[mapguide-commits] r5006 - trunk/MgDev/Common/PlatformBase/Services
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu Jul 8 03:43:01 EDT 2010
Author: leaf
Date: 2010-07-08 07:43:01 +0000 (Thu, 08 Jul 2010)
New Revision: 5006
   trunk/MgDev/Common/PlatformBase/Services/FeatureQueryOptions.h
Ticket# 1395: Method MgFeatureQueryOptions::SetFetchSize(...) isn't exposed in MapGudie Web API
When implementing MapGuide RFC 84 (http://trac.osgeo.org/mapguide/wiki/MapGuideRfc84), method MgFeatureQueryOptions::SetFetchSize(INT32 fetchSize) is decorated by INTERNAL_API so that it will not be exposed in MapGuide Web API because we don't have enough time to test it. Now I modify it to PUBLISHED_API so that it can be used in MapGuide Web API.
Modified: trunk/MgDev/Common/PlatformBase/Services/FeatureQueryOptions.h
--- trunk/MgDev/Common/PlatformBase/Services/FeatureQueryOptions.h	2010-07-08 04:17:53 UTC (rev 5005)
+++ trunk/MgDev/Common/PlatformBase/Services/FeatureQueryOptions.h	2010-07-08 07:43:01 UTC (rev 5006)
@@ -455,33 +455,6 @@
     void RemoveComputedProperty(CREFSTRING aliasName);
-INTERNAL_API:
-    virtual ~MgFeatureQueryOptions();
-    MgStringCollection* GetClassProperties();
-    MgStringPropertyCollection* GetComputedProperties();
-    MgStringCollection* GetOrderingProperties();
-    STRING GetFilter();
-    bool GetBinaryOperator();
-    STRING GetGeometryProperty();
-    MgGeometry* GetGeometry();
-    INT32 GetOrderOption();
-    INT32 GetSpatialOperation();
-    INT32 GetFetchSize();
-    virtual void Serialize(MgStream* stream);
-    virtual void Deserialize(MgStream* stream);
-    STRING GetLogString();
-    virtual INT32 GetClassId() { return m_cls_id; }
-    virtual void Dispose() { delete this; }
-    void ValidateEmptyArgument(CREFSTRING value);
     /// \brief
     /// For queries that return a large number of objects
@@ -512,6 +485,33 @@
     void SetFetchSize(INT32 fetchSize);
+INTERNAL_API:
+    virtual ~MgFeatureQueryOptions();
+    MgStringCollection* GetClassProperties();
+    MgStringPropertyCollection* GetComputedProperties();
+    MgStringCollection* GetOrderingProperties();
+    STRING GetFilter();
+    bool GetBinaryOperator();
+    STRING GetGeometryProperty();
+    MgGeometry* GetGeometry();
+    INT32 GetOrderOption();
+    INT32 GetSpatialOperation();
+    INT32 GetFetchSize();
+    virtual void Serialize(MgStream* stream);
+    virtual void Deserialize(MgStream* stream);
+    STRING GetLogString();
+    virtual INT32 GetClassId() { return m_cls_id; }
+    virtual void Dispose() { delete this; }
+    void ValidateEmptyArgument(CREFSTRING value);
 private:
     STRING m_filterText;                                  // Where Clause
More information about the mapguide-commits mailing list
