[mapguide-commits] r4552 - trunk/MgDev/Common/Geometry
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Jan 28 15:50:09 EST 2010
Author: NormOlsen
Date: 2010-01-28 15:50:07 -0500 (Thu, 28 Jan 2010)
New Revision: 4552
Removed:
   trunk/MgDev/Common/Geometry/CoordinateSystemMgrs.h
Trac Ticket 1251 -- Somehow or other, this file escaped the recent patch added at revision 4550.  The existence of this file at this location is bogus.
Deleted: trunk/MgDev/Common/Geometry/CoordinateSystemMgrs.h
--- trunk/MgDev/Common/Geometry/CoordinateSystemMgrs.h	2010-01-28 20:16:04 UTC (rev 4551)
+++ trunk/MgDev/Common/Geometry/CoordinateSystemMgrs.h	2010-01-28 20:50:07 UTC (rev 4552)
@@ -1,357 +0,0 @@
-// Existing stuff for reference only.
-class MG_GEOMETRY_API MgCoordinateCollection : public MgGuardDisposable
-PUBLISHED_API:
-    virtual INT32 GetCount() const;
-    virtual MgCoordinate* GetItem(INT32 index) const;
-    virtual void SetItem(INT32 index, MgCoordinate* value);
-    virtual void Add(MgCoordinate* value);
-    virtual void Insert(INT32 index, MgCoordinate* value);
-    virtual void Clear();
-    virtual bool Remove(const MgCoordinate* value);
-    virtual void RemoveAt(INT32 index);
-    virtual bool Contains(const MgCoordinate* value) const;
-    virtual INT32 IndexOf(const MgCoordinate* value) const;
-    MgCoordinateCollection();
-EXTERNAL_API:
-    virtual ~MgCoordinateCollection();
-INTERNAL_API:
-    MgCoordinateIterator* GetIterator();
-    MgCoordinateCollection* Copy();
-    virtual void ToAwkt(REFSTRING awktStr, REFSTRING coordDim, bool is2dOnly);
-protected:
-    void Dispose() { delete this; }
-private:
-    Ptr<MgDisposableCollection> m_collection;
-// New stuff for Grid/Graticule generally.
-enum EmgGridLineType { lnDirNone = 0,
-                       lnDirEastWest,
-                       lnDirNorthSouth,
-                       lnDirUnknown
-enum EmgGridLineTerm { lnTrmNone = 0,
-                       lnTrmEast,
-                       lnTrmWest,
-                       lnTrmNorth,
-                       lnTrmSouth,
-                       lnTrmInternal,
-                       lnTrmUnknown
-class MgGridCoordinateCollection : public MgCoordinateCollection
-public:
-    MgGridCoordinateCollection (EmgGridLineType lnDir,double isoValue,double chord = 0.0);
-    MgGridCoordinateCollection (const MgGridCoordinateCollection& rhs);     //???//
-    MgGridCoordinateCollection operator= (const MgGridCoordinateCollection& rhs);   //???//
-    EmgGridLineType GetLineType (void);
-    double GetIsoValue (void) const;
-    double GetChord (void) const;
-    EmgGridLineTerm FirstPoint;
-    EmgGridLineTerm LastPoint;
-private:
-    EmgGridLineType LineType;       // Essentially indicates if the IsoValue is an
-                                    // easting/longitude or a northing/latitude
-    double IsoValue;                // value represented by the line
-    double ChordValue;              // an indication of the accuracy of representation
-                                    // not really used, but will be available at
-                                    // contsruction time and cannot reconstructed.
-class MgMgrsCoordinateCollection : public MgGridCoordinateCOllection
-    MgMgrsCoordinateCollection (INT32 utmZone,wchar_t quadEast,wchar_t quadWest);
-    INT32 GetUtmZone (void);
-    STRING GetQuadDesignation (void);
-    INT32 GetMGRSLabelValue (void);
-private:
-    INT32 UtmZone;                  // 0 = invalid,
-                                    // > 0 means northern hemisphere
-                                    // < 0 means southern hemisphere
-                                    // value of 61 indicates polar region
-    wchar_t QuadDesignation [2];    // Easting portion of the Quad designation
-    wchar_t QuadNorth;              // Northing portion of the Quad Designation
-    double QuadBaseEasting;         // The base UTM easting value of the quad.
-    double QuadBaseNorthing;        // The base UTM northing value of the quad.
-//  Copyright (C) 2004-2010 by Autodesk, Inc.
-//  This library is free software; you can redistribute it and/or
-//  modify it under the terms of version 2.1 of the GNU Lesser
-//  General Public License as published by the Free Software Foundation.
-//  This library is distributed in the hope that it will be useful,
-//  but WITHOUT ANY WARRANTY; without even the implied warranty of
-//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
-//  Lesser General Public License for more details.
-//  You should have received a copy of the GNU Lesser General Public
-//  License along with this library; if not, write to the Free Software
-//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
-#ifndef _MGCOORDINATESYSTEMMGRS_H_
-#define _MGCOORDINATESYSTEMMGRS_H_
-class MgCoordinateSystemFactory : public MgGuardDisposable
-    virtual MgCoordinateSystemMgrs* GetMgrs(
-        CREFSTRING sTargetCsCode,           //system used for input and output coordinates
-        bool bUseTargetDatum,               //true to have the MGRS use the datum of pTargetCs. false to use WGS84
-        int nLetteringScheme,               //a value from MgCoordinateSystemMgrsLetteringScheme
-        bool bSetExceptionsOn);             //true to repport errors as MgExceptions. false to use MgCoordinateSystemMgrs::GetLastError
-        MgCoordinateSystem *pTargetCs,      //system used for input and output coordinates
-class MgCoordinateSystemBoundary : public MgGuardDisposable
-    virtual MgCoordinate* GetTopLeft();  //do we want to name this NorthWest????
-    virtual MgCoordinate* GetTopRight();  //do we want to name this ????
-    virtual MgCoordinate* GetBottomRight();  //do we want to name this ????
-    virtual MgCoordinate* GetBottomLeft();  //do we want to name this ????
-//defines the lines of an MGRS grid of a given precision, a value from MgCoordinateSystemMgrsPrecision
-class MgrsGridLines : public MgGuardDisposable
-    virtual INT8 GetMgrsPrecision();
-    virtual MgCoordinateCollection* GetLine(INT32 index);
-//defines the avrious grid levels of an MGRS grid
-//each entry lists all the lines of a grid of a given precision, a value from MgCoordinateSystemMgrsPrecision
-class MgCoordinateSystemMgrsGridLinesCollection : public MgGuardDisposable
-    virtual MgCoordinateSystemMgrsGridLines* GetItem(INT32 index) const;
-    virtual MgCoordinateSystemMgrsGridLines* GetItem(INT8 nMgrsPrecision) const;
-    virtual INT32 IndexOf(INT8 nMgrsPrecision) const;
-class MgCoordinateSystemMgrsTickMark : public MgGuardDisposable
-    virtual MgCoordinate* GetPosition();
-    virtual MgCoordinate* GetDirectionFromPosition();
-class MgCoordinateSystemMgrsTickMarkCollection : public MgGuardDisposable
-    virtual MgCoordinateSystemMgrsTickMark* GetItem(INT32 index) const;
-class MgCoordinateSystemMgrsLabel : public MgGuardDisposable
-    virtual MgCoordinate* GetBaseLineStart();
-    virtual MgCoordinate* GetBaseLineEnd();
-    virtual MgCoordinate* GetBaseLineAngle();
-class MgCoordinateSystemMgrsDoubleLabel : public MgCoordinateSystemMgrsLabel
-    virtual double GetValue();
-class MgCoordinateSystemMgrsTextLabel : public MgCoordinateSystemMgrsLabel
-    virtual STRING GetValue();
-class MgCoordinateSystemMgrsLabelCollection : public MgGuardDisposable
-    virtual MgCoordinateSystemMgrsLabel* GetItem(INT32 index) const;
-class MgCoordinateSystemMgrsPrecision
-PUBLISHED_API:
-    static const INT8 Graticule     = 0; //the 6 x 8 degree zones
-    static const INT8 Grid100Km     = 1; //the 100 Km squares
-    static const INT8 Grid10Km      = 2; //the 10 Km squares
-    static const INT8 Grid1Km       = 3; //the 1 Km squares
-    static const INT8 Grid100m      = 4; //the 100 m squares
-    static const INT8 Grid10m       = 5; //the 10 m squares
-    static const INT8 Grid1m        = 6; //the 1 m squares
-class MgCoordinateSystemMgrs : public MgGuardDisposable
-PUBLISHED_API:
-    virtual INT8 GetLetteringScheme()=0;
-    //section that reads/writes MGRS coordinates
-    virtual STRING ConvertFromLonLat(double dLongitude, double dLatitude, int nPrecision)=0;
-    virtual STRING ConvertFromLonLat(MgCoordinate* pLonLat, int nPrecision)=0;
-    virtual MgCoordinate* ConvertToLonLat(CREFSTRING sMgrs)=0;
-    virtual STRING ConvertFromXY(double dX, double dY, int nPrecision)=0;
-    virtual STRING ConvertFrom(MgCoordinate* pCsCoordinate, int nPrecision)=0;
-    virtual MgCoordinate* ConvertTo(CREFSTRING sMgrs)=0;
-    //error mechanism
-    virtual INT32 GetLastError()=0;
-    virtual void ResetLastError()=0;
-    virtual bool AreExceptionsOn()=0;
-    virtual void SetExceptionsOn(bool bOn)=0;
-    //grids and graticules
-    //get all the grid lines included inside the extents
-    //If multiple precisions are requested, the various grids will all be returned at once
-    //the output polylines are straight lines if the MGRS coordinate system
-    //is a UTM system and if the area of coverage is within the range of this UTM system
-    //the ouput polylines are segmented if the area of coverage is outside the range of this UTM system
-    //or if the MGRS coordinate system is not a UTM system
-    virtual MgCoordinateSystemMgrsGridLinesCollection* GetGridLines(
-        const MgCoordinateSystemBoundary& extents,                          //extents of the area of interest defined in the MGRS coordinate system
-        INT8[] nMgrsPrecision);                                             //precision of the grids, a list of values from MgCoordinateSystemMgrsPrecision
-    //get all the grid line tick marks that can positioned on the top of a given area
-    //defined in the MGRS coordinate system
-    //This method doesn't make sense for MgCoordinateSystemMgrsPrecision::Graticule and will return an empty list
-    virtual MgCoordinateSystemMgrsTickMarkCollection* GetTopTickMarks(
-        INT8 nMgrsPrecision,                                                //precision of the grids, a list of values from MgCoordinateSystemMgrsPrecision
-        INT8 nSubDivisions);                                                //number of tick marks that divide a grid square of MgCoordinateSystemMgrsPrecision
-    //get all the grid line tick marks that can positioned on the right of a given area
-    virtual MgCoordinateSystemMgrsTickMarkCollection* GetRightTickMarks(
-    //get all the grid line tick marks that can positioned on the bottom of a given area
-    virtual MgCoordinateSystemMgrsTickMarkCollection* GetBottomTickMarks(
-    virtual MgCoordinateSystemMgrsTickMarkCollection* GetLeftTickMarks(
-    //get all the grid line labels that can positioned on the outside top of a given area
-    //returns a list of MgCoordinateSystemMgrsTextLabel for MgCoordinateSystemMgrsPrecision::Graticule and MgCoordinateSystemMgrsPrecision::Grid100Km
-    //returns a list of MgCoordinateSystemMgrsDoubleLabel for other MgCoordinateSystemMgrsPrecision values
-    virtual MgCoordinateSystemMgrsLabelCollection* GetGridTopLabels(
-        INT8 nMgrsPrecision);                                               //precision of the grid to be labeled, a value from MgCoordinateSystemMgrsPrecision
-    //get all the grid line labels that can positioned on the outside right of a given area
-    virtual MgCoordinateSystemMgrsLabelCollection* GetGridRightLabels(
-    //precision of the grid to be labeled, a value from MgCoordinateSystemMgrsPrecision
-    //get all the grid line labels that can positioned on the outside bottom of a given area
-    virtual MgCoordinateSystemMgrsLabelCollection* GetGridBottomLabels(
-    //get all the grid line labels that can positioned on the outside left of a given area
-    virtual MgCoordinateSystemMgrsLabelCollection* GetGridLeftLabels(
-    //returns the labels for all the 6x8 degree graticule zones that are entirely included inside the
-    //area of interest
-    virtual MgCoordinateSystemMgrsLabelCollection* GetGraticuleWholeZoneLabels(
-        const MgCoordinateSystemBoundary& extents);                         //extents of the area of interest defined in the MGRS coordinate system
-    //returns the labels for all the intersections between four 6x8 degree graticule zones included inside the
-    virtual MgCoordinateSystemMgrsLabelCollection* GetGraticuleFourCornerLabels(
-        bool bIgnoreFourCornersOfWholeZones);                               //true if we want to ignore the 6x8 degree zones that entirely fit inside the extents
-    //returns the labels for all the 100Km squares that are entirely included inside the
-    virtual MgCoordinateSystemMgrsLabelCollection* GetGrid100KmWholeSquareLabels(
-    //returns the labels for all the intersections between four 100Km squares included inside the
-    virtual MgCoordinateSystemMgrsLabelCollection* GetGrid100KmFourCornerLabels(
-        bool bIgnoreFourCornersOfWholeZones);                               //true if we want to ignore the 100Km squares that entirely fit inside the extents
-INTERNAL_API:
-    virtual INT32 ConvertFromLonLat(double dLongitude, double dLatitude, int nPrecision, REFSTRING sMgrs)=0;
-    virtual INT32 ConvertFromLonLat(MgCoordinate* pLonLat, int nPrecision, REFSTRING sMgrs)=0;
-    virtual INT32 ConvertToLonLat(CREFSTRING sMgrs, MgCoordinate* pLonLat)=0;
-    virtual INT32 ConvertToLonLat(CREFSTRING sMgrs, double& dLongitude, double& dLatitude)=0;
-    virtual INT32 ConvertFromXY(double dX, double dY, int nPrecision, REFSTRING sMgrs)=0;
-    virtual INT32 ConvertFrom(MgCoordinate* pCsCoordinate, int nPrecision, REFSTRING sMgrs)=0;
-    virtual INT32 ConvertTo(CREFSTRING sMgrs, MgCoordinate* pCsCoordinate)=0;
-    virtual INT32 ConvertToXY(CREFSTRING sMgrs, double& dX, double& dY)=0;
-protected:
-    /// \brief
-    /// Get the class Id
-    /// \return
-    /// The integer value
-    INT32 GetClassId(){return m_cls_id;};
-CLASS_ID:
-    static const INT32 m_cls_id = CoordinateSystem_CoordinateSystemMgrs;
-#endif //_MGCOORDINATESYSTEMMGRS_H_
More information about the mapguide-commits mailing list
