[mapguide-commits] r5033 - in trunk/Installer: Installers/MapGuide Libraries/MapGuide Web Extensions
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Fri Jul 16 06:03:45 EDT 2010
Author: jng
Date: 2010-07-16 10:03:44 +0000 (Fri, 16 Jul 2010)
New Revision: 5033
   trunk/Installer/Installers/MapGuide/MapGuide.wxs
   trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs
This submission includes the following changes:
 - #1062: Set Application Pool to 32-bit for IIS7. This only applies when running an x86 installer on 64-bit windows.
 - #1388: Set mandatory reboot for IIS configuration on 64-bit windows. A reboot is required to resolve this issue. Alternatively, users who do not wish to reboot can use IIS environment variable overrides to have a functional MG installation without rebooting (http://www.teachout.com/Blog/tabid/165/EntryId/246/Windows-Environment-Variables-Overrides-for-IIS6.aspx)
Modified: trunk/Installer/Installers/MapGuide/MapGuide.wxs
--- trunk/Installer/Installers/MapGuide/MapGuide.wxs	2010-07-15 21:47:04 UTC (rev 5032)
+++ trunk/Installer/Installers/MapGuide/MapGuide.wxs	2010-07-16 10:03:44 UTC (rev 5033)
@@ -607,7 +607,14 @@
           <!-- IIS7 Base deferred CAs -->
             <Custom Action="MapGuideIIS7_I_CreateAppPool" After="InstallFiles">MGWEB_CONFIG=&quot;IIS&quot; AND IISVERSIONMAJOR=&quot;#7&quot; AND &amp;WebExtensionsFeature&gt;2</Custom>
             <Custom Action="MapGuideIIS7_I_SetAppPoolProp" After="MapGuideIIS7_I_CreateAppPool">MGWEB_CONFIG=&quot;IIS&quot; AND IISVERSIONMAJOR=&quot;#7&quot; AND &amp;WebExtensionsFeature&gt;2</Custom>
+            <?if "$(var.MgPlatform)" = "x64" ?>
             <Custom Action="MapGuideIIS7_I_UnlockSrvHandlers" After="MapGuideIIS7_I_SetAppPoolProp">MGWEB_CONFIG=&quot;IIS&quot; AND IISVERSIONMAJOR=&quot;#7&quot; AND &amp;WebExtensionsFeature&gt;2</Custom>
+            <?else ?>
+            <Custom Action="MapGuideIIS7_I_Set32BitAppPool" After="MapGuideIIS7_I_SetAppPoolProp">MGWEB_CONFIG=&quot;IIS&quot; AND IISVERSIONMAJOR=&quot;#7&quot; AND &amp;WebExtensionsFeature&gt;2</Custom>
+            <Custom Action="MapGuideIIS7_I_UnlockSrvHandlers" After="MapGuideIIS7_I_Set32BitAppPool">MGWEB_CONFIG=&quot;IIS&quot; AND IISVERSIONMAJOR=&quot;#7&quot; AND &amp;WebExtensionsFeature&gt;2</Custom>
+            <?endif ?>
             <Custom Action="MapGuideIIS7_I_UnlockSiteHandlers" After="MapGuideIIS7_I_UnlockSrvHandlers">MGWEB_CONFIG=&quot;IIS&quot; AND IISVERSIONMAJOR=&quot;#7&quot; AND &amp;WebExtensionsFeature&gt;2</Custom>
             <Custom Action="MapGuideIIS7_I_CreateMapGuideApp" After="MapGuideIIS7_I_UnlockSiteHandlers">MGWEB_CONFIG=&quot;IIS&quot; AND IISVERSIONMAJOR=&quot;#7&quot; AND &amp;WebExtensionsFeature&gt;2</Custom>
             <Custom Action="MapGuideIIS7_I_CreatePhpScriptMapping" After="MapGuideIIS7_I_CreateMapGuideApp">MGWEB_CONFIG=&quot;IIS&quot; AND IISVERSIONMAJOR=&quot;#7&quot; AND &amp;WebExtensionsFeature&gt;2</Custom>
@@ -752,8 +759,27 @@
             <Custom
                 Action="RemoveApacheServiceCA"
                 Before="RemoveFiles">MGWEB_CONFIG=&quot;APACHE&quot; AND &amp;WebExtApacheFeature=2</Custom>
-            <!-- 502 = Windows Server 2003 -->
-            <ScheduleReboot After="InstallFinalize">VersionNT&lt;502 AND NOT Installed AND &amp;CSMapFeature&gt;2</ScheduleReboot>
+            64-bit IIS requires a machine reboot in order for MENTOR_DICTIONARY_PATH to be picked up by the Web Extensions
+            You can technically avoid this reboot by using IIS environment variable overrides as described here:
+            http://www.teachout.com/Blog/tabid/165/EntryId/246/Windows-Environment-Variables-Overrides-for-IIS6.aspx
+            If you follow this approach, just say "no" at the reboot prompt.
+            Read the below condition as:
+            REBOOT if:
+                (("Configuration is IIS" AND "This is a 64-bit windows") OR ("Windows XP or older"))
+                AND "Not installed" AND "CS-Map is freshly installed"
+            The 64-bit condition is tested first before the "Windows XP or older" condition
+            502 is the VersionNT value for Windows Server 2003
+            <ScheduleReboot After="InstallFinalize">((VersionNT64 AND MGWEB_CONFIG=&quot;IIS&quot;) OR VersionNT&lt;502) AND NOT Installed AND &amp;CSMapFeature&gt;2</ScheduleReboot>
         </InstallExecuteSequence>
     </Product>
 </Wix>
Modified: trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs
--- trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs	2010-07-15 21:47:04 UTC (rev 5032)
+++ trunk/Installer/Libraries/MapGuide Web Extensions/IIS7.wxs	2010-07-16 10:03:44 UTC (rev 5033)
@@ -65,6 +65,11 @@
         Value="[AppCmd] set config /section:isapiCgiRestriction /+[\[]path='&quot;[WEBEXTENSIONSLOCATION]www\mapagent\isapi_MapAgent.dll&quot;',allowed='True',description='&quot;MapGuide MapAgent ISAPI handler&quot;'[\]]" />
     <CustomAction Id="MapGuideIIS7_I_EnableMapAgentExtension" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no"/>
+    <!-- Set App Pool to 32-bit mode (applies to 64-bit windows) -->
+    <CustomAction Id="MapGuideIIS7_I_Set32BitAppPool_Cmd" Property="MapGuideIIS7_I_Set32BitAppPool" Execute="immediate"
+        Value="[AppCmd] apppool set /apppool.name:&quot;[APP_POOL_NAME]&quot; /enable32BitAppOnWin64:true" />
+    <CustomAction Id="MapGuideIIS7_I_Set32BitAppPool" BinaryKey="WixCA" DllEntry="CAQuietExec" Execute="deferred" Return="ignore" Impersonate="no" />
     <!-- Make the MapGuide application run in the MapGuide app pool -->
     <CustomAction Id="MapGuideIIS7_I_AssignMapGuideAppPool_Cmd" Property="MapGuideIIS7_I_AssignMapGuideAppPool" Execute="immediate"
         Value="[AppCmd] set app &quot;[MG_WEBSITE]/[VIRTUALDIR]&quot; /applicationPool:&quot;[APP_POOL_NAME]&quot;" />
More information about the mapguide-commits mailing list
