 CLASS_ID:
     static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGridRegionCollection;
+/// \defgroup MgCoordinateSystemGridTickCollection MgCoordinateSystemGridTickCollection
 // An MgCoordinateSystemGridTickCollection is collection of
 // MgCoordinateSystemGridTick objects.  MgCoordinateSystemGridTickCollection
@@ -898,5 +948,6 @@
 CLASS_ID:
     static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemGridTickCollection;
 #endif //_MGCOORDINATESYSTEMGRIDS_H_
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrs.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrs.h	2010-01-28 07:19:33 UTC (rev 4549)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrs.h	2010-01-28 20:10:42 UTC (rev 4550)
@@ -18,6 +18,10 @@
 #ifndef _MGCOORDINATESYSTEMMGRS_H_
 #define _MGCOORDINATESYSTEMMGRS_H_
+/// \defgroup MgCoordinateSystemMgrs MgCoordinateSystemMgrs
 /// This object carries most, if not all, intelligence specific to the MGRS
 /// (Military Grid Reference System) grid standard.  It can be used at two
@@ -115,4 +119,6 @@
     static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemMgrs;
 #endif //_MGCOORDINATESYSTEMMGRS_H_
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridLevel.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridLevel.h	2010-01-28 07:19:33 UTC (rev 4549)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridLevel.h	2010-01-28 20:10:42 UTC (rev 4550)
@@ -18,6 +18,10 @@
 #ifndef _MGCOORDINATESYSTEMMGRSGRIDLEVEL_H_
 #define _MGCOORDINATESYSTEMMGRSGRIDLEVEL_H_
+/// \defgroup MgCoordinateSystemMgrsGridLevel MgCoordinateSystemMgrsGridLevel
 /// \brief
 /// Defines constants used to indicate the MGRS grid level
@@ -37,4 +41,6 @@
     static const INT32 MgrsUnknown = 99;
 #endif //_MGCOORDINATESYSTEMMGRSGRIDLEVEL_H_
More information about the mapguide-commits mailing list
