[mapguide-commits] r5026 - in
trunk/Tools/Maestro/Maestro/ResourceValidators: . Strings
svn_mapguide at osgeo.org
Mon Jul 12 02:56:18 EDT 2010
Author: jng
Date: 2010-07-12 06:56:18 +0000 (Mon, 12 Jul 2010)
New Revision: 5026
trunk/Tools/Maestro/Maestro/ResourceValidators/FeatureSourceValidator.cs
trunk/Tools/Maestro/Maestro/ResourceValidators/Strings/FeatureSourceValidator.Designer.cs
trunk/Tools/Maestro/Maestro/ResourceValidators/Strings/FeatureSourceValidator.resx
Fix #1401: The problem is simply the server-side will *never* return an empty array for the GETIDENTITYPROPERTIES call. It will throw a MgClassNotFoundException for classes without identity properties, which I believe is incorrect. Nevertheless, I've updated the Feature Source validation to handle this scenario.
Modified: trunk/Tools/Maestro/Maestro/ResourceValidators/FeatureSourceValidator.cs
--- trunk/Tools/Maestro/Maestro/ResourceValidators/FeatureSourceValidator.cs 2010-07-12 02:23:54 UTC (rev 5025)
+++ trunk/Tools/Maestro/Maestro/ResourceValidators/FeatureSourceValidator.cs 2010-07-12 06:56:18 UTC (rev 5026)
@@ -83,13 +83,24 @@
try
string[] ids = feature.GetIdentityProperties(cl);
+ //According to my tests, this code path never gets reached because the
+ //MG server will incorrectly throw MgClassNotFoundException when querying
+ //a class with no identity properties. Nevertheless we'll leave this in, if/when
+ //this logic is fixed server-side.
if (ids == null || ids.Length == 0)
issues.Add(new ValidationIssue(feature, ValidationStatus.Information, string.Format(Strings.FeatureSourceValidator.PrimaryKeyMissingInformation, cl)));
catch (Exception ex)
string msg = NestedExceptionMessageProcessor.GetFullMessage(ex);
- issues.Add(new ValidationIssue(feature, ValidationStatus.Error, string.Format(Strings.FeatureSourceValidator.PrimaryKeyReadError, msg)));
+ if (msg.IndexOf("MgClassNotFoundException") >= 0)
+ issues.Add(new ValidationIssue(feature, ValidationStatus.Warning, string.Format(Strings.FeatureSourceValidator.NoPrimaryKeyOrView, cl)));
+ else
+ issues.Add(new ValidationIssue(feature, ValidationStatus.Error, string.Format(Strings.FeatureSourceValidator.PrimaryKeyReadError, msg)));
Modified: trunk/Tools/Maestro/Maestro/ResourceValidators/Strings/FeatureSourceValidator.Designer.cs
--- trunk/Tools/Maestro/Maestro/ResourceValidators/Strings/FeatureSourceValidator.Designer.cs 2010-07-12 02:23:54 UTC (rev 5025)
+++ trunk/Tools/Maestro/Maestro/ResourceValidators/Strings/FeatureSourceValidator.Designer.cs 2010-07-12 06:56:18 UTC (rev 5026)
@@ -79,6 +79,15 @@
/// <summary>
+ /// Looks up a localized string similar to Could not obtain identity properties for {0}. This class either has no identity properties and/or is derived from a view with no uniquely identifiable columns. Attempting to create feature joins from this class may produce unexpected results..
+ /// </summary>
+ internal static string NoPrimaryKeyOrView {
+ get {
+ return ResourceManager.GetString("NoPrimaryKeyOrView", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to No spatial contexts found.
/// </summary>
internal static string NoSpatialContextWarning {
Modified: trunk/Tools/Maestro/Maestro/ResourceValidators/Strings/FeatureSourceValidator.resx
--- trunk/Tools/Maestro/Maestro/ResourceValidators/Strings/FeatureSourceValidator.resx 2010-07-12 02:23:54 UTC (rev 5025)
+++ trunk/Tools/Maestro/Maestro/ResourceValidators/Strings/FeatureSourceValidator.resx 2010-07-12 06:56:18 UTC (rev 5026)
@@ -125,6 +125,10 @@
<value>Empty spatial context extent detected</value>
<comment>A warning message that is displayed when the spatial context is empty</comment>
</data>
+ <data name="NoPrimaryKeyOrView" xml:space="preserve">
+ <value>Could not obtain identity properties for {0}. This class either has no identity properties and/or is derived from a view with no uniquely identifiable columns. Attempting to create feature joins from this class may produce unexpected results.</value>
+ <comment>A warning message that is displayed when we can't obtain identity properties from a class because it is a view</comment>
+ </data>
<data name="NoSpatialContextWarning" xml:space="preserve">
<value>No spatial contexts found</value>
<comment>A warning message that is displayed when the featuresource fails to report its spatial context</comment>
More information about the mapguide-commits
