[mapguide-commits] r5001 - in sandbox/maestro-3.0: Generated
Maestro.Base Maestro.Base/Editor Maestro.Base/Services
Maestro.Base/UI Maestro.Editors/DrawingSource
Maestro.Editors/MapDefinition OSGeo.MapGuide.MaestroAPI
svn_mapguide at osgeo.org
Wed Jul 7 05:30:03 EDT 2010
Author: jng
Date: 2010-07-07 09:30:03 +0000 (Wed, 07 Jul 2010)
New Revision: 5001
Added:
sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.cs
sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.resx
sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.resx
sandbox/maestro-3.0/Generated/MapDefinition-1.0.0.designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.cs
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs
sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.cs
sandbox/maestro-3.0/Maestro.Editors/DrawingSource/DrawingSourceEditorCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ResourceTypeRegistry.cs
This submission includes the following changes:
- Add missing MapDefinition serializer to ResourceTypeRegistry
- Add top-level DrawingSourceEditor control
- Activate editors for MapDefinition and DrawingSource resource types
- Implement data-binding for MapDefinition editor (map settings)
- Tweak the visual layout of items in New Resource dialog
- Remove generated INotifyPropertyChanged code from MapDefinition which was shadowing the identical code in its superclass.
Modified: sandbox/maestro-3.0/Generated/MapDefinition-1.0.0.designer.cs
--- sandbox/maestro-3.0/Generated/MapDefinition-1.0.0.designer.cs 2010-07-07 08:23:07 UTC (rev 5000)
+++ sandbox/maestro-3.0/Generated/MapDefinition-1.0.0.designer.cs 2010-07-07 09:30:03 UTC (rev 5001)
@@ -35,7 +35,7 @@
return serializer;
public event System.ComponentModel.PropertyChangedEventHandler PropertyChanged;
public virtual void OnPropertyChanged(string info) {
@@ -43,7 +43,7 @@
if ((handler != null)) {
handler(this, new System.ComponentModel.PropertyChangedEventArgs(info));
#region Serialize/Deserialize
/// <summary>
Added: sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.Designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.Designer.cs 2010-07-07 09:30:03 UTC (rev 5001)
@@ -0,0 +1,61 @@
+namespace Maestro.Base.Editor
+ partial class DrawingSourceEditor
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Component Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.dsEditorCtrl = new Maestro.Editors.DrawingSource.DrawingSourceEditorCtrl();
+ this.panelBody.SuspendLayout();
+ this.SuspendLayout();
+ // panelBody
+ this.panelBody.Controls.Add(this.dsEditorCtrl);
+ // dsEditorCtrl
+ this.dsEditorCtrl.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.dsEditorCtrl.Location = new System.Drawing.Point(0, 0);
+ this.dsEditorCtrl.Name = "dsEditorCtrl";
+ this.dsEditorCtrl.Size = new System.Drawing.Size(614, 520);
+ this.dsEditorCtrl.TabIndex = 0;
+ // DrawingSourceEditor
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.Name = "DrawingSourceEditor";
+ this.panelBody.ResumeLayout(false);
+ this.ResumeLayout(false);
+ #endregion
+ private Maestro.Editors.DrawingSource.DrawingSourceEditorCtrl dsEditorCtrl;
Added: sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.cs 2010-07-07 09:30:03 UTC (rev 5001)
@@ -0,0 +1,68 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Drawing;
+using System.Data;
+using System.Text;
+using System.Windows.Forms;
+using ICSharpCode.Core;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using Maestro.Editors;
+ public partial class DrawingSourceEditor : EditorContentBase
+ public DrawingSourceEditor()
+ InitializeComponent();
+ private IResource _res;
+ private IEditorService _edsvc;
+ protected override void Bind(IEditorService service)
+ _edsvc = service;
+ _res = _edsvc.GetEditedResource();
+ _edsvc.BeforeSave += new CancelEventHandler(OnBeforeSave);
+ dsEditorCtrl.Bind(service);
+ void OnBeforeSave(object sender, CancelEventArgs e)
+ //We've been editing an in-memory model of the session copy
+ //so we need to save this model back to the session copy before Save()
+ //commits the changes back to the original resource
+ try
+ _edsvc.UpdateResourceContent(_res.Serialize());
+ e.Cancel = false;
+ catch (Exception ex)
+ MessageService.ShowError(ex);
+ e.Cancel = true;
Added: sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.resx
--- sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/DrawingSourceEditor.resx 2010-07-07 09:30:03 UTC (rev 5001)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+</root>
\ No newline at end of file
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.Designer.cs 2010-07-07 08:23:07 UTC (rev 5000)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.Designer.cs 2010-07-07 09:30:03 UTC (rev 5001)
@@ -28,10 +28,35 @@
/// </summary>
- components = new System.ComponentModel.Container();
+ this.mapEditorCtrl = new Maestro.Editors.MapDefinition.MapDefinitionEditorCtrl();
+ // panelBody
+ this.panelBody.Controls.Add(this.mapEditorCtrl);
+ // mapEditorCtrl
+ this.mapEditorCtrl.AutoScroll = true;
+ this.mapEditorCtrl.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.mapEditorCtrl.Location = new System.Drawing.Point(0, 0);
+ this.mapEditorCtrl.Name = "mapEditorCtrl";
+ this.mapEditorCtrl.Size = new System.Drawing.Size(614, 520);
+ this.mapEditorCtrl.TabIndex = 0;
+ // MapDefinitionEditor
+ this.Name = "MapDefinitionEditor";
#endregion
+ private Maestro.Editors.MapDefinition.MapDefinitionEditorCtrl mapEditorCtrl;
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.cs 2010-07-07 08:23:07 UTC (rev 5000)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.cs 2010-07-07 09:30:03 UTC (rev 5001)
@@ -24,6 +24,9 @@
using System.Data;
using System.Text;
@@ -34,9 +37,32 @@
- protected override void Bind(Maestro.Editors.IEditorService service)
+ _edsvc = service;
+ mapEditorCtrl.Bind(service);
+ try
+ e.Cancel = false;
+ e.Cancel = true;
Added: sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.resx
--- sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/MapDefinitionEditor.resx 2010-07-07 09:30:03 UTC (rev 5001)
@@ -0,0 +1,120 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+</root>
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-07-07 08:23:07 UTC (rev 5000)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-07-07 09:30:03 UTC (rev 5001)
@@ -3,7 +3,7 @@
<PropertyGroup>
<Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
<Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
- <ProductVersion>9.0.21022</ProductVersion>
+ <ProductVersion>9.0.30729</ProductVersion>
<SchemaVersion>2.0</SchemaVersion>
<ProjectGuid>{F1E2F468-5030-4DBA-968C-9620284AFAA1}</ProjectGuid>
<OutputType>Library</OutputType>
@@ -72,6 +72,12 @@
<Compile Include="Commands\Toggle\ToggleMessagesCommand.cs" />
<Compile Include="Commands\ValidateResourceCommand.cs" />
<Compile Include="Commands\XmlEditCommand.cs" />
+ <Compile Include="Editor\DrawingSourceEditor.cs">
+ <SubType>UserControl</SubType>
+ </Compile>
+ <Compile Include="Editor\DrawingSourceEditor.Designer.cs">
+ <DependentUpon>DrawingSourceEditor.cs</DependentUpon>
+ </Compile>
<Compile Include="Editor\FeatureSourceEditor.cs">
</Compile>
@@ -264,6 +270,9 @@
<None Include="Resources\MapGuide Maestro.ico" />
</ItemGroup>
<ItemGroup>
+ <EmbeddedResource Include="Editor\DrawingSourceEditor.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="Editor\EditorContentBase.resx">
<DependentUpon>EditorContentBase.cs</DependentUpon>
<SubType>Designer</SubType>
@@ -280,6 +289,9 @@
<DependentUpon>LoadProcedureEditor.cs</DependentUpon>
</EmbeddedResource>
+ <EmbeddedResource Include="Editor\MapDefinitionEditor.resx">
+ <DependentUpon>MapDefinitionEditor.cs</DependentUpon>
<EmbeddedResource Include="Editor\WebLayoutEditor.resx">
<DependentUpon>WebLayoutEditor.cs</DependentUpon>
Modified: sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs 2010-07-07 08:23:07 UTC (rev 5000)
+++ sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs 2010-07-07 09:30:03 UTC (rev 5001)
@@ -106,6 +106,7 @@
case ResourceTypes.ApplicationDefinition:
break;
case ResourceTypes.DrawingSource:
+ ed = svc.OpenContent<DrawingSourceEditor>(ViewRegion.Document);
break;
case ResourceTypes.FeatureSource:
ed = svc.OpenContent<FeatureSourceEditor>(ViewRegion.Document);
@@ -117,7 +118,7 @@
ed = svc.OpenContent<LoadProcedureEditor>(ViewRegion.Document);
break;
case ResourceTypes.MapDefinition:
- //ed = svc.OpenContent<MapDefinitionEditor>(ViewRegion.Document);
+ ed = svc.OpenContent<MapDefinitionEditor>(ViewRegion.Document);
break;
case ResourceTypes.PrintLayout:
//ed = svc.OpenContent<PrintLayoutEditor>(ViewRegion.Document);
Modified: sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.Designer.cs 2010-07-07 08:23:07 UTC (rev 5000)
+++ sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.Designer.cs 2010-07-07 09:30:03 UTC (rev 5001)
@@ -52,7 +52,7 @@
this.lstTemplates.Size = new System.Drawing.Size(433, 225);
this.lstTemplates.TabIndex = 0;
this.lstTemplates.UseCompatibleStateImageBehavior = false;
- this.lstTemplates.View = System.Windows.Forms.View.SmallIcon;
+ this.lstTemplates.View = System.Windows.Forms.View.Tile;
this.lstTemplates.SelectedIndexChanged += new System.EventHandler(this.lstTemplates_SelectedIndexChanged);
// lstCategories
Modified: sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.cs 2010-07-07 08:23:07 UTC (rev 5000)
+++ sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.cs 2010-07-07 09:30:03 UTC (rev 5001)
@@ -41,10 +41,14 @@
private IResourceService _resSvc;
private NewItemTemplateService _nits;
- public NewResourceDialog(IResourceService resSvc, NewItemTemplateService nits) : this()
+ public NewResourceDialog(IResourceService resSvc, NewItemTemplateService nits) : this(resSvc, nits, "Library://") { }
+ public NewResourceDialog(IResourceService resSvc, NewItemTemplateService nits, string startPoint) : this()
_resSvc = resSvc;
_nits = nits;
+ txtParentFolder.Text = startPoint;
protected override void OnLoad(EventArgs e)
@@ -105,6 +109,7 @@
lstTemplates.Items.Add(li);
lstTemplates.SmallImageList = tplImgList;
+ lstTemplates.LargeImageList = tplImgList;
private void lstTemplates_SelectedIndexChanged(object sender, EventArgs e)
Modified: sandbox/maestro-3.0/Maestro.Editors/DrawingSource/DrawingSourceEditorCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/DrawingSource/DrawingSourceEditorCtrl.cs 2010-07-07 08:23:07 UTC (rev 5000)
+++ sandbox/maestro-3.0/Maestro.Editors/DrawingSource/DrawingSourceEditorCtrl.cs 2010-07-07 09:30:03 UTC (rev 5001)
@@ -27,7 +27,7 @@
namespace Maestro.Editors.DrawingSource
- public partial class DrawingSourceEditorCtrl : UserControl
+ public partial class DrawingSourceEditorCtrl : EditorBase
public DrawingSourceEditorCtrl()
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.cs 2010-07-07 08:23:07 UTC (rev 5000)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapDefinitionEditorCtrl.cs 2010-07-07 09:30:03 UTC (rev 5001)
@@ -27,11 +27,21 @@
namespace Maestro.Editors.MapDefinition
- public partial class MapDefinitionEditorCtrl : UserControl
+ public partial class MapDefinitionEditorCtrl : EditorBase
public MapDefinitionEditorCtrl()
+ private OSGeo.MapGuide.ObjectModels.MapDefinition.MapDefinition _map;
+ public override void Bind(IEditorService service)
+ _map = service.GetEditedResource() as OSGeo.MapGuide.ObjectModels.MapDefinition.MapDefinition;
+ mapSettingsSectionCtrl1.Bind(service);
+ mapLayersSectionCtrl1.Bind(service);
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs 2010-07-07 08:23:07 UTC (rev 5000)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs 2010-07-07 09:30:03 UTC (rev 5001)
@@ -29,11 +29,23 @@
[ToolboxItem(true)]
- internal partial class MapLayersSectionCtrl : CollapsiblePanel
+ internal partial class MapLayersSectionCtrl : CollapsiblePanel, IEditorBindable
public MapLayersSectionCtrl()
+ public void Bind(IEditorService service)
+ service.RegisterCustomNotifier(this);
+ _map = (OSGeo.MapGuide.ObjectModels.MapDefinition.MapDefinition)service.GetEditedResource();
+ public event EventHandler ResourceChanged;
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.Designer.cs 2010-07-07 08:23:07 UTC (rev 5000)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.Designer.cs 2010-07-07 09:30:03 UTC (rev 5001)
@@ -45,8 +45,8 @@
this.label9 = new System.Windows.Forms.Label();
this.txtDescription = new System.Windows.Forms.TextBox();
this.txtCoordinateSystem = new System.Windows.Forms.TextBox();
+ this.btnPickCs = new System.Windows.Forms.Button();
this.cmbBackgroundColor = new Maestro.Editors.Common.ColorComboBox();
- this.btnPickCs = new System.Windows.Forms.Button();
this.contentPanel.SuspendLayout();
this.groupBox2.SuspendLayout();
@@ -226,14 +226,6 @@
this.txtCoordinateSystem.Size = new System.Drawing.Size(371, 20);
this.txtCoordinateSystem.TabIndex = 6;
- // cmbBackgroundColor
- this.cmbBackgroundColor.FormattingEnabled = true;
- this.cmbBackgroundColor.Location = new System.Drawing.Point(143, 58);
- this.cmbBackgroundColor.Name = "cmbBackgroundColor";
- this.cmbBackgroundColor.Size = new System.Drawing.Size(121, 21);
- this.cmbBackgroundColor.TabIndex = 7;
// btnPickCs
this.btnPickCs.Location = new System.Drawing.Point(520, 30);
@@ -242,7 +234,16 @@
this.btnPickCs.TabIndex = 8;
this.btnPickCs.Text = "...";
this.btnPickCs.UseVisualStyleBackColor = true;
+ this.btnPickCs.Click += new System.EventHandler(this.btnPickCs_Click);
+ // cmbBackgroundColor
+ this.cmbBackgroundColor.FormattingEnabled = true;
+ this.cmbBackgroundColor.Location = new System.Drawing.Point(143, 58);
+ this.cmbBackgroundColor.Name = "cmbBackgroundColor";
+ this.cmbBackgroundColor.Size = new System.Drawing.Size(121, 21);
+ this.cmbBackgroundColor.TabIndex = 7;
// MapSettingsSectionCtrl
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs 2010-07-07 08:23:07 UTC (rev 5000)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs 2010-07-07 09:30:03 UTC (rev 5001)
@@ -25,15 +25,78 @@
using System.Text;
using Maestro.Shared.UI;
+using Maestro.Editors.Common;
[ToolboxItem(true)]
- internal partial class MapSettingsSectionCtrl : CollapsiblePanel
+ internal partial class MapSettingsSectionCtrl : CollapsiblePanel, IEditorBindable
public MapSettingsSectionCtrl()
+ const string META_START = "<MapDescription>";
+ const string META_END = "</MapDescription>";
+ private IEditorService _service;
+ _service = service;
+ _service.RegisterCustomNotifier(this);
+ var b = new Binding("Text", _map, "Metadata");
+ b.Parse += (sender, e) =>
+ e.Value = META_START + e.Value + META_END;
+ b.Format += (sender, e) =>
+ var str = e.Value.ToString();
+ if (str.StartsWith(META_START) && str.EndsWith(META_END))
+ e.Value = str.Substring(META_START.Length, str.Length - (META_START.Length + META_END.Length));
+ txtDescription.DataBindings.Add(b);
+ txtCoordinateSystem.DataBindings.Add("Text", _map, "CoordinateSystem");
+ //TODO: Find proper binding target
+ cmbBackgroundColor.DataBindings.Add("Tag", _map, "BackgroundColor");
+ txtLowerX.DataBindings.Add("Text", _map.Extents, "MinX");
+ txtLowerY.DataBindings.Add("Text", _map.Extents, "MinY");
+ txtUpperX.DataBindings.Add("Text", _map.Extents, "MaxX");
+ txtUpperY.DataBindings.Add("Text", _map.Extents, "MaxY");
+ _map.Extents.PropertyChanged += (sender, e) => { OnResourceChanged(); };
+ private void OnResourceChanged()
+ var handler = this.ResourceChanged;
+ if (handler != null)
+ handler(this, EventArgs.Empty);
+ private void btnPickCs_Click(object sender, EventArgs e)
+ string cs = _service.GetCoordinateSystem();
+ if (!string.IsNullOrEmpty(cs))
+ txtCoordinateSystem.Text = cs;
+ //HACK: Force the binding to update
+ //http://stackoverflow.com/questions/1060080/databound-winforms-control-does-not-recognize-change-until-losing-focus
+ txtCoordinateSystem.DataBindings[0].WriteValue();
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ResourceTypeRegistry.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ResourceTypeRegistry.cs 2010-07-07 08:23:07 UTC (rev 5000)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ResourceTypeRegistry.cs 2010-07-07 09:30:03 UTC (rev 5001)
@@ -35,6 +35,7 @@
using System.Xml;
using OSGeo.MapGuide.MaestroAPI.ObjectModels;
using OSGeo.MapGuide.ObjectModels.FeatureSource;
+using OSGeo.MapGuide.ObjectModels.MapDefinition;
namespace OSGeo.MapGuide.MaestroAPI
@@ -101,6 +102,15 @@
Deserialize = (xml) => { return LoadProcedure.Deserialize(xml); }
+ //MapDefinition 1.0.0
+ _serializers.Add(
+ ResourceTypeDescriptor.MapDefinition,
+ new ResourceSerializer()
+ Serialize = (res) => { return res.SerializeToStream(); },
+ Deserialize = (xml) => { return MapDefinition.Deserialize(xml); }
//PrintLayout 1.0.0
_serializers.Add(
ResourceTypeDescriptor.PrintLayout,
More information about the mapguide-commits
