[mapguide-commits] r4564 - in trunk/Tools/Maestro:
Localization/da-DK/Maestro/Strings Maestro
svn_mapguide at osgeo.org
Sat Jan 30 14:23:57 EST 2010
Author: ksgeograf
Date: 2010-01-30 14:23:57 -0500 (Sat, 30 Jan 2010)
New Revision: 4564
trunk/Tools/Maestro/Localization/da-DK/Maestro/Strings/Profiling.da-DK.resx
trunk/Tools/Maestro/Maestro/FormMain.cs
trunk/Tools/Maestro/Maestro/Profiling.Designer.cs
trunk/Tools/Maestro/Maestro/Profiling.cs
trunk/Tools/Maestro/Maestro/Profiling.resx
trunk/Tools/Maestro/Maestro/Program.cs
Maestro:
Fixed cosmetic issues with Profiling, and cleaned up the code.
Modified: trunk/Tools/Maestro/Localization/da-DK/Maestro/Strings/Profiling.da-DK.resx
--- trunk/Tools/Maestro/Localization/da-DK/Maestro/Strings/Profiling.da-DK.resx 2010-01-30 19:22:17 UTC (rev 4563)
+++ trunk/Tools/Maestro/Localization/da-DK/Maestro/Strings/Profiling.da-DK.resx 2010-01-30 19:23:57 UTC (rev 4564)
@@ -151,7 +151,7 @@
<comment>A message written in the log when profiling runtime map rendering</comment>
</data>
<data name="LogMessageRenderingScales" xml:space="preserve">
- <value>Rendering af zoomeniveauer:</value>
+ <value>Rendering af zoom niveauer:</value>
<comment>A message written in the log when profiling a scale rendering</comment>
</data>
<data name="LogMessageRuntimeLayer" xml:space="preserve">
Modified: trunk/Tools/Maestro/Maestro/FormMain.cs
--- trunk/Tools/Maestro/Maestro/FormMain.cs 2010-01-30 19:22:17 UTC (rev 4563)
+++ trunk/Tools/Maestro/Maestro/FormMain.cs 2010-01-30 19:23:57 UTC (rev 4564)
@@ -2455,7 +2455,7 @@
if (ei == null || ei.Resource == null)
return;
- Profiling dlg = new Profiling(ei.Resource, m_connection);
+ Profiling dlg = new Profiling(ei.Resource, edi.ResourceId, m_connection);
dlg.ShowDialog(this);
Modified: trunk/Tools/Maestro/Maestro/Profiling.Designer.cs
--- trunk/Tools/Maestro/Maestro/Profiling.Designer.cs 2010-01-30 19:22:17 UTC (rev 4563)
+++ trunk/Tools/Maestro/Maestro/Profiling.Designer.cs 2010-01-30 19:23:57 UTC (rev 4564)
@@ -32,6 +32,7 @@
this.panel1 = new System.Windows.Forms.Panel();
this.CancelBtn = new System.Windows.Forms.Button();
this.Results = new System.Windows.Forms.TextBox();
+ this.backgroundWorker = new System.ComponentModel.BackgroundWorker();
this.panel1.SuspendLayout();
this.SuspendLayout();
@@ -54,6 +55,14 @@
this.Results.Name = "Results";
this.Results.ReadOnly = true;
+ // backgroundWorker
+ this.backgroundWorker.WorkerReportsProgress = true;
+ this.backgroundWorker.WorkerSupportsCancellation = true;
+ this.backgroundWorker.DoWork += new System.ComponentModel.DoWorkEventHandler(this.backgroundWorker_DoWork);
+ this.backgroundWorker.RunWorkerCompleted += new System.ComponentModel.RunWorkerCompletedEventHandler(this.backgroundWorker_RunWorkerCompleted);
+ this.backgroundWorker.ProgressChanged += new System.ComponentModel.ProgressChangedEventHandler(this.backgroundWorker_ProgressChanged);
// Profiling
resources.ApplyResources(this, "$this");
@@ -77,5 +86,6 @@
private System.Windows.Forms.Panel panel1;
private System.Windows.Forms.Button CancelBtn;
private System.Windows.Forms.TextBox Results;
+ private System.ComponentModel.BackgroundWorker backgroundWorker;
\ No newline at end of file
Modified: trunk/Tools/Maestro/Maestro/Profiling.cs
--- trunk/Tools/Maestro/Maestro/Profiling.cs 2010-01-30 19:22:17 UTC (rev 4563)
+++ trunk/Tools/Maestro/Maestro/Profiling.cs 2010-01-30 19:23:57 UTC (rev 4564)
@@ -31,103 +31,38 @@
public partial class Profiling : Form
private ServerConnectionI m_connection;
- private System.Threading.Thread m_thread;
- private System.Threading.AutoResetEvent m_event;
private object m_item;
- private bool m_cancel;
- private bool m_done;
- private WriteStringDelegate m_writer;
+ private string m_resourceId;
private OSGeo.MapGuide.MaestroAPI.RuntimeClasses.RuntimeMap m_tempmap;
- public Profiling(object item, ServerConnectionI connection)
+ public Profiling(object item, string resourceId, ServerConnectionI connection)
: this()
m_connection = connection;
m_item = item;
- m_thread.Start();
+ m_resourceId = resourceId;
private Profiling()
InitializeComponent();
- m_cancel = false;
- m_done = false;
m_tempmap = null;
- m_writer = new WriteStringDelegate(WriteString);
- m_event = new System.Threading.AutoResetEvent(false);
- m_thread = new System.Threading.Thread(new System.Threading.ThreadStart(RunThread));
- m_thread.IsBackground = true;
- private void RunThread()
- m_event.WaitOne();
- if (m_item as FeatureSource != null)
- ProfileFeatureSource(m_item as FeatureSource);
- else if (m_item as LayerDefinition != null)
- ProfileLayerDefinition(m_item as LayerDefinition);
- else if (m_item as MapDefinition != null)
- ProfileMapDefinition(m_item as MapDefinition);
- else
- WriteString(Strings.Profiling.LogMessageUnsupportedResourceType);
- SignalDone();
- private delegate void SignalDoneDelegate();
- private void SignalDone()
- if (this.InvokeRequired)
- this.Invoke(new SignalDoneDelegate(SignalDone));
- else
- CancelBtn.Text = Strings.Profiling.CloseButtonText;
- WriteString(Strings.Profiling.LogMessageDone);
- m_done = true;
- private delegate void WriteStringDelegate(string text);
- private void WriteString(string text)
- this.Invoke(new WriteStringDelegate(WriteString), text);
- else
- bool scroll = Math.Abs((Results.SelectionStart + Results.SelectionLength) - Results.Text.Length) < 20;
- Results.Text += text + "\r\n";
- if (scroll)
- Results.SelectionLength = 0;
- Results.SelectionStart = Results.Text.Length;
- Results.ScrollToCaret();
private void CancelBtn_Click(object sender, EventArgs e)
- if (m_done)
+ if (!backgroundWorker.IsBusy)
this.Close();
- else
- m_cancel = true;
+ else if (!backgroundWorker.CancellationPending)
+ backgroundWorker.CancelAsync();
private void ProfileFeatureSource(FeatureSource fs)
- m_writer(string.Format(Strings.Profiling.LogMessageFeatureSource, fs.ResourceId));
+ string resourceId = fs == m_item ? m_resourceId : fs.ResourceId;
+ backgroundWorker.ReportProgress(0, (string.Format(Strings.Profiling.LogMessageFeatureSource, resourceId)));
private void SetTempLayer(string resourceId)
@@ -171,13 +106,15 @@
private void ProfileLayerDefinition(LayerDefinition ldef)
- if (m_cancel)
+ if (backgroundWorker.CancellationPending)
return;
+ string resourceId = ldef == m_item ? m_resourceId : ldef.ResourceId;
MakeTempMap();
- m_writer(string.Format(Strings.Profiling.LogMessageLayerDefinition, ldef.ResourceId));
- using (new Timer(Strings.Profiling.LogMessageRuntimeLayer, m_writer))
+ backgroundWorker.ReportProgress(0, (string.Format(Strings.Profiling.LogMessageLayerDefinition, resourceId)));
+ using (new Timer(Strings.Profiling.LogMessageRuntimeLayer, backgroundWorker))
try
@@ -190,8 +127,11 @@
mdef.Layers.Add(mltype);
m_connection.ResetFeatureSourceSchemaCache();
+ return;
OSGeo.MapGuide.MaestroAPI.RuntimeClasses.RuntimeMap map = new OSGeo.MapGuide.MaestroAPI.RuntimeClasses.RuntimeMap(mdef);
- using (new Timer(Strings.Profiling.LogMessageIdentifyFetching, m_writer))
+ using (new Timer(Strings.Profiling.LogMessageIdentifyFetching, backgroundWorker))
//map.Layers[0].Parent = map;
map.Layers[0].Visible = true;
@@ -200,114 +140,163 @@
catch (Exception ex)
- m_writer(string.Format(Strings.Profiling.LayerDefinitionProfilingError, ldef.ResourceId, ex.Message));
+ backgroundWorker.ReportProgress(0, (string.Format(Strings.Profiling.LayerDefinitionProfilingError, resourceId, ex.Message)));
- LayerDefinition lx = (LayerDefinition)Utility.XmlDeepCopy(ldef);
- if (lx.Item as VectorLayerDefinitionType != null || lx.Item as GridLayerDefinitionType != null)
+ return;
+ LayerDefinition lx = (LayerDefinition)Utility.XmlDeepCopy(ldef);
+ if (lx.Item as VectorLayerDefinitionType != null || lx.Item as GridLayerDefinitionType != null)
+ using (new Timer(Strings.Profiling.LogMessageRenderingScales, backgroundWorker))
- using (new Timer(Strings.Profiling.LogMessageRenderingScales, m_writer))
+ if (lx.Item as VectorLayerDefinitionType != null)
- if (lx.Item as VectorLayerDefinitionType != null)
+ VectorLayerDefinitionType vlx = lx.Item as VectorLayerDefinitionType;
+ VectorScaleRangeTypeCollection ranges = vlx.VectorScaleRange;
+ foreach (VectorScaleRangeType vsr in ranges)
- VectorLayerDefinitionType vlx = lx.Item as VectorLayerDefinitionType;
- VectorScaleRangeTypeCollection ranges = vlx.VectorScaleRange;
+ return;
- foreach (VectorScaleRangeType vsr in ranges)
+ string tmp1 = new ResourceIdentifier(Guid.NewGuid().ToString(), ResourceTypes.LayerDefiniton, m_connection.SessionID);
+ try
- string tmp1 = new ResourceIdentifier(Guid.NewGuid().ToString(), ResourceTypes.LayerDefiniton, m_connection.SessionID);
+ double minscale = vsr.MinScaleSpecified ? vsr.MinScale : 0;
+ double maxscale = vsr.MaxScaleSpecified ? vsr.MaxScale : 10000000;
- try
- double minscale = vsr.MinScaleSpecified ? vsr.MinScale : 0;
- double maxscale = vsr.MaxScaleSpecified ? vsr.MaxScale : 10000000;
+ vlx.VectorScaleRange = new VectorScaleRangeTypeCollection();
+ vsr.MaxScaleSpecified = false;
+ vsr.MinScaleSpecified = false;
+ vlx.VectorScaleRange.Add(vsr);
- vlx.VectorScaleRange = new VectorScaleRangeTypeCollection();
- vsr.MaxScaleSpecified = false;
- vsr.MinScaleSpecified = false;
- vlx.VectorScaleRange.Add(vsr);
+ m_connection.SaveResourceAs(lx, tmp1);
- m_connection.SaveResourceAs(lx, tmp1);
+ return;
+ OSGeo.MapGuide.MaestroAPI.FdoSpatialContextList lst = m_connection.GetSpatialContextInfo(vlx.ResourceId, false);
- OSGeo.MapGuide.MaestroAPI.FdoSpatialContextList lst = m_connection.GetSpatialContextInfo(vlx.ResourceId, false);
+ if (lst.SpatialContext != null && lst.SpatialContext.Count >= 1)
+ m_tempmap.CoordinateSystem = lst.SpatialContext[0].CoordinateSystemWkt;
+ if (string.IsNullOrEmpty(m_tempmap.CoordinateSystem))
+ m_tempmap.CoordinateSystem = @"LOCAL_CS[""*XY-M*"", LOCAL_DATUM[""*X-Y*"", 10000], UNIT[""Meter"", 1], AXIS[""X"", EAST], AXIS[""Y"", NORTH]]";
+ m_tempmap.Extents = new OSGeo.MapGuide.MaestroAPI.Box2DType();
+ m_tempmap.Extents.MinX = double.Parse(lst.SpatialContext[0].Extent.LowerLeftCoordinate.X, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture);
+ m_tempmap.Extents.MinY = double.Parse(lst.SpatialContext[0].Extent.LowerLeftCoordinate.Y, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture); ;
+ m_tempmap.Extents.MaxX = double.Parse(lst.SpatialContext[0].Extent.UpperRightCoordinate.X, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture); ;
+ m_tempmap.Extents.MaxY = double.Parse(lst.SpatialContext[0].Extent.UpperRightCoordinate.Y, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture); ;
- if (lst.SpatialContext != null && lst.SpatialContext.Count >= 1)
- m_tempmap.CoordinateSystem = lst.SpatialContext[0].CoordinateSystemWkt;
- if (string.IsNullOrEmpty(m_tempmap.CoordinateSystem))
- m_tempmap.CoordinateSystem = @"LOCAL_CS[""*XY-M*"", LOCAL_DATUM[""*X-Y*"", 10000], UNIT[""Meter"", 1], AXIS[""X"", EAST], AXIS[""Y"", NORTH]]";
- m_tempmap.Extents = new OSGeo.MapGuide.MaestroAPI.Box2DType();
- m_tempmap.Extents.MinX = double.Parse(lst.SpatialContext[0].Extent.LowerLeftCoordinate.X, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture);
- m_tempmap.Extents.MinY = double.Parse(lst.SpatialContext[0].Extent.LowerLeftCoordinate.Y, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture); ;
- m_tempmap.Extents.MaxX = double.Parse(lst.SpatialContext[0].Extent.UpperRightCoordinate.X, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture); ;
- m_tempmap.Extents.MaxY = double.Parse(lst.SpatialContext[0].Extent.UpperRightCoordinate.Y, System.Globalization.NumberStyles.Float, System.Globalization.CultureInfo.InvariantCulture); ;
+ SetTempLayer(tmp1);
+ m_connection.SaveRuntimeMap(m_tempmap.ResourceID, m_tempmap);
- SetTempLayer(tmp1);
- m_connection.SaveRuntimeMap(m_tempmap.ResourceID, m_tempmap);
+ return;
- using (new Timer(string.Format(Strings.Profiling.LogMessageScaleRange, minscale, maxscale), m_writer))
- //TODO: Use extents rather than scale
- //using (System.IO.Stream s = m_connection.RenderRuntimeMap(tmp2, m.Extents, 1024, 800, 96))
- using (System.IO.Stream s = m_connection.RenderRuntimeMap(m_tempmap.ResourceID, ((m_tempmap.Extents.MaxX - m_tempmap.Extents.MinX) / 2) + m_tempmap.Extents.MinX, ((m_tempmap.Extents.MaxY - m_tempmap.Extents.MinY) / 2) + m_tempmap.Extents.MinY, 50000, 1024, 800, 96))
- new Bitmap(s).Dispose();
- finally
+ using (new Timer(string.Format(Strings.Profiling.LogMessageScaleRange, minscale, maxscale), backgroundWorker))
- try { m_connection.DeleteResource(tmp1); }
- catch { }
+ //TODO: Use extents rather than scale
+ //using (System.IO.Stream s = m_connection.RenderRuntimeMap(tmp2, m.Extents, 1024, 800, 96))
+ using (System.IO.Stream s = m_connection.RenderRuntimeMap(m_tempmap.ResourceID, ((m_tempmap.Extents.MaxX - m_tempmap.Extents.MinX) / 2) + m_tempmap.Extents.MinX, ((m_tempmap.Extents.MaxY - m_tempmap.Extents.MinY) / 2) + m_tempmap.Extents.MinY, 50000, 1024, 800, 96))
+ new Bitmap(s).Dispose();
+ finally
+ try { m_connection.DeleteResource(tmp1); }
+ catch { }
- m_writer("\r\n");
+ return;
+ backgroundWorker.ReportProgress(0, ("\r\n"));
private void ProfileMapDefinition(MapDefinition mdef)
- m_writer(string.Format(Strings.Profiling.LogMessageMapDefinition, mdef.ResourceId));
+ return;
- using(new Timer(Strings.Profiling.LogMessageRuntimeMap, m_writer))
+ string resourceId = mdef == m_item ? m_resourceId : mdef.ResourceId;
+ backgroundWorker.ReportProgress(0, (string.Format(Strings.Profiling.LogMessageMapDefinition, resourceId)));
+ using (new Timer(Strings.Profiling.LogMessageRuntimeMap, backgroundWorker))
foreach (MapLayerType ml in mdef.Layers)
try
+ return;
LayerDefinition ldef = mdef.CurrentConnection.GetLayerDefinition(ml.ResourceId);
ProfileLayerDefinition(ldef);
- m_writer(string.Format(Strings.Profiling.LayerDefinitionProfilingError, ml.ResourceId, ex.Message));
+ backgroundWorker.ReportProgress(0, (string.Format(Strings.Profiling.LayerDefinitionProfilingError, ml.ResourceId, ex.Message)));
- if (m_cancel)
+ if (mdef.BaseMapDefinition != null && mdef.BaseMapDefinition.BaseMapLayerGroup != null)
+ foreach (BaseMapLayerGroupCommonType g in mdef.BaseMapDefinition.BaseMapLayerGroup)
+ if (g.BaseMapLayer != null)
+ foreach (BaseMapLayerType ml in g.BaseMapLayer)
+ try
+ return;
+ LayerDefinition ldef = mdef.CurrentConnection.GetLayerDefinition(ml.ResourceId);
+ ProfileLayerDefinition(ldef);
+ catch (Exception ex)
return;
try
+ return;
- using (new Timer(Strings.Profiling.LogMessageRuntimeMapTotal, m_writer))
+ using (new Timer(Strings.Profiling.LogMessageRuntimeMapTotal, backgroundWorker))
- m_writer(string.Format(Strings.Profiling.RuntimeMapProfilingError, mdef.ResourceId, ex.Message));
+ backgroundWorker.ReportProgress(0, (string.Format(Strings.Profiling.RuntimeMapProfilingError, resourceId, ex.Message)));
string tmp2 = new ResourceIdentifier(Guid.NewGuid().ToString(), ResourceTypes.RuntimeMap, m_connection.SessionID);
try
+ return;
m_connection.CreateRuntimeMap(tmp2, mdef);
- using (new Timer(Strings.Profiling.LogMessageRenderingMap, m_writer))
+ using (new Timer(Strings.Profiling.LogMessageRenderingMap, backgroundWorker))
//using (System.IO.Stream s = m_connection.RenderRuntimeMap(tmp2, mdef.Extents, 1024, 800, 96))
@@ -320,7 +309,7 @@
- m_writer(string.Format(Strings.Profiling.MapRenderingError, mdef.ResourceId, ex.Message));
+ backgroundWorker.ReportProgress(0, (string.Format(Strings.Profiling.MapRenderingError, resourceId, ex.Message)));
finally
@@ -335,14 +324,14 @@
private string m_text;
private bool m_isDisposed;
private DateTime m_begin;
+ private BackgroundWorker m_worker;
- public Timer(string text, WriteStringDelegate writer)
+ public Timer(string text, BackgroundWorker worker)
m_begin = DateTime.Now;
m_isDisposed = false;
m_text = text;
- m_writer = writer;
+ m_worker = worker;
#region IDisposable Members
@@ -353,8 +342,8 @@
TimeSpan ts = DateTime.Now - m_begin;
m_isDisposed = true;
- m_writer(m_text + ts.Minutes.ToString("00") + ":" + ts.Seconds.ToString("00") + "." + ts.Milliseconds.ToString("000"));
- m_writer = null;
+ m_worker.ReportProgress(0, (m_text + ts.Minutes.ToString("00") + ":" + ts.Seconds.ToString("00") + "." + ts.Milliseconds.ToString("000")));
+ m_worker = null;
m_text = null;
@@ -364,14 +353,66 @@
private void Profiling_Load(object sender, EventArgs e)
- m_event.Set();
+ backgroundWorker.RunWorkerAsync();
private void Profiling_FormClosing(object sender, FormClosingEventArgs e)
- if (e.CloseReason == CloseReason.UserClosing)
- m_cancel = true;
+ if (backgroundWorker.IsBusy)
+ e.Cancel = true;
+ if (!backgroundWorker.CancellationPending)
+ private void backgroundWorker_DoWork(object sender, DoWorkEventArgs e)
+ if (m_item as FeatureSource != null)
+ ProfileFeatureSource(m_item as FeatureSource);
+ else if (m_item as LayerDefinition != null)
+ ProfileLayerDefinition(m_item as LayerDefinition);
+ else if (m_item as MapDefinition != null)
+ ProfileMapDefinition(m_item as MapDefinition);
+ else
+ backgroundWorker.ReportProgress(0, Strings.Profiling.LogMessageUnsupportedResourceType);
+ private void backgroundWorker_RunWorkerCompleted(object sender, RunWorkerCompletedEventArgs e)
+ CancelBtn.Text = Strings.Profiling.CloseButtonText;
+ WriteString(Strings.Profiling.LogMessageDone);
+ private void WriteString(string message)
+ if (string.IsNullOrEmpty(message))
+ return;
+ bool scroll = Math.Abs((Results.SelectionStart + Results.SelectionLength) - Results.Text.Length) < 20;
+ Results.Text += message + "\r\n";
+ if (scroll)
+ Results.SelectionLength = 0;
+ Results.SelectionStart = Results.Text.Length;
+ Results.ScrollToCaret();
+ private void backgroundWorker_ProgressChanged(object sender, ProgressChangedEventArgs e)
+ WriteString(e.UserState as string);
Modified: trunk/Tools/Maestro/Maestro/Profiling.resx
--- trunk/Tools/Maestro/Maestro/Profiling.resx 2010-01-30 19:22:17 UTC (rev 4563)
+++ trunk/Tools/Maestro/Maestro/Profiling.resx 2010-01-30 19:23:57 UTC (rev 4564)
@@ -201,6 +201,9 @@
<data name=">>Results.ZOrder" xml:space="preserve">
<value>0</value>
</data>
+ <metadata name="backgroundWorker.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
<metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
@@ -216,6 +219,12 @@
<data name="$this.Text" xml:space="preserve">
<value>Profiling</value>
</data>
+ <data name=">>backgroundWorker.Name" xml:space="preserve">
+ <value>backgroundWorker</value>
+ </data>
+ <data name=">>backgroundWorker.Type" xml:space="preserve">
+ <value>System.ComponentModel.BackgroundWorker, System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
<data name=">>$this.Name" xml:space="preserve">
</data>
Modified: trunk/Tools/Maestro/Maestro/Program.cs
--- trunk/Tools/Maestro/Maestro/Program.cs 2010-01-30 19:22:17 UTC (rev 4563)
+++ trunk/Tools/Maestro/Maestro/Program.cs 2010-01-30 19:23:57 UTC (rev 4564)
@@ -30,32 +30,8 @@
[STAThread()]
public static void Main(string[] args)
- //System.Text.RegularExpressions.Regex m_filenameTransformer = new System.Text.RegularExpressions.Regex(@"[^A-Za-z0-9\.-\/]");
- //System.Text.RegularExpressions.Match m = m_filenameTransformer.Match("xx���");
+ //MaestroAPI.HttpServerConnection con = new OSGeo.MapGuide.MaestroAPI.HttpServerConnection(new Uri("http://localhost/mapguide"), "Administrator", "admin", "da", true);
- /*MaestroAPI.HttpServerConnection con = new OSGeo.MapGuide.MaestroAPI.HttpServerConnection(new Uri("http://localhost:8008/mapguide"), "Administrator", "admin", "da", true);
- con.CreateRuntimeMap("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
- MaestroAPI.MapLayerType mlt = new OSGeo.MapGuide.MaestroAPI.MapLayerType();
- mlt.ResourceId = "Library://Samples/Sheboygan/Layers/Buildings.LayerDefinition";
- mlt.Parent = con.GetMapDefinition("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
- MaestroAPI.RuntimeClasses.RuntimeMapLayer rml = new OSGeo.MapGuide.MaestroAPI.RuntimeClasses.RuntimeMapLayer(mlt);*/
- //MaestroAPI.FeatureSetReader fs = con.QueryFeatureSource("Library://JammerbugtGrundsalg/sqlite.FeatureSource", "Grunde", null, new string[] { "ID" });
- //fs.Read();
- //MaestroAPI.LayerDefinition ldef = con.CreateResourceObject<MaestroAPI.LayerDefinition>();
- /*MaestroAPI.ResourceIdentifier ri = new OSGeo.MapGuide.MaestroAPI.ResourceIdentifier("Library://folder/");
- string s = ri.Folder;
- ri.Folder = "xfolder";
- ri.Folder = "Library://yfolder";
- ri = new OSGeo.MapGuide.MaestroAPI.ResourceIdentifier("Library://folder/mapdef.LayerDefinition");
- ri.Folder = "";
- ri = new OSGeo.MapGuide.MaestroAPI.ResourceIdentifier("Library://");
- s = ri.Folder;*/
try
Application.EnableVisualStyles();
More information about the mapguide-commits
