[mapguide-commits] r5010 - in sandbox/adsk/2.2gp:
Common/MapGuideCommon/System Web/src/ApacheAgent
Web/src/CgiAgent Web/src/HttpHandler Web/src/IsapiAgent
Web/src/MapAgentCommon Web/src/WebSupport
svn_mapguide at osgeo.org
Thu Jul 8 12:32:10 EDT 2010
Author: brucedechant
Date: 2010-07-08 16:32:10 +0000 (Thu, 08 Jul 2010)
New Revision: 5010
sandbox/adsk/2.2gp/Common/MapGuideCommon/System/ConfigProperties.cpp
sandbox/adsk/2.2gp/Common/MapGuideCommon/System/ConfigProperties.h
sandbox/adsk/2.2gp/Web/src/ApacheAgent/ApacheAgent.cpp
sandbox/adsk/2.2gp/Web/src/CgiAgent/CgiAgent.cpp
sandbox/adsk/2.2gp/Web/src/HttpHandler/HttpUtil.cpp
sandbox/adsk/2.2gp/Web/src/HttpHandler/HttpUtil.h
sandbox/adsk/2.2gp/Web/src/IsapiAgent/IsapiAgent.cpp
sandbox/adsk/2.2gp/Web/src/MapAgentCommon/MapAgentCommon.cpp
sandbox/adsk/2.2gp/Web/src/MapAgentCommon/MapAgentCommon.h
sandbox/adsk/2.2gp/Web/src/WebSupport/InitializeWebTier.cpp
Fix for trac ticket 1337 - Web tier logging
http://trac.osgeo.org/mapguide/ticket/1337
Notes:
- Add web tier logging
Modified: sandbox/adsk/2.2gp/Common/MapGuideCommon/System/ConfigProperties.cpp
--- sandbox/adsk/2.2gp/Common/MapGuideCommon/System/ConfigProperties.cpp 2010-07-08 16:31:12 UTC (rev 5009)
+++ sandbox/adsk/2.2gp/Common/MapGuideCommon/System/ConfigProperties.cpp 2010-07-08 16:32:10 UTC (rev 5010)
@@ -481,6 +481,14 @@
const STRING MgConfigProperties::AgentDisableAuthoring = L"DisableAuthoring";
const STRING MgConfigProperties::AgentDisableWfs = L"DisableWfs";
const STRING MgConfigProperties::AgentDisableWms = L"DisableWms";
+const STRING MgConfigProperties::AgentErrorLogEnabled = L"ErrorLogEnabled";
+const bool MgConfigProperties::DefaultAgentErrorLogEnabled = false;
+const STRING MgConfigProperties::AgentErrorLogFilename = L"ErrorLogFilename";
+const STRING MgConfigProperties::DefaultAgentErrorLogFilename = L"Error.log";
+const STRING MgConfigProperties::AgentRequestLogEnabled = L"RequestLogEnabled";
+const bool MgConfigProperties::DefaultAgentRequestLogEnabled = false;
+const STRING MgConfigProperties::AgentRequestLogFilename = L"RequestLogFilename";
+const STRING MgConfigProperties::DefaultAgentRequestLogFilename = L"Request.log";
// OGC Properties
@@ -723,6 +731,10 @@
{ MgConfigProperties::AgentDisableAuthoring , MgPropertyType::Boolean , 0 , 1 , L"" },
{ MgConfigProperties::AgentDisableWfs , MgPropertyType::Boolean , 0 , 1 , L"" },
{ MgConfigProperties::AgentDisableWms , MgPropertyType::Boolean , 0 , 1 , L"" },
+ { MgConfigProperties::AgentErrorLogEnabled , MgPropertyType::Boolean , 0 , 1 , L"" },
+ { MgConfigProperties::AgentErrorLogFilename , MgPropertyType::String , MG_CONFIG_MIN_FILE_NAME_LENGTH , MG_CONFIG_MAX_FILE_NAME_LENGTH , MG_CONFIG_FILE_NAME_RESERVED_CHARACTERS },
+ { MgConfigProperties::AgentRequestLogEnabled , MgPropertyType::Boolean , 0 , 1 , L"" },
+ { MgConfigProperties::AgentRequestLogFilename , MgPropertyType::String , MG_CONFIG_MIN_FILE_NAME_LENGTH , MG_CONFIG_MAX_FILE_NAME_LENGTH , MG_CONFIG_FILE_NAME_RESERVED_CHARACTERS },
{ L"" , 0 , 0.0 , 0.0 , L"" }
Modified: sandbox/adsk/2.2gp/Common/MapGuideCommon/System/ConfigProperties.h
--- sandbox/adsk/2.2gp/Common/MapGuideCommon/System/ConfigProperties.h 2010-07-08 16:31:12 UTC (rev 5009)
+++ sandbox/adsk/2.2gp/Common/MapGuideCommon/System/ConfigProperties.h 2010-07-08 16:32:10 UTC (rev 5010)
@@ -828,6 +828,22 @@
/// Disables Http operations used for OGC Wms
static const STRING AgentDisableWms; /// value("DisableWms")
+ /// Agent error log enabled
+ static const STRING AgentErrorLogEnabled; /// value("ErrorLogEnabled")
+ static const bool DefaultAgentErrorLogEnabled; /// value(false)
+ /// Agent error log filename
+ static const STRING AgentErrorLogFilename; /// value("ErrorLogFilename")
+ static const STRING DefaultAgentErrorLogFilename; /// value("Error.log")
+ /// Agent request log enabled
+ static const STRING AgentRequestLogEnabled; /// value("RequestLogEnabled")
+ static const bool DefaultAgentRequestLogEnabled; /// value(false)
+ static const STRING AgentRequestLogFilename; /// value("RequestLogFilename")
+ static const STRING DefaultAgentRequestLogFilename; /// value("Request.log")
/// OGC PROPERTIES SECTION -------------------------------------------------------------------------------------------
/// Ogc properties
Modified: sandbox/adsk/2.2gp/Web/src/ApacheAgent/ApacheAgent.cpp
--- sandbox/adsk/2.2gp/Web/src/ApacheAgent/ApacheAgent.cpp 2010-07-08 16:31:12 UTC (rev 5009)
+++ sandbox/adsk/2.2gp/Web/src/ApacheAgent/ApacheAgent.cpp 2010-07-08 16:32:10 UTC (rev 5010)
@@ -155,24 +155,25 @@
// check for CLIENTIP, if it's not there (and it shouldn't be),
// add it in using httpClientIp. httpXFF or remoteAddr
+ STRING clientIp = L"";
if (!params->ContainsParameter(L"CLIENTIP")) // NOXLATE
if (!httpClientIp.empty()
&& _stricmp(httpClientIp.c_str(), MapAgentStrings::Unknown) != 0)
- STRING wHttpClientIp = MgUtil::MultiByteToWideChar(httpClientIp);
- params->AddParameter(L"CLIENTIP", wHttpClientIp); // NOXLATE
+ clientIp = MgUtil::MultiByteToWideChar(httpClientIp);
+ params->AddParameter(L"CLIENTIP", clientIp); // NOXLATE
else if (!httpXFF.empty()
&& _stricmp(httpXFF.c_str(), MapAgentStrings::Unknown) != 0)
- STRING wHttpXFF = MgUtil::MultiByteToWideChar(httpXFF);
- params->AddParameter(L"CLIENTIP", wHttpXFF); // NOXLATE
+ clientIp = MgUtil::MultiByteToWideChar(httpXFF);
else if (!remoteAddr.empty())
- STRING wRemoteAddr = MgUtil::MultiByteToWideChar(remoteAddr);
- params->AddParameter(L"CLIENTIP", wRemoteAddr); // NOXLATE
+ clientIp = MgUtil::MultiByteToWideChar(remoteAddr);
@@ -187,6 +188,17 @@
gotAuth = MapAgentCommon::ParseAuth((char *)auth.c_str(), params);
+ // Log request information
+ string postData = "";
+ if (!requestMethod.empty() && requestMethod.find("POST") != string::npos) // NOXLATE
+ // Get the post xml data
+ postData = params->GetXmlPostData();
+ STRING client = params->GetParameterValue(MgHttpResourceStrings::reqClientAgent);
+ MapAgentCommon::LogRequest(client, clientIp, url, requestMethod, postData, query);
Ptr<MgPropertyCollection> paramList = params->GetParameters()->GetPropertyCollection();
if (paramList != NULL)
Modified: sandbox/adsk/2.2gp/Web/src/CgiAgent/CgiAgent.cpp
--- sandbox/adsk/2.2gp/Web/src/CgiAgent/CgiAgent.cpp 2010-07-08 16:31:12 UTC (rev 5009)
+++ sandbox/adsk/2.2gp/Web/src/CgiAgent/CgiAgent.cpp 2010-07-08 16:32:10 UTC (rev 5010)
@@ -52,6 +52,7 @@
bool ParseAuth(char* AuthString, MgHttpRequestParam* params);
bool AuthenticateOgcRequest(MgHttpRequestParam* params);
+void LogRequest(CREFSTRING client, CREFSTRING clientIp, std::string &url, std::string &requestMethod, std::string &postData, std::string &query);
// Forward declare Web Tier initialization routine
void Initialize();
@@ -165,24 +166,25 @@
if (NULL != httpClientIp && strlen(httpClientIp) > 0
&& _stricmp(httpClientIp, MapAgentStrings::Unknown) != 0)
else if (NULL != httpXFF && strlen(httpXFF) > 0
&& _stricmp(httpXFF, MapAgentStrings::Unknown) != 0)
else if (NULL != remoteAddr && strlen(remoteAddr) > 0)
@@ -197,6 +199,19 @@
gotAuth = ParseAuth(auth, params);
+ if (requestMethod && _stricmp(requestMethod, "POST") == 0) // NOXLATE
+ string strRequestMethod= std::string(requestMethod);
+ string strQuery = std::string(query);
+ LogRequest(client, clientIp, url, strRequestMethod, postData, strQuery);
@@ -477,3 +492,54 @@
#endif
+ ACE_MT (ACE_GUARD(ACE_Recursive_Thread_Mutex, ace_mon, *ACE_Static_Object_Lock::instance()));
+ static INT32 requestId = 1;
+ MgConfiguration* cfg = MgConfiguration::GetInstance();
+ // Is log enabled?
+ bool bLogEnabled = false;
+ cfg->GetBoolValue(MgConfigProperties::AgentPropertiesSection, MgConfigProperties::AgentRequestLogEnabled, bLogEnabled, MgConfigProperties::DefaultAgentRequestLogEnabled);
+ if(bLogEnabled)
+ // Get the logs path
+ STRING path = L"";
+ cfg->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyLogsPath, path, MgConfigProperties::DefaultGeneralPropertyLogsPath);
+ // Check if path ends with a '/' if not, add one if needed
+ MgFileUtil::AppendSlashToEndOfPath(path);
+ STRING filename = L"";
+ cfg->GetStringValue(MgConfigProperties::AgentPropertiesSection, MgConfigProperties::AgentRequestLogFilename, filename, MgConfigProperties::DefaultAgentRequestLogFilename);
+ filename = path + filename;
+ FILE* fp = ACE_OS::fopen(MG_WCHAR_TO_TCHAR(filename), ACE_TEXT("a+"));
+ if (fp)
+ MgDateTime currentTime;
+ STRING strCurrentTime = currentTime.ToXmlString(false);
+ ACE_OS::fprintf(fp, ACE_TEXT("<%s> %d\t%s\t%s\t%s\t%s\n"), MG_WCHAR_TO_TCHAR(strCurrentTime), requestId, MG_WCHAR_TO_TCHAR(client), MG_WCHAR_TO_TCHAR(clientIp), MG_WCHAR_TO_TCHAR(MgUtil::MultiByteToWideChar(requestMethod)), MG_WCHAR_TO_TCHAR(MgUtil::MultiByteToWideChar(url)));
+ if (!postData.empty()) // NOXLATE
+ ACE_OS::fprintf(fp, ACE_TEXT(" Postdata: %s\n"), MG_WCHAR_TO_TCHAR(MgUtil::MultiByteToWideChar(postData)));
+ if (!query.empty())
+ ACE_OS::fprintf(fp, ACE_TEXT(" Query : %s\n"), MG_WCHAR_TO_TCHAR(MgUtil::MultiByteToWideChar(query)));
+ ACE_OS::fclose(fp);
+ // Increment the request Id
+ requestId++;
Modified: sandbox/adsk/2.2gp/Web/src/HttpHandler/HttpUtil.cpp
--- sandbox/adsk/2.2gp/Web/src/HttpHandler/HttpUtil.cpp 2010-07-08 16:31:12 UTC (rev 5009)
+++ sandbox/adsk/2.2gp/Web/src/HttpHandler/HttpUtil.cpp 2010-07-08 16:32:10 UTC (rev 5010)
@@ -17,3 +17,72 @@
#include "HttpHandler.h"
#include "HttpUtil.h"
+void MgHttpUtil::LogException(MgException* exception)
+ if(NULL != exception)
+ cfg->GetBoolValue(MgConfigProperties::AgentPropertiesSection, MgConfigProperties::AgentErrorLogEnabled, bLogEnabled, MgConfigProperties::DefaultAgentErrorLogEnabled);
+ if(bLogEnabled)
+ cfg->GetStringValue(MgConfigProperties::AgentPropertiesSection, MgConfigProperties::AgentErrorLogFilename, filename, MgConfigProperties::DefaultAgentErrorLogFilename);
+ if (fp)
+ STRING message = exception->GetExceptionMessage();
+ STRING stackTrace = exception->GetStackTrace();
+ ACE_OS::fprintf(fp, ACE_TEXT("<%s>\n"), MG_WCHAR_TO_TCHAR(strCurrentTime));
+ ACE_OS::fprintf(fp, ACE_TEXT(" Error: %s\n"), MG_WCHAR_TO_TCHAR(message));
+ // Add the stack trace
+ // Do not log empty stack traces
+ if (!stackTrace.empty())
+ STRING entry = L"";
+ entry += L" " + MgResources::StackTrace + L":";
+ size_t size = stackTrace.size();
+ if (size > 0)
+ STRING trace = stackTrace.c_str();
+ // Get rid of extra \n at the end of the stack trace
+ if (trace[size-1] == L'\n')
+ trace.erase((size-1), 1);
+ // Make it look "pretty"
+ trace = MgUtil::ReplaceString(trace, L"\n", L"\n ");
+ entry += L"\n " + trace + L"\n";
+ ACE_OS::fprintf(fp, ACE_TEXT("%s"), MG_WCHAR_TO_TCHAR(entry));
Modified: sandbox/adsk/2.2gp/Web/src/HttpHandler/HttpUtil.h
--- sandbox/adsk/2.2gp/Web/src/HttpHandler/HttpUtil.h 2010-07-08 16:31:12 UTC (rev 5009)
+++ sandbox/adsk/2.2gp/Web/src/HttpHandler/HttpUtil.h 2010-07-08 16:32:10 UTC (rev 5010)
@@ -25,15 +25,20 @@
#define MG_HTTP_HANDLER_CATCH(methodName) \
MG_CATCH(methodName) \
+ MgHttpUtil::LogException(mgException); \
#define MG_HTTP_HANDLER_THROW() \
MG_THROW() \
#define MG_HTTP_HANDLER_CATCH_AND_THROW(methodName) \
- MG_CATCH_AND_THROW(methodName) \
+ MG_CATCH(methodName) \
+ MG_THROW() \
#define MG_HTTP_HANDLER_CATCH_AND_THROW_EX(methodName) \
if (mgException != NULL) \
@@ -48,6 +53,7 @@
#define MG_HTTP_HANDLER_CATCH_AND_THROW_EX2(methodName, hResult, hRequest) \
@@ -60,4 +66,13 @@
mgException->Raise(); \
+class MgHttpUtil
+public:
+ MgHttpUtil();
+ ~MgHttpUtil();
+ static void LogException(MgException* exception);
#endif
Modified: sandbox/adsk/2.2gp/Web/src/IsapiAgent/IsapiAgent.cpp
--- sandbox/adsk/2.2gp/Web/src/IsapiAgent/IsapiAgent.cpp 2010-07-08 16:31:12 UTC (rev 5009)
+++ sandbox/adsk/2.2gp/Web/src/IsapiAgent/IsapiAgent.cpp 2010-07-08 16:32:10 UTC (rev 5010)
@@ -119,24 +119,25 @@
if (bHttpClientIp && NULL != httpClientIp && strlen(httpClientIp) > 0
else if (bHttpXFF && NULL != httpXFF && strlen(httpXFF) > 0
else if (bRemoteAddr && NULL != remoteAddr && strlen(remoteAddr) > 0)
@@ -154,6 +155,17 @@
gotAuth = MapAgentCommon::ParseAuth(auth, params);
+ MapAgentCommon::LogRequest(client, clientIp, url, std::string(requestMethod), postData, std::string(query));
Modified: sandbox/adsk/2.2gp/Web/src/MapAgentCommon/MapAgentCommon.cpp
--- sandbox/adsk/2.2gp/Web/src/MapAgentCommon/MapAgentCommon.cpp 2010-07-08 16:31:12 UTC (rev 5009)
+++ sandbox/adsk/2.2gp/Web/src/MapAgentCommon/MapAgentCommon.cpp 2010-07-08 16:32:10 UTC (rev 5010)
@@ -287,3 +287,54 @@
+void MapAgentCommon::LogRequest(CREFSTRING client, CREFSTRING clientIp, std::string &url, std::string &requestMethod, std::string &postData, std::string &query)
+ if(bLogEnabled)
+ if (fp)
+ requestId++;
Modified: sandbox/adsk/2.2gp/Web/src/MapAgentCommon/MapAgentCommon.h
--- sandbox/adsk/2.2gp/Web/src/MapAgentCommon/MapAgentCommon.h 2010-07-08 16:31:12 UTC (rev 5009)
+++ sandbox/adsk/2.2gp/Web/src/MapAgentCommon/MapAgentCommon.h 2010-07-08 16:32:10 UTC (rev 5010)
@@ -37,6 +37,7 @@
STRING& paramName, STRING& paramType, MgHttpRequestParam* params, bool& bIsFile);
static void DeleteTempFiles(MgHttpRequestParam* params);
+ static void LogRequest(CREFSTRING client, CREFSTRING clientIp, std::string &url, std::string &requestMethod, std::string &postData, std::string &query);
#endif
Modified: sandbox/adsk/2.2gp/Web/src/WebSupport/InitializeWebTier.cpp
--- sandbox/adsk/2.2gp/Web/src/WebSupport/InitializeWebTier.cpp 2010-07-08 16:31:12 UTC (rev 5009)
+++ sandbox/adsk/2.2gp/Web/src/WebSupport/InitializeWebTier.cpp 2010-07-08 16:32:10 UTC (rev 5010)
@@ -51,6 +51,16 @@
resources->Initialize(resourcesPath);
resources->LoadResources(locale);
+ config->GetStringValue(MgConfigProperties::GeneralPropertiesSection, MgConfigProperties::GeneralPropertyLogsPath, path, MgConfigProperties::DefaultGeneralPropertyLogsPath);
+ // Try and create the directory. If it already exists this will error and not a problem
+ ACE_OS::mkdir(MG_WCHAR_TO_TCHAR(path));
m_bInitialized = true;
More information about the mapguide-commits
